[PATCH 0/6] rockchip: efuse: add support for more platfroms
Finley Xiao (6): rockchip: efuse: Add support for rk3288 efuse rockchip: efuse: Add support for rk3066a efuse rockchip: efuse: Add support for rk3188 efuse rockchip: efuse: Add support for rk322x efuse rockchip: efuse: Add support for rk3328 non-secure efuse rockchip: efuse: Add support for rk1808 non-secure efuse
drivers/misc/rockchip-efuse.c | 271 +++++++++++++++++++++++++++++++++++++++++- 1 file changed, 267 insertions(+), 4 deletions(-)
This adds the necessary data for handling eFuse on the rk3288.
Signed-off-by: Finley Xiao finley.xiao@rock-chips.com --- drivers/misc/rockchip-efuse.c | 76 ++++++++++++++++++++++++++++++++++++++++--- 1 file changed, 72 insertions(+), 4 deletions(-)
diff --git a/drivers/misc/rockchip-efuse.c b/drivers/misc/rockchip-efuse.c index 2520c6a38e..f01d877e33 100644 --- a/drivers/misc/rockchip-efuse.c +++ b/drivers/misc/rockchip-efuse.c @@ -15,6 +15,15 @@ #include <linux/delay.h> #include <misc.h>
+#define RK3288_A_SHIFT 6 +#define RK3288_A_MASK 0x3ff +#define RK3288_NFUSES 32 +#define RK3288_BYTES_PER_FUSE 1 +#define RK3288_PGENB BIT(3) +#define RK3288_LOAD BIT(2) +#define RK3288_STROBE BIT(1) +#define RK3288_CSB BIT(0) + #define RK3399_A_SHIFT 16 #define RK3399_A_MASK 0x3ff #define RK3399_NFUSES 32 @@ -27,6 +36,9 @@ #define RK3399_STROBE BIT(1) #define RK3399_CSB BIT(0)
+typedef int (*EFUSE_READ)(struct udevice *dev, int offset, void *buf, + int size); + struct rockchip_efuse_regs { u32 ctrl; /* 0x00 efuse control register */ u32 dout; /* 0x04 efuse data out register */ @@ -53,7 +65,7 @@ static int dump_efuses(cmd_tbl_t *cmdtp, int flag, */
struct udevice *dev; - u8 fuses[128]; + u8 fuses[128] = {0}; int ret;
/* retrieve the device */ @@ -77,12 +89,55 @@ static int dump_efuses(cmd_tbl_t *cmdtp, int flag, }
U_BOOT_CMD( - rk3399_dump_efuses, 1, 1, dump_efuses, + rockchip_dump_efuses, 1, 1, dump_efuses, "Dump the content of the efuses", "" ); #endif
+static int rockchip_rk3288_efuse_read(struct udevice *dev, int offset, + void *buf, int size) +{ + struct rockchip_efuse_platdata *plat = dev_get_platdata(dev); + struct rockchip_efuse_regs *efuse = + (struct rockchip_efuse_regs *)plat->base; + u8 *buffer = buf; + int max_size = RK3288_NFUSES * RK3288_BYTES_PER_FUSE; + + if (size > (max_size - offset)) + size = max_size - offset; + + /* Switch to read mode */ + writel(RK3288_LOAD | RK3288_PGENB, &efuse->ctrl); + udelay(1); + + while (size--) { + writel(readl(&efuse->ctrl) & + (~(RK3288_A_MASK << RK3288_A_SHIFT)), + &efuse->ctrl); + /* set addr */ + writel(readl(&efuse->ctrl) | + ((offset++ & RK3288_A_MASK) << RK3288_A_SHIFT), + &efuse->ctrl); + udelay(1); + /* strobe low to high */ + writel(readl(&efuse->ctrl) | + RK3288_STROBE, &efuse->ctrl); + ndelay(60); + /* read data */ + *buffer++ = readl(&efuse->dout); + /* reset strobe to low */ + writel(readl(&efuse->ctrl) & + (~RK3288_STROBE), &efuse->ctrl); + udelay(1); + } + + /* Switch to standby mode */ + writel(RK3288_PGENB | RK3288_CSB, &efuse->ctrl); + + return 0; +} + static int rockchip_rk3399_efuse_read(struct udevice *dev, int offset, void *buf, int size) { @@ -130,7 +185,13 @@ static int rockchip_rk3399_efuse_read(struct udevice *dev, int offset, static int rockchip_efuse_read(struct udevice *dev, int offset, void *buf, int size) { - return rockchip_rk3399_efuse_read(dev, offset, buf, size); + EFUSE_READ efuse_read = NULL; + + efuse_read = (EFUSE_READ)dev_get_driver_data(dev); + if (!efuse_read) + return -EINVAL; + + return (*efuse_read)(dev, offset, buf, size); }
static const struct misc_ops rockchip_efuse_ops = { @@ -146,7 +207,14 @@ static int rockchip_efuse_ofdata_to_platdata(struct udevice *dev) }
static const struct udevice_id rockchip_efuse_ids[] = { - { .compatible = "rockchip,rk3399-efuse" }, + { + .compatible = "rockchip,rk3288-efuse", + .data = (ulong)&rockchip_rk3288_efuse_read, + }, + { + .compatible = "rockchip,rk3399-efuse", + .data = (ulong)&rockchip_rk3399_efuse_read, + }, {} };
This adds the necessary data for handling eFuse on the rk3328.
Signed-off-by: Finley Xiao finley.xiao@rock-chips.com --- drivers/misc/rockchip-efuse.c | 69 +++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 69 insertions(+)
diff --git a/drivers/misc/rockchip-efuse.c b/drivers/misc/rockchip-efuse.c index 175a7fe2f5..68762d3f6f 100644 --- a/drivers/misc/rockchip-efuse.c +++ b/drivers/misc/rockchip-efuse.c @@ -13,6 +13,7 @@ #include <dm.h> #include <linux/bitops.h> #include <linux/delay.h> +#include <malloc.h> #include <misc.h>
#define RK3288_A_SHIFT 6 @@ -24,6 +25,15 @@ #define RK3288_STROBE BIT(1) #define RK3288_CSB BIT(0)
+#define RK3328_INT_STATUS 0x0018 +#define RK3328_DOUT 0x0020 +#define RK3328_AUTO_CTRL 0x0024 +#define RK3328_INT_FINISH BIT(0) +#define RK3328_AUTO_ENB BIT(0) +#define RK3328_AUTO_RD BIT(1) +#define RK3328_NO_SECURE_BYTES 32 +#define RK3328_SECURE_BYTES 96 + #define RK3399_A_SHIFT 16 #define RK3399_A_MASK 0x3ff #define RK3399_NFUSES 32 @@ -47,6 +57,10 @@ struct rockchip_efuse_regs { u32 jtag_pass; /* 0x10 JTAG password */ u32 strobe_finish_ctrl; /* 0x14 efuse strobe finish control register */ + u32 int_status;/* 0x18 */ + u32 reserved; /* 0x1c */ + u32 dout2; /* 0x20 */ + u32 auto_ctrl; /* 0x24 */ };
struct rockchip_efuse_platdata { @@ -138,6 +152,57 @@ static int rockchip_rk3288_efuse_read(struct udevice *dev, int offset, return 0; }
+static int rockchip_rk3328_efuse_read(struct udevice *dev, int offset, + void *buf, int size) +{ + struct rockchip_efuse_platdata *plat = dev_get_platdata(dev); + struct rockchip_efuse_regs *efuse = + (struct rockchip_efuse_regs *)plat->base; + unsigned int addr_start, addr_end, addr_offset, addr_len; + u32 out_value, status; + u8 *buffer; + int ret = 0, i = 0, j = 0; + + /* Max non-secure Byte */ + if (size > RK3328_NO_SECURE_BYTES) + size = RK3328_NO_SECURE_BYTES; + + /* 128 Byte efuse, 96 Byte for secure, 32 Byte for non-secure */ + offset += RK3328_SECURE_BYTES; + addr_start = rounddown(offset, RK3399_BYTES_PER_FUSE) / + RK3399_BYTES_PER_FUSE; + addr_end = roundup(offset + size, RK3399_BYTES_PER_FUSE) / + RK3399_BYTES_PER_FUSE; + addr_offset = offset % RK3399_BYTES_PER_FUSE; + addr_len = addr_end - addr_start; + + buffer = calloc(1, sizeof(*buffer) * addr_len * RK3399_BYTES_PER_FUSE); + if (!buffer) + return -ENOMEM; + + for (j = 0; j < addr_len; j++) { + writel(RK3328_AUTO_RD | RK3328_AUTO_ENB | + ((addr_start++ & RK3399_A_MASK) << RK3399_A_SHIFT), + &efuse->auto_ctrl); + udelay(5); + status = readl(&efuse->int_status); + if (!(status & RK3328_INT_FINISH)) { + ret = -EIO; + goto err; + } + out_value = readl(&efuse->dout2); + writel(RK3328_INT_FINISH, &efuse->int_status); + + memcpy(&buffer[i], &out_value, RK3399_BYTES_PER_FUSE); + i += RK3399_BYTES_PER_FUSE; + } + memcpy(buf, buffer + addr_offset, size); +err: + free(buffer); + + return ret; +} + static int rockchip_rk3399_efuse_read(struct udevice *dev, int offset, void *buf, int size) { @@ -224,6 +289,10 @@ static const struct udevice_id rockchip_efuse_ids[] = { .data = (ulong)&rockchip_rk3288_efuse_read, }, { + .compatible = "rockchip,rk3328-efuse", + .data = (ulong)&rockchip_rk3328_efuse_read, + }, + { .compatible = "rockchip,rk3399-efuse", .data = (ulong)&rockchip_rk3399_efuse_read, },
This adds the necessary data for handling eFuse on the rk1808.
Signed-off-by: Finley Xiao finley.xiao@rock-chips.com --- drivers/misc/rockchip-efuse.c | 114 ++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 114 insertions(+)
diff --git a/drivers/misc/rockchip-efuse.c b/drivers/misc/rockchip-efuse.c index 68762d3f6f..778e29f30d 100644 --- a/drivers/misc/rockchip-efuse.c +++ b/drivers/misc/rockchip-efuse.c @@ -16,6 +16,46 @@ #include <malloc.h> #include <misc.h>
+#define T_CSB_P_S 0 +#define T_PGENB_P_S 0 +#define T_LOAD_P_S 0 +#define T_ADDR_P_S 0 +#define T_STROBE_P_S (0 + 110) /* 1.1us */ +#define T_CSB_P_L (0 + 110 + 1000 + 20) /* 200ns */ +#define T_PGENB_P_L (0 + 110 + 1000 + 20) +#define T_LOAD_P_L (0 + 110 + 1000 + 20) +#define T_ADDR_P_L (0 + 110 + 1000 + 20) +#define T_STROBE_P_L (0 + 110 + 1000) /* 10us */ +#define T_CSB_R_S 0 +#define T_PGENB_R_S 0 +#define T_LOAD_R_S 0 +#define T_ADDR_R_S 2 +#define T_STROBE_R_S (2 + 3) +#define T_CSB_R_L (2 + 3 + 3 + 3) +#define T_PGENB_R_L (2 + 3 + 3 + 3) +#define T_LOAD_R_L (2 + 3 + 3 + 3) +#define T_ADDR_R_L (2 + 3 + 3 + 2) +#define T_STROBE_R_L (2 + 3 + 3) + +#define T_CSB_P 0x28 +#define T_PGENB_P 0x2c +#define T_LOAD_P 0x30 +#define T_ADDR_P 0x34 +#define T_STROBE_P 0x38 +#define T_CSB_R 0x3c +#define T_PGENB_R 0x40 +#define T_LOAD_R 0x44 +#define T_ADDR_R 0x48 +#define T_STROBE_R 0x4c + +#define RK1808_USER_MODE BIT(0) +#define RK1808_INT_FINISH BIT(0) +#define RK1808_AUTO_ENB BIT(0) +#define RK1808_AUTO_RD BIT(1) +#define RK1808_A_SHIFT 16 +#define RK1808_A_MASK 0x3ff +#define RK1808_NBYTES 4 + #define RK3288_A_SHIFT 6 #define RK3288_A_MASK 0x3ff #define RK3288_NFUSES 32 @@ -109,6 +149,76 @@ U_BOOT_CMD( ); #endif
+static void rk1808_efuse_timing_init(void __iomem *base) +{ + static bool init; + + if (init) + return; + + /* enable auto mode */ + writel(readl(base) & (~RK1808_USER_MODE), base); + + /* setup efuse timing */ + writel((T_CSB_P_S << 16) | T_CSB_P_L, base + T_CSB_P); + writel((T_PGENB_P_S << 16) | T_PGENB_P_L, base + T_PGENB_P); + writel((T_LOAD_P_S << 16) | T_LOAD_P_L, base + T_LOAD_P); + writel((T_ADDR_P_S << 16) | T_ADDR_P_L, base + T_ADDR_P); + writel((T_STROBE_P_S << 16) | T_STROBE_P_L, base + T_STROBE_P); + writel((T_CSB_R_S << 16) | T_CSB_R_L, base + T_CSB_R); + writel((T_PGENB_R_S << 16) | T_PGENB_R_L, base + T_PGENB_R); + writel((T_LOAD_R_S << 16) | T_LOAD_R_L, base + T_LOAD_R); + writel((T_ADDR_R_S << 16) | T_ADDR_R_L, base + T_ADDR_R); + writel((T_STROBE_R_S << 16) | T_STROBE_R_L, base + T_STROBE_R); + + init = true; +} + +static int rockchip_rk1808_efuse_read(struct udevice *dev, int offset, + void *buf, int size) +{ + struct rockchip_efuse_platdata *plat = dev_get_platdata(dev); + struct rockchip_efuse_regs *efuse = + (struct rockchip_efuse_regs *)plat->base; + unsigned int addr_start, addr_end, addr_offset, addr_len; + u32 out_value, status; + u8 *buffer; + int ret = 0, i = 0; + + rk1808_efuse_timing_init(plat->base); + + addr_start = rounddown(offset, RK1808_NBYTES) / RK1808_NBYTES; + addr_end = roundup(offset + size, RK1808_NBYTES) / RK1808_NBYTES; + addr_offset = offset % RK1808_NBYTES; + addr_len = addr_end - addr_start; + + buffer = calloc(1, sizeof(*buffer) * addr_len * RK1808_NBYTES); + if (!buffer) + return -ENOMEM; + + while (addr_len--) { + writel(RK1808_AUTO_RD | RK1808_AUTO_ENB | + ((addr_start++ & RK1808_A_MASK) << RK1808_A_SHIFT), + &efuse->auto_ctrl); + udelay(2); + status = readl(&efuse->int_status); + if (!(status & RK1808_INT_FINISH)) { + ret = -EIO; + goto err; + } + out_value = readl(&efuse->dout2); + writel(RK1808_INT_FINISH, &efuse->int_status); + + memcpy(&buffer[i], &out_value, RK1808_NBYTES); + i += RK1808_NBYTES; + } + memcpy(buf, buffer + addr_offset, size); +err: + free(buffer); + + return ret; +} + static int rockchip_rk3288_efuse_read(struct udevice *dev, int offset, void *buf, int size) { @@ -273,6 +383,10 @@ static int rockchip_efuse_ofdata_to_platdata(struct udevice *dev)
static const struct udevice_id rockchip_efuse_ids[] = { { + .compatible = "rockchip,rk1808-efuse", + .data = (ulong)&rockchip_rk1808_efuse_read, + }, + { .compatible = "rockchip,rk3066a-efuse", .data = (ulong)&rockchip_rk3288_efuse_read, },
This adds the necessary data for handling eFuse on the rk3066a.
Signed-off-by: Finley Xiao finley.xiao@rock-chips.com --- drivers/misc/rockchip-efuse.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/misc/rockchip-efuse.c b/drivers/misc/rockchip-efuse.c index f01d877e33..3f2c64b105 100644 --- a/drivers/misc/rockchip-efuse.c +++ b/drivers/misc/rockchip-efuse.c @@ -208,6 +208,10 @@ static int rockchip_efuse_ofdata_to_platdata(struct udevice *dev)
static const struct udevice_id rockchip_efuse_ids[] = { { + .compatible = "rockchip,rk3066a-efuse", + .data = (ulong)&rockchip_rk3288_efuse_read, + }, + { .compatible = "rockchip,rk3288-efuse", .data = (ulong)&rockchip_rk3288_efuse_read, },
Finley Xiao
