[U-Boot-Users] reserving RAM
Hi, I am using a freescale eval board with 256M DDR, and want to bootup the Linux kernel with only a part of this memory, I tried setting the memsize env variable to (equivalent of this value in hex), no use. then i appened bootargs with "boot=128m", and saveenv. Linux still boots without the appended bootargs, any ideas what is causing this?
thanks
Probably you should look into "linux-KERNEL_ROOT/Documentation/kernel-parameters.txt" for passing boot arguments to the kernel. The correct option would be to use "mem=xyzM" in bootargs.
Ramasamy C
Ramasamy C
Surya Ravikiran
