[U-Boot] [PATCH v2 0/3] EXYNOS: Add support for Exynos4x12
This patch series popultes Register addresses, clock structure and gpio structure for Exynos4x12.
Changes in v2: - Fixed the GPIO base address macro for exynos4x12_gpio_part3_get_nr in arch/arm/include/asm/arch-exynos/gpio.h Chander Kashyap (3): EXYNOS: EXYNOS4X12: Populate Exynos4x12 register addresses EXYNOS: EXYNOS4X12: Add clock structure for EXYNOS4X12 EXYNOS: EXYNOS4X12: Add gpio structure for EXYNOS4X12
arch/arm/include/asm/arch-exynos/clock.h | 276 ++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-exynos/cpu.h | 48 +++++- arch/arm/include/asm/arch-exynos/gpio.h | 85 +++++++++ 3 files changed, 402 insertions(+), 7 deletions(-)
This patch populates base addresses of Exynos4x12 registers.
Signed-off-by: Chander Kashyap chander.kashyap@linaro.org --- arch/arm/include/asm/arch-exynos/cpu.h | 48 +++++++++++++++++++++++++++----- 1 file changed, 41 insertions(+), 7 deletions(-)
diff --git a/arch/arm/include/asm/arch-exynos/cpu.h b/arch/arm/include/asm/arch-exynos/cpu.h index 2bde10c..680b93b 100644 --- a/arch/arm/include/asm/arch-exynos/cpu.h +++ b/arch/arm/include/asm/arch-exynos/cpu.h @@ -27,7 +27,7 @@ #define EXYNOS_CPU_NAME "Exynos" #define EXYNOS4_ADDR_BASE 0x10000000
-/* EXYNOS4 */ +/* EXYNOS4 Common*/ #define EXYNOS4_GPIO_PART3_BASE 0x03860000 #define EXYNOS4_PRO_ID 0x10000000 #define EXYNOS4_SYSREG_BASE 0x10010000 @@ -58,7 +58,37 @@ #define EXYNOS4_GPIO_PART4_BASE DEVICE_NOT_AVAILABLE #define EXYNOS4_DP_BASE DEVICE_NOT_AVAILABLE
-/* EXYNOS5 */ +/* EXYNOS4X12 */ +#define EXYNOS4X12_GPIO_PART3_BASE 0x03860000 +#define EXYNOS4X12_PRO_ID 0x10000000 +#define EXYNOS4X12_SYSREG_BASE 0x10010000 +#define EXYNOS4X12_POWER_BASE 0x10020000 +#define EXYNOS4X12_SWRESET 0x10020400 +#define EXYNOS4X12_USBPHY_CONTROL 0x10020704 +#define EXYNOS4X12_CLOCK_BASE 0x10030000 +#define EXYNOS4X12_SYSTIMER_BASE 0x10050000 +#define EXYNOS4X12_WATCHDOG_BASE 0x10060000 +#define EXYNOS4X12_DMC0_BASE 0x10600000 +#define EXYNOS4X12_DMC1_BASE 0x10610000 +#define EXYNOS4X12_GPIO_PART4_BASE 0x106E0000 +#define EXYNOS4X12_GPIO_PART2_BASE 0x11000000 +#define EXYNOS4X12_GPIO_PART1_BASE 0x11400000 +#define EXYNOS4X12_FIMD_BASE 0x11C00000 +#define EXYNOS4X12_MIPI_DSIM_BASE 0x11C80000 +#define EXYNOS4X12_USBOTG_BASE 0x12480000 +#define EXYNOS4X12_MMC_BASE 0x12510000 +#define EXYNOS4X12_SROMC_BASE 0x12570000 +#define EXYNOS4X12_USB_HOST_EHCI_BASE 0x12580000 +#define EXYNOS4X12_USBPHY_BASE 0x125B0000 +#define EXYNOS4X12_UART_BASE 0x13800000 +#define EXYNOS4X12_I2C_BASE 0x13860000 +#define EXYNOS4X12_PWMTIMER_BASE 0x139D0000 + +#define EXYNOS4X12_ADC_BASE DEVICE_NOT_AVAILABLE +#define EXYNOS4X12_DP_BASE DEVICE_NOT_AVAILABLE +#define EXYNOS4X12_MODEM_BASE DEVICE_NOT_AVAILABLE + +/* EXYNOS5 Common*/ #define EXYNOS5_I2C_SPACING 0x10000
#define EXYNOS5_GPIO_PART4_BASE 0x03860000 @@ -146,17 +176,21 @@ static inline int proid_is_##type(void) \ }
IS_EXYNOS_TYPE(exynos4210, 0x4210) +IS_EXYNOS_TYPE(exynos4412, 0x4412) IS_EXYNOS_TYPE(exynos5250, 0x5250)
#define SAMSUNG_BASE(device, base) \ static inline unsigned int samsung_get_base_##device(void) \ { \ - if (cpu_is_exynos4()) \ - return EXYNOS4_##base; \ - else if (cpu_is_exynos5()) \ + if (cpu_is_exynos4()) { \ + if (proid_is_exynos4412()) \ + return EXYNOS4X12_##base; \ + else \ + return EXYNOS4_##base; \ + } else if (cpu_is_exynos5()) { \ return EXYNOS5_##base; \ - else \ - return 0; \ + } \ + return 0; \ }
SAMSUNG_BASE(adc, ADC_BASE)
This patch adds clock structure for Exynos4x12.
Signed-off-by: Chander Kashyap chander.kashyap@linaro.org --- arch/arm/include/asm/arch-exynos/clock.h | 276 ++++++++++++++++++++++++++++++ 1 file changed, 276 insertions(+)
diff --git a/arch/arm/include/asm/arch-exynos/clock.h b/arch/arm/include/asm/arch-exynos/clock.h index fce38ef..8492f4e 100644 --- a/arch/arm/include/asm/arch-exynos/clock.h +++ b/arch/arm/include/asm/arch-exynos/clock.h @@ -251,6 +251,282 @@ struct exynos4_clock { unsigned int div_iem_l1; };
+struct exynos4x12_clock { + unsigned char res1[0x4200]; + unsigned int src_leftbus; + unsigned char res2[0x1fc]; + unsigned int mux_stat_leftbus; + unsigned char res3[0xfc]; + unsigned int div_leftbus; + unsigned char res4[0xfc]; + unsigned int div_stat_leftbus; + unsigned char res5[0x1fc]; + unsigned int gate_ip_leftbus; + unsigned char res6[0x12c]; + unsigned int gate_ip_image; + unsigned char res7[0xcc]; + unsigned int clkout_leftbus; + unsigned int clkout_leftbus_div_stat; + unsigned char res8[0x37f8]; + unsigned int src_rightbus; + unsigned char res9[0x1fc]; + unsigned int mux_stat_rightbus; + unsigned char res10[0xfc]; + unsigned int div_rightbus; + unsigned char res11[0xfc]; + unsigned int div_stat_rightbus; + unsigned char res12[0x1fc]; + unsigned int gate_ip_rightbus; + unsigned char res13[0x15c]; + unsigned int gate_ip_perir; + unsigned char res14[0x9c]; + unsigned int clkout_rightbus; + unsigned int clkout_rightbus_div_stat; + unsigned char res15[0x3608]; + unsigned int epll_lock; + unsigned char res16[0xc]; + unsigned int vpll_lock; + unsigned char res17[0xec]; + unsigned int epll_con0; + unsigned int epll_con1; + unsigned int epll_con2; + unsigned char res18[0x4]; + unsigned int vpll_con0; + unsigned int vpll_con1; + unsigned int vpll_con2; + unsigned char res19[0xe4]; + unsigned int src_top0; + unsigned int src_top1; + unsigned char res20[0x8]; + unsigned int src_cam; + unsigned int src_tv; + unsigned int src_mfc; + unsigned int src_g3d; + unsigned char res21[0x4]; + unsigned int src_lcd; + unsigned int src_isp; + unsigned int src_maudio; + unsigned int src_fsys; + unsigned char res22[0xc]; + unsigned int src_peril0; + unsigned int src_peril1; + unsigned int src_cam1; + unsigned char res23[0xb4]; + unsigned int src_mask_top; + unsigned char res24[0xc]; + unsigned int src_mask_cam; + unsigned int src_mask_tv; + unsigned char res25[0xc]; + unsigned int src_mask_lcd; + unsigned int src_mask_isp; + unsigned int src_mask_maudio; + unsigned int src_mask_fsys; + unsigned char res26[0xc]; + unsigned int src_mask_peril0; + unsigned int src_mask_peril1; + unsigned char res27[0xb8]; + unsigned int mux_stat_top0; + unsigned int mux_stat_top1; + unsigned char res28[0x10]; + unsigned int mux_stat_mfc; + unsigned int mux_stat_g3d; + unsigned char res29[0x28]; + unsigned int mux_stat_cam1; + unsigned char res30[0xb4]; + unsigned int div_top; + unsigned char res31[0xc]; + unsigned int div_cam; + unsigned int div_tv; + unsigned int div_mfc; + unsigned int div_g3d; + unsigned char res32[0x4]; + unsigned int div_lcd; + unsigned int div_isp; + unsigned int div_maudio; + unsigned int div_fsys0; + unsigned int div_fsys1; + unsigned int div_fsys2; + unsigned int div_fsys3; + unsigned int div_peril0; + unsigned int div_peril1; + unsigned int div_peril2; + unsigned int div_peril3; + unsigned int div_peril4; + unsigned int div_peril5; + unsigned int div_cam1; + unsigned char res33[0x14]; + unsigned int div2_ratio; + unsigned char res34[0x8c]; + unsigned int div_stat_top; + unsigned char res35[0xc]; + unsigned int div_stat_cam; + unsigned int div_stat_tv; + unsigned int div_stat_mfc; + unsigned int div_stat_g3d; + unsigned char res36[0x4]; + unsigned int div_stat_lcd; + unsigned int div_stat_isp; + unsigned int div_stat_maudio; + unsigned int div_stat_fsys0; + unsigned int div_stat_fsys1; + unsigned int div_stat_fsys2; + unsigned int div_stat_fsys3; + unsigned int div_stat_peril0; + unsigned int div_stat_peril1; + unsigned int div_stat_peril2; + unsigned int div_stat_peril3; + unsigned int div_stat_peril4; + unsigned int div_stat_peril5; + unsigned int div_stat_cam1; + unsigned char res37[0x14]; + unsigned int div2_stat; + unsigned char res38[0x29c]; + unsigned int gate_ip_cam; + unsigned int gate_ip_tv; + unsigned int gate_ip_mfc; + unsigned int gate_ip_g3d; + unsigned char res39[0x4]; + unsigned int gate_ip_lcd; + unsigned int gate_ip_isp; + unsigned char res40[0x4]; + unsigned int gate_ip_fsys; + unsigned char res41[0x8]; + unsigned int gate_ip_gps; + unsigned int gate_ip_peril; + unsigned char res42[0xc]; + unsigned char res43[0x4]; + unsigned char res44[0xc]; + unsigned int gate_block; + unsigned char res45[0x8c]; + unsigned int clkout_cmu_top; + unsigned int clkout_cmu_top_div_stat; + unsigned char res46[0x3600]; + unsigned int mpll_lock; + unsigned char res47[0xfc]; + unsigned int mpll_con0; + unsigned int mpll_con1; + unsigned char res48[0xf0]; + unsigned int src_dmc; + unsigned char res49[0xfc]; + unsigned int src_mask_dmc; + unsigned char res50[0xfc]; + unsigned int mux_stat_dmc; + unsigned char res51[0xfc]; + unsigned int div_dmc0; + unsigned int div_dmc1; + unsigned char res52[0xf8]; + unsigned int div_stat_dmc0; + unsigned int div_stat_dmc1; + unsigned char res53[0xf8]; + unsigned int gate_bus_dmc0; + unsigned int gate_bus_dmc1; + unsigned char res54[0x1f8]; + unsigned int gate_ip_dmc0; + unsigned int gate_ip_dmc1; + unsigned char res55[0xf8]; + unsigned int clkout_cmu_dmc; + unsigned int clkout_cmu_dmc_div_stat; + unsigned char res56[0x5f8]; + unsigned int dcgidx_map0; + unsigned int dcgidx_map1; + unsigned int dcgidx_map2; + unsigned char res57[0x14]; + unsigned int dcgperf_map0; + unsigned int dcgperf_map1; + unsigned char res58[0x18]; + unsigned int dvcidx_map; + unsigned char res59[0x1c]; + unsigned int freq_cpu; + unsigned int freq_dpm; + unsigned char res60[0x18]; + unsigned int dvsemclk_en; + unsigned int maxperf; + unsigned char res61[0x8]; + unsigned int dmc_freq_ctrl; + unsigned int dmc_pause_ctrl; + unsigned int dddrphy_lock_ctrl; + unsigned int c2c_state; + unsigned char res62[0x2f60]; + unsigned int apll_lock; + unsigned char res63[0x8]; + unsigned char res64[0xf4]; + unsigned int apll_con0; + unsigned int apll_con1; + unsigned char res65[0xf8]; + unsigned int src_cpu; + unsigned char res66[0x1fc]; + unsigned int mux_stat_cpu; + unsigned char res67[0xfc]; + unsigned int div_cpu0; + unsigned int div_cpu1; + unsigned char res68[0xf8]; + unsigned int div_stat_cpu0; + unsigned int div_stat_cpu1; + unsigned char res69[0x2f8]; + unsigned int clk_gate_ip_cpu; + unsigned char res70[0xfc]; + unsigned int clkout_cmu_cpu; + unsigned int clkout_cmu_cpu_div_stat; + unsigned char res71[0x5f8]; + unsigned int armclk_stopctrl; + unsigned int atclk_stopctrl; + unsigned char res72[0x10]; + unsigned char res73[0x8]; + unsigned int pwr_ctrl; + unsigned int pwr_ctrl2; + unsigned char res74[0xd8]; + unsigned int apll_con0_l8; + unsigned int apll_con0_l7; + unsigned int apll_con0_l6; + unsigned int apll_con0_l5; + unsigned int apll_con0_l4; + unsigned int apll_con0_l3; + unsigned int apll_con0_l2; + unsigned int apll_con0_l1; + unsigned int iem_control; + unsigned char res75[0xdc]; + unsigned int apll_con1_l8; + unsigned int apll_con1_l7; + unsigned int apll_con1_l6; + unsigned int apll_con1_l5; + unsigned int apll_con1_l4; + unsigned int apll_con1_l3; + unsigned int apll_con1_l2; + unsigned int apll_con1_l1; + unsigned char res76[0xe0]; + unsigned int div_iem_l8; + unsigned int div_iem_l7; + unsigned int div_iem_l6; + unsigned int div_iem_l5; + unsigned int div_iem_l4; + unsigned int div_iem_l3; + unsigned int div_iem_l2; + unsigned int div_iem_l1; + unsigned char res77[0xe0]; + unsigned int l2_status; + unsigned char res78[0xc]; + unsigned int cpu_status; + unsigned char res79[0xc]; + unsigned int ptm_status; + unsigned char res80[0x2edc]; + unsigned int div_isp0; + unsigned int div_isp1; + unsigned char res81[0xf8]; + unsigned int div_stat_isp0; + unsigned int div_stat_isp1; + unsigned char res82[0x3f8]; + unsigned int gate_ip_isp0; + unsigned int gate_ip_isp1; + unsigned char res83[0x1f8]; + unsigned int clkout_cmu_isp; + unsigned int clkout_cmu_ispd_div_stat; + unsigned char res84[0xf8]; + unsigned int cmu_isp_spar0; + unsigned int cmu_isp_spar1; + unsigned int cmu_isp_spar2; + unsigned int cmu_isp_spar3; +}; + struct exynos5_clock { unsigned int apll_lock; unsigned char res1[0xfc];
This patch adds gpio structure for Exynos4x12.
Signed-off-by: Chander Kashyap chander.kashyap@linaro.org --- arch/arm/include/asm/arch-exynos/gpio.h | 85 +++++++++++++++++++++++++++++++ 1 file changed, 85 insertions(+)
diff --git a/arch/arm/include/asm/arch-exynos/gpio.h b/arch/arm/include/asm/arch-exynos/gpio.h index 4db8fd6..cfe1024 100644 --- a/arch/arm/include/asm/arch-exynos/gpio.h +++ b/arch/arm/include/asm/arch-exynos/gpio.h @@ -79,6 +79,67 @@ struct exynos4_gpio_part3 { struct s5p_gpio_bank z; };
+struct exynos4x12_gpio_part1 { + struct s5p_gpio_bank a0; + struct s5p_gpio_bank a1; + struct s5p_gpio_bank b; + struct s5p_gpio_bank c0; + struct s5p_gpio_bank c1; + struct s5p_gpio_bank d0; + struct s5p_gpio_bank d1; + struct s5p_gpio_bank res1[0x5]; + struct s5p_gpio_bank f0; + struct s5p_gpio_bank f1; + struct s5p_gpio_bank f2; + struct s5p_gpio_bank f3; + struct s5p_gpio_bank res2[0x2]; + struct s5p_gpio_bank j0; + struct s5p_gpio_bank j1; +}; + +struct exynos4x12_gpio_part2 { + struct s5p_gpio_bank res1[0x2]; + struct s5p_gpio_bank k0; + struct s5p_gpio_bank k1; + struct s5p_gpio_bank k2; + struct s5p_gpio_bank k3; + struct s5p_gpio_bank l0; + struct s5p_gpio_bank l1; + struct s5p_gpio_bank l2; + struct s5p_gpio_bank y0; + struct s5p_gpio_bank y1; + struct s5p_gpio_bank y2; + struct s5p_gpio_bank y3; + struct s5p_gpio_bank y4; + struct s5p_gpio_bank y5; + struct s5p_gpio_bank y6; + struct s5p_gpio_bank res2[0x3]; + struct s5p_gpio_bank m0; + struct s5p_gpio_bank m1; + struct s5p_gpio_bank m2; + struct s5p_gpio_bank m3; + struct s5p_gpio_bank m4; + struct s5p_gpio_bank res3[0x48]; + struct s5p_gpio_bank x0; + struct s5p_gpio_bank x1; + struct s5p_gpio_bank x2; + struct s5p_gpio_bank x3; +}; + +struct exynos4x12_gpio_part3 { + struct s5p_gpio_bank z; +}; + +struct exynos4x12_gpio_part4 { + struct s5p_gpio_bank v0; + struct s5p_gpio_bank v1; + struct s5p_gpio_bank res1[0x1]; + struct s5p_gpio_bank v2; + struct s5p_gpio_bank v3; + struct s5p_gpio_bank res2[0x1]; + struct s5p_gpio_bank v4; +}; + struct exynos5_gpio_part1 { struct s5p_gpio_bank a0; struct s5p_gpio_bank a1; @@ -163,6 +224,30 @@ void s5p_gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode); - EXYNOS4_GPIO_PART2_BASE) / sizeof(struct s5p_gpio_bank)) \ * GPIO_PER_BANK) + pin) + EXYNOS4_GPIO_PART1_MAX)
+#define exynos4x12_gpio_part1_get_nr(bank, pin) \ + ((((((unsigned int) &(((struct exynos4x12_gpio_part1 *) \ + EXYNOS4X12_GPIO_PART1_BASE)->bank)) \ + - EXYNOS4X12_GPIO_PART1_BASE) / sizeof(struct s5p_gpio_bank)) \ + * GPIO_PER_BANK) + pin) + +#define EXYNOS4X12_GPIO_PART1_MAX ((sizeof(struct exynos4x12_gpio_part1) \ + / sizeof(struct s5p_gpio_bank)) * GPIO_PER_BANK) + +#define exynos4x12_gpio_part2_get_nr(bank, pin) \ + (((((((unsigned int) &(((struct exynos4x12_gpio_part2 *) \ + EXYNOS4X12_GPIO_PART2_BASE)->bank)) \ + - EXYNOS4X12_GPIO_PART2_BASE) / sizeof(struct s5p_gpio_bank)) \ + * GPIO_PER_BANK) + pin) + EXYNOS4X12_GPIO_PART1_MAX) + +#define EXYNOS4X12_GPIO_PART2_MAX ((sizeof(struct exynos4x12_gpio_part2) \ + / sizeof(struct s5p_gpio_bank)) * GPIO_PER_BANK) + +#define exynos4x12_gpio_part3_get_nr(bank, pin) \ + (((((((unsigned int) &(((struct exynos4x12_gpio_part3 *) \ + EXYNOS4X12_GPIO_PART3_BASE)->bank)) \ + - EXYNOS4X12_GPIO_PART3_BASE) / sizeof(struct s5p_gpio_bank)) \ + * GPIO_PER_BANK) + pin) + EXYNOS4X12_GPIO_PART2_MAX) + #define exynos5_gpio_part1_get_nr(bank, pin) \ ((((((unsigned int) &(((struct exynos5_gpio_part1 *) \ EXYNOS5_GPIO_PART1_BASE)->bank)) \
Dear Chander Kashyap,
Changes in v2:
CCing Minkyu
Best regards, Marek Vasut
Dear Marek, thanks. On 3 October 2012 05:46, Marek Vasut marex@denx.de wrote:
CCing Minkyu
mk7.kang@samsung.com is also Minkyu's ID.
On 3 October 2012 11:04, Chander Kashyap chander.kashyap@linaro.org wrote:
CCing Minkyu
Tip: Always place a blank line before/after your comments, when replying mails. That makes it much more readable to others.
ping
-- 1.7.9.5
ping
CCing custodian.
-- 1.7.9.5
Dear Chander,
On 02/11/12 19:51, Chander Kashyap wrote:
ping
Patches are looks good. Please rebase this patchset.
Thanks. Minkyu Kang.
Dear Minkyu,
On 7 December 2012 13:19, Minkyu Kang mk7.kang@samsung.com wrote:
Dear Chander,
ping
Sure i will resend after re-basing.
Chander Kashyap
Minkyu Kang
Viresh Kumar
