[U-Boot] [ppc4xx/next] Please pull git://www.denx.de/git/u-boot-ppc4xx.git
The following changes since commit 74957cb4295e39c8f2e05e0f1828917a450171f9: Graeme Russ (1): Add basic relocation to i386 port
git://www.denx.de/git/u-boot-ppc4xx.git next
Matthias Fuchs (6): ppc4xx: Abort autoboot only by space key on CPCI405 boards ppc4xx: DU405 maintenance fix ppc4xx: Update TEXT_BASE for DASA_SIM boards ppc4xx: Cleanup linker scripts of esd 4xx boards ppc4xx: Use correct io accessors for esd 405 boards ppc4xx: Use correct io accessors for esd 405/440 boards
Stefan Roese (1): ppc4xx: Don't write the MAC address into the internal SoC registers
board/esd/adciop/u-boot.lds | 4 - board/esd/apc405/apc405.c | 2 +- board/esd/apc405/u-boot.lds | 15 --- board/esd/ar405/ar405.c | 83 +++++++++--------- board/esd/ar405/u-boot.lds | 28 ------ board/esd/ash405/ash405.c | 12 +-- board/esd/ash405/u-boot.lds | 15 --- board/esd/canbt/canbt.c | 7 +- board/esd/canbt/u-boot.lds | 26 ------ board/esd/cms700/cms700.c | 13 ++-- board/esd/cms700/u-boot.lds | 15 --- board/esd/common/fpga.c | 14 ++- board/esd/common/lcd.h | 14 ++-- board/esd/common/xilinx_jtag/ports.c | 5 +- board/esd/cpci2dp/cpci2dp.c | 18 +++-- board/esd/cpci2dp/u-boot.lds | 15 --- board/esd/cpci405/cpci405.c | 8 +- board/esd/cpciiser4/cpciiser4.c | 3 +- board/esd/cpciiser4/u-boot.lds | 15 --- board/esd/dasa_sim/cmd_dasa_sim.c | 9 +- board/esd/dasa_sim/config.mk | 11 +-- board/esd/dasa_sim/dasa_sim.c | 12 ++- board/esd/dasa_sim/eeprom.c | 18 ++-- board/esd/dasa_sim/u-boot.lds | 26 ------ board/esd/dp405/dp405.c | 14 ++- board/esd/dp405/u-boot.lds | 16 ---- board/esd/du405/du405.c | 14 ++- board/esd/du405/u-boot.lds | 15 --- board/esd/du440/du440.c | 13 ++-- board/esd/du440/u-boot.lds | 3 - board/esd/hh405/hh405.c | 166 +++++++++++++++++++++------------- board/esd/hh405/u-boot.lds | 15 --- board/esd/hub405/hub405.c | 56 ++++++------ board/esd/hub405/u-boot.lds | 16 ---- board/esd/pci405/pci405.c | 8 +- board/esd/pci405/u-boot.lds | 15 --- board/esd/plu405/plu405.c | 10 +- board/esd/plu405/u-boot.lds | 3 - board/esd/pmc405/u-boot.lds | 15 --- board/esd/pmc440/cmd_pmc440.c | 2 +- board/esd/pmc440/pmc440.c | 59 +++++++------ board/esd/pmc440/u-boot.lds | 3 - board/esd/tasreg/tasreg.c | 7 +- board/esd/voh405/u-boot.lds | 16 ---- board/esd/voh405/voh405.c | 10 +- board/esd/vom405/u-boot.lds | 3 - board/esd/vom405/vom405.c | 17 ++-- board/esd/wuh405/u-boot.lds | 15 --- board/esd/wuh405/wuh405.c | 18 ++-- board/g2000/u-boot.lds | 16 ---- cpu/ppc4xx/cpu_init.c | 29 +------ include/configs/CPCI4052.h | 6 ++ include/configs/CPCI405AB.h | 6 ++ include/configs/DASA_SIM.h | 4 +- include/configs/DU405.h | 14 ++-- include/configs/HH405.h | 17 ---- 56 files changed, 360 insertions(+), 649 deletions(-)
Dear Stefan Roese,
Applied to "next" branch.
Why didn't you include these two patches, too:
02/23 Stefan Roese [U-Boot] [PATCH/next branch] powerpc: Fix compilation warning in board.c 02/23 Stefan Roese [U-Boot] [PATCH/next branch] powerpc: Only use eth_getenv_enetaddr() if networking is enabled
Stefan Roese
