[PATCH v2] rtc: add support for rv3028 rtc
Add support for rtc3028 rtc from microcrystal. based on linux dirver: commit a38fd8748464: ("Linux 5.12-rc2")
Signed-off-by: Heiko Schocher hs@denx.de
Reviewed-by: Stefan Roese sr@denx.de --- Driver is based on code in linux, but with already corrected weekday usage. Linux codes the weekday bitwise, while the weekday register has only 3 valid bits as the app manual [1] says:
This register holds the current day of the week. Each value represents one weekday that is assigned by the user. Values will range from 0 to 6 The weekday counter is simply a 3-bit counter which counts up to 6 and then resets to 0.
[1] https://www.microcrystal.com/fileadmin/Media/Products/RTC/App.Manual/RV-3028...
This is not a big problem, as userspace never use weekday. Nevertheless, sent an update for the linux driver also:
https://marc.info/?l=linux-rtc&m=161529769106774&w=2
azure build: https://dev.azure.com/hs0298/hs/_build/results?buildId=64&view=results
Changes in v2: - add comments from Stefan - start sentence with upper-case - remove not needed includes, thanks! - add Reviewed-by from Stefan
drivers/rtc/Kconfig | 6 ++ drivers/rtc/Makefile | 1 + drivers/rtc/rv3028.c | 208 +++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 215 insertions(+) create mode 100644 drivers/rtc/rv3028.c
diff --git a/drivers/rtc/Kconfig b/drivers/rtc/Kconfig index aa6d90158c..e451308b40 100644 --- a/drivers/rtc/Kconfig +++ b/drivers/rtc/Kconfig @@ -95,6 +95,12 @@ config RTC_PCF8563 If you say yes here you get support for the Philips PCF8563 RTC and compatible chips.
+config RTC_RV3028 + bool "Enable RV3028 driver" + depends on DM_RTC + help + The MicroCrystal RV3028 is a I2C Real Time Clock (RTC) + config RTC_RV3029 bool "Enable RV3029 driver" depends on DM_RTC diff --git a/drivers/rtc/Makefile b/drivers/rtc/Makefile index 6a45a9c874..e7acd76266 100644 --- a/drivers/rtc/Makefile +++ b/drivers/rtc/Makefile @@ -46,6 +46,7 @@ obj-$(CONFIG_RTC_PCF2127) += pcf2127.o obj-$(CONFIG_RTC_PL031) += pl031.o obj-$(CONFIG_RTC_PT7C4338) += pt7c4338.o obj-$(CONFIG_RTC_RS5C372A) += rs5c372.o +obj-$(CONFIG_RTC_RV3028) += rv3028.o obj-$(CONFIG_RTC_RV3029) += rv3029.o obj-$(CONFIG_RTC_RV8803) += rv8803.o obj-$(CONFIG_RTC_RX8025) += rx8025.o diff --git a/drivers/rtc/rv3028.c b/drivers/rtc/rv3028.c new file mode 100644 index 0000000000..9f63afc14a --- /dev/null +++ b/drivers/rtc/rv3028.c @@ -0,0 +1,208 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * RTC driver for the Micro Crystal RV3028 + * + * based on linux driver from + * Copyright (C) 2019 Micro Crystal SA + * + * Alexandre Belloni alexandre.belloni@bootlin.com + * + */ + +#include <dm.h> +#include <i2c.h> +#include <rtc.h> + +#define RV3028_SEC 0x00 +#define RV3028_MIN 0x01 +#define RV3028_HOUR 0x02 +#define RV3028_WDAY 0x03 +#define RV3028_DAY 0x04 +#define RV3028_MONTH 0x05 +#define RV3028_YEAR 0x06 +#define RV3028_ALARM_MIN 0x07 +#define RV3028_ALARM_HOUR 0x08 +#define RV3028_ALARM_DAY 0x09 +#define RV3028_STATUS 0x0E +#define RV3028_CTRL1 0x0F +#define RV3028_CTRL2 0x10 +#define RV3028_EVT_CTRL 0x13 +#define RV3028_TS_COUNT 0x14 +#define RV3028_TS_SEC 0x15 +#define RV3028_RAM1 0x1F +#define RV3028_EEPROM_ADDR 0x25 +#define RV3028_EEPROM_DATA 0x26 +#define RV3028_EEPROM_CMD 0x27 +#define RV3028_CLKOUT 0x35 +#define RV3028_OFFSET 0x36 +#define RV3028_BACKUP 0x37 + +#define RV3028_STATUS_PORF BIT(0) +#define RV3028_STATUS_EVF BIT(1) +#define RV3028_STATUS_AF BIT(2) +#define RV3028_STATUS_TF BIT(3) +#define RV3028_STATUS_UF BIT(4) +#define RV3028_STATUS_BSF BIT(5) +#define RV3028_STATUS_CLKF BIT(6) +#define RV3028_STATUS_EEBUSY BIT(7) + +#define RV3028_CLKOUT_FD_MASK GENMASK(2, 0) +#define RV3028_CLKOUT_PORIE BIT(3) +#define RV3028_CLKOUT_CLKSY BIT(6) +#define RV3028_CLKOUT_CLKOE BIT(7) + +#define RV3028_CTRL1_EERD BIT(3) +#define RV3028_CTRL1_WADA BIT(5) + +#define RV3028_CTRL2_RESET BIT(0) +#define RV3028_CTRL2_12_24 BIT(1) +#define RV3028_CTRL2_EIE BIT(2) +#define RV3028_CTRL2_AIE BIT(3) +#define RV3028_CTRL2_TIE BIT(4) +#define RV3028_CTRL2_UIE BIT(5) +#define RV3028_CTRL2_TSE BIT(7) + +#define RV3028_EVT_CTRL_TSR BIT(2) + +#define RV3028_EEPROM_CMD_UPDATE 0x11 +#define RV3028_EEPROM_CMD_WRITE 0x21 +#define RV3028_EEPROM_CMD_READ 0x22 + +#define RV3028_EEBUSY_POLL 10000 +#define RV3028_EEBUSY_TIMEOUT 100000 + +#define RV3028_BACKUP_TCE BIT(5) +#define RV3028_BACKUP_TCR_MASK GENMASK(1, 0) + +#define OFFSET_STEP_PPT 953674 + +#define RTC_RV3028_LEN 7 + +static int rv3028_rtc_get(struct udevice *dev, struct rtc_time *tm) +{ + u8 regs[RTC_RV3028_LEN]; + u8 status; + int ret; + + ret = dm_i2c_read(dev, RV3028_STATUS, &status, 1); + if (ret < 0) { + printf("%s: error reading RTC status: %x\n", __func__, ret); + return -EIO; + } + + if (status & RV3028_STATUS_PORF) { + printf("Voltage low, data is invalid.\n"); + return -EINVAL; + } + + ret = dm_i2c_read(dev, RV3028_SEC, regs, sizeof(regs)); + if (ret < 0) { + printf("%s: error reading RTC: %x\n", __func__, ret); + return -EIO; + } + + tm->tm_sec = bcd2bin(regs[RV3028_SEC] & 0x7f); + tm->tm_min = bcd2bin(regs[RV3028_MIN] & 0x7f); + tm->tm_hour = bcd2bin(regs[RV3028_HOUR] & 0x3f); + tm->tm_wday = regs[RV3028_WDAY] & 0x7; + tm->tm_mday = bcd2bin(regs[RV3028_DAY] & 0x3f); + tm->tm_mon = bcd2bin(regs[RV3028_MONTH] & 0x1f); + tm->tm_year = bcd2bin(regs[RV3028_YEAR]) + 2000; + tm->tm_yday = 0; + tm->tm_isdst = 0; + + debug("%s: %4d-%02d-%02d (wday=%d) %2d:%02d:%02d\n", + __func__, tm->tm_year, tm->tm_mon, tm->tm_mday, + tm->tm_wday, tm->tm_hour, tm->tm_min, tm->tm_sec); + + return 0; +} + +static int rv3028_rtc_set(struct udevice *dev, const struct rtc_time *tm) +{ + u8 regs[RTC_RV3028_LEN]; + u8 status; + int ret; + + debug("%s: %4d-%02d-%02d (wday=%d( %2d:%02d:%02d\n", + __func__, tm->tm_year, tm->tm_mon, tm->tm_mday, + tm->tm_wday, tm->tm_hour, tm->tm_min, tm->tm_sec); + + if (tm->tm_year < 2000) { + printf("%s: year %d (before 2000) not supported\n", + __func__, tm->tm_year); + return -EINVAL; + } + + regs[RV3028_SEC] = bin2bcd(tm->tm_sec); + regs[RV3028_MIN] = bin2bcd(tm->tm_min); + regs[RV3028_HOUR] = bin2bcd(tm->tm_hour); + regs[RV3028_WDAY] = tm->tm_wday; + regs[RV3028_DAY] = bin2bcd(tm->tm_mday); + regs[RV3028_MONTH] = bin2bcd(tm->tm_mon); + regs[RV3028_YEAR] = bin2bcd(tm->tm_year - 2000); + + ret = dm_i2c_write(dev, RV3028_SEC, regs, sizeof(regs)); + if (ret) { + printf("%s: set rtc error: %d\n", __func__, ret); + return ret; + } + + ret = dm_i2c_read(dev, RV3028_STATUS, &status, 1); + if (ret < 0) { + printf("%s: error reading RTC status: %x\n", __func__, ret); + return -EIO; + } + status |= RV3028_STATUS_PORF; + return dm_i2c_write(dev, RV3028_STATUS, &status, 1); +} + +static int rv3028_rtc_reset(struct udevice *dev) +{ + return 0; +} + +static int rv3028_rtc_read8(struct udevice *dev, unsigned int reg) +{ + u8 data; + int ret; + + ret = dm_i2c_read(dev, reg, &data, sizeof(data)); + return ret < 0 ? ret : data; +} + +static int rv3028_rtc_write8(struct udevice *dev, unsigned int reg, int val) +{ + u8 data = val; + + return dm_i2c_write(dev, reg, &data, 1); +} + +static int rv3028_probe(struct udevice *dev) +{ + i2c_set_chip_flags(dev, DM_I2C_CHIP_RD_ADDRESS | + DM_I2C_CHIP_WR_ADDRESS); + + return 0; +} + +static const struct rtc_ops rv3028_rtc_ops = { + .get = rv3028_rtc_get, + .set = rv3028_rtc_set, + .read8 = rv3028_rtc_read8, + .write8 = rv3028_rtc_write8, + .reset = rv3028_rtc_reset, +}; + +static const struct udevice_id rv3028_rtc_ids[] = { + { .compatible = "microcrystal,rv3028" }, + { } +}; + +U_BOOT_DRIVER(rtc_rv3028) = { + .name = "rtc-rv3028", + .id = UCLASS_RTC, + .probe = rv3028_probe, + .of_match = rv3028_rtc_ids, + .ops = &rv3028_rtc_ops, +};
Heiko Schocher
