[U-Boot] [PATCH 1/4] mtd: nand: Rename nand.h into rawnand.h
This header was renamed to rawnand.h in Linux.
The following is the corresponding commit in Linux.
commit d4092d76a4a4e57b65910899948a83cc8646c5a5 Author: Boris Brezillon boris.brezillon@free-electrons.com Date: Fri Aug 4 17:29:10 2017 +0200
We are planning to share more code between different NAND based devices (SPI NAND, OneNAND and raw NANDs), but before doing that we need to move the existing include/linux/mtd/nand.h file into include/linux/mtd/rawnand.h so we can later create a nand.h header containing all common structure and function prototypes.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/include/asm/ti-common/davinci_nand.h | 2 +- arch/arm/mach-omap2/omap3/spl_id_nand.c | 2 +- board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c | 2 +- board/isee/igep00x0/common.c | 2 +- board/isee/igep00x0/igep00x0.c | 2 +- board/isee/igep00x0/spl.c | 2 +- board/logicpd/omap3som/omap3logic.c | 2 +- board/mini-box/picosam9g45/picosam9g45.c | 2 +- board/overo/overo.c | 2 +- board/siemens/taurus/taurus.c | 2 +- board/ti/beagle/beagle.c | 2 +- board/ti/evm/evm.c | 2 +- cmd/jffs2.c | 2 +- cmd/mtdparts.c | 2 +- drivers/mtd/nand/arasan_nfc.c | 2 +- drivers/mtd/nand/denali.h | 2 +- drivers/mtd/nand/denali_spl.c | 2 +- drivers/mtd/nand/fsl_elbc_nand.c | 2 +- drivers/mtd/nand/fsl_ifc_nand.c | 2 +- drivers/mtd/nand/fsl_ifc_spl.c | 2 +- drivers/mtd/nand/mxs_nand.c | 2 +- drivers/mtd/nand/nand_base.c | 2 +- drivers/mtd/nand/nand_bbt.c | 2 +- drivers/mtd/nand/nand_bch.c | 2 +- drivers/mtd/nand/nand_ids.c | 2 +- drivers/mtd/nand/nand_timings.c | 2 +- drivers/mtd/nand/pxa3xx_nand.c | 2 +- drivers/mtd/nand/sunxi_nand.c | 2 +- drivers/mtd/nand/vf610_nfc.c | 2 +- drivers/mtd/nand/zynq_nand.c | 2 +- fs/yaffs2/yaffs_mtdif.c | 2 +- include/linux/mtd/fsl_upm.h | 2 +- include/linux/mtd/fsmc_nand.h | 2 +- include/linux/mtd/{nand.h => rawnand.h} | 9 +++------ include/nand.h | 2 +- 35 files changed, 37 insertions(+), 40 deletions(-) rename include/linux/mtd/{nand.h => rawnand.h} (99%)
diff --git a/arch/arm/include/asm/ti-common/davinci_nand.h b/arch/arm/include/asm/ti-common/davinci_nand.h index f343ac2..e26381c 100644 --- a/arch/arm/include/asm/ti-common/davinci_nand.h +++ b/arch/arm/include/asm/ti-common/davinci_nand.h @@ -9,7 +9,7 @@ #ifndef _DAVINCI_NAND_H_ #define _DAVINCI_NAND_H_
-#include <linux/mtd/nand.h> +#include <linux/mtd/rawnand.h> #include <asm/arch/hardware.h>
#define NAND_READ_START 0x00 diff --git a/arch/arm/mach-omap2/omap3/spl_id_nand.c b/arch/arm/mach-omap2/omap3/spl_id_nand.c index 0e2f0a2..5c9549c 100644 --- a/arch/arm/mach-omap2/omap3/spl_id_nand.c +++ b/arch/arm/mach-omap2/omap3/spl_id_nand.c @@ -14,7 +14,7 @@
#include <common.h> #include <jffs2/load_kernel.h> -#include <linux/mtd/nand.h> +#include <linux/mtd/rawnand.h> #include <linux/mtd/omap_gpmc.h> #include <asm/io.h> #include <asm/arch/sys_proto.h> diff --git a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c index 98430c4..78ddbbb 100644 --- a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c +++ b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c @@ -16,7 +16,7 @@ #include <asm/arch/gpio.h> #include <asm/arch/clk.h> #include <lcd.h> -#include <linux/mtd/nand.h> +#include <linux/mtd/rawnand.h> #include <atmel_lcdc.h> #include <asm/mach-types.h>
diff --git a/board/isee/igep00x0/common.c b/board/isee/igep00x0/common.c index e59516f..d35afa5 100644 --- a/board/isee/igep00x0/common.c +++ b/board/isee/igep00x0/common.c @@ -8,7 +8,7 @@ #include <asm/arch/mux.h> #include <asm/arch/sys_proto.h> #include <jffs2/load_kernel.h> -#include <linux/mtd/nand.h> +#include <linux/mtd/rawnand.h> #include "igep00x0.h"
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/isee/igep00x0/igep00x0.c b/board/isee/igep00x0/igep00x0.c index 5c7f256..01bb99f 100644 --- a/board/isee/igep00x0/igep00x0.c +++ b/board/isee/igep00x0/igep00x0.c @@ -18,7 +18,7 @@ #include <asm/arch/mux.h> #include <asm/arch/sys_proto.h> #include <linux/mtd/mtd.h> -#include <linux/mtd/nand.h> +#include <linux/mtd/rawnand.h> #include <linux/mtd/onenand.h> #include <jffs2/load_kernel.h> #include <mtd_node.h> diff --git a/board/isee/igep00x0/spl.c b/board/isee/igep00x0/spl.c index eb705cb..f1c99dd 100644 --- a/board/isee/igep00x0/spl.c +++ b/board/isee/igep00x0/spl.c @@ -5,7 +5,7 @@ #include <asm/arch/mem.h> #include <asm/arch/sys_proto.h> #include <jffs2/load_kernel.h> -#include <linux/mtd/nand.h> +#include <linux/mtd/rawnand.h> #include "igep00x0.h"
/* diff --git a/board/logicpd/omap3som/omap3logic.c b/board/logicpd/omap3som/omap3logic.c index 1da9e38..a55a520 100644 --- a/board/logicpd/omap3som/omap3logic.c +++ b/board/logicpd/omap3som/omap3logic.c @@ -26,7 +26,7 @@ #include <asm/arch/sys_proto.h> #include <asm/gpio.h> #include <asm/mach-types.h> -#include <linux/mtd/nand.h> +#include <linux/mtd/rawnand.h> #include <asm/omap_musb.h> #include <linux/errno.h> #include <linux/usb/ch9.h> diff --git a/board/mini-box/picosam9g45/picosam9g45.c b/board/mini-box/picosam9g45/picosam9g45.c index f3263eb..dd2db9a 100644 --- a/board/mini-box/picosam9g45/picosam9g45.c +++ b/board/mini-box/picosam9g45/picosam9g45.c @@ -20,7 +20,7 @@ #include <asm/arch/gpio.h> #include <asm/arch/clk.h> #include <lcd.h> -#include <linux/mtd/nand.h> +#include <linux/mtd/rawnand.h> #include <atmel_lcdc.h> #include <atmel_mci.h> #if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) diff --git a/board/overo/overo.c b/board/overo/overo.c index 140e34d..7b44a37 100644 --- a/board/overo/overo.c +++ b/board/overo/overo.c @@ -17,7 +17,7 @@ #include <ns16550.h> #include <netdev.h> #include <twl4030.h> -#include <linux/mtd/nand.h> +#include <linux/mtd/rawnand.h> #include <asm/io.h> #include <asm/arch/mmc_host_def.h> #include <asm/arch/mux.h> diff --git a/board/siemens/taurus/taurus.c b/board/siemens/taurus/taurus.c index 8390bdd..71541ba 100644 --- a/board/siemens/taurus/taurus.c +++ b/board/siemens/taurus/taurus.c @@ -26,7 +26,7 @@ #include <asm/arch/atmel_serial.h> #include <asm/arch/clk.h> #include <asm/gpio.h> -#include <linux/mtd/nand.h> +#include <linux/mtd/rawnand.h> #include <atmel_mci.h> #include <asm/arch/at91_spi.h> #include <spi.h> diff --git a/board/ti/beagle/beagle.c b/board/ti/beagle/beagle.c index 2f62fbe..bdf84b0 100644 --- a/board/ti/beagle/beagle.c +++ b/board/ti/beagle/beagle.c @@ -20,7 +20,7 @@ #include <status_led.h> #endif #include <twl4030.h> -#include <linux/mtd/nand.h> +#include <linux/mtd/rawnand.h> #include <asm/io.h> #include <asm/arch/mmc_host_def.h> #include <asm/arch/mux.h> diff --git a/board/ti/evm/evm.c b/board/ti/evm/evm.c index 1f0433d..4d5ddff 100644 --- a/board/ti/evm/evm.c +++ b/board/ti/evm/evm.c @@ -25,7 +25,7 @@ #include <twl4030.h> #include <asm/mach-types.h> #include <asm/omap_musb.h> -#include <linux/mtd/nand.h> +#include <linux/mtd/rawnand.h> #include <linux/usb/ch9.h> #include <linux/usb/gadget.h> #include <linux/usb/musb.h> diff --git a/cmd/jffs2.c b/cmd/jffs2.c index aee2f45..13c533c 100644 --- a/cmd/jffs2.c +++ b/cmd/jffs2.c @@ -80,7 +80,7 @@ #include <cramfs/cramfs_fs.h>
#if defined(CONFIG_CMD_NAND) -#include <linux/mtd/nand.h> +#include <linux/mtd/rawnand.h> #include <nand.h> #endif
diff --git a/cmd/mtdparts.c b/cmd/mtdparts.c index 3275eb9..3169c33 100644 --- a/cmd/mtdparts.c +++ b/cmd/mtdparts.c @@ -81,7 +81,7 @@ #include <linux/mtd/mtd.h>
diff --git a/drivers/mtd/nand/arasan_nfc.c b/drivers/mtd/nand/arasan_nfc.c index a8f795d..14b2733 100644 --- a/drivers/mtd/nand/arasan_nfc.c +++ b/drivers/mtd/nand/arasan_nfc.c @@ -11,7 +11,7 @@ #include <asm/io.h> #include <linux/errno.h> #include <linux/mtd/mtd.h> -#include <linux/mtd/nand.h> +#include <linux/mtd/rawnand.h> #include <linux/mtd/partitions.h> #include <linux/mtd/nand_ecc.h> #include <asm/arch/hardware.h> diff --git a/drivers/mtd/nand/denali.h b/drivers/mtd/nand/denali.h index 04b4ae2..bdaea71 100644 --- a/drivers/mtd/nand/denali.h +++ b/drivers/mtd/nand/denali.h @@ -9,7 +9,7 @@ #define __DENALI_H__
#include <linux/bitops.h> -#include <linux/mtd/nand.h> +#include <linux/mtd/rawnand.h> #include <linux/types.h>
#define DEVICE_RESET 0x0 diff --git a/drivers/mtd/nand/denali_spl.c b/drivers/mtd/nand/denali_spl.c index 3cb9849..1a59b93 100644 --- a/drivers/mtd/nand/denali_spl.c +++ b/drivers/mtd/nand/denali_spl.c @@ -8,7 +8,7 @@ #include <common.h> #include <asm/io.h> #include <asm/unaligned.h> -#include <linux/mtd/nand.h> +#include <linux/mtd/rawnand.h> #include "denali.h"
#define DENALI_MAP01 (1 << 26) /* read/write pages in PIO */ diff --git a/drivers/mtd/nand/fsl_elbc_nand.c b/drivers/mtd/nand/fsl_elbc_nand.c index b3c23b0..fc3720b 100644 --- a/drivers/mtd/nand/fsl_elbc_nand.c +++ b/drivers/mtd/nand/fsl_elbc_nand.c @@ -13,7 +13,7 @@ #include <nand.h>
#include <linux/mtd/mtd.h> -#include <linux/mtd/nand.h> +#include <linux/mtd/rawnand.h> #include <linux/mtd/nand_ecc.h>
#include <asm/io.h> diff --git a/drivers/mtd/nand/fsl_ifc_nand.c b/drivers/mtd/nand/fsl_ifc_nand.c index a757a3b..d1165f7 100644 --- a/drivers/mtd/nand/fsl_ifc_nand.c +++ b/drivers/mtd/nand/fsl_ifc_nand.c @@ -12,7 +12,7 @@ #include <nand.h>
#include <asm/io.h> diff --git a/drivers/mtd/nand/fsl_ifc_spl.c b/drivers/mtd/nand/fsl_ifc_spl.c index 4e49a4e..5946194 100644 --- a/drivers/mtd/nand/fsl_ifc_spl.c +++ b/drivers/mtd/nand/fsl_ifc_spl.c @@ -10,7 +10,7 @@ #include <common.h> #include <asm/io.h> #include <fsl_ifc.h> -#include <linux/mtd/nand.h> +#include <linux/mtd/rawnand.h> #ifdef CONFIG_CHAIN_OF_TRUST #include <fsl_validate.h> #endif diff --git a/drivers/mtd/nand/mxs_nand.c b/drivers/mtd/nand/mxs_nand.c index d774ab8..bed9b65 100644 --- a/drivers/mtd/nand/mxs_nand.c +++ b/drivers/mtd/nand/mxs_nand.c @@ -15,7 +15,7 @@
#include <common.h> #include <linux/mtd/mtd.h> -#include <linux/mtd/nand.h> +#include <linux/mtd/rawnand.h> #include <linux/types.h> #include <malloc.h> #include <linux/errno.h> diff --git a/drivers/mtd/nand/nand_base.c b/drivers/mtd/nand/nand_base.c index aca3231..eb9f121 100644 --- a/drivers/mtd/nand/nand_base.c +++ b/drivers/mtd/nand/nand_base.c @@ -37,7 +37,7 @@ #include <linux/err.h> #include <linux/compat.h> #include <linux/mtd/mtd.h> -#include <linux/mtd/nand.h> +#include <linux/mtd/rawnand.h> #include <linux/mtd/nand_ecc.h> #include <linux/mtd/nand_bch.h> #ifdef CONFIG_MTD_PARTITIONS diff --git a/drivers/mtd/nand/nand_bbt.c b/drivers/mtd/nand/nand_bbt.c index 74c4c9a..ba785c5 100644 --- a/drivers/mtd/nand/nand_bbt.c +++ b/drivers/mtd/nand/nand_bbt.c @@ -62,7 +62,7 @@ #include <linux/compat.h> #include <linux/mtd/mtd.h> #include <linux/mtd/bbm.h> -#include <linux/mtd/nand.h> +#include <linux/mtd/rawnand.h> #include <linux/bitops.h> #include <linux/string.h>
diff --git a/drivers/mtd/nand/nand_bch.c b/drivers/mtd/nand/nand_bch.c index 6c20d53..b7c1171 100644 --- a/drivers/mtd/nand/nand_bch.c +++ b/drivers/mtd/nand/nand_bch.c @@ -13,7 +13,7 @@
#include <linux/bitops.h> #include <linux/mtd/mtd.h> -#include <linux/mtd/nand.h> +#include <linux/mtd/rawnand.h> #include <linux/mtd/nand_bch.h> #include <linux/bch.h> #include <malloc.h> diff --git a/drivers/mtd/nand/nand_ids.c b/drivers/mtd/nand/nand_ids.c index d36f900..4009d64 100644 --- a/drivers/mtd/nand/nand_ids.c +++ b/drivers/mtd/nand/nand_ids.c @@ -7,7 +7,7 @@ * */ #include <common.h> -#include <linux/mtd/nand.h> +#include <linux/mtd/rawnand.h> #include <linux/sizes.h>
#define LP_OPTIONS NAND_SAMSUNG_LP_OPTIONS diff --git a/drivers/mtd/nand/nand_timings.c b/drivers/mtd/nand/nand_timings.c index 9935557..c0545a4 100644 --- a/drivers/mtd/nand/nand_timings.c +++ b/drivers/mtd/nand/nand_timings.c @@ -10,7 +10,7 @@ */ #include <common.h> #include <linux/kernel.h> -#include <linux/mtd/nand.h> +#include <linux/mtd/rawnand.h>
static const struct nand_data_interface onfi_sdr_timings[] = { /* Mode 0 */ diff --git a/drivers/mtd/nand/pxa3xx_nand.c b/drivers/mtd/nand/pxa3xx_nand.c index 6ab3c8a..5a9bc42 100644 --- a/drivers/mtd/nand/pxa3xx_nand.c +++ b/drivers/mtd/nand/pxa3xx_nand.c @@ -15,7 +15,7 @@ #include <asm/io.h> #include <asm/arch/cpu.h> #include <linux/mtd/mtd.h> -#include <linux/mtd/nand.h> +#include <linux/mtd/rawnand.h> #include <linux/types.h>
#include "pxa3xx_nand.h" diff --git a/drivers/mtd/nand/sunxi_nand.c b/drivers/mtd/nand/sunxi_nand.c index 8bc3828..532e03c 100644 --- a/drivers/mtd/nand/sunxi_nand.c +++ b/drivers/mtd/nand/sunxi_nand.c @@ -32,7 +32,7 @@
#include <linux/kernel.h> #include <linux/mtd/mtd.h> -#include <linux/mtd/nand.h> +#include <linux/mtd/rawnand.h> #include <linux/mtd/partitions.h> #include <linux/io.h>
diff --git a/drivers/mtd/nand/vf610_nfc.c b/drivers/mtd/nand/vf610_nfc.c index f99bdaf..dd53f2b 100644 --- a/drivers/mtd/nand/vf610_nfc.c +++ b/drivers/mtd/nand/vf610_nfc.c @@ -26,7 +26,7 @@ #include <malloc.h>
#include <nand.h> diff --git a/drivers/mtd/nand/zynq_nand.c b/drivers/mtd/nand/zynq_nand.c index 076b878..6494196 100644 --- a/drivers/mtd/nand/zynq_nand.c +++ b/drivers/mtd/nand/zynq_nand.c @@ -13,7 +13,7 @@ #include <linux/errno.h> #include <nand.h> #include <linux/mtd/mtd.h> -#include <linux/mtd/nand.h> +#include <linux/mtd/rawnand.h> #include <linux/mtd/partitions.h> #include <linux/mtd/nand_ecc.h> #include <asm/arch/hardware.h> diff --git a/fs/yaffs2/yaffs_mtdif.c b/fs/yaffs2/yaffs_mtdif.c index 636c777..d338f9a 100644 --- a/fs/yaffs2/yaffs_mtdif.c +++ b/fs/yaffs2/yaffs_mtdif.c @@ -22,7 +22,7 @@ #include <linux/mtd/mtd.h> #include <linux/types.h> #include <linux/time.h> -#include <linux/mtd/nand.h> +#include <linux/mtd/rawnand.h>
static inline void translate_spare2oob(const struct yaffs_spare *spare, u8 *oob) diff --git a/include/linux/mtd/fsl_upm.h b/include/linux/mtd/fsl_upm.h index 0a949bc..a023860 100644 --- a/include/linux/mtd/fsl_upm.h +++ b/include/linux/mtd/fsl_upm.h @@ -10,7 +10,7 @@ #ifndef __LINUX_MTD_NAND_FSL_UPM #define __LINUX_MTD_NAND_FSL_UPM
#define FSL_UPM_WAIT_RUN_PATTERN 0x1 #define FSL_UPM_WAIT_WRITE_BYTE 0x2 diff --git a/include/linux/mtd/fsmc_nand.h b/include/linux/mtd/fsmc_nand.h index f0f7727..bc3db03 100644 --- a/include/linux/mtd/fsmc_nand.h +++ b/include/linux/mtd/fsmc_nand.h @@ -8,7 +8,7 @@ #ifndef __FSMC_NAND_H__ #define __FSMC_NAND_H__
struct fsmc_regs { u32 ctrl; /* 0x00 */ diff --git a/include/linux/mtd/nand.h b/include/linux/mtd/rawnand.h similarity index 99% rename from include/linux/mtd/nand.h rename to include/linux/mtd/rawnand.h index d1db34c..192709b 100644 --- a/include/linux/mtd/nand.h +++ b/include/linux/mtd/rawnand.h @@ -1,6 +1,4 @@ /* - * linux/include/linux/mtd/nand.h - * * Copyright © 2000-2010 David Woodhouse dwmw2@infradead.org * Steven J. Hill sjhill@realitydiluted.com * Thomas Gleixner tglx@linutronix.de @@ -13,8 +11,8 @@ * Changelog: * See git changelog. */ -#ifndef __LINUX_MTD_NAND_H -#define __LINUX_MTD_NAND_H +#ifndef __LINUX_MTD_RAWNAND_H +#define __LINUX_MTD_RAWNAND_H
#include <config.h>
@@ -1270,5 +1268,4 @@ int nand_maximize_ecc(struct nand_chip *chip,
/* Reset and initialize a NAND device */ int nand_reset(struct nand_chip *chip, int chipnr); - -#endif /* __LINUX_MTD_NAND_H */ +#endif /* __LINUX_MTD_RAWNAND_H */ diff --git a/include/nand.h b/include/nand.h index c1c1d8c..cead563 100644 --- a/include/nand.h +++ b/include/nand.h @@ -32,7 +32,7 @@ unsigned long nand_size(void);
int nand_mtd_to_devnum(struct mtd_info *mtd);
This is needed for ARCH_DMA_MINALIGN.
include/linux/mtd/rawnand.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/linux/mtd/rawnand.h b/include/linux/mtd/rawnand.h index 192709b..6c3e838 100644 --- a/include/linux/mtd/rawnand.h +++ b/include/linux/mtd/rawnand.h @@ -20,6 +20,7 @@ #include <linux/mtd/mtd.h> #include <linux/mtd/flashchip.h> #include <linux/mtd/bbm.h> +#include <asm/cache.h>
struct mtd_info; struct nand_flash_dev;
The Linux derived log functions can be used anywhere and easily turned on/off by CONFIG_LOGLEVEL.
drivers/mtd/nand/denali_dt.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/nand/denali_dt.c b/drivers/mtd/nand/denali_dt.c index 9d6cb09..c96512f 100644 --- a/drivers/mtd/nand/denali_dt.c +++ b/drivers/mtd/nand/denali_dt.c @@ -5,11 +5,11 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#include <common.h> #include <clk.h> #include <dm.h> #include <linux/io.h> #include <linux/ioport.h> +#include <linux/printk.h>
#include "denali.h"
@@ -118,6 +118,6 @@ void board_nand_init(void) DM_GET_DRIVER(denali_nand_dt), &dev); if (ret && ret != -ENODEV) - printf("Failed to initialize Denali NAND controller. (error %d)\n", + pr_err("Failed to initialize Denali NAND controller. (error %d)\n", ret); }
Include necessary headers explicitly without relying on indirect header inclusion.
<common.h>, <malloc.h> are unneeded.
drivers/mtd/nand/denali.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/nand/denali.c b/drivers/mtd/nand/denali.c index 8ff2d09..3a67653 100644 --- a/drivers/mtd/nand/denali.c +++ b/drivers/mtd/nand/denali.c @@ -6,14 +6,14 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#include <common.h> -#include <malloc.h> -#include <nand.h> #include <dm.h> +#include <nand.h> #include <linux/bitfield.h> #include <linux/dma-direction.h> #include <linux/errno.h> #include <linux/io.h> +#include <linux/mtd/mtd.h> +#include <linux/mtd/rawnand.h>
#include "denali.h"
2017-11-30 13:45 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
mtd: nand: Rename nand.h into rawnand.h We are planning to share more code between different NAND based devices (SPI NAND, OneNAND and raw NANDs), but before doing that we need to move the existing include/linux/mtd/nand.h file into include/linux/mtd/rawnand.h so we can later create a nand.h header containing all common structure and function prototypes.
Applied to u-boot-uniphier.
Masahiro Yamada
