[U-Boot] [PATCH v2 1/1] omap4: allow the use of a plain text env file instead boot scripts
For production systems it is better to use script images since they are protected by checksums and carry valuable information like name and timestamp. Also, you can't validate the content passed to env import.
But for development, it is easier to use the env import command and plain text files instead of script-images.
Since both OMAP4 supported boards (Panda and TI SDP4430) are used primarily for development, this patch allows U-Boot to load env var from a text file in case that an boot.scr script-image is not present.
The variable uenvcmd (if existent) will be executed (using run) after uEnv.txt was loaded. If uenvcmd doesn't exist the default boot sequence will be started.
Signed-off-by: Javier Martinez Canillas javier.martinez@collabora.co.uk ---
Changes since v2: - Comment the advantages and drawbacks of using env import instead of boot scripts as explained by Wolfgang Denk. - Don't break existing users/distributions that rely on boot.scr by looking for uEnv.txt only if boot.scr does not exist as suggested by Tom Rini.
include/configs/omap4_common.h | 17 ++++++++++++++--- 1 files changed, 14 insertions(+), 3 deletions(-)
diff --git a/include/configs/omap4_common.h b/include/configs/omap4_common.h index a32369a..dfdfea9 100644 --- a/include/configs/omap4_common.h +++ b/include/configs/omap4_common.h @@ -159,6 +159,9 @@ "loadbootscript=fatload mmc ${mmcdev} ${loadaddr} boot.scr\0" \ "bootscript=echo Running bootscript from mmc${mmcdev} ...; " \ "source ${loadaddr}\0" \ + "loadbootenv=fatload mmc ${mmcdev} ${loadaddr} uEnv.txt\0" \ + "importbootenv=echo Importing environment from mmc${mmcdev} ...; " \ + "env import -t ${loadaddr} ${filesize}\0" \ "loaduimage=fatload mmc ${mmcdev} ${loadaddr} uImage\0" \ "mmcboot=echo Booting from mmc${mmcdev} ...; " \ "run mmcargs; " \ @@ -166,12 +169,20 @@
#define CONFIG_BOOTCOMMAND \ "mmc dev ${mmcdev}; if mmc rescan; then " \ + "echo SD/MMC found on device ${mmcdev};" \ "if run loadbootscript; then " \ "run bootscript; " \ "else " \ - "if run loaduimage; then " \ - "run mmcboot; " \ - "fi; " \ + "if run loadbootenv; then " \ + "run importbootenv; " \ + "fi;" \ + "if test -n ${uenvcmd}; then " \ + "echo Running uenvcmd ...;" \ + "run uenvcmd;" \ + "fi;" \ + "fi;" \ + "if run loaduimage; then " \ + "run mmcboot; " \ "fi; " \ "fi"
On Mon, Jan 7, 2013 at 7:51 AM, Javier Martinez Canillas javier@dowhile0.org wrote:
Acked-by: Nishanth Menon nm@ti.com
Tested on PandaBoard ES. Regards, Nishanth Menon
Hello Tom,
Any comments on this patch?
Thanks a lot and best regards, Javier
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
Hello Tom,
My Friday got overly busy, I hope to prepare a pull request for u-boot-ti early next week, with this patch. Thanks!
- -- Tom
Signed-off-by: Javier Martinez Canillas javier.martinez@collabora.co.uk Acked-by: Nishanth Menon nm@ti.com
Applied to u-boot-ti/master, thanks!
Nishanth Menon
