[U-Boot] [PATCH] macb: make checkpatch clean
This also renames the CONFIG_SYS_MACB_xx defines. They are used just local and therefore don't need the CONFIG_SYS_ prefix.
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com ---
drivers/net/macb.c | 56 +++++++++++++++++++++++++++------------------------- 1 file changed, 29 insertions(+), 27 deletions(-)
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index 781a272..750331d 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -40,11 +40,11 @@
#include "macb.h"
-#define CONFIG_SYS_MACB_RX_BUFFER_SIZE 4096 -#define CONFIG_SYS_MACB_RX_RING_SIZE (CONFIG_SYS_MACB_RX_BUFFER_SIZE / 128) -#define CONFIG_SYS_MACB_TX_RING_SIZE 16 -#define CONFIG_SYS_MACB_TX_TIMEOUT 1000 -#define CONFIG_SYS_MACB_AUTONEG_TIMEOUT 5000000 +#define MACB_RX_BUFFER_SIZE 4096 +#define MACB_RX_RING_SIZE (MACB_RX_BUFFER_SIZE / 128) +#define MACB_TX_RING_SIZE 16 +#define MACB_TX_TIMEOUT 1000 +#define MACB_AUTONEG_TIMEOUT 5000000
struct macb_dma_desc { u32 addr; @@ -170,7 +170,7 @@ int macb_miiphy_read(const char *devname, u8 phy_adr, u8 reg, u16 *value) struct eth_device *dev = eth_get_dev_by_name(devname); struct macb_device *macb = to_macb(dev);
- if ( macb->phy_addr != phy_adr ) + if (macb->phy_addr != phy_adr) return -1;
arch_get_mdio_control(devname); @@ -184,7 +184,7 @@ int macb_miiphy_write(const char *devname, u8 phy_adr, u8 reg, u16 value) struct eth_device *dev = eth_get_dev_by_name(devname); struct macb_device *macb = to_macb(dev);
arch_get_mdio_control(devname); @@ -208,11 +208,12 @@ static int macb_send(struct eth_device *netdev, void *packet, int length)
ctrl = length & TXBUF_FRMLEN_MASK; ctrl |= TXBUF_FRAME_END; - if (tx_head == (CONFIG_SYS_MACB_TX_RING_SIZE - 1)) { + if (tx_head == (MACB_TX_RING_SIZE - 1)) { ctrl |= TXBUF_WRAP; macb->tx_head = 0; - } else + } else { macb->tx_head++; + }
macb->tx_ring[tx_head].ctrl = ctrl; macb->tx_ring[tx_head].addr = paddr; @@ -223,7 +224,7 @@ static int macb_send(struct eth_device *netdev, void *packet, int length) * I guess this is necessary because the networking core may * re-use the transmit buffer as soon as we return... */ - for (i = 0; i <= CONFIG_SYS_MACB_TX_TIMEOUT; i++) { + for (i = 0; i <= MACB_TX_TIMEOUT; i++) { barrier(); ctrl = macb->tx_ring[tx_head].ctrl; if (ctrl & TXBUF_USED) @@ -233,7 +234,7 @@ static int macb_send(struct eth_device *netdev, void *packet, int length)
dma_unmap_single(packet, length, paddr);
- if (i <= CONFIG_SYS_MACB_TX_TIMEOUT) { + if (i <= MACB_TX_TIMEOUT) { if (ctrl & TXBUF_UNDERRUN) printf("%s: TX underrun\n", netdev->name); if (ctrl & TXBUF_EXHAUSTED) @@ -256,7 +257,7 @@ static void reclaim_rx_buffers(struct macb_device *macb, while (i > new_tail) { macb->rx_ring[i].addr &= ~RXADDR_USED; i++; - if (i > CONFIG_SYS_MACB_RX_RING_SIZE) + if (i > MACB_RX_RING_SIZE) i = 0; }
@@ -295,7 +296,7 @@ static int macb_recv(struct eth_device *netdev) if (wrapped) { unsigned int headlen, taillen;
- headlen = 128 * (CONFIG_SYS_MACB_RX_RING_SIZE + headlen = 128 * (MACB_RX_RING_SIZE - macb->rx_tail); taillen = length - headlen; memcpy((void *)NetRxPackets[0], @@ -306,11 +307,11 @@ static int macb_recv(struct eth_device *netdev) }
NetReceive(buffer, length); - if (++rx_tail >= CONFIG_SYS_MACB_RX_RING_SIZE) + if (++rx_tail >= MACB_RX_RING_SIZE) rx_tail = 0; reclaim_rx_buffers(macb, rx_tail); } else { - if (++rx_tail >= CONFIG_SYS_MACB_RX_RING_SIZE) { + if (++rx_tail >= MACB_RX_RING_SIZE) { wrapped = 1; rx_tail = 0; } @@ -333,7 +334,7 @@ static void macb_phy_reset(struct macb_device *macb) macb_mdio_write(macb, MII_BMCR, (BMCR_ANENABLE | BMCR_ANRESTART));
- for (i = 0; i < CONFIG_SYS_MACB_AUTONEG_TIMEOUT / 100; i++) { + for (i = 0; i < MACB_AUTONEG_TIMEOUT / 100; i++) { status = macb_mdio_read(macb, MII_BMSR); if (status & BMSR_ANEGCOMPLETE) break; @@ -385,9 +386,8 @@ static int macb_phy_init(struct macb_device *macb) arch_get_mdio_control(netdev->name); #ifdef CONFIG_MACB_SEARCH_PHY /* Auto-detect phy_addr */ - if (!macb_phy_find(macb)) { + if (!macb_phy_find(macb)) return 0; - } #endif /* CONFIG_MACB_SEARCH_PHY */
/* Check if the PHY is up to snuff... */ @@ -414,7 +414,7 @@ static int macb_phy_init(struct macb_device *macb) /* Try to re-negotiate if we don't have link already. */ macb_phy_reset(macb);
- for (i = 0; i < CONFIG_SYS_MACB_AUTONEG_TIMEOUT / 100; i++) { + for (i = 0; i < MACB_AUTONEG_TIMEOUT / 100; i++) { status = macb_mdio_read(macb, MII_BMSR); if (status & BMSR_LSTATUS) break; @@ -499,21 +499,23 @@ static int macb_init(struct eth_device *netdev, bd_t *bd)
/* initialize DMA descriptors */ paddr = macb->rx_buffer_dma; - for (i = 0; i < CONFIG_SYS_MACB_RX_RING_SIZE; i++) { - if (i == (CONFIG_SYS_MACB_RX_RING_SIZE - 1)) + for (i = 0; i < MACB_RX_RING_SIZE; i++) { + if (i == (MACB_RX_RING_SIZE - 1)) paddr |= RXADDR_WRAP; macb->rx_ring[i].addr = paddr; macb->rx_ring[i].ctrl = 0; paddr += 128; } - for (i = 0; i < CONFIG_SYS_MACB_TX_RING_SIZE; i++) { + for (i = 0; i < MACB_TX_RING_SIZE; i++) { macb->tx_ring[i].addr = 0; - if (i == (CONFIG_SYS_MACB_TX_RING_SIZE - 1)) + if (i == (MACB_TX_RING_SIZE - 1)) macb->tx_ring[i].ctrl = TXBUF_USED | TXBUF_WRAP; else macb->tx_ring[i].ctrl = TXBUF_USED; } - macb->rx_tail = macb->tx_head = macb->tx_tail = 0; + macb->rx_tail = 0; + macb->tx_head = 0; + macb->tx_tail = 0;
macb_writel(macb, RBQP, macb->rx_ring_dma); macb_writel(macb, TBQP, macb->tx_ring_dma); @@ -654,12 +656,12 @@ int macb_eth_initialize(int id, void *regs, unsigned int phy_addr)
netdev = &macb->netdev;
- macb->rx_buffer = dma_alloc_coherent(CONFIG_SYS_MACB_RX_BUFFER_SIZE, + macb->rx_buffer = dma_alloc_coherent(MACB_RX_BUFFER_SIZE, &macb->rx_buffer_dma); - macb->rx_ring = dma_alloc_coherent(CONFIG_SYS_MACB_RX_RING_SIZE + macb->rx_ring = dma_alloc_coherent(MACB_RX_RING_SIZE * sizeof(struct macb_dma_desc), &macb->rx_ring_dma); - macb->tx_ring = dma_alloc_coherent(CONFIG_SYS_MACB_TX_RING_SIZE + macb->tx_ring = dma_alloc_coherent(MACB_TX_RING_SIZE * sizeof(struct macb_dma_desc), &macb->tx_ring_dma);
Hi, Dear Andreas
This patch looks good to me. Reviewed-by: Josh Wu josh.wu@atmel.com
Best Regards, Josh Wu
#include "macb.h"
- if (tx_head == (MACB_TX_RING_SIZE - 1)) { ctrl |= TXBUF_WRAP; macb->tx_head = 0;
- } else
- for (i = 0; i <= MACB_TX_TIMEOUT; i++) { barrier(); ctrl = macb->tx_ring[tx_head].ctrl; if (ctrl & TXBUF_USED)
- if (i <= MACB_TX_TIMEOUT) { if (ctrl & TXBUF_UNDERRUN) printf("%s: TX underrun\n", netdev->name); if (ctrl & TXBUF_EXHAUSTED)
}if (i > MACB_RX_RING_SIZE) i = 0;
} else {if (++rx_tail >= MACB_RX_RING_SIZE) rx_tail = 0; reclaim_rx_buffers(macb, rx_tail);
- for (i = 0; i < MACB_AUTONEG_TIMEOUT / 100; i++) { status = macb_mdio_read(macb, MII_BMSR); if (status & BMSR_ANEGCOMPLETE) break;
- if (!macb_phy_find(macb)) return 0;
- for (i = 0; i < MACB_RX_RING_SIZE; i++) {
macb->rx_ring[i].addr = paddr; macb->rx_ring[i].ctrl = 0; paddr += 128; }if (i == (MACB_RX_RING_SIZE - 1)) paddr |= RXADDR_WRAP;
- for (i = 0; i < MACB_TX_RING_SIZE; i++) { macb->tx_ring[i].addr = 0;
else macb->tx_ring[i].ctrl = TXBUF_USED; }if (i == (MACB_TX_RING_SIZE - 1)) macb->tx_ring[i].ctrl = TXBUF_USED | TXBUF_WRAP;
macb->rx_tail = 0;
macb->tx_head = 0;
macb->tx_tail = 0;
- macb->rx_buffer = dma_alloc_coherent(MACB_RX_BUFFER_SIZE, &macb->rx_buffer_dma);
- macb->rx_ring = dma_alloc_coherent(MACB_RX_RING_SIZE * sizeof(struct macb_dma_desc), &macb->rx_ring_dma);
- macb->tx_ring = dma_alloc_coherent(MACB_TX_RING_SIZE * sizeof(struct macb_dma_desc), &macb->tx_ring_dma);
On Tue, May 27, 2014 at 04:07:30PM +0800, Josh Wu wrote:
Hi, Dear Andreas
For clarity, I'm fine with this coming via u-boot-atmel..
Hi Tom,
Hi, Dear Andreas
me too, I just haven't had time to process these. Will do until this weekend.
Regards,
Andreas Bießmann
Dear Andreas Devel,
Andreas Devel andreas.devel@googlemail.com writes:
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com Reviewed-by: Josh Wu josh.wu@atmel.com
applied to u-boot-atmel/master, thanks!
Best regards, Andreas Bießmann
Andreas Bießmann
Josh Wu
