[PATCH] tiny-printf: revert patch to fix spl eth boot
From: Moses Christopher Bollavarapu moseschristopherb@gmail.com
- Revert commit 831c16111959 ("tiny-printf: Reorder code to support %p")
The mentioned commit does not handle the ethaddr properly. Hence, I tried to disable SPL_TINY_PRINTF, but then it was suggested to keep using the tiny-printf library in SPL and revert the patch that caused the issue.
- The issue is observed in both Beaglebone Black and Guardian Board, while trying to boot the board using USB-ETH in SPL stage.
Signed-off-by: Moses Christopher Bollavarapu moseschristopherb@gmail.com --- lib/tiny-printf.c | 10 ---------- 1 file changed, 10 deletions(-)
diff --git a/lib/tiny-printf.c b/lib/tiny-printf.c index 1138c7012a..8ee0ffb9ca 100644 --- a/lib/tiny-printf.c +++ b/lib/tiny-printf.c @@ -268,20 +268,10 @@ static int _vprintf(struct printf_info *info, const char *fmt, va_list va) } break; case 'p': -#ifdef DEBUG pointer(info, fmt, va_arg(va, void *)); - /* - * Skip this because it pulls in _ctype which is - * 256 bytes, and we don't generally implement - * pointer anyway - */ while (isalnum(fmt[0])) fmt++; break; -#else - islong = true; - /* no break */ -#endif case 'x': if (islong) { num = va_arg(va, unsigned long);
Moses Christopher
