[U-Boot] [PATCH] Add linux/compiler-gcc5.h to fix builds with gcc5
Hi Tom,
Here is a patch to fix building u-boot with gcc5 (which has landed in Fedora rawhide / F22 recently). Can you please review and merge this ?
Regards,
Hans
Add linux/compiler-gcc5/h from the kernel sources at:
commit 5631b8fba640a4ab2f8a954f63a603fa34eda96b Author: Steven Noonan steven@uplinklabs.net Date: Sat Oct 25 15:09:42 2014 -0700
compiler/gcc4+: Remove inaccurate comment about 'asm goto' miscompiles
Signed-off-by: Hans de Goede hdegoede@redhat.com --- include/linux/compiler-gcc5.h | 65 +++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 65 insertions(+) create mode 100644 include/linux/compiler-gcc5.h
diff --git a/include/linux/compiler-gcc5.h b/include/linux/compiler-gcc5.h new file mode 100644 index 0000000..c8c5659 --- /dev/null +++ b/include/linux/compiler-gcc5.h @@ -0,0 +1,65 @@ +#ifndef __LINUX_COMPILER_H +#error "Please don't include <linux/compiler-gcc5.h> directly, include <linux/compiler.h> instead." +#endif + +#define __used __attribute__((__used__)) +#define __must_check __attribute__((warn_unused_result)) +#define __compiler_offsetof(a, b) __builtin_offsetof(a, b) + +/* Mark functions as cold. gcc will assume any path leading to a call + to them will be unlikely. This means a lot of manual unlikely()s + are unnecessary now for any paths leading to the usual suspects + like BUG(), printk(), panic() etc. [but let's keep them for now for + older compilers] + + Early snapshots of gcc 4.3 don't support this and we can't detect this + in the preprocessor, but we can live with this because they're unreleased. + Maketime probing would be overkill here. + + gcc also has a __attribute__((__hot__)) to move hot functions into + a special section, but I don't see any sense in this right now in + the kernel context */ +#define __cold __attribute__((__cold__)) + +#define __UNIQUE_ID(prefix) __PASTE(__PASTE(__UNIQUE_ID_, prefix), __COUNTER__) + +#ifndef __CHECKER__ +# define __compiletime_warning(message) __attribute__((warning(message))) +# define __compiletime_error(message) __attribute__((error(message))) +#endif /* __CHECKER__ */ + +/* + * Mark a position in code as unreachable. This can be used to + * suppress control flow warnings after asm blocks that transfer + * control elsewhere. + * + * Early snapshots of gcc 4.5 don't support this and we can't detect + * this in the preprocessor, but we can live with this because they're + * unreleased. Really, we need to have autoconf for the kernel. + */ +#define unreachable() __builtin_unreachable() + +/* Mark a function definition as prohibited from being cloned. */ +#define __noclone __attribute__((__noclone__)) + +/* + * Tell the optimizer that something else uses this function or variable. + */ +#define __visible __attribute__((externally_visible)) + +/* + * GCC 'asm goto' miscompiles certain code sequences: + * + * http://gcc.gnu.org/bugzilla/show_bug.cgi?id=58670 + * + * Work it around via a compiler barrier quirk suggested by Jakub Jelinek. + * + * (asm goto is automatically volatile - the naming reflects this.) + */ +#define asm_volatile_goto(x...) do { asm goto(x); asm (""); } while (0) + +#ifdef CONFIG_ARCH_USE_BUILTIN_BSWAP +#define __HAVE_BUILTIN_BSWAP32__ +#define __HAVE_BUILTIN_BSWAP64__ +#define __HAVE_BUILTIN_BSWAP16__ +#endif /* CONFIG_ARCH_USE_BUILTIN_BSWAP */
Hans de Goede
