[PATCH] dm: serial: introduce puts hook
Introduce puts hook for dm serial driver.
Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/serial/serial-uclass.c | 13 +++++++++++-- include/serial.h | 8 ++++++++ 2 files changed, 19 insertions(+), 2 deletions(-)
diff --git a/drivers/serial/serial-uclass.c b/drivers/serial/serial-uclass.c index 7703c67492..b6a7502ac8 100644 --- a/drivers/serial/serial-uclass.c +++ b/drivers/serial/serial-uclass.c @@ -189,8 +189,17 @@ static void _serial_putc(struct udevice *dev, char ch)
static void _serial_puts(struct udevice *dev, const char *str) { - while (*str) - _serial_putc(dev, *str++); + struct dm_serial_ops *ops = serial_get_ops(dev); + int err; + + if (ops->puts) { + do { + err = ops->puts(dev, str); + } while (err == -EAGAIN); + } else { + while (*str) + _serial_putc(dev, *str++); + } }
static int __serial_getc(struct udevice *dev) diff --git a/include/serial.h b/include/serial.h index 54b21a0470..0b40b27526 100644 --- a/include/serial.h +++ b/include/serial.h @@ -186,6 +186,14 @@ struct dm_serial_ops { * @return character (0..255), -ve on error */ int (*getc)(struct udevice *dev); + /** + * puts() - puts a string + * + * @dev: Device pointer + * @str: string to write + * @return 0 if OK, -ve on error + */ + int (*puts)(struct udevice *dev, const char *str); /** * putc() - Write a character *
Hi Peng,
I'm just wondering why we need this? Isn't serial_putc() enough?
Hi Simon,
Subject: Re: [PATCH] dm: serial: introduce puts hook
Hi Peng,
This is to let u-boot could run in a XEN hypervisor DomU virtual machine. It is low efficiently if each time, we use putc to let xen dom0 print uboot log.
We could pass a string, not a char to improve performance.
Thanks, Peng.
Hi Peng,
On Mon, 4 May 2020 at 08:24, Peng Fan peng.fan@nxp.com wrote:
Hi Simon,
Hi Peng,
OK that is the sort of thing that should be in the commit message :-)
If we are going to do that, I think it would be better to add a write() call, with a length. It should return the number of bytes written, since sometimes the port might be full.
The uclass itself needs a serial_write() call which would then fall back to writing characters if the driver doesn't have the write method.
Also should have a test.
Peng Fan
