ARM A53 and initial MMU mapping for EL0/1/2/3 ?
Trying to figure out how I should map the MMU for normal RAM so it acessible from all ELx security states. So far I have this mem_map:
/* memory mapped RAM. 32MB */ .virt = 0x60000000UL, .phys = 0x60000000UL, .size = 0x02000000UL, .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | PTE_BLOCK_INNER_SHARE
but starting to doubt that is correct, can someone suggest what to put in the .attrs field?
Jocke
On Tue, 8 Feb 2022 22:05:00 +0000 Joakim Tjernlund Joakim.Tjernlund@infinera.com wrote:
Hi Joakim,
This does not make much sense. U-Boot is typically running in one exception level only, and sets up the page table for exactly that EL. Each EL uses a separate translation regime (with some twists for stage 2 EL2 and combined EL1/0, plus VHE). If you map your memory in EL3, then drop to EL2, the EL3 page tables become irrelevant.
So in U-Boot we just set up the page tables for the EL we are running in, and leave the paging for the lower exception levels to be set up at the discretion of our payloads (kernels, hypervisors).
Please not that *secure* memory is a separate concept, and handled by external hardware, typically using regions, not page tables.
Those are the correct attributes for normal ("cache-able") memory. However you probably need at least another mapping for MMIO accesses, which MUST NOT be cacheable (MT_DEVICE_NGNRNE), but device memory. See the beginning of arch/arm/mach-sunxi/board.c for an example.
Cheers, Andre
Hi Joakim,
I am a beginner w.r.t ARM and Secure/Non secure so thank you for above.
The problem I have is that I boot a custom SOC into u-boot and when u-boot tries to boot linux I get an error exception when u-boot calls armv8_switch_to_el2 to enter linux. I think the exception means "Instruction Abort taken without a change in Exception level." I was thinking it could be some privilege missing in MMU map. Note that kernel boots from a different memory region than u-boot but those two regions are mapped the same way.
Jocke
PS. I can cheat/hack u-boot to branch to the linux kernel address and that works until kernel tries to switch EL.
Cheers, Andre
On Wed, 9 Feb 2022 08:35:04 +0000 Joakim Tjernlund Joakim.Tjernlund@infinera.com wrote:
Hi Joakim,
So that means that U-Boot runs in EL3, is that the first and only firmware that you run? I think the EL3 part of U-Boot is not widely used and tested beyond the very few platforms that use it.
Do you have the exact address that fails? That should be in ELR, it would be great if you can pinpoint the exact instruction in macro.h that fails.
Could be. One thing that made me wonder is your rather miserly mapping of only 32MB, which sounds a bit on the small side. Typically we just map the whole first DRAM bank, regardless of whether you actually have memory there or not. U-Boot should know how much DRAM you have, so will not go beyond that. Having page tables covering more address space does not really hurt, but avoids all kind of problems. And please note that U-Boot loves to move things around: itself from the load address to the end of DRAM (that it knows of); possibly the kernel, when the alignment is not right, or the DT and initrd if it sees fit. So there is little point in mapping just portions of the memory.
Cheers, Andre
Jocke
Cheers, Andre
Hi Joakim,
Yes, u-boot is first firmware and runs in EL3(ATM, may change once initial bringup is complete) Maybe u-boot then lacks some critical init? Do you have an example of a board in u-boot that starts in EL3(from reset) using an A53 cpu?
Yes, the address is the first address where kernel is loaded and you can branch there without problems. It is the eret instruction(last insn in macro armv8_switch_to_el2_m) that fails.
We only have 32 MB ATM :( a bit small but it may increase to 64MB
U-boot moves around a lot, I know :) In this case u-boot lives in is own 4MB SRAM but kernel lives in a 32MB HyperRAM.
Cheers, Andre
Jocke
Cheers, Andre
On Wed, 9 Feb 2022 12:03:47 +0000 Joakim Tjernlund Joakim.Tjernlund@infinera.com wrote:
Hi Joakim,
As you have probably figured out by now, the whole Layerscape family uses that approach. However most other platforms go with Trusted-Firmware as the EL3 setup and secure runtime service provider, so the U-Boot EL3 code in here is not well tested or looked after. For initial bringup it might be OK, but maybe the problems you run into are due to issues in this code.
You mean if you load the kernel and branch to the entry point, it starts running, but crashes as soon as it realises that in runs in EL3?
Interesting. Maybe there is something missing in the EL2 setup, but my understanding is that this is the part that is actually used by Layerscape, for instance.
That sounds very miserly. Can you actually run an arm64 Linux kernel with that little RAM? IIRC for QEMU we need at least 128 MB, and I haven't seen an ARMv8 hardware platform with less than 512MB (maybe 256MB) DRAM yet.
Interesting. I wonder if this works well with U-Boot's memory management, which assumes it has quite some DRAM to play with.
Cheers, Andre
Jocke
Cheers, Andre
Hi Joakim,
Found it, all memory spaces were set to secure mode, the req. spec does not agree :(
Anyhow, now kernel enters into EL2 then EL1 to EL0, all is well until kernel tries to do simple cache ops like dc ivac, x0 or mrs x3,ctr_el0 when I again just get an error exception: EXC [0x400] Synchronous Lower EL using AArch64 so there is something missing here but I cannot figure out what. u-boot really don't know about the 32 MB RAM kernel is using, it booted just its own 4MB and I guessing u-boot then missed to configure something for the 32 MB RAM but what ?
Jocke
On Thu, 10 Feb 2022 21:58:30 +0000 Joakim Tjernlund Joakim.Tjernlund@infinera.com wrote:
Hi Joakim,
> Trying to figure out how I should map the MMU for normal RAM so it acessible > from all ELx security states.
Ah, yes, if the DRAM is configured as secure only, running in EL2 (always non-secure on the A53) will not end well.
Was this with Linux, or some other kernel? IIRC cache maintenance instructions in EL0 need to be enabled in SCTLR_EL1 (.UCI and .DZE, for instance, plus maybe more registers), and those and other operations should not be trapped to EL2 as well.
But you did map this RAM, and probably loaded the kernel in there? So U-Boot would need to touch this memory. Maybe it left something behind? PSCI handlers? UEFI runtime services?
I really don't understand enough of your setup to be of help here.
Cheers, Andre
On Wed, 2022-02-09 at 00:33 +0000, Andre Przywara wrote: > On Tue, 8 Feb 2022 22:05:00 +0000 > Joakim Tjernlund Joakim.Tjernlund@infinera.com wrote: > > Hi Joakim, > > > Trying to figure out how I should map the MMU for normal RAM so it acessible > > from all ELx security states. > > ^^^^^^^ > > This does not make much sense. U-Boot is typically running in one > exception level only, and sets up the page table for exactly that EL. > Each EL uses a separate translation regime (with some twists for stage > 2 EL2 and combined EL1/0, plus VHE). If you map your memory in EL3, then > drop to EL2, the EL3 page tables become irrelevant. > > So in U-Boot we just set up the page tables for the EL we are running > in, and leave the paging for the lower exception levels to be set up at > the discretion of our payloads (kernels, hypervisors). > > Please not that *secure* memory is a separate concept, and handled by > external hardware, typically using regions, not page tables.
Yes, 5.14.x
SCTLR_EL1 is 0x30500800 and does not seem to match with above. looks like it is kernel that sets this reg? how can kernel get that wrong ?
u-boot has this mapped and can branch to it. Kernel is an ITS img loaded so kernel exec XIP. No PSCI or UEFI configured.
Cheers, Andre
On Fri, 11 Feb 2022 00:22:25 +0000 Joakim Tjernlund Joakim.Tjernlund@infinera.com wrote:
> On Wed, 2022-02-09 at 00:33 +0000, Andre Przywara wrote: > > On Tue, 8 Feb 2022 22:05:00 +0000 > > Joakim Tjernlund Joakim.Tjernlund@infinera.com wrote: > > > > Hi Joakim, > > > > > Trying to figure out how I should map the MMU for normal RAM so it acessible > > > from all ELx security states. > > > > ^^^^^^^ > > > > This does not make much sense. U-Boot is typically running in one > > exception level only, and sets up the page table for exactly that EL. > > Each EL uses a separate translation regime (with some twists for stage > > 2 EL2 and combined EL1/0, plus VHE). If you map your memory in EL3, then > > drop to EL2, the EL3 page tables become irrelevant. > > > > So in U-Boot we just set up the page tables for the EL we are running > > in, and leave the paging for the lower exception levels to be set up at > > the discretion of our payloads (kernels, hypervisors). > > > > Please not that *secure* memory is a separate concept, and handled by > > external hardware, typically using regions, not page tables. > > I am a beginner w.r.t ARM and Secure/Non secure so thank you for above. > > The problem I have is that I boot a custom SOC into u-boot and when u-boot tries > to boot linux I get an error exception when u-boot calls armv8_switch_to_el2 to enter linux.
> I think the exception means "Instruction Abort taken without a change in Exception level." > I was thinking it could be some privilege missing in MMU map.
Yes, 5.14.x
Ah, I see. And that really runs with 32MB? I think we need at least 64MB. Maybe the issues you see are related to that? IIRC the effects can look rather random.
That can't be really the kernel value, because the MMU needs to be on (bit 0). Is this the reset value, read in U-Boot? The kernel sets those bits, check the definition of INIT_SCTLR_EL1_MMU_ON in the kernel source. Maybe (the generic EL3) U-Boot code misses to set some EL3 registers, so some stuff is blocked already there, and the kernel is helpless?
It's not really XIP per se, since it's in DRAM. arm64 Linux doesn't support real XIP (from ROM) anyway. And U-Boot would still move it around if it's not properly aligned. TEXT_OFFSET in the arm64 5.14 kernel header is probably 0, so you would need to load it at an 2MB aligned address (so either right at the start or 2MB into DRAM) to avoid copying. The old 512K offset is not anymore with modern kernels.
I guessed so ...
Cheers, Andre
Cheers, Andre
On Wed, 2022-02-09 at 10:45 +0000, Andre Przywara wrote: > On Wed, 9 Feb 2022 08:35:04 +0000 > Joakim Tjernlund Joakim.Tjernlund@infinera.com wrote: > > Hi, > > > On Wed, 2022-02-09 at 00:33 +0000, Andre Przywara wrote: > > > On Tue, 8 Feb 2022 22:05:00 +0000 > > > Joakim Tjernlund Joakim.Tjernlund@infinera.com wrote: > > > > > > Hi Joakim, > > > > > > > Trying to figure out how I should map the MMU for normal RAM so it acessible > > > > from all ELx security states. > > > > > > ^^^^^^^ > > > > > > This does not make much sense. U-Boot is typically running in one > > > exception level only, and sets up the page table for exactly that EL. > > > Each EL uses a separate translation regime (with some twists for stage > > > 2 EL2 and combined EL1/0, plus VHE). If you map your memory in EL3, then > > > drop to EL2, the EL3 page tables become irrelevant. > > > > > > So in U-Boot we just set up the page tables for the EL we are running > > > in, and leave the paging for the lower exception levels to be set up at > > > the discretion of our payloads (kernels, hypervisors). > > > > > > Please not that *secure* memory is a separate concept, and handled by > > > external hardware, typically using regions, not page tables. > > > > I am a beginner w.r.t ARM and Secure/Non secure so thank you for above. > > > > The problem I have is that I boot a custom SOC into u-boot and when u-boot tries > > to boot linux I get an error exception when u-boot calls armv8_switch_to_el2 to enter linux. > > So that means that U-Boot runs in EL3, is that the first and only firmware > that you run? I think the EL3 part of U-Boot is not widely used and tested > beyond the very few platforms that use it.
> Do you have the exact address that fails? That should be in ELR, it would > be great if you can pinpoint the exact instruction in macro.h that fails.
> > I think the exception means "Instruction Abort taken without a change in Exception level." > > I was thinking it could be some privilege missing in MMU map. > > Could be. One thing that made me wonder is your rather miserly mapping of > only 32MB, which sounds a bit on the small side. Typically we just map the
> whole first DRAM bank, regardless of whether you actually have memory > there or not. U-Boot should know how much DRAM you have, so will not go > beyond that. Having page tables covering more address space does not > really hurt, but avoids all kind of problems. > And please note that U-Boot loves to move things around: itself from the > load address to the end of DRAM (that it knows of); possibly the kernel, > when the alignment is not right, or the DT and initrd if it sees fit. > So there is little point in mapping just portions of the memory.
Yes, 5.14.x
This is before MMU is on, kernel has forced SCTLR_EL1 to ENDIAN_SET_EL1 | SCTLR_EL1_RES1 via INIT_SCTLR_EL1_MMU_OFF I hacked the define to: #define INIT_SCTLR_EL1_MMU_OFF \ - (ENDIAN_SET_EL1 | SCTLR_EL1_RES1) + (ENDIAN_SET_EL1 | SCTLR_EL1_RES1 | SCTLR_EL1_DZE | SCTLR_EL1_UCI)
but that didn't change anything. The only thing I can think of is some prep u-boot must do while in EL3 or maybe the A53 core has been oddly wired into the ASIC(own custom ASIC) and changed som default setting in HW ?
Jocke
> On Wed, 2022-02-09 at 10:45 +0000, Andre Przywara wrote: > > On Wed, 9 Feb 2022 08:35:04 +0000 > > Joakim Tjernlund Joakim.Tjernlund@infinera.com wrote: > > > > Hi, > > > > > On Wed, 2022-02-09 at 00:33 +0000, Andre Przywara wrote: > > > > On Tue, 8 Feb 2022 22:05:00 +0000 > > > > Joakim Tjernlund Joakim.Tjernlund@infinera.com wrote: > > > > > > > > Hi Joakim, > > > > > > > > > Trying to figure out how I should map the MMU for normal RAM so it acessible > > > > > from all ELx security states. > > > > > > > > ^^^^^^^ > > > > > > > > This does not make much sense. U-Boot is typically running in one > > > > exception level only, and sets up the page table for exactly that EL. > > > > Each EL uses a separate translation regime (with some twists for stage > > > > 2 EL2 and combined EL1/0, plus VHE). If you map your memory in EL3, then > > > > drop to EL2, the EL3 page tables become irrelevant. > > > > > > > > So in U-Boot we just set up the page tables for the EL we are running > > > > in, and leave the paging for the lower exception levels to be set up at > > > > the discretion of our payloads (kernels, hypervisors). > > > > > > > > Please not that *secure* memory is a separate concept, and handled by > > > > external hardware, typically using regions, not page tables. > > > > > > I am a beginner w.r.t ARM and Secure/Non secure so thank you for above. > > > > > > The problem I have is that I boot a custom SOC into u-boot and when u-boot tries > > > to boot linux I get an error exception when u-boot calls armv8_switch_to_el2 to enter linux. > > > > So that means that U-Boot runs in EL3, is that the first and only firmware > > that you run? I think the EL3 part of U-Boot is not widely used and tested > > beyond the very few platforms that use it. > > Yes, u-boot is first firmware and runs in EL3(ATM, may change once initial bringup is complete) > Maybe u-boot then lacks some critical init? Do you have an example of a board in u-boot > that starts in EL3(from reset) using an A53 cpu?
> > Do you have the exact address that fails? That should be in ELR, it would > > be great if you can pinpoint the exact instruction in macro.h that fails. > > Yes, the address is the first address where kernel is loaded and you can branch there without problems.
> > > I think the exception means "Instruction Abort taken without a change in Exception level." > > > I was thinking it could be some privilege missing in MMU map. > > > > Could be. One thing that made me wonder is your rather miserly mapping of > > only 32MB, which sounds a bit on the small side. Typically we just map the > > We only have 32 MB ATM :( a bit small but it may increase to 64MB
> > whole first DRAM bank, regardless of whether you actually have memory > > there or not. U-Boot should know how much DRAM you have, so will not go > > beyond that. Having page tables covering more address space does not > > really hurt, but avoids all kind of problems. > > And please note that U-Boot loves to move things around: itself from the > > load address to the end of DRAM (that it knows of); possibly the kernel, > > when the alignment is not right, or the DT and initrd if it sees fit. > > So there is little point in mapping just portions of the memory. > > U-boot moves around a lot, I know :) In this case u-boot lives > in is own 4MB SRAM but kernel lives in a 32MB HyperRAM.
Yes, 5.14.x
Found it! A kernel bug actually: diff --git a/arch/arm64/include/asm/el2_setup.h b/arch/arm64/include/asm/el2_setup.h index 3198acb2aad8..7f3c87f7a0ce 100644 --- a/arch/arm64/include/asm/el2_setup.h +++ b/arch/arm64/include/asm/el2_setup.h @@ -106,7 +106,7 @@ msr_s SYS_ICC_SRE_EL2, x0 isb // Make sure SRE is now set mrs_s x0, SYS_ICC_SRE_EL2 // Read SRE back, - tbz x0, #0, 1f // and check that it sticks + tbz x0, #0, .Lskip_gicv3_@ // and check that it sticks msr_s SYS_ICH_HCR_EL2, xzr // Reset ICC_HCR_EL2 to defaults .Lskip_gicv3_@: .endm
branching to 1f got you way off and into el0 when you were supposed be in el2/el1 still.
Not sure why GIC init fails there, we got a GIC-500v4 but I think it should pass this test still ? If so I guess we need to something with GIC in uboot before booting Linux? Any idea what I might be missing?
Jocke
On Fri, 11 Feb 2022 17:00:48 +0000 Joakim Tjernlund Joakim.Tjernlund@infinera.com wrote:
On Thu, 2022-02-10 at 10:22 +0000, Andre Przywara wrote: > On Wed, 9 Feb 2022 12:03:47 +0000 > Joakim Tjernlund Joakim.Tjernlund@infinera.com wrote: > > Hi, > > > On Wed, 2022-02-09 at 10:45 +0000, Andre Przywara wrote: > > > On Wed, 9 Feb 2022 08:35:04 +0000 > > > Joakim Tjernlund Joakim.Tjernlund@infinera.com wrote: > > > > > > Hi, > > > > > > > On Wed, 2022-02-09 at 00:33 +0000, Andre Przywara wrote: > > > > > On Tue, 8 Feb 2022 22:05:00 +0000 > > > > > Joakim Tjernlund Joakim.Tjernlund@infinera.com wrote: > > > > > > > > > > Hi Joakim, > > > > > > > > > > > Trying to figure out how I should map the MMU for normal RAM so it acessible > > > > > > from all ELx security states. > > > > > > > > > > ^^^^^^^ > > > > > > > > > > This does not make much sense. U-Boot is typically running in one > > > > > exception level only, and sets up the page table for exactly that EL. > > > > > Each EL uses a separate translation regime (with some twists for stage > > > > > 2 EL2 and combined EL1/0, plus VHE). If you map your memory in EL3, then > > > > > drop to EL2, the EL3 page tables become irrelevant. > > > > > > > > > > So in U-Boot we just set up the page tables for the EL we are running > > > > > in, and leave the paging for the lower exception levels to be set up at > > > > > the discretion of our payloads (kernels, hypervisors). > > > > > > > > > > Please not that *secure* memory is a separate concept, and handled by > > > > > external hardware, typically using regions, not page tables. > > > > > > > > I am a beginner w.r.t ARM and Secure/Non secure so thank you for above. > > > > > > > > The problem I have is that I boot a custom SOC into u-boot and when u-boot tries > > > > to boot linux I get an error exception when u-boot calls armv8_switch_to_el2 to enter linux. > > > > > > So that means that U-Boot runs in EL3, is that the first and only firmware > > > that you run? I think the EL3 part of U-Boot is not widely used and tested > > > beyond the very few platforms that use it. > > > > Yes, u-boot is first firmware and runs in EL3(ATM, may change once initial bringup is complete) > > Maybe u-boot then lacks some critical init? Do you have an example of a board in u-boot > > that starts in EL3(from reset) using an A53 cpu? > > As you have probably figured out by now, the whole Layerscape family uses > that approach. However most other platforms go with Trusted-Firmware as the > EL3 setup and secure runtime service provider, so the U-Boot EL3 code in > here is not well tested or looked after. For initial bringup it might be > OK, but maybe the problems you run into are due to issues in this code. > > > > Do you have the exact address that fails? That should be in ELR, it would > > > be great if you can pinpoint the exact instruction in macro.h that fails. > > > > Yes, the address is the first address where kernel is loaded and you can branch there without problems. > > You mean if you load the kernel and branch to the entry point, it starts > running, but crashes as soon as it realises that in runs in EL3? > > > It is the eret instruction(last insn in macro armv8_switch_to_el2_m) that fails. > > Interesting. Maybe there is something missing in the EL2 setup, but my > understanding is that this is the part that is actually used by > Layerscape, for instance. > > > > > I think the exception means "Instruction Abort taken without a change in Exception level." > > > > I was thinking it could be some privilege missing in MMU map. > > > > > > Could be. One thing that made me wonder is your rather miserly mapping of > > > only 32MB, which sounds a bit on the small side. Typically we just map the > > > > We only have 32 MB ATM :( a bit small but it may increase to 64MB > > That sounds very miserly. Can you actually run an arm64 Linux kernel with > that little RAM? IIRC for QEMU we need at least 128 MB, and I haven't seen > an ARMv8 hardware platform with less than 512MB (maybe 256MB) DRAM yet. > > > > whole first DRAM bank, regardless of whether you actually have memory > > > there or not. U-Boot should know how much DRAM you have, so will not go > > > beyond that. Having page tables covering more address space does not > > > really hurt, but avoids all kind of problems. > > > And please note that U-Boot loves to move things around: itself from the > > > load address to the end of DRAM (that it knows of); possibly the kernel, > > > when the alignment is not right, or the DT and initrd if it sees fit. > > > So there is little point in mapping just portions of the memory. > > > > U-boot moves around a lot, I know :) In this case u-boot lives > > in is own 4MB SRAM but kernel lives in a 32MB HyperRAM. > > Interesting. I wonder if this works well with U-Boot's memory management, > which assumes it has quite some DRAM to play with.
Yes, 5.14.x
tbz x0, #0, .Lskip_gicv3_\@ // and check that it sticks msr_s SYS_ICH_HCR_EL2, xzr // Reset ICC_HCR_EL2 to defaults
Well, as the list confirmed, that is indeed a bug, but the more important question is why. The bug wasn't noticed because this is some kind of error path only anyway, so any sane setup wouldn't trigger this.
So do you actually enable the EL3 GICv3 setup in your U-Boot build? That would be CONFIG_GICV3, and you need to define the GICD base address, I believe. But as Marc hinted already, this code is not well tested. Not sure it covers the WAKER setup that the GIC500 requires.
There is a list of requirements that Linux expects to be fulfilled by the firmware, check the section "system registers" under https://www.kernel.org/doc/html/v5.15/arm64/booting.html#call-the-kernel-ima...
In general the GIC resets to be accessible from secure state only, and needs to be setup to be usable from non-secure lower ELs. This affects some GICD registers and some GICv3 system registers. U-Boot *should* do the basics, but either it's not enabled, or it's missing something.
Cheers, Andre
> On Thu, 2022-02-10 at 10:22 +0000, Andre Przywara wrote: > > On Wed, 9 Feb 2022 12:03:47 +0000 > > Joakim Tjernlund Joakim.Tjernlund@infinera.com wrote: > > > > Hi, > > > > > On Wed, 2022-02-09 at 10:45 +0000, Andre Przywara wrote: > > > > On Wed, 9 Feb 2022 08:35:04 +0000 > > > > Joakim Tjernlund Joakim.Tjernlund@infinera.com wrote: > > > > > > > > Hi, > > > > > > > > > On Wed, 2022-02-09 at 00:33 +0000, Andre Przywara wrote: > > > > > > On Tue, 8 Feb 2022 22:05:00 +0000 > > > > > > Joakim Tjernlund Joakim.Tjernlund@infinera.com wrote: > > > > > > > > > > > > Hi Joakim, > > > > > > > > > > > > > Trying to figure out how I should map the MMU for normal RAM so it acessible > > > > > > > from all ELx security states. > > > > > > > > > > > > ^^^^^^^ > > > > > > > > > > > > This does not make much sense. U-Boot is typically running in one > > > > > > exception level only, and sets up the page table for exactly that EL. > > > > > > Each EL uses a separate translation regime (with some twists for stage > > > > > > 2 EL2 and combined EL1/0, plus VHE). If you map your memory in EL3, then > > > > > > drop to EL2, the EL3 page tables become irrelevant. > > > > > > > > > > > > So in U-Boot we just set up the page tables for the EL we are running > > > > > > in, and leave the paging for the lower exception levels to be set up at > > > > > > the discretion of our payloads (kernels, hypervisors). > > > > > > > > > > > > Please not that *secure* memory is a separate concept, and handled by > > > > > > external hardware, typically using regions, not page tables. > > > > > > > > > > I am a beginner w.r.t ARM and Secure/Non secure so thank you for above. > > > > > > > > > > The problem I have is that I boot a custom SOC into u-boot and when u-boot tries > > > > > to boot linux I get an error exception when u-boot calls armv8_switch_to_el2 to enter linux. > > > > > > > > So that means that U-Boot runs in EL3, is that the first and only firmware > > > > that you run? I think the EL3 part of U-Boot is not widely used and tested > > > > beyond the very few platforms that use it. > > > > > > Yes, u-boot is first firmware and runs in EL3(ATM, may change once initial bringup is complete) > > > Maybe u-boot then lacks some critical init? Do you have an example of a board in u-boot > > > that starts in EL3(from reset) using an A53 cpu? > > > > As you have probably figured out by now, the whole Layerscape family uses > > that approach. However most other platforms go with Trusted-Firmware as the > > EL3 setup and secure runtime service provider, so the U-Boot EL3 code in > > here is not well tested or looked after. For initial bringup it might be > > OK, but maybe the problems you run into are due to issues in this code. > > > > > > Do you have the exact address that fails? That should be in ELR, it would > > > > be great if you can pinpoint the exact instruction in macro.h that fails. > > > > > > Yes, the address is the first address where kernel is loaded and you can branch there without problems. > > > > You mean if you load the kernel and branch to the entry point, it starts > > running, but crashes as soon as it realises that in runs in EL3? > > > > > It is the eret instruction(last insn in macro armv8_switch_to_el2_m) that fails. > > > > Interesting. Maybe there is something missing in the EL2 setup, but my > > understanding is that this is the part that is actually used by > > Layerscape, for instance. > > > > > > > I think the exception means "Instruction Abort taken without a change in Exception level." > > > > > I was thinking it could be some privilege missing in MMU map. > > > > > > > > Could be. One thing that made me wonder is your rather miserly mapping of > > > > only 32MB, which sounds a bit on the small side. Typically we just map the > > > > > > We only have 32 MB ATM :( a bit small but it may increase to 64MB > > > > That sounds very miserly. Can you actually run an arm64 Linux kernel with > > that little RAM? IIRC for QEMU we need at least 128 MB, and I haven't seen > > an ARMv8 hardware platform with less than 512MB (maybe 256MB) DRAM yet. > > > > > > whole first DRAM bank, regardless of whether you actually have memory > > > > there or not. U-Boot should know how much DRAM you have, so will not go > > > > beyond that. Having page tables covering more address space does not > > > > really hurt, but avoids all kind of problems. > > > > And please note that U-Boot loves to move things around: itself from the > > > > load address to the end of DRAM (that it knows of); possibly the kernel, > > > > when the alignment is not right, or the DT and initrd if it sees fit. > > > > So there is little point in mapping just portions of the memory. > > > > > > U-boot moves around a lot, I know :) In this case u-boot lives > > > in is own 4MB SRAM but kernel lives in a 32MB HyperRAM. > > > > Interesting. I wonder if this works well with U-Boot's memory management, > > which assumes it has quite some DRAM to play with. > > Found it, all memory spaces were set to secure mode, the req. spec does not agree :(
> Anyhow, now kernel enters into EL2 then EL1 to EL0, all is well until kernel tries > to do simple cache ops like dc ivac, x0 or mrs x3,ctr_el0 when I again just get an error exception: > EXC [0x400] Synchronous Lower EL using AArch64
Yes, 5.14.x
Right, my setup was not sane ...
I had not setup GICv3, I found some define for that, was not possible to select this from Kconfig in u-boot. Only had to define GICD and GICR and u-boot did the rest.
It boots OK now(gets to mounting rootfs which remains to do) The one thing I havn't figured out w.r.t GIC DTS config is Rediststributor SPI/PPI init. We have 4 cores but only one runs linux and linux boots first. Should the other cores setup their own Rediststributor space or should the kernel do it for them(can it ?)?
There is a list of requirements that Linux expects to be fulfilled by the firmware, check the section "system registers" under https://nam11.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.kernel...
Nice! I must check that to see if I have missed something
U-boot does the required setup in EL3 before booting kernel into EL2 I think.
Cheers, Andre
Hi again
Got something I cannot figure out and was hoping to pick your brain: timeofday does not count. I can now boot fine into user space but then I tested the date command and my time stands still on 1970. I can set date but the time still does not count. Normal sleep 1 works though. Using 32 bit user space with musl libc.
Since I boot/reset directly into u-boot I guess I have forgotten to configure something. Any ideas?
Jocke
Yes, 5.14.x
Cheers, Andre
On Wed, 16 Mar 2022 20:28:31 +0000 Joakim Tjernlund Joakim.Tjernlund@infinera.com wrote:
So depending on your platform the arch time clock base might need to be enabled explicitly (some clock gate or extra register)? It should be fairly easy to just read the virt counter and see it progressing (mrs x0, CNTVCT_EL0).
Another thing to check for is whether CNTFRQ_EL0 has been setup by U-Boot: define COUNTER_FREQUENCY to the frequency of the arch timer clock, see arch/arm/cpu/armv8/start.S.
Cheers, Andre
Jocke
On Thu, 2022-02-10 at 22:43 +0000, Andre Przywara wrote: > On Thu, 10 Feb 2022 21:58:30 +0000 > Joakim Tjernlund Joakim.Tjernlund@infinera.com wrote: > > Hi, > > > On Thu, 2022-02-10 at 10:22 +0000, Andre Przywara wrote: > > > On Wed, 9 Feb 2022 12:03:47 +0000 > > > Joakim Tjernlund Joakim.Tjernlund@infinera.com wrote: > > > > > > Hi, > > > > > > > On Wed, 2022-02-09 at 10:45 +0000, Andre Przywara wrote: > > > > > On Wed, 9 Feb 2022 08:35:04 +0000 > > > > > Joakim Tjernlund Joakim.Tjernlund@infinera.com wrote: > > > > > > > > > > Hi, > > > > > > > > > > > On Wed, 2022-02-09 at 00:33 +0000, Andre Przywara wrote: > > > > > > > On Tue, 8 Feb 2022 22:05:00 +0000 > > > > > > > Joakim Tjernlund Joakim.Tjernlund@infinera.com wrote: > > > > > > > > > > > > > > Hi Joakim, > > > > > > > > > > > > > > > Trying to figure out how I should map the MMU for normal RAM so it acessible > > > > > > > > from all ELx security states. > > > > > > > > > > > > > > ^^^^^^^ > > > > > > > > > > > > > > This does not make much sense. U-Boot is typically running in one > > > > > > > exception level only, and sets up the page table for exactly that EL. > > > > > > > Each EL uses a separate translation regime (with some twists for stage > > > > > > > 2 EL2 and combined EL1/0, plus VHE). If you map your memory in EL3, then > > > > > > > drop to EL2, the EL3 page tables become irrelevant. > > > > > > > > > > > > > > So in U-Boot we just set up the page tables for the EL we are running > > > > > > > in, and leave the paging for the lower exception levels to be set up at > > > > > > > the discretion of our payloads (kernels, hypervisors). > > > > > > > > > > > > > > Please not that *secure* memory is a separate concept, and handled by > > > > > > > external hardware, typically using regions, not page tables. > > > > > > > > > > > > I am a beginner w.r.t ARM and Secure/Non secure so thank you for above. > > > > > > > > > > > > The problem I have is that I boot a custom SOC into u-boot and when u-boot tries > > > > > > to boot linux I get an error exception when u-boot calls armv8_switch_to_el2 to enter linux. > > > > > > > > > > So that means that U-Boot runs in EL3, is that the first and only firmware > > > > > that you run? I think the EL3 part of U-Boot is not widely used and tested > > > > > beyond the very few platforms that use it. > > > > > > > > Yes, u-boot is first firmware and runs in EL3(ATM, may change once initial bringup is complete) > > > > Maybe u-boot then lacks some critical init? Do you have an example of a board in u-boot > > > > that starts in EL3(from reset) using an A53 cpu? > > > > > > As you have probably figured out by now, the whole Layerscape family uses > > > that approach. However most other platforms go with Trusted-Firmware as the > > > EL3 setup and secure runtime service provider, so the U-Boot EL3 code in > > > here is not well tested or looked after. For initial bringup it might be > > > OK, but maybe the problems you run into are due to issues in this code. > > > > > > > > Do you have the exact address that fails? That should be in ELR, it would > > > > > be great if you can pinpoint the exact instruction in macro.h that fails. > > > > > > > > Yes, the address is the first address where kernel is loaded and you can branch there without problems. > > > > > > You mean if you load the kernel and branch to the entry point, it starts > > > running, but crashes as soon as it realises that in runs in EL3? > > > > > > > It is the eret instruction(last insn in macro armv8_switch_to_el2_m) that fails. > > > > > > Interesting. Maybe there is something missing in the EL2 setup, but my > > > understanding is that this is the part that is actually used by > > > Layerscape, for instance. > > > > > > > > > I think the exception means "Instruction Abort taken without a change in Exception level." > > > > > > I was thinking it could be some privilege missing in MMU map. > > > > > > > > > > Could be. One thing that made me wonder is your rather miserly mapping of > > > > > only 32MB, which sounds a bit on the small side. Typically we just map the > > > > > > > > We only have 32 MB ATM :( a bit small but it may increase to 64MB > > > > > > That sounds very miserly. Can you actually run an arm64 Linux kernel with > > > that little RAM? IIRC for QEMU we need at least 128 MB, and I haven't seen > > > an ARMv8 hardware platform with less than 512MB (maybe 256MB) DRAM yet. > > > > > > > > whole first DRAM bank, regardless of whether you actually have memory > > > > > there or not. U-Boot should know how much DRAM you have, so will not go > > > > > beyond that. Having page tables covering more address space does not > > > > > really hurt, but avoids all kind of problems. > > > > > And please note that U-Boot loves to move things around: itself from the > > > > > load address to the end of DRAM (that it knows of); possibly the kernel, > > > > > when the alignment is not right, or the DT and initrd if it sees fit. > > > > > So there is little point in mapping just portions of the memory. > > > > > > > > U-boot moves around a lot, I know :) In this case u-boot lives > > > > in is own 4MB SRAM but kernel lives in a 32MB HyperRAM. > > > > > > Interesting. I wonder if this works well with U-Boot's memory management, > > > which assumes it has quite some DRAM to play with. > > > > Found it, all memory spaces were set to secure mode, the req. spec does not agree :( > > Ah, yes, if the DRAM is configured as secure only, running in EL2 > (always non-secure on the A53) will not end well. > > > Anyhow, now kernel enters into EL2 then EL1 to EL0, all is well until kernel tries > > to do simple cache ops like dc ivac, x0 or mrs x3,ctr_el0 when I again just get an error exception: > > EXC [0x400] Synchronous Lower EL using AArch64 > > Was this with Linux, or some other kernel? IIRC cache maintenance
Yes, 5.14.x
> instructions in EL0 need to be enabled in SCTLR_EL1 (.UCI and .DZE, for > instance, plus maybe more registers), and those and other operations > should not be trapped to EL2 as well.
Cheers, Andre
I can see CNTVCT_EL0 counting in u-boot and I can see the relative timestamp in dmesg cont but timeofday is not moving, very odd.
COUNTER_FREQUENCY is also there and correct.
Jocke ________________________________________ From: Andre Przywara andre.przywara@arm.com Sent: 17 March 2022 01:32 To: Joakim Tjernlund Cc: u-boot@lists.denx.de Subject: Re: ARM A53 and initial MMU mapping for EL0/1/2/3 ?
Cheers, Andre
Jocke
Yes, 5.14.x
Cheers, Andre
FWIW, the u-boot on the kontron_sl28 (which is a A72 core) is running in EL3. But it's a layerscape so it might be worth looking in arch/arm/cpu/armv8/fsl-layerscale/ if there is anything special.
-michael
Thanks Michael, that's what I meant: the generic EL3 code in arch/arm/cpu/armv8 might depend on more platform specific code to make it work.
Cheers, Andre
Thanks guys, will look at these boards. I have learnt that EL2 state in our design may be broken so I started to look at going directly to EL1 instead, is that a bad idea?
In u-boot I find:
#ifdef CONFIG_ARMV8_SWITCH_TO_EL1 static void switch_to_el1(void) { if ((IH_ARCH_DEFAULT == IH_ARCH_ARM64) && (images.os.arch == IH_ARCH_ARM)) armv8_switch_to_el1(0, (u64)gd->bd->bi_arch_number, (u64)images.ft_addr, 0, (u64)images.ep, ES_TO_AARCH32); else armv8_switch_to_el1((u64)images.ft_addr, 0, 0, 0, images.ep, ES_TO_AARCH64); } #endif .... #ifdef CONFIG_ARMV8_SWITCH_TO_EL1 armv8_switch_to_el2((u64)images->ft_addr, 0, 0, 0, (u64)switch_to_el1, ES_TO_AARCH64); #else .....
which looks promising but when I look closer I see that this seems to do: EL3 -> EL1 -> EL2 Really? What is the point ? Looks like I need to hack something myself to go EL3->EL1 or am I missing something ?
Jocke
On Wed, 9 Feb 2022 18:07:24 +0000 Joakim Tjernlund Joakim.Tjernlund@infinera.com wrote:
How so? The exception levels itself are completely capsuled in the CPU core, so Arm Cortex-A53, in your case. And EL2 surely runs happily there. I wouldn't know of any peripherals being affected by the EL the core is running in (ignoring secure state for now).
So what is the problem, exactly? The only EL2 problems I heard of were firmware related (not setting up EL2 correctly), but we are looking at the firmware here.
Please don't do this. For a start, I don't think it's necessary, and also you are leaving the architectural trails here. In particular you are getting into trouble with PSCI. Sure, you can somehow hack this up, but it will stay a hack and it will come back and bite you later. Promised ;-)
In u-boot I find:
Last time I tried this, for an experiment, this part was broken, it sets up SCTLR wrongly, making the Linux kernel decompressor hang. I am tempted to ask for removal, since it has architectural problems with PSCI anyway.
And this has issues with PSCI as well, since we now skip one EL, which the spec does not allow.
Cheers, Andre
Jocke
Andre Przywara
Joakim Tjernlund
Michael Walle
