[PATCH v2 2/2] config: Adjust Phytec imx8mm module config to support NVME disk
This change adds support for PCIe connected nvme disk - phyBOARD-Polis base board.
One needs to call following commands in u-boot:
pci enum nvme scan nvme info
And then ones to access proper file system (like fat[ls|load|write], ext4[ls|load|write]).
Signed-off-by: Lukasz Majewski lukma@denx.de --- Changes for v2: - Remove not needed adjustment for CONFIG_CYCLIC_MAX_CPU_TIME_US=1000
--- configs/phycore-imx8mm_defconfig | 10 +++++++++- 1 file changed, 9 insertions(+), 1 deletion(-)
diff --git a/configs/phycore-imx8mm_defconfig b/configs/phycore-imx8mm_defconfig index 22d419024f..a2d79a6aa7 100644 --- a/configs/phycore-imx8mm_defconfig +++ b/configs/phycore-imx8mm_defconfig @@ -12,6 +12,7 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="imx8mm-phyboard-polis-rdk" CONFIG_SPL_TEXT_BASE=0x7E1000 CONFIG_TARGET_PHYCORE_IMX8MM=y +CONFIG_DM_RESET=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_SPL_MMC=y CONFIG_SPL_SERIAL=y @@ -23,6 +24,7 @@ CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL=y CONFIG_ENV_OFFSET_REDUND=0x3E0000 CONFIG_SYS_LOAD_ADDR=0x40480000 +CONFIG_PCI=y CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y @@ -59,6 +61,7 @@ CONFIG_CMD_FUSE=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y CONFIG_CMD_SF_TEST=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y @@ -110,10 +113,15 @@ CONFIG_PHY_TI_DP83867=y CONFIG_PHY_GIGE=y CONFIG_FEC_MXC=y CONFIG_MII=y +CONFIG_NVME_PCI=y +CONFIG_PCIE_DW_IMX=y +CONFIG_PHY=y +CONFIG_PHY_IMX8M_PCIE=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y CONFIG_PINCTRL_IMX8M=y -CONFIG_DM_REGULATOR=y +CONFIG_POWER_DOMAIN=y +CONFIG_IMX8M_POWER_DOMAIN=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_SERIAL=y
Changes for v2:
Applied only this one, thanks.
Hi Fabio,
Changes for v2:
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Erika Unter HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
Fabio Estevam
Lukasz Majewski
