[PATCH] ARM: imx: imx8mn-*-evk: use DM settings for PHY configuration
With the correct settings described in the device-tree the PHY settings in the board init are no longer required. The values are taken from the linux device tree.
Suggested-by: Michael Walle michael@walle.cc Signed-off-by: Heiko Thiery heiko.thiery@gmail.com --- arch/arm/dts/imx8mn-evk.dtsi | 9 +++++++++ board/freescale/imx8mn_evk/imx8mn_evk.c | 16 ---------------- 2 files changed, 9 insertions(+), 16 deletions(-)
diff --git a/arch/arm/dts/imx8mn-evk.dtsi b/arch/arm/dts/imx8mn-evk.dtsi index 416fadb22b..4453a1a281 100644 --- a/arch/arm/dts/imx8mn-evk.dtsi +++ b/arch/arm/dts/imx8mn-evk.dtsi @@ -64,6 +64,15 @@ ethphy0: ethernet-phy@0 { compatible = "ethernet-phy-ieee802.3-c22"; reg = <0>; + reset-gpios = <&gpio4 22 GPIO_ACTIVE_LOW>; + reset-assert-us = <10000>; + qca,disable-smarteee; + vddio-supply = <&vddio>; + + vddio: vddio-regulator { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; }; }; }; diff --git a/board/freescale/imx8mn_evk/imx8mn_evk.c b/board/freescale/imx8mn_evk/imx8mn_evk.c index b24342fd5c..e35d505aea 100644 --- a/board/freescale/imx8mn_evk/imx8mn_evk.c +++ b/board/freescale/imx8mn_evk/imx8mn_evk.c @@ -27,22 +27,6 @@ static void setup_fec(void) clrsetbits_le32(&gpr->gpr[1], 0x2000, 0); }
-int board_phy_config(struct phy_device *phydev) -{ - /* enable rgmii rxc skew and phy mode select to RGMII copper */ - phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x1f); - phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x8); - - phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x00); - phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x82ee); - phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05); - phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x100); - - if (phydev->drv->config) - phydev->drv->config(phydev); - return 0; -} - int board_init(void) { setup_fec();
Am 2022-02-22 15:47, schrieb Heiko Thiery:
u-boot already has this property in the fec node. So it is now duplicated.
Both properties are documented in the bindings spec and it seems u-boot also supports both. So to be aligned with the linux dtb, I guess it should be kept here and the one in the fec node should be removed (?).
-michael
Heiko Thiery
Michael Walle
