[U-Boot] [PATCH] Fix breakage in SMC EEPROM standalone applications
Commit 6a45e384955262882375a2785426dc65aeb636c4 (Make getenv_IPaddr() global) inadvertently added ' #include "net.h" ' to the standalone programs, creating duplicate definitions of 'struct eth_device'. This patch removes the local definitions and removes other code that breaks due to the change in definition.
Signed-off-by: Ben Warren biggerbadderben@gmail.com --- examples/standalone/smc91111_eeprom.c | 2 -- examples/standalone/smc911x_eeprom.c | 8 -------- 2 files changed, 0 insertions(+), 10 deletions(-)
diff --git a/examples/standalone/smc91111_eeprom.c b/examples/standalone/smc91111_eeprom.c index 428ea7b..9145763 100644 --- a/examples/standalone/smc91111_eeprom.c +++ b/examples/standalone/smc91111_eeprom.c @@ -29,8 +29,6 @@
#include <common.h> #include <exports.h> -/* the smc91111.h gets base addr through eth_device' iobase */ -struct eth_device { unsigned long iobase; }; #include "../drivers/net/smc91111.h"
#ifndef SMC91111_EEPROM_INIT diff --git a/examples/standalone/smc911x_eeprom.c b/examples/standalone/smc911x_eeprom.c index fff3123..104047f 100644 --- a/examples/standalone/smc911x_eeprom.c +++ b/examples/standalone/smc911x_eeprom.c @@ -16,13 +16,6 @@
#include <common.h> #include <exports.h> - -/* the smc911x.h gets base addr through eth_device' iobase */ -struct eth_device { - const char *name; - unsigned long iobase; - void *priv; -}; #include "../drivers/net/smc911x.h"
/** @@ -324,7 +317,6 @@ int smc911x_eeprom(int argc, char *argv[]) { /* Avoid initializing on stack as gcc likes to call memset() */ struct eth_device dev; - dev.name = __func__; dev.iobase = CONFIG_SMC911X_BASE;
/* Print the ABI version */
Yes, great. This looks better than my proposal to fix this some minutes ago :)
Thanks
Dirk
Signed-off-by: Ben Warrenbiggerbadderben@gmail.com
#include<common.h> #include<exports.h> -/* the smc91111.h gets base addr through eth_device' iobase */ -struct eth_device { unsigned long iobase; }; #include "../drivers/net/smc91111.h"
- const char *name;
- void *priv;
On Monday 18 January 2010 14:35:31 Ben Warren wrote:
--- a/examples/standalone/smc911x_eeprom.c +++ b/examples/standalone/smc911x_eeprom.c @@ -324,7 +317,6 @@ int smc911x_eeprom(int argc, char *argv[]) { /* Avoid initializing on stack as gcc likes to call memset() */ struct eth_device dev;
the .name was added because some patch was changing smc911x.h to use it in error reporting, but i guess that never made it in as the current header uses DRIVERNAME ...
Acked-by: Mike Frysinger vapier@gentoo.org -mike
Dear Ben Warren,
In message 1263843331-30089-1-git-send-email-biggerbadderben@gmail.com you wrote:
Applied, thanks.
Ben Warren
Dirk Behme
Mike Frysinger
