[U-Boot] [PATCH] imx8qxp_mek: add README
Add README file for i.MX8QXP MEK board.
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Anatolij Gustschin agust@denx.de ---
This patch is for testing i.MX8QXP patchset [PATCH V2 00/32] i.MX: Add i.MX8QXP support https://lists.denx.de/pipermail/u-boot/2018-July/335079.html The board is using B0 chip, A0 chip is not being supported. Please help test if you are interested. I'll post out V3 after collecting more comments. Sadly, I do not know where to download scfw_tcm.bin in public for B0 QXP.
Thanks, Peng.
board/freescale/imx8qxp_mek/README | 70 ++++++++++++++++++++++++++++++++++++++ 1 file changed, 70 insertions(+) create mode 100644 board/freescale/imx8qxp_mek/README
diff --git a/board/freescale/imx8qxp_mek/README b/board/freescale/imx8qxp_mek/README new file mode 100644 index 0000000000..97c244543a --- /dev/null +++ b/board/freescale/imx8qxp_mek/README @@ -0,0 +1,70 @@ +U-Boot for the NXP i.MX8QXP EVK board + +Quick Start +=========== + +- Build U-Boot +- Build the ARM Trusted firmware binary +- Get scfw_tcm.bin and ahab-container.img +- Get mkimage tool +- Generate flash.bin using imx-mkimage +- Flash the binary into the SD card +- Boot + +Build U-Boot +============ + +$ make imx8qxp_mek_defconfig +$ make + +Get and Build the ARM Trusted firmware +====================================== + +$ git clone https://source.codeaurora.org/external/imx/imx-atf +$ cd imx-atf/ +$ git checkout origin/imx_4.9.88_imx8qxp_beta2 +$ make PLAT=imx8qxp bl31 + +Get scfw_tcm.bin and ahab-container.img +============================== + +$ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-7.6.bin +$ chmod +x firmware-imx-7.6.bin +$ ./firmware-imx-7.6.bin + +scfw_tcm.bin [TODO] + +Get mkimage tool +============================== +Download the imx-mkimage tool: + +$ git clone https://source.codeaurora.org/external/imx/imx-mkimage/ +$ cd imx-mkimage/ +$ git checkout origin/imx_4.9.88_imx8qxp_beta2 + + +Generate flash.bin using imx-mkimage +==================================== + +Copy the following binaries to imx-mkimage/iMX8M folder: + +$ cp imx-atf/build/imx8qxp/release/bl31.bin imx-mkimage/iMX8QX/ +$ cp u-boot/u-boot.bin imx-mkimage/iMX8QX/ + +Copy the following firmwares to imx-mkimage/iMX8 folder : + +$ cp firmware-imx-7.6/firmware/seco/ahab-container.img imx-mkimage/iMX8QX/ + +$ cd imx-mkimage/ +$ make SOC=iMX8QX flash + +Flash the binary into the SD card +================================= + +Burn the flash.bin binary to SD card offset 32KB: + +$ sudo dd if=iMX8QX/flash.bin of=/dev/sd[x] bs=1024 seek=32 + +Boot +==== +Set Boot switch SW2: 1100.
Hi Peng,
Thanks for submitting the README file.
Could you please check how to make this binary available to the users?
Users need to have access to the firmware, otherwise it is a blocking issue for upstreaming mx8qxp support.
Thanks
-----Original Message----- From: Fabio Estevam [mailto:festevam@gmail.com] Sent: 2018年7月23日 21:44 To: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de; Fabio Estevam fabio.estevam@nxp.com; U-Boot-Denx u-boot@lists.denx.de; Diego Dorta diego.dorta@nxp.com Subject: Re: [U-Boot] [PATCH] imx8qxp_mek: add README
Hi Peng,
This patch is for testing i.MX8QXP patchset [PATCH V2 00/32] i.MX: Add i.MX8QXP support https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flis
ts.denx.de%2Fpipermail%2Fu-boot%2F2018-July%2F335079.html&data=0 2%
7C01%7Cpeng.fan%40nxp.com%7Ca0880385d7064b72028108d5f0a262b5%7C6 86ea1d
3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C636679502587918095&sdata =a%2FO
Mb17xmtxbjSaXbNpkOnHWERFkrH4Y0jA8EkqF8ic%3D&reserved=0 The board is using B0 chip, A0 chip is not being supported. Please help test if you are interested. I'll post out V3 after collecting more comments. Sadly, I do not know where to download scfw_tcm.bin in public for B0 QXP.
Need to wait external releases for i.MX8QXP B0. Hope soon.
Different boards needs different scfw, there will be a porting kit for users when external release. I just do not know where to download scfw_tcm.bin for i.MX8QXP MEK board (:
Thanks, Peng.
Thanks
Fabio Estevam
Peng Fan
