[U-Boot] [PATCH] arm: mx6: Change defines ENET_xxMHz to ENET_xxMHZ (no CamelCase)
As checkpatch complaines about these camel-case defines, lets change them to only use upper-case characters.
Signed-off-by: Stefan Roese sr@denx.de Cc: Heiko Schocher hs@denx.de Cc: Fabio Estevam fabio.estevam@freescale.com Cc: Jon Nettleton jon.nettleton@gmail.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/cpu/armv7/mx6/clock.c | 2 +- arch/arm/include/asm/arch-mx6/clock.h | 8 ++++---- board/aristainetos/aristainetos.c | 2 +- board/freescale/mx6slevk/mx6slevk.c | 2 +- board/freescale/mx6sxsabresd/mx6sxsabresd.c | 2 +- board/solidrun/hummingboard/hummingboard.c | 2 +- 6 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/clock.c b/arch/arm/cpu/armv7/mx6/clock.c index 6c9c78c..bf2a6ec 100644 --- a/arch/arm/cpu/armv7/mx6/clock.c +++ b/arch/arm/cpu/armv7/mx6/clock.c @@ -443,7 +443,7 @@ int enable_fec_anatop_clock(enum enet_freq freq) struct anatop_regs __iomem *anatop = (struct anatop_regs __iomem *)ANATOP_BASE_ADDR;
- if (freq < ENET_25MHz || freq > ENET_125MHz) + if (freq < ENET_25MHZ || freq > ENET_125MHZ) return -EINVAL;
reg = readl(&anatop->pll_enet); diff --git a/arch/arm/include/asm/arch-mx6/clock.h b/arch/arm/include/asm/arch-mx6/clock.h index 3c58a0a..ec5d026 100644 --- a/arch/arm/include/asm/arch-mx6/clock.h +++ b/arch/arm/include/asm/arch-mx6/clock.h @@ -43,10 +43,10 @@ enum mxc_clock { };
enum enet_freq { - ENET_25MHz, - ENET_50MHz, - ENET_100MHz, - ENET_125MHz, + ENET_25MHZ, + ENET_50MHZ, + ENET_100MHZ, + ENET_125MHZ, };
u32 imx_get_uartclk(void); diff --git a/board/aristainetos/aristainetos.c b/board/aristainetos/aristainetos.c index 06922c0..67ac260 100644 --- a/board/aristainetos/aristainetos.c +++ b/board/aristainetos/aristainetos.c @@ -301,7 +301,7 @@ int board_eth_init(bd_t *bis) /* clear gpr1[14], gpr1[18:17] to select anatop clock */ clrsetbits_le32(&iomuxc_regs->gpr[1], IOMUX_GPR1_FEC_MASK, 0);
- ret = enable_fec_anatop_clock(ENET_50MHz); + ret = enable_fec_anatop_clock(ENET_50MHZ); if (ret) return ret;
diff --git a/board/freescale/mx6slevk/mx6slevk.c b/board/freescale/mx6slevk/mx6slevk.c index e76c343..ffd1117 100644 --- a/board/freescale/mx6slevk/mx6slevk.c +++ b/board/freescale/mx6slevk/mx6slevk.c @@ -235,7 +235,7 @@ static int setup_fec(void) /* clear gpr1[14], gpr1[18:17] to select anatop clock */ clrsetbits_le32(&iomuxc_regs->gpr[1], IOMUX_GPR1_FEC_MASK, 0);
diff --git a/board/freescale/mx6sxsabresd/mx6sxsabresd.c b/board/freescale/mx6sxsabresd/mx6sxsabresd.c index 68d3718..42928f8 100644 --- a/board/freescale/mx6sxsabresd/mx6sxsabresd.c +++ b/board/freescale/mx6sxsabresd/mx6sxsabresd.c @@ -140,7 +140,7 @@ static int setup_fec(void) reg |= BM_ANADIG_PLL_ENET_REF_25M_ENABLE; writel(reg, &anatop->pll_enet);
- ret = enable_fec_anatop_clock(ENET_125MHz); + ret = enable_fec_anatop_clock(ENET_125MHZ); if (ret) return ret;
diff --git a/board/solidrun/hummingboard/hummingboard.c b/board/solidrun/hummingboard/hummingboard.c index 6d204b3..52c384b 100644 --- a/board/solidrun/hummingboard/hummingboard.c +++ b/board/solidrun/hummingboard/hummingboard.c @@ -146,7 +146,7 @@ int board_eth_init(bd_t *bis) { struct iomuxc *const iomuxc_regs = (struct iomuxc *)IOMUXC_BASE_ADDR;
- int ret = enable_fec_anatop_clock(ENET_25MHz); + int ret = enable_fec_anatop_clock(ENET_25MHZ); if (ret) return ret;
Hello Stefan,
Am 19.11.2014 16:30, schrieb Stefan Roese:
Thanks!
Acked-by: Heiko Schocher hs@denx.de
bye, Heiko
Heiko Schocher
Stefan Roese
