[U-Boot] [PATCH 1/3] PCI: dm: Ignore 64-bit memory regions if CONFIG_SYS_PCI_64BIT not set
Currently, qemu_arm_defconfig and qemu_arm64_defconfig only work with the 'highmem=off' parameter passed to QEMU's virt machine. The reason is that when 'highmem' is not disabled, QEMU appends 64-bit a memory resource to the PCI controller's regions property in DT in addition to the 32-bit PCI memory window in low memory. And the current DT parsing code picks the last (thus the 64-bit one) memory resource, whose address eventually gets silently truncated to 32 bits because CONFIG_SYS_PCI_64BIT is not set, which obviously causes PCI to break.
Avoid this problem by ignoring memory regions whose addresses are above the 32-bit boundary when CONFIG_SYS_PCI_64BIT is not set.
Signed-off-by: Tuomas Tynkkynen tuomas.tynkkynen@iki.fi --- drivers/pci/pci-uclass.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index 49be1ebdd7..1cd1e409e3 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -860,6 +860,13 @@ static int decode_regions(struct pci_controller *hose, ofnode parent_node, } else { continue; } + + if (!IS_ENABLED(CONFIG_SYS_PCI_64BIT) && + type == PCI_REGION_MEM && upper_32_bits(pci_addr)) { + debug(" - beyond the 32-bit boundary, ignoring\n"); + continue; + } + pos = -1; for (i = 0; i < hose->region_count; i++) { if (hose->regions[i].flags == type)
Now that PCI devices work with highmem-enabled QEMU emulation, bump up the RAM size in the MMU tables to gain access to the full 255 GB of RAM potential instead of the puny 3 GB.
Signed-off-by: Tuomas Tynkkynen tuomas.tynkkynen@iki.fi --- board/emulation/qemu-arm/qemu-arm.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/emulation/qemu-arm/qemu-arm.c b/board/emulation/qemu-arm/qemu-arm.c index 6ec4200170..085cbbef99 100644 --- a/board/emulation/qemu-arm/qemu-arm.c +++ b/board/emulation/qemu-arm/qemu-arm.c @@ -28,7 +28,7 @@ static struct mm_region qemu_arm64_mem_map[] = { /* RAM */ .virt = 0x40000000UL, .phys = 0x40000000UL, - .size = 0xc0000000UL, + .size = 255UL * SZ_1G, .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | PTE_BLOCK_INNER_SHARE }, {
Signed-off-by: Tuomas Tynkkynen tuomas.tynkkynen@iki.fi Reviewed-by: Simon Glass sjg@chromium.org
Now that U-Boot works fine with highmem enabled, there is no need to tell users to disable highmem.
Signed-off-by: Tuomas Tynkkynen tuomas.tynkkynen@iki.fi --- doc/README.qemu-arm | 7 +++---- 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/doc/README.qemu-arm b/doc/README.qemu-arm index 6f6f07d8bb..260165638a 100644 --- a/doc/README.qemu-arm +++ b/doc/README.qemu-arm @@ -39,13 +39,12 @@ Running U-Boot The minimal QEMU command line to get U-Boot up and running is:
- For ARM: - qemu-system-arm -machine virt,highmem=off -bios u-boot.bin + qemu-system-arm -machine virt -bios u-boot.bin
- For AArch64: - qemu-system-aarch64 -machine virt,highmem=off -cpu cortex-a57 -bios u-boot.bin + qemu-system-aarch64 -machine virt -cpu cortex-a57 -bios u-boot.bin
-The 'highmem=off' parameter to the 'virt' machine is required for PCI to work -in U-Boot. Also, for some odd reason qemu-system-aarch64 needs to be explicitly +Note that for some odd reason qemu-system-aarch64 needs to be explicitly told to use a 64-bit CPU or it will boot in 32-bit mode.
Additional peripherals that have been tested to work in both U-Boot and Linux
- For ARM:
- qemu-system-arm -machine virt -bios u-boot.bin
- For AArch64:
- qemu-system-aarch64 -machine virt -cpu cortex-a57 -bios u-boot.bin
Something has changed as qemu 3.0 requires highmem=off again. qemu 2.12.0 works without highmem=off.
$ qemu-system-aarch64 --version QEMU emulator version 3.0.0 Copyright (c) 2003-2017 Fabrice Bellard and the QEMU Project developers $ qemu-system-aarch64 -M virt -cpu cortex-a57 -bios u-boot.bin -serial stdio
U-Boot 2018.09-rc3 (Sep 04 2018 - 13:03:12 +1000)
DRAM: 128 MiB In: pl011@9000000 Out: pl011@9000000 Err: pl011@9000000 Net: No ethernet found. "Synchronous Abort" handler, esr 0x96000005 elr: 00000000000258e0 lr : 000000000002589c (reloc) elr: 0000000047f978e0 lr : 0000000047f9789c x0 : 000000401000000e x1 : 0000000000000000 x2 : 000000401000000e x3 : 0000000046e608c8 x4 : 0000004010000000 x5 : 0000000000000000 x6 : 0000000047f9889c x7 : 0000000000000002 x8 : 0000000000000003 x9 : 0000000000000004 x10: 0000000046e60de8 x11: 000000000000152c x12: 0000000046e6089c x13: 0000000000001200 x14: 0000000046e6092c x15: 0000000046e60de8 x16: 0000000000000000 x17: 0000000000000000 x18: 0000000046f61de8 x19: 0000000046e60940 x20: 0000000000000000 x21: 0000000047fcc0a8 x22: 0000000046f62450 x23: 0000000047fcc680 x24: 000000000000ff00 x25: 0000000000000000 x26: 0000000047fcc000 x27: 0000000000000000 x28: 0000000000000000 x29: 0000000046e608a0
Resetting CPU ...
resetting ...
$ qemu-system-aarch64 -M virt,highmem=off -cpu cortex-a57 -bios u-boot.bin -serial stdio
DRAM: 128 MiB In: pl011@9000000 Out: pl011@9000000 Err: pl011@9000000 Net: No ethernet found. Hit any key to stop autoboot: 0 scanning bus for devices...
Device 0: unknown device =>
Jonathan Gray
Tuomas Tynkkynen
