[U-Boot] SPI on PPC MPC85xx
Hi all,
I've been trying to setup SPI on our MPC85xx based board.
Unfortunately, compilation of mpc8xxx_spi.c fails due to a missing immap_t datatype.
I see, that this datatype is defined in the headers immap_83xx.h and immap_86xx.h but it is not in immap_85xx.h.
I am using u-boot-2009.11.1 but I also looked into the latest git sources, and there's no immap_t in that specific file neither.
Is there a reason why it is not implemented for MPC85xx? Or do I just need some more defines?
So far I only have CONFIG_MPC8XXX_SPI and undef CONFIG_SOFT_SPI.
Cheers Matthias Dunda
Hi again,
unfortunately I have to push this message, as I received no comment on it, yet.
Is there a reason why the immap_t is not implemented for mpc85xx?
I tried to copy it from mpc8360 but there are so many dependent mpc83xx datatypes in that struct that I postponed the work on that, because I think it'll lead to no success...
Even trying to use the soft SPI fails, because first thing the code does is using that immap_t datatype... :-(
Does anyone have a comment on this?
Cheers Matthias
Am 25.10.2010 um 13:05 schrieb Matthias:
Hi all,
Dear Matthias Dunda,
See http://catb.org/esr/faqs/smart-questions.html#id586288
Hi Matthias,
I took a quick glance at this. There are different versions of SPI controllers in the MPC8xxx SoC's. As it seems mpc8xxx_spi.c does "only" support the "CPU- mode" (meaning non-CPM/QE-mode) Freescale SPI controllers. This controller is implemented for example in the MPC8349. For your SoC (MPC8568) you need to implement the QE-mode which is currently not supported.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Hi Matthias,
Stefan Roese schrieb:
Hi Matthias,
I didn't compare the MPC85xx QE SPI controller with the MPC8xx CPM SPI controller, but maybe a look at arch/powerpc/cpu/mpc8xx/spi.c could help you as a base for porting/creating a driver?
On Wed, 27 Oct 2010 08:55:42 +0200 Matthias Dunda user254@t1817.greatnet.de wrote:
Hi again,
immap_t gets to be a mess of ifdefs when you're trying to support a bunch of different chips with slight differences, not to mention having to manage all the reserved regions with obscure size values to keep everything in the right spot (versus a simple offset of the start of a register block that can be easily compared to the manual).
-Scott
participants (6)
Jens Gehrlein
Matthias
Matthias Dunda
Scott Wood
Stefan Roese
