[PATCH] test: efi_loader: Fix dependency for http test
The config setting CMD_BOOTEFI_HELLO_COMPILE was removed in favour of BOOTEFI_HELLO_COMPILE but the dependency for test_efi_helloworld_net_http was not updated and so is now incorrect preventing the test from ever running. Fix it.
Fixes: 6fe80876dcc7 ("efi_loader: Rename and move CMD_BOOTEFI_HELLO_COMPILE") Signed-off-by: Andrew Goodbody andrew.goodbody@linaro.org ---
test/py/tests/test_efi_loader.py | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/test/py/tests/test_efi_loader.py b/test/py/tests/test_efi_loader.py index 707b2c9e79..33434935fe 100644 --- a/test/py/tests/test_efi_loader.py +++ b/test/py/tests/test_efi_loader.py @@ -182,7 +182,7 @@ def test_efi_helloworld_net_tftp(u_boot_console): do_test_efi_helloworld_net(u_boot_console, PROTO_TFTP);
@pytest.mark.buildconfigspec('of_control') -@pytest.mark.buildconfigspec('cmd_bootefi_hello_compile') +@pytest.mark.buildconfigspec('bootefi_hello_compile') @pytest.mark.buildconfigspec('cmd_wget') def test_efi_helloworld_net_http(u_boot_console): """Run the helloworld.efi binary via HTTP.
And I see arch/x86/lib/Makefile has an invalid reference still now too, can you please fix that as a follow up? Thanks.
Patch sent.
Andrew
Thanks, Andrew
On Fri, 25 Oct 2024 at 19:47, Andrew Goodbody andrew.goodbody@linaro.org wrote:
@pytest.mark.buildconfigspec('of_control') -@pytest.mark.buildconfigspec('cmd_bootefi_hello_compile') +@pytest.mark.buildconfigspec('bootefi_hello_compile') @pytest.mark.buildconfigspec('cmd_wget') def test_efi_helloworld_net_http(u_boot_console): """Run the helloworld.efi binary via HTTP. -- 2.39.5
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Andrew Goodbody
Ilias Apalodimas
