[PATCH v2] blk: fix a couple of trivial documentation typos
In some cases, the param variable is wrong, and in other cases we have undocumented arguments.
Fix the docs.
Signed-off-by: Mattijs Korpershoek mkorpershoek@baylibre.com --- Changes in v2:
* Don't edit blk_foreach_probe() comment as it's just returing (Simon) * Link to v1: https://lore.kernel.org/r/20221013-blk-doc-typos-v1-0-8031607c6a4c@baylibre.... --- include/blk.h | 8 +++++--- 1 file changed, 5 insertions(+), 3 deletions(-)
diff --git a/include/blk.h b/include/blk.h index 8806c382d4e7..d3ab9a10b969 100644 --- a/include/blk.h +++ b/include/blk.h @@ -119,7 +119,7 @@ int blkcache_init(void); * @param start - starting block number * @param blkcnt - number of blocks to read * @param blksz - size in bytes of each block - * @param buf - buffer to contain cached data + * @param buffer - buffer to contain cached data * * Return: - 1 if block returned from cache, 0 otherwise. */ @@ -136,7 +136,7 @@ int blkcache_read(int iftype, int dev, * @param start - starting block number * @param blkcnt - number of blocks available * @param blksz - size in bytes of each block - * @param buf - buffer containing data to cache + * @param buffer - buffer containing data to cache * */ void blkcache_fill(int iftype, int dev, @@ -250,7 +250,7 @@ struct blk_ops { * The MMC standard provides for two boot partitions (numbered 1 and 2), * rpmb (3), and up to 4 addition general-purpose partitions (4-7). * - * @desc: Block device to update + * @dev: Block device to update * @hwpart: Hardware partition number to select. 0 means the raw * device, 1 is the first partition, 2 is the second, etc. * @return 0 if OK, -ve on error @@ -642,6 +642,7 @@ int blk_print_part_devnum(enum uclass_id uclass_id, int devnum); * * @uclass_id: Block device type * @devnum: Device number + * @start: Start block number to read (0=first) * @blkcnt: Number of blocks to read * @buffer: Address to write data to * Return: number of blocks read, or -ve error number on error @@ -654,6 +655,7 @@ ulong blk_read_devnum(enum uclass_id uclass_id, int devnum, lbaint_t start, * * @uclass_id: Block device type * @devnum: Device number + * @start: Start block number to write (0=first) * @blkcnt: Number of blocks to write * @buffer: Address to read data from * Return: number of blocks written, or -ve error number on error
--- base-commit: 0e49f5c26caf9972137a474065afd4bdfe5ec062 change-id: 20221013-blk-doc-typos-de90e92ccd6b
On Mon, 17 Oct 2022 at 01:35, Mattijs Korpershoek mkorpershoek@baylibre.com wrote:
Fix the docs.
Changes in v2:
- Don't edit blk_foreach_probe() comment as it's just returing (Simon)
- Link to v1: https://lore.kernel.org/r/20221013-blk-doc-typos-v1-0-8031607c6a4c@baylibre....
Fix the docs.
Signed-off-by: Mattijs Korpershoek mkorpershoek@baylibre.com Reviewed-by: Simon Glass sjg@chromium.org
Mattijs Korpershoek
