[U-Boot] flash post test
Hi all,
Currently I am testing the Flash memory by using "Write and Read the same pattern" method (Protecting the UBoot Flash Sectors).
Is it safer to test flash memory during bootup?what if power gets off during process?
I want to know whether there is any alternative method to test the complete FLASH MEMORY.
Hi vk,
Le 31/01/2012 10:27, vk a écrit :
Hi all,
Do you mean that you want to test the flash by writing to it on every power-up? What is the point?
Amicalement,
hi albert
Yes,actually there is already support of flash test in POST of latest uboot.They are testing flash on every power on so am I for my board.But i don't want to disturb sectors in which uboot code relies. Can you help me here? On Sat, Feb 4, 2012 at 3:02 AM, Albert ARIBAUD albert.u.boot@aribaud.netwrote:
Hi vk,
Hi all,
Amicalement,
Albert.
Hi Vaibhav,
Le 06/02/2012 05:57, vaibhav kothari a écrit :
hi albert
I am no NAND specialist, but I do hope NAND POST tests are pure read tests and thus are not affected by poweroffs (and can actually test any part of NAND).
Amicalement,
On 02/06/2012 04:23 PM, Albert ARIBAUD wrote:
Hi Vaibhav,
hi albert
NAND has a property called "read disturb", where excessively reading a sector without writing to it can eventually cause data loss. U-Boot is already read once per boot, but reading it a second time could halve the expected lifetime. Data managed by something like ubi is be scrubbed in a way that avoids this, but U-Boot itself is not usually managed in this way (boot hardware/rom does not understand ubi).
-Scott
Hi Scott,
Hi Vaibhav,
hi albert
I *did* say I am not a NAND expert. :)
Thanks Scott. But then, isn't NAND testing a kind of catch-22, where by actually tesing if NAND works it one ends up weakening it either through read disturb, or simply through writes?
-Scott
Amicalement,
On 02/06/2012 04:59 PM, Albert ARIBAUD wrote:
Hi Scott,
Hi Vaibhav,
hi albert
It's fine for occasional manual testing, or routine testing of an area that gets properly scrubbed.
-Scott
hi albert,Scott
Thnks for your reply.Other than uib ,is there any data pattern/algorithm for flash testing which effects less on lifespan of flash??
Albert ARIBAUD
Scott Wood
vaibhav kothari
vk
