[U-Boot] [PATCH 0/3] Small fixes for Olimex MX23 based Olinuxino boards
Testing of v2018.11-rc2 on this board uncovered three small "issues" I would like to see fixed. See individual patch descriptions for details.
Michael Heimpold (3): configs: drop CMD_CACHE from mx23_olinuxino_defconfig configs: mx23_olinuxino_defconfig: fix status led definition configs: mx23_olinuxino_defconfig: disable bootefi command
configs/mx23_olinuxino_defconfig | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
This prevents the warning message "No arch specific invalidate_icache_all available!" during boot.
Signed-off-by: Michael Heimpold mhei@heimpold.de --- configs/mx23_olinuxino_defconfig | 1 - 1 file changed, 1 deletion(-)
diff --git a/configs/mx23_olinuxino_defconfig b/configs/mx23_olinuxino_defconfig index 2eee19dab5..6597dc3870 100644 --- a/configs/mx23_olinuxino_defconfig +++ b/configs/mx23_olinuxino_defconfig @@ -20,7 +20,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y -CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_MMC=y
Can you implement it ? The cache support worked on MX23.
Am Dienstag, 30. Oktober 2018, 11:35:25 CET schrieb Marek Vasut:
Hm, I had a second look: for invalidate_icache_all() - we already have an implementation in arch/arm/cpu/arm926ejs/cache.c - we have a weak symbol in cmd/cache.c - we have a weak symbol in lib/efi_loader/efi_image_loader.c
I don't know how I managed to get the warning - cannot reproduce it anymore. So I withdraw this one patch, sorry for the noise.
Regards, Michael
-CONFIG_CMD_CACHE=y
While migrating individual status led usages to Kconfig stuff, a (random) value was introduced for this board which does not work but produces the following error message during boot:
__led_init: failed requesting GPIO59!
Since Kconfig does not seem to accept a define as this point, but the mxs gpio driver requires not only a simple integer value, we need to use the plain value of MX23_PAD_SSP1_DETECT__GPIO_2_1.
Signed-off-by: Michael Heimpold mhei@heimpold.de Fixes: 2d8d190c8394 ("status_led: Kconfig migration") --- configs/mx23_olinuxino_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/mx23_olinuxino_defconfig b/configs/mx23_olinuxino_defconfig index 6597dc3870..598547a5f5 100644 --- a/configs/mx23_olinuxino_defconfig +++ b/configs/mx23_olinuxino_defconfig @@ -26,7 +26,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_LED_STATUS=y CONFIG_LED_STATUS_GPIO=y CONFIG_LED_STATUS0=y -CONFIG_LED_STATUS_BIT=59 +CONFIG_LED_STATUS_BIT=778 CONFIG_LED_STATUS_STATE=2 CONFIG_LED_STATUS_BOOT_ENABLE=y CONFIG_LED_STATUS_BOOT=0
Best regards, Stefano Babic
CONFIG_CMD_BOOTEFI is enabled by Kconfig default, but rarely used on this board/platform. So let's disable it for the boards default config. This also saves around 16 KiB in the final u-boot.sb.
Signed-off-by: Michael Heimpold mhei@heimpold.de --- configs/mx23_olinuxino_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/mx23_olinuxino_defconfig b/configs/mx23_olinuxino_defconfig index 598547a5f5..1bf76e2e11 100644 --- a/configs/mx23_olinuxino_defconfig +++ b/configs/mx23_olinuxino_defconfig @@ -14,6 +14,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_HUSH_PARSER=y +# CONFIG_CMD_BOOTEFI is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y
Michael Heimpold
Stefano Babic
