[U-Boot] [PATCH] bootcount: flush after storing the bootcounter
If the bootcounter address is in a cached memory, a flush of dcache must occur after updateing the bootcounter.
Issue found on i.MX6 where bootcounter is put into the internal (cached) IRAM.
Signed-off-by: Stefano Babic sbabic@denx.de --- drivers/bootcount/bootcount.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/bootcount/bootcount.c b/drivers/bootcount/bootcount.c index d5ce450..48594a6 100644 --- a/drivers/bootcount/bootcount.c +++ b/drivers/bootcount/bootcount.c @@ -59,6 +59,9 @@ __weak void bootcount_store(ulong a) raw_bootcount_store(reg, a); raw_bootcount_store(reg + 4, BOOTCOUNT_MAGIC); #endif /* defined(CONFIG_SYS_BOOTCOUNT_SINGLEWORD */ + flush_dcache_range(CONFIG_SYS_BOOTCOUNT_ADDR, + CONFIG_SYS_BOOTCOUNT_ADDR + + CONFIG_SYS_CACHELINE_SIZE); }
__weak ulong bootcount_load(void)
Hi Stefano,
- flush_dcache_range(CONFIG_SYS_BOOTCOUNT_ADDR,
Is it safe to flush the whole cache line?
For iMX6Q I do use SNVS_LPGR register (0x020CC068). It will preserve its content after reset caused by WDT (also reset command in u-boot). I also do use the SINGLEWORD to store "magic" and boot count in a single 32 bit number.
You may also want to consider using SRC_GPRx registers: https://community.nxp.com/message/985790?commentID=985790&et=watches.ema...
As it shall be safe to use them for bootcount scenario. However, I do prefer SNVS_LPGR.
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
Hi Lukasz,
On 22/02/2018 12:52, Lukasz Majewski wrote:
Hi Stefano,
Is there is some drawbacks ?
flush_dcache_range() requires that addresses are aligned with CONFIG_SYS_CACHELINE_SIZE. I cannot flush a single word.
It is a long story...
I used it in the past - Heiko found issues with recent kernel versions because kernel is using it. That means, after a rebootwe get what the kernel has written in it, not the bootcounter anymore.
It looks like, too, that SNVS behavior changes between i.MX6 variants. Even in manual, there are discordances (on i.MX6Q seems can be used, on DL seems to be reserved,...).
Due to recent issues, I searched for a suitable place in IRAM.
Anyway, this has nothing to do with the issue. If the storage with the bootcounter is cached, it must be flushed.
See above, waiting for Heiko's comment,too.
Rather, it looks like it is not safe. Or it was safe, it is not. Or it depends on i.MX6 revisions....
You're lucky you do not yet go into trouble :-)
Best regards, Stefano
Hi Stefano,
Hi Lukasz,
Hi Stefano,
I think not - as we are now in u-boot.
(I do have patches, which add also support for bootcount in SPL - I will send them when Kconfig prerequisities go into mainline).
Yes. Correct.
You mean the SRC_GPRx registers?
What I can say.... :/
Ok.
Yes. Of course.
Ok. Maybe the reply from the NXP community is not complete...
It would be great if Heiko could share the problem with SRC_GPRx registers. I would like to know the root cause for the future usage.
Devlopment by luck :-)
Lukasz Majewski
Hello Lukasz,
Am 22.02.2018 um 14:03 schrieb Lukasz Majewski:
Hi Stefano,
Hi Lukasz,
Hi Stefano,
Yes. Correct.
Ok.
Yes. Of course.
Hmm.. I have here an imx6dl based board:
CPU: Freescale i.MX6DL rev1.3 at 792 MHz
and I tried to put the bootcounter into the iram, but found no addr, which is stable over a reboot from linux into U-Boot ... I must admit, that I use the GPU may it use iram? Nevertheless, unsure place.
Tried SRC_GPRx registers, but also not stable after a "boot linux - reboot to U-Boot" cycle.
imx6 D/QL UML says SRC_GPRx with x = 5-8 for quad only -> so not usable for me
and x=(1-8):
"Holds argument of entry function for coreX. The SRC ensures that the register value will persist across system resets."
with (X=0-3)
So, the core may uses them ...
The S/DL manual says to this registers: "Read/write general purpose bits used to store an arbitrary value. This register is used by the ROM code and should not be used by application software."
So also on S/DL no chance to use this registers without risk ...
I have on my hw a pfuze100 and I stored the bootcounter in the 4 8bit registers MEMA - MEMD ... as we have no battery attached to the pfuze this works fine... as you said "Development by luck" :-D
Hmm... SVN_LGPR regsiter ... sounds good. Tried it fast here on my hw, seems to work ... but may instability remains, UML says:
"When GPR_SL or GPR_HL bit is set, the register cannot be programmed."
Once GPR_SL bit is set, it can only cleared through System Reset ...
May a risk?
bye, Heiko
Lukasz Majewski
Hi Heiko,
Hello Lukasz,
Hi Stefano,
Hi Lukasz,
Hi Stefano,
Yes. Correct.
Ok.
Yes. Of course.
and x=(1-8):
with (X=0-3)
This was also my concern. Hence I've asked NXP community (support) explicitly:
Maybe the BootROM is different for different SoC versions? (My iMX6Q is rev. 1.5, yours iMX6DL is 1.3)?
Maybe it would be good to ask your case on the NXP community site as well?
Similar symptomps I had with some Samsung SoCs. In their case the FBL (not BootROM) from Samsung was using those registers to check if we go out from "sleep" mode.
However, what I've understood from iMX6 User Manual, the BootROM on iMX6 needs values from SRC_GPRx - and it shall restore the LInux without the need for bootloader intervention.
The same case for me. I also don't have the battery attached - hence the SNVS_LGPR is OK to use.
But this would be need to be set by other user application. Also, this register is marked as the one to be used with "user application".
May a risk?
If your user write an application, which will use this regsiter, then yes, it may be a risk.
bye, Heiko
Lukasz Majewski
Lukasz Majewski
Heiko Schocher
Lukasz Majewski
Stefano Babic
