[PATCH 1/3] imx7d-sdb-u-boot: Pass SPDX-License tag
SPDX-License tag is missing and checkpatch complains about it.
Add the SPDX-License tag using the same one from imx7d-sdb.dts.
Signed-off-by: Fabio Estevam festevam@denx.de --- arch/arm/dts/imx7d-sdb-u-boot.dtsi | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/dts/imx7d-sdb-u-boot.dtsi b/arch/arm/dts/imx7d-sdb-u-boot.dtsi index ac1d6e2e6480..818528c418f5 100644 --- a/arch/arm/dts/imx7d-sdb-u-boot.dtsi +++ b/arch/arm/dts/imx7d-sdb-u-boot.dtsi @@ -1,3 +1,5 @@ +// SPDX-License-Identifier: GPL-2.0+ OR MIT + &fec2 { status = "disable"; };
Commit 68dcbdd594d4 ("ARM: imx: Add weak default reset_cpu()") caused the 'reset' command in U-Boot to not cause a board reset.
Fix it by switching to the watchdog driver model via sysreset, which is the preferred method for implementing the watchdog reset.
Signed-off-by: Fabio Estevam festevam@denx.de --- arch/arm/dts/imx7d-sdb-u-boot.dtsi | 12 ++++++++++++ configs/mx7dsabresd_defconfig | 3 +++ 2 files changed, 15 insertions(+)
diff --git a/arch/arm/dts/imx7d-sdb-u-boot.dtsi b/arch/arm/dts/imx7d-sdb-u-boot.dtsi index 818528c418f5..2e234b6b5828 100644 --- a/arch/arm/dts/imx7d-sdb-u-boot.dtsi +++ b/arch/arm/dts/imx7d-sdb-u-boot.dtsi @@ -1,5 +1,13 @@ // SPDX-License-Identifier: GPL-2.0+ OR MIT
+/ { + wdt-reboot { + compatible = "wdt-reboot"; + wdt = <&wdog1>; + bootph-pre-ram; + }; +}; + &fec2 { status = "disable"; }; @@ -58,3 +66,7 @@ >; }; }; + +&wdog1 { + bootph-pre-ram; +}; diff --git a/configs/mx7dsabresd_defconfig b/configs/mx7dsabresd_defconfig index 26e68d30d267..1c8105f44f28 100644 --- a/configs/mx7dsabresd_defconfig +++ b/configs/mx7dsabresd_defconfig @@ -73,6 +73,8 @@ CONFIG_MXC_UART=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_SOFT_SPI=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_WATCHDOG=y CONFIG_IMX_THERMAL=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y @@ -85,4 +87,5 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_IMX_WATCHDOG=y CONFIG_ERRNO_STR=y
Awesome
From: Fabio Estevam festevam@denx.de Commit 68dcbdd594d4 ("ARM: imx: Add weak default reset_cpu()") caused the 'reset' command in U-Boot to not cause a board reset. Fix it by switching to the watchdog driver model via sysreset, which is the preferred method for implementing the watchdog reset. Signed-off-by: Fabio Estevam festevam@denx.de Reviewed-by: Marek Vasut marex@denx.de
Best regards, Stefano Babic
Signed-off-by: Fabio Estevam festevam@denx.de --- arch/arm/dts/imx7d-smegw01-u-boot.dtsi | 13 +++++++++++++ configs/smegw01_defconfig | 3 +++ 2 files changed, 16 insertions(+) create mode 100644 arch/arm/dts/imx7d-smegw01-u-boot.dtsi
diff --git a/arch/arm/dts/imx7d-smegw01-u-boot.dtsi b/arch/arm/dts/imx7d-smegw01-u-boot.dtsi new file mode 100644 index 000000000000..cf7ba3a95817 --- /dev/null +++ b/arch/arm/dts/imx7d-smegw01-u-boot.dtsi @@ -0,0 +1,13 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +/ { + wdt-reboot { + compatible = "wdt-reboot"; + wdt = <&wdog1>; + bootph-pre-ram; + }; +}; + +&wdog1 { + bootph-pre-ram; +}; diff --git a/configs/smegw01_defconfig b/configs/smegw01_defconfig index 7f1b2bee8e16..a3d289eeca1a 100644 --- a/configs/smegw01_defconfig +++ b/configs/smegw01_defconfig @@ -80,5 +80,8 @@ CONFIG_DM_REGULATOR_GPIO=y CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_WATCHDOG=y CONFIG_IMX_THERMAL=y +CONFIG_IMX_WATCHDOG=y # CONFIG_CMD_BOOTEFI_BOOTMGR is not set
- &fec2 { status = "disable"; };
From: Fabio Estevam festevam@denx.de SPDX-License tag is missing and checkpatch complains about it. Add the SPDX-License tag using the same one from imx7d-sdb.dts. Signed-off-by: Fabio Estevam festevam@denx.de Reviewed-by: Marek Vasut marex@denx.de
Fabio Estevam
sbabic@denx.de
