[U-Boot] Please pull u-boot-ti/master
Hello,
The following changes since commit 9ed887caecb9ecb0c68773a1870d143b9f28d3da:
Merge branch 'u-boot-imx/master' into 'u-boot-arm/master' (2013-08-17 18:24:13 +0200)
git://git.denx.de/u-boot-ti.git master
for you to fetch changes up to 901ce27c6f018992b7dd6c08d3c98cf217cc4c96:
siemens-am33x-common.h: Always build CONFIG_OMAP_GPIO support (2013-08-28 12:01:30 -0400)
---------------------------------------------------------------- Albert ARIBAUD (1): arm: omap3: fix SRAM copy and execution sequence
Heiko Schocher (6): arm, am33xx: add defines for gmii_sel_register bits arm, am335x: add some missing registers and defines for lcd and epwm support arm, spl: add watchdog library to SPL arm, am335x: add watchdog support video: add formike lcd panel init arm, am335x: add support for 3 siemens boards
Javier Martinez Canillas (1): ARM: igep00x0.h: Enable raw initrd support
Lubomir Popov (1): ARM: OMAP4470: Add Elpida EDB8164B3PF memory configuration
Oleksandr Tyshchenko (1): sdp4430: Initialize board id using CONFIG_MACH_TYPE
Taras Kondratiuk (3): ARM: OMAP4470: Add OMAP4470 identification ARM: OMAP4470: Add voltage and dpll data ARM: OMAP4460: sdp: Limit TPS mux config to 4460
Tom Rini (13): am33xx: Correct and expand comments on CONFIG_SPL_MAX_SIZE TI:armv7: Move CONFIG_SPL_LIBDISK_SUPPORT to MMC section omap5: Expand CONFIG_SPL_MAX_SIZE and comment upon SRAM_SCRATCH_SPACE_ADDR TI:am335x: Better comment and organize the networking related options am335x_evm: Add comment by SPL SPI support am335x_evm: Regroup USB options TI:armv7: Re-order slightly the generic CONFIG options, expand related comments am335x_evm: Update README for customization TI:am33xx: Move SPL YMODEM support to the per-board config TI:omap5: Clarify comments about SPL and DDR timings in common config omap5_uevm: Better comment why we have TCA642X and the reset time dra7xx_evm: Re-order and comment the networking related config options siemens-am33x-common.h: Always build CONFIG_OMAP_GPIO support
MAINTAINERS | 5 + arch/arm/cpu/armv7/omap3/clock.c | 6 +- arch/arm/cpu/armv7/omap3/lowlevel_init.S | 8 +- arch/arm/cpu/armv7/omap4/hw_data.c | 36 ++ arch/arm/cpu/armv7/omap4/hwinit.c | 3 + arch/arm/cpu/armv7/omap4/sdram_elpida.c | 41 +- arch/arm/include/asm/arch-am33xx/cpu.h | 74 ++- arch/arm/include/asm/arch-am33xx/hardware_am33xx.h | 7 + arch/arm/include/asm/arch-am33xx/omap.h | 2 +- arch/arm/include/asm/arch-omap3/clock.h | 2 - arch/arm/include/asm/arch-omap4/clock.h | 7 +- arch/arm/include/asm/arch-omap4/omap.h | 1 + arch/arm/include/asm/arch-omap5/omap.h | 11 +- arch/arm/include/asm/omap_common.h | 1 + board/isee/igep0033/board.c | 6 +- board/phytec/pcm051/board.c | 2 - board/siemens/common/board.c | 171 +++++++ board/siemens/common/factoryset.c | 284 +++++++++++ board/siemens/common/factoryset.h | 27 ++ board/siemens/dxr2/Makefile | 49 ++ board/siemens/dxr2/board.c | 241 +++++++++ board/siemens/dxr2/board.h | 69 +++ board/siemens/dxr2/mux.c | 112 +++++ board/siemens/pxm2/Makefile | 49 ++ board/siemens/pxm2/board.c | 429 ++++++++++++++++ board/siemens/pxm2/board.h | 22 + board/siemens/pxm2/mux.c | 186 +++++++ board/siemens/pxm2/pmic.h | 71 +++ board/siemens/rut/Makefile | 49 ++ board/siemens/rut/board.c | 432 +++++++++++++++++ board/siemens/rut/board.h | 22 + board/siemens/rut/mux.c | 347 +++++++++++++ board/ti/am335x/README | 28 +- board/ti/am335x/board.c | 6 +- board/ti/sdp4430/sdp.c | 4 +- boards.cfg | 3 + doc/README.SPL | 2 +- drivers/video/Makefile | 1 + drivers/video/formike.c | 511 ++++++++++++++++++++ drivers/watchdog/Makefile | 1 + drivers/watchdog/omap_wdt.c | 121 +++++ include/configs/am335x_evm.h | 93 ++-- include/configs/dra7xx_evm.h | 18 +- include/configs/dxr2.h | 94 ++++ include/configs/igep00x0.h | 1 + include/configs/omap4_sdp4430.h | 1 + include/configs/omap5_common.h | 19 +- include/configs/omap5_uevm.h | 3 + include/configs/pxm2.h | 153 ++++++ include/configs/rut.h | 156 ++++++ include/configs/siemens-am33x-common.h | 461 ++++++++++++++++++ include/configs/ti_am335x_common.h | 22 +- include/configs/ti_armv7_common.h | 26 +- include/video.h | 4 + spl/Makefile | 1 + tools/logos/siemens.bmp | Bin 0 -> 25766 bytes 56 files changed, 4387 insertions(+), 114 deletions(-) create mode 100644 board/siemens/common/board.c create mode 100644 board/siemens/common/factoryset.c create mode 100644 board/siemens/common/factoryset.h create mode 100644 board/siemens/dxr2/Makefile create mode 100644 board/siemens/dxr2/board.c create mode 100644 board/siemens/dxr2/board.h create mode 100644 board/siemens/dxr2/mux.c create mode 100644 board/siemens/pxm2/Makefile create mode 100644 board/siemens/pxm2/board.c create mode 100644 board/siemens/pxm2/board.h create mode 100644 board/siemens/pxm2/mux.c create mode 100644 board/siemens/pxm2/pmic.h create mode 100644 board/siemens/rut/Makefile create mode 100644 board/siemens/rut/board.c create mode 100644 board/siemens/rut/board.h create mode 100644 board/siemens/rut/mux.c create mode 100644 drivers/video/formike.c create mode 100644 drivers/watchdog/omap_wdt.c create mode 100644 include/configs/dxr2.h create mode 100644 include/configs/pxm2.h create mode 100644 include/configs/rut.h create mode 100644 include/configs/siemens-am33x-common.h create mode 100644 tools/logos/siemens.bmp
Hi Tom,
On Wed, 28 Aug 2013 14:25:07 -0400, Tom Rini trini@ti.com wrote:
Hello,
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
