[U-Boot] [RESEND PATCH v2 01/27] cfi_flash: Fix space between function name and parenthesis
Signed-off-by: Mario Six mario.six@gdsys.cc ---
v1 -> v2: None
--- drivers/mtd/cfi_flash.c | 428 ++++++++++++++++++++++++------------------------ 1 file changed, 214 insertions(+), 214 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index f096e039cb..0dc7f4a6ba 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -204,7 +204,7 @@ unsigned long flash_sector_size(flash_info_t *info, flash_sect_t sect) * create an address based on the offset and the port width */ static inline void * -flash_map (flash_info_t * info, flash_sect_t sect, uint offset) +flash_map(flash_info_t * info, flash_sect_t sect, uint offset) { unsigned int byte_offset = offset * info->portwidth;
@@ -247,17 +247,17 @@ static void flash_make_cmd(flash_info_t *info, u32 cmd, void *cmdbuf) /*----------------------------------------------------------------------- * Debug support */ -static void print_longlong (char *str, unsigned long long data) +static void print_longlong(char *str, unsigned long long data) { int i; char *cp;
cp = (char *) &data; for (i = 0; i < 8; i++) - sprintf (&str[i * 2], "%2.2x", *cp++); + sprintf(&str[i * 2], "%2.2x", *cp++); }
-static void flash_printqry (struct cfi_qry *qry) +static void flash_printqry(struct cfi_qry *qry) { u8 *p = (u8 *)qry; int x, y; @@ -283,31 +283,31 @@ static void flash_printqry (struct cfi_qry *qry) /*----------------------------------------------------------------------- * read a character at a port width address */ -static inline uchar flash_read_uchar (flash_info_t * info, uint offset) +static inline uchar flash_read_uchar(flash_info_t * info, uint offset) { uchar *cp; uchar retval;
- cp = flash_map (info, 0, offset); + cp = flash_map(info, 0, offset); #if defined(__LITTLE_ENDIAN) || defined(CONFIG_SYS_WRITE_SWAPPED_DATA) retval = flash_read8(cp); #else retval = flash_read8(cp + info->portwidth - 1); #endif - flash_unmap (info, 0, offset, cp); + flash_unmap(info, 0, offset, cp); return retval; }
/*----------------------------------------------------------------------- * read a word at a port width address, assume 16bit bus */ -static inline ushort flash_read_word (flash_info_t * info, uint offset) +static inline ushort flash_read_word(flash_info_t * info, uint offset) { ushort *addr, retval;
- addr = flash_map (info, 0, offset); - retval = flash_read16 (addr); - flash_unmap (info, 0, offset, addr); + addr = flash_map(info, 0, offset); + retval = flash_read16(addr); + flash_unmap(info, 0, offset, addr); return retval; }
@@ -325,13 +325,13 @@ static ulong flash_read_long (flash_info_t * info, flash_sect_t sect, #ifdef DEBUG int x; #endif - addr = flash_map (info, sect, offset); + addr = flash_map(info, sect, offset);
#ifdef DEBUG - debug ("long addr is at %p info->portwidth = %d\n", addr, + debug("long addr is at %p info->portwidth = %d\n", addr, info->portwidth); for (x = 0; x < 4 * info->portwidth; x++) { - debug ("addr[%x] = 0x%x\n", x, flash_read8(addr + x)); + debug("addr[%x] = 0x%x\n", x, flash_read8(addr + x)); } #endif #if defined(__LITTLE_ENDIAN) || defined(CONFIG_SYS_WRITE_SWAPPED_DATA) @@ -360,22 +360,22 @@ static void flash_write_cmd(flash_info_t *info, flash_sect_t sect, void *addr; cfiword_t cword;
- addr = flash_map (info, sect, offset); - flash_make_cmd (info, cmd, &cword); + addr = flash_map(info, sect, offset); + flash_make_cmd(info, cmd, &cword); switch (info->portwidth) { case FLASH_CFI_8BIT: - debug ("fwc addr %p cmd %x %x 8bit x %d bit\n", addr, cmd, + debug("fwc addr %p cmd %x %x 8bit x %d bit\n", addr, cmd, cword.w8, info->chipwidth << CFI_FLASH_SHIFT_WIDTH); flash_write8(cword.w8, addr); break; case FLASH_CFI_16BIT: - debug ("fwc addr %p cmd %x %4.4x 16bit x %d bit\n", addr, + debug("fwc addr %p cmd %x %4.4x 16bit x %d bit\n", addr, cmd, cword.w16, info->chipwidth << CFI_FLASH_SHIFT_WIDTH); flash_write16(cword.w16, addr); break; case FLASH_CFI_32BIT: - debug ("fwc addr %p cmd %x %8.8x 32bit x %d bit\n", addr, + debug("fwc addr %p cmd %x %8.8x 32bit x %d bit\n", addr, cmd, cword.w32, info->chipwidth << CFI_FLASH_SHIFT_WIDTH); flash_write32(cword.w32, addr); @@ -385,9 +385,9 @@ static void flash_write_cmd(flash_info_t *info, flash_sect_t sect, { char str[20];
- print_longlong (str, cword.w64); + print_longlong(str, cword.w64);
- debug ("fwrite addr %p cmd %x %s 64 bit x %d bit\n", + debug("fwrite addr %p cmd %x %s 64 bit x %d bit\n", addr, cmd, str, info->chipwidth << CFI_FLASH_SHIFT_WIDTH); } @@ -402,36 +402,36 @@ static void flash_write_cmd(flash_info_t *info, flash_sect_t sect, flash_unmap(info, sect, offset, addr); }
-static void flash_unlock_seq (flash_info_t * info, flash_sect_t sect) +static void flash_unlock_seq(flash_info_t * info, flash_sect_t sect) { - flash_write_cmd (info, sect, info->addr_unlock1, AMD_CMD_UNLOCK_START); - flash_write_cmd (info, sect, info->addr_unlock2, AMD_CMD_UNLOCK_ACK); + flash_write_cmd(info, sect, info->addr_unlock1, AMD_CMD_UNLOCK_START); + flash_write_cmd(info, sect, info->addr_unlock2, AMD_CMD_UNLOCK_ACK); }
/*----------------------------------------------------------------------- */ -static int flash_isequal (flash_info_t * info, flash_sect_t sect, +static int flash_isequal(flash_info_t * info, flash_sect_t sect, uint offset, uchar cmd) { void *addr; cfiword_t cword; int retval;
- debug ("is= cmd %x(%c) addr %p ", cmd, cmd, addr); + debug("is= cmd %x(%c) addr %p ", cmd, cmd, addr); switch (info->portwidth) { case FLASH_CFI_8BIT: - debug ("is= %x %x\n", flash_read8(addr), cword.w8); + debug("is= %x %x\n", flash_read8(addr), cword.w8); retval = (flash_read8(addr) == cword.w8); break; case FLASH_CFI_16BIT: - debug ("is= %4.4x %4.4x\n", flash_read16(addr), cword.w16); + debug("is= %4.4x %4.4x\n", flash_read16(addr), cword.w16); retval = (flash_read16(addr) == cword.w16); break; case FLASH_CFI_32BIT: - debug ("is= %8.8x %8.8x\n", flash_read32(addr), cword.w32); + debug("is= %8.8x %8.8x\n", flash_read32(addr), cword.w32); retval = (flash_read32(addr) == cword.w32); break; case FLASH_CFI_64BIT: @@ -440,9 +440,9 @@ static int flash_isequal (flash_info_t * info, flash_sect_t sect, char str1[20]; char str2[20];
- print_longlong (str1, flash_read64(addr)); - print_longlong (str2, cword.w64); - debug ("is= %s %s\n", str1, str2); + print_longlong(str1, flash_read64(addr)); + print_longlong(str2, cword.w64); + debug("is= %s %s\n", str1, str2); } #endif retval = (flash_read64(addr) == cword.w64); @@ -458,15 +458,15 @@ static int flash_isequal (flash_info_t * info, flash_sect_t sect,
/*----------------------------------------------------------------------- */ -static int flash_isset (flash_info_t * info, flash_sect_t sect, +static int flash_isset(flash_info_t * info, flash_sect_t sect, uint offset, uchar cmd) { void *addr; cfiword_t cword; int retval;
- addr = flash_map (info, sect, offset); - flash_make_cmd (info, cmd, &cword); + addr = flash_map(info, sect, offset); + flash_make_cmd(info, cmd, &cword); switch (info->portwidth) { case FLASH_CFI_8BIT: retval = ((flash_read8(addr) & cword.w8) == cword.w8); @@ -491,15 +491,15 @@ static int flash_isset (flash_info_t * info, flash_sect_t sect,
/*----------------------------------------------------------------------- */ -static int flash_toggle (flash_info_t * info, flash_sect_t sect, +static int flash_toggle(flash_info_t * info, flash_sect_t sect, uint offset, uchar cmd) { void *addr; cfiword_t cword; int retval;
- addr = flash_map (info, sect, offset); - flash_make_cmd (info, cmd, &cword); + addr = flash_map(info, sect, offset); + flash_make_cmd(info, cmd, &cword); switch (info->portwidth) { case FLASH_CFI_8BIT: retval = flash_read8(addr) != flash_read8(addr); @@ -529,7 +529,7 @@ static int flash_toggle (flash_info_t * info, flash_sect_t sect, * This routine checks the status of the chip and returns true if the * chip is busy. */ -static int flash_is_busy (flash_info_t * info, flash_sect_t sect) +static int flash_is_busy(flash_info_t * info, flash_sect_t sect) { int retval;
@@ -537,7 +537,7 @@ static int flash_is_busy (flash_info_t * info, flash_sect_t sect) case CFI_CMDSET_INTEL_PROG_REGIONS: case CFI_CMDSET_INTEL_STANDARD: case CFI_CMDSET_INTEL_EXTENDED: - retval = !flash_isset (info, sect, 0, FLASH_STATUS_DONE); + retval = !flash_isset(info, sect, 0, FLASH_STATUS_DONE); break; case CFI_CMDSET_AMD_STANDARD: case CFI_CMDSET_AMD_EXTENDED: @@ -545,12 +545,12 @@ static int flash_is_busy (flash_info_t * info, flash_sect_t sect) case CFI_CMDSET_AMD_LEGACY: #endif if (info->sr_supported) { - flash_write_cmd (info, sect, info->addr_unlock1, + flash_write_cmd(info, sect, info->addr_unlock1, FLASH_CMD_READ_STATUS); - retval = !flash_isset (info, sect, 0, + retval = !flash_isset(info, sect, 0, FLASH_STATUS_DONE); } else { - retval = flash_toggle (info, sect, 0, + retval = flash_toggle(info, sect, 0, AMD_STATUS_TOGGLE); }
@@ -558,7 +558,7 @@ static int flash_is_busy (flash_info_t * info, flash_sect_t sect) default: retval = 0; } - debug ("flash_is_busy: %d\n", retval); + debug("flash_is_busy: %d\n", retval); return retval; }
@@ -566,7 +566,7 @@ static int flash_is_busy (flash_info_t * info, flash_sect_t sect) * wait for XSR.7 to be set. Time out with an error if it does not. * This routine does not set the flash to read-array mode. */ -static int flash_status_check (flash_info_t * info, flash_sect_t sector, +static int flash_status_check(flash_info_t * info, flash_sect_t sector, ulong tout, char *prompt) { ulong start; @@ -582,18 +582,18 @@ static int flash_status_check (flash_info_t * info, flash_sect_t sector, #ifdef CONFIG_SYS_LOW_RES_TIMER reset_timer(); #endif - start = get_timer (0); + start = get_timer(0); WATCHDOG_RESET(); - while (flash_is_busy (info, sector)) { - if (get_timer (start) > tout) { - printf ("Flash %s timeout at address %lx data %lx\n", + while (flash_is_busy(info, sector)) { + if (get_timer(start) > tout) { + printf("Flash %s timeout at address %lx data %lx\n", prompt, info->start[sector], - flash_read_long (info, sector, 0)); - flash_write_cmd (info, sector, 0, info->cmd_reset); + flash_read_long(info, sector, 0)); + flash_write_cmd(info, sector, 0, info->cmd_reset); udelay(1); return ERR_TIMOUT; } - udelay (1); /* also triggers watchdog */ + udelay(1); /* also triggers watchdog */ } return ERR_OK; } @@ -604,12 +604,12 @@ static int flash_status_check (flash_info_t * info, flash_sect_t sector, * * This routine sets the flash to read-array mode. */ -static int flash_full_status_check (flash_info_t * info, flash_sect_t sector, +static int flash_full_status_check(flash_info_t * info, flash_sect_t sector, ulong tout, char *prompt) { int retcode;
- retcode = flash_status_check (info, sector, tout, prompt); + retcode = flash_status_check(info, sector, tout, prompt); switch (info->vendor) { case CFI_CMDSET_INTEL_PROG_REGIONS: case CFI_CMDSET_INTEL_EXTENDED: @@ -617,27 +617,27 @@ static int flash_full_status_check (flash_info_t * info, flash_sect_t sector, if ((retcode == ERR_OK) && !flash_isset(info, sector, 0, FLASH_STATUS_DONE)) { retcode = ERR_INVAL; - printf ("Flash %s error at address %lx\n", prompt, + printf("Flash %s error at address %lx\n", prompt, info->start[sector]); - if (flash_isset (info, sector, 0, FLASH_STATUS_ECLBS | + if (flash_isset(info, sector, 0, FLASH_STATUS_ECLBS | FLASH_STATUS_PSLBS)) { - puts ("Command Sequence Error.\n"); - } else if (flash_isset (info, sector, 0, + puts("Command Sequence Error.\n"); + } else if (flash_isset(info, sector, 0, FLASH_STATUS_ECLBS)) { - puts ("Block Erase Error.\n"); + puts("Block Erase Error.\n"); retcode = ERR_NOT_ERASED; - } else if (flash_isset (info, sector, 0, + } else if (flash_isset(info, sector, 0, FLASH_STATUS_PSLBS)) { - puts ("Locking Error\n"); + puts("Locking Error\n"); } - if (flash_isset (info, sector, 0, FLASH_STATUS_DPS)) { - puts ("Block locked.\n"); + if (flash_isset(info, sector, 0, FLASH_STATUS_DPS)) { + puts("Block locked.\n"); retcode = ERR_PROTECTED; } - if (flash_isset (info, sector, 0, FLASH_STATUS_VPENS)) - puts ("Vpp Low Error.\n"); + if (flash_isset(info, sector, 0, FLASH_STATUS_VPENS)) + puts("Vpp Low Error.\n"); } - flash_write_cmd (info, sector, 0, info->cmd_reset); + flash_write_cmd(info, sector, 0, info->cmd_reset); udelay(1); break; default: @@ -709,7 +709,7 @@ static int flash_status_poll(flash_info_t *info, void *src, void *dst,
/*----------------------------------------------------------------------- */ -static void flash_add_byte (flash_info_t * info, cfiword_t * cword, uchar c) +static void flash_add_byte(flash_info_t * info, cfiword_t * cword, uchar c) { #if defined(__LITTLE_ENDIAN) && !defined(CONFIG_SYS_WRITE_SWAPPED_DATA) unsigned short w; @@ -755,7 +755,7 @@ static void flash_add_byte (flash_info_t * info, cfiword_t * cword, uchar c) * Loop through the sector table starting from the previously found sector. * Searches forwards or backwards, dependent on the passed address. */ -static flash_sect_t find_sector (flash_info_t * info, ulong addr) +static flash_sect_t find_sector(flash_info_t * info, ulong addr) { static flash_sect_t saved_sector; /* previously found sector */ static flash_info_t *saved_info; /* previously used flash bank */ @@ -781,7 +781,7 @@ static flash_sect_t find_sector (flash_info_t * info, ulong addr)
/*----------------------------------------------------------------------- */ -static int flash_write_cfiword (flash_info_t * info, ulong dest, +static int flash_write_cfiword(flash_info_t * info, ulong dest, cfiword_t cword) { void *dstaddr = (void *)dest; @@ -811,27 +811,27 @@ static int flash_write_cfiword (flash_info_t * info, ulong dest, return ERR_NOT_ERASED;
/* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts (); + flag = disable_interrupts();
switch (info->vendor) { case CFI_CMDSET_INTEL_PROG_REGIONS: case CFI_CMDSET_INTEL_EXTENDED: case CFI_CMDSET_INTEL_STANDARD: - flash_write_cmd (info, 0, 0, FLASH_CMD_CLEAR_STATUS); - flash_write_cmd (info, 0, 0, FLASH_CMD_WRITE); + flash_write_cmd(info, 0, 0, FLASH_CMD_CLEAR_STATUS); + flash_write_cmd(info, 0, 0, FLASH_CMD_WRITE); break; case CFI_CMDSET_AMD_EXTENDED: case CFI_CMDSET_AMD_STANDARD: sect = find_sector(info, dest); - flash_unlock_seq (info, sect); - flash_write_cmd (info, sect, info->addr_unlock1, AMD_CMD_WRITE); + flash_unlock_seq(info, sect); + flash_write_cmd(info, sect, info->addr_unlock1, AMD_CMD_WRITE); sect_found = 1; break; #ifdef CONFIG_FLASH_CFI_LEGACY case CFI_CMDSET_AMD_LEGACY: sect = find_sector(info, dest); - flash_unlock_seq (info, 0); - flash_write_cmd (info, 0, info->addr_unlock1, AMD_CMD_WRITE); + flash_unlock_seq(info, 0); + flash_write_cmd(info, 0, info->addr_unlock1, AMD_CMD_WRITE); sect_found = 1; break; #endif @@ -854,10 +854,10 @@ static int flash_write_cfiword (flash_info_t * info, ulong dest,
/* re-enable interrupts if necessary */ if (flag) - enable_interrupts (); + enable_interrupts();
if (!sect_found) - sect = find_sector (info, dest); + sect = find_sector(info, dest);
if (use_flash_status_poll(info)) return flash_status_poll(info, &cword, dstaddr, @@ -869,7 +869,7 @@ static int flash_write_cfiword (flash_info_t * info, ulong dest,
#ifdef CONFIG_SYS_FLASH_USE_BUFFER_WRITE
-static int flash_write_cfibuffer (flash_info_t * info, ulong dest, uchar * cp, +static int flash_write_cfibuffer(flash_info_t * info, ulong dest, uchar * cp, int len) { flash_sect_t sector; @@ -933,7 +933,7 @@ static int flash_write_cfibuffer (flash_info_t * info, ulong dest, uchar * cp, }
src = cp; - sector = find_sector (info, dest); + sector = find_sector(info, dest);
switch (info->vendor) { case CFI_CMDSET_INTEL_PROG_REGIONS: @@ -941,17 +941,17 @@ static int flash_write_cfibuffer (flash_info_t * info, ulong dest, uchar * cp, case CFI_CMDSET_INTEL_EXTENDED: write_cmd = (info->vendor == CFI_CMDSET_INTEL_PROG_REGIONS) ? FLASH_CMD_WRITE_BUFFER_PROG : FLASH_CMD_WRITE_TO_BUFFER; - flash_write_cmd (info, sector, 0, FLASH_CMD_CLEAR_STATUS); - flash_write_cmd (info, sector, 0, FLASH_CMD_READ_STATUS); - flash_write_cmd (info, sector, 0, write_cmd); - retcode = flash_status_check (info, sector, + flash_write_cmd(info, sector, 0, FLASH_CMD_CLEAR_STATUS); + flash_write_cmd(info, sector, 0, FLASH_CMD_READ_STATUS); + flash_write_cmd(info, sector, 0, write_cmd); + retcode = flash_status_check(info, sector, info->buffer_write_tout, "write to buffer"); if (retcode == ERR_OK) { /* reduce the number of loops by the width of * the port */ cnt = len >> shift; - flash_write_cmd (info, sector, 0, cnt - 1); + flash_write_cmd(info, sector, 0, cnt - 1); while (cnt-- > 0) { switch (info->portwidth) { case FLASH_CFI_8BIT: @@ -975,9 +975,9 @@ static int flash_write_cfibuffer (flash_info_t * info, ulong dest, uchar * cp, goto out_unmap; } } - flash_write_cmd (info, sector, 0, + flash_write_cmd(info, sector, 0, FLASH_CMD_WRITE_BUFFER_CONFIRM); - retcode = flash_full_status_check ( + retcode = flash_full_status_check( info, sector, info->buffer_write_tout, "buffer write"); } @@ -1025,7 +1025,7 @@ static int flash_write_cfibuffer (flash_info_t * info, ulong dest, uchar * cp, goto out_unmap; }
- flash_write_cmd (info, sector, 0, AMD_CMD_WRITE_BUFFER_CONFIRM); + flash_write_cmd(info, sector, 0, AMD_CMD_WRITE_BUFFER_CONFIRM); if (use_flash_status_poll(info)) retcode = flash_status_poll(info, src - (1 << shift), dst - (1 << shift), @@ -1038,7 +1038,7 @@ static int flash_write_cfibuffer (flash_info_t * info, ulong dest, uchar * cp, break;
default: - debug ("Unknown Command Set\n"); + debug("Unknown Command Set\n"); retcode = ERR_INVAL; break; } @@ -1051,7 +1051,7 @@ out_unmap:
/*----------------------------------------------------------------------- */ -int flash_erase (flash_info_t * info, int s_first, int s_last) +int flash_erase(flash_info_t * info, int s_first, int s_last) { int rcode = 0; int prot; @@ -1059,11 +1059,11 @@ int flash_erase (flash_info_t * info, int s_first, int s_last) int st;
if (info->flash_id != FLASH_MAN_CFI) { - puts ("Can't erase unknown flash type - aborted\n"); + puts("Can't erase unknown flash type - aborted\n"); return 1; } if ((s_first < 0) || (s_first > s_last)) { - puts ("- no sectors to erase\n"); + puts("- no sectors to erase\n"); return 1; }
@@ -1074,10 +1074,10 @@ int flash_erase (flash_info_t * info, int s_first, int s_last) } } if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", + printf("- Warning: %d protected sectors will not be erased!\n", prot); } else if (flash_verbose) { - putc ('\n'); + putc('\n'); }
@@ -1118,35 +1118,35 @@ int flash_erase (flash_info_t * info, int s_first, int s_last) case CFI_CMDSET_INTEL_PROG_REGIONS: case CFI_CMDSET_INTEL_STANDARD: case CFI_CMDSET_INTEL_EXTENDED: - flash_write_cmd (info, sect, 0, + flash_write_cmd(info, sect, 0, FLASH_CMD_CLEAR_STATUS); - flash_write_cmd (info, sect, 0, + flash_write_cmd(info, sect, 0, FLASH_CMD_BLOCK_ERASE); - flash_write_cmd (info, sect, 0, + flash_write_cmd(info, sect, 0, FLASH_CMD_ERASE_CONFIRM); break; case CFI_CMDSET_AMD_STANDARD: case CFI_CMDSET_AMD_EXTENDED: - flash_unlock_seq (info, sect); - flash_write_cmd (info, sect, + flash_unlock_seq(info, sect); + flash_write_cmd(info, sect, info->addr_unlock1, AMD_CMD_ERASE_START); - flash_unlock_seq (info, sect); - flash_write_cmd (info, sect, 0, + flash_unlock_seq(info, sect); + flash_write_cmd(info, sect, 0, info->cmd_erase_sector); break; #ifdef CONFIG_FLASH_CFI_LEGACY case CFI_CMDSET_AMD_LEGACY: - flash_unlock_seq (info, 0); - flash_write_cmd (info, 0, info->addr_unlock1, + flash_unlock_seq(info, 0); + flash_write_cmd(info, 0, info->addr_unlock1, AMD_CMD_ERASE_START); - flash_unlock_seq (info, 0); - flash_write_cmd (info, sect, 0, + flash_unlock_seq(info, 0); + flash_write_cmd(info, sect, 0, AMD_CMD_ERASE_SECTOR); break; #endif default: - debug ("Unkown flash vendor %d\n", + debug("Unkown flash vendor %d\n", info->vendor); break; } @@ -1166,12 +1166,12 @@ int flash_erase (flash_info_t * info, int s_first, int s_last) if (st) rcode = 1; else if (flash_verbose) - putc ('.'); + putc('.'); } }
if (flash_verbose) - puts (" done\n"); + puts(" done\n");
return rcode; } @@ -1200,53 +1200,53 @@ static int sector_erased(flash_info_t *info, int i) } #endif /* CONFIG_SYS_FLASH_EMPTY_INFO */
-void flash_print_info (flash_info_t * info) +void flash_print_info(flash_info_t * info) { int i;
if (info->flash_id != FLASH_MAN_CFI) { - puts ("missing or unknown FLASH type\n"); + puts("missing or unknown FLASH type\n"); return; }
- printf ("%s flash (%d x %d)", + printf("%s flash (%d x %d)", info->name, (info->portwidth << 3), (info->chipwidth << 3)); if (info->size < 1024*1024) - printf (" Size: %ld kB in %d Sectors\n", + printf(" Size: %ld kB in %d Sectors\n", info->size >> 10, info->sector_count); else - printf (" Size: %ld MB in %d Sectors\n", + printf(" Size: %ld MB in %d Sectors\n", info->size >> 20, info->sector_count); - printf (" "); + printf(" "); switch (info->vendor) { case CFI_CMDSET_INTEL_PROG_REGIONS: - printf ("Intel Prog Regions"); + printf("Intel Prog Regions"); break; case CFI_CMDSET_INTEL_STANDARD: - printf ("Intel Standard"); + printf("Intel Standard"); break; case CFI_CMDSET_INTEL_EXTENDED: - printf ("Intel Extended"); + printf("Intel Extended"); break; case CFI_CMDSET_AMD_STANDARD: - printf ("AMD Standard"); + printf("AMD Standard"); break; case CFI_CMDSET_AMD_EXTENDED: - printf ("AMD Extended"); + printf("AMD Extended"); break; #ifdef CONFIG_FLASH_CFI_LEGACY case CFI_CMDSET_AMD_LEGACY: - printf ("AMD Legacy"); + printf("AMD Legacy"); break; #endif default: - printf ("Unknown (%d)", info->vendor); + printf("Unknown (%d)", info->vendor); break; } - printf (" command set, Manufacturer ID: 0x%02X, Device ID: 0x", + printf(" command set, Manufacturer ID: 0x%02X, Device ID: 0x", info->manufacturer_id); - printf (info->chipwidth == FLASH_CFI_16BIT ? "%04X" : "%02X", + printf(info->chipwidth == FLASH_CFI_16BIT ? "%04X" : "%02X", info->device_id); if ((info->device_id & 0xff) == 0x7E) { printf(info->chipwidth == FLASH_CFI_16BIT ? "%04X" : "%02X", @@ -1254,17 +1254,17 @@ void flash_print_info (flash_info_t * info) } if ((info->vendor == CFI_CMDSET_AMD_STANDARD) && (info->legacy_unlock)) printf("\n Advanced Sector Protection (PPB) enabled"); - printf ("\n Erase timeout: %ld ms, write timeout: %ld ms\n", + printf("\n Erase timeout: %ld ms, write timeout: %ld ms\n", info->erase_blk_tout, info->write_tout); if (info->buffer_size > 1) { - printf (" Buffer write timeout: %ld ms, " + printf(" Buffer write timeout: %ld ms, " "buffer size: %d bytes\n", info->buffer_write_tout, info->buffer_size); }
- puts ("\n Sector Start Addresses:"); + puts("\n Sector Start Addresses:"); for (i = 0; i < info->sector_count; ++i) { if (ctrlc()) break; @@ -1272,17 +1272,17 @@ void flash_print_info (flash_info_t * info) putc('\n'); #ifdef CONFIG_SYS_FLASH_EMPTY_INFO /* print empty and read-only info */ - printf (" %08lX %c %s ", + printf(" %08lX %c %s ", info->start[i], sector_erased(info, i) ? 'E' : ' ', info->protect[i] ? "RO" : " "); #else /* ! CONFIG_SYS_FLASH_EMPTY_INFO */ - printf (" %08lX %s ", + printf(" %08lX %s ", info->start[i], info->protect[i] ? "RO" : " "); #endif } - putc ('\n'); + putc('\n'); return; }
@@ -1298,9 +1298,9 @@ void flash_print_info (flash_info_t * info) dots -= dots_sub; \ if ((scale > 0) && (dots <= 0)) { \ if ((digit % 5) == 0) \ - printf ("%d", digit / 5); \ + printf("%d", digit / 5); \ else \ - putc ('.'); \ + putc('.'); \ digit--; \ dots += scale; \ } \ @@ -1315,7 +1315,7 @@ void flash_print_info (flash_info_t * info) * 1 - write timeout * 2 - Flash not erased */ -int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt) +int write_buff(flash_info_t * info, uchar * src, ulong addr, ulong cnt) { ulong wp; uchar *p; @@ -1347,16 +1347,16 @@ int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt) cword.w32 = 0; p = (uchar *)wp; for (i = 0; i < aln; ++i) - flash_add_byte (info, &cword, flash_read8(p + i)); + flash_add_byte(info, &cword, flash_read8(p + i));
for (; (i < info->portwidth) && (cnt > 0); i++) { - flash_add_byte (info, &cword, *src++); + flash_add_byte(info, &cword, *src++); cnt--; } for (; (cnt == 0) && (i < info->portwidth); ++i) - flash_add_byte (info, &cword, flash_read8(p + i)); + flash_add_byte(info, &cword, flash_read8(p + i));
- rc = flash_write_cfiword (info, wp, cword); + rc = flash_write_cfiword(info, wp, cword); if (rc != 0) return rc;
@@ -1373,8 +1373,8 @@ int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt) if (info->buffer_size == 1) { cword.w32 = 0; for (i = 0; i < info->portwidth; i++) - flash_add_byte (info, &cword, *src++); - if ((rc = flash_write_cfiword (info, wp, cword)) != 0) + flash_add_byte(info, &cword, *src++); + if ((rc = flash_write_cfiword(info, wp, cword)) != 0) return rc; wp += info->portwidth; cnt -= info->portwidth; @@ -1385,7 +1385,7 @@ int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt) i = buffered_size - (wp % buffered_size); if (i > cnt) i = cnt; - if ((rc = flash_write_cfibuffer (info, wp, src, i)) != ERR_OK) + if ((rc = flash_write_cfibuffer(info, wp, src, i)) != ERR_OK) return rc; i -= i & (info->portwidth - 1); wp += i; @@ -1400,9 +1400,9 @@ int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt) while (cnt >= info->portwidth) { cword.w32 = 0; for (i = 0; i < info->portwidth; i++) { - flash_add_byte (info, &cword, *src++); + flash_add_byte(info, &cword, *src++); } - if ((rc = flash_write_cfiword (info, wp, cword)) != 0) + if ((rc = flash_write_cfiword(info, wp, cword)) != 0) return rc; wp += info->portwidth; cnt -= info->portwidth; @@ -1423,13 +1423,13 @@ int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt) cword.w32 = 0; p = (uchar *)wp; for (i = 0; (i < info->portwidth) && (cnt > 0); ++i) { - flash_add_byte (info, &cword, *src++); + flash_add_byte(info, &cword, *src++); --cnt; } for (; i < info->portwidth; ++i) - flash_add_byte (info, &cword, flash_read8(p + i)); + flash_add_byte(info, &cword, flash_read8(p + i));
- return flash_write_cfiword (info, wp, cword); + return flash_write_cfiword(info, wp, cword); }
static inline int manufact_match(flash_info_t *info, u32 manu) @@ -1475,7 +1475,7 @@ static int cfi_protect_bugfix(flash_info_t *info, long sector, int prot) return 0; }
-int flash_real_protect (flash_info_t * info, long sector, int prot) +int flash_real_protect(flash_info_t * info, long sector, int prot) { int retcode = 0;
@@ -1502,19 +1502,19 @@ int flash_real_protect (flash_info_t * info, long sector, int prot) /* U-Boot only checks the first byte */ if (manufact_match(info, ATM_MANUFACT)) { if (prot) { - flash_unlock_seq (info, 0); - flash_write_cmd (info, 0, + flash_unlock_seq(info, 0); + flash_write_cmd(info, 0, info->addr_unlock1, ATM_CMD_SOFTLOCK_START); - flash_unlock_seq (info, 0); - flash_write_cmd (info, sector, 0, + flash_unlock_seq(info, 0); + flash_write_cmd(info, sector, 0, ATM_CMD_LOCK_SECT); } else { - flash_write_cmd (info, 0, + flash_write_cmd(info, 0, info->addr_unlock1, AMD_CMD_UNLOCK_START); if (info->device_id == ATM_ID_BV6416) - flash_write_cmd (info, sector, + flash_write_cmd(info, sector, 0, ATM_CMD_UNLOCK_SECT); } } @@ -1562,12 +1562,12 @@ int flash_real_protect (flash_info_t * info, long sector, int prot) break; #ifdef CONFIG_FLASH_CFI_LEGACY case CFI_CMDSET_AMD_LEGACY: - flash_write_cmd (info, sector, 0, FLASH_CMD_CLEAR_STATUS); - flash_write_cmd (info, sector, 0, FLASH_CMD_PROTECT); + flash_write_cmd(info, sector, 0, FLASH_CMD_CLEAR_STATUS); + flash_write_cmd(info, sector, 0, FLASH_CMD_PROTECT); if (prot) - flash_write_cmd (info, sector, 0, FLASH_CMD_PROTECT_SET); + flash_write_cmd(info, sector, 0, FLASH_CMD_PROTECT_SET); else - flash_write_cmd (info, sector, 0, FLASH_CMD_PROTECT_CLEAR); + flash_write_cmd(info, sector, 0, FLASH_CMD_PROTECT_CLEAR); #endif };
@@ -1577,7 +1577,7 @@ int flash_real_protect (flash_info_t * info, long sector, int prot) */ flash_write_cmd(info, sector, 0, FLASH_CMD_READ_STATUS); if ((retcode = - flash_full_status_check (info, sector, info->erase_blk_tout, + flash_full_status_check(info, sector, info->erase_blk_tout, prot ? "protect" : "unprotect")) == 0) {
info->protect[sector] = prot; @@ -1591,7 +1591,7 @@ int flash_real_protect (flash_info_t * info, long sector, int prot)
for (i = 0; i < info->sector_count; i++) { if (info->protect[i]) - flash_real_protect (info, i, 1); + flash_real_protect(info, i, 1); } } } @@ -1601,17 +1601,17 @@ int flash_real_protect (flash_info_t * info, long sector, int prot) /*----------------------------------------------------------------------- * flash_read_user_serial - read the OneTimeProgramming cells */ -void flash_read_user_serial (flash_info_t * info, void *buffer, int offset, +void flash_read_user_serial(flash_info_t * info, void *buffer, int offset, int len) { uchar *src; uchar *dst;
dst = buffer; - src = flash_map (info, 0, FLASH_OFFSET_USER_PROTECTION); - flash_write_cmd (info, 0, 0, FLASH_CMD_READ_ID); - memcpy (dst, src + offset, len); - flash_write_cmd (info, 0, 0, info->cmd_reset); + src = flash_map(info, 0, FLASH_OFFSET_USER_PROTECTION); + flash_write_cmd(info, 0, 0, FLASH_CMD_READ_ID); + memcpy(dst, src + offset, len); + flash_write_cmd(info, 0, 0, info->cmd_reset); udelay(1); flash_unmap(info, 0, FLASH_OFFSET_USER_PROTECTION, src); } @@ -1619,15 +1619,15 @@ void flash_read_user_serial (flash_info_t * info, void *buffer, int offset, /* * flash_read_factory_serial - read the device Id from the protection area */ -void flash_read_factory_serial (flash_info_t * info, void *buffer, int offset, +void flash_read_factory_serial(flash_info_t * info, void *buffer, int offset, int len) { uchar *src;
- src = flash_map (info, 0, FLASH_OFFSET_INTEL_PROTECTION); - flash_write_cmd (info, 0, 0, FLASH_CMD_READ_ID); - memcpy (buffer, src + offset, len); - flash_write_cmd (info, 0, 0, info->cmd_reset); + src = flash_map(info, 0, FLASH_OFFSET_INTEL_PROTECTION); + flash_write_cmd(info, 0, 0, FLASH_CMD_READ_ID); + memcpy(buffer, src + offset, len); + flash_write_cmd(info, 0, 0, info->cmd_reset); udelay(1); flash_unmap(info, 0, FLASH_OFFSET_INTEL_PROTECTION, src); } @@ -1664,11 +1664,11 @@ static void cmdset_intel_read_jedec_ids(flash_info_t *info) udelay(1); flash_write_cmd(info, 0, 0, FLASH_CMD_READ_ID); udelay(1000); /* some flash are slow to respond */ - info->manufacturer_id = flash_read_uchar (info, + info->manufacturer_id = flash_read_uchar(info, FLASH_OFFSET_MANUFACTURER_ID); info->device_id = (info->chipwidth == FLASH_CFI_16BIT) ? - flash_read_word (info, FLASH_OFFSET_DEVICE_ID) : - flash_read_uchar (info, FLASH_OFFSET_DEVICE_ID); + flash_read_word(info, FLASH_OFFSET_DEVICE_ID) : + flash_read_uchar(info, FLASH_OFFSET_DEVICE_ID); flash_write_cmd(info, 0, 0, FLASH_CMD_RESET); }
@@ -1682,7 +1682,7 @@ static int cmdset_intel_init(flash_info_t *info, struct cfi_qry *qry) #ifdef CONFIG_SYS_FLASH_PROTECTION /* read legacy lock/unlock bit from intel flash */ if (info->ext_addr) { - info->legacy_unlock = flash_read_uchar (info, + info->legacy_unlock = flash_read_uchar(info, info->ext_addr + 5) & 0x08; } #endif @@ -1701,11 +1701,11 @@ static void cmdset_amd_read_jedec_ids(flash_info_t *info) flash_write_cmd(info, 0, info->addr_unlock1, FLASH_CMD_READ_ID); udelay(1000); /* some flash are slow to respond */
- manuId = flash_read_uchar (info, FLASH_OFFSET_MANUFACTURER_ID); + manuId = flash_read_uchar(info, FLASH_OFFSET_MANUFACTURER_ID); /* JEDEC JEP106Z specifies ID codes up to bank 7 */ while (manuId == FLASH_CONTINUATION_CODE && bankId < 0x800) { bankId += 0x100; - manuId = flash_read_uchar (info, + manuId = flash_read_uchar(info, bankId | FLASH_OFFSET_MANUFACTURER_ID); } info->manufacturer_id = manuId; @@ -1721,26 +1721,26 @@ static void cmdset_amd_read_jedec_ids(flash_info_t *info)
switch (info->chipwidth){ case FLASH_CFI_8BIT: - info->device_id = flash_read_uchar (info, + info->device_id = flash_read_uchar(info, FLASH_OFFSET_DEVICE_ID); if (info->device_id == 0x7E) { /* AMD 3-byte (expanded) device ids */ - info->device_id2 = flash_read_uchar (info, + info->device_id2 = flash_read_uchar(info, FLASH_OFFSET_DEVICE_ID2); info->device_id2 <<= 8; - info->device_id2 |= flash_read_uchar (info, + info->device_id2 |= flash_read_uchar(info, FLASH_OFFSET_DEVICE_ID3); } break; case FLASH_CFI_16BIT: - info->device_id = flash_read_word (info, + info->device_id = flash_read_word(info, FLASH_OFFSET_DEVICE_ID); if ((info->device_id & 0xff) == 0x7E) { /* AMD 3-byte (expanded) device ids */ - info->device_id2 = flash_read_uchar (info, + info->device_id2 = flash_read_uchar(info, FLASH_OFFSET_DEVICE_ID2); info->device_id2 <<= 8; - info->device_id2 |= flash_read_uchar (info, + info->device_id2 |= flash_read_uchar(info, FLASH_OFFSET_DEVICE_ID3); } break; @@ -1771,7 +1771,7 @@ static int cmdset_amd_init(flash_info_t *info, struct cfi_qry *qry) }
#ifdef CONFIG_FLASH_CFI_LEGACY -static void flash_read_jedec_ids (flash_info_t * info) +static void flash_read_jedec_ids(flash_info_t * info) { info->manufacturer_id = 0; info->device_id = 0; @@ -1866,7 +1866,7 @@ static inline int flash_detect_legacy(phys_addr_t base, int banknum) * detect if flash is compatible with the Common Flash Interface (CFI) * http://www.jedec.org/download/search/jesd68.pdf */ -static void flash_read_cfi (flash_info_t *info, void *buf, +static void flash_read_cfi(flash_info_t *info, void *buf, unsigned int start, size_t len) { u8 *p = buf; @@ -1890,7 +1890,7 @@ static void __flash_cmd_reset(flash_info_t *info) void flash_cmd_reset(flash_info_t *info) __attribute__((weak,alias("__flash_cmd_reset")));
-static int __flash_detect_cfi (flash_info_t * info, struct cfi_qry *qry) +static int __flash_detect_cfi(flash_info_t * info, struct cfi_qry *qry) { int cfi_offset;
@@ -1899,21 +1899,21 @@ static int __flash_detect_cfi (flash_info_t * info, struct cfi_qry *qry)
for (cfi_offset = 0; cfi_offset < ARRAY_SIZE(flash_offset_cfi); cfi_offset++) { - flash_write_cmd (info, 0, flash_offset_cfi[cfi_offset], + flash_write_cmd(info, 0, flash_offset_cfi[cfi_offset], FLASH_CMD_CFI); - if (flash_isequal (info, 0, FLASH_OFFSET_CFI_RESP, 'Q') - && flash_isequal (info, 0, FLASH_OFFSET_CFI_RESP + 1, 'R') - && flash_isequal (info, 0, FLASH_OFFSET_CFI_RESP + 2, 'Y')) { + if (flash_isequal(info, 0, FLASH_OFFSET_CFI_RESP, 'Q') + && flash_isequal(info, 0, FLASH_OFFSET_CFI_RESP + 1, 'R') + && flash_isequal(info, 0, FLASH_OFFSET_CFI_RESP + 2, 'Y')) { flash_read_cfi(info, qry, FLASH_OFFSET_CFI_RESP, sizeof(struct cfi_qry)); info->interface = le16_to_cpu(qry->interface_desc);
info->cfi_offset = flash_offset_cfi[cfi_offset]; - debug ("device interface is %d\n", + debug("device interface is %d\n", info->interface); - debug ("found port %d chip %d ", + debug("found port %d chip %d ", info->portwidth, info->chipwidth); - debug ("port %d bits chip %d bits\n", + debug("port %d bits chip %d bits\n", info->portwidth << CFI_FLASH_SHIFT_WIDTH, info->chipwidth << CFI_FLASH_SHIFT_WIDTH);
@@ -1944,9 +1944,9 @@ static int __flash_detect_cfi (flash_info_t * info, struct cfi_qry *qry) return 0; }
-static int flash_detect_cfi (flash_info_t * info, struct cfi_qry *qry) +static int flash_detect_cfi(flash_info_t * info, struct cfi_qry *qry) { - debug ("flash detect cfi\n"); + debug("flash detect cfi\n");
for (info->portwidth = CONFIG_SYS_FLASH_CFI_WIDTH; info->portwidth <= FLASH_CFI_64BIT; info->portwidth <<= 1) { @@ -1956,7 +1956,7 @@ static int flash_detect_cfi (flash_info_t * info, struct cfi_qry *qry) if (__flash_detect_cfi(info, qry)) return 1; } - debug ("not found\n"); + debug("not found\n"); return 0; }
@@ -2063,7 +2063,7 @@ static void flash_fixup_num(flash_info_t *info, struct cfi_qry *qry) * The following code cannot be run from FLASH! * */ -ulong flash_get_size (phys_addr_t base, int banknum) +ulong flash_get_size(phys_addr_t base, int banknum) { flash_info_t *info = &flash_info[banknum]; int i, j; @@ -2087,20 +2087,20 @@ ulong flash_get_size (phys_addr_t base, int banknum)
info->start[0] = (ulong)map_physmem(base, info->portwidth, MAP_NOCACHE);
- if (flash_detect_cfi (info, &qry)) { + if (flash_detect_cfi(info, &qry)) { info->vendor = le16_to_cpu(get_unaligned(&(qry.p_id))); info->ext_addr = le16_to_cpu(get_unaligned(&(qry.p_adr))); num_erase_regions = qry.num_erase_regions;
if (info->ext_addr) { - info->cfi_version = (ushort) flash_read_uchar (info, + info->cfi_version = (ushort) flash_read_uchar(info, info->ext_addr + 3) << 8; - info->cfi_version |= (ushort) flash_read_uchar (info, + info->cfi_version |= (ushort) flash_read_uchar(info, info->ext_addr + 4); }
#ifdef DEBUG - flash_printqry (&qry); + flash_printqry(&qry); #endif
switch (info->vendor) { @@ -2145,11 +2145,11 @@ ulong flash_get_size (phys_addr_t base, int banknum) break; }
- debug ("manufacturer is %d\n", info->vendor); - debug ("manufacturer id is 0x%x\n", info->manufacturer_id); - debug ("device id is 0x%x\n", info->device_id); - debug ("device id2 is 0x%x\n", info->device_id2); - debug ("cfi version is 0x%04x\n", info->cfi_version); + debug("manufacturer is %d\n", info->vendor); + debug("manufacturer id is 0x%x\n", info->manufacturer_id); + debug("device id is 0x%x\n", info->device_id); + debug("device id2 is 0x%x\n", info->device_id2); + debug("cfi version is 0x%04x\n", info->cfi_version);
size_ratio = info->portwidth / info->chipwidth; /* if the chip is x8/x16 reduce the ratio by half */ @@ -2157,7 +2157,7 @@ ulong flash_get_size (phys_addr_t base, int banknum) && (info->chipwidth == FLASH_CFI_BY8)) { size_ratio >>= 1; } - debug ("size_ratio %d port %d bits chip %d bits\n", + debug("size_ratio %d port %d bits chip %d bits\n", size_ratio, info->portwidth << CFI_FLASH_SHIFT_WIDTH, info->chipwidth << CFI_FLASH_SHIFT_WIDTH); info->size = 1 << qry.dev_size; @@ -2168,12 +2168,12 @@ ulong flash_get_size (phys_addr_t base, int banknum) debug("[truncated from %ldMiB]", info->size >> 20); info->size = max_size; } - debug ("found %d erase regions\n", num_erase_regions); + debug("found %d erase regions\n", num_erase_regions); sect_cnt = 0; sector = base; for (i = 0; i < num_erase_regions; i++) { if (i > NUM_ERASE_REGIONS) { - printf ("%d erase regions found, only %d used\n", + printf("%d erase regions found, only %d used\n", num_erase_regions, NUM_ERASE_REGIONS); break; } @@ -2186,7 +2186,7 @@ ulong flash_get_size (phys_addr_t base, int banknum) tmp >>= 16; erase_region_size = (tmp & 0xffff) ? ((tmp & 0xffff) * 256) : 128; - debug ("erase_region_count = %d erase_region_size = %d\n", + debug("erase_region_count = %d erase_region_size = %d\n", erase_region_count, erase_region_size); for (j = 0; j < erase_region_count; j++) { if (sector - base >= info->size) @@ -2217,7 +2217,7 @@ ulong flash_get_size (phys_addr_t base, int banknum) flash_write_cmd(info, sect_cnt, 0, FLASH_CMD_READ_ID); info->protect[sect_cnt] = - flash_isset (info, sect_cnt, + flash_isset(info, sect_cnt, FLASH_OFFSET_PROTECT, FLASH_STATUS_PROTECT); flash_write_cmd(info, sect_cnt, 0, @@ -2274,7 +2274,7 @@ ulong flash_get_size (phys_addr_t base, int banknum) info->portwidth >>= 1; }
- flash_write_cmd (info, 0, 0, info->cmd_reset); + flash_write_cmd(info, 0, 0, info->cmd_reset); }
return (info->size); @@ -2362,7 +2362,7 @@ static void flash_protect_default(void) #endif }
-unsigned long flash_init (void) +unsigned long flash_init(void) { unsigned long size = 0; int i; @@ -2390,7 +2390,7 @@ unsigned long flash_init (void) size += flash_info[i].size; if (flash_info[i].flash_id == FLASH_UNKNOWN) { #ifndef CONFIG_SYS_FLASH_QUIET_TEST - printf ("## Unknown flash on Bank %d " + printf("## Unknown flash on Bank %d " "- Size = 0x%08lx = %ld MB\n", i+1, flash_info[i].size, flash_info[i].size >> 20); @@ -2422,7 +2422,7 @@ unsigned long flash_init (void) * unlock only one sector. This will * unlock all sectors. */ - flash_real_protect (&flash_info[i], 0, 0); + flash_real_protect(&flash_info[i], 0, 0);
flash_info[i].legacy_unlock = 1;
@@ -2436,7 +2436,7 @@ unsigned long flash_init (void) /* * No legancy unlocking -> unlock all sectors */ - flash_protect (FLAG_PROTECT_CLEAR, + flash_protect(FLAG_PROTECT_CLEAR, flash_info[i].start[0], flash_info[i].start[0] + flash_info[i].size - 1, -- 2.11.0
v1 -> v2: None
--- drivers/mtd/cfi_flash.c | 48 ++++++++++++++++++++++++------------------------ 1 file changed, 24 insertions(+), 24 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 0dc7f4a6ba..a1b217cc0c 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -204,7 +204,7 @@ unsigned long flash_sector_size(flash_info_t *info, flash_sect_t sect) * create an address based on the offset and the port width */ static inline void * -flash_map(flash_info_t * info, flash_sect_t sect, uint offset) +flash_map(flash_info_t *info, flash_sect_t sect, uint offset) { unsigned int byte_offset = offset * info->portwidth;
@@ -283,7 +283,7 @@ static void flash_printqry(struct cfi_qry *qry) /*----------------------------------------------------------------------- * read a character at a port width address */ -static inline uchar flash_read_uchar(flash_info_t * info, uint offset) +static inline uchar flash_read_uchar(flash_info_t *info, uint offset) { uchar *cp; uchar retval; @@ -301,7 +301,7 @@ static inline uchar flash_read_uchar(flash_info_t * info, uint offset) /*----------------------------------------------------------------------- * read a word at a port width address, assume 16bit bus */ -static inline ushort flash_read_word(flash_info_t * info, uint offset) +static inline ushort flash_read_word(flash_info_t *info, uint offset) { ushort *addr, retval;
@@ -316,7 +316,7 @@ static inline ushort flash_read_word(flash_info_t * info, uint offset) * read a long word by picking the least significant byte of each maximum * port size word. Swap for ppc format. */ -static ulong flash_read_long (flash_info_t * info, flash_sect_t sect, +static ulong flash_read_long (flash_info_t *info, flash_sect_t sect, uint offset) { uchar *addr; @@ -402,7 +402,7 @@ static void flash_write_cmd(flash_info_t *info, flash_sect_t sect, flash_unmap(info, sect, offset, addr); }
-static void flash_unlock_seq(flash_info_t * info, flash_sect_t sect) +static void flash_unlock_seq(flash_info_t *info, flash_sect_t sect) { flash_write_cmd(info, sect, info->addr_unlock1, AMD_CMD_UNLOCK_START); flash_write_cmd(info, sect, info->addr_unlock2, AMD_CMD_UNLOCK_ACK); @@ -410,7 +410,7 @@ static void flash_unlock_seq(flash_info_t * info, flash_sect_t sect)
/*----------------------------------------------------------------------- */ -static int flash_isequal(flash_info_t * info, flash_sect_t sect, +static int flash_isequal(flash_info_t *info, flash_sect_t sect, uint offset, uchar cmd) { void *addr; @@ -458,7 +458,7 @@ static int flash_isequal(flash_info_t * info, flash_sect_t sect,
/*----------------------------------------------------------------------- */ -static int flash_isset(flash_info_t * info, flash_sect_t sect, +static int flash_isset(flash_info_t *info, flash_sect_t sect, uint offset, uchar cmd) { void *addr; @@ -491,7 +491,7 @@ static int flash_isset(flash_info_t * info, flash_sect_t sect,
/*----------------------------------------------------------------------- */ -static int flash_toggle(flash_info_t * info, flash_sect_t sect, +static int flash_toggle(flash_info_t *info, flash_sect_t sect, uint offset, uchar cmd) { void *addr; @@ -529,7 +529,7 @@ static int flash_toggle(flash_info_t * info, flash_sect_t sect, * This routine checks the status of the chip and returns true if the * chip is busy. */ -static int flash_is_busy(flash_info_t * info, flash_sect_t sect) +static int flash_is_busy(flash_info_t *info, flash_sect_t sect) { int retval;
@@ -566,7 +566,7 @@ static int flash_is_busy(flash_info_t * info, flash_sect_t sect) * wait for XSR.7 to be set. Time out with an error if it does not. * This routine does not set the flash to read-array mode. */ -static int flash_status_check(flash_info_t * info, flash_sect_t sector, +static int flash_status_check(flash_info_t *info, flash_sect_t sector, ulong tout, char *prompt) { ulong start; @@ -604,7 +604,7 @@ static int flash_status_check(flash_info_t * info, flash_sect_t sector, * * This routine sets the flash to read-array mode. */ -static int flash_full_status_check(flash_info_t * info, flash_sect_t sector, +static int flash_full_status_check(flash_info_t *info, flash_sect_t sector, ulong tout, char *prompt) { int retcode; @@ -709,7 +709,7 @@ static int flash_status_poll(flash_info_t *info, void *src, void *dst,
/*----------------------------------------------------------------------- */ -static void flash_add_byte(flash_info_t * info, cfiword_t * cword, uchar c) +static void flash_add_byte(flash_info_t *info, cfiword_t *cword, uchar c) { #if defined(__LITTLE_ENDIAN) && !defined(CONFIG_SYS_WRITE_SWAPPED_DATA) unsigned short w; @@ -755,7 +755,7 @@ static void flash_add_byte(flash_info_t * info, cfiword_t * cword, uchar c) * Loop through the sector table starting from the previously found sector. * Searches forwards or backwards, dependent on the passed address. */ -static flash_sect_t find_sector(flash_info_t * info, ulong addr) +static flash_sect_t find_sector(flash_info_t *info, ulong addr) { static flash_sect_t saved_sector; /* previously found sector */ static flash_info_t *saved_info; /* previously used flash bank */ @@ -781,7 +781,7 @@ static flash_sect_t find_sector(flash_info_t * info, ulong addr)
/*----------------------------------------------------------------------- */ -static int flash_write_cfiword(flash_info_t * info, ulong dest, +static int flash_write_cfiword(flash_info_t *info, ulong dest, cfiword_t cword) { void *dstaddr = (void *)dest; @@ -869,7 +869,7 @@ static int flash_write_cfiword(flash_info_t * info, ulong dest,
-static int flash_write_cfibuffer(flash_info_t * info, ulong dest, uchar * cp, +static int flash_write_cfibuffer(flash_info_t *info, ulong dest, uchar *cp, int len) { flash_sect_t sector; @@ -1051,7 +1051,7 @@ out_unmap:
/*----------------------------------------------------------------------- */ -int flash_erase(flash_info_t * info, int s_first, int s_last) +int flash_erase(flash_info_t *info, int s_first, int s_last) { int rcode = 0; int prot; @@ -1200,7 +1200,7 @@ static int sector_erased(flash_info_t *info, int i) } #endif /* CONFIG_SYS_FLASH_EMPTY_INFO */
-void flash_print_info(flash_info_t * info) +void flash_print_info(flash_info_t *info) { int i;
@@ -1315,7 +1315,7 @@ void flash_print_info(flash_info_t * info) * 1 - write timeout * 2 - Flash not erased */ -int write_buff(flash_info_t * info, uchar * src, ulong addr, ulong cnt) +int write_buff(flash_info_t *info, uchar *src, ulong addr, ulong cnt) { ulong wp; uchar *p; @@ -1475,7 +1475,7 @@ static int cfi_protect_bugfix(flash_info_t *info, long sector, int prot) return 0; }
-int flash_real_protect(flash_info_t * info, long sector, int prot) +int flash_real_protect(flash_info_t *info, long sector, int prot) { int retcode = 0;
@@ -1601,7 +1601,7 @@ int flash_real_protect(flash_info_t * info, long sector, int prot) /*----------------------------------------------------------------------- * flash_read_user_serial - read the OneTimeProgramming cells */ -void flash_read_user_serial(flash_info_t * info, void *buffer, int offset, +void flash_read_user_serial(flash_info_t *info, void *buffer, int offset, int len) { uchar *src; @@ -1619,7 +1619,7 @@ void flash_read_user_serial(flash_info_t * info, void *buffer, int offset, /* * flash_read_factory_serial - read the device Id from the protection area */ -void flash_read_factory_serial(flash_info_t * info, void *buffer, int offset, +void flash_read_factory_serial(flash_info_t *info, void *buffer, int offset, int len) { uchar *src; @@ -1771,7 +1771,7 @@ static int cmdset_amd_init(flash_info_t *info, struct cfi_qry *qry) }
#ifdef CONFIG_FLASH_CFI_LEGACY -static void flash_read_jedec_ids(flash_info_t * info) +static void flash_read_jedec_ids(flash_info_t *info) { info->manufacturer_id = 0; info->device_id = 0; @@ -1890,7 +1890,7 @@ static void __flash_cmd_reset(flash_info_t *info) void flash_cmd_reset(flash_info_t *info) __attribute__((weak,alias("__flash_cmd_reset")));
-static int __flash_detect_cfi(flash_info_t * info, struct cfi_qry *qry) +static int __flash_detect_cfi(flash_info_t *info, struct cfi_qry *qry) { int cfi_offset;
@@ -1944,7 +1944,7 @@ static int __flash_detect_cfi(flash_info_t * info, struct cfi_qry *qry) return 0; }
-static int flash_detect_cfi(flash_info_t * info, struct cfi_qry *qry) +static int flash_detect_cfi(flash_info_t *info, struct cfi_qry *qry) { debug("flash detect cfi\n");
-- 2.11.0
v1 -> v2: None
--- drivers/mtd/cfi_flash.c | 22 +++++++++++----------- 1 file changed, 11 insertions(+), 11 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index a1b217cc0c..e8f1739254 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -230,7 +230,7 @@ static void flash_make_cmd(flash_info_t *info, u32 cmd, void *cmdbuf) uchar val; uchar *cp = (uchar *) cmdbuf;
- for (i = info->portwidth; i > 0; i--){ + for (i = info->portwidth; i > 0; i--) { cword_offset = (info->portwidth-i)%info->chipwidth; #if defined(__LITTLE_ENDIAN) || defined(CONFIG_SYS_WRITE_SWAPPED_DATA) cp_offset = info->portwidth - i; @@ -511,8 +511,8 @@ static int flash_toggle(flash_info_t *info, flash_sect_t sect, retval = flash_read32(addr) != flash_read32(addr); break; case FLASH_CFI_64BIT: - retval = ( (flash_read32( addr ) != flash_read32( addr )) || - (flash_read32(addr+4) != flash_read32(addr+4)) ); + retval = ((flash_read32(addr) != flash_read32(addr)) || + (flash_read32(addr+4) != flash_read32(addr+4))); break; default: retval = 0; @@ -1719,7 +1719,7 @@ static void cmdset_amd_read_jedec_ids(flash_info_t *info) info->sr_supported = feature & 0x1; }
- switch (info->chipwidth){ + switch (info->chipwidth) { case FLASH_CFI_8BIT: info->device_id = flash_read_uchar(info, FLASH_OFFSET_DEVICE_ID); @@ -1838,7 +1838,7 @@ static int flash_detect_legacy(phys_addr_t base, int banknum) } }
- switch(info->vendor) { + switch (info->vendor) { case CFI_CMDSET_INTEL_PROG_REGIONS: case CFI_CMDSET_INTEL_STANDARD: case CFI_CMDSET_INTEL_EXTENDED: @@ -1925,12 +1925,12 @@ static int __flash_detect_cfi(flash_info_t *info, struct cfi_qry *qry) * modify the unlock address if we are * in compatibility mode */ - if ( /* x8/x16 in x8 mode */ - ((info->chipwidth == FLASH_CFI_BY8) && - (info->interface == FLASH_CFI_X8X16)) || - /* x16/x32 in x16 mode */ - ((info->chipwidth == FLASH_CFI_BY16) && - (info->interface == FLASH_CFI_X16X32))) + if (/* x8/x16 in x8 mode */ + ((info->chipwidth == FLASH_CFI_BY8) && + (info->interface == FLASH_CFI_X8X16)) || + /* x16/x32 in x16 mode */ + ((info->chipwidth == FLASH_CFI_BY16) && + (info->interface == FLASH_CFI_X16X32))) { info->addr_unlock1 = 0xaaa; info->addr_unlock2 = 0x555; -- 2.11.0
v1 -> v2: None
--- drivers/mtd/cfi_flash.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index e8f1739254..2dc6b09cd9 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -234,10 +234,10 @@ static void flash_make_cmd(flash_info_t *info, u32 cmd, void *cmdbuf) cword_offset = (info->portwidth-i)%info->chipwidth; #if defined(__LITTLE_ENDIAN) || defined(CONFIG_SYS_WRITE_SWAPPED_DATA) cp_offset = info->portwidth - i; - val = *((uchar*)&cmd_le + cword_offset); + val = *((uchar *)&cmd_le + cword_offset); #else cp_offset = i - 1; - val = *((uchar*)&cmd + sizeof(u32) - cword_offset - 1); + val = *((uchar *)&cmd + sizeof(u32) - cword_offset - 1); #endif cp[cp_offset] = (cword_offset >= sizeof(u32)) ? 0x00 : val; } -- 2.11.0
v1 -> v2: None
--- drivers/mtd/cfi_flash.c | 200 ++++++++++++++++++++++++------------------------ 1 file changed, 100 insertions(+), 100 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 2dc6b09cd9..b77fd3c0a2 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -1220,29 +1220,29 @@ void flash_print_info(flash_info_t *info) info->size >> 20, info->sector_count); printf(" "); switch (info->vendor) { - case CFI_CMDSET_INTEL_PROG_REGIONS: - printf("Intel Prog Regions"); - break; - case CFI_CMDSET_INTEL_STANDARD: - printf("Intel Standard"); - break; - case CFI_CMDSET_INTEL_EXTENDED: - printf("Intel Extended"); - break; - case CFI_CMDSET_AMD_STANDARD: - printf("AMD Standard"); - break; - case CFI_CMDSET_AMD_EXTENDED: - printf("AMD Extended"); - break; + case CFI_CMDSET_INTEL_PROG_REGIONS: + printf("Intel Prog Regions"); + break; + case CFI_CMDSET_INTEL_STANDARD: + printf("Intel Standard"); + break; + case CFI_CMDSET_INTEL_EXTENDED: + printf("Intel Extended"); + break; + case CFI_CMDSET_AMD_STANDARD: + printf("AMD Standard"); + break; + case CFI_CMDSET_AMD_EXTENDED: + printf("AMD Extended"); + break; #ifdef CONFIG_FLASH_CFI_LEGACY - case CFI_CMDSET_AMD_LEGACY: - printf("AMD Legacy"); - break; + case CFI_CMDSET_AMD_LEGACY: + printf("AMD Legacy"); + break; #endif - default: - printf("Unknown (%d)", info->vendor); - break; + default: + printf("Unknown (%d)", info->vendor); + break; } printf(" command set, Manufacturer ID: 0x%02X, Device ID: 0x", info->manufacturer_id); @@ -1480,94 +1480,94 @@ int flash_real_protect(flash_info_t *info, long sector, int prot) int retcode = 0;
switch (info->vendor) { - case CFI_CMDSET_INTEL_PROG_REGIONS: - case CFI_CMDSET_INTEL_STANDARD: - case CFI_CMDSET_INTEL_EXTENDED: - if (!cfi_protect_bugfix(info, sector, prot)) { + case CFI_CMDSET_INTEL_PROG_REGIONS: + case CFI_CMDSET_INTEL_STANDARD: + case CFI_CMDSET_INTEL_EXTENDED: + if (!cfi_protect_bugfix(info, sector, prot)) { + flash_write_cmd(info, sector, 0, + FLASH_CMD_CLEAR_STATUS); + flash_write_cmd(info, sector, 0, + FLASH_CMD_PROTECT); + if (prot) flash_write_cmd(info, sector, 0, - FLASH_CMD_CLEAR_STATUS); + FLASH_CMD_PROTECT_SET); + else flash_write_cmd(info, sector, 0, - FLASH_CMD_PROTECT); - if (prot) - flash_write_cmd(info, sector, 0, - FLASH_CMD_PROTECT_SET); - else - flash_write_cmd(info, sector, 0, - FLASH_CMD_PROTECT_CLEAR); + FLASH_CMD_PROTECT_CLEAR);
+ } + break; + case CFI_CMDSET_AMD_EXTENDED: + case CFI_CMDSET_AMD_STANDARD: + /* U-Boot only checks the first byte */ + if (manufact_match(info, ATM_MANUFACT)) { + if (prot) { + flash_unlock_seq(info, 0); + flash_write_cmd(info, 0, + info->addr_unlock1, + ATM_CMD_SOFTLOCK_START); + flash_unlock_seq(info, 0); + flash_write_cmd(info, sector, 0, + ATM_CMD_LOCK_SECT); + } else { + flash_write_cmd(info, 0, + info->addr_unlock1, + AMD_CMD_UNLOCK_START); + if (info->device_id == ATM_ID_BV6416) + flash_write_cmd(info, sector, + 0, ATM_CMD_UNLOCK_SECT); } - break; - case CFI_CMDSET_AMD_EXTENDED: - case CFI_CMDSET_AMD_STANDARD: - /* U-Boot only checks the first byte */ - if (manufact_match(info, ATM_MANUFACT)) { - if (prot) { - flash_unlock_seq(info, 0); - flash_write_cmd(info, 0, - info->addr_unlock1, - ATM_CMD_SOFTLOCK_START); - flash_unlock_seq(info, 0); + } + if (info->legacy_unlock) { + int flag = disable_interrupts(); + int lock_flag; + + flash_unlock_seq(info, 0); + flash_write_cmd(info, 0, info->addr_unlock1, + AMD_CMD_SET_PPB_ENTRY); + lock_flag = flash_isset(info, sector, 0, 0x01); + if (prot) { + if (lock_flag) { flash_write_cmd(info, sector, 0, - ATM_CMD_LOCK_SECT); - } else { - flash_write_cmd(info, 0, - info->addr_unlock1, - AMD_CMD_UNLOCK_START); - if (info->device_id == ATM_ID_BV6416) - flash_write_cmd(info, sector, - 0, ATM_CMD_UNLOCK_SECT); + AMD_CMD_PPB_LOCK_BC1); + flash_write_cmd(info, sector, 0, + AMD_CMD_PPB_LOCK_BC2); } - } - if (info->legacy_unlock) { - int flag = disable_interrupts(); - int lock_flag; - - flash_unlock_seq(info, 0); - flash_write_cmd(info, 0, info->addr_unlock1, - AMD_CMD_SET_PPB_ENTRY); - lock_flag = flash_isset(info, sector, 0, 0x01); - if (prot) { - if (lock_flag) { - flash_write_cmd(info, sector, 0, - AMD_CMD_PPB_LOCK_BC1); - flash_write_cmd(info, sector, 0, - AMD_CMD_PPB_LOCK_BC2); - } - debug("sector %ld %slocked\n", sector, - lock_flag ? "" : "already "); - } else { - if (!lock_flag) { - debug("unlock %ld\n", sector); - flash_write_cmd(info, 0, 0, - AMD_CMD_PPB_UNLOCK_BC1); - flash_write_cmd(info, 0, 0, - AMD_CMD_PPB_UNLOCK_BC2); - } - debug("sector %ld %sunlocked\n", sector, - !lock_flag ? "" : "already "); + debug("sector %ld %slocked\n", sector, + lock_flag ? "" : "already "); + } else { + if (!lock_flag) { + debug("unlock %ld\n", sector); + flash_write_cmd(info, 0, 0, + AMD_CMD_PPB_UNLOCK_BC1); + flash_write_cmd(info, 0, 0, + AMD_CMD_PPB_UNLOCK_BC2); } - if (flag) - enable_interrupts(); - - if (flash_status_check(info, sector, - info->erase_blk_tout, - prot ? "protect" : "unprotect")) - printf("status check error\n"); - - flash_write_cmd(info, 0, 0, - AMD_CMD_SET_PPB_EXIT_BC1); - flash_write_cmd(info, 0, 0, - AMD_CMD_SET_PPB_EXIT_BC2); + debug("sector %ld %sunlocked\n", sector, + !lock_flag ? "" : "already "); } - break; + if (flag) + enable_interrupts(); + + if (flash_status_check(info, sector, + info->erase_blk_tout, + prot ? "protect" : "unprotect")) + printf("status check error\n"); + + flash_write_cmd(info, 0, 0, + AMD_CMD_SET_PPB_EXIT_BC1); + flash_write_cmd(info, 0, 0, + AMD_CMD_SET_PPB_EXIT_BC2); + } + break; #ifdef CONFIG_FLASH_CFI_LEGACY - case CFI_CMDSET_AMD_LEGACY: - flash_write_cmd(info, sector, 0, FLASH_CMD_CLEAR_STATUS); - flash_write_cmd(info, sector, 0, FLASH_CMD_PROTECT); - if (prot) - flash_write_cmd(info, sector, 0, FLASH_CMD_PROTECT_SET); - else - flash_write_cmd(info, sector, 0, FLASH_CMD_PROTECT_CLEAR); + case CFI_CMDSET_AMD_LEGACY: + flash_write_cmd(info, sector, 0, FLASH_CMD_CLEAR_STATUS); + flash_write_cmd(info, sector, 0, FLASH_CMD_PROTECT); + if (prot) + flash_write_cmd(info, sector, 0, FLASH_CMD_PROTECT_SET); + else + flash_write_cmd(info, sector, 0, FLASH_CMD_PROTECT_CLEAR); #endif };
-- 2.11.0
v1 -> v2: None
--- drivers/mtd/cfi_flash.c | 18 +++++++++--------- 1 file changed, 9 insertions(+), 9 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index b77fd3c0a2..0d58914e44 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -231,7 +231,7 @@ static void flash_make_cmd(flash_info_t *info, u32 cmd, void *cmdbuf) uchar *cp = (uchar *) cmdbuf;
for (i = info->portwidth; i > 0; i--) { - cword_offset = (info->portwidth-i)%info->chipwidth; + cword_offset = (info->portwidth - i) % info->chipwidth; #if defined(__LITTLE_ENDIAN) || defined(CONFIG_SYS_WRITE_SWAPPED_DATA) cp_offset = info->portwidth - i; val = *((uchar *)&cmd_le + cword_offset); @@ -252,7 +252,7 @@ static void print_longlong(char *str, unsigned long long data) int i; char *cp;
- cp = (char *) &data; + cp = (char *)&data; for (i = 0; i < 8; i++) sprintf(&str[i * 2], "%2.2x", *cp++); } @@ -512,7 +512,7 @@ static int flash_toggle(flash_info_t *info, flash_sect_t sect, break; case FLASH_CFI_64BIT: retval = ((flash_read32(addr) != flash_read32(addr)) || - (flash_read32(addr+4) != flash_read32(addr+4))); + (flash_read32(addr + 4) != flash_read32(addr + 4))); break; default: retval = 0; @@ -1212,7 +1212,7 @@ void flash_print_info(flash_info_t *info) printf("%s flash (%d x %d)", info->name, (info->portwidth << 3), (info->chipwidth << 3)); - if (info->size < 1024*1024) + if (info->size < 1024 * 1024) printf(" Size: %ld kB in %d Sectors\n", info->size >> 10, info->sector_count); else @@ -1888,7 +1888,7 @@ static void __flash_cmd_reset(flash_info_t *info) flash_write_cmd(info, 0, 0, FLASH_CMD_RESET); } void flash_cmd_reset(flash_info_t *info) - __attribute__((weak,alias("__flash_cmd_reset"))); + __attribute__((weak, alias("__flash_cmd_reset")));
static int __flash_detect_cfi(flash_info_t *info, struct cfi_qry *qry) { @@ -2035,7 +2035,7 @@ static void flash_fixup_sst(flash_info_t *info, struct cfi_qry *qry) if (info->device_id == 0x5D23 || /* SST39VF3201B */ info->device_id == 0x5C23) { /* SST39VF3202B */ /* set sector granularity to 4KB */ - info->cmd_erase_sector=0x50; + info->cmd_erase_sector = 0x50; } }
@@ -2093,9 +2093,9 @@ ulong flash_get_size(phys_addr_t base, int banknum) num_erase_regions = qry.num_erase_regions;
if (info->ext_addr) { - info->cfi_version = (ushort) flash_read_uchar(info, + info->cfi_version = (ushort)flash_read_uchar(info, info->ext_addr + 3) << 8; - info->cfi_version |= (ushort) flash_read_uchar(info, + info->cfi_version |= (ushort)flash_read_uchar(info, info->ext_addr + 4); }
@@ -2392,7 +2392,7 @@ unsigned long flash_init(void) #ifndef CONFIG_SYS_FLASH_QUIET_TEST printf("## Unknown flash on Bank %d " "- Size = 0x%08lx = %ld MB\n", - i+1, flash_info[i].size, + i + 1, flash_info[i].size, flash_info[i].size >> 20); #endif /* CONFIG_SYS_FLASH_QUIET_TEST */ } -- 2.11.0
Signed-off-by: Mario Six mario.six@gdsys.cc ---
v1 -> v2: None
--- drivers/mtd/cfi_flash.c | 11 ++++------- 1 file changed, 4 insertions(+), 7 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 0d58914e44..9cc1b2b16f 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -269,6 +269,7 @@ static void flash_printqry(struct cfi_qry *qry) debug(" "); for (y = 0; y < 16; y++) { unsigned char c = p[x + y]; + if (c >= 0x20 && c <= 0x7e) debug("%c", c); else @@ -279,7 +280,6 @@ static void flash_printqry(struct cfi_qry *qry) } #endif
- /*----------------------------------------------------------------------- * read a character at a port width address */ @@ -311,7 +311,6 @@ static inline ushort flash_read_word(flash_info_t *info, uint offset) return retval; }
- /*----------------------------------------------------------------------- * read a long word by picking the least significant byte of each maximum * port size word. Swap for ppc format. @@ -356,7 +355,6 @@ static ulong flash_read_long (flash_info_t *info, flash_sect_t sect, static void flash_write_cmd(flash_info_t *info, flash_sect_t sect, uint offset, u32 cmd) { - void *addr; cfiword_t cword;
@@ -1048,7 +1046,6 @@ out_unmap: } #endif /* CONFIG_SYS_FLASH_USE_BUFFER_WRITE */
- /*----------------------------------------------------------------------- */ int flash_erase(flash_info_t *info, int s_first, int s_last) @@ -1080,7 +1077,6 @@ int flash_erase(flash_info_t *info, int s_first, int s_last) putc('\n'); }
- for (sect = s_first; sect <= s_last; sect++) { if (ctrlc()) { printf("\n"); @@ -1154,6 +1150,7 @@ int flash_erase(flash_info_t *info, int s_first, int s_last) if (use_flash_status_poll(info)) { cfiword_t cword; void *dest; + cword.w64 = 0xffffffffffffffffULL; dest = flash_map(info, sect, 0); st = flash_status_poll(info, &cword, dest, @@ -1494,7 +1491,6 @@ int flash_real_protect(flash_info_t *info, long sector, int prot) else flash_write_cmd(info, sector, 0, FLASH_CMD_PROTECT_CLEAR); - } break; case CFI_CMDSET_AMD_EXTENDED: @@ -1579,7 +1575,6 @@ int flash_real_protect(flash_info_t *info, long sector, int prot) if ((retcode = flash_full_status_check(info, sector, info->erase_blk_tout, prot ? "protect" : "unprotect")) == 0) { - info->protect[sector] = prot;
/* @@ -1887,6 +1882,7 @@ static void __flash_cmd_reset(flash_info_t *info) udelay(1); flash_write_cmd(info, 0, 0, FLASH_CMD_RESET); } + void flash_cmd_reset(flash_info_t *info) __attribute__((weak, alias("__flash_cmd_reset")));
@@ -2370,6 +2366,7 @@ unsigned long flash_init(void) #ifdef CONFIG_SYS_FLASH_PROTECTION /* read environment from EEPROM */ char s[64]; + env_get_f("unlock", s, sizeof(s)); #endif
-- 2.11.0
v1 -> v2: None
--- drivers/mtd/cfi_flash.c | 15 +++++---------- 1 file changed, 5 insertions(+), 10 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 9cc1b2b16f..e2469055b8 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -329,9 +329,8 @@ static ulong flash_read_long (flash_info_t *info, flash_sect_t sect, #ifdef DEBUG debug("long addr is at %p info->portwidth = %d\n", addr, info->portwidth); - for (x = 0; x < 4 * info->portwidth; x++) { + for (x = 0; x < 4 * info->portwidth; x++) debug("addr[%x] = 0x%x\n", x, flash_read8(addr + x)); - } #endif #if defined(__LITTLE_ENDIAN) || defined(CONFIG_SYS_WRITE_SWAPPED_DATA) retval = ((flash_read8(addr) << 16) | @@ -1065,11 +1064,9 @@ int flash_erase(flash_info_t *info, int s_first, int s_last) }
prot = 0; - for (sect = s_first; sect <= s_last; ++sect) { - if (info->protect[sect]) { + for (sect = s_first; sect <= s_last; ++sect) + if (info->protect[sect]) prot++; - } - } if (prot) { printf("- Warning: %d protected sectors will not be erased!\n", prot); @@ -1396,9 +1393,8 @@ int write_buff(flash_info_t *info, uchar *src, ulong addr, ulong cnt) #else while (cnt >= info->portwidth) { cword.w32 = 0; - for (i = 0; i < info->portwidth; i++) { + for (i = 0; i < info->portwidth; i++) flash_add_byte(info, &cword, *src++); - } if ((rc = flash_write_cfiword(info, wp, cword)) != 0) return rc; wp += info->portwidth; @@ -1410,9 +1406,8 @@ int write_buff(flash_info_t *info, uchar *src, ulong addr, ulong cnt) } #endif /* CONFIG_SYS_FLASH_USE_BUFFER_WRITE */
- if (cnt == 0) { + if (cnt == 0) return (0); - }
/* * handle unaligned tail bytes -- 2.11.0
v1 -> v2: None
--- drivers/mtd/cfi_flash.c | 26 +++++++++++++------------- 1 file changed, 13 insertions(+), 13 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index e2469055b8..eebd641e36 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -611,8 +611,8 @@ static int flash_full_status_check(flash_info_t *info, flash_sect_t sector, case CFI_CMDSET_INTEL_PROG_REGIONS: case CFI_CMDSET_INTEL_EXTENDED: case CFI_CMDSET_INTEL_STANDARD: - if ((retcode == ERR_OK) - && !flash_isset(info, sector, 0, FLASH_STATUS_DONE)) { + if ((retcode == ERR_OK) && + !flash_isset(info, sector, 0, FLASH_STATUS_DONE)) { retcode = ERR_INVAL; printf("Flash %s error at address %lx\n", prompt, info->start[sector]); @@ -761,8 +761,8 @@ static flash_sect_t find_sector(flash_info_t *info, ulong addr) if ((info != saved_info) || (sector >= info->sector_count)) sector = 0;
- while ((info->start[sector] < addr) - && (sector < info->sector_count - 1)) + while ((info->start[sector] < addr) && + (sector < info->sector_count - 1)) sector++; while ((info->start[sector] > addr) && (sector > 0)) /* @@ -1435,8 +1435,8 @@ static inline int manufact_match(flash_info_t *info, u32 manu)
static int cfi_protect_bugfix(flash_info_t *info, long sector, int prot) { - if (manufact_match(info, INTEL_MANUFACT) - && info->device_id == NUMONYX_256MBIT) { + if (manufact_match(info, INTEL_MANUFACT) && + info->device_id == NUMONYX_256MBIT) { /* * see errata called * "Numonyx Axcell P33/P30 Specification Update" :) @@ -1807,8 +1807,8 @@ static int flash_detect_legacy(phys_addr_t base, int banknum) (ulong)map_physmem(base, info->portwidth, MAP_NOCACHE); - if (info->portwidth == FLASH_CFI_8BIT - && info->interface == FLASH_CFI_X8X16) { + if (info->portwidth == FLASH_CFI_8BIT && + info->interface == FLASH_CFI_X8X16) { info->addr_unlock1 = 0x2AAA; info->addr_unlock2 = 0x5555; } else { @@ -1892,9 +1892,9 @@ static int __flash_detect_cfi(flash_info_t *info, struct cfi_qry *qry) cfi_offset++) { flash_write_cmd(info, 0, flash_offset_cfi[cfi_offset], FLASH_CMD_CFI); - if (flash_isequal(info, 0, FLASH_OFFSET_CFI_RESP, 'Q') - && flash_isequal(info, 0, FLASH_OFFSET_CFI_RESP + 1, 'R') - && flash_isequal(info, 0, FLASH_OFFSET_CFI_RESP + 2, 'Y')) { + if (flash_isequal(info, 0, FLASH_OFFSET_CFI_RESP, 'Q') && + flash_isequal(info, 0, FLASH_OFFSET_CFI_RESP + 1, 'R') && + flash_isequal(info, 0, FLASH_OFFSET_CFI_RESP + 2, 'Y')) { flash_read_cfi(info, qry, FLASH_OFFSET_CFI_RESP, sizeof(struct cfi_qry)); info->interface = le16_to_cpu(qry->interface_desc); @@ -2144,8 +2144,8 @@ ulong flash_get_size(phys_addr_t base, int banknum)
size_ratio = info->portwidth / info->chipwidth; /* if the chip is x8/x16 reduce the ratio by half */ - if ((info->interface == FLASH_CFI_X8X16) - && (info->chipwidth == FLASH_CFI_BY8)) { + if ((info->interface == FLASH_CFI_X8X16) && + (info->chipwidth == FLASH_CFI_BY8)) { size_ratio >>= 1; } debug("size_ratio %d port %d bits chip %d bits\n", -- 2.11.0
v1 -> v2: None
--- drivers/mtd/cfi_flash.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index eebd641e36..6ae1ac871f 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -555,7 +555,7 @@ static int flash_is_busy(flash_info_t *info, flash_sect_t sect) default: retval = 0; } - debug("flash_is_busy: %d\n", retval); + debug("%s: %d\n", __func__, retval); return retval; }
-- 2.11.0
v1 -> v2: None
--- drivers/mtd/cfi_flash.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 6ae1ac871f..a21c407ed7 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -946,7 +946,8 @@ static int flash_write_cfibuffer(flash_info_t *info, ulong dest, uchar *cp, "write to buffer"); if (retcode == ERR_OK) { /* reduce the number of loops by the width of - * the port */ + * the port + */ cnt = len >> shift; flash_write_cmd(info, sector, 0, cnt - 1); while (cnt-- > 0) { @@ -1793,7 +1794,8 @@ static int flash_detect_legacy(phys_addr_t base, int banknum)
if (board_flash_get_legacy(base, banknum, info)) { /* board code may have filled info completely. If not, we - use JEDEC ID probing. */ + * use JEDEC ID probing. + */ if (!info->vendor) { int modes[] = { CFI_CMDSET_AMD_STANDARD, -- 2.11.0
v1 -> v2: None
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index a21c407ed7..0a24e9173a 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -611,7 +611,7 @@ static int flash_full_status_check(flash_info_t *info, flash_sect_t sector, case CFI_CMDSET_INTEL_PROG_REGIONS: case CFI_CMDSET_INTEL_EXTENDED: case CFI_CMDSET_INTEL_STANDARD: - if ((retcode == ERR_OK) && + if (retcode == ERR_OK && !flash_isset(info, sector, 0, FLASH_STATUS_DONE)) { retcode = ERR_INVAL; printf("Flash %s error at address %lx\n", prompt, @@ -758,7 +758,7 @@ static flash_sect_t find_sector(flash_info_t *info, ulong addr) static flash_info_t *saved_info; /* previously used flash bank */ flash_sect_t sector = saved_sector;
- if ((info != saved_info) || (sector >= info->sector_count)) + if (info != saved_info || sector >= info->sector_count) sector = 0;
while ((info->start[sector] < addr) && @@ -1059,7 +1059,7 @@ int flash_erase(flash_info_t *info, int s_first, int s_last) puts("Can't erase unknown flash type - aborted\n"); return 1; } - if ((s_first < 0) || (s_first > s_last)) { + if (s_first < 0 || s_first > s_last) { puts("- no sectors to erase\n"); return 1; } @@ -1247,7 +1247,7 @@ void flash_print_info(flash_info_t *info) printf(info->chipwidth == FLASH_CFI_16BIT ? "%04X" : "%02X", info->device_id2); } - if ((info->vendor == CFI_CMDSET_AMD_STANDARD) && (info->legacy_unlock)) + if (info->vendor == CFI_CMDSET_AMD_STANDARD && info->legacy_unlock) printf("\n Advanced Sector Protection (PPB) enabled"); printf("\n Erase timeout: %ld ms, write timeout: %ld ms\n", info->erase_blk_tout, @@ -1291,7 +1291,7 @@ void flash_print_info(flash_info_t *info) #define FLASH_SHOW_PROGRESS(scale, dots, digit, dots_sub) \ if (flash_verbose) { \ dots -= dots_sub; \ - if ((scale > 0) && (dots <= 0)) { \ + if (scale > 0 && dots <= 0) { \ if ((digit % 5) == 0) \ printf("%d", digit / 5); \ else \ @@ -1577,7 +1577,7 @@ int flash_real_protect(flash_info_t *info, long sector, int prot) * On some of Intel's flash chips (marked via legacy_unlock) * unprotect unprotects all locking. */ - if ((prot == 0) && (info->legacy_unlock)) { + if (prot == 0 && info->legacy_unlock) { flash_sect_t i;
for (i = 0; i < info->sector_count; i++) { @@ -1636,10 +1636,10 @@ static void cfi_reverse_geometry(struct cfi_qry *qry) u32 tmp;
for (i = 0, j = qry->num_erase_regions - 1; i < j; i++, j--) { - tmp = get_unaligned(&(qry->erase_region_info[i])); - put_unaligned(get_unaligned(&(qry->erase_region_info[j])), - &(qry->erase_region_info[i])); - put_unaligned(tmp, &(qry->erase_region_info[j])); + tmp = get_unaligned(&qry->erase_region_info[i]); + put_unaligned(get_unaligned(&qry->erase_region_info[j]), + &qry->erase_region_info[i]); + put_unaligned(tmp, &qry->erase_region_info[j]); } }
@@ -1919,11 +1919,11 @@ static int __flash_detect_cfi(flash_info_t *info, struct cfi_qry *qry) * in compatibility mode */ if (/* x8/x16 in x8 mode */ - ((info->chipwidth == FLASH_CFI_BY8) && - (info->interface == FLASH_CFI_X8X16)) || + (info->chipwidth == FLASH_CFI_BY8 && + info->interface == FLASH_CFI_X8X16) || /* x16/x32 in x16 mode */ - ((info->chipwidth == FLASH_CFI_BY16) && - (info->interface == FLASH_CFI_X16X32))) + (info->chipwidth == FLASH_CFI_BY16 && + info->interface == FLASH_CFI_X16X32)) { info->addr_unlock1 = 0xaaa; info->addr_unlock2 = 0x555; @@ -2040,8 +2040,8 @@ static void flash_fixup_num(flash_info_t *info, struct cfi_qry *qry) * There's an app note from Numonyx on this issue. * So adjust the buffer size for M29EW while operating in 8-bit mode */ - if (((qry->max_buf_write_size) > 0x8) && - (info->device_id == 0x7E) && + if (qry->max_buf_write_size > 0x8 && + info->device_id == 0x7E && (info->device_id2 == 0x2201 || info->device_id2 == 0x2301 || info->device_id2 == 0x2801 || @@ -2081,8 +2081,8 @@ ulong flash_get_size(phys_addr_t base, int banknum) info->start[0] = (ulong)map_physmem(base, info->portwidth, MAP_NOCACHE);
if (flash_detect_cfi(info, &qry)) { - info->vendor = le16_to_cpu(get_unaligned(&(qry.p_id))); - info->ext_addr = le16_to_cpu(get_unaligned(&(qry.p_adr))); + info->vendor = le16_to_cpu(get_unaligned(&qry.p_id)); + info->ext_addr = le16_to_cpu(get_unaligned(&qry.p_adr)); num_erase_regions = qry.num_erase_regions;
if (info->ext_addr) { @@ -2146,8 +2146,8 @@ ulong flash_get_size(phys_addr_t base, int banknum)
size_ratio = info->portwidth / info->chipwidth; /* if the chip is x8/x16 reduce the ratio by half */ - if ((info->interface == FLASH_CFI_X8X16) && - (info->chipwidth == FLASH_CFI_BY8)) { + if (info->interface == FLASH_CFI_X8X16 && + info->chipwidth == FLASH_CFI_BY8) { size_ratio >>= 1; } debug("size_ratio %d port %d bits chip %d bits\n", @@ -2157,7 +2157,7 @@ ulong flash_get_size(phys_addr_t base, int banknum) /* multiply the size by the number of chips */ info->size *= size_ratio; max_size = cfi_flash_bank_size(banknum); - if (max_size && (info->size > max_size)) { + if (max_size && info->size > max_size) { debug("[truncated from %ldMiB]", info->size >> 20); info->size = max_size; } @@ -2172,7 +2172,7 @@ ulong flash_get_size(phys_addr_t base, int banknum) }
tmp = le32_to_cpu(get_unaligned( - &(qry.erase_region_info[i]))); + &qry.erase_region_info[i])); debug("erase region %u: 0x%08lx\n", i, tmp);
erase_region_count = (tmp & 0xffff) + 1; @@ -2261,8 +2261,8 @@ ulong flash_get_size(phys_addr_t base, int banknum) /* round up when converting to ms */ info->write_tout = (tmp + 999) / 1000; info->flash_id = FLASH_MAN_CFI; - if ((info->interface == FLASH_CFI_X8X16) && - (info->chipwidth == FLASH_CFI_BY8)) { + if (info->interface == FLASH_CFI_X8X16 && + info->chipwidth == FLASH_CFI_BY8) { /* XXX - Need to test on x8/x16 in parallel. */ info->portwidth >>= 1; } -- 2.11.0
v1 -> v2: None
--- drivers/mtd/cfi_flash.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 0a24e9173a..53842443eb 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -1154,10 +1154,12 @@ int flash_erase(flash_info_t *info, int s_first, int s_last) st = flash_status_poll(info, &cword, dest, info->erase_blk_tout, "erase"); flash_unmap(info, sect, 0, dest); - } else + } else { st = flash_full_status_check(info, sect, info->erase_blk_tout, "erase"); + } + if (st) rcode = 1; else if (flash_verbose) -- 2.11.0
v1 -> v2: None
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 53842443eb..4c5e1568e6 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -1140,7 +1140,7 @@ int flash_erase(flash_info_t *info, int s_first, int s_last) break; #endif default: - debug("Unkown flash vendor %d\n", + debug("Unknown flash vendor %d\n", info->vendor); break; } -- 2.11.0
v1 -> v2: None
--- drivers/mtd/cfi_flash.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 4c5e1568e6..5b3c071b30 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -1826,9 +1826,9 @@ static int flash_detect_legacy(phys_addr_t base, int banknum) info->device_id2); if (jedec_flash_match(info, info->start[0])) break; - else - unmap_physmem((void *)info->start[0], - info->portwidth); + + unmap_physmem((void *)info->start[0], + info->portwidth); } }
-- 2.11.0
v1 -> v2: None
--- drivers/mtd/cfi_flash.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 5b3c071b30..7aa379b0d8 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -1925,8 +1925,7 @@ static int __flash_detect_cfi(flash_info_t *info, struct cfi_qry *qry) info->interface == FLASH_CFI_X8X16) || /* x16/x32 in x16 mode */ (info->chipwidth == FLASH_CFI_BY16 && - info->interface == FLASH_CFI_X16X32)) - { + info->interface == FLASH_CFI_X16X32)) { info->addr_unlock1 = 0xaaa; info->addr_unlock2 = 0x555; } -- 2.11.0
v1 -> v2: None
--- drivers/mtd/cfi_flash.c | 1 - 1 file changed, 1 deletion(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 7aa379b0d8..d16357343f 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -1280,7 +1280,6 @@ void flash_print_info(flash_info_t *info) #endif } putc('\n'); - return; }
/*----------------------------------------------------------------------- -- 2.11.0
v1 -> v2: None
--- drivers/mtd/cfi_flash.c | 18 +++++++++++------- 1 file changed, 11 insertions(+), 7 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index d16357343f..48086ded5c 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -1339,7 +1339,8 @@ int write_buff(flash_info_t *info, uchar *src, ulong addr, ulong cnt) wp = (addr & ~(info->portwidth - 1));
/* handle unaligned start */ - if ((aln = addr - wp) != 0) { + aln = addr - wp; + if (aln != 0) { cword.w32 = 0; p = (uchar *)wp; for (i = 0; i < aln; ++i) @@ -1370,7 +1371,8 @@ int write_buff(flash_info_t *info, uchar *src, ulong addr, ulong cnt) cword.w32 = 0; for (i = 0; i < info->portwidth; i++) flash_add_byte(info, &cword, *src++); - if ((rc = flash_write_cfiword(info, wp, cword)) != 0) + rc = flash_write_cfiword(info, wp, cword); + if (rc != 0) return rc; wp += info->portwidth; cnt -= info->portwidth; @@ -1381,7 +1383,8 @@ int write_buff(flash_info_t *info, uchar *src, ulong addr, ulong cnt) i = buffered_size - (wp % buffered_size); if (i > cnt) i = cnt; - if ((rc = flash_write_cfibuffer(info, wp, src, i)) != ERR_OK) + rc = flash_write_cfibuffer(info, wp, src, i); + if (rc != ERR_OK) return rc; i -= i & (info->portwidth - 1); wp += i; @@ -1397,7 +1400,8 @@ int write_buff(flash_info_t *info, uchar *src, ulong addr, ulong cnt) cword.w32 = 0; for (i = 0; i < info->portwidth; i++) flash_add_byte(info, &cword, *src++); - if ((rc = flash_write_cfiword(info, wp, cword)) != 0) + rc = flash_write_cfiword(info, wp, cword); + if (rc != 0) return rc; wp += info->portwidth; cnt -= info->portwidth; @@ -1569,9 +1573,9 @@ int flash_real_protect(flash_info_t *info, long sector, int prot) * flash_full_status_check() to work correctly */ flash_write_cmd(info, sector, 0, FLASH_CMD_READ_STATUS); - if ((retcode = - flash_full_status_check(info, sector, info->erase_blk_tout, - prot ? "protect" : "unprotect")) == 0) { + retcode = flash_full_status_check(info, sector, info->erase_blk_tout, + prot ? "protect" : "unprotect"); + if (retcode == 0) { info->protect[sector] = prot;
/* -- 2.11.0
v1 -> v2: None
--- drivers/mtd/cfi_flash.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 48086ded5c..fced9847ef 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -491,7 +491,7 @@ static int flash_isset(flash_info_t *info, flash_sect_t sect, static int flash_toggle(flash_info_t *info, flash_sect_t sect, uint offset, uchar cmd) { - void *addr; + u8 *addr; cfiword_t cword; int retval;
@@ -872,9 +872,9 @@ static int flash_write_cfibuffer(flash_info_t *info, ulong dest, uchar *cp, flash_sect_t sector; int cnt; int retcode; - void *src = cp; - void *dst = (void *)dest; - void *dst2 = dst; + u8 *src = cp; + u8 *dst = (u8 *)dest; + u8 *dst2 = dst; int flag = 1; uint offset = 0; unsigned int shift; -- 2.11.0
v1 -> v2: None
--- drivers/mtd/cfi_flash.c | 17 ++++++++--------- 1 file changed, 8 insertions(+), 9 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index fced9847ef..8040e43de7 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -1255,10 +1255,9 @@ void flash_print_info(flash_info_t *info) info->erase_blk_tout, info->write_tout); if (info->buffer_size > 1) { - printf(" Buffer write timeout: %ld ms, " - "buffer size: %d bytes\n", - info->buffer_write_tout, - info->buffer_size); + printf(" Buffer write timeout: %ld ms, ", + info->buffer_write_tout); + printf("buffer size: %d bytes\n", info->buffer_size); }
puts("\n Sector Start Addresses:"); @@ -2050,8 +2049,8 @@ static void flash_fixup_num(flash_info_t *info, struct cfi_qry *qry) info->device_id2 == 0x2301 || info->device_id2 == 0x2801 || info->device_id2 == 0x4801)) { - debug("Adjusted buffer size on Numonyx flash" - " M29EW family in 8 bit mode\n"); + debug("Adjusted buffer size on Numonyx flash"); + debug(" M29EW family in 8 bit mode\n"); qry->max_buf_write_size = 0x8; } } @@ -2388,9 +2387,9 @@ unsigned long flash_init(void) size += flash_info[i].size; if (flash_info[i].flash_id == FLASH_UNKNOWN) { #ifndef CONFIG_SYS_FLASH_QUIET_TEST - printf("## Unknown flash on Bank %d " - "- Size = 0x%08lx = %ld MB\n", - i + 1, flash_info[i].size, + printf("## Unknown flash on Bank %d ", i + 1); + printf("- Size = 0x%08lx = %ld MB\n", + flash_info[i].size, flash_info[i].size >> 20); #endif /* CONFIG_SYS_FLASH_QUIET_TEST */ } -- 2.11.0
v1 -> v2: None
--- drivers/mtd/cfi_flash.c | 16 ++++++++-------- 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 8040e43de7..e94a7269e1 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -1687,8 +1687,8 @@ static int cmdset_intel_init(flash_info_t *info, struct cfi_qry *qry)
static void cmdset_amd_read_jedec_ids(flash_info_t *info) { - ushort bankId = 0; - uchar manuId; + ushort bank_id = 0; + uchar manu_id; uchar feature;
flash_write_cmd(info, 0, 0, AMD_CMD_RESET); @@ -1696,14 +1696,14 @@ static void cmdset_amd_read_jedec_ids(flash_info_t *info) flash_write_cmd(info, 0, info->addr_unlock1, FLASH_CMD_READ_ID); udelay(1000); /* some flash are slow to respond */
- manuId = flash_read_uchar(info, FLASH_OFFSET_MANUFACTURER_ID); + manu_id = flash_read_uchar(info, FLASH_OFFSET_MANUFACTURER_ID); /* JEDEC JEP106Z specifies ID codes up to bank 7 */ - while (manuId == FLASH_CONTINUATION_CODE && bankId < 0x800) { - bankId += 0x100; - manuId = flash_read_uchar(info, - bankId | FLASH_OFFSET_MANUFACTURER_ID); + while (manu_id == FLASH_CONTINUATION_CODE && bank_id < 0x800) { + bank_id += 0x100; + manu_id = flash_read_uchar(info, + bank_id | FLASH_OFFSET_MANUFACTURER_ID); } - info->manufacturer_id = manuId; + info->manufacturer_id = manu_id;
debug("info->ext_addr = 0x%x, cfi_version = 0x%x\n", info->ext_addr, info->cfi_version); -- 2.11.0
checkpatch.pl complains about the spelling of ERR_TIMOUT. Since the error is only used in a handful of files, we rename the error to ERR_TIMEOUT.
v1 -> v2: None
--- board/cobra5272/flash.c | 2 +- common/flash.c | 4 ++-- drivers/mtd/cfi_flash.c | 4 ++-- drivers/mtd/pic32_flash.c | 6 +++--- include/flash.h | 2 +- 5 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/board/cobra5272/flash.c b/board/cobra5272/flash.c index 4fac6880f1..ca27b49a3b 100644 --- a/board/cobra5272/flash.c +++ b/board/cobra5272/flash.c @@ -216,7 +216,7 @@ int flash_erase (flash_info_t * info, int s_first, int s_last) goto outahere; } if (chip1 == TMO) { - rc = ERR_TIMOUT; + rc = ERR_TIMEOUT; goto outahere; }
diff --git a/common/flash.c b/common/flash.c index 587ef60158..876677493f 100644 --- a/common/flash.c +++ b/common/flash.c @@ -112,7 +112,7 @@ addr2info (ulong addr) * and no protected sectors are hit. * Returns: * ERR_OK 0 - OK - * ERR_TIMOUT 1 - write timeout + * ERR_TIMEOUT 1 - write timeout * ERR_NOT_ERASED 2 - Flash not erased * ERR_PROTECTED 4 - target range includes protected sectors * ERR_INVAL 8 - target address not in Flash memory @@ -185,7 +185,7 @@ void flash_perror (int err) switch (err) { case ERR_OK: break; - case ERR_TIMOUT: + case ERR_TIMEOUT: puts ("Timeout writing to Flash\n"); break; case ERR_NOT_ERASED: diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index e94a7269e1..5ba0c5fdec 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -588,7 +588,7 @@ static int flash_status_check(flash_info_t *info, flash_sect_t sector, flash_read_long(info, sector, 0)); flash_write_cmd(info, sector, 0, info->cmd_reset); udelay(1); - return ERR_TIMOUT; + return ERR_TIMEOUT; } udelay(1); /* also triggers watchdog */ } @@ -696,7 +696,7 @@ static int flash_status_poll(flash_info_t *info, void *src, void *dst, if (get_timer(start) > tout) { printf("Flash %s timeout at address %lx data %lx\n", prompt, (ulong)dst, (ulong)flash_read8(dst)); - return ERR_TIMOUT; + return ERR_TIMEOUT; } udelay(1); /* also triggers watchdog */ } diff --git a/drivers/mtd/pic32_flash.c b/drivers/mtd/pic32_flash.c index e1a8d3bc4b..a6a5d1cc2e 100644 --- a/drivers/mtd/pic32_flash.c +++ b/drivers/mtd/pic32_flash.c @@ -69,7 +69,7 @@ static int flash_wait_till_busy(const char *func, ulong timeout) int ret = wait_for_bit(__func__, &nvm_regs_p->ctrl.raw, NVM_WR, false, timeout, false);
- return ret ? ERR_TIMOUT : ERR_OK; + return ret ? ERR_TIMEOUT : ERR_OK; }
static inline int flash_complete_operation(void) @@ -99,7 +99,7 @@ static inline int flash_complete_operation(void) * Erase flash sectors, returns: * ERR_OK - OK * ERR_INVAL - invalid sector arguments - * ERR_TIMOUT - write timeout + * ERR_TIMEOUT - write timeout * ERR_NOT_ERASED - Flash not erased * ERR_UNKNOWN_FLASH_VENDOR - incorrect flash */ @@ -217,7 +217,7 @@ static int write_word(flash_info_t *info, ulong dest, ulong word) /* * Copy memory to flash, returns: * ERR_OK - OK - * ERR_TIMOUT - write timeout + * ERR_TIMEOUT - write timeout * ERR_NOT_ERASED - Flash not erased */ int write_buff(flash_info_t *info, uchar *src, ulong addr, ulong cnt) diff --git a/include/flash.h b/include/flash.h index dc67cb2df6..1a4e879009 100644 --- a/include/flash.h +++ b/include/flash.h @@ -122,7 +122,7 @@ extern int jedec_flash_match(flash_info_t *info, ulong base); * return codes from flash_write(): */ #define ERR_OK 0 -#define ERR_TIMOUT 1 +#define ERR_TIMEOUT 1 #define ERR_NOT_ERASED 2 #define ERR_PROTECTED 4 #define ERR_INVAL 8 -- 2.11.0
In a while loop in cfi_flash.c the array "start" is accessed at the index "sector" before the index variable "sector" is bounds-checked, which might lead to accesses beyond the bounds of the array.
Swap the order of the checks in the "&&" expression, so that the short-circuit evaluation prevents out-of-bounds array accesses.
v1 -> v2: None
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 5ba0c5fdec..61c2e6379d 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -761,8 +761,8 @@ static flash_sect_t find_sector(flash_info_t *info, ulong addr) if (info != saved_info || sector >= info->sector_count) sector = 0;
- while ((info->start[sector] < addr) && - (sector < info->sector_count - 1)) + while ((sector < info->sector_count - 1) && + (info->start[sector] < addr)) sector++; while ((info->start[sector] > addr) && (sector > 0)) /* -- 2.11.0
v1 -> v2: None
--- drivers/mtd/cfi_flash.c | 31 +++++++++++++++++++------------ 1 file changed, 19 insertions(+), 12 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 61c2e6379d..88c47cad90 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -175,7 +175,8 @@ __maybe_weak u64 flash_read64(void *addr)
/*----------------------------------------------------------------------- */ -#if defined(CONFIG_ENV_IS_IN_FLASH) || defined(CONFIG_ENV_ADDR_REDUND) || (CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE) +#if defined(CONFIG_ENV_IS_IN_FLASH) || defined(CONFIG_ENV_ADDR_REDUND) || \ + (CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE) static flash_info_t *flash_get_info(ulong base) { int i; @@ -569,8 +570,9 @@ static int flash_status_check(flash_info_t *info, flash_sect_t sector, ulong start;
#if CONFIG_SYS_HZ != 1000 + /* Avoid overflow for large HZ */ if ((ulong)CONFIG_SYS_HZ > 100000) - tout *= (ulong)CONFIG_SYS_HZ / 1000; /* for a big HZ, avoid overflow */ + tout *= (ulong)CONFIG_SYS_HZ / 1000; else tout = DIV_ROUND_UP(tout * (ulong)CONFIG_SYS_HZ, 1000); #endif @@ -661,8 +663,9 @@ static int flash_status_poll(flash_info_t *info, void *src, void *dst, int ready;
#if CONFIG_SYS_HZ != 1000 + /* Avoid overflow for large HZ */ if ((ulong)CONFIG_SYS_HZ > 100000) - tout *= (ulong)CONFIG_SYS_HZ / 1000; /* for a big HZ, avoid overflow */ + tout *= (ulong)CONFIG_SYS_HZ / 1000; else tout = DIV_ROUND_UP(tout * (ulong)CONFIG_SYS_HZ, 1000); #endif @@ -937,7 +940,8 @@ static int flash_write_cfibuffer(flash_info_t *info, ulong dest, uchar *cp, case CFI_CMDSET_INTEL_STANDARD: case CFI_CMDSET_INTEL_EXTENDED: write_cmd = (info->vendor == CFI_CMDSET_INTEL_PROG_REGIONS) ? - FLASH_CMD_WRITE_BUFFER_PROG : FLASH_CMD_WRITE_TO_BUFFER; + FLASH_CMD_WRITE_BUFFER_PROG : + FLASH_CMD_WRITE_TO_BUFFER; flash_write_cmd(info, sector, 0, FLASH_CMD_CLEAR_STATUS); flash_write_cmd(info, sector, 0, FLASH_CMD_READ_STATUS); flash_write_cmd(info, sector, 0, write_cmd); @@ -1152,7 +1156,8 @@ int flash_erase(flash_info_t *info, int s_first, int s_last) cword.w64 = 0xffffffffffffffffULL; dest = flash_map(info, sect, 0); st = flash_status_poll(info, &cword, dest, - info->erase_blk_tout, "erase"); + info->erase_blk_tout, + "erase"); flash_unmap(info, sect, 0, dest); } else { st = flash_full_status_check(info, sect, @@ -1561,9 +1566,11 @@ int flash_real_protect(flash_info_t *info, long sector, int prot) flash_write_cmd(info, sector, 0, FLASH_CMD_CLEAR_STATUS); flash_write_cmd(info, sector, 0, FLASH_CMD_PROTECT); if (prot) - flash_write_cmd(info, sector, 0, FLASH_CMD_PROTECT_SET); + flash_write_cmd(info, sector, 0, + FLASH_CMD_PROTECT_SET); else - flash_write_cmd(info, sector, 0, FLASH_CMD_PROTECT_CLEAR); + flash_write_cmd(info, sector, 0, + FLASH_CMD_PROTECT_CLEAR); #endif };
@@ -1899,9 +1906,9 @@ static int __flash_detect_cfi(flash_info_t *info, struct cfi_qry *qry) flash_write_cmd(info, 0, flash_offset_cfi[cfi_offset], FLASH_CMD_CFI); if (flash_isequal(info, 0, FLASH_OFFSET_CFI_RESP, 'Q') && - flash_isequal(info, 0, FLASH_OFFSET_CFI_RESP + 1, 'R') && - flash_isequal(info, 0, FLASH_OFFSET_CFI_RESP + 2, 'Y')) { - flash_read_cfi(info, qry, FLASH_OFFSET_CFI_RESP, + flash_isequal(info, 0, FLASH_OFFSET_CFI_RESP + 1, 'R') && + flash_isequal(info, 0, FLASH_OFFSET_CFI_RESP + 2, 'Y')) { + flash_read_cfi(info, qry, FLASH_OFFSET_CFI_RESP, sizeof(struct cfi_qry)); info->interface = le16_to_cpu(qry->interface_desc);
@@ -2182,8 +2189,8 @@ ulong flash_get_size(phys_addr_t base, int banknum) tmp >>= 16; erase_region_size = (tmp & 0xffff) ? ((tmp & 0xffff) * 256) : 128; - debug("erase_region_count = %d erase_region_size = %d\n", - erase_region_count, erase_region_size); + debug("erase_region_count = %d ", erase_region_count); + debug("erase_region_size = %d\n", erase_region_size); for (j = 0; j < erase_region_count; j++) { if (sector - base >= info->size) break; -- 2.11.0
v1 -> v2: None
--- drivers/mtd/cfi_flash.c | 238 ++++++++++++++++++++++++------------------------ 1 file changed, 118 insertions(+), 120 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 88c47cad90..347382f529 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -213,7 +213,7 @@ flash_map(flash_info_t *info, flash_sect_t sect, uint offset) }
static inline void flash_unmap(flash_info_t *info, flash_sect_t sect, - unsigned int offset, void *addr) + unsigned int offset, void *addr) { }
@@ -329,7 +329,7 @@ static ulong flash_read_long (flash_info_t *info, flash_sect_t sect,
#ifdef DEBUG debug("long addr is at %p info->portwidth = %d\n", addr, - info->portwidth); + info->portwidth); for (x = 0; x < 4 * info->portwidth; x++) debug("addr[%x] = 0x%x\n", x, flash_read8(addr + x)); #endif @@ -363,19 +363,19 @@ static void flash_write_cmd(flash_info_t *info, flash_sect_t sect, switch (info->portwidth) { case FLASH_CFI_8BIT: debug("fwc addr %p cmd %x %x 8bit x %d bit\n", addr, cmd, - cword.w8, info->chipwidth << CFI_FLASH_SHIFT_WIDTH); + cword.w8, info->chipwidth << CFI_FLASH_SHIFT_WIDTH); flash_write8(cword.w8, addr); break; case FLASH_CFI_16BIT: debug("fwc addr %p cmd %x %4.4x 16bit x %d bit\n", addr, - cmd, cword.w16, - info->chipwidth << CFI_FLASH_SHIFT_WIDTH); + cmd, cword.w16, + info->chipwidth << CFI_FLASH_SHIFT_WIDTH); flash_write16(cword.w16, addr); break; case FLASH_CFI_32BIT: debug("fwc addr %p cmd %x %8.8x 32bit x %d bit\n", addr, - cmd, cword.w32, - info->chipwidth << CFI_FLASH_SHIFT_WIDTH); + cmd, cword.w32, + info->chipwidth << CFI_FLASH_SHIFT_WIDTH); flash_write32(cword.w32, addr); break; case FLASH_CFI_64BIT: @@ -386,8 +386,8 @@ static void flash_write_cmd(flash_info_t *info, flash_sect_t sect, print_longlong(str, cword.w64);
debug("fwrite addr %p cmd %x %s 64 bit x %d bit\n", - addr, cmd, str, - info->chipwidth << CFI_FLASH_SHIFT_WIDTH); + addr, cmd, str, + info->chipwidth << CFI_FLASH_SHIFT_WIDTH); } #endif flash_write64(cword.w64, addr); @@ -408,8 +408,8 @@ static void flash_unlock_seq(flash_info_t *info, flash_sect_t sect)
/*----------------------------------------------------------------------- */ -static int flash_isequal(flash_info_t *info, flash_sect_t sect, - uint offset, uchar cmd) +static int flash_isequal(flash_info_t *info, flash_sect_t sect, uint offset, + uchar cmd) { void *addr; cfiword_t cword; @@ -456,8 +456,8 @@ static int flash_isequal(flash_info_t *info, flash_sect_t sect,
/*----------------------------------------------------------------------- */ -static int flash_isset(flash_info_t *info, flash_sect_t sect, - uint offset, uchar cmd) +static int flash_isset(flash_info_t *info, flash_sect_t sect, uint offset, + uchar cmd) { void *addr; cfiword_t cword; @@ -489,8 +489,8 @@ static int flash_isset(flash_info_t *info, flash_sect_t sect,
/*----------------------------------------------------------------------- */ -static int flash_toggle(flash_info_t *info, flash_sect_t sect, - uint offset, uchar cmd) +static int flash_toggle(flash_info_t *info, flash_sect_t sect, uint offset, + uchar cmd) { u8 *addr; cfiword_t cword; @@ -544,12 +544,12 @@ static int flash_is_busy(flash_info_t *info, flash_sect_t sect) #endif if (info->sr_supported) { flash_write_cmd(info, sect, info->addr_unlock1, - FLASH_CMD_READ_STATUS); + FLASH_CMD_READ_STATUS); retval = !flash_isset(info, sect, 0, - FLASH_STATUS_DONE); + FLASH_STATUS_DONE); } else { retval = flash_toggle(info, sect, 0, - AMD_STATUS_TOGGLE); + AMD_STATUS_TOGGLE); }
break; @@ -565,7 +565,7 @@ static int flash_is_busy(flash_info_t *info, flash_sect_t sect) * This routine does not set the flash to read-array mode. */ static int flash_status_check(flash_info_t *info, flash_sect_t sector, - ulong tout, char *prompt) + ulong tout, char *prompt) { ulong start;
@@ -586,8 +586,8 @@ static int flash_status_check(flash_info_t *info, flash_sect_t sector, while (flash_is_busy(info, sector)) { if (get_timer(start) > tout) { printf("Flash %s timeout at address %lx data %lx\n", - prompt, info->start[sector], - flash_read_long(info, sector, 0)); + prompt, info->start[sector], + flash_read_long(info, sector, 0)); flash_write_cmd(info, sector, 0, info->cmd_reset); udelay(1); return ERR_TIMEOUT; @@ -604,7 +604,7 @@ static int flash_status_check(flash_info_t *info, flash_sect_t sector, * This routine sets the flash to read-array mode. */ static int flash_full_status_check(flash_info_t *info, flash_sect_t sector, - ulong tout, char *prompt) + ulong tout, char *prompt) { int retcode;
@@ -614,10 +614,10 @@ static int flash_full_status_check(flash_info_t *info, flash_sect_t sector, case CFI_CMDSET_INTEL_EXTENDED: case CFI_CMDSET_INTEL_STANDARD: if (retcode == ERR_OK && - !flash_isset(info, sector, 0, FLASH_STATUS_DONE)) { + !flash_isset(info, sector, 0, FLASH_STATUS_DONE)) { retcode = ERR_INVAL; printf("Flash %s error at address %lx\n", prompt, - info->start[sector]); + info->start[sector]); if (flash_isset(info, sector, 0, FLASH_STATUS_ECLBS | FLASH_STATUS_PSLBS)) { puts("Command Sequence Error.\n"); @@ -765,7 +765,7 @@ static flash_sect_t find_sector(flash_info_t *info, ulong addr) sector = 0;
while ((sector < info->sector_count - 1) && - (info->start[sector] < addr)) + (info->start[sector] < addr)) sector++; while ((info->start[sector] > addr) && (sector > 0)) /* @@ -781,8 +781,7 @@ static flash_sect_t find_sector(flash_info_t *info, ulong addr)
/*----------------------------------------------------------------------- */ -static int flash_write_cfiword(flash_info_t *info, ulong dest, - cfiword_t cword) +static int flash_write_cfiword(flash_info_t *info, ulong dest, cfiword_t cword) { void *dstaddr = (void *)dest; int flag; @@ -870,7 +869,7 @@ static int flash_write_cfiword(flash_info_t *info, ulong dest, #ifdef CONFIG_SYS_FLASH_USE_BUFFER_WRITE
static int flash_write_cfibuffer(flash_info_t *info, ulong dest, uchar *cp, - int len) + int len) { flash_sect_t sector; int cnt; @@ -946,8 +945,8 @@ static int flash_write_cfibuffer(flash_info_t *info, ulong dest, uchar *cp, flash_write_cmd(info, sector, 0, FLASH_CMD_READ_STATUS); flash_write_cmd(info, sector, 0, write_cmd); retcode = flash_status_check(info, sector, - info->buffer_write_tout, - "write to buffer"); + info->buffer_write_tout, + "write to buffer"); if (retcode == ERR_OK) { /* reduce the number of loops by the width of * the port @@ -978,7 +977,7 @@ static int flash_write_cfibuffer(flash_info_t *info, ulong dest, uchar *cp, } } flash_write_cmd(info, sector, 0, - FLASH_CMD_WRITE_BUFFER_CONFIRM); + FLASH_CMD_WRITE_BUFFER_CONFIRM); retcode = flash_full_status_check( info, sector, info->buffer_write_tout, "buffer write"); @@ -1074,7 +1073,7 @@ int flash_erase(flash_info_t *info, int s_first, int s_last) prot++; if (prot) { printf("- Warning: %d protected sectors will not be erased!\n", - prot); + prot); } else if (flash_verbose) { putc('\n'); } @@ -1117,11 +1116,11 @@ int flash_erase(flash_info_t *info, int s_first, int s_last) case CFI_CMDSET_INTEL_STANDARD: case CFI_CMDSET_INTEL_EXTENDED: flash_write_cmd(info, sect, 0, - FLASH_CMD_CLEAR_STATUS); + FLASH_CMD_CLEAR_STATUS); flash_write_cmd(info, sect, 0, - FLASH_CMD_BLOCK_ERASE); + FLASH_CMD_BLOCK_ERASE); flash_write_cmd(info, sect, 0, - FLASH_CMD_ERASE_CONFIRM); + FLASH_CMD_ERASE_CONFIRM); break; case CFI_CMDSET_AMD_STANDARD: case CFI_CMDSET_AMD_EXTENDED: @@ -1131,7 +1130,7 @@ int flash_erase(flash_info_t *info, int s_first, int s_last) AMD_CMD_ERASE_START); flash_unlock_seq(info, sect); flash_write_cmd(info, sect, 0, - info->cmd_erase_sector); + info->cmd_erase_sector); break; #ifdef CONFIG_FLASH_CFI_LEGACY case CFI_CMDSET_AMD_LEGACY: @@ -1145,7 +1144,7 @@ int flash_erase(flash_info_t *info, int s_first, int s_last) #endif default: debug("Unknown flash vendor %d\n", - info->vendor); + info->vendor); break; }
@@ -1212,14 +1211,14 @@ void flash_print_info(flash_info_t *info) }
printf("%s flash (%d x %d)", - info->name, - (info->portwidth << 3), (info->chipwidth << 3)); + info->name, + (info->portwidth << 3), (info->chipwidth << 3)); if (info->size < 1024 * 1024) printf(" Size: %ld kB in %d Sectors\n", - info->size >> 10, info->sector_count); + info->size >> 10, info->sector_count); else printf(" Size: %ld MB in %d Sectors\n", - info->size >> 20, info->sector_count); + info->size >> 20, info->sector_count); printf(" "); switch (info->vendor) { case CFI_CMDSET_INTEL_PROG_REGIONS: @@ -1247,21 +1246,20 @@ void flash_print_info(flash_info_t *info) break; } printf(" command set, Manufacturer ID: 0x%02X, Device ID: 0x", - info->manufacturer_id); + info->manufacturer_id); printf(info->chipwidth == FLASH_CFI_16BIT ? "%04X" : "%02X", - info->device_id); + info->device_id); if ((info->device_id & 0xff) == 0x7E) { printf(info->chipwidth == FLASH_CFI_16BIT ? "%04X" : "%02X", - info->device_id2); + info->device_id2); } if (info->vendor == CFI_CMDSET_AMD_STANDARD && info->legacy_unlock) printf("\n Advanced Sector Protection (PPB) enabled"); printf("\n Erase timeout: %ld ms, write timeout: %ld ms\n", - info->erase_blk_tout, - info->write_tout); + info->erase_blk_tout, info->write_tout); if (info->buffer_size > 1) { printf(" Buffer write timeout: %ld ms, ", - info->buffer_write_tout); + info->buffer_write_tout); printf("buffer size: %d bytes\n", info->buffer_size); }
@@ -1274,13 +1272,13 @@ void flash_print_info(flash_info_t *info) #ifdef CONFIG_SYS_FLASH_EMPTY_INFO /* print empty and read-only info */ printf(" %08lX %c %s ", - info->start[i], - sector_erased(info, i) ? 'E' : ' ', - info->protect[i] ? "RO" : " "); + info->start[i], + sector_erased(info, i) ? 'E' : ' ', + info->protect[i] ? "RO" : " "); #else /* ! CONFIG_SYS_FLASH_EMPTY_INFO */ printf(" %08lX %s ", - info->start[i], - info->protect[i] ? "RO" : " "); + info->start[i], + info->protect[i] ? "RO" : " "); #endif } putc('\n'); @@ -1446,7 +1444,7 @@ static inline int manufact_match(flash_info_t *info, u32 manu) static int cfi_protect_bugfix(flash_info_t *info, long sector, int prot) { if (manufact_match(info, INTEL_MANUFACT) && - info->device_id == NUMONYX_256MBIT) { + info->device_id == NUMONYX_256MBIT) { /* * see errata called * "Numonyx Axcell P33/P30 Specification Update" :) @@ -1487,15 +1485,15 @@ int flash_real_protect(flash_info_t *info, long sector, int prot) case CFI_CMDSET_INTEL_EXTENDED: if (!cfi_protect_bugfix(info, sector, prot)) { flash_write_cmd(info, sector, 0, - FLASH_CMD_CLEAR_STATUS); + FLASH_CMD_CLEAR_STATUS); flash_write_cmd(info, sector, 0, - FLASH_CMD_PROTECT); + FLASH_CMD_PROTECT); if (prot) flash_write_cmd(info, sector, 0, - FLASH_CMD_PROTECT_SET); + FLASH_CMD_PROTECT_SET); else flash_write_cmd(info, sector, 0, - FLASH_CMD_PROTECT_CLEAR); + FLASH_CMD_PROTECT_CLEAR); } break; case CFI_CMDSET_AMD_EXTENDED: @@ -1516,7 +1514,7 @@ int flash_real_protect(flash_info_t *info, long sector, int prot) AMD_CMD_UNLOCK_START); if (info->device_id == ATM_ID_BV6416) flash_write_cmd(info, sector, - 0, ATM_CMD_UNLOCK_SECT); + 0, ATM_CMD_UNLOCK_SECT); } } if (info->legacy_unlock) { @@ -1530,29 +1528,29 @@ int flash_real_protect(flash_info_t *info, long sector, int prot) if (prot) { if (lock_flag) { flash_write_cmd(info, sector, 0, - AMD_CMD_PPB_LOCK_BC1); + AMD_CMD_PPB_LOCK_BC1); flash_write_cmd(info, sector, 0, - AMD_CMD_PPB_LOCK_BC2); + AMD_CMD_PPB_LOCK_BC2); } debug("sector %ld %slocked\n", sector, - lock_flag ? "" : "already "); + lock_flag ? "" : "already "); } else { if (!lock_flag) { debug("unlock %ld\n", sector); flash_write_cmd(info, 0, 0, - AMD_CMD_PPB_UNLOCK_BC1); + AMD_CMD_PPB_UNLOCK_BC1); flash_write_cmd(info, 0, 0, - AMD_CMD_PPB_UNLOCK_BC2); + AMD_CMD_PPB_UNLOCK_BC2); } debug("sector %ld %sunlocked\n", sector, - !lock_flag ? "" : "already "); + !lock_flag ? "" : "already "); } if (flag) enable_interrupts();
if (flash_status_check(info, sector, - info->erase_blk_tout, - prot ? "protect" : "unprotect")) + info->erase_blk_tout, + prot ? "protect" : "unprotect")) printf("status check error\n");
flash_write_cmd(info, 0, 0, @@ -1580,7 +1578,7 @@ int flash_real_protect(flash_info_t *info, long sector, int prot) */ flash_write_cmd(info, sector, 0, FLASH_CMD_READ_STATUS); retcode = flash_full_status_check(info, sector, info->erase_blk_tout, - prot ? "protect" : "unprotect"); + prot ? "protect" : "unprotect"); if (retcode == 0) { info->protect[sector] = prot;
@@ -1604,7 +1602,7 @@ int flash_real_protect(flash_info_t *info, long sector, int prot) * flash_read_user_serial - read the OneTimeProgramming cells */ void flash_read_user_serial(flash_info_t *info, void *buffer, int offset, - int len) + int len) { uchar *src; uchar *dst; @@ -1622,7 +1620,7 @@ void flash_read_user_serial(flash_info_t *info, void *buffer, int offset, * flash_read_factory_serial - read the device Id from the protection area */ void flash_read_factory_serial(flash_info_t *info, void *buffer, int offset, - int len) + int len) { uchar *src;
@@ -1667,7 +1665,7 @@ static void cmdset_intel_read_jedec_ids(flash_info_t *info) flash_write_cmd(info, 0, 0, FLASH_CMD_READ_ID); udelay(1000); /* some flash are slow to respond */ info->manufacturer_id = flash_read_uchar(info, - FLASH_OFFSET_MANUFACTURER_ID); + FLASH_OFFSET_MANUFACTURER_ID); info->device_id = (info->chipwidth == FLASH_CFI_16BIT) ? flash_read_word(info, FLASH_OFFSET_DEVICE_ID) : flash_read_uchar(info, FLASH_OFFSET_DEVICE_ID); @@ -1684,8 +1682,8 @@ static int cmdset_intel_init(flash_info_t *info, struct cfi_qry *qry) #ifdef CONFIG_SYS_FLASH_PROTECTION /* read legacy lock/unlock bit from intel flash */ if (info->ext_addr) { - info->legacy_unlock = flash_read_uchar(info, - info->ext_addr + 5) & 0x08; + info->legacy_unlock = + flash_read_uchar(info, info->ext_addr + 5) & 0x08; } #endif
@@ -1708,7 +1706,7 @@ static void cmdset_amd_read_jedec_ids(flash_info_t *info) while (manu_id == FLASH_CONTINUATION_CODE && bank_id < 0x800) { bank_id += 0x100; manu_id = flash_read_uchar(info, - bank_id | FLASH_OFFSET_MANUFACTURER_ID); + bank_id | FLASH_OFFSET_MANUFACTURER_ID); } info->manufacturer_id = manu_id;
@@ -1724,11 +1722,11 @@ static void cmdset_amd_read_jedec_ids(flash_info_t *info) switch (info->chipwidth) { case FLASH_CFI_8BIT: info->device_id = flash_read_uchar(info, - FLASH_OFFSET_DEVICE_ID); + FLASH_OFFSET_DEVICE_ID); if (info->device_id == 0x7E) { /* AMD 3-byte (expanded) device ids */ info->device_id2 = flash_read_uchar(info, - FLASH_OFFSET_DEVICE_ID2); + FLASH_OFFSET_DEVICE_ID2); info->device_id2 <<= 8; info->device_id2 |= flash_read_uchar(info, FLASH_OFFSET_DEVICE_ID3); @@ -1736,11 +1734,11 @@ static void cmdset_amd_read_jedec_ids(flash_info_t *info) break; case FLASH_CFI_16BIT: info->device_id = flash_read_word(info, - FLASH_OFFSET_DEVICE_ID); + FLASH_OFFSET_DEVICE_ID); if ((info->device_id & 0xff) == 0x7E) { /* AMD 3-byte (expanded) device ids */ info->device_id2 = flash_read_uchar(info, - FLASH_OFFSET_DEVICE_ID2); + FLASH_OFFSET_DEVICE_ID2); info->device_id2 <<= 8; info->device_id2 |= flash_read_uchar(info, FLASH_OFFSET_DEVICE_ID3); @@ -1821,7 +1819,7 @@ static int flash_detect_legacy(phys_addr_t base, int banknum) info->portwidth, MAP_NOCACHE); if (info->portwidth == FLASH_CFI_8BIT && - info->interface == FLASH_CFI_X8X16) { + info->interface == FLASH_CFI_X8X16) { info->addr_unlock1 = 0x2AAA; info->addr_unlock2 = 0x5555; } else { @@ -1830,9 +1828,9 @@ static int flash_detect_legacy(phys_addr_t base, int banknum) } flash_read_jedec_ids(info); debug("JEDEC PROBE: ID %x %x %x\n", - info->manufacturer_id, - info->device_id, - info->device_id2); + info->manufacturer_id, + info->device_id, + info->device_id2); if (jedec_flash_match(info, info->start[0])) break;
@@ -1869,8 +1867,8 @@ static inline int flash_detect_legacy(phys_addr_t base, int banknum) * detect if flash is compatible with the Common Flash Interface (CFI) * http://www.jedec.org/download/search/jesd68.pdf */ -static void flash_read_cfi(flash_info_t *info, void *buf, - unsigned int start, size_t len) +static void flash_read_cfi(flash_info_t *info, void *buf, unsigned int start, + size_t len) { u8 *p = buf; unsigned int i; @@ -1904,22 +1902,22 @@ static int __flash_detect_cfi(flash_info_t *info, struct cfi_qry *qry) for (cfi_offset = 0; cfi_offset < ARRAY_SIZE(flash_offset_cfi); cfi_offset++) { flash_write_cmd(info, 0, flash_offset_cfi[cfi_offset], - FLASH_CMD_CFI); + FLASH_CMD_CFI); if (flash_isequal(info, 0, FLASH_OFFSET_CFI_RESP, 'Q') && flash_isequal(info, 0, FLASH_OFFSET_CFI_RESP + 1, 'R') && flash_isequal(info, 0, FLASH_OFFSET_CFI_RESP + 2, 'Y')) { - flash_read_cfi(info, qry, FLASH_OFFSET_CFI_RESP, - sizeof(struct cfi_qry)); + flash_read_cfi(info, qry, FLASH_OFFSET_CFI_RESP, + sizeof(struct cfi_qry)); info->interface = le16_to_cpu(qry->interface_desc);
info->cfi_offset = flash_offset_cfi[cfi_offset]; debug("device interface is %d\n", - info->interface); + info->interface); debug("found port %d chip %d ", - info->portwidth, info->chipwidth); + info->portwidth, info->chipwidth); debug("port %d bits chip %d bits\n", - info->portwidth << CFI_FLASH_SHIFT_WIDTH, - info->chipwidth << CFI_FLASH_SHIFT_WIDTH); + info->portwidth << CFI_FLASH_SHIFT_WIDTH, + info->chipwidth << CFI_FLASH_SHIFT_WIDTH);
/* calculate command offsets as in the Linux driver */ info->addr_unlock1 = 0x555; @@ -2051,11 +2049,11 @@ static void flash_fixup_num(flash_info_t *info, struct cfi_qry *qry) * So adjust the buffer size for M29EW while operating in 8-bit mode */ if (qry->max_buf_write_size > 0x8 && - info->device_id == 0x7E && - (info->device_id2 == 0x2201 || - info->device_id2 == 0x2301 || - info->device_id2 == 0x2801 || - info->device_id2 == 0x4801)) { + info->device_id == 0x7E && + (info->device_id2 == 0x2201 || + info->device_id2 == 0x2301 || + info->device_id2 == 0x2801 || + info->device_id2 == 0x4801)) { debug("Adjusted buffer size on Numonyx flash"); debug(" M29EW family in 8 bit mode\n"); qry->max_buf_write_size = 0x8; @@ -2118,7 +2116,7 @@ ulong flash_get_size(phys_addr_t base, int banknum) break; default: printf("CFI: Unknown command set 0x%x\n", - info->vendor); + info->vendor); /* * Unfortunately, this means we don't know how * to get the chip back to Read mode. Might @@ -2157,12 +2155,12 @@ ulong flash_get_size(phys_addr_t base, int banknum) size_ratio = info->portwidth / info->chipwidth; /* if the chip is x8/x16 reduce the ratio by half */ if (info->interface == FLASH_CFI_X8X16 && - info->chipwidth == FLASH_CFI_BY8) { + info->chipwidth == FLASH_CFI_BY8) { size_ratio >>= 1; } debug("size_ratio %d port %d bits chip %d bits\n", - size_ratio, info->portwidth << CFI_FLASH_SHIFT_WIDTH, - info->chipwidth << CFI_FLASH_SHIFT_WIDTH); + size_ratio, info->portwidth << CFI_FLASH_SHIFT_WIDTH, + info->chipwidth << CFI_FLASH_SHIFT_WIDTH); info->size = 1 << qry.dev_size; /* multiply the size by the number of chips */ info->size *= size_ratio; @@ -2177,7 +2175,7 @@ ulong flash_get_size(phys_addr_t base, int banknum) for (i = 0; i < num_erase_regions; i++) { if (i > NUM_ERASE_REGIONS) { printf("%d erase regions found, only %d used\n", - num_erase_regions, NUM_ERASE_REGIONS); + num_erase_regions, NUM_ERASE_REGIONS); break; }
@@ -2221,8 +2219,8 @@ ulong flash_get_size(phys_addr_t base, int banknum) FLASH_CMD_READ_ID); info->protect[sect_cnt] = flash_isset(info, sect_cnt, - FLASH_OFFSET_PROTECT, - FLASH_STATUS_PROTECT); + FLASH_OFFSET_PROTECT, + FLASH_STATUS_PROTECT); flash_write_cmd(info, sect_cnt, 0, FLASH_CMD_RESET); break; @@ -2332,25 +2330,25 @@ static void flash_protect_default(void) #if (CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE) && \ (!defined(CONFIG_MONITOR_IS_IN_RAM)) flash_protect(FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE + monitor_flash_len - 1, - flash_get_info(CONFIG_SYS_MONITOR_BASE)); + CONFIG_SYS_MONITOR_BASE, + CONFIG_SYS_MONITOR_BASE + monitor_flash_len - 1, + flash_get_info(CONFIG_SYS_MONITOR_BASE)); #endif
/* Environment protection ON by default */ #ifdef CONFIG_ENV_IS_IN_FLASH flash_protect(FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE - 1, - flash_get_info(CONFIG_ENV_ADDR)); + CONFIG_ENV_ADDR, + CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE - 1, + flash_get_info(CONFIG_ENV_ADDR)); #endif
/* Redundant environment protection ON by default */ #ifdef CONFIG_ENV_ADDR_REDUND flash_protect(FLAG_PROTECT_SET, - CONFIG_ENV_ADDR_REDUND, - CONFIG_ENV_ADDR_REDUND + CONFIG_ENV_SECT_SIZE - 1, - flash_get_info(CONFIG_ENV_ADDR_REDUND)); + CONFIG_ENV_ADDR_REDUND, + CONFIG_ENV_ADDR_REDUND + CONFIG_ENV_SECT_SIZE - 1, + flash_get_info(CONFIG_ENV_ADDR_REDUND)); #endif
#if defined(CONFIG_SYS_FLASH_AUTOPROTECT_LIST) @@ -2358,9 +2356,9 @@ static void flash_protect_default(void) debug("autoprotecting from %08lx to %08lx\n", apl[i].start, apl[i].start + apl[i].size - 1); flash_protect(FLAG_PROTECT_SET, - apl[i].start, - apl[i].start + apl[i].size - 1, - flash_get_info(apl[i].start)); + apl[i].start, + apl[i].start + apl[i].size - 1, + flash_get_info(apl[i].start)); } #endif } @@ -2396,8 +2394,8 @@ unsigned long flash_init(void) #ifndef CONFIG_SYS_FLASH_QUIET_TEST printf("## Unknown flash on Bank %d ", i + 1); printf("- Size = 0x%08lx = %ld MB\n", - flash_info[i].size, - flash_info[i].size >> 20); + flash_info[i].size, + flash_info[i].size >> 20); #endif /* CONFIG_SYS_FLASH_QUIET_TEST */ } #ifdef CONFIG_SYS_FLASH_PROTECTION @@ -2441,10 +2439,10 @@ unsigned long flash_init(void) * No legancy unlocking -> unlock all sectors */ flash_protect(FLAG_PROTECT_CLEAR, - flash_info[i].start[0], - flash_info[i].start[0] - + flash_info[i].size - 1, - &flash_info[i]); + flash_info[i].start[0], + flash_info[i].start[0] + + flash_info[i].size - 1, + &flash_info[i]); } } #endif /* CONFIG_SYS_FLASH_PROTECTION */ -- 2.11.0
The variable cfi_flash_num_flash_banks is defined iff CONFIG_SYS_MAX_FLASH_BANKS_DETECT is defined, but it is used unconditionally in the function cfi_flash_init_dm. This leads to a undefined variable compile error when CONFIG_SYS_MAX_FLASH_BANKS_DETECT is not defined, but DM is enabled.
Fix this by always defining the cfi_flash_num_flash_banks variable.
v1 -> v2: None
--- drivers/mtd/cfi_flash.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 347382f529..da44e6184e 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -91,6 +91,8 @@ static u16 cfi_flash_config_reg(int i)
#if defined(CONFIG_SYS_MAX_FLASH_BANKS_DETECT) int cfi_flash_num_flash_banks = CONFIG_SYS_MAX_FLASH_BANKS_DETECT; +#else +int cfi_flash_num_flash_banks; #endif
#ifdef CONFIG_CFI_FLASH /* for driver model */ -- 2.11.0
Make the cfi_flash driver compatible with a live device tree.
v1 -> v2: None
--- drivers/mtd/cfi_flash.c | 21 +++++++++++---------- 1 file changed, 11 insertions(+), 10 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index da44e6184e..e5509fe353 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -2461,27 +2461,28 @@ unsigned long flash_init(void) #ifdef CONFIG_CFI_FLASH /* for driver model */ static int cfi_flash_probe(struct udevice *dev) { - void *blob = (void *)gd->fdt_blob; - int node = dev_of_offset(dev); const fdt32_t *cell; - phys_addr_t addr; - int parent, addrc, sizec; + int addrc, sizec; int len, idx;
- parent = fdt_parent_offset(blob, node); - fdt_support_default_count_cells(blob, parent, &addrc, &sizec); - /* decode regs, there may be multiple reg tuples. */ - cell = fdt_getprop(blob, node, "reg", &len); + addrc = dev_read_addr_cells(dev); + sizec = dev_read_size_cells(dev); + + /* decode regs; there may be multiple reg tuples. */ + cell = dev_read_prop(dev, "reg", &len); if (!cell) return -ENOENT; idx = 0; len /= sizeof(fdt32_t); while (idx < len) { - addr = fdt_translate_address((void *)blob, - node, cell + idx); + phys_addr_t addr; + + addr = dev_translate_address(dev, cell + idx); + flash_info[cfi_flash_num_flash_banks].dev = dev; flash_info[cfi_flash_num_flash_banks].base = addr; cfi_flash_num_flash_banks++; + idx += addrc + sizec; } gd->bd->bi_flashstart = flash_info[0].base; -- 2.11.0
Hi Mario,
after applying these patches and running them through Travis, I'm getting a few errors.
Here some MIPS related errors:
configs/socfpga_de0_nano_soc_defconfig: /tmp/tmphcvND0:40: warning: overriding the value of CMD_PART. Old value: "y", new value: "y". configs/evb-rk3288_defconfig: /tmp/tmpmq3AJA:78: warning: overriding the value of USB. Old value: "y", new value: "y". configs/dragonboard410c_defconfig: /tmp/tmpVc91dr:47: warning: overriding the value of ENV_IS_IN_MMC. Old value: "y", new value: "y". Building current source for 42 boards (2 threads, 1 job per thread) mips: + boston32r2el + addr = dev_translate_address(dev, cell + idx); + ^ +drivers/mtd/built-in.o: In function `cfi_flash_probe': +drivers/mtd/cfi_flash.c:(.text.cfi_flash_probe+0xa8): undefined reference to `dev_translate_address' +make[1]: *** [u-boot] Error 1 +make: *** [sub-make] Error 2 w+drivers/mtd/cfi_flash.c: In function 'cfi_flash_probe': w+drivers/mtd/cfi_flash.c:2480:3: warning: implicit declaration of function 'dev_translate_address' [-Wimplicit-function-declaration] mips: + ap121 +arch/mips/dts/ap121.dtb: Warning (interrupts_property): Missing interrupt-parent for /ahb/apb/uart@18020000 +arch/mips/dts/ap121.dtb: Warning (interrupts_property): Missing interrupt-parent for /ahb/spi@1f000000 mips: + huawei_hg556a_ram + addr = dev_translate_address(dev, cell + idx); + ^ +drivers/mtd/built-in.o: In function `cfi_flash_probe': +drivers/mtd/cfi_flash.c:(.text.cfi_flash_probe+0xa4): undefined reference to `dev_translate_address' +make[1]: *** [u-boot] Error 1 +make: *** [sub-make] Error 2 w+drivers/mtd/cfi_flash.c: In function 'cfi_flash_probe': w+drivers/mtd/cfi_flash.c:2480:3: warning: implicit declaration of function 'dev_translate_address' [-Wimplicit-function-declaration] mips: + boston64r2 + addr = dev_translate_address(dev, cell + idx); + ^ +drivers/mtd/built-in.o: In function `cfi_flash_probe': +drivers/mtd/cfi_flash.c:2480: undefined reference to `dev_translate_address' +make[1]: *** [u-boot] Error 1 +make: *** [sub-make] Error 2 w+drivers/mtd/cfi_flash.c: In function 'cfi_flash_probe': w+drivers/mtd/cfi_flash.c:2480:3: warning: implicit declaration of function 'dev_translate_address' [-Wimplicit-function-declaration] mips: + boston32r2 + addr = dev_translate_address(dev, cell + idx); + ^ +drivers/mtd/built-in.o: In function `cfi_flash_probe': +drivers/mtd/cfi_flash.c:(.text.cfi_flash_probe+0xa8): undefined reference to `dev_translate_address' +make[1]: *** [u-boot] Error 1 +make: *** [sub-make] Error 2
And here some aarch64 related errors:
Building current source for 29 boards (2 threads, 1 job per thread) aarch64: + r8a77995_draak + addr = dev_translate_address(dev, cell + idx); + ^~~~~~~~~~~~~~~~~~~~~ +drivers/mtd/built-in.o: In function `cfi_flash_probe': +drivers/mtd/cfi_flash.c:2480: undefined reference to `dev_translate_address' +make[1]: *** [u-boot] Error 139 +make: *** [sub-make] Error 2 w+drivers/mtd/cfi_flash.c: In function ?cfi_flash_probe?: w+drivers/mtd/cfi_flash.c:2480:10: warning: implicit declaration of function ?dev_translate_address? [-Wimplicit-function-declaration] aarch64: + rpi_3 +arch/arm/dts/bcm2835-rpi-a-plus.dtb: Warning (phys_property): Missing property '#phy-cells' in node /phy or bad phandle (referred from /soc/usb@7e980000:phys[0]) +arch/arm/dts/bcm2835-rpi-a.dtb: Warning (phys_property): Missing property '#phy-cells' in node /phy or bad phandle (referred from /soc/usb@7e980000:phys[0]) +arch/arm/dts/bcm2835-rpi-b-plus.dtb: Warning (phys_property): Missing property '#phy-cells' in node /phy or bad phandle (referred from /soc/usb@7e980000:phys[0]) +arch/arm/dts/bcm2835-rpi-b-rev2.dtb: Warning (phys_property): Missing property '#phy-cells' in node /phy or bad phandle (referred from /soc/usb@7e980000:phys[0]) +arch/arm/dts/bcm2835-rpi-b.dtb: Warning (phys_property): Missing property '#phy-cells' in node /phy or bad phandle (referred from /soc/usb@7e980000:phys[0]) +arch/arm/dts/bcm2836-rpi-2-b.dtb: Warning (phys_property): Missing property '#phy-cells' in node /phy or bad phandle (referred from /soc/usb@7e980000:phys[0]) +arch/arm/dts/bcm2837-rpi-3-b.dtb: Warning (phys_property): Missing property '#phy-cells' in node /phy or bad phandle (referred from /soc/usb@7e980000:phys[0]) 27 1 1 /29 hikey boards.cfg is up to date. Nothing to do. Summary of current source for 29 boards (2 threads, 1 job per thread) aarch64: + r8a77995_draak rpi_3 + addr = dev_translate_address(dev, cell + idx); + ^~~~~~~~~~~~~~~~~~~~~ +drivers/mtd/built-in.o: In function `cfi_flash_probe': +drivers/mtd/cfi_flash.c:2480: undefined reference to `dev_translate_address' +make[1]: *** [u-boot] Error 139 +make: *** [sub-make] Error 2
Could you please take a look and send a fixed version please?
Thanks, Stefan
On 15.01.2018 11:02, Mario Six wrote:
Signed-off-by: Mario Six mario.six@gdsys.cc
v1 -> v2: None
drivers/mtd/cfi_flash.c | 428 ++++++++++++++++++++++++------------------------ 1 file changed, 214 insertions(+), 214 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index f096e039cb..0dc7f4a6ba 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -204,7 +204,7 @@ unsigned long flash_sector_size(flash_info_t *info, flash_sect_t sect)
- create an address based on the offset and the port width
*/ static inline void * -flash_map (flash_info_t * info, flash_sect_t sect, uint offset) +flash_map(flash_info_t * info, flash_sect_t sect, uint offset) { unsigned int byte_offset = offset * info->portwidth;
@@ -247,17 +247,17 @@ static void flash_make_cmd(flash_info_t *info, u32 cmd, void *cmdbuf) /*-----------------------------------------------------------------------
- Debug support
*/ -static void print_longlong (char *str, unsigned long long data) +static void print_longlong(char *str, unsigned long long data) { int i; char *cp;
cp = (char *) &data; for (i = 0; i < 8; i++)
sprintf (&str[i * 2], "%2.2x", *cp++);
}sprintf(&str[i * 2], "%2.2x", *cp++);
-static void flash_printqry (struct cfi_qry *qry) +static void flash_printqry(struct cfi_qry *qry) { u8 *p = (u8 *)qry; int x, y; @@ -283,31 +283,31 @@ static void flash_printqry (struct cfi_qry *qry) /*-----------------------------------------------------------------------
- read a character at a port width address
*/ -static inline uchar flash_read_uchar (flash_info_t * info, uint offset) +static inline uchar flash_read_uchar(flash_info_t * info, uint offset) { uchar *cp; uchar retval;
- cp = flash_map (info, 0, offset);
- cp = flash_map(info, 0, offset); #if defined(__LITTLE_ENDIAN) || defined(CONFIG_SYS_WRITE_SWAPPED_DATA) retval = flash_read8(cp); #else retval = flash_read8(cp + info->portwidth - 1); #endif
- flash_unmap (info, 0, offset, cp);
flash_unmap(info, 0, offset, cp); return retval; }
- read a word at a port width address, assume 16bit bus
-static inline ushort flash_read_word (flash_info_t * info, uint offset) +static inline ushort flash_read_word(flash_info_t * info, uint offset) { ushort *addr, retval;
- addr = flash_map (info, 0, offset);
- retval = flash_read16 (addr);
- flash_unmap (info, 0, offset, addr);
- addr = flash_map(info, 0, offset);
- retval = flash_read16(addr);
- flash_unmap(info, 0, offset, addr); return retval; }
@@ -325,13 +325,13 @@ static ulong flash_read_long (flash_info_t * info, flash_sect_t sect, #ifdef DEBUG int x; #endif
- addr = flash_map (info, sect, offset);
addr = flash_map(info, sect, offset);
#ifdef DEBUG
- debug ("long addr is at %p info->portwidth = %d\n", addr,
- debug("long addr is at %p info->portwidth = %d\n", addr, info->portwidth); for (x = 0; x < 4 * info->portwidth; x++) {
debug ("addr[%x] = 0x%x\n", x, flash_read8(addr + x));
} #endif #if defined(__LITTLE_ENDIAN) || defined(CONFIG_SYS_WRITE_SWAPPED_DATA)debug("addr[%x] = 0x%x\n", x, flash_read8(addr + x));
@@ -360,22 +360,22 @@ static void flash_write_cmd(flash_info_t *info, flash_sect_t sect, void *addr; cfiword_t cword;
- flash_make_cmd (info, cmd, &cword);
- addr = flash_map(info, sect, offset);
- flash_make_cmd(info, cmd, &cword); switch (info->portwidth) { case FLASH_CFI_8BIT:
debug ("fwc addr %p cmd %x %x 8bit x %d bit\n", addr, cmd,
flash_write8(cword.w8, addr); break; case FLASH_CFI_16BIT:debug("fwc addr %p cmd %x %x 8bit x %d bit\n", addr, cmd, cword.w8, info->chipwidth << CFI_FLASH_SHIFT_WIDTH);
debug ("fwc addr %p cmd %x %4.4x 16bit x %d bit\n", addr,
flash_write16(cword.w16, addr); break; case FLASH_CFI_32BIT:debug("fwc addr %p cmd %x %4.4x 16bit x %d bit\n", addr, cmd, cword.w16, info->chipwidth << CFI_FLASH_SHIFT_WIDTH);
debug ("fwc addr %p cmd %x %8.8x 32bit x %d bit\n", addr,
flash_write32(cword.w32, addr);debug("fwc addr %p cmd %x %8.8x 32bit x %d bit\n", addr, cmd, cword.w32, info->chipwidth << CFI_FLASH_SHIFT_WIDTH);
@@ -385,9 +385,9 @@ static void flash_write_cmd(flash_info_t *info, flash_sect_t sect, { char str[20];
print_longlong (str, cword.w64);
debug ("fwrite addr %p cmd %x %s 64 bit x %d bit\n",
}debug("fwrite addr %p cmd %x %s 64 bit x %d bit\n", addr, cmd, str, info->chipwidth << CFI_FLASH_SHIFT_WIDTH);
@@ -402,36 +402,36 @@ static void flash_write_cmd(flash_info_t *info, flash_sect_t sect, flash_unmap(info, sect, offset, addr); }
-static void flash_unlock_seq (flash_info_t * info, flash_sect_t sect) +static void flash_unlock_seq(flash_info_t * info, flash_sect_t sect) {
- flash_write_cmd (info, sect, info->addr_unlock1, AMD_CMD_UNLOCK_START);
- flash_write_cmd (info, sect, info->addr_unlock2, AMD_CMD_UNLOCK_ACK);
flash_write_cmd(info, sect, info->addr_unlock1, AMD_CMD_UNLOCK_START);
flash_write_cmd(info, sect, info->addr_unlock2, AMD_CMD_UNLOCK_ACK); }
-static int flash_isequal (flash_info_t * info, flash_sect_t sect, +static int flash_isequal(flash_info_t * info, flash_sect_t sect, uint offset, uchar cmd) { void *addr; cfiword_t cword; int retval;
- debug ("is= cmd %x(%c) addr %p ", cmd, cmd, addr);
- debug("is= cmd %x(%c) addr %p ", cmd, cmd, addr); switch (info->portwidth) { case FLASH_CFI_8BIT:
debug ("is= %x %x\n", flash_read8(addr), cword.w8);
retval = (flash_read8(addr) == cword.w8); break; case FLASH_CFI_16BIT:debug("is= %x %x\n", flash_read8(addr), cword.w8);
debug ("is= %4.4x %4.4x\n", flash_read16(addr), cword.w16);
retval = (flash_read16(addr) == cword.w16); break; case FLASH_CFI_32BIT:debug("is= %4.4x %4.4x\n", flash_read16(addr), cword.w16);
debug ("is= %8.8x %8.8x\n", flash_read32(addr), cword.w32);
retval = (flash_read32(addr) == cword.w32); break; case FLASH_CFI_64BIT:debug("is= %8.8x %8.8x\n", flash_read32(addr), cword.w32);
@@ -440,9 +440,9 @@ static int flash_isequal (flash_info_t * info, flash_sect_t sect, char str1[20]; char str2[20];
print_longlong (str1, flash_read64(addr));
print_longlong (str2, cword.w64);
debug ("is= %s %s\n", str1, str2);
print_longlong(str1, flash_read64(addr));
print_longlong(str2, cword.w64);
} #endif retval = (flash_read64(addr) == cword.w64);debug("is= %s %s\n", str1, str2);
@@ -458,15 +458,15 @@ static int flash_isequal (flash_info_t * info, flash_sect_t sect,
/*----------------------------------------------------------------------- */ -static int flash_isset (flash_info_t * info, flash_sect_t sect, +static int flash_isset(flash_info_t * info, flash_sect_t sect, uint offset, uchar cmd) { void *addr; cfiword_t cword; int retval;
- flash_make_cmd(info, cmd, &cword); switch (info->portwidth) { case FLASH_CFI_8BIT: retval = ((flash_read8(addr) & cword.w8) == cword.w8);
@@ -491,15 +491,15 @@ static int flash_isset (flash_info_t * info, flash_sect_t sect,
/*----------------------------------------------------------------------- */ -static int flash_toggle (flash_info_t * info, flash_sect_t sect, +static int flash_toggle(flash_info_t * info, flash_sect_t sect, uint offset, uchar cmd) { void *addr; cfiword_t cword; int retval;
- flash_make_cmd(info, cmd, &cword); switch (info->portwidth) { case FLASH_CFI_8BIT: retval = flash_read8(addr) != flash_read8(addr);
@@ -529,7 +529,7 @@ static int flash_toggle (flash_info_t * info, flash_sect_t sect,
- This routine checks the status of the chip and returns true if the
- chip is busy.
*/ -static int flash_is_busy (flash_info_t * info, flash_sect_t sect) +static int flash_is_busy(flash_info_t * info, flash_sect_t sect) { int retval;
@@ -537,7 +537,7 @@ static int flash_is_busy (flash_info_t * info, flash_sect_t sect) case CFI_CMDSET_INTEL_PROG_REGIONS: case CFI_CMDSET_INTEL_STANDARD: case CFI_CMDSET_INTEL_EXTENDED:
retval = !flash_isset (info, sect, 0, FLASH_STATUS_DONE);
break; case CFI_CMDSET_AMD_STANDARD: case CFI_CMDSET_AMD_EXTENDED:retval = !flash_isset(info, sect, 0, FLASH_STATUS_DONE);
@@ -545,12 +545,12 @@ static int flash_is_busy (flash_info_t * info, flash_sect_t sect) case CFI_CMDSET_AMD_LEGACY: #endif if (info->sr_supported) {
flash_write_cmd(info, sect, info->addr_unlock1, FLASH_CMD_READ_STATUS);
} else {retval = !flash_isset(info, sect, 0, FLASH_STATUS_DONE);
retval = flash_toggle (info, sect, 0,
}retval = flash_toggle(info, sect, 0, AMD_STATUS_TOGGLE);
@@ -558,7 +558,7 @@ static int flash_is_busy (flash_info_t * info, flash_sect_t sect) default: retval = 0; }
- debug ("flash_is_busy: %d\n", retval);
- debug("flash_is_busy: %d\n", retval); return retval; }
@@ -566,7 +566,7 @@ static int flash_is_busy (flash_info_t * info, flash_sect_t sect)
- wait for XSR.7 to be set. Time out with an error if it does not.
- This routine does not set the flash to read-array mode.
*/ -static int flash_status_check (flash_info_t * info, flash_sect_t sector, +static int flash_status_check(flash_info_t * info, flash_sect_t sector, ulong tout, char *prompt) { ulong start; @@ -582,18 +582,18 @@ static int flash_status_check (flash_info_t * info, flash_sect_t sector, #ifdef CONFIG_SYS_LOW_RES_TIMER reset_timer(); #endif
- start = get_timer (0);
- start = get_timer(0); WATCHDOG_RESET();
- while (flash_is_busy (info, sector)) {
if (get_timer (start) > tout) {
printf ("Flash %s timeout at address %lx data %lx\n",
- while (flash_is_busy(info, sector)) {
printf("Flash %s timeout at address %lx data %lx\n", prompt, info->start[sector],
flash_read_long (info, sector, 0));
flash_write_cmd (info, sector, 0, info->cmd_reset);
}flash_write_cmd(info, sector, 0, info->cmd_reset); udelay(1); return ERR_TIMOUT;
udelay (1); /* also triggers watchdog */
} return ERR_OK; }udelay(1); /* also triggers watchdog */
@@ -604,12 +604,12 @@ static int flash_status_check (flash_info_t * info, flash_sect_t sector,
- This routine sets the flash to read-array mode.
*/ -static int flash_full_status_check (flash_info_t * info, flash_sect_t sector, +static int flash_full_status_check(flash_info_t * info, flash_sect_t sector, ulong tout, char *prompt) { int retcode;
- retcode = flash_status_check (info, sector, tout, prompt);
- retcode = flash_status_check(info, sector, tout, prompt); switch (info->vendor) { case CFI_CMDSET_INTEL_PROG_REGIONS: case CFI_CMDSET_INTEL_EXTENDED:
@@ -617,27 +617,27 @@ static int flash_full_status_check (flash_info_t * info, flash_sect_t sector, if ((retcode == ERR_OK) && !flash_isset(info, sector, 0, FLASH_STATUS_DONE)) { retcode = ERR_INVAL;
printf ("Flash %s error at address %lx\n", prompt,
printf("Flash %s error at address %lx\n", prompt, info->start[sector]);
if (flash_isset (info, sector, 0, FLASH_STATUS_ECLBS |
puts ("Command Sequence Error.\n");
} else if (flash_isset (info, sector, 0,
} else if (flash_isset(info, sector, 0, FLASH_STATUS_ECLBS)) {
puts ("Block Erase Error.\n");
puts("Block Erase Error.\n"); retcode = ERR_NOT_ERASED;
} else if (flash_isset(info, sector, 0, FLASH_STATUS_PSLBS)) {
puts ("Locking Error\n");
puts("Locking Error\n"); }
if (flash_isset (info, sector, 0, FLASH_STATUS_DPS)) {
puts ("Block locked.\n");
if (flash_isset(info, sector, 0, FLASH_STATUS_DPS)) {
puts("Block locked.\n"); retcode = ERR_PROTECTED; }
if (flash_isset (info, sector, 0, FLASH_STATUS_VPENS))
puts ("Vpp Low Error.\n");
if (flash_isset(info, sector, 0, FLASH_STATUS_VPENS))
}puts("Vpp Low Error.\n");
udelay(1); break; default:flash_write_cmd(info, sector, 0, info->cmd_reset);
@@ -709,7 +709,7 @@ static int flash_status_poll(flash_info_t *info, void *src, void *dst,
/*----------------------------------------------------------------------- */ -static void flash_add_byte (flash_info_t * info, cfiword_t * cword, uchar c) +static void flash_add_byte(flash_info_t * info, cfiword_t * cword, uchar c) { #if defined(__LITTLE_ENDIAN) && !defined(CONFIG_SYS_WRITE_SWAPPED_DATA) unsigned short w; @@ -755,7 +755,7 @@ static void flash_add_byte (flash_info_t * info, cfiword_t * cword, uchar c)
- Loop through the sector table starting from the previously found sector.
- Searches forwards or backwards, dependent on the passed address.
*/ -static flash_sect_t find_sector (flash_info_t * info, ulong addr) +static flash_sect_t find_sector(flash_info_t * info, ulong addr) { static flash_sect_t saved_sector; /* previously found sector */ static flash_info_t *saved_info; /* previously used flash bank */ @@ -781,7 +781,7 @@ static flash_sect_t find_sector (flash_info_t * info, ulong addr)
/*----------------------------------------------------------------------- */ -static int flash_write_cfiword (flash_info_t * info, ulong dest, +static int flash_write_cfiword(flash_info_t * info, ulong dest, cfiword_t cword) { void *dstaddr = (void *)dest; @@ -811,27 +811,27 @@ static int flash_write_cfiword (flash_info_t * info, ulong dest, return ERR_NOT_ERASED;
/* Disable interrupts which might cause a timeout here */
- flag = disable_interrupts ();
flag = disable_interrupts();
switch (info->vendor) { case CFI_CMDSET_INTEL_PROG_REGIONS: case CFI_CMDSET_INTEL_EXTENDED: case CFI_CMDSET_INTEL_STANDARD:
flash_write_cmd (info, 0, 0, FLASH_CMD_CLEAR_STATUS);
flash_write_cmd (info, 0, 0, FLASH_CMD_WRITE);
flash_write_cmd(info, 0, 0, FLASH_CMD_CLEAR_STATUS);
break; case CFI_CMDSET_AMD_EXTENDED: case CFI_CMDSET_AMD_STANDARD: sect = find_sector(info, dest);flash_write_cmd(info, 0, 0, FLASH_CMD_WRITE);
flash_unlock_seq (info, sect);
flash_write_cmd (info, sect, info->addr_unlock1, AMD_CMD_WRITE);
sect_found = 1; break; #ifdef CONFIG_FLASH_CFI_LEGACY case CFI_CMDSET_AMD_LEGACY: sect = find_sector(info, dest);flash_write_cmd(info, sect, info->addr_unlock1, AMD_CMD_WRITE);
flash_unlock_seq (info, 0);
flash_write_cmd (info, 0, info->addr_unlock1, AMD_CMD_WRITE);
flash_unlock_seq(info, 0);
sect_found = 1; break; #endifflash_write_cmd(info, 0, info->addr_unlock1, AMD_CMD_WRITE);
@@ -854,10 +854,10 @@ static int flash_write_cfiword (flash_info_t * info, ulong dest,
/* re-enable interrupts if necessary */ if (flag)
enable_interrupts ();
if (!sect_found)
sect = find_sector (info, dest);
if (use_flash_status_poll(info)) return flash_status_poll(info, &cword, dstaddr,
@@ -869,7 +869,7 @@ static int flash_write_cfiword (flash_info_t * info, ulong dest,
-static int flash_write_cfibuffer (flash_info_t * info, ulong dest, uchar * cp, +static int flash_write_cfibuffer(flash_info_t * info, ulong dest, uchar * cp, int len) { flash_sect_t sector; @@ -933,7 +933,7 @@ static int flash_write_cfibuffer (flash_info_t * info, ulong dest, uchar * cp, }
src = cp;
- sector = find_sector (info, dest);
sector = find_sector(info, dest);
@@ -941,17 +941,17 @@ static int flash_write_cfibuffer (flash_info_t * info, ulong dest, uchar * cp, case CFI_CMDSET_INTEL_EXTENDED: write_cmd = (info->vendor == CFI_CMDSET_INTEL_PROG_REGIONS) ? FLASH_CMD_WRITE_BUFFER_PROG : FLASH_CMD_WRITE_TO_BUFFER;
flash_write_cmd (info, sector, 0, FLASH_CMD_CLEAR_STATUS);
flash_write_cmd (info, sector, 0, FLASH_CMD_READ_STATUS);
flash_write_cmd (info, sector, 0, write_cmd);
if (retcode == ERR_OK) { /* reduce the number of loops by the width of * the port */ cnt = len >> shift;retcode = flash_status_check(info, sector, info->buffer_write_tout, "write to buffer");
flash_write_cmd (info, sector, 0, cnt - 1);
flash_write_cmd(info, sector, 0, cnt - 1); while (cnt-- > 0) { switch (info->portwidth) { case FLASH_CFI_8BIT:
@@ -975,9 +975,9 @@ static int flash_write_cfibuffer (flash_info_t * info, ulong dest, uchar * cp, goto out_unmap; } }
flash_write_cmd(info, sector, 0, FLASH_CMD_WRITE_BUFFER_CONFIRM);
retcode = flash_full_status_check (
}retcode = flash_full_status_check( info, sector, info->buffer_write_tout, "buffer write");
@@ -1025,7 +1025,7 @@ static int flash_write_cfibuffer (flash_info_t * info, ulong dest, uchar * cp, goto out_unmap; }
flash_write_cmd (info, sector, 0, AMD_CMD_WRITE_BUFFER_CONFIRM);
if (use_flash_status_poll(info)) retcode = flash_status_poll(info, src - (1 << shift), dst - (1 << shift),flash_write_cmd(info, sector, 0, AMD_CMD_WRITE_BUFFER_CONFIRM);
@@ -1038,7 +1038,7 @@ static int flash_write_cfibuffer (flash_info_t * info, ulong dest, uchar * cp, break;
default:
debug ("Unknown Command Set\n");
retcode = ERR_INVAL; break; }debug("Unknown Command Set\n");
@@ -1051,7 +1051,7 @@ out_unmap:
/*----------------------------------------------------------------------- */ -int flash_erase (flash_info_t * info, int s_first, int s_last) +int flash_erase(flash_info_t * info, int s_first, int s_last) { int rcode = 0; int prot; @@ -1059,11 +1059,11 @@ int flash_erase (flash_info_t * info, int s_first, int s_last) int st;
if (info->flash_id != FLASH_MAN_CFI) {
puts ("Can't erase unknown flash type - aborted\n");
return 1; } if ((s_first < 0) || (s_first > s_last)) {puts("Can't erase unknown flash type - aborted\n");
puts ("- no sectors to erase\n");
return 1; }puts("- no sectors to erase\n");
@@ -1074,10 +1074,10 @@ int flash_erase (flash_info_t * info, int s_first, int s_last) } } if (prot) {
printf ("- Warning: %d protected sectors will not be erased!\n",
} else if (flash_verbose) {printf("- Warning: %d protected sectors will not be erased!\n", prot);
putc ('\n');
}putc('\n');
@@ -1118,35 +1118,35 @@ int flash_erase (flash_info_t * info, int s_first, int s_last) case CFI_CMDSET_INTEL_PROG_REGIONS: case CFI_CMDSET_INTEL_STANDARD: case CFI_CMDSET_INTEL_EXTENDED:
flash_write_cmd (info, sect, 0,
flash_write_cmd(info, sect, 0, FLASH_CMD_CLEAR_STATUS);
flash_write_cmd(info, sect, 0, FLASH_CMD_BLOCK_ERASE);
flash_write_cmd(info, sect, 0, FLASH_CMD_ERASE_CONFIRM); break; case CFI_CMDSET_AMD_STANDARD: case CFI_CMDSET_AMD_EXTENDED:
flash_write_cmd(info, sect, info->addr_unlock1, AMD_CMD_ERASE_START);
#ifdef CONFIG_FLASH_CFI_LEGACY case CFI_CMDSET_AMD_LEGACY:flash_write_cmd(info, sect, 0, info->cmd_erase_sector); break;
flash_write_cmd(info, 0, info->addr_unlock1, AMD_CMD_ERASE_START);
#endif default:flash_write_cmd(info, sect, 0, AMD_CMD_ERASE_SECTOR); break;
debug ("Unkown flash vendor %d\n",
debug("Unkown flash vendor %d\n", info->vendor); break; }
@@ -1166,12 +1166,12 @@ int flash_erase (flash_info_t * info, int s_first, int s_last) if (st) rcode = 1; else if (flash_verbose)
putc ('.');
putc('.');
if (flash_verbose)
puts (" done\n");
puts(" done\n");
return rcode; }
@@ -1200,53 +1200,53 @@ static int sector_erased(flash_info_t *info, int i) } #endif /* CONFIG_SYS_FLASH_EMPTY_INFO */
-void flash_print_info (flash_info_t * info) +void flash_print_info(flash_info_t * info) { int i;
puts ("missing or unknown FLASH type\n");
return; }puts("missing or unknown FLASH type\n");
- printf ("%s flash (%d x %d)",
- printf("%s flash (%d x %d)", info->name, (info->portwidth << 3), (info->chipwidth << 3)); if (info->size < 1024*1024)
printf (" Size: %ld kB in %d Sectors\n",
elseprintf(" Size: %ld kB in %d Sectors\n", info->size >> 10, info->sector_count);
printf (" Size: %ld MB in %d Sectors\n",
printf(" Size: %ld MB in %d Sectors\n", info->size >> 20, info->sector_count);
- printf (" ");
- printf(" "); switch (info->vendor) { case CFI_CMDSET_INTEL_PROG_REGIONS:
printf ("Intel Prog Regions");
case CFI_CMDSET_INTEL_STANDARD:printf("Intel Prog Regions"); break;
printf ("Intel Standard");
case CFI_CMDSET_INTEL_EXTENDED:printf("Intel Standard"); break;
printf ("Intel Extended");
case CFI_CMDSET_AMD_STANDARD:printf("Intel Extended"); break;
printf ("AMD Standard");
case CFI_CMDSET_AMD_EXTENDED:printf("AMD Standard"); break;
printf ("AMD Extended");
#ifdef CONFIG_FLASH_CFI_LEGACY case CFI_CMDSET_AMD_LEGACY:printf("AMD Extended"); break;
printf ("AMD Legacy");
#endif default:printf("AMD Legacy"); break;
printf ("Unknown (%d)", info->vendor);
}printf("Unknown (%d)", info->vendor); break;
- printf (" command set, Manufacturer ID: 0x%02X, Device ID: 0x",
- printf(" command set, Manufacturer ID: 0x%02X, Device ID: 0x", info->manufacturer_id);
- printf (info->chipwidth == FLASH_CFI_16BIT ? "%04X" : "%02X",
- printf(info->chipwidth == FLASH_CFI_16BIT ? "%04X" : "%02X", info->device_id); if ((info->device_id & 0xff) == 0x7E) { printf(info->chipwidth == FLASH_CFI_16BIT ? "%04X" : "%02X",
@@ -1254,17 +1254,17 @@ void flash_print_info (flash_info_t * info) } if ((info->vendor == CFI_CMDSET_AMD_STANDARD) && (info->legacy_unlock)) printf("\n Advanced Sector Protection (PPB) enabled");
- printf ("\n Erase timeout: %ld ms, write timeout: %ld ms\n",
- printf("\n Erase timeout: %ld ms, write timeout: %ld ms\n", info->erase_blk_tout, info->write_tout); if (info->buffer_size > 1) {
printf (" Buffer write timeout: %ld ms, "
info->buffer_write_tout, info->buffer_size); }printf(" Buffer write timeout: %ld ms, " "buffer size: %d bytes\n",
- puts ("\n Sector Start Addresses:");
- puts("\n Sector Start Addresses:"); for (i = 0; i < info->sector_count; ++i) { if (ctrlc()) break;
@@ -1272,17 +1272,17 @@ void flash_print_info (flash_info_t * info) putc('\n'); #ifdef CONFIG_SYS_FLASH_EMPTY_INFO /* print empty and read-only info */
printf (" %08lX %c %s ",
#else /* ! CONFIG_SYS_FLASH_EMPTY_INFO */printf(" %08lX %c %s ", info->start[i], sector_erased(info, i) ? 'E' : ' ', info->protect[i] ? "RO" : " ");
printf (" %08lX %s ",
#endif }printf(" %08lX %s ", info->start[i], info->protect[i] ? "RO" : " ");
- putc ('\n');
- putc('\n'); return; }
@@ -1298,9 +1298,9 @@ void flash_print_info (flash_info_t * info) dots -= dots_sub; \ if ((scale > 0) && (dots <= 0)) { \ if ((digit % 5) == 0) \
printf ("%d", digit / 5); \
printf("%d", digit / 5); \ else \
putc ('.'); \
} \putc('.'); \ digit--; \ dots += scale; \
@@ -1315,7 +1315,7 @@ void flash_print_info (flash_info_t * info)
- 1 - write timeout
- 2 - Flash not erased
*/ -int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt) +int write_buff(flash_info_t * info, uchar * src, ulong addr, ulong cnt) { ulong wp; uchar *p; @@ -1347,16 +1347,16 @@ int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt) cword.w32 = 0; p = (uchar *)wp; for (i = 0; i < aln; ++i)
flash_add_byte (info, &cword, flash_read8(p + i));
flash_add_byte(info, &cword, flash_read8(p + i));
for (; (i < info->portwidth) && (cnt > 0); i++) {
flash_add_byte (info, &cword, *src++);
} for (; (cnt == 0) && (i < info->portwidth); ++i)flash_add_byte(info, &cword, *src++); cnt--;
rc = flash_write_cfiword (info, wp, cword);
if (rc != 0) return rc;rc = flash_write_cfiword(info, wp, cword);
@@ -1373,8 +1373,8 @@ int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt) if (info->buffer_size == 1) { cword.w32 = 0; for (i = 0; i < info->portwidth; i++)
if ((rc = flash_write_cfiword (info, wp, cword)) != 0)
if ((rc = flash_write_cfiword(info, wp, cword)) != 0) return rc; wp += info->portwidth; cnt -= info->portwidth;
@@ -1385,7 +1385,7 @@ int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt) i = buffered_size - (wp % buffered_size); if (i > cnt) i = cnt;
if ((rc = flash_write_cfibuffer (info, wp, src, i)) != ERR_OK)
i -= i & (info->portwidth - 1); wp += i;if ((rc = flash_write_cfibuffer(info, wp, src, i)) != ERR_OK) return rc;
@@ -1400,9 +1400,9 @@ int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt) while (cnt >= info->portwidth) { cword.w32 = 0; for (i = 0; i < info->portwidth; i++) {
}flash_add_byte(info, &cword, *src++);
wp += info->portwidth; cnt -= info->portwidth;if ((rc = flash_write_cfiword(info, wp, cword)) != 0) return rc;
@@ -1423,13 +1423,13 @@ int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt) cword.w32 = 0; p = (uchar *)wp; for (i = 0; (i < info->portwidth) && (cnt > 0); ++i) {
--cnt; } for (; i < info->portwidth; ++i)flash_add_byte(info, &cword, *src++);
- return flash_write_cfiword (info, wp, cword);
return flash_write_cfiword(info, wp, cword); }
@@ -1475,7 +1475,7 @@ static int cfi_protect_bugfix(flash_info_t *info, long sector, int prot) return 0; }
-int flash_real_protect (flash_info_t * info, long sector, int prot) +int flash_real_protect(flash_info_t * info, long sector, int prot) { int retcode = 0;
@@ -1502,19 +1502,19 @@ int flash_real_protect (flash_info_t * info, long sector, int prot) /* U-Boot only checks the first byte */ if (manufact_match(info, ATM_MANUFACT)) { if (prot) {
flash_write_cmd(info, 0, info->addr_unlock1, ATM_CMD_SOFTLOCK_START);
flash_write_cmd(info, sector, 0, ATM_CMD_LOCK_SECT); } else {
flash_write_cmd(info, 0, info->addr_unlock1, AMD_CMD_UNLOCK_START); if (info->device_id == ATM_ID_BV6416)
flash_write_cmd(info, sector, 0, ATM_CMD_UNLOCK_SECT); } }
@@ -1562,12 +1562,12 @@ int flash_real_protect (flash_info_t * info, long sector, int prot) break; #ifdef CONFIG_FLASH_CFI_LEGACY case CFI_CMDSET_AMD_LEGACY:
flash_write_cmd (info, sector, 0, FLASH_CMD_PROTECT);
flash_write_cmd (info, sector, 0, FLASH_CMD_PROTECT_SET);
flash_write_cmd(info, sector, 0, FLASH_CMD_PROTECT_SET); else
flash_write_cmd (info, sector, 0, FLASH_CMD_PROTECT_CLEAR);
#endif };flash_write_cmd(info, sector, 0, FLASH_CMD_PROTECT_CLEAR);
@@ -1577,7 +1577,7 @@ int flash_real_protect (flash_info_t * info, long sector, int prot) */ flash_write_cmd(info, sector, 0, FLASH_CMD_READ_STATUS); if ((retcode =
flash_full_status_check (info, sector, info->erase_blk_tout,
flash_full_status_check(info, sector, info->erase_blk_tout, prot ? "protect" : "unprotect")) == 0) {
@@ -1591,7 +1591,7 @@ int flash_real_protect (flash_info_t * info, long sector, int prot)
for (i = 0; i < info->sector_count; i++) { if (info->protect[i])
flash_real_protect (info, i, 1);
} }flash_real_protect(info, i, 1); }
@@ -1601,17 +1601,17 @@ int flash_real_protect (flash_info_t * info, long sector, int prot) /*-----------------------------------------------------------------------
- flash_read_user_serial - read the OneTimeProgramming cells
*/ -void flash_read_user_serial (flash_info_t * info, void *buffer, int offset, +void flash_read_user_serial(flash_info_t * info, void *buffer, int offset, int len) { uchar *src; uchar *dst;
dst = buffer;
- src = flash_map (info, 0, FLASH_OFFSET_USER_PROTECTION);
- flash_write_cmd (info, 0, 0, FLASH_CMD_READ_ID);
- memcpy (dst, src + offset, len);
- flash_write_cmd (info, 0, 0, info->cmd_reset);
- src = flash_map(info, 0, FLASH_OFFSET_USER_PROTECTION);
- flash_write_cmd(info, 0, 0, FLASH_CMD_READ_ID);
- memcpy(dst, src + offset, len);
- flash_write_cmd(info, 0, 0, info->cmd_reset); udelay(1); flash_unmap(info, 0, FLASH_OFFSET_USER_PROTECTION, src); }
@@ -1619,15 +1619,15 @@ void flash_read_user_serial (flash_info_t * info, void *buffer, int offset, /*
- flash_read_factory_serial - read the device Id from the protection area
*/ -void flash_read_factory_serial (flash_info_t * info, void *buffer, int offset, +void flash_read_factory_serial(flash_info_t * info, void *buffer, int offset, int len) { uchar *src;
- src = flash_map (info, 0, FLASH_OFFSET_INTEL_PROTECTION);
- memcpy (buffer, src + offset, len);
- src = flash_map(info, 0, FLASH_OFFSET_INTEL_PROTECTION);
- memcpy(buffer, src + offset, len);
- flash_write_cmd(info, 0, 0, info->cmd_reset); udelay(1); flash_unmap(info, 0, FLASH_OFFSET_INTEL_PROTECTION, src); }
@@ -1664,11 +1664,11 @@ static void cmdset_intel_read_jedec_ids(flash_info_t *info) udelay(1); flash_write_cmd(info, 0, 0, FLASH_CMD_READ_ID); udelay(1000); /* some flash are slow to respond */
- info->manufacturer_id = flash_read_uchar (info,
- info->manufacturer_id = flash_read_uchar(info, FLASH_OFFSET_MANUFACTURER_ID); info->device_id = (info->chipwidth == FLASH_CFI_16BIT) ?
flash_read_word (info, FLASH_OFFSET_DEVICE_ID) :
flash_read_uchar (info, FLASH_OFFSET_DEVICE_ID);
flash_write_cmd(info, 0, 0, FLASH_CMD_RESET); }flash_read_uchar(info, FLASH_OFFSET_DEVICE_ID);
@@ -1682,7 +1682,7 @@ static int cmdset_intel_init(flash_info_t *info, struct cfi_qry *qry) #ifdef CONFIG_SYS_FLASH_PROTECTION /* read legacy lock/unlock bit from intel flash */ if (info->ext_addr) {
info->legacy_unlock = flash_read_uchar (info,
} #endifinfo->legacy_unlock = flash_read_uchar(info, info->ext_addr + 5) & 0x08;
@@ -1701,11 +1701,11 @@ static void cmdset_amd_read_jedec_ids(flash_info_t *info) flash_write_cmd(info, 0, info->addr_unlock1, FLASH_CMD_READ_ID); udelay(1000); /* some flash are slow to respond */
- manuId = flash_read_uchar (info, FLASH_OFFSET_MANUFACTURER_ID);
- manuId = flash_read_uchar(info, FLASH_OFFSET_MANUFACTURER_ID); /* JEDEC JEP106Z specifies ID codes up to bank 7 */ while (manuId == FLASH_CONTINUATION_CODE && bankId < 0x800) { bankId += 0x100;
} info->manufacturer_id = manuId;manuId = flash_read_uchar(info, bankId | FLASH_OFFSET_MANUFACTURER_ID);
@@ -1721,26 +1721,26 @@ static void cmdset_amd_read_jedec_ids(flash_info_t *info)
switch (info->chipwidth){ case FLASH_CFI_8BIT:
info->device_id = flash_read_uchar (info,
if (info->device_id == 0x7E) { /* AMD 3-byte (expanded) device ids */info->device_id = flash_read_uchar(info, FLASH_OFFSET_DEVICE_ID);
info->device_id2 = flash_read_uchar (info,
info->device_id2 = flash_read_uchar(info, FLASH_OFFSET_DEVICE_ID2); info->device_id2 <<= 8;
info->device_id2 |= flash_read_uchar (info,
} break; case FLASH_CFI_16BIT:info->device_id2 |= flash_read_uchar(info, FLASH_OFFSET_DEVICE_ID3);
info->device_id = flash_read_word (info,
if ((info->device_id & 0xff) == 0x7E) { /* AMD 3-byte (expanded) device ids */info->device_id = flash_read_word(info, FLASH_OFFSET_DEVICE_ID);
} break;info->device_id2 |= flash_read_uchar(info, FLASH_OFFSET_DEVICE_ID3);
@@ -1771,7 +1771,7 @@ static int cmdset_amd_init(flash_info_t *info, struct cfi_qry *qry) }
#ifdef CONFIG_FLASH_CFI_LEGACY -static void flash_read_jedec_ids (flash_info_t * info) +static void flash_read_jedec_ids(flash_info_t * info) { info->manufacturer_id = 0; info->device_id = 0; @@ -1866,7 +1866,7 @@ static inline int flash_detect_legacy(phys_addr_t base, int banknum)
- detect if flash is compatible with the Common Flash Interface (CFI)
- http://www.jedec.org/download/search/jesd68.pdf
*/ -static void flash_read_cfi (flash_info_t *info, void *buf, +static void flash_read_cfi(flash_info_t *info, void *buf, unsigned int start, size_t len) { u8 *p = buf; @@ -1890,7 +1890,7 @@ static void __flash_cmd_reset(flash_info_t *info) void flash_cmd_reset(flash_info_t *info) __attribute__((weak,alias("__flash_cmd_reset")));
-static int __flash_detect_cfi (flash_info_t * info, struct cfi_qry *qry) +static int __flash_detect_cfi(flash_info_t * info, struct cfi_qry *qry) { int cfi_offset;
@@ -1899,21 +1899,21 @@ static int __flash_detect_cfi (flash_info_t * info, struct cfi_qry *qry)
flash_write_cmd (info, 0, flash_offset_cfi[cfi_offset],
flash_write_cmd(info, 0, flash_offset_cfi[cfi_offset], FLASH_CMD_CFI);
if (flash_isequal (info, 0, FLASH_OFFSET_CFI_RESP, 'Q')
&& flash_isequal (info, 0, FLASH_OFFSET_CFI_RESP + 1, 'R')
&& flash_isequal (info, 0, FLASH_OFFSET_CFI_RESP + 2, 'Y')) {
&& flash_isequal(info, 0, FLASH_OFFSET_CFI_RESP + 2, 'Y')) { flash_read_cfi(info, qry, FLASH_OFFSET_CFI_RESP, sizeof(struct cfi_qry)); info->interface = le16_to_cpu(qry->interface_desc); info->cfi_offset = flash_offset_cfi[cfi_offset];
debug ("device interface is %d\n",
debug("device interface is %d\n", info->interface);
debug ("found port %d chip %d ",
debug("found port %d chip %d ", info->portwidth, info->chipwidth);
debug ("port %d bits chip %d bits\n",
debug("port %d bits chip %d bits\n", info->portwidth << CFI_FLASH_SHIFT_WIDTH, info->chipwidth << CFI_FLASH_SHIFT_WIDTH);
@@ -1944,9 +1944,9 @@ static int __flash_detect_cfi (flash_info_t * info, struct cfi_qry *qry) return 0; }
-static int flash_detect_cfi (flash_info_t * info, struct cfi_qry *qry) +static int flash_detect_cfi(flash_info_t * info, struct cfi_qry *qry) {
- debug ("flash detect cfi\n");
debug("flash detect cfi\n");
for (info->portwidth = CONFIG_SYS_FLASH_CFI_WIDTH; info->portwidth <= FLASH_CFI_64BIT; info->portwidth <<= 1) {
@@ -1956,7 +1956,7 @@ static int flash_detect_cfi (flash_info_t * info, struct cfi_qry *qry) if (__flash_detect_cfi(info, qry)) return 1; }
- debug ("not found\n");
- debug("not found\n"); return 0; }
@@ -2063,7 +2063,7 @@ static void flash_fixup_num(flash_info_t *info, struct cfi_qry *qry)
- The following code cannot be run from FLASH!
*/ -ulong flash_get_size (phys_addr_t base, int banknum) +ulong flash_get_size(phys_addr_t base, int banknum) { flash_info_t *info = &flash_info[banknum]; int i, j; @@ -2087,20 +2087,20 @@ ulong flash_get_size (phys_addr_t base, int banknum)
info->start[0] = (ulong)map_physmem(base, info->portwidth, MAP_NOCACHE);
- if (flash_detect_cfi (info, &qry)) {
if (flash_detect_cfi(info, &qry)) { info->vendor = le16_to_cpu(get_unaligned(&(qry.p_id))); info->ext_addr = le16_to_cpu(get_unaligned(&(qry.p_adr))); num_erase_regions = qry.num_erase_regions;
info->cfi_version = (ushort) flash_read_uchar (info,
info->cfi_version = (ushort) flash_read_uchar(info, info->ext_addr + 3) << 8;
info->cfi_version |= (ushort) flash_read_uchar (info,
info->cfi_version |= (ushort) flash_read_uchar(info, info->ext_addr + 4);
#ifdef DEBUG
flash_printqry (&qry);
flash_printqry(&qry);
#endif
@@ -2145,11 +2145,11 @@ ulong flash_get_size (phys_addr_t base, int banknum) break; }
debug ("manufacturer is %d\n", info->vendor);
debug ("manufacturer id is 0x%x\n", info->manufacturer_id);
debug ("device id is 0x%x\n", info->device_id);
debug ("device id2 is 0x%x\n", info->device_id2);
debug ("cfi version is 0x%04x\n", info->cfi_version);
debug("manufacturer is %d\n", info->vendor);
debug("manufacturer id is 0x%x\n", info->manufacturer_id);
debug("device id is 0x%x\n", info->device_id);
debug("device id2 is 0x%x\n", info->device_id2);
debug("cfi version is 0x%04x\n", info->cfi_version);
@@ -2157,7 +2157,7 @@ ulong flash_get_size (phys_addr_t base, int banknum) && (info->chipwidth == FLASH_CFI_BY8)) { size_ratio >>= 1; }
debug ("size_ratio %d port %d bits chip %d bits\n",
info->size = 1 << qry.dev_size;debug("size_ratio %d port %d bits chip %d bits\n", size_ratio, info->portwidth << CFI_FLASH_SHIFT_WIDTH, info->chipwidth << CFI_FLASH_SHIFT_WIDTH);
@@ -2168,12 +2168,12 @@ ulong flash_get_size (phys_addr_t base, int banknum) debug("[truncated from %ldMiB]", info->size >> 20); info->size = max_size; }
debug ("found %d erase regions\n", num_erase_regions);
sect_cnt = 0; sector = base; for (i = 0; i < num_erase_regions; i++) { if (i > NUM_ERASE_REGIONS) {debug("found %d erase regions\n", num_erase_regions);
printf ("%d erase regions found, only %d used\n",
printf("%d erase regions found, only %d used\n", num_erase_regions, NUM_ERASE_REGIONS); break; }
@@ -2186,7 +2186,7 @@ ulong flash_get_size (phys_addr_t base, int banknum) tmp >>= 16; erase_region_size = (tmp & 0xffff) ? ((tmp & 0xffff) * 256) : 128;
debug ("erase_region_count = %d erase_region_size = %d\n",
debug("erase_region_count = %d erase_region_size = %d\n", erase_region_count, erase_region_size); for (j = 0; j < erase_region_count; j++) { if (sector - base >= info->size)
@@ -2217,7 +2217,7 @@ ulong flash_get_size (phys_addr_t base, int banknum) flash_write_cmd(info, sect_cnt, 0, FLASH_CMD_READ_ID); info->protect[sect_cnt] =
flash_isset (info, sect_cnt,
flash_isset(info, sect_cnt, FLASH_OFFSET_PROTECT, FLASH_STATUS_PROTECT); flash_write_cmd(info, sect_cnt, 0,
@@ -2274,7 +2274,7 @@ ulong flash_get_size (phys_addr_t base, int banknum) info->portwidth >>= 1; }
return (info->size);
@@ -2362,7 +2362,7 @@ static void flash_protect_default(void) #endif }
-unsigned long flash_init (void) +unsigned long flash_init(void) { unsigned long size = 0; int i; @@ -2390,7 +2390,7 @@ unsigned long flash_init (void) size += flash_info[i].size; if (flash_info[i].flash_id == FLASH_UNKNOWN) { #ifndef CONFIG_SYS_FLASH_QUIET_TEST
printf ("## Unknown flash on Bank %d "
printf("## Unknown flash on Bank %d " "- Size = 0x%08lx = %ld MB\n", i+1, flash_info[i].size, flash_info[i].size >> 20);
@@ -2422,7 +2422,7 @@ unsigned long flash_init (void) * unlock only one sector. This will * unlock all sectors. */
flash_real_protect (&flash_info[i], 0, 0);
flash_real_protect(&flash_info[i], 0, 0); flash_info[i].legacy_unlock = 1;
@@ -2436,7 +2436,7 @@ unsigned long flash_init (void) /* * No legancy unlocking -> unlock all sectors */
flash_protect (FLAG_PROTECT_CLEAR,
flash_protect(FLAG_PROTECT_CLEAR, flash_info[i].start[0], flash_info[i].start[0] + flash_info[i].size - 1,
-- 2.11.0
Viele Grüße, Stefan
Actual commit message in all those patches would be real nice to have.
Mario Six
Stefan Roese
