[PATCH 0/6 v2] EFI variable support via OP-TEE
Hi!
This is the v2 of the patchset adding EFI variable support via OP-TEE originally posted here [1]
Changes since v1: * patch #2: - Fix Copyright issues - Merge the include files in mm_communication.h - Rename some variables and follow EDK2 naming - Added proper documentation on struct definitions - Add missing defines (unused but good to have there) - Use flexible array members on structs and replace data[1] with data[] * patch #3: - Adjust efi_variable_tee.c to header file changes and fix typos * patch #4: - Remove EFI_HANDLE_WIDTH on printing - Rephrase 'efidebug query' help message * patch #5 - Move mm_communication.h maintenership * patch #6 - Heinrich's suggestion, on the help file, was a lot cleaner and easier to understand. Using it as-is
[1] https://lists.denx.de/pipermail/u-boot/2020-May/410772.html
Ilias Apalodimas (4): efi_loader: Implement EFI variable handling via OP-TEE cmd: efidebug: Add support for querying UEFI variable storage MAINTAINERS: Add maintainer for EFI variables via OP-TEE doc: uefi.rst: Add OP-TEE variable storage config options
Sughosh Ganu (1): efi_loader: Add headers for EDK2 StandAloneMM communication
MAINTAINERS | 6 + cmd/efidebug.c | 44 +- doc/uefi/uefi.rst | 17 + include/mm_communication.h | 207 ++++++++++ lib/efi_loader/Kconfig | 9 + lib/efi_loader/Makefile | 4 + lib/efi_loader/efi_variable_tee.c | 643 ++++++++++++++++++++++++++++++ 7 files changed, 929 insertions(+), 1 deletion(-) create mode 100644 include/mm_communication.h create mode 100644 lib/efi_loader/efi_variable_tee.c
In Arm devices OP-TEE has the ability to run StandAloneMM (from EDK2) in a separate partition and handle UEFI variables. A following patch introduces this functionality.
Add the headers needed for OP-TEE <--> StandAloneMM communication
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- include/mm_communication.h | 207 +++++++++++++++++++++++++++++++++++++ 1 file changed, 207 insertions(+) create mode 100644 include/mm_communication.h
diff --git a/include/mm_communication.h b/include/mm_communication.h new file mode 100644 index 000000000000..b9bfbe4cf0a1 --- /dev/null +++ b/include/mm_communication.h @@ -0,0 +1,207 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Headers for EFI variable service via StandAloneMM, EDK2 application running + * in OP-TEE + * + * Copyright (c) 2017, Intel Corporation. All rights reserved. + * Copyright (C) 2020 Linaro Ltd. sughosh.ganu@linaro.org + * Copyright (C) 2020 Linaro Ltd. ilias.apalodimas@linaro.org + */ + +#ifndef _MM_VARIABLE_H_ +#define _MM_VARIABLE_H_ + +#include <part_efi.h> + +/* + * Interface to the pseudo TA, which provides a communication channel with + * the StandaloneMM Secure Partition (StMM) running at S-EL0 + */ + +#define PTA_STMM_CMDID_COMMUNICATE 0 + +/* OP-TEE is using big endian GUIDs while UEFI uses little endian ones */ +#define PTA_STMM_UUID { 0xed32d533, 0x99e6, 0x4209, {\ + 0x9c, 0xc0, 0x2d, 0x72, 0xcd, 0xd9, 0x98, 0xa7 } } + +#define EFI_MM_VARIABLE_GUID \ + EFI_GUID(0xed32d533, 0x99e6, 0x4209, \ + 0x9c, 0xc0, 0x2d, 0x72, 0xcd, 0xd9, 0x98, 0xa7) + +/* Defined in EDK2 MdePkg/Include/Protocol/MmCommunication.h */ + +/** + * struct efi_mm_communicate_header - Header used for SMM variable communication + + * @header_guid: header use for disambiguation of content + * @message_len: length of the message. Does not include the size of the + * header + * @data: payload of the message + * + * Defined in EDK2 as EFI_MM_COMMUNICATE_HEADER + * To avoid confusion in interpreting frames, the communication buffer should + * always begin with efi_mm_communicate_header + */ +struct efi_mm_communicate_header { + efi_guid_t header_guid; + size_t message_len; + u8 data[]; +}; + +#define MM_COMMUNICATE_HEADER_SIZE \ + (sizeof(struct efi_mm_communicate_header)) + +/* Defined in EDK2 ArmPkg/Include/IndustryStandard/ArmStdSmc.h */ + +/* MM return error codes */ +#define ARM_SMC_MM_RET_SUCCESS 0 +#define ARM_SMC_MM_RET_NOT_SUPPORTED -1 +#define ARM_SMC_MM_RET_INVALID_PARAMS -2 +#define ARM_SMC_MM_RET_DENIED -3 +#define ARM_SMC_MM_RET_NO_MEMORY -4 + +/* Defined in EDK2 MdeModulePkg/Include/Guid/SmmVariableCommon.h */ + +#define SMM_VARIABLE_FUNCTION_GET_VARIABLE 1 +/* + * The payload for this function is + * SMM_VARIABLE_COMMUNICATE_GET_NEXT_VARIABLE_NAME. + */ +#define SMM_VARIABLE_FUNCTION_GET_NEXT_VARIABLE_NAME 2 +/* + * The payload for this function is SMM_VARIABLE_COMMUNICATE_ACCESS_VARIABLE. + */ +#define SMM_VARIABLE_FUNCTION_SET_VARIABLE 3 +/* + * The payload for this function is + * SMM_VARIABLE_COMMUNICATE_QUERY_VARIABLE_INFO. + */ +#define SMM_VARIABLE_FUNCTION_QUERY_VARIABLE_INFO 4 +/* + * It is a notify event, no extra payload for this function. + */ +#define SMM_VARIABLE_FUNCTION_READY_TO_BOOT 5 +/* + * It is a notify event, no extra payload for this function. + */ +#define SMM_VARIABLE_FUNCTION_EXIT_BOOT_SERVICE 6 +/* + * The payload for this function is VARIABLE_INFO_ENTRY. + * The GUID in EFI_SMM_COMMUNICATE_HEADER is gEfiSmmVariableProtocolGuid. + */ +#define SMM_VARIABLE_FUNCTION_GET_STATISTICS 7 +/* + * The payload for this function is SMM_VARIABLE_COMMUNICATE_LOCK_VARIABLE + */ +#define SMM_VARIABLE_FUNCTION_LOCK_VARIABLE 8 + +#define SMM_VARIABLE_FUNCTION_VAR_CHECK_VARIABLE_PROPERTY_SET 9 + +#define SMM_VARIABLE_FUNCTION_VAR_CHECK_VARIABLE_PROPERTY_GET 10 + +#define SMM_VARIABLE_FUNCTION_GET_PAYLOAD_SIZE 11 +/* + * The payload for this function is + * SMM_VARIABLE_COMMUNICATE_RUNTIME_VARIABLE_CACHE_CONTEXT + */ +#define SMM_VARIABLE_FUNCTION_INIT_RUNTIME_VARIABLE_CACHE_CONTEXT 12 + +#define SMM_VARIABLE_FUNCTION_SYNC_RUNTIME_CACHE 13 +/* + * The payload for this function is + * SMM_VARIABLE_COMMUNICATE_GET_RUNTIME_CACHE_INFO + */ +#define SMM_VARIABLE_FUNCTION_GET_RUNTIME_CACHE_INFO 14 + +/** + * struct smm_variable_communicate_header - Used for SMM variable communication + + * @function: function to call in Smm. + * @ret_status: return status + * @data: payload + * + * Defined in EDK2 as SMM_VARIABLE_COMMUNICATE_HEADER + */ +struct smm_variable_communicate_header { + efi_uintn_t function; + efi_status_t ret_status; + u8 data[]; +}; + +#define MM_VARIABLE_COMMUNICATE_SIZE \ + (sizeof(struct smm_variable_communicate_header)) + +/** + * struct smm_variable_access - Used to communicate with StMM by + * SetVariable and GetVariable. + + * @function: vendor GUID to call in Smm + * @data_size: size of EFI variable data + * @name_size: size of EFI name + * @attr: attributes + * @name: variable name + * + * Defined in EDK2 as SMM_VARIABLE_COMMUNICATE_ACCESS_VARIABLE + * + */ +struct smm_variable_access { + efi_guid_t guid; + efi_uintn_t data_size; + efi_uintn_t name_size; + u32 attr; + u16 name[]; +}; + +#define MM_VARIABLE_ACCESS_HEADER_SIZE \ + (sizeof(struct smm_variable_access)) +/** + * struct smm_variable_payload_size - Used to get the max allowed + * payload used in StMM. + * + * @size: size to fill in + * + * Defined in EDK2 as SMM_VARIABLE_COMMUNICATE_GET_PAYLOAD_SIZE + * + */ +struct smm_variable_payload_size { + efi_uintn_t size; +}; + +/** + * struct smm_variable_getnext - Used to communicate with StMM for + * GetNextVariableName. + * + * @size: vendor GUID + * @name_size: size of the name of the variable + * @name: variable name + * + * Defined in EDK2 as SMM_VARIABLE_COMMUNICATE_GET_PAYLOAD_SIZE + */ +struct smm_variable_getnext { + efi_guid_t guid; + efi_uintn_t name_size; + u16 name[]; +}; + +#define MM_VARIABLE_GET_NEXT_HEADER_SIZE \ + (sizeof(struct smm_variable_getnext)) + +/** + * struct smm_variable_query_info - Used to communicate with StMM for + * QueryVariableInfo. + * + * @max_variable_storage: max available storage + * @remaining_variable_storage: remaining available storage + * @max_variable_size: max variable supported size + * @attr: attributes to query storage for + * + * Defined in EDK2 as SMM_VARIABLE_COMMUNICATE_GET_PAYLOAD_SIZE + */ +struct smm_variable_query_info { + u64 max_variable_storage; + u64 remaining_variable_storage; + u64 max_variable_size; + u32 attr; +}; + +#endif /* _MM_VARIABLE_H_ */
- Headers for EFI variable service via StandAloneMM, EDK2 application running
- in OP-TEE
- Copyright (c) 2017, Intel Corporation. All rights reserved.
- Copyright (C) 2020 Linaro Ltd. sughosh.ganu@linaro.org
- Copyright (C) 2020 Linaro Ltd. ilias.apalodimas@linaro.org
- Interface to the pseudo TA, which provides a communication channel with
U-Boot developers might not know the OP-TEE terms. So I would tend to avoid abbreviations at least in the first reference.
%s/pseudo TA/Pseudo Trusted Application/
- the StandaloneMM Secure Partition (StMM) running at S-EL0
What does MM stand for? Management Mode?
- EFI_GUID(0xed32d533, 0x99e6, 0x4209, \
- struct efi_mm_communicate_header - Header used for SMM variable communication
- @header_guid: header use for disambiguation of content
- @message_len: length of the message. Does not include the size of the
header
- @data: payload of the message
- Defined in EDK2 as EFI_MM_COMMUNICATE_HEADER
- To avoid confusion in interpreting frames, the communication buffer should
- always begin with efi_mm_communicate_header
%s/efi_mm_communicate_header/efi_mm_communicate_header./
- efi_guid_t header_guid;
- size_t message_len;
- u8 data[];
- (sizeof(struct efi_mm_communicate_header))
- The payload for this function is
- SMM_VARIABLE_COMMUNICATE_GET_NEXT_VARIABLE_NAME.
- The payload for this function is SMM_VARIABLE_COMMUNICATE_ACCESS_VARIABLE.
- SMM_VARIABLE_COMMUNICATE_QUERY_VARIABLE_INFO.
- It is a notify event, no extra payload for this function.
- The payload for this function is VARIABLE_INFO_ENTRY.
- The GUID in EFI_SMM_COMMUNICATE_HEADER is gEfiSmmVariableProtocolGuid.
- The payload for this function is SMM_VARIABLE_COMMUNICATE_LOCK_VARIABLE
- SMM_VARIABLE_COMMUNICATE_RUNTIME_VARIABLE_CACHE_CONTEXT
- SMM_VARIABLE_COMMUNICATE_GET_RUNTIME_CACHE_INFO
- struct smm_variable_communicate_header - Used for SMM variable communication
- @function: function to call in Smm.
- @ret_status: return status
- @data: payload
- Defined in EDK2 as SMM_VARIABLE_COMMUNICATE_HEADER
- efi_uintn_t function;
- efi_status_t ret_status;
- u8 data[];
- (sizeof(struct smm_variable_communicate_header))
- struct smm_variable_access - Used to communicate with StMM by
- @function: vendor GUID to call in Smm
- @data_size: size of EFI variable data
- @name_size: size of EFI name
- @attr: attributes
- @name: variable name
- Defined in EDK2 as SMM_VARIABLE_COMMUNICATE_ACCESS_VARIABLE
- efi_guid_t guid;
- efi_uintn_t data_size;
- efi_uintn_t name_size;
- u32 attr;
- u16 name[];
- (sizeof(struct smm_variable_access))
- struct smm_variable_payload_size - Used to get the max allowed
- @size: size to fill in
- Defined in EDK2 as SMM_VARIABLE_COMMUNICATE_GET_PAYLOAD_SIZE
%s/SMM_VARIABLE_COMMUNICATE_GET_PAYLOAD_SIZE/SMM_VARIABLE_COMMUNICATE_GET_PAYLOAD_SIZE./
- efi_uintn_t size;
- struct smm_variable_getnext - Used to communicate with StMM for
- @size: vendor GUID
- @name_size: size of the name of the variable
%s/SMM_VARIABLE_COMMUNICATE_GET_PAYLOAD_SIZE/SMM_VARIABLE_COMMUNICATE_GET_NEXT_VARIABLE_NAME./
Too much copy and paste ;)
- efi_guid_t guid;
- u16 name[];
- (sizeof(struct smm_variable_getnext))
- struct smm_variable_query_info - Used to communicate with StMM for
QueryVariableInfo.
- @max_variable_storage: max available storage
- @remaining_variable_storage: remaining available storage
- @max_variable_size: max variable supported size
- @attr: attributes to query storage for
%s/SMM_VARIABLE_COMMUNICATE_GET_PAYLOAD_SIZE/SMM_VARIABLE_COMMUNICATE_QUERY_VARIABLE_INFO./
I hope I caught all comment errors. Please, recheck.
Otherwise: Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
- u64 max_variable_storage;
- u64 remaining_variable_storage;
- u64 max_variable_size;
- u32 attr;
Hi Heinrich
Yes
Indeed! Thanks for cathcing those
- efi_guid_t guid;
- u16 name[];
QueryVariableInfo.
Ok will do
Thanks! /Ilias
There were 3-4 more c/p trainwrecks in there. I'll post a v3 once you are done with your testing.
Thanks /Ilias
In OP-TEE we can run EDK2's StandAloneMM on a secure partition. StandAloneMM is responsible for the UEFI variable support. In combination with OP-TEE and it's U-Boot supplicant, variables are authenticated/validated in secure world and stored on an RPMB partition.
So let's add a new config option in U-Boot implementing the necessary calls to OP-TEE for the variable management.
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org Signed-off-by: Pipat Methavanitpong pipat1010@gmail.com Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org --- lib/efi_loader/Kconfig | 9 + lib/efi_loader/Makefile | 4 + lib/efi_loader/efi_variable_tee.c | 643 ++++++++++++++++++++++++++++++ 3 files changed, 656 insertions(+) create mode 100644 lib/efi_loader/efi_variable_tee.c
diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index 1cfa24ffcf72..e385cd0b9dae 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -164,4 +164,13 @@ config EFI_SECURE_BOOT it is signed with a trusted key. To do that, you need to install, at least, PK, KEK and db.
+config EFI_MM_COMM_TEE + bool "UEFI variables storage service via OP-TEE" + depends on SUPPORT_EMMC_RPMB + default n + help + If OP-TEE is present and running StandAloneMM dispatch all UEFI variable + related operations to that. The application will verify, authenticate and + store the variables on an RPMB + endif diff --git a/lib/efi_loader/Makefile b/lib/efi_loader/Makefile index eff3c25ec301..dba652121eab 100644 --- a/lib/efi_loader/Makefile +++ b/lib/efi_loader/Makefile @@ -34,7 +34,11 @@ obj-y += efi_root_node.o obj-y += efi_runtime.o obj-y += efi_setup.o obj-$(CONFIG_EFI_UNICODE_COLLATION_PROTOCOL2) += efi_unicode_collation.o +ifeq ($(CONFIG_EFI_MM_COMM_TEE),y) +obj-y += efi_variable_tee.o +else obj-y += efi_variable.o +endif obj-y += efi_watchdog.o obj-$(CONFIG_LCD) += efi_gop.o obj-$(CONFIG_DM_VIDEO) += efi_gop.o diff --git a/lib/efi_loader/efi_variable_tee.c b/lib/efi_loader/efi_variable_tee.c new file mode 100644 index 000000000000..f8857bb81e72 --- /dev/null +++ b/lib/efi_loader/efi_variable_tee.c @@ -0,0 +1,643 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * EFI variable service via OP-TEE + * + * Copyright (C) 2019 Linaro Ltd. sughosh.ganu@linaro.org + * Copyright (C) 2019 Linaro Ltd. ilias.apalodimas@linaro.org + */ + +#include <common.h> +#include <efi.h> +#include <efi_api.h> +#include <efi_loader.h> +#include <tee.h> +#include <malloc.h> +#include <mm_communication.h> + +static efi_uintn_t max_buffer_size; /* comm + var + func + data */ +static efi_uintn_t max_payload_size; /* func + data */ + +struct mm_connection { + struct udevice *tee; + u32 session; +}; + +/** + * get_connection() - Retrieve OP-TEE session for a specific UUID. + * + * @conn: session buffer to fill + * Return: status code + */ +static int get_connection(struct mm_connection *conn) +{ + static const struct tee_optee_ta_uuid uuid = PTA_STMM_UUID; + struct udevice *tee = NULL; + struct tee_open_session_arg arg; + int rc; + + tee = tee_find_device(tee, NULL, NULL, NULL); + if (!tee) + return -ENODEV; + + memset(&arg, 0, sizeof(arg)); + tee_optee_ta_uuid_to_octets(arg.uuid, &uuid); + rc = tee_open_session(tee, &arg, 0, NULL); + if (!rc) { + conn->tee = tee; + conn->session = arg.session; + } + + return rc; +} + +/** + * optee_mm_communicate() - Pass a buffer to StandaloneMM running in OP-TEE + * + * @comm_buf: locally allocted communcation buffer + * @dsize: buffer size + * Return: status code + */ +static efi_status_t optee_mm_communicate(void *comm_buf, ulong dsize) +{ + ulong buf_size; + efi_status_t ret; + struct efi_mm_communicate_header *mm_hdr; + struct mm_connection conn = { NULL, 0 }; + struct tee_invoke_arg arg; + struct tee_param param[2]; + struct tee_shm *shm = NULL; + int rc; + + if (!comm_buf) + return EFI_INVALID_PARAMETER; + + mm_hdr = (struct efi_mm_communicate_header *)comm_buf; + buf_size = mm_hdr->message_len + sizeof(efi_guid_t) + sizeof(size_t); + + if (dsize != buf_size) + return EFI_INVALID_PARAMETER; + + rc = get_connection(&conn); + if (rc) { + log_err("Unable to open OP-TEE session (err=%d)\n", rc); + return EFI_UNSUPPORTED; + } + + if (tee_shm_register(conn.tee, comm_buf, buf_size, 0, &shm)) { + log_err("Unable to register shared memory\n"); + return EFI_UNSUPPORTED; + } + + memset(&arg, 0, sizeof(arg)); + arg.func = PTA_STMM_CMDID_COMMUNICATE; + arg.session = conn.session; + + memset(param, 0, sizeof(param)); + param[0].attr = TEE_PARAM_ATTR_TYPE_MEMREF_INOUT; + param[0].u.memref.size = buf_size; + param[0].u.memref.shm = shm; + param[1].attr = TEE_PARAM_ATTR_TYPE_VALUE_OUTPUT; + + rc = tee_invoke_func(conn.tee, &arg, 2, param); + if (rc) + return EFI_INVALID_PARAMETER; + tee_shm_free(shm); + tee_close_session(conn.tee, conn.session); + + switch (param[1].u.value.a) { + case ARM_SMC_MM_RET_SUCCESS: + ret = EFI_SUCCESS; + break; + + case ARM_SMC_MM_RET_INVALID_PARAMS: + ret = EFI_INVALID_PARAMETER; + break; + + case ARM_SMC_MM_RET_DENIED: + ret = EFI_ACCESS_DENIED; + break; + + case ARM_SMC_MM_RET_NO_MEMORY: + ret = EFI_OUT_OF_RESOURCES; + break; + + default: + ret = EFI_ACCESS_DENIED; + } + + return ret; +} + +/** + * mm_communicate() - Adjust the cmonnucation buffer to StandAlonneMM and send + * it to OP-TEE + * + * @comm_buf: locally allocted communcation buffer + * @dsize: buffer size + * Return: status code + */ +static efi_status_t mm_communicate(u8 *comm_buf, efi_uintn_t dsize) +{ + efi_status_t ret; + struct efi_mm_communicate_header *mm_hdr; + struct smm_variable_communicate_header *var_hdr; + + dsize += MM_COMMUNICATE_HEADER_SIZE + MM_VARIABLE_COMMUNICATE_SIZE; + mm_hdr = (struct efi_mm_communicate_header *)comm_buf; + var_hdr = (struct smm_variable_communicate_header *)mm_hdr->data; + + ret = optee_mm_communicate(comm_buf, dsize); + if (ret != EFI_SUCCESS) { + log_err("%s failed!\n", __func__); + return ret; + } + + return var_hdr->ret_status; +} + +/** + * setup_mm_hdr() - Allocate a buffer for StandAloneMM and initialize the + * header data. + * + * @dptr: pointer address of the corresponding StandAloneMM + * function + * @payload_size: buffer size + * @func: standAloneMM function number + * @ret: EFI return code + * Return: buffer or NULL + */ +static u8 *setup_mm_hdr(void **dptr, efi_uintn_t payload_size, + efi_uintn_t func, efi_status_t *ret) +{ + const efi_guid_t mm_var_guid = EFI_MM_VARIABLE_GUID; + struct efi_mm_communicate_header *mm_hdr; + struct smm_variable_communicate_header *var_hdr; + u8 *comm_buf; + + /* In the init function we initialize max_buffer_size with + * get_max_payload(). So skip the test if max_buffer_size is initialized + * StandAloneMM will perform similar checks and drop the buffer if it's + * too long + */ + if (max_buffer_size && max_buffer_size < + (MM_COMMUNICATE_HEADER_SIZE + + MM_VARIABLE_COMMUNICATE_SIZE + + payload_size)) { + *ret = EFI_INVALID_PARAMETER; + return NULL; + } + + comm_buf = calloc(1, MM_COMMUNICATE_HEADER_SIZE + + MM_VARIABLE_COMMUNICATE_SIZE + + payload_size); + if (!comm_buf) { + *ret = EFI_OUT_OF_RESOURCES; + return NULL; + } + + mm_hdr = (struct efi_mm_communicate_header *)comm_buf; + guidcpy(&mm_hdr->header_guid, &mm_var_guid); + mm_hdr->message_len = MM_VARIABLE_COMMUNICATE_SIZE + payload_size; + + var_hdr = (struct smm_variable_communicate_header *)mm_hdr->data; + var_hdr->function = func; + if (dptr) + *dptr = var_hdr->data; + *ret = EFI_SUCCESS; + + return comm_buf; +} + +/** + * get_max_payload() - Get variable payload size from StandAloneMM. + * + * @size: size of the variable in storage + * Return: status code + */ +efi_status_t EFIAPI get_max_payload(efi_uintn_t *size) +{ + struct smm_variable_payload_size *var_payload = NULL; + efi_uintn_t payload_size; + efi_status_t ret; + u8 *comm_buf; + + if (!size) + return EFI_INVALID_PARAMETER; + + payload_size = sizeof(*var_payload); + comm_buf = setup_mm_hdr((void **)&var_payload, payload_size, + SMM_VARIABLE_FUNCTION_GET_PAYLOAD_SIZE, &ret); + if (!comm_buf) + return EFI_EXIT(ret); + + ret = mm_communicate(comm_buf, payload_size); + if (ret != EFI_SUCCESS) + goto out; + + *size = var_payload->size; + +out: + free(comm_buf); + return ret; +} + +/** + * efi_get_variable() - retrieve value of a UEFI variable + * + * This function implements the GetVariable runtime service. + * + * See the Unified Extensible Firmware Interface (UEFI) specification for + * details. + * + * @name: name of the variable + * @guid: vendor GUID + * @attr: attributes of the variable + * @data_size: size of the buffer to which the variable value is copied + * @data: buffer to which the variable value is copied + * Return: status code + */ +efi_status_t EFIAPI efi_get_variable(u16 *name, const efi_guid_t *guid, + u32 *attr, efi_uintn_t *data_size, + void *data) +{ + struct smm_variable_access *var_acc; + efi_uintn_t payload_size; + efi_uintn_t name_size; + efi_uintn_t tmp_dsize; + efi_status_t ret; + u8 *comm_buf; + + EFI_ENTRY(""%ls" %pUl %p %p %p", name, guid, attr, data_size, data); + + if (!name || !guid || !data_size) + return EFI_EXIT(EFI_INVALID_PARAMETER); + + /* Check payload size */ + name_size = u16_strsize(name); + if (name_size > max_payload_size - MM_VARIABLE_ACCESS_HEADER_SIZE) + return EFI_EXIT(EFI_INVALID_PARAMETER); + + /* Trim output buffer size */ + tmp_dsize = *data_size; + if (name_size + tmp_dsize > + max_payload_size - MM_VARIABLE_ACCESS_HEADER_SIZE) { + tmp_dsize = max_payload_size - + MM_VARIABLE_ACCESS_HEADER_SIZE - + name_size; + } + + /* Get communication buffer and initialize header */ + payload_size = MM_VARIABLE_ACCESS_HEADER_SIZE + name_size + tmp_dsize; + comm_buf = setup_mm_hdr((void **)&var_acc, payload_size, + SMM_VARIABLE_FUNCTION_GET_VARIABLE, &ret); + if (!comm_buf) + return EFI_EXIT(ret); + + /* Fill in contents */ + guidcpy(&var_acc->guid, guid); + var_acc->data_size = tmp_dsize; + var_acc->name_size = name_size; + var_acc->attr = attr ? *attr : 0; + memcpy(var_acc->name, name, name_size); + + /* Communicate */ + ret = mm_communicate(comm_buf, payload_size); + if (ret == EFI_SUCCESS || ret == EFI_BUFFER_TOO_SMALL) { + /* Update with reported data size for trimmed case */ + *data_size = var_acc->data_size; + } + if (ret != EFI_SUCCESS) + goto done; + + if (attr) + *attr = var_acc->attr; + if (data) + memcpy(data, (u8 *)var_acc->name + var_acc->name_size, + var_acc->data_size); + else + ret = EFI_INVALID_PARAMETER; + +done: + free(comm_buf); + return EFI_EXIT(ret); +} + +/** + * efi_get_next_variable_name() - enumerate the current variable names + * + * @variable_name_size: size of variable_name buffer in byte + * @variable_name: name of uefi variable's name in u16 + * @guid: vendor's guid + * + * This function implements the GetNextVariableName service. + * + * See the Unified Extensible Firmware Interface (UEFI) specification for + * details. + * + * Return: status code + */ +efi_status_t EFIAPI efi_get_next_variable_name(efi_uintn_t *variable_name_size, + u16 *variable_name, + efi_guid_t *guid) +{ + struct smm_variable_getnext *var_getnext; + efi_uintn_t payload_size; + efi_uintn_t tmp_dsize; + efi_uintn_t name_size; + efi_status_t ret; + efi_uintn_t out_name_size; + efi_uintn_t in_name_size; + u8 *comm_buf; + + EFI_ENTRY("%p "%ls" %pUl", variable_name_size, variable_name, guid); + + if (!variable_name_size || !variable_name || !guid) + return EFI_EXIT(EFI_INVALID_PARAMETER); + + out_name_size = *variable_name_size; + in_name_size = u16_strsize(variable_name); + + name_size = u16_strsize(variable_name); + if (name_size > max_payload_size - MM_VARIABLE_GET_NEXT_HEADER_SIZE) + return EFI_EXIT(EFI_INVALID_PARAMETER); + + /* Trim output buffer size */ + tmp_dsize = *variable_name_size; + if (name_size + tmp_dsize > + max_payload_size - MM_VARIABLE_GET_NEXT_HEADER_SIZE) { + tmp_dsize = max_payload_size - + MM_VARIABLE_GET_NEXT_HEADER_SIZE - + name_size; + } + + payload_size = MM_VARIABLE_GET_NEXT_HEADER_SIZE + + max(out_name_size, in_name_size); + comm_buf = setup_mm_hdr((void **)&var_getnext, payload_size, + SMM_VARIABLE_FUNCTION_GET_NEXT_VARIABLE_NAME, + &ret); + if (!comm_buf) + return EFI_EXIT(ret); + + /* Fill in contents */ + guidcpy(&var_getnext->guid, guid); + var_getnext->name_size = out_name_size; + memcpy(var_getnext->name, variable_name, in_name_size); + if (out_name_size > in_name_size) { + memset((u8 *)var_getnext->name + in_name_size, 0x0, + out_name_size - in_name_size); + } + + /* Communicate */ + ret = mm_communicate(comm_buf, payload_size); + if (ret == EFI_SUCCESS || ret == EFI_BUFFER_TOO_SMALL) { + /* Update with reported data size for trimmed case */ + *variable_name_size = var_getnext->name_size; + } + if (ret != EFI_SUCCESS) + goto done; + + guidcpy(guid, &var_getnext->guid); + memcpy(variable_name, (u8 *)var_getnext->name, + var_getnext->name_size); + +done: + free(comm_buf); + return EFI_EXIT(ret); +} + +/** + * efi_set_variable() - set value of a UEFI variable + * + * This function implements the SetVariable runtime service. + * + * See the Unified Extensible Firmware Interface (UEFI) specification for + * details. + * + * @name: name of the variable + * @guid: vendor GUID + * @attr: attributes of the variable + * @data_size: size of the buffer with the variable value + * @data: buffer with the variable value + * Return: status code + */ +efi_status_t EFIAPI efi_set_variable(u16 *name, const efi_guid_t *guid, + u32 attr, efi_uintn_t data_size, + const void *data) +{ + struct smm_variable_access *var_acc; + efi_uintn_t payload_size; + efi_uintn_t name_size; + efi_status_t ret; + u8 *comm_buf; + + EFI_ENTRY(""%ls" %pUl %x %zu %p", name, guid, attr, data_size, data); + + if (!name || name[0] == 0 || !guid) + return EFI_EXIT(EFI_INVALID_PARAMETER); + if (data_size > 0 && !data) + return EFI_EXIT(EFI_INVALID_PARAMETER); + + /* Check payload size */ + name_size = u16_strsize(name); + payload_size = MM_VARIABLE_ACCESS_HEADER_SIZE + name_size + data_size; + if (payload_size > max_payload_size) + return EFI_EXIT(EFI_INVALID_PARAMETER); + + /* Get communication buffer and initialize header */ + comm_buf = setup_mm_hdr((void **)&var_acc, payload_size, + SMM_VARIABLE_FUNCTION_SET_VARIABLE, &ret); + if (!comm_buf) + return EFI_EXIT(ret); + + /* Fill in contents */ + guidcpy(&var_acc->guid, guid); + var_acc->data_size = data_size; + var_acc->name_size = name_size; + var_acc->attr = attr; + memcpy(var_acc->name, name, name_size); + memcpy((u8 *)var_acc->name + name_size, data, data_size); + + /* Communicate */ + ret = mm_communicate(comm_buf, payload_size); + free(comm_buf); + + return EFI_EXIT(ret); +} + +/** + * efi_query_variable_info() - get information about EFI variables + * + * This function implements the QueryVariableInfo() runtime service. + * + * See the Unified Extensible Firmware Interface (UEFI) specification for + * details. + * + * @attributes: bitmask to select variables to be + * queried + * @maximum_variable_storage_size: maximum size of storage area for the + * selected variable types + * @remaining_variable_storage_size: remaining size of storage are for the + * selected variable types + * @maximum_variable_size: maximum size of a variable of the + * selected type + * Returns: status code + */ +efi_status_t EFIAPI __efi_runtime +efi_query_variable_info(u32 attributes, u64 *max_variable_storage_size, + u64 *remain_variable_storage_size, + u64 *max_variable_size) +{ + struct smm_variable_query_info *mm_query_info; + efi_uintn_t payload_size; + efi_status_t ret; + u8 *comm_buf; + + EFI_ENTRY("%x %p %p %p", attributes, max_variable_storage_size, + remain_variable_storage_size, max_variable_size); + + payload_size = sizeof(*mm_query_info); + comm_buf = setup_mm_hdr((void **)&mm_query_info, payload_size, + SMM_VARIABLE_FUNCTION_QUERY_VARIABLE_INFO, + &ret); + if (!comm_buf) + return EFI_EXIT(ret); + + mm_query_info->attr = attributes; + ret = mm_communicate(comm_buf, payload_size); + if (ret != EFI_SUCCESS) + goto out; + *max_variable_storage_size = mm_query_info->max_variable_storage; + *remain_variable_storage_size = + mm_query_info->remaining_variable_storage; + *max_variable_size = mm_query_info->max_variable_size; + +out: + free(comm_buf); + return EFI_EXIT(ret); +} + +/** + * efi_get_variable_runtime() - runtime implementation of GetVariable() + * + * @variable_name: name of the variable + * @guid: vendor GUID + * @attributes: attributes of the variable + * @data_size: size of the buffer to which the variable value is copied + * @data: buffer to which the variable value is copied + * Return: status code + */ +static efi_status_t __efi_runtime EFIAPI +efi_get_variable_runtime(u16 *variable_name, const efi_guid_t *guid, + u32 *attributes, efi_uintn_t *data_size, void *data) +{ + return EFI_UNSUPPORTED; +} + +/** + * efi_get_next_variable_name_runtime() - runtime implementation of + * GetNextVariable() + * + * @variable_name_size: size of variable_name buffer in byte + * @variable_name: name of uefi variable's name in u16 + * @guid: vendor's guid + * Return: status code + */ +static efi_status_t __efi_runtime EFIAPI +efi_get_next_variable_name_runtime(efi_uintn_t *variable_name_size, + u16 *variable_name, efi_guid_t *guid) +{ + return EFI_UNSUPPORTED; +} + +/** + * efi_query_variable_info() - get information about EFI variables + * + * This function implements the QueryVariableInfo() runtime service. + * + * See the Unified Extensible Firmware Interface (UEFI) specification for + * details. + * + * @attributes: bitmask to select variables to be + * queried + * @maximum_variable_storage_size: maximum size of storage area for the + * selected variable types + * @remaining_variable_storage_size: remaining size of storage are for the + * selected variable types + * @maximum_variable_size: maximum size of a variable of the + * selected type + * Return: status code + */ +efi_status_t EFIAPI __efi_runtime +efi_query_variable_info_runtime(u32 attributes, u64 *max_variable_storage_size, + u64 *remain_variable_storage_size, + u64 *max_variable_size) +{ + return EFI_UNSUPPORTED; +} + +/** + * efi_set_variable_runtime() - runtime implementation of SetVariable() + * + * @variable_name: name of the variable + * @guid: vendor GUID + * @attributes: attributes of the variable + * @data_size: size of the buffer with the variable value + * @data: buffer with the variable value + * Return: status code + */ +static efi_status_t __efi_runtime EFIAPI +efi_set_variable_runtime(u16 *variable_name, const efi_guid_t *guid, + u32 attributes, efi_uintn_t data_size, + const void *data) +{ + return EFI_UNSUPPORTED; +} + +/** + * efi_variables_boot_exit_notify() - notify ExitBootServices() is called + */ +void efi_variables_boot_exit_notify(void) +{ + u8 *comm_buf; + efi_status_t ret; + + comm_buf = setup_mm_hdr(NULL, 0, + SMM_VARIABLE_FUNCTION_EXIT_BOOT_SERVICE, &ret); + if (comm_buf) + ret = mm_communicate(comm_buf, 0); + else + ret = EFI_NOT_FOUND; + + if (ret != EFI_SUCCESS) + log_err("Unable to notify StMM for ExitBootServices\n"); + free(comm_buf); + + /* Update runtime service table */ + efi_runtime_services.query_variable_info = + efi_query_variable_info_runtime; + efi_runtime_services.get_variable = efi_get_variable_runtime; + efi_runtime_services.get_next_variable_name = + efi_get_next_variable_name_runtime; + efi_runtime_services.set_variable = efi_set_variable_runtime; + efi_update_table_header_crc32(&efi_runtime_services.hdr); +} + +/** + * efi_init_variables() - initialize variable services + * + * Return: status code + */ +efi_status_t efi_init_variables(void) +{ + efi_status_t ret; + + ret = get_max_payload(&max_payload_size); + if (ret != EFI_SUCCESS) + return ret; + + max_buffer_size = MM_COMMUNICATE_HEADER_SIZE + + MM_VARIABLE_COMMUNICATE_SIZE + + max_payload_size; + + return EFI_SUCCESS; +}
- bool "UEFI variables storage service via OP-TEE"
- depends on SUPPORT_EMMC_RPMB
- default n
- help
- EFI variable service via OP-TEE
- Copyright (C) 2019 Linaro Ltd. sughosh.ganu@linaro.org
- Copyright (C) 2019 Linaro Ltd. ilias.apalodimas@linaro.org
- struct udevice *tee;
- u32 session;
- get_connection() - Retrieve OP-TEE session for a specific UUID.
- @conn: session buffer to fill
- Return: status code
- static const struct tee_optee_ta_uuid uuid = PTA_STMM_UUID;
- struct udevice *tee = NULL;
- struct tee_open_session_arg arg;
- int rc;
- tee = tee_find_device(tee, NULL, NULL, NULL);
- if (!tee)
return -ENODEV;
- memset(&arg, 0, sizeof(arg));
- tee_optee_ta_uuid_to_octets(arg.uuid, &uuid);
- rc = tee_open_session(tee, &arg, 0, NULL);
- if (!rc) {
conn->tee = tee;
- return rc;
- optee_mm_communicate() - Pass a buffer to StandaloneMM running in OP-TEE
- @comm_buf: locally allocted communcation buffer
- @dsize: buffer size
- ulong buf_size;
- efi_status_t ret;
- struct efi_mm_communicate_header *mm_hdr;
- struct mm_connection conn = { NULL, 0 };
- struct tee_invoke_arg arg;
- struct tee_param param[2];
- struct tee_shm *shm = NULL;
- int rc;
- if (!comm_buf)
- mm_hdr = (struct efi_mm_communicate_header *)comm_buf;
- buf_size = mm_hdr->message_len + sizeof(efi_guid_t) + sizeof(size_t);
- if (dsize != buf_size)
- rc = get_connection(&conn);
- if (rc) {
- if (tee_shm_register(conn.tee, comm_buf, buf_size, 0, &shm)) {
- arg.func = PTA_STMM_CMDID_COMMUNICATE;
- arg.session = conn.session;
- memset(param, 0, sizeof(param));
- param[0].attr = TEE_PARAM_ATTR_TYPE_MEMREF_INOUT;
- param[0].u.memref.size = buf_size;
- param[0].u.memref.shm = shm;
- param[1].attr = TEE_PARAM_ATTR_TYPE_VALUE_OUTPUT;
- rc = tee_invoke_func(conn.tee, &arg, 2, param);
- if (rc)
- tee_shm_free(shm);
- tee_close_session(conn.tee, conn.session);
- switch (param[1].u.value.a) {
- case ARM_SMC_MM_RET_SUCCESS:
ret = EFI_SUCCESS;
break;
- case ARM_SMC_MM_RET_INVALID_PARAMS:
break;
- case ARM_SMC_MM_RET_DENIED:
break;
- case ARM_SMC_MM_RET_NO_MEMORY:
break;
- default:
- return ret;
- mm_communicate() - Adjust the cmonnucation buffer to StandAlonneMM and send
- it to OP-TEE
- efi_status_t ret;
- struct smm_variable_communicate_header *var_hdr;
- dsize += MM_COMMUNICATE_HEADER_SIZE + MM_VARIABLE_COMMUNICATE_SIZE;
- var_hdr = (struct smm_variable_communicate_header *)mm_hdr->data;
- ret = optee_mm_communicate(comm_buf, dsize);
- if (ret != EFI_SUCCESS) {
return ret;
- return var_hdr->ret_status;
- setup_mm_hdr() - Allocate a buffer for StandAloneMM and initialize the
header data.
- @dptr: pointer address of the corresponding StandAloneMM
function
- @payload_size: buffer size
- @func: standAloneMM function number
- @ret: EFI return code
- Return: buffer or NULL
- const efi_guid_t mm_var_guid = EFI_MM_VARIABLE_GUID;
- u8 *comm_buf;
- /* In the init function we initialize max_buffer_size with
* too long
- if (max_buffer_size && max_buffer_size <
payload_size)) {
return NULL;
- comm_buf = calloc(1, MM_COMMUNICATE_HEADER_SIZE +
payload_size);
- if (!comm_buf) {
return NULL;
- guidcpy(&mm_hdr->header_guid, &mm_var_guid);
- mm_hdr->message_len = MM_VARIABLE_COMMUNICATE_SIZE + payload_size;
- var_hdr->function = func;
- if (dptr)
- *ret = EFI_SUCCESS;
- return comm_buf;
- get_max_payload() - Get variable payload size from StandAloneMM.
- @size: size of the variable in storage
- struct smm_variable_payload_size *var_payload = NULL;
- efi_uintn_t payload_size;
- efi_status_t ret;
- u8 *comm_buf;
- if (!size)
- payload_size = sizeof(*var_payload);
- comm_buf = setup_mm_hdr((void **)&var_payload, payload_size,
- if (!comm_buf)
- ret = mm_communicate(comm_buf, payload_size);
goto out;
- *size = var_payload->size;
+out:
- free(comm_buf);
- return ret;
- efi_get_variable() - retrieve value of a UEFI variable
- This function implements the GetVariable runtime service.
- See the Unified Extensible Firmware Interface (UEFI) specification for
- details.
- @name: name of the variable
- @guid: vendor GUID
- @attr: attributes of the variable
- @data_size: size of the buffer to which the variable value is copied
- @data: buffer to which the variable value is copied
void *data)
- struct smm_variable_access *var_acc;
- efi_uintn_t tmp_dsize;
- efi_status_t ret;
- u8 *comm_buf;
- EFI_ENTRY(""%ls" %pUl %p %p %p", name, guid, attr, data_size, data);
- if (!name || !guid || !data_size)
- /* Check payload size */
- name_size = u16_strsize(name);
- if (name_size > max_payload_size - MM_VARIABLE_ACCESS_HEADER_SIZE)
- /* Trim output buffer size */
- tmp_dsize = *data_size;
- if (name_size + tmp_dsize >
name_size;
- /* Get communication buffer and initialize header */
- payload_size = MM_VARIABLE_ACCESS_HEADER_SIZE + name_size + tmp_dsize;
- comm_buf = setup_mm_hdr((void **)&var_acc, payload_size,
- if (!comm_buf)
- /* Fill in contents */
- guidcpy(&var_acc->guid, guid);
- var_acc->data_size = tmp_dsize;
- var_acc->name_size = name_size;
- var_acc->attr = attr ? *attr : 0;
- memcpy(var_acc->name, name, name_size);
- /* Communicate */
- if (ret == EFI_SUCCESS || ret == EFI_BUFFER_TOO_SMALL) {
goto done;
- if (attr)
- if (data)
- else
+done:
- free(comm_buf);
- return EFI_EXIT(ret);
- efi_get_next_variable_name() - enumerate the current variable names
- @variable_name_size: size of variable_name buffer in byte
- @variable_name: name of uefi variable's name in u16
- @guid: vendor's guid
- This function implements the GetNextVariableName service.
- details.
u16 *variable_name,
efi_guid_t *guid)
- struct smm_variable_getnext *var_getnext;
- efi_status_t ret;
- efi_uintn_t out_name_size;
- efi_uintn_t in_name_size;
- u8 *comm_buf;
- EFI_ENTRY("%p "%ls" %pUl", variable_name_size, variable_name, guid);
- if (!variable_name_size || !variable_name || !guid)
- out_name_size = *variable_name_size;
- in_name_size = u16_strsize(variable_name);
The UEFI spec requires that EFI_INVALID_PARAMETER should be returned if there is no '\0' character in the first *variable_name_size words of variable_name. I think we should add this test here instead of using max(out_name_size, in_name_size) later in the code.
You are currently calling EFI_EXIT() in many places. Depending on the level of code optimizations done by the compiler and the debug settings this may need to unnecessary code size. I suggest to use a single exit point in each of the functions, e.g.
if (out_name_size > in_name_size) { ret = EFI_INVALID_PARAMETER; goto out; } ... out: EFI_EXIT(ret); }
Best regards
Heinrich
- name_size = u16_strsize(variable_name);
- if (name_size > max_payload_size - MM_VARIABLE_GET_NEXT_HEADER_SIZE)
- tmp_dsize = *variable_name_size;
name_size;
- payload_size = MM_VARIABLE_GET_NEXT_HEADER_SIZE +
- comm_buf = setup_mm_hdr((void **)&var_getnext, payload_size,
&ret);
- if (!comm_buf)
- guidcpy(&var_getnext->guid, guid);
- var_getnext->name_size = out_name_size;
- memcpy(var_getnext->name, variable_name, in_name_size);
- if (out_name_size > in_name_size) {
- /* Communicate */
goto done;
- guidcpy(guid, &var_getnext->guid);
- memcpy(variable_name, (u8 *)var_getnext->name,
+done:
- free(comm_buf);
- efi_set_variable() - set value of a UEFI variable
- This function implements the SetVariable runtime service.
- details.
- @data_size: size of the buffer with the variable value
- @data: buffer with the variable value
const void *data)
- efi_status_t ret;
- u8 *comm_buf;
- EFI_ENTRY(""%ls" %pUl %x %zu %p", name, guid, attr, data_size, data);
- if (!name || name[0] == 0 || !guid)
- if (data_size > 0 && !data)
- payload_size = MM_VARIABLE_ACCESS_HEADER_SIZE + name_size + data_size;
- if (payload_size > max_payload_size)
- if (!comm_buf)
- var_acc->data_size = data_size;
- var_acc->attr = attr;
- memcpy((u8 *)var_acc->name + name_size, data, data_size);
- /* Communicate */
- free(comm_buf);
- efi_query_variable_info() - get information about EFI variables
- This function implements the QueryVariableInfo() runtime service.
- details.
- @attributes: bitmask to select variables to be
queried
- @maximum_variable_storage_size: maximum size of storage area for the
- @remaining_variable_storage_size: remaining size of storage are for the
- @maximum_variable_size: maximum size of a variable of the
selected type
- Returns: status code
- struct smm_variable_query_info *mm_query_info;
- efi_status_t ret;
- u8 *comm_buf;
- EFI_ENTRY("%x %p %p %p", attributes, max_variable_storage_size,
- payload_size = sizeof(*mm_query_info);
- comm_buf = setup_mm_hdr((void **)&mm_query_info, payload_size,
&ret);
- if (!comm_buf)
- mm_query_info->attr = attributes;
goto out;
- *max_variable_storage_size = mm_query_info->max_variable_storage;
- *remain_variable_storage_size =
- *max_variable_size = mm_query_info->max_variable_size;
+out:
- free(comm_buf);
- efi_get_variable_runtime() - runtime implementation of GetVariable()
- @variable_name: name of the variable
- @attributes: attributes of the variable
- return EFI_UNSUPPORTED;
- efi_get_next_variable_name_runtime() - runtime implementation of
GetNextVariable()
- details.
queried
selected type
- efi_set_variable_runtime() - runtime implementation of SetVariable()
const void *data)
- efi_variables_boot_exit_notify() - notify ExitBootServices() is called
- u8 *comm_buf;
- efi_status_t ret;
- comm_buf = setup_mm_hdr(NULL, 0,
- if (comm_buf)
- else
- free(comm_buf);
- /* Update runtime service table */
- efi_runtime_services.query_variable_info =
- efi_runtime_services.get_variable = efi_get_variable_runtime;
- efi_runtime_services.get_next_variable_name =
- efi_runtime_services.set_variable = efi_set_variable_runtime;
- efi_update_table_header_crc32(&efi_runtime_services.hdr);
- efi_init_variables() - initialize variable services
- efi_status_t ret;
- ret = get_max_payload(&max_payload_size);
return ret;
- max_buffer_size = MM_COMMUNICATE_HEADER_SIZE +
max_payload_size;
- return EFI_SUCCESS;
Ok I'll have a look
Fair enough, most of U-Boot is coded that way anyway, might as well have a common approach.
I'll post a v3 with the changes, so you can do your testing directly in that
Regards /Ilias
- default n
- help
endif
Dear Ilias,
at least CONFIG_TEE=y is needed as dependency. Otherwise compiling fails.
If OP-TEE is not found:
=> bootefi hello Unable to open OP-TEE session (err=-19) mm_communicate failed! Error: Cannot initialize UEFI sub-system, r = 3
I think it could be allowable to boot without variable support unless we are in secure boot audit mode. So if CONFIG_EFI_SECURE_BOOT=n, maybe we should be less strict. I guess it will end up in weighing user friendliness against complexity. What are your ideas?
Best regards
Heinrich
- default n
- help
endif
Dear Ilias,
Ok I'll add that
I don't have any strong opinions on that tbh. But I think i'd choose the stricter approach. If it's a UEFI boot/whatever, variables must be initialized and accessible.
Regards /Ilias
Best regards
Heinrich
With the previous patches that use OP-TEE and StandAloneMM for UEFI variable storage we've added functionality for efi_query_variable_info. So let's add the relevant command to efidebug and retrieve information about the container used to store UEFI variables
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- cmd/efidebug.c | 44 +++++++++++++++++++++++++++++++++++++++++++- 1 file changed, 43 insertions(+), 1 deletion(-)
diff --git a/cmd/efidebug.c b/cmd/efidebug.c index d8a76d78a388..a3980772c934 100644 --- a/cmd/efidebug.c +++ b/cmd/efidebug.c @@ -1160,6 +1160,44 @@ static int do_efi_test(cmd_tbl_t *cmdtp, int flag, return cp->cmd(cmdtp, flag, argc, argv); }
+/** + * do_efi_query_info() - QueryVariableInfo EFI service + * + * @cmdtp: Command table + * @flag: Command flag + * @argc: Number of arguments + * @argv: Argument array + * Return: CMD_RET_SUCCESS on success, + * CMD_RET_USAGE or CMD_RET_FAILURE on failure + * + * Implement efidebug "test" sub-command. + */ + +static int do_efi_query_info(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + efi_status_t ret; + u32 attr = EFI_VARIABLE_BOOTSERVICE_ACCESS | + EFI_VARIABLE_RUNTIME_ACCESS | + EFI_VARIABLE_NON_VOLATILE; + u64 max_variable_storage_size; + u64 remain_variable_storage_size; + u64 max_variable_size; + + ret = EFI_CALL(efi_query_variable_info(attr, + &max_variable_storage_size, + &remain_variable_storage_size, + &max_variable_size)); + if (ret != EFI_SUCCESS) + return CMD_RET_FAILURE; + + printf("Max storage size %llu\n", max_variable_storage_size); + printf("Remaining storage size %llu\n", remain_variable_storage_size); + printf("Max variable size %llu\n", max_variable_size); + + return CMD_RET_SUCCESS; +} + static cmd_tbl_t cmd_efidebug_sub[] = { U_BOOT_CMD_MKENT(boot, CONFIG_SYS_MAXARGS, 1, do_efi_boot_opt, "", ""), U_BOOT_CMD_MKENT(devices, CONFIG_SYS_MAXARGS, 1, do_efi_show_devices, @@ -1176,6 +1214,8 @@ static cmd_tbl_t cmd_efidebug_sub[] = { "", ""), U_BOOT_CMD_MKENT(test, CONFIG_SYS_MAXARGS, 1, do_efi_test, "", ""), + U_BOOT_CMD_MKENT(query, CONFIG_SYS_MAXARGS, 1, do_efi_query_info, + "", ""), };
/** @@ -1247,7 +1287,9 @@ static char efidebug_help_text[] = "efidebug tables\n" " - show UEFI configuration tables\n" "efidebug test bootmgr\n" - " - run simple bootmgr for test\n"; + " - run simple bootmgr for test\n" + "efidebug query\n" + " - show size of UEFI variables store\n"; #endif
U_BOOT_CMD(
For now attributes (e.g. EFI_VARIABLE_NON_VOLATILE) cannot be passed to the 'efidebug query' sub-command instead a fixed value is used. We can add attributes on the command line later.
- do_efi_query_info() - QueryVariableInfo EFI service
- @cmdtp: Command table
- @flag: Command flag
- @argc: Number of arguments
- @argv: Argument array
- Return: CMD_RET_SUCCESS on success,
- Implement efidebug "test" sub-command.
- efi_status_t ret;
- u32 attr = EFI_VARIABLE_BOOTSERVICE_ACCESS |
As we do not support variables at runtime currently shouldn't we remove EFI_VARIABLE_RUNTIME_ACCESS from the default value? I could do that when merging.
Otherwise:
- u64 max_variable_storage_size;
- u64 remain_variable_storage_size;
- ret = EFI_CALL(efi_query_variable_info(attr,
- printf("Max storage size %llu\n", max_variable_storage_size);
- printf("Remaining storage size %llu\n", remain_variable_storage_size);
- printf("Max variable size %llu\n", max_variable_size);
- return CMD_RET_SUCCESS;
- U_BOOT_CMD_MKENT(query, CONFIG_SYS_MAXARGS, 1, do_efi_query_info,
- "efidebug query\n"
- " - show size of UEFI variables store\n";
#endif
U_BOOT_CMD(
Good point, I'll add it on the commit message for v3
- efi_status_t ret;
We can still add variables marked as runtime in U-Boot's cmd line although we don't support those in Linux. So I'd keep that flag on the defaults.
Otherwise:
Regards /Ilias
Add myself as maintainer for the OP-TEE related UEFI variable storage and add the headers file on the existing EFI list
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- MAINTAINERS | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/MAINTAINERS b/MAINTAINERS index ec59ce8b8802..0c38890be09c 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -635,6 +635,12 @@ F: cmd/efidebug.c F: cmd/nvedit_efi.c F: tools/file2include.c
+EFI VARIABLES VIA OP-TEE +M: Ilias Apalodimas ilias.apalodimas@linaro.org +S: Maintained +F: lib/efi_loader/efi_variable_tee.c +F: include/mm_communication.h + ENVIRONMENT M: Joe Hershberger joe.hershberger@ni.com R: Wolfgang Denk wd@denx.de
If OP-TEE is compiled with an EDK2 application running in secure world it can process and store UEFI variables in an RPMB. Add documentation for the config options enabling this
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- doc/uefi/uefi.rst | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/doc/uefi/uefi.rst b/doc/uefi/uefi.rst index 4fda00d68721..03d6fd0c6aa8 100644 --- a/doc/uefi/uefi.rst +++ b/doc/uefi/uefi.rst @@ -188,6 +188,23 @@ on the sandbox cd <U-Boot source directory> pytest.py test/py/tests/test_efi_secboot/test_signed.py --bd sandbox
+Using OP-TEE for EFI variables +~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ + +Instead of implementing UEFI variable services inside U-Boot they can +also be provided in the secure world by a module for OP-TEE[1]. The +interface between U-Boot and OP-TEE for variable services is enabled by +CONFIG_EFI_MM_COMM_TEE=y. + +Tianocore EDK II's standalone management mode driver for variables can +be linked to OP-TEE for this purpose. This module uses the Replay +Protected Memory Block (RPMB) of an eMMC device for persisting +non-volatile variables. When calling the variable services via the +OP-TEE API U-Boot's OP-TEE supplicant relays calls to the RPMB driver +which has to be enabled via CONFIG_SUPPORT_EMMC_RPMB=y. + +[1] https://optee.readthedocs.io/ - OP-TEE documentation + Executing the boot manager ~~~~~~~~~~~~~~~~~~~~~~~~~~
Ilias Apalodimas
