[U-Boot] [PATCH] ARM: UniPhier: add static to local functions
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_init.c | 6 +++--- arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_init.c | 6 +++--- arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_init.c | 6 +++--- 3 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_init.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_init.c index 68b9d5f..b83582f 100644 --- a/arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_init.c +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_init.c @@ -11,7 +11,7 @@
#undef DPLL_SSC_RATE_1PER
-void dpll_init(void) +static void dpll_init(void) { u32 tmp;
@@ -42,7 +42,7 @@ void dpll_init(void) writel(tmp, SC_DPLLCTRL2); }
-void upll_init(void) +static void upll_init(void) { u32 tmp, clk_mode_upll, clk_mode_axosel;
@@ -82,7 +82,7 @@ void upll_init(void) writel(tmp, SC_UPLLCTRL); }
-void vpll_init(void) +static void vpll_init(void) { u32 tmp, clk_mode_axosel;
diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_init.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_init.c index 2dcc089..1db90f8 100644 --- a/arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_init.c +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_init.c @@ -11,7 +11,7 @@
@@ -46,7 +46,7 @@ void dpll_init(void) writel(tmp, SC_DPLLCTRL2); }
-void stop_mpll(void) +static void stop_mpll(void) { u32 tmp;
@@ -62,7 +62,7 @@ void stop_mpll(void) ; }
diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_init.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_init.c index 4d87053..4b82700 100644 --- a/arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_init.c +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_init.c @@ -9,7 +9,7 @@ #include <asm/arch/sc-regs.h> #include <asm/arch/sg-regs.h>
-void dpll_init(void) +static void dpll_init(void) { u32 tmp; /* @@ -54,7 +54,7 @@ void dpll_init(void) writel(tmp, SC_DPLLCTRL2); }
@@ -94,7 +94,7 @@ void upll_init(void) writel(tmp, SC_UPLLCTRL); }
Masahiro Yamada
