[PATCH] arm64: zynqmp: Configure SoC RTC on SOM
Use RTC available in HW on Kria SOM without using emulation that's why configure it properly and disable emulated one. Power on reset value of RTC Calibration register without battery backup is not matching with crystal frequency which leads to RTC time drift. That's why write CALIB_WRITE register with crystal frequency (0x7FFF). There is also an option to write zero so that Linux will set default value (0x7FFF) in driver probe but calibration 0 is not permited by DT schema.
Co-developed-by: Srinivas Goud srinivas.goud@amd.com Signed-off-by: Srinivas Goud srinivas.goud@amd.com Signed-off-by: Michal Simek michal.simek@amd.com ---
arch/arm/dts/zynqmp-sm-k26-revA.dts | 1 + configs/xilinx_zynqmp_kria_defconfig | 1 - 2 files changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/zynqmp-sm-k26-revA.dts b/arch/arm/dts/zynqmp-sm-k26-revA.dts index 8056f6b176ed..8c43ade94053 100644 --- a/arch/arm/dts/zynqmp-sm-k26-revA.dts +++ b/arch/arm/dts/zynqmp-sm-k26-revA.dts @@ -387,6 +387,7 @@
&rtc { status = "okay"; + calibration = <0x7fff>; };
&lpd_dma_chan1 { diff --git a/configs/xilinx_zynqmp_kria_defconfig b/configs/xilinx_zynqmp_kria_defconfig index dd4df0b2da17..0dddf69c5d05 100644 --- a/configs/xilinx_zynqmp_kria_defconfig +++ b/configs/xilinx_zynqmp_kria_defconfig @@ -187,7 +187,6 @@ CONFIG_DM_PWM=y CONFIG_PWM_CADENCE_TTC=y CONFIG_RESET_ZYNQMP=y CONFIG_DM_RTC=y -CONFIG_RTC_EMULATION=y CONFIG_RTC_ZYNQMP=y CONFIG_SCSI=y CONFIG_ARM_DCC=y
Applied. M
Michal Simek
