[U-Boot] [PATCH 0/4] i2c: UniPhier: add I2C drivers based on driver model
Masahiro Yamada (4): i2c: UniPhier: add driver for UniPhier i2c controller i2c: UniPhier: add driver for UniPhier FIFO-builtin i2c controller ARM: UniPhier: enable UniPhier I2C driver ARM: UniPhier: enable CONFIG_I2C_EEPROM
configs/ph1_ld4_defconfig | 2 + configs/ph1_pro4_defconfig | 2 + configs/ph1_sld8_defconfig | 2 + drivers/i2c/Kconfig | 22 +++ drivers/i2c/Makefile | 2 + drivers/i2c/i2c-uniphier-f.c | 355 +++++++++++++++++++++++++++++++++++++++++++ drivers/i2c/i2c-uniphier.c | 225 +++++++++++++++++++++++++++ include/configs/uniphier.h | 3 + 8 files changed, 613 insertions(+) create mode 100644 drivers/i2c/i2c-uniphier-f.c create mode 100644 drivers/i2c/i2c-uniphier.c
This commit adds on-chip I2C driver used on some old Panasonic UniPhier SoCs.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
drivers/i2c/Kconfig | 14 +++ drivers/i2c/Makefile | 1 + drivers/i2c/i2c-uniphier.c | 225 +++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 240 insertions(+) create mode 100644 drivers/i2c/i2c-uniphier.c
diff --git a/drivers/i2c/Kconfig b/drivers/i2c/Kconfig index e69de29..6a479ef 100644 --- a/drivers/i2c/Kconfig +++ b/drivers/i2c/Kconfig @@ -0,0 +1,14 @@ +config DM_I2C + bool "Enable Driver Model for I2C drivers" + depends on DM + help + If you want to use driver model for I2C drivers, say Y. + To use legacy I2C drivers, say N. + +config SYS_I2C_UNIPHIER + bool "UniPhier I2C driver" + depends on ARCH_UNIPHIER && DM_I2C + default y + help + Support for Panasonic UniPhier I2C controller driver. This I2C + controller is used on PH1-LD4, PH1-sLD8 or older UniPhier SoCs. diff --git a/drivers/i2c/Makefile b/drivers/i2c/Makefile index 6f3c86c..e2fcd24 100644 --- a/drivers/i2c/Makefile +++ b/drivers/i2c/Makefile @@ -31,4 +31,5 @@ obj-$(CONFIG_SYS_I2C_SANDBOX) += sandbox_i2c.o i2c-emul-uclass.o obj-$(CONFIG_SYS_I2C_SH) += sh_i2c.o obj-$(CONFIG_SYS_I2C_SOFT) += soft_i2c.o obj-$(CONFIG_SYS_I2C_TEGRA) += tegra_i2c.o +obj-$(CONFIG_SYS_I2C_UNIPHIER) += i2c-uniphier.o obj-$(CONFIG_SYS_I2C_ZYNQ) += zynq_i2c.o diff --git a/drivers/i2c/i2c-uniphier.c b/drivers/i2c/i2c-uniphier.c new file mode 100644 index 0000000..05035ac --- /dev/null +++ b/drivers/i2c/i2c-uniphier.c @@ -0,0 +1,225 @@ +/* + * Copyright (C) 2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <linux/types.h> +#include <asm/io.h> +#include <asm/errno.h> +#include <dm/device.h> +#include <dm/root.h> +#include <i2c.h> +#include <fdtdec.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define I2C_DTRM 0x00 /* data transmission */ +#define I2C_DTRM_STA (1 << 10) +#define I2C_DTRM_STO (1 << 9) +#define I2C_DTRM_NACK (1 << 8) +#define I2C_DTRM_RD (1 << 0) +#define I2C_DREC 0x04 /* data reception */ +#define I2C_DREC_STS (1 << 12) +#define I2C_DREC_LRB (1 << 11) +#define I2C_DREC_LAB (1 << 9) +#define I2C_MYAD 0x08 +#define I2C_CLK 0x0c +#define I2C_BRST 0x10 /* bus reset */ +#define I2C_BRST_FOEN (1 << 1) +#define I2C_BRST_BRST (1 << 0) +#define I2C_HOLD 0x14 +#define I2C_BSTS 0x18 +#define I2C_NOISE 0x1c +#define I2C_SETUP 0x20 + +#define IOBUS_FREQ 100000000 + +struct uniphier_i2c_dev { + void __iomem *base; /* register base */ + unsigned long input_clk; /* master clock (Hz) */ + unsigned long wait_us; /* wait for every byte transfer (us) */ +}; + +static int uniphier_i2c_probe(struct udevice *dev) +{ + fdt_addr_t addr; + fdt_size_t size; + struct uniphier_i2c_dev *priv = dev_get_priv(dev); + + addr = fdtdec_get_addr_size(gd->fdt_blob, dev->of_offset, "reg", &size); + + priv->base = map_sysmem(addr, size); + + if (!priv->base) + return -ENOMEM; + + priv->input_clk = IOBUS_FREQ; + + /* deassert reset */ + writel(0x3, priv->base + I2C_BRST); + + return 0; +} + +static int uniphier_i2c_remove(struct udevice *dev) +{ + struct uniphier_i2c_dev *priv = dev_get_priv(dev); + + unmap_sysmem(priv->base); + + return 0; +} + +static int uniphier_i2c_child_pre_probe(struct udevice *dev) +{ + struct dm_i2c_chip *i2c_chip = dev_get_parentdata(dev); + + if (dev->of_offset == -1) + return 0; + return i2c_chip_ofdata_to_platdata(gd->fdt_blob, dev->of_offset, + i2c_chip); +} + +static int send_and_recv_byte(struct uniphier_i2c_dev *dev, u32 dtrm) +{ + writel(dtrm, dev->base + I2C_DTRM); + + /* + * U-Boot does not have a good support of interrupt. + * Wait for a while. + */ + udelay(dev->wait_us); + + return readl(dev->base + I2C_DREC); +} + +static int send_byte(struct uniphier_i2c_dev *dev, u32 dtrm, bool *stop) +{ + int ret = 0; + u32 drec; + + drec = send_and_recv_byte(dev, dtrm); + + if (drec & I2C_DREC_LAB) { + debug("uniphier_i2c: bus arbitration failed\n"); + *stop = false; + ret = -EREMOTEIO; + } + if (drec & I2C_DREC_LRB) { + debug("uniphier_i2c: slave did not return ACK\n"); + ret = -EREMOTEIO; + } + return ret; +} + +static int uniphier_i2c_transmit(struct uniphier_i2c_dev *dev, + uint addr, uint len, const u8 *buf) +{ + int ret; + bool stop = true; + + ret = send_byte(dev, I2C_DTRM_STA | I2C_DTRM_NACK | addr << 1, &stop); + if (ret < 0) + goto fail; + + while (len--) { + ret = send_byte(dev, I2C_DTRM_NACK | *buf++, &stop); + if (ret < 0) + goto fail; + } + +fail: + if (stop) + writel(I2C_DTRM_STO | I2C_DTRM_NACK, dev->base + I2C_DTRM); + + return ret; +} + +static int uniphier_i2c_receive(struct uniphier_i2c_dev *dev, + uint addr, uint len, u8 *buf) +{ + int ret; + bool stop = true; + + ret = send_byte(dev, I2C_DTRM_STA | I2C_DTRM_NACK | + I2C_DTRM_RD | addr << 1, &stop); + if (ret < 0) + goto fail; + + while (len--) + *buf++ = send_and_recv_byte(dev, len ? 0 : I2C_DTRM_NACK); + +fail: + if (stop) + writel(I2C_DTRM_STO | I2C_DTRM_NACK, dev->base + I2C_DTRM); + + return ret; +} + +static int uniphier_i2c_xfer(struct udevice *bus, struct i2c_msg *msg, + int nmsgs) +{ + int ret = 0; + struct uniphier_i2c_dev *dev = dev_get_priv(bus); + + for (; nmsgs > 0; nmsgs--, msg++) { + if (msg->flags & I2C_M_RD) + ret = uniphier_i2c_receive(dev, msg->addr, + msg->len, msg->buf); + else + ret = uniphier_i2c_transmit(dev, msg->addr, + msg->len, msg->buf); + + if (ret < 0) + break; + } + + return ret; +} + +static int uniphier_i2c_set_bus_speed(struct udevice *bus, unsigned int speed) +{ + struct uniphier_i2c_dev *priv = dev_get_priv(bus); + + /* max supported frequency is 400 kHz */ + if (speed > 400000) + return -EINVAL; + + /* bus reset: make sure the bus is idle when change the freqency */ + writel(0x1, priv->base + I2C_BRST); + + writel((priv->input_clk / speed / 2 << 16) | (priv->input_clk / speed), + priv->base + I2C_CLK); + + writel(0x3, priv->base + I2C_BRST); + + priv->wait_us = 20000000 / speed; + + return 0; +} + + +static const struct dm_i2c_ops uniphier_i2c_ops = { + .xfer = uniphier_i2c_xfer, + .set_bus_speed = uniphier_i2c_set_bus_speed, +}; + +static const struct udevice_id uniphier_i2c_of_match[] = { + { .compatible = "panasonic,uniphier-i2c" }, + {}, +}; + +U_BOOT_DRIVER(uniphier_i2c) = { + .name = "uniphier-i2c", + .id = UCLASS_I2C, + .of_match = uniphier_i2c_of_match, + .probe = uniphier_i2c_probe, + .remove = uniphier_i2c_remove, + .per_child_auto_alloc_size = sizeof(struct dm_i2c_chip), + .child_pre_probe = uniphier_i2c_child_pre_probe, + .priv_auto_alloc_size = sizeof(struct uniphier_i2c_dev), + .ops = &uniphier_i2c_ops, +};
Hi Masahiro,
On 22 December 2014 at 03:58, Masahiro Yamada yamada.m@jp.panasonic.com wrote:
From a driver model perspective:
A few comments below.
depends on DM
help
default y
help
- Copyright (C) 2014 Panasonic Corporation
- Author: Masahiro Yamada yamada.m@jp.panasonic.com
U-Boot normally uses a struct for register access.
fdt_addr_t addr;
fdt_size_t size;
if (!priv->base)
return -ENOMEM;
i2c_chip);
* Wait for a while.
It might be possible to check a 'ready' bit in the hardware, but I suppose this works and is simple for what sounds like old hardware.
int ret = 0;
u32 drec;
*stop = false;
ret = -EREMOTEIO;
ret = -EREMOTEIO;
return ret;
int ret;
bool stop = true;
if (ret < 0)
goto fail;
while (len--) {
if (ret < 0)
goto fail;
+fail:
if (stop)
return ret;
int ret;
bool stop = true;
if (ret < 0)
goto fail;
while (len--)
+fail:
if (stop)
return ret;
int nmsgs)
int ret = 0;
else
if (ret < 0)
break;
return ret;
if (speed > 400000)
return -EINVAL;
How is that calculated? Perhaps have a comment?
.id = UCLASS_I2C,
1.9.1
Simon, Heiko,
If you have no objection to this series, I will apply it to u-boot-uniphier.
Is this OK?
Some replies below to Simon's comment.
IMHO, we can play it by ear.
I notice two disadvantages of struct strategy.
[1] we have to intert dummy registers where no register exist.
For example, there is no register at offset address 0x8 of fi2c controller.
struct uniphier_fi2c_regs { u32 cr; u32 dttx; u32 __dummy; <-- necessary u32 slad; ...
[2] It is difficult to describe alias register name for the same address.
For example,
#define I2C_DTTX 0x04 /* send FIFO */ #define I2C_DTRX 0x04 /* receive FIFO */
DTTX is write-only register. DTRX is read-only register.
They are assigned to the same address.
fdt_addr_t addr;
fdt_size_t size;
if (!priv->base)
return -ENOMEM;
i2c_chip);
* Wait for a while.
Unfortunately, there is no 'ready' bit in this I2C controller. This hardware expects intrruption is checked.
It is true that we can check the GIC register of ARM processor, but I think it is too much for this driver.
if (speed > 400000)
return -EINVAL;
OK, I will add some comments. No precise theory for this line. Rough calculation.
Best Regards Masahiro Yamada
Hi Masahiro,
On 25 December 2014 at 00:15, Masahiro Yamada yamada.m@jp.panasonic.com wrote:
Simon, Heiko,
Is this OK?
That seems like a minor problem to me. A better term might be 'reserved'.
For example,
You could use fifo or rx_tx or data. Of even a #define if you can't avoid it.
There has been quite a bit of discussion about this U-Boot design decision. I think Albert is the main expert.
fdt_addr_t addr;
fdt_size_t size;
if (!priv->base)
return -ENOMEM;
i2c_chip);
* Wait for a while.
OK.
if (speed > 400000)
return -EINVAL;
OK.
Hi Simon,
For example,
Finally, I posted v4 using a structure for register access.
This commit adds on-chip I2C driver used on newer SoCs of Panasonic UniPhier platform.
drivers/i2c/Kconfig | 8 + drivers/i2c/Makefile | 1 + drivers/i2c/i2c-uniphier-f.c | 355 +++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 364 insertions(+) create mode 100644 drivers/i2c/i2c-uniphier-f.c
diff --git a/drivers/i2c/Kconfig b/drivers/i2c/Kconfig index 6a479ef..e75c1ff 100644 --- a/drivers/i2c/Kconfig +++ b/drivers/i2c/Kconfig @@ -12,3 +12,11 @@ config SYS_I2C_UNIPHIER help Support for Panasonic UniPhier I2C controller driver. This I2C controller is used on PH1-LD4, PH1-sLD8 or older UniPhier SoCs. + +config SYS_I2C_UNIPHIER_F + bool "UniPhier I2C with FIFO driver" + depends on ARCH_UNIPHIER && DM_I2C + default y + help + Support for Panasonic UniPhier I2C with FIFO controller driver. + This I2C controller is used on PH1-Pro4 or newer UniPhier SoCs. diff --git a/drivers/i2c/Makefile b/drivers/i2c/Makefile index e2fcd24..0e4c9f4 100644 --- a/drivers/i2c/Makefile +++ b/drivers/i2c/Makefile @@ -32,4 +32,5 @@ obj-$(CONFIG_SYS_I2C_SH) += sh_i2c.o obj-$(CONFIG_SYS_I2C_SOFT) += soft_i2c.o obj-$(CONFIG_SYS_I2C_TEGRA) += tegra_i2c.o obj-$(CONFIG_SYS_I2C_UNIPHIER) += i2c-uniphier.o +obj-$(CONFIG_SYS_I2C_UNIPHIER_F) += i2c-uniphier-f.o obj-$(CONFIG_SYS_I2C_ZYNQ) += zynq_i2c.o diff --git a/drivers/i2c/i2c-uniphier-f.c b/drivers/i2c/i2c-uniphier-f.c new file mode 100644 index 0000000..14a7f1c --- /dev/null +++ b/drivers/i2c/i2c-uniphier-f.c @@ -0,0 +1,355 @@ +/* + * Copyright (C) 2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* #define DEBUG */ + +#include <common.h> +#include <linux/types.h> +#include <asm/io.h> +#include <asm/errno.h> +#include <dm/device.h> +#include <dm/root.h> +#include <i2c.h> +#include <fdtdec.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define I2C_CR 0x00 /* control register */ +#define I2C_CR_MST (1 << 3) /* master mode */ +#define I2C_CR_STA (1 << 2) /* start condition */ +#define I2C_CR_STO (1 << 1) /* stop condition */ +#define I2C_CR_NACK (1 << 0) /* not ACK */ + +#define I2C_DTTX 0x04 /* send FIFO */ +#define I2C_DTRX 0x04 /* receive FIFO */ +#define I2C_DTTX_CMD (1 << 8) /* send command (slave addr) */ +#define I2C_DTTX_RD (1 << 0) /* read */ +#define I2C_SLAD 0x0c /* slave address */ +#define I2C_CYC 0x10 /* clock cycle control */ +#define I2C_LCTL 0x14 /* clock low period control */ +#define I2C_SSUT 0x18 /* restart/stop setup time control */ +#define I2C_DSUT 0x1c /* data setup time control */ +#define I2C_INT 0x20 /* interrupt status */ +#define I2C_IE 0x24 /* interrupt enable */ +#define I2C_IC 0x28 /* interrupt clear */ +#define I2C_INT_TE (1 << 9) /* TX FIFO empty */ +#define I2C_INT_RB (1 << 4) /* received specified bytes */ +#define I2C_INT_NA (1 << 2) /* no answer */ +#define I2C_INT_AL (1 << 1) /* arbitration lost */ +#define I2C_SR 0x2c /* status register */ +#define I2C_SR_DB (1 << 12) /* device busy */ +#define I2C_SR_BB (1 << 8) /* bus busy */ +#define I2C_SR_RFF (1 << 3) /* Rx FIFO full */ +#define I2C_SR_RNE (1 << 2) /* Rx FIFO not empty */ +#define I2C_SR_TNF (1 << 1) /* Tx FIFO not full */ +#define I2C_SR_TFE (1 << 0) /* Tx FIFO empty */ +#define I2C_RST 0x34 /* reset control */ +#define I2C_RST_TBRST (1 << 2) /* clear Tx FIFO */ +#define I2C_RST_RBRST (1 << 1) /* clear Rx FIFO */ +#define I2C_RST_RST (1 << 0) /* forcible bus reset */ +#define I2C_TBC 0x40 +#define I2C_RBC 0x44 +#define I2C_TBCM 0x48 +#define I2C_RBCM 0x4c +#define I2C_BRST 0x50 /* bus reset */ +#define I2C_BRST_FOEN (1 << 1) /* normal operation */ +#define I2C_BRST_RSCLO (1 << 0) /* release SCL low fixing */ + +#define FIOCLK 50000000 + +struct uniphier_fi2c_dev { + void __iomem *base; /* register base */ + unsigned long fioclk; /* internal operation clock */ + unsigned long wait_us; /* wait for every byte transfer (us) */ +}; + +static int poll_status(struct uniphier_fi2c_dev *dev, int offset, u32 flag) +{ + int wait = 1000000; /* 1 sec */ + + while (readl(dev->base + offset) & flag) { + if (wait-- < 0) + return -EREMOTEIO; + udelay(1); + } + + return 0; +} + +static int uniphier_fi2c_probe(struct udevice *dev) +{ + fdt_addr_t addr; + fdt_size_t size; + struct uniphier_fi2c_dev *priv = dev_get_priv(dev); + int ret; + + addr = fdtdec_get_addr_size(gd->fdt_blob, dev->of_offset, "reg", + &size); + + priv->base = map_sysmem(addr, size); + + if (!priv->base) + return -ENOMEM; + + priv->fioclk = FIOCLK; + + /* bus forcible reset */ + writel(I2C_RST_RST, priv->base + I2C_RST); + ret = poll_status(priv, I2C_RST, I2C_RST_RST); + if (ret < 0) { + debug("error: fail to reset I2C controller\n"); + return ret; + } + + writel(I2C_BRST_FOEN | I2C_BRST_RSCLO, priv->base + I2C_BRST); + + return 0; +} + +static int uniphier_fi2c_remove(struct udevice *dev) +{ + struct uniphier_fi2c_dev *priv = dev_get_priv(dev); + + unmap_sysmem(priv->base); + + return 0; +} + +static int uniphier_fi2c_child_pre_probe(struct udevice *dev) +{ + struct dm_i2c_chip *i2c_chip = dev_get_parentdata(dev); + + if (dev->of_offset == -1) + return 0; + return i2c_chip_ofdata_to_platdata(gd->fdt_blob, dev->of_offset, + i2c_chip); +} + +static int wait_for_irq(struct uniphier_fi2c_dev *dev, u32 flags, + bool *stop) +{ + u32 irq; + unsigned long wait = dev->wait_us; + int ret = -EREMOTEIO; + + do { + udelay(1); + irq = readl(dev->base + I2C_INT); + } while (!(irq & flags) && wait--); + + if (wait < 0) { + debug("error: time out\n"); + return ret; + } + + if (irq & I2C_INT_AL) { + debug("error: arbitration lost\n"); + *stop = false; + return ret; + } + + if (irq & I2C_INT_NA) { + debug("error: no answer\n"); + return ret; + } + + return 0; +} + +static int uniphier_fi2c_transmit(struct uniphier_fi2c_dev *dev, + uint addr, uint len, const u8 *buf) +{ + int ret, ret2; + const u32 irq_flags = I2C_INT_TE | I2C_INT_NA | I2C_INT_AL; + bool stop = true; + + debug("%s: addr = %x, len = %d\n", __func__, addr, len); + + ret = poll_status(dev, I2C_SR, I2C_SR_DB); + if (ret < 0) { + debug("error: device busy\n"); + return ret; + } + + writel(I2C_DTTX_CMD | addr << 1, dev->base + I2C_DTTX); + + writel(irq_flags, dev->base + I2C_IE); + writel(irq_flags, dev->base + I2C_IC); + + debug("start condition\n"); + writel(I2C_CR_MST | I2C_CR_STA, dev->base + I2C_CR); + + ret = wait_for_irq(dev, irq_flags, &stop); + if (ret < 0) + goto error; + + while (len--) { + debug("sending %x\n", *buf); + writel(*buf++, dev->base + I2C_DTTX); + + writel(irq_flags, dev->base + I2C_IC); + + ret = wait_for_irq(dev, irq_flags, &stop); + if (ret < 0) + goto error; + } + +error: + if (stop) { + debug("stop condition\n"); + writel(I2C_CR_MST | I2C_CR_STO, dev->base + I2C_CR); + } + + writel(irq_flags, dev->base + I2C_IC); + + ret2 = poll_status(dev, I2C_SR, I2C_SR_DB); + if (ret2 < 0) { + debug("error: device busy after operation\n"); + ret = ret ? ret : ret2; + } + + return ret; +} + +static int uniphier_fi2c_receive(struct uniphier_fi2c_dev *dev, + uint addr, uint len, u8 *buf) +{ + int ret, ret2; + const u32 irq_flags = I2C_INT_RB | I2C_INT_NA | I2C_INT_AL; + bool stop = true; + + debug("%s: addr = %x, len = %d\n", __func__, addr, len); + + /* + * In case 'len == 0', only the slave address should be sent + * for probing, which is covered by the transmit function. + */ + if (len == 0) + return uniphier_fi2c_transmit(dev, addr, len, buf); + + ret = poll_status(dev, I2C_SR, I2C_SR_DB); + if (ret < 0) { + debug("error: device busy\n"); + return ret; + } + + writel(I2C_DTTX_CMD | I2C_DTTX_RD | addr << 1, dev->base + I2C_DTTX); + + writel(0, dev->base + I2C_RBC); + writel(irq_flags, dev->base + I2C_IE); + writel(irq_flags, dev->base + I2C_IC); + + debug("start condition\n"); + writel(I2C_CR_MST | I2C_CR_STA | (len == 1 ? I2C_CR_NACK : 0), + dev->base + I2C_CR); + + while (len--) { + ret = wait_for_irq(dev, irq_flags, &stop); + if (ret < 0) + goto error; + + *buf++ = readl(dev->base + I2C_DTRX); + debug("received %x\n", *(buf - 1)); + + if (len == 1) + writel(I2C_CR_MST | I2C_CR_NACK, dev->base + I2C_CR); + + writel(irq_flags, dev->base + I2C_IC); + } + +error: + if (stop) { + debug("stop condition\n"); + writel(I2C_CR_MST | I2C_CR_STO, dev->base + I2C_CR); + } + + writel(irq_flags, dev->base + I2C_IC); + + ret2 = poll_status(dev, I2C_SR, I2C_SR_DB); + if (ret2 < 0) { + debug("error: device busy after operation\n"); + ret = ret ? ret : ret2; + } + + return ret; +} + +static int uniphier_fi2c_xfer(struct udevice *bus, struct i2c_msg *msg, + int nmsgs) +{ + int ret = 0; + struct uniphier_fi2c_dev *dev = dev_get_priv(bus); + + for (; nmsgs > 0; nmsgs--, msg++) { + if (msg->flags & I2C_M_RD) + ret = uniphier_fi2c_receive(dev, msg->addr, + msg->len, msg->buf); + else + ret = uniphier_fi2c_transmit(dev, msg->addr, + msg->len, msg->buf); + + if (ret < 0) + break; + } + + return ret; +} + +static int uniphier_fi2c_set_bus_speed(struct udevice *bus, unsigned int speed) +{ + struct uniphier_fi2c_dev *dev = dev_get_priv(bus); + unsigned int clk_count; + int ret; + + /* max supported frequency is 400 kHz */ + if (speed > 400000) + return -EINVAL; + + ret = poll_status(dev, I2C_SR, I2C_SR_DB); + if (ret < 0) { + debug("error: device busy\n"); + return ret; + } + + /* make sure the bus is idle when change the freqency */ + writel(I2C_BRST_RSCLO, dev->base + I2C_BRST); + + clk_count = dev->fioclk / speed; + + writel(clk_count, dev->base + I2C_CYC); + writel(clk_count / 2, dev->base + I2C_LCTL); + writel(clk_count / 2, dev->base + I2C_SSUT); + writel(clk_count / 16, dev->base + I2C_DSUT); + + writel(I2C_BRST_FOEN | I2C_BRST_RSCLO, dev->base + I2C_BRST); + + dev->wait_us = 20000000 / speed; + + return 0; +} + +static const struct dm_i2c_ops uniphier_fi2c_ops = { + .xfer = uniphier_fi2c_xfer, + .set_bus_speed = uniphier_fi2c_set_bus_speed, +}; + +static const struct udevice_id uniphier_fi2c_of_match[] = { + { .compatible = "panasonic,uniphier-fi2c" }, + {}, +}; + +U_BOOT_DRIVER(uniphier_fi2c) = { + .name = "uniphier-fi2c", + .id = UCLASS_I2C, + .of_match = uniphier_fi2c_of_match, + .probe = uniphier_fi2c_probe, + .remove = uniphier_fi2c_remove, + .per_child_auto_alloc_size = sizeof(struct dm_i2c_chip), + .child_pre_probe = uniphier_fi2c_child_pre_probe, + .priv_auto_alloc_size = sizeof(struct uniphier_fi2c_dev), + .ops = &uniphier_fi2c_ops, +};
Hi Masahiro,
For driver model bits:
default y
help
struct i2c_reg { u32 cr; u32 fifo; ... }
Should use register access in U-Boot.
This is really a timeout isn't it?
if (wait-- < 0)
return -EREMOTEIO;
udelay(1);
fdt_addr_t addr;
fdt_size_t size;
int ret;
&size);
if (!priv->base)
return -ENOMEM;
if (ret < 0) {
return ret;
i2c_chip);
bool *stop)
u32 irq;
do {
udelay(1);
if (wait < 0) {
return ret;
*stop = false;
return ret;
return ret;
int ret, ret2;
bool stop = true;
if (ret < 0) {
return ret;
if (ret < 0)
goto error;
while (len--) {
if (ret < 0)
goto error;
+error:
if (stop) {
if (ret2 < 0) {
return ret;
int ret, ret2;
bool stop = true;
if (len == 0)
if (ret < 0) {
return ret;
while (len--) {
if (ret < 0)
goto error;
if (len == 1)
+error:
if (stop) {
if (ret2 < 0) {
return ret;
int nmsgs)
int ret = 0;
else
if (ret < 0)
break;
return ret;
int ret;
if (speed > 400000)
return -EINVAL;
if (ret < 0) {
return ret;
.id = UCLASS_I2C,
1.9.1
Hi Simon,
On Tue, 23 Dec 2014 12:58:12 -0700 Simon Glass sjg@chromium.org wrote:
Hi Masahiro,
default y
help
I answered in the other reply.
Yes. I will fix this comment.
configs/ph1_ld4_defconfig | 2 ++ configs/ph1_pro4_defconfig | 2 ++ configs/ph1_sld8_defconfig | 2 ++ 3 files changed, 6 insertions(+)
diff --git a/configs/ph1_ld4_defconfig b/configs/ph1_ld4_defconfig index 2e9dd00..86b4b15 100644 --- a/configs/ph1_ld4_defconfig +++ b/configs/ph1_ld4_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_LOADB=y CONFIG_CMD_LOADS=y CONFIG_CMD_FLASH=y CONFIG_CMD_NAND=y +CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_ECHO=y CONFIG_CMD_ITEST=y @@ -34,6 +35,7 @@ CONFIG_SYS_NAND_DENALI_64BIT=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 CONFIG_DM_SERIAL=y CONFIG_UNIPHIER_SERIAL=y +CONFIG_DM_I2C=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/ph1_pro4_defconfig b/configs/ph1_pro4_defconfig index 5dca64b..242bcf9 100644 --- a/configs/ph1_pro4_defconfig +++ b/configs/ph1_pro4_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_LOADB=y CONFIG_CMD_LOADS=y CONFIG_CMD_FLASH=y CONFIG_CMD_NAND=y +CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_ECHO=y CONFIG_CMD_ITEST=y @@ -34,6 +35,7 @@ CONFIG_SYS_NAND_DENALI_64BIT=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 CONFIG_DM_SERIAL=y CONFIG_UNIPHIER_SERIAL=y +CONFIG_DM_I2C=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/ph1_sld8_defconfig b/configs/ph1_sld8_defconfig index 2a6e334..8e95f17 100644 --- a/configs/ph1_sld8_defconfig +++ b/configs/ph1_sld8_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_LOADB=y CONFIG_CMD_LOADS=y CONFIG_CMD_FLASH=y CONFIG_CMD_NAND=y +CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_ECHO=y CONFIG_CMD_ITEST=y @@ -34,6 +35,7 @@ CONFIG_SYS_NAND_DENALI_64BIT=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 CONFIG_DM_SERIAL=y CONFIG_UNIPHIER_SERIAL=y +CONFIG_DM_I2C=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y
To apply this commit, the following must be applied in advance: http://patchwork.ozlabs.org/patch/422543/
include/configs/uniphier.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index 5a53c50..9ad47f6 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -43,6 +43,9 @@ #define CONFIG_SDRAM1_SIZE 0x10000000 #endif
+#define CONFIG_I2C_EEPROM +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 + /* * Support card address map */
Masahiro Yamada
