[U-Boot] [PATCH v4 1/5] spi: cadence_qspi: Ensure spi_calibration is run when sclk change
From f22064087684b04d6d6ff105a4766a0902d361a8 Mon Sep 17 00:00:00 2001
From: Chin Liang See clsee@altera.com Date: Thu, 15 Oct 2015 13:56:45 +0800 Subject: [PATCH 1/5] spi: cadence_qspi: Ensure spi_calibration is run when sclk change
Ensuring spi_calibration is run when there is a change of sclk frequency. This will ensure the qspi flash access works for high sclk frequency
Signed-off-by: Chin Liang See clsee@altera.com Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Dinh Nguyen dinh.linux@gmail.com Cc: Marek Vasut marex@denx.de Cc: Stefan Roese sr@denx.de Cc: Vikas Manocha vikas.manocha@st.com Cc: Jagannadh Teki jteki@openedev.com Cc: Pavel Machek pavel@denx.de Acked-by: Marek Vasut marex@denx.de Reviewed-by: Jagan Teki jteki@openedev.com --- Changes for v4 - shift the checking for requested SCLK to the caller Changes for v3 - no changes Changes for v2 - remove frequency set before calibration - introducing previous_hz to store requested frequency - prevent calibration run when request same frequency --- drivers/spi/cadence_qspi.c | 22 +++++++++++++--------- drivers/spi/cadence_qspi.h | 1 + 2 files changed, 14 insertions(+), 9 deletions(-)
diff --git a/drivers/spi/cadence_qspi.c b/drivers/spi/cadence_qspi.c index 34a0f46..c5a4276 100644 --- a/drivers/spi/cadence_qspi.c +++ b/drivers/spi/cadence_qspi.c @@ -37,9 +37,8 @@ static int cadence_spi_write_speed(struct udevice *bus, uint hz) }
/* Calibration sequence to determine the read data capture delay register */ -static int spi_calibration(struct udevice *bus) +static int spi_calibration(struct udevice *bus, uint hz) { - struct cadence_spi_platdata *plat = bus->platdata; struct cadence_spi_priv *priv = dev_get_priv(bus); void *base = priv->regbase; u8 opcode_rdid = 0x9F; @@ -64,7 +63,7 @@ static int spi_calibration(struct udevice *bus) }
/* use back the intended clock and find low range */ - cadence_spi_write_speed(bus, plat->max_hz); + cadence_spi_write_speed(bus, hz); for (i = 0; i < CQSPI_READ_CAPTURE_MAX_DELAY; i++) { /* Disable QSPI */ cadence_qspi_apb_controller_disable(base); @@ -111,7 +110,7 @@ static int spi_calibration(struct udevice *bus) (range_hi + range_lo) / 2, range_lo, range_hi);
/* just to ensure we do once only when speed or chip select change */ - priv->qspi_calibrated_hz = plat->max_hz; + priv->qspi_calibrated_hz = hz; priv->qspi_calibrated_cs = spi_chip_select(bus);
return 0; @@ -126,14 +125,19 @@ static int cadence_spi_set_speed(struct udevice *bus, uint hz) /* Disable QSPI */ cadence_qspi_apb_controller_disable(priv->regbase);
- cadence_spi_write_speed(bus, hz); - - /* Calibration required for different SCLK speed or chip select */ - if (priv->qspi_calibrated_hz != plat->max_hz || + /* + * Calibration required for different current SCLK speed, requested + * SCLK speed or chip select + */ + if (priv->previous_hz != hz || + priv->qspi_calibrated_hz != hz || priv->qspi_calibrated_cs != spi_chip_select(bus)) { - err = spi_calibration(bus); + err = spi_calibration(bus, hz); if (err) return err; + + /* prevent calibration run when same as previous request */ + priv->previous_hz = hz; }
/* Enable QSPI */ diff --git a/drivers/spi/cadence_qspi.h b/drivers/spi/cadence_qspi.h index 98e57aa..2912e36 100644 --- a/drivers/spi/cadence_qspi.h +++ b/drivers/spi/cadence_qspi.h @@ -38,6 +38,7 @@ struct cadence_spi_priv { int qspi_is_init; unsigned int qspi_calibrated_hz; unsigned int qspi_calibrated_cs; + unsigned int previous_hz; };
/* Functions call declaration */
On Friday, October 16, 2015 at 12:12:16 PM, Chin Liang See wrote:
Hi!
From f22064087684b04d6d6ff105a4766a0902d361a8 Mon Sep 17 00:00:00 2001 From: Chin Liang See clsee@altera.com Date: Thu, 15 Oct 2015 13:56:45 +0800 Subject: [PATCH 1/5] spi: cadence_qspi: Ensure spi_calibration is run when sclk change
Did something funny happen to the altera mail system ? :-)
Best regards, Marek Vasut
Hi Marek,
Hi!
Haha, its fixed now after doing part time IT job :)
Thanks Chin Liang
On Saturday, October 17, 2015 at 02:48:20 PM, Chin Liang See wrote:
Hi Marek,
Hi!
Hi!
sclk change
Chin Liang See
