[PATCH 0/2] rockchip: rk35xx: Fix SPI Flash alias
The series "rockchip: rk35xx: Update defconfigs and enable boot from SPI NOR flash" enabled SPI flash boot support on ROCK 3A and ROCK 5B using a spi0 alias.
This spi0 alias should be used for the spi0 device tree node and not the sfc node.
Correct this by adding spi4 and spi5 aliases to <soc>-u-boot.dtsi and use SF_DEFAULT_BUS option to define the SPI flash bus. Also enabled support for parsing and auto discovery of parameters, SFDP, for the affected boards.
Jonas Karlman (2): rockchip: rk3568-rock-3a: Fix SPI Flash alias rockchip: rk3588-rock-5b: Fix SPI Flash alias
arch/arm/dts/rk3568-rock-3a-u-boot.dtsi | 4 ---- arch/arm/dts/rk356x-u-boot.dtsi | 1 + arch/arm/dts/rk3588-rock-5b-u-boot.dtsi | 1 - arch/arm/dts/rk3588s-u-boot.dtsi | 9 +++++++++ configs/rock-3a-rk3568_defconfig | 3 +++ configs/rock5b-rk3588_defconfig | 3 +++ 6 files changed, 16 insertions(+), 5 deletions(-)
The commit 64f79f88a751 ("rockchip: rk3568-rock-3a: Enable boot from SPI NOR flash") enabled SPI flash support by overriding the spi0 alias.
Correct this by adding a new spi4 alias in rk356x-u-boot.dtsi and SF_DEFAULT_BUS=4 and SPL_DM_SEQ_ALIAS=y in defconfig. Also enabled support for parsing and auto discovery of parameters, SFDP.
Fixes: 64f79f88a751 ("rockchip: rk3568-rock-3a: Enable boot from SPI NOR flash") Signed-off-by: Jonas Karlman jonas@kwiboo.se --- arch/arm/dts/rk3568-rock-3a-u-boot.dtsi | 4 ---- arch/arm/dts/rk356x-u-boot.dtsi | 1 + configs/rock-3a-rk3568_defconfig | 3 +++ 3 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/rk3568-rock-3a-u-boot.dtsi b/arch/arm/dts/rk3568-rock-3a-u-boot.dtsi index 45e9390f202d..6d1d3731d1da 100644 --- a/arch/arm/dts/rk3568-rock-3a-u-boot.dtsi +++ b/arch/arm/dts/rk3568-rock-3a-u-boot.dtsi @@ -7,10 +7,6 @@ #include "rk356x-u-boot.dtsi"
/ { - aliases { - spi0 = &sfc; - }; - chosen { stdout-path = &uart2; }; diff --git a/arch/arm/dts/rk356x-u-boot.dtsi b/arch/arm/dts/rk356x-u-boot.dtsi index 5644f78ec774..d21b18205220 100644 --- a/arch/arm/dts/rk356x-u-boot.dtsi +++ b/arch/arm/dts/rk356x-u-boot.dtsi @@ -9,6 +9,7 @@ aliases { mmc0 = &sdhci; mmc1 = &sdmmc0; + spi4 = &sfc; };
chosen { diff --git a/configs/rock-3a-rk3568_defconfig b/configs/rock-3a-rk3568_defconfig index cc3677e93b7a..c8b3e0430b6d 100644 --- a/configs/rock-3a-rk3568_defconfig +++ b/configs/rock-3a-rk3568_defconfig @@ -56,6 +56,7 @@ CONFIG_CMD_REGULATOR=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIVE=y CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_REGMAP=y CONFIG_SPL_SYSCON=y CONFIG_SPL_CLK=y @@ -68,6 +69,8 @@ CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_SF_DEFAULT_BUS=4 +CONFIG_SPI_FLASH_SFDP_SUPPORT=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_XTX=y CONFIG_ETH_DESIGNWARE=y
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- aliases {
spi0 = &sfc;
spi4 = &sfc;
chosen {
The commit fd6e425be243 ("rockchip: rk3588-rock-5b: Enable boot from SPI NOR flash") enabled SPI flash support by adding a spi0 alias.
Correct this by adding spi0-spi5 aliases in rk3588s-u-boot.dtsi and SF_DEFAULT_BUS=5 and SPL_DM_SEQ_ALIAS=y in defconfig. Also enabled support for parsing and auto discovery of parameters, SFDP.
Fixes: fd6e425be243 ("rockchip: rk3588-rock-5b: Enable boot from SPI NOR flash") Signed-off-by: Jonas Karlman jonas@kwiboo.se --- arch/arm/dts/rk3588-rock-5b-u-boot.dtsi | 1 - arch/arm/dts/rk3588s-u-boot.dtsi | 9 +++++++++ configs/rock5b-rk3588_defconfig | 3 +++ 3 files changed, 12 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi b/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi index 1cd8a57a6fa6..fc2825931a30 100644 --- a/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi +++ b/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi @@ -11,7 +11,6 @@ / { aliases { mmc1 = &sdmmc; - spi0 = &sfc; };
chosen { diff --git a/arch/arm/dts/rk3588s-u-boot.dtsi b/arch/arm/dts/rk3588s-u-boot.dtsi index c703e41802b6..53b514ac52c0 100644 --- a/arch/arm/dts/rk3588s-u-boot.dtsi +++ b/arch/arm/dts/rk3588s-u-boot.dtsi @@ -7,6 +7,15 @@ #include <dt-bindings/phy/phy.h>
/ { + aliases { + spi0 = &spi0; + spi1 = &spi1; + spi2 = &spi2; + spi3 = &spi3; + spi4 = &spi4; + spi5 = &sfc; + }; + dmc { compatible = "rockchip,rk3588-dmc"; bootph-all; diff --git a/configs/rock5b-rk3588_defconfig b/configs/rock5b-rk3588_defconfig index 17205a56cd99..f35886d9ffd1 100644 --- a/configs/rock5b-rk3588_defconfig +++ b/configs/rock5b-rk3588_defconfig @@ -56,6 +56,7 @@ CONFIG_CMD_REGULATOR=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIVE=y CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_REGMAP=y CONFIG_SPL_SYSCON=y CONFIG_SPL_CLK=y @@ -68,6 +69,8 @@ CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_SF_DEFAULT_BUS=5 +CONFIG_SPI_FLASH_SFDP_SUPPORT=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_XTX=y CONFIG_ETH_DESIGNWARE=y
Thanks, - Kever
spi0 = &sfc;
chosen {
- aliases {
spi0 = &spi0;
spi1 = &spi1;
spi2 = &spi2;
spi3 = &spi3;
spi4 = &spi4;
spi5 = &sfc;
- dmc { compatible = "rockchip,rk3588-dmc"; bootph-all;
Jonas Karlman
Kever Yang
