[U-Boot] [PATCH 1/1] efi_loader: update TODOs in doc/README.uefi
The following TODOs are closed:
- GetNextVariableName is not implemented - event groups - manage events in a linked list
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- doc/README.uefi | 5 +---- 1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/doc/README.uefi b/doc/README.uefi index cda29cdcf7..b38efbc0cc 100644 --- a/doc/README.uefi +++ b/doc/README.uefi @@ -299,7 +299,7 @@ This driver is only available if U-Boot is configured with CONFIG_BLK=y CONFIG_PARTITIONS=y
-## TODOs as of U-Boot 2018.07 +## TODOs as of U-Boot 2019.04
* unimplemented or incompletely implemented boot services * Exit - call unload function, unload applications only @@ -308,16 +308,13 @@ This driver is only available if U-Boot is configured with
* unimplemented or incompletely implemented runtime services * SetVariable() ignores attribute EFI_VARIABLE_APPEND_WRITE - * GetNextVariableName is not implemented * QueryVariableInfo is not implemented
* unimplemented events * EVT_RUNTIME * EVT_SIGNAL_VIRTUAL_ADDRESS_CHANGE - * event groups
* data model - * manage events in a linked list * manage configuration tables in a linked list
* UEFI drivers -- 2.20.1
Hi Heinrich,
As a matter of fact and strictly speaking, there are bunch of missing features; * Boot manager (section 3) - boot manager policy - support for some of Boot option variables - boot recovery * various protocols, - from section 11 to section 20 and - from section 24 to section 30 * Firmware Update (Spec section 23) * UEFI Byte Code(EBC) machine (Spec section 22) * Secure boot (Spec section 31) * Support for some of HII packages (section 33) * HII configuration protocols (section 34) * security&crypto-related protocols (section 36) * Variables - support for authentication
I don't think that we should list all of them, but we should definitely describe the *criteria* for what features be implemented and what not.
# Personally, I'd like to add "integration of DM and UEFI objects" :)
Thanks, -Takahiro Akashi
- event groups
- unimplemented or incompletely implemented boot services
- Exit - call unload function, unload applications only
- unimplemented or incompletely implemented runtime services
- SetVariable() ignores attribute EFI_VARIABLE_APPEND_WRITE
- QueryVariableInfo is not implemented
- unimplemented events
- EVT_RUNTIME
- EVT_SIGNAL_VIRTUAL_ADDRESS_CHANGE
- event groups
- data model
- manage configuration tables in a linked list
- UEFI drivers
-- 2.20.1
On 3/28/19 1:50 AM, AKASHI Takahiro wrote:
Hi Heinrich,
- Boot manager (section 3)
- boot recovery
- various protocols,
- Firmware Update (Spec section 23)
- UEFI Byte Code(EBC) machine (Spec section 22)
- Secure boot (Spec section 31)
- Support for some of HII packages (section 33)
- HII configuration protocols (section 34)
- security&crypto-related protocols (section 36)
- Variables
Alex suggested to base the scope of our implementation on the minimum requirements of this document:
Server Base Boot Requirements System Software on ARM Platforms - Version 1.1 https://developer.arm.com/docs/den0044/latest/server-base-boot-requirements-...
The deficiencies that I listed in README.uefi are the user view.
I agree that we should also define our U-Boot internal development targets and better DM-UEFI integration should be part of it.
Best regards
Heinrich
- event groups
- EVT_RUNTIME
- event groups
- data model
- UEFI drivers
-- 2.20.1
Hi Heinrich,
- boot recovery
- Variables
Yeah, I heard that but "minimum" is always a moving target and
this document yet has a much larger amount of requirements list than current U-Boot supports.
-Takahiro Akashi
Best regards
Heinrich
- event groups
- EVT_RUNTIME
- event groups
- data model
- UEFI drivers
-- 2.20.1
AKASHI Takahiro
