How to modify defconfig file - make savedefconfig?
What is the "right" way to modify a defconfig file?
Most sources I've found just say things like "edit the defconfig file". That seems error-prone -- especially when dealing with settings that have side effects.
I did stumble across one mention of "make savedefconfig", and this seems to be the right way to modify a defconfig file:
make myboard_defconfig make menuconfig make savedefconfig cp defconfig configs/myboard_defconfig
Do people manually edit their defconfig file when they want to make a change, or do they use "make savedefconfig" like I show above?
One reason I'm asking is that the original defconfig file provided by the silicon vendor (Renesas) appears to be a manually stripped-down ..config file, because when I do
make vendors_defconfig make savedefconfig
The defconfig file generated by 'make savedefconfig' looks _nothing_ like the starting vendors_defconfig. The new defconfig generates the same .config file as the vendors_defconfig file. But the vendors_defconfig file is arranged completely differently with different/extra comments, extra blank lines, etc.
-- Grant
Hello Grant,
Am Thu, Jan 27, 2022 at 04:46:48PM -0000 schrieb Grant Edwards:
That's what I do.
You can do both. If you already have a defconfig, this:
1) edit your myboard_defconfig 2) make myboard_defconfig 3) make savedefconfig 4) cp defconfig configs/myboard_defconfig
You might want to `git add configs/myboard_defconfig` in between those stages if you want to inspect what changed with those calls.
I think U-Boot expects those files to be created by savedefconfig, see all the changesets in Git reading 'configs: Resync with savedefconfig'.
Greets Alex
Alexander Dahl
Grant Edwards
