[U-Boot] [PATCH] fsl_esdhc: Add no-snoop config for default init
cfg->no_snoop was available only through custom fsl_esdhc_mmc init functions. Add a config options to make it available also through the default init.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com Cc: Andy Fleming afleming@gmail.com Cc: Stefano Babic sbabic@denx.de Cc: Kim Phillips kim.phillips@freescale.com --- .../drivers/mmc/fsl_esdhc.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git u-boot-4d3c95f.orig/drivers/mmc/fsl_esdhc.c u-boot-4d3c95f/drivers/mmc/fsl_esdhc.c index b6c969d..21154e5 100644 --- u-boot-4d3c95f.orig/drivers/mmc/fsl_esdhc.c +++ u-boot-4d3c95f/drivers/mmc/fsl_esdhc.c @@ -597,6 +597,9 @@ int fsl_esdhc_mmc_init(bd_t *bis) cfg = malloc(sizeof(struct fsl_esdhc_cfg)); memset(cfg, 0, sizeof(struct fsl_esdhc_cfg)); cfg->esdhc_base = CONFIG_SYS_FSL_ESDHC_ADDR; +#ifdef CONFIG_SYS_FSL_ESDHC_NO_SNOOP + cfg->no_snoop = 1; +#endif return fsl_esdhc_initialize(bis, cfg); }
Hi Benoît,
- cfg->no_snoop = 1;
Using a structure to setup the controller avoids to add further CONFIG_ switch. I do not find the needs to have both. Why do you need ?
Best regards, Stefano Babic
Hi Stefano,
Hi Benoît,
fsl_esdhc_mmc_init() exists, so it should give access to all features. Moreover, it's shorter to #define a config option than to create custom fsl_esdhc_mmc init functions when only a single eSDHC instance is needed.
Besides that, the cache snooping feature is not available on i.MX, which means that without CONFIG_SYS_FSL_ESDHC_NO_SNOOP or an equivalent, boards using fsl_esdhc_mmc_init() will make esdhc_init() access a reserved bit of a reserved register, which is not really recommended.
On i.MX, the patch could also be improved by not making this option available, but behaving as if it were set.
Best regards, Benoît
On 11/08/2012 16:39, Benoît Thébaudeau wrote:
Hi Stefano,
This was left for compatibility with PowerPC SOCs.
However, the number of CONFIG_ continues to increase, often not well documented.
It should be masked by the i.MX code. You add CONFIG_SYS_FSL_ESDHC_NO_SNOOP and this is set inside the board configuration file. But this is not a board configuration option, rather a SOC option. Then it should the initialization code of i.MX that should hide this bit to the board itself.
Instead of this, I think it is better to change cpu_mmc_init() in arch/arm/cpu/armv7/imx-common/cpu.c, setting the structure and fixing the soop bit to 1, because i.MX has not this feature. Then all i.MX boards using ESDHC have the no_snoop bit set.
Right. It should not be configurable. We know that the i.MXs have no snoop cabability.
Hi Stefano,
Hi Stefano,
OK.
OK.
That could be a solution. However, that would have to be done for i.MX25 and i.MX35 too (I have patches to add/fix eSDHC support for these that I will post shortly), which means more duplicated code that should rather be centralized somewhere.
The solution I would like would be to have some automatic ARCH_IMX (or ARCH_MXC) config like on Linux. Then the fsl_esdhc driver could use this config to remove all cache snooping stuff from its code and from struct fsl_esdhc_cfg.
The i.MX board files would have to be updated to no longer refer to the no_snoop field. struct fsl_esdhc_cfg would then have only one field for i.MX, but this is not really an issue.
ARCH_IMX could be defined in all imx-regs.h files. Or the fsl_esdhc driver could simply use a #if testing all the supported CONFIG_MX*.
What do you think?
Am 11/08/2012 19:59, schrieb Benoît Thébaudeau:
Hi Stefano,
Hi Benoît,
Ok, I'll wait for your patches ;-)
Yes, this is no an issue.
Let the fsl_edhc checking for CONFIG_MX* results clear for us today, but nobody will remember after some times and if the checked CONFIG_MX* will be changed, it will have drawbacks not so evident on MMC. I prefer the first solution, adding an entry to imx-regs.h.
Define ARCH_IMX for i.MX devices. This is useful to identify features or behaviors common to all i.MX SoCs.
The i.MX28 is omitted because its architecture is a bit different (like imx/mxc vs. mxs in Linux).
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com Cc: Stefano Babic sbabic@denx.de Cc: Andy Fleming afleming@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- .../arch/arm/include/asm/arch-imx/imx-regs.h | 3 +++ .../arch/arm/include/asm/arch-mx25/imx-regs.h | 2 ++ .../arch/arm/include/asm/arch-mx27/imx-regs.h | 2 ++ .../arch/arm/include/asm/arch-mx31/imx-regs.h | 2 ++ .../arch/arm/include/asm/arch-mx35/imx-regs.h | 2 ++ .../arch/arm/include/asm/arch-mx5/imx-regs.h | 2 ++ .../arch/arm/include/asm/arch-mx6/imx-regs.h | 2 ++ 7 files changed, 15 insertions(+)
diff --git u-boot-4d3c95f.orig/arch/arm/include/asm/arch-imx/imx-regs.h u-boot-4d3c95f/arch/arm/include/asm/arch-imx/imx-regs.h index ec94ba9..35ebf82 100644 --- u-boot-4d3c95f.orig/arch/arm/include/asm/arch-imx/imx-regs.h +++ u-boot-4d3c95f/arch/arm/include/asm/arch-imx/imx-regs.h @@ -1,5 +1,8 @@ #ifndef _IMX_REGS_H #define _IMX_REGS_H + +#define ARCH_IMX + /* ------------------------------------------------------------------------ * Motorola IMX system registers * ------------------------------------------------------------------------ diff --git u-boot-4d3c95f.orig/arch/arm/include/asm/arch-mx25/imx-regs.h u-boot-4d3c95f/arch/arm/include/asm/arch-mx25/imx-regs.h index cf925d7..3e48fe9 100644 --- u-boot-4d3c95f.orig/arch/arm/include/asm/arch-mx25/imx-regs.h +++ u-boot-4d3c95f/arch/arm/include/asm/arch-mx25/imx-regs.h @@ -172,6 +172,8 @@ struct aips_regs {
#endif
+#define ARCH_IMX + /* AIPS 1 */ #define IMX_AIPS1_BASE (0x43F00000) #define IMX_MAX_BASE (0x43F04000) diff --git u-boot-4d3c95f.orig/arch/arm/include/asm/arch-mx27/imx-regs.h u-boot-4d3c95f/arch/arm/include/asm/arch-mx27/imx-regs.h index ced5b2a..d095c17 100644 --- u-boot-4d3c95f.orig/arch/arm/include/asm/arch-mx27/imx-regs.h +++ u-boot-4d3c95f/arch/arm/include/asm/arch-mx27/imx-regs.h @@ -217,6 +217,8 @@ struct fuse_bank0_regs {
#endif
+#define ARCH_IMX + #define IMX_IO_BASE 0x10000000
#define IMX_AIPI1_BASE (0x00000 + IMX_IO_BASE) diff --git u-boot-4d3c95f.orig/arch/arm/include/asm/arch-mx31/imx-regs.h u-boot-4d3c95f/arch/arm/include/asm/arch-mx31/imx-regs.h index 7ddbbd6..59fb7c4 100644 --- u-boot-4d3c95f.orig/arch/arm/include/asm/arch-mx31/imx-regs.h +++ u-boot-4d3c95f/arch/arm/include/asm/arch-mx31/imx-regs.h @@ -541,6 +541,8 @@ struct esdc_regs {
#endif
+#define ARCH_IMX + #define __REG(x) (*((volatile u32 *)(x))) #define __REG16(x) (*((volatile u16 *)(x))) #define __REG8(x) (*((volatile u8 *)(x))) diff --git u-boot-4d3c95f.orig/arch/arm/include/asm/arch-mx35/imx-regs.h u-boot-4d3c95f/arch/arm/include/asm/arch-mx35/imx-regs.h index 3146006..d80d52f 100644 --- u-boot-4d3c95f.orig/arch/arm/include/asm/arch-mx35/imx-regs.h +++ u-boot-4d3c95f/arch/arm/include/asm/arch-mx35/imx-regs.h @@ -25,6 +25,8 @@ #ifndef __ASM_ARCH_MX35_H #define __ASM_ARCH_MX35_H
+#define ARCH_IMX + /* * IRAM */ diff --git u-boot-4d3c95f.orig/arch/arm/include/asm/arch-mx5/imx-regs.h u-boot-4d3c95f/arch/arm/include/asm/arch-mx5/imx-regs.h index 7f66b61..24daef0 100644 --- u-boot-4d3c95f.orig/arch/arm/include/asm/arch-mx5/imx-regs.h +++ u-boot-4d3c95f/arch/arm/include/asm/arch-mx5/imx-regs.h @@ -23,6 +23,8 @@ #ifndef __ASM_ARCH_MX5_IMX_REGS_H__ #define __ASM_ARCH_MX5_IMX_REGS_H__
+#define ARCH_IMX + #if defined(CONFIG_MX51) #define IRAM_BASE_ADDR 0x1FFE0000 /* internal ram */ #define IPU_SOC_BASE_ADDR 0x40000000 diff --git u-boot-4d3c95f.orig/arch/arm/include/asm/arch-mx6/imx-regs.h u-boot-4d3c95f/arch/arm/include/asm/arch-mx6/imx-regs.h index 5d77603..1edfc25 100644 --- u-boot-4d3c95f.orig/arch/arm/include/asm/arch-mx6/imx-regs.h +++ u-boot-4d3c95f/arch/arm/include/asm/arch-mx6/imx-regs.h @@ -19,6 +19,8 @@ #ifndef __ASM_ARCH_MX6_IMX_REGS_H__ #define __ASM_ARCH_MX6_IMX_REGS_H__
+#define ARCH_IMX + #define CONFIG_SYS_CACHELINE_SIZE 32
#define ROMCP_ARB_BASE_ADDR 0x00000000
The cache snooping feature of Freescale's eSDHC IP is not available on i.MX, so disable it globally for this architecture. This avoids setting no_snoop for all i.MX boards, and it prevents setting a reserved bit of a reserved register if fsl_esdhc_mmc_init() were used for an i.MX board.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com Cc: Andy Fleming afleming@gmail.com Cc: Stefano Babic sbabic@denx.de Cc: Kim Phillips kim.phillips@freescale.com --- .../board/efikamx/efikamx.c | 4 ++-- .../board/esg/ima3-mx53/ima3-mx53.c | 2 +- .../board/freescale/mx51evk/mx51evk.c | 4 ++-- .../board/freescale/mx53ard/mx53ard.c | 4 ++-- .../board/freescale/mx53evk/mx53evk.c | 4 ++-- .../board/freescale/mx53loco/mx53loco.c | 4 ++-- .../board/freescale/mx53smd/mx53smd.c | 2 +- .../board/freescale/mx6qarm2/mx6qarm2.c | 4 ++-- .../board/freescale/mx6qsabrelite/mx6qsabrelite.c | 4 ++-- .../board/ttcontrol/vision2/vision2.c | 2 +- .../drivers/mmc/fsl_esdhc.c | 2 ++ .../include/fsl_esdhc.h | 3 +++ 12 files changed, 22 insertions(+), 17 deletions(-)
diff --git u-boot-4d3c95f.orig/board/efikamx/efikamx.c u-boot-4d3c95f/board/efikamx/efikamx.c index e88b2ed..1e643d7 100644 --- u-boot-4d3c95f.orig/board/efikamx/efikamx.c +++ u-boot-4d3c95f/board/efikamx/efikamx.c @@ -302,8 +302,8 @@ static inline void power_init(void) { } */ #ifdef CONFIG_FSL_ESDHC struct fsl_esdhc_cfg esdhc_cfg[2] = { - {MMC_SDHC1_BASE_ADDR, 1}, - {MMC_SDHC2_BASE_ADDR, 1}, + {MMC_SDHC1_BASE_ADDR}, + {MMC_SDHC2_BASE_ADDR}, };
static inline uint32_t efika_mmc_cd(void) diff --git u-boot-4d3c95f.orig/board/esg/ima3-mx53/ima3-mx53.c u-boot-4d3c95f/board/esg/ima3-mx53/ima3-mx53.c index 9ecf31d..e947330 100644 --- u-boot-4d3c95f.orig/board/esg/ima3-mx53/ima3-mx53.c +++ u-boot-4d3c95f/board/esg/ima3-mx53/ima3-mx53.c @@ -172,7 +172,7 @@ static void setup_iomux_fec(void) }
#ifdef CONFIG_FSL_ESDHC -struct fsl_esdhc_cfg esdhc_cfg = { MMC_SDHC1_BASE_ADDR, 1 }; +struct fsl_esdhc_cfg esdhc_cfg = { MMC_SDHC1_BASE_ADDR };
int board_mmc_getcd(struct mmc *mmc) { diff --git u-boot-4d3c95f.orig/board/freescale/mx51evk/mx51evk.c u-boot-4d3c95f/board/freescale/mx51evk/mx51evk.c index 514a7ac..7e50688 100644 --- u-boot-4d3c95f.orig/board/freescale/mx51evk/mx51evk.c +++ u-boot-4d3c95f/board/freescale/mx51evk/mx51evk.c @@ -47,8 +47,8 @@ DECLARE_GLOBAL_DATA_PTR;
#ifdef CONFIG_FSL_ESDHC struct fsl_esdhc_cfg esdhc_cfg[2] = { - {MMC_SDHC1_BASE_ADDR, 1}, - {MMC_SDHC2_BASE_ADDR, 1}, + {MMC_SDHC1_BASE_ADDR}, + {MMC_SDHC2_BASE_ADDR}, }; #endif
diff --git u-boot-4d3c95f.orig/board/freescale/mx53ard/mx53ard.c u-boot-4d3c95f/board/freescale/mx53ard/mx53ard.c index 2d21584..6fea7e5 100644 --- u-boot-4d3c95f.orig/board/freescale/mx53ard/mx53ard.c +++ u-boot-4d3c95f/board/freescale/mx53ard/mx53ard.c @@ -79,8 +79,8 @@ static void setup_iomux_uart(void)
#ifdef CONFIG_FSL_ESDHC struct fsl_esdhc_cfg esdhc_cfg[2] = { - {MMC_SDHC1_BASE_ADDR, 1 }, - {MMC_SDHC2_BASE_ADDR, 1 }, + {MMC_SDHC1_BASE_ADDR}, + {MMC_SDHC2_BASE_ADDR}, };
int board_mmc_getcd(struct mmc *mmc) diff --git u-boot-4d3c95f.orig/board/freescale/mx53evk/mx53evk.c u-boot-4d3c95f/board/freescale/mx53evk/mx53evk.c index 8a6e31d..2a90a4c 100644 --- u-boot-4d3c95f.orig/board/freescale/mx53evk/mx53evk.c +++ u-boot-4d3c95f/board/freescale/mx53evk/mx53evk.c @@ -204,8 +204,8 @@ static void setup_iomux_fec(void)
#ifdef CONFIG_FSL_ESDHC struct fsl_esdhc_cfg esdhc_cfg[2] = { - {MMC_SDHC1_BASE_ADDR, 1}, - {MMC_SDHC3_BASE_ADDR, 1}, + {MMC_SDHC1_BASE_ADDR}, + {MMC_SDHC3_BASE_ADDR}, };
int board_mmc_getcd(struct mmc *mmc) diff --git u-boot-4d3c95f.orig/board/freescale/mx53loco/mx53loco.c u-boot-4d3c95f/board/freescale/mx53loco/mx53loco.c index cbdcfad..3195b22 100644 --- u-boot-4d3c95f.orig/board/freescale/mx53loco/mx53loco.c +++ u-boot-4d3c95f/board/freescale/mx53loco/mx53loco.c @@ -165,8 +165,8 @@ static void setup_iomux_fec(void)
int board_mmc_getcd(struct mmc *mmc) diff --git u-boot-4d3c95f.orig/board/freescale/mx53smd/mx53smd.c u-boot-4d3c95f/board/freescale/mx53smd/mx53smd.c index c237980..b816377 100644 --- u-boot-4d3c95f.orig/board/freescale/mx53smd/mx53smd.c +++ u-boot-4d3c95f/board/freescale/mx53smd/mx53smd.c @@ -129,7 +129,7 @@ static void setup_iomux_fec(void)
#ifdef CONFIG_FSL_ESDHC struct fsl_esdhc_cfg esdhc_cfg[1] = { - {MMC_SDHC1_BASE_ADDR, 1}, + {MMC_SDHC1_BASE_ADDR}, };
int board_mmc_getcd(struct mmc *mmc) diff --git u-boot-4d3c95f.orig/board/freescale/mx6qarm2/mx6qarm2.c u-boot-4d3c95f/board/freescale/mx6qarm2/mx6qarm2.c index 340c4c4..69f5781 100644 --- u-boot-4d3c95f.orig/board/freescale/mx6qarm2/mx6qarm2.c +++ u-boot-4d3c95f/board/freescale/mx6qarm2/mx6qarm2.c @@ -116,8 +116,8 @@ static void setup_iomux_enet(void)
#ifdef CONFIG_FSL_ESDHC struct fsl_esdhc_cfg usdhc_cfg[2] = { - {USDHC3_BASE_ADDR, 1}, - {USDHC4_BASE_ADDR, 1}, + {USDHC3_BASE_ADDR}, + {USDHC4_BASE_ADDR}, };
int board_mmc_getcd(struct mmc *mmc) diff --git u-boot-4d3c95f.orig/board/freescale/mx6qsabrelite/mx6qsabrelite.c u-boot-4d3c95f/board/freescale/mx6qsabrelite/mx6qsabrelite.c index 01e5083..c40db59 100644 --- u-boot-4d3c95f.orig/board/freescale/mx6qsabrelite/mx6qsabrelite.c +++ u-boot-4d3c95f/board/freescale/mx6qsabrelite/mx6qsabrelite.c @@ -237,8 +237,8 @@ int board_ehci_hcd_init(int port)
int board_mmc_getcd(struct mmc *mmc) diff --git u-boot-4d3c95f.orig/board/ttcontrol/vision2/vision2.c u-boot-4d3c95f/board/ttcontrol/vision2/vision2.c index d68bef7..d4ca510 100644 --- u-boot-4d3c95f.orig/board/ttcontrol/vision2/vision2.c +++ u-boot-4d3c95f/board/ttcontrol/vision2/vision2.c @@ -521,7 +521,7 @@ static void setup_fec(void) }
int get_mmc_getcd(u8 *cd, struct mmc *mmc) diff --git u-boot-4d3c95f.orig/drivers/mmc/fsl_esdhc.c u-boot-4d3c95f/drivers/mmc/fsl_esdhc.c index b6c969d..efdc6be 100644 --- u-boot-4d3c95f.orig/drivers/mmc/fsl_esdhc.c +++ u-boot-4d3c95f/drivers/mmc/fsl_esdhc.c @@ -479,9 +479,11 @@ static int esdhc_init(struct mmc *mmc) while ((esdhc_read32(®s->sysctl) & SYSCTL_RSTA) && --timeout) udelay(1000);
+#ifndef ARCH_IMX /* Enable cache snooping */ if (cfg && !cfg->no_snoop) esdhc_write32(®s->scr, 0x00000040); +#endif
esdhc_write32(®s->sysctl, SYSCTL_HCKEN | SYSCTL_IPGEN);
diff --git u-boot-4d3c95f.orig/include/fsl_esdhc.h u-boot-4d3c95f/include/fsl_esdhc.h index 0e26558..44f9f06 100644 --- u-boot-4d3c95f.orig/include/fsl_esdhc.h +++ u-boot-4d3c95f/include/fsl_esdhc.h @@ -26,6 +26,7 @@ #ifndef __FSL_ESDHC_H__ #define __FSL_ESDHC_H__
+#include <config.h> #include <asm/errno.h> #include <asm/byteorder.h>
@@ -167,7 +168,9 @@
struct fsl_esdhc_cfg { u32 esdhc_base; +#ifndef ARCH_IMX u32 no_snoop; +#endif };
/* Select the correct accessors depending on endianess */
Hi Benoît,
@@ -167,7 +168,9 @@
Why don't you get rid of no_snoop at all ? Using ARCH_IMX is not needed anymore.
Hi Stefano,
Hi Benoît,
@@ -167,7 +168,9 @@
Because I didn't know if disabling cache snooping could be a useful option or not for architectures other than i.MX, so I preferred to leave it just in case, even if it seems to be unused.
But if you are certain that disabling cache snooping can not be useful for architectures other than i.MX (now or in the future, for boards in or out of tree), I can completely remove no_snoop. Just tell me.
Perhaps you have a rule such as "remove any stuff that is unused in mainstream".
I introduce no_snoop when I adapted the driver for iMX. I do not see PowerPC boards setting this bit.
And checking this, it seems to me that code in arch/arm/cpu/armv7/imx-common/cpu.c is wrong, because cpu_mmc_init() does not set the bit and the scr register is set (or could be set) even for i.MX6 SOCs. Maybe writing at this adress does not cause problems, but it seems wrong. You patch then fixes also this issue.
IMHO you can drop it.
It would be nice to have it ;-)
The cache snooping feature of Freescale's eSDHC IP is not available on i.MX, so disable it globally for this architecture. This avoids setting no_snoop for all i.MX boards, and it prevents setting a reserved bit of a reserved register if fsl_esdhc_mmc_init() is used on i.MX, like in arch/arm/cpu/armv7/imx-common/cpu.c/cpu_mmc_init().
Since no_snoop was only used on i.MX, get rid of it BTW.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com Cc: Andy Fleming afleming@gmail.com Cc: Stefano Babic sbabic@denx.de Cc: Kim Phillips kim.phillips@freescale.com --- Changes for v2: - Get rid of no_snoop.
.../board/efikamx/efikamx.c | 4 ++-- .../board/esg/ima3-mx53/ima3-mx53.c | 2 +- .../board/freescale/mx51evk/mx51evk.c | 4 ++-- .../board/freescale/mx53ard/mx53ard.c | 4 ++-- .../board/freescale/mx53evk/mx53evk.c | 4 ++-- .../board/freescale/mx53loco/mx53loco.c | 4 ++-- .../board/freescale/mx53smd/mx53smd.c | 2 +- .../board/freescale/mx6qarm2/mx6qarm2.c | 4 ++-- .../board/freescale/mx6qsabrelite/mx6qsabrelite.c | 4 ++-- .../board/ttcontrol/vision2/vision2.c | 2 +- .../drivers/mmc/fsl_esdhc.c | 5 +++-- .../include/fsl_esdhc.h | 1 - 12 files changed, 20 insertions(+), 20 deletions(-)
int get_mmc_getcd(u8 *cd, struct mmc *mmc) diff --git u-boot-4d3c95f.orig/drivers/mmc/fsl_esdhc.c u-boot-4d3c95f/drivers/mmc/fsl_esdhc.c index b6c969d..1ed89a3 100644 --- u-boot-4d3c95f.orig/drivers/mmc/fsl_esdhc.c +++ u-boot-4d3c95f/drivers/mmc/fsl_esdhc.c @@ -479,9 +479,10 @@ static int esdhc_init(struct mmc *mmc) while ((esdhc_read32(®s->sysctl) & SYSCTL_RSTA) && --timeout) udelay(1000);
+#ifndef ARCH_IMX /* Enable cache snooping */ - if (cfg && !cfg->no_snoop) - esdhc_write32(®s->scr, 0x00000040); + esdhc_write32(®s->scr, 0x00000040); +#endif
diff --git u-boot-4d3c95f.orig/include/fsl_esdhc.h u-boot-4d3c95f/include/fsl_esdhc.h index 0e26558..4e321e7 100644 --- u-boot-4d3c95f.orig/include/fsl_esdhc.h +++ u-boot-4d3c95f/include/fsl_esdhc.h @@ -167,7 +167,6 @@
struct fsl_esdhc_cfg { u32 esdhc_base; - u32 no_snoop; };
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com Cc: Andy Fleming afleming@gmail.com Cc: Stefano Babic sbabic@denx.de Cc: Kim Phillips kim.phillips@freescale.com --- Changes for v2: - Get rid of no_snoop. Changes for v3: - Rename ARCH_IMX to ARCH_MXC to emphasize the difference between mxc and mxs.
int get_mmc_getcd(u8 *cd, struct mmc *mmc) diff --git u-boot-4d3c95f.orig/drivers/mmc/fsl_esdhc.c u-boot-4d3c95f/drivers/mmc/fsl_esdhc.c index b6c969d..3f8d30d 100644 --- u-boot-4d3c95f.orig/drivers/mmc/fsl_esdhc.c +++ u-boot-4d3c95f/drivers/mmc/fsl_esdhc.c @@ -479,9 +479,10 @@ static int esdhc_init(struct mmc *mmc) while ((esdhc_read32(®s->sysctl) & SYSCTL_RSTA) && --timeout) udelay(1000);
+#ifndef ARCH_MXC /* Enable cache snooping */ - if (cfg && !cfg->no_snoop) - esdhc_write32(®s->scr, 0x00000040); + esdhc_write32(®s->scr, 0x00000040); +#endif
On Mon, Aug 13, 2012 at 11:18 AM, Benoît Thébaudeau benoit.thebaudeau@advansee.com wrote:
Wouldn't be better to use ARCH_MXC in this case?
Define ARCH_MXC for i.MX devices. This is useful to identify features or behaviors common to all i.MX SoCs.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com Cc: Stefano Babic sbabic@denx.de Cc: Andy Fleming afleming@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- Changes for v2: None. Changes for v3: - Rename ARCH_IMX to ARCH_MXC to emphasize the difference between mxc and mxs.
diff --git u-boot-4d3c95f.orig/arch/arm/include/asm/arch-imx/imx-regs.h u-boot-4d3c95f/arch/arm/include/asm/arch-imx/imx-regs.h index ec94ba9..4de0779 100644 --- u-boot-4d3c95f.orig/arch/arm/include/asm/arch-imx/imx-regs.h +++ u-boot-4d3c95f/arch/arm/include/asm/arch-imx/imx-regs.h @@ -1,5 +1,8 @@ #ifndef _IMX_REGS_H #define _IMX_REGS_H + +#define ARCH_MXC + /* ------------------------------------------------------------------------ * Motorola IMX system registers * ------------------------------------------------------------------------ diff --git u-boot-4d3c95f.orig/arch/arm/include/asm/arch-mx25/imx-regs.h u-boot-4d3c95f/arch/arm/include/asm/arch-mx25/imx-regs.h index cf925d7..672f9d7 100644 --- u-boot-4d3c95f.orig/arch/arm/include/asm/arch-mx25/imx-regs.h +++ u-boot-4d3c95f/arch/arm/include/asm/arch-mx25/imx-regs.h @@ -172,6 +172,8 @@ struct aips_regs {
#endif
+#define ARCH_MXC + /* AIPS 1 */ #define IMX_AIPS1_BASE (0x43F00000) #define IMX_MAX_BASE (0x43F04000) diff --git u-boot-4d3c95f.orig/arch/arm/include/asm/arch-mx27/imx-regs.h u-boot-4d3c95f/arch/arm/include/asm/arch-mx27/imx-regs.h index ced5b2a..546b8a1 100644 --- u-boot-4d3c95f.orig/arch/arm/include/asm/arch-mx27/imx-regs.h +++ u-boot-4d3c95f/arch/arm/include/asm/arch-mx27/imx-regs.h @@ -217,6 +217,8 @@ struct fuse_bank0_regs {
#endif
+#define ARCH_MXC + #define IMX_IO_BASE 0x10000000
#define IMX_AIPI1_BASE (0x00000 + IMX_IO_BASE) diff --git u-boot-4d3c95f.orig/arch/arm/include/asm/arch-mx31/imx-regs.h u-boot-4d3c95f/arch/arm/include/asm/arch-mx31/imx-regs.h index 7ddbbd6..766049b 100644 --- u-boot-4d3c95f.orig/arch/arm/include/asm/arch-mx31/imx-regs.h +++ u-boot-4d3c95f/arch/arm/include/asm/arch-mx31/imx-regs.h @@ -541,6 +541,8 @@ struct esdc_regs {
#endif
+#define ARCH_MXC + #define __REG(x) (*((volatile u32 *)(x))) #define __REG16(x) (*((volatile u16 *)(x))) #define __REG8(x) (*((volatile u8 *)(x))) diff --git u-boot-4d3c95f.orig/arch/arm/include/asm/arch-mx35/imx-regs.h u-boot-4d3c95f/arch/arm/include/asm/arch-mx35/imx-regs.h index 3146006..d6d7225 100644 --- u-boot-4d3c95f.orig/arch/arm/include/asm/arch-mx35/imx-regs.h +++ u-boot-4d3c95f/arch/arm/include/asm/arch-mx35/imx-regs.h @@ -25,6 +25,8 @@ #ifndef __ASM_ARCH_MX35_H #define __ASM_ARCH_MX35_H
+#define ARCH_MXC + /* * IRAM */ diff --git u-boot-4d3c95f.orig/arch/arm/include/asm/arch-mx5/imx-regs.h u-boot-4d3c95f/arch/arm/include/asm/arch-mx5/imx-regs.h index 7f66b61..fb8668f 100644 --- u-boot-4d3c95f.orig/arch/arm/include/asm/arch-mx5/imx-regs.h +++ u-boot-4d3c95f/arch/arm/include/asm/arch-mx5/imx-regs.h @@ -23,6 +23,8 @@ #ifndef __ASM_ARCH_MX5_IMX_REGS_H__ #define __ASM_ARCH_MX5_IMX_REGS_H__
+#define ARCH_MXC + #if defined(CONFIG_MX51) #define IRAM_BASE_ADDR 0x1FFE0000 /* internal ram */ #define IPU_SOC_BASE_ADDR 0x40000000 diff --git u-boot-4d3c95f.orig/arch/arm/include/asm/arch-mx6/imx-regs.h u-boot-4d3c95f/arch/arm/include/asm/arch-mx6/imx-regs.h index 5d77603..76fab09 100644 --- u-boot-4d3c95f.orig/arch/arm/include/asm/arch-mx6/imx-regs.h +++ u-boot-4d3c95f/arch/arm/include/asm/arch-mx6/imx-regs.h @@ -19,6 +19,8 @@ #ifndef __ASM_ARCH_MX6_IMX_REGS_H__ #define __ASM_ARCH_MX6_IMX_REGS_H__
+#define ARCH_MXC + #define CONFIG_SYS_CACHELINE_SIZE 32
Hi Benoît,
I checked again this patch and I already set this patch in patchwork as "merged" (=awaiting upstream), but I could not find it in u-boot-imx. Something went wrong..
I have applied it now to u-boot-imx.
On 11/08/2012 19:59, Benoît Thébaudeau wrote:
Hi Benoît,
can I ask you which kind of problems you have seen on a i.MX35 ? I was curious after your e-amil and I enabled the FSL_ESDHC driver on a mx35pdk - it seems working out of the box, I have not changed the driver.
Hi Stefano,
Hi Benoît,
Yes, it's not a big deal. The driver itself is fine. The issues are clock and init issues in the mx25- and mx35-specific files (clock.c, generic.c and the associated headers I think). I don't remember precisely what applied to mx25 and/or mx35, but what I fixed is: - init code referring to mxc mmc instead of fsl esdhc, - wrong handling of the cpu_mmc_init return value in some cases, - wrong source clock reported to the fsl_esdhc driver (not the eSDHC clock, and not making any difference between the clocks of the various eSDHC instances), so that if it works it's only by chance, and the actual SD clock will likely be different from what mmcinfo reports, depending on the selected board clock dividers.
Benoît Thébaudeau
Otavio Salvador
Stefano Babic
stefano babic
