[U-Boot] [PATCH V2] MMC: davinici_mmc: Enable CD and WP with DM and OF_CONTROL
When used with a device tree, this will extract the card detect and write protect pins from the device tree and configure them accordingly. This assumes the GPIO_ACTIVE_LOW/HIGH is supported by da8xx_gpio.
Signed-off-by: Adam Ford aford173@gmail.com --- V2: Wrap the CD and WP GPIO references around DM_GPIO to prevent errors
diff --git a/drivers/mmc/davinci_mmc.c b/drivers/mmc/davinci_mmc.c index db950ea5ec..0d63279db0 100644 --- a/drivers/mmc/davinci_mmc.c +++ b/drivers/mmc/davinci_mmc.c @@ -15,6 +15,7 @@ #include <malloc.h> #include <asm/io.h> #include <asm/arch/sdmmc_defs.h> +#include <asm-generic/gpio.h>
#define DAVINCI_MAX_BLOCKS (32) #define WATCHDOG_COUNT (100000) @@ -35,6 +36,8 @@ struct davinci_mmc_priv { struct davinci_mmc_regs *reg_base; /* Register base address */ uint input_clk; /* Input clock to MMC controller */ uint version; /* MMC Controller version */ + struct gpio_desc cd_gpio; /* Card Detect GPIO */ + struct gpio_desc wp_gpio; /* Write Protect GPIO */ };
struct davinci_mmc_plat @@ -425,9 +428,41 @@ static const struct mmc_ops dmmc_ops = { .init = dmmc_init, }; #else + +static int davinci_mmc_getcd(struct udevice *dev) +{ + int value = -1; +#if CONFIG_IS_ENABLED(DM_GPIO) + struct davinci_mmc_priv *priv = dev_get_priv(dev); + value = dm_gpio_get_value(&priv->cd_gpio); +#endif + /* if no CD return as 1 */ + if (value < 0) + return 1; + + return value; +} + +static int davinci_mmc_getwp(struct udevice *dev) +{ + int value = -1; +#if CONFIG_IS_ENABLED(DM_GPIO) + struct davinci_mmc_priv *priv = dev_get_priv(dev); + + value = dm_gpio_get_value(&priv->wp_gpio); +#endif + /* if no WP return as 0 */ + if (value < 0) + return 0; + + return value; +} + static const struct dm_mmc_ops davinci_mmc_ops = { .send_cmd = davinci_mmc_send_cmd, .set_ios = davinci_mmc_set_ios, + .get_cd = davinci_mmc_getcd, + .get_wp = davinci_mmc_getwp, }; #endif
@@ -475,6 +510,12 @@ static int davinci_mmc_probe(struct udevice *dev) priv->reg_base = (struct davinci_mmc_regs *)dev_read_addr(dev); priv->input_clk = clk_get(DAVINCI_MMCSD_CLKID);
+#if CONFIG_IS_ENABLED(DM_GPIO) + /* These GPIOs are optional */ + gpio_request_by_name(dev, "cd-gpios", 0, &priv->cd_gpio, GPIOD_IS_IN); + gpio_request_by_name(dev, "wp-gpios", 0, &priv->wp_gpio, GPIOD_IS_IN); +#endif + upriv->mmc = &plat->mmc;
return davinci_dm_mmc_init(dev);
Adam Ford
