[U-Boot] Is the Numonyx's M29W128 fully supported in U-Boot?
Hi all,
We have a MPC5200B custom board and we are evaluating the Numonyx M29W128 Flash as a second source for the Spansion's S29GL128. I've checked the top of the tree version of the U-Boot (u-boot.git) CFI driver and the Numonyx Flash is not detected. This is the U-Boot debug output:
FLASH: flash detect cfi fwc addr fe000000 cmd f0 f0 8bit x 8 bit fwc addr fe000055 cmd 98 98 8bit x 8 bit is= cmd 51(Q) addr fe000010 is= 0 51 fwc addr fe000000 cmd f0 f0f0 16bit x 8 bit fwc addr fe0000aa cmd 98 9898 16bit x 8 bit is= cmd 51(Q) addr fe000020 is= 5100 5151 fwc addr fe000000 cmd f0 00f0 16bit x 16 bit fwc addr fe0000aa cmd 98 0098 16bit x 16 bit is= cmd 51(Q) addr fe000020 is= 6d69 0051 fwc addr fe000000 cmd f0 f0f0f0f0 32bit x 8 bit fwc addr fe000154 cmd 98 98989898 32bit x 8 bit is= cmd 51(Q) addr fe000040 is= 4e6f7620 51515151 fwc addr fe000000 cmd f0 00f000f0 32bit x 16 bit fwc addr fe000154 cmd 98 00980098 32bit x 16 bit is= cmd 51(Q) addr fe000040 is= 4e6f7620 00510051 fwc addr fe000000 cmd f0 000000f0 32bit x 32 bit fwc addr fe000154 cmd 98 00000098 32bit x 32 bit is= cmd 51(Q) addr fe000040 is= 4e6f7620 00000051 fwrite addr fe000000 cmd f0 f0f0f0f0f0f0f0f0 64 bit x 8 bit fwrite addr fe0002a8 cmd 98 9898989898989898 64 bit x 8 bit is= cmd 51(Q) addr fe000080 is= 0000000000000000 5151515151515151 fwrite addr fe000000 cmd f0 00f000f000f000f0 64 bit x 16 bit fwrite addr fe0002a8 cmd 98 0098009800980098 64 bit x 16 bit is= cmd 51(Q) addr fe000080 is= 0000000000000000 0051005100510051 fwrite addr fe000000 cmd f0 000000f0000000f0 64 bit x 32 bit fwrite addr fe0002a8 cmd 98 0000009800000098 64 bit x 32 bit is= cmd 51(Q) addr fe000080 is= 0000000000000000 0000005100000051 fwrite addr fe000000 cmd f0 00000000000000f0 64 bit x 64 bit fwrite addr fe0002a8 cmd 98 0000000000000098 64 bit x 64 bit is= cmd 51(Q) addr fe000080 is= 0000000000000000 0000000000000051 not found ## Unknown FLASH on Bank 0 - Size = 0x00000000 = 0 MB
This is the debug output for the Spansion Flash that works fine.
FLASH: flash detect cfi fwc addr fe000000 cmd f0 f0 8bit x 8 bit fwc addr fe000055 cmd 98 98 8bit x 8 bit is= cmd 51(Q) addr fe000010 is= 0 51 fwc addr fe000000 cmd f0 f0f0 16bit x 8 bit fwc addr fe0000aa cmd 98 9898 16bit x 8 bit is= cmd 51(Q) addr fe000020 is= 5151 5151 is= cmd 52(R) addr fe000022 is= 5252 5252 is= cmd 59(Y) addr fe000024 is= 5959 5959 ushort addr is at fe000050 info->portwidth = 2 addr[0] = 0x2 addr[1] = 0x2 addr[2] = 0x0 addr[3] = 0x0 retval = 0x2 device interface is 2 found port 2 chip 1 port 16 bits chip 8 bits ushort addr is at fe000026 info->portwidth = 2 addr[0] = 0x2 addr[1] = 0x2 addr[2] = 0x0 addr[3] = 0x0 retval = 0x2 fe000020 : 51 51 52 52 59 59 02 02 00 00 40 40 00 00 00 00 QQRRYY....@@.... fe000030 : 00 00 00 00 00 00 27 27 36 36 00 00 00 00 06 06 ......''66...... fe000040 : 06 06 09 09 13 13 03 03 05 05 03 03 02 02 18 18 ................ fe000050 : 02 02 00 00 06 06 00 00 01 01 7f 7f 00 00 00 00 ................ fe000060 : 02 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ fe000070 : 00 00 00 00 00 00 00 00 00 00 ff ff ff ff ff ff ................ fe000080 : 50 50 52 52 49 49 31 31 33 33 14 14 02 02 01 01 PPRRII1133...... fe000090 : 00 00 08 08 00 00 00 00 02 02 b5 b5 c5 c5 04 04 ................ manufacturer is 2 size_ratio 1 port 16 bits chip 8 bits found 1 erase regions long addr is at fe00005a info->portwidth = 2 addr[0] = 0x7f addr[1] = 0x7f addr[2] = 0x0 addr[3] = 0x0 addr[4] = 0x0 addr[5] = 0x0 addr[6] = 0x2 addr[7] = 0x2 erase_region_count = 128 erase_region_size = 131072 ushort addr is at fe000054 info->portwidth = 2 addr[0] = 0x6 addr[1] = 0x6 addr[2] = 0x0 addr[3] = 0x0 retval = 0x6
So the problem seems to be that the Numonyx Flash do not put the CFI query information in the odd bytes as you can see here: fwc addr fe000000 cmd f0 f0f0 16bit x 8 bit fwc addr fe0000aa cmd 98 9898 16bit x 8 bit is= cmd 51(Q) addr fe000020 is= 5100 5151
I've checked the U-Boot mainling list and I've found only something about a M29W128 bug but in a coldfire architecture. So I think the Numonyx Flash has been tested in some boards but I don't knwon if there is full support in U-Boot for it. If not, is there a patch available or in process? Any clue will be welcomed.
TIA,
Hi all,
I'm sorry, I sent to the list the debug messages of a older U-Boot version. Here are the debug messages of the current U-Boot version.
FLASH: flash detect cfi fwc addr fe000000 cmd f0 f0 8bit x 8 bit fwc addr fe000000 cmd ff ff 8bit x 8 bit fwc addr fe000055 cmd 98 98 8bit x 8 bit is= cmd 51(Q) addr fe000010 is= 0 51 fwc addr fe000555 cmd 98 98 8bit x 8 bit is= cmd 51(Q) addr fe000010 is= 0 51 fwc addr fe000000 cmd f0 f0f0 16bit x 8 bit fwc addr fe000000 cmd ff ffff 16bit x 8 bit fwc addr fe0000aa cmd 98 9898 16bit x 8 bit is= cmd 51(Q) addr fe000020 is= 5100 5151 fwc addr fe000aaa cmd 98 9898 16bit x 8 bit is= cmd 51(Q) addr fe000020 is= 5100 5151 fwc addr fe000000 cmd f0 00f0 16bit x 16 bit fwc addr fe000000 cmd ff 00ff 16bit x 16 bit fwc addr fe0000aa cmd 98 0098 16bit x 16 bit is= cmd 51(Q) addr fe000020 is= 6d69 0051 fwc addr fe000aaa cmd 98 0098 16bit x 16 bit is= cmd 51(Q) addr fe000020 is= 6d69 0051 fwc addr fe000000 cmd f0 f0f0f0f0 32bit x 8 bit fwc addr fe000000 cmd ff ffffffff 32bit x 8 bit fwc addr fe000154 cmd 98 98989898 32bit x 8 bit is= cmd 51(Q) addr fe000040 is= 4e6f7620 51515151 fwc addr fe001554 cmd 98 98989898 32bit x 8 bit is= cmd 51(Q) addr fe000040 is= 4e6f7620 51515151 fwc addr fe000000 cmd f0 00f000f0 32bit x 16 bit fwc addr fe000000 cmd ff 00ff00ff 32bit x 16 bit fwc addr fe000154 cmd 98 00980098 32bit x 16 bit is= cmd 51(Q) addr fe000040 is= 4e6f7620 00510051 fwc addr fe001554 cmd 98 00980098 32bit x 16 bit is= cmd 51(Q) addr fe000040 is= 4e6f7620 00510051 fwc addr fe000000 cmd f0 000000f0 32bit x 32 bit fwc addr fe000000 cmd ff 000000ff 32bit x 32 bit fwc addr fe000154 cmd 98 00000098 32bit x 32 bit is= cmd 51(Q) addr fe000040 is= 4e6f7620 00000051 fwc addr fe001554 cmd 98 00000098 32bit x 32 bit is= cmd 51(Q) addr fe000040 is= 4e6f7620 00000051 fwrite addr fe000000 cmd f0 f0f0f0f0f0f0f0f0 64 bit x 8 bit fwrite addr fe000000 cmd ff ffffffffffffffff 64 bit x 8 bit fwrite addr fe0002a8 cmd 98 9898989898989898 64 bit x 8 bit is= cmd 51(Q) addr fe000080 is= 0000000000000000 5151515151515151 fwrite addr fe002aa8 cmd 98 9898989898989898 64 bit x 8 bit is= cmd 51(Q) addr fe000080 is= 0000000000000000 5151515151515151 fwrite addr fe000000 cmd f0 00f000f000f000f0 64 bit x 16 bit fwrite addr fe000000 cmd ff 00ff00ff00ff00ff 64 bit x 16 bit fwrite addr fe0002a8 cmd 98 0098009800980098 64 bit x 16 bit is= cmd 51(Q) addr fe000080 is= 0000000000000000 0051005100510051 fwrite addr fe002aa8 cmd 98 0098009800980098 64 bit x 16 bit is= cmd 51(Q) addr fe000080 is= 0000000000000000 0051005100510051 fwrite addr fe000000 cmd f0 000000f0000000f0 64 bit x 32 bit fwrite addr fe000000 cmd ff 000000ff000000ff 64 bit x 32 bit fwrite addr fe0002a8 cmd 98 0000009800000098 64 bit x 32 bit is= cmd 51(Q) addr fe000080 is= 0000000000000000 0000005100000051 fwrite addr fe002aa8 cmd 98 0000009800000098 64 bit x 32 bit is= cmd 51(Q) addr fe000080 is= 0000000000000000 0000005100000051 fwrite addr fe000000 cmd f0 00000000000000f0 64 bit x 64 bit fwrite addr fe000000 cmd ff 00000000000000ff 64 bit x 64 bit fwrite addr fe0002a8 cmd 98 0000000000000098 64 bit x 64 bit is= cmd 51(Q) addr fe000080 is= 0000000000000000 0000000000000051 fwrite addr fe002aa8 cmd 98 0000000000000098 64 bit x 64 bit is= cmd 51(Q) addr fe000080 is= 0000000000000000 0000000000000051 not found
El vie, 11-12-2009 a las 15:03 +0100, txema lopez escribió:
Hi all,
TIA,
Hi all,
This is a patch to fix the NUMONYX's M29W128GL cfi detection bug in my Lite5200B based custom board. I thing I's only a starting point for a more formal patch valid for any kind of architecture (big and little endian) and flash layout (I've only check it in a 16x portwitdh 8x chipwitch). I'm not a CFI flash expert and any feedback about this issue will be welcomed.
TIA,
--- cfi_flash_old.c 2009-12-09 18:25:44.000000000 +0100 +++ cfi_flash_new.c 2009-12-17 10:28:00.000000000 +0100 @@ -214,6 +214,10 @@ static void flash_make_cmd(flash_info_t val = *((uchar*)&cmd + sizeof(u32) - cword_offset - 1); #endif cp[cp_offset] = (cword_offset >= sizeof(u32)) ? 0x00 : val; + if(info->cfi_fixup & CFI_NUMONYX_FIXUP) { + if(cp_offset & 1) + cp[cp_offset] = 0x00; + } } }
@@ -266,7 +270,10 @@ static inline uchar flash_read_uchar (fl #if defined(__LITTLE_ENDIAN) || defined(CONFIG_SYS_WRITE_SWAPPED_DATA) retval = flash_read8(cp); #else - retval = flash_read8(cp + info->portwidth - 1); + if(info->cfi_fixup & CFI_NUMONYX_FIXUP) + retval = flash_read8(cp); + else + retval = flash_read8(cp + info->portwidth - 1); #endif flash_unmap (info, 0, offset, cp); return retval; @@ -1420,7 +1427,12 @@ static void cmdset_amd_read_jedec_ids(fl { ushort bankId = 0; uchar manuId; + uchar portwidth;
+ portwidth = info->portwidth; + if(info->chipwidth == FLASH_CFI_8BIT) + info->portwidth = FLASH_CFI_8BIT; + flash_write_cmd(info, 0, 0, AMD_CMD_RESET); flash_unlock_seq(info, 0); flash_write_cmd(info, 0, info->addr_unlock1, FLASH_CMD_READ_ID); @@ -1438,14 +1450,14 @@ static void cmdset_amd_read_jedec_ids(fl switch (info->chipwidth){ case FLASH_CFI_8BIT: info->device_id = flash_read_uchar (info, - FLASH_OFFSET_DEVICE_ID); + FLASH_OFFSET_DEVICE_ID * portwidth); if (info->device_id == 0x7E) { /* AMD 3-byte (expanded) device ids */ info->device_id2 = flash_read_uchar (info, - FLASH_OFFSET_DEVICE_ID2); + FLASH_OFFSET_DEVICE_ID2 * portwidth); info->device_id2 <<= 8; info->device_id2 |= flash_read_uchar (info, - FLASH_OFFSET_DEVICE_ID3); + FLASH_OFFSET_DEVICE_ID3 * portwidth); } break; case FLASH_CFI_16BIT: @@ -1456,6 +1468,9 @@ static void cmdset_amd_read_jedec_ids(fl break; } flash_write_cmd(info, 0, 0, AMD_CMD_RESET); + + info->portwidth = portwidth; + }
static int cmdset_amd_init(flash_info_t *info, struct cfi_qry *qry) @@ -1582,6 +1597,10 @@ void __flash_cmd_reset(flash_info_t *inf * that AMD flash roms ignore the Intel command. */ flash_write_cmd(info, 0, 0, AMD_CMD_RESET); + + if(info->cfi_fixup & CFI_NUMONYX_FIXUP) + return; + flash_write_cmd(info, 0, 0, FLASH_CMD_RESET); } void flash_cmd_reset(flash_info_t *info) @@ -1646,6 +1665,12 @@ static int flash_detect_cfi (flash_info_ { debug ("flash detect cfi\n");
+ info->cfi_fixup = 0; + +#ifdef CONFIG_FLASH_NUMONYX_FIXUP + info->cfi_fixup = CFI_NUMONYX_FIXUP; +#endif + for (info->portwidth = CONFIG_SYS_FLASH_CFI_WIDTH; info->portwidth <= FLASH_CFI_64BIT; info->portwidth <<= 1) { for (info->chipwidth = FLASH_CFI_BY8;
--- flash_old.h 2009-12-10 12:25:41.000000000 +0100 +++ flash_new.h 2009-12-17 10:26:55.000000000 +0100 @@ -55,6 +55,7 @@ typedef struct { ulong addr_unlock1; /* unlock address 1 for AMD flash roms */ ulong addr_unlock2; /* unlock address 2 for AMD flash roms */ const char *name; /* human-readable name */ + uchar cfi_fixup; #endif } flash_info_t;
@@ -87,6 +88,9 @@ typedef unsigned long flash_sect_t; /* convert between bit value and numeric value */ #define CFI_FLASH_SHIFT_WIDTH 3
+ +#define CFI_NUMONYX_FIXUP 0x01 + /* Prototypes */
extern unsigned long flash_init (void);
txema lopez <tlopez <at> aotek.es> writes:
Hi all,
Hi, Did you manage to solve this problem eventually?
Yes, and I submitted a patch only valid for my board architecture and flash layout. See, http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/72598/focus=72602
Best Regards
Avi Elbaz
txema lopez
Txema López
