[PATCH] imx: cmd: use struct cmd_tbl
cmd_tbl_t is removed, need use struct cmd_tbl
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/cmd_mfgprot.c | 2 +- arch/arm/mach-imx/priblob.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-imx/cmd_mfgprot.c b/arch/arm/mach-imx/cmd_mfgprot.c index 1e866b76c8..aed3b2f83d 100644 --- a/arch/arm/mach-imx/cmd_mfgprot.c +++ b/arch/arm/mach-imx/cmd_mfgprot.c @@ -29,7 +29,7 @@ DECLARE_GLOBAL_DATA_PTR; * Returns zero on success, CMD_RET_USAGE in case of misuse and negative * on error. */ -static int do_mfgprot(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +static int do_mfgprot(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { u8 *m_ptr, *dgst_ptr, *c_ptr, *d_ptr, *dst_ptr; char *pubk, *sign, *sel; diff --git a/arch/arm/mach-imx/priblob.c b/arch/arm/mach-imx/priblob.c index e253eddfdc..9b92eae781 100644 --- a/arch/arm/mach-imx/priblob.c +++ b/arch/arm/mach-imx/priblob.c @@ -15,7 +15,7 @@ #include <command.h> #include "../drivers/crypto/fsl_caam_internal.h"
-int do_priblob_write(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +int do_priblob_write(struct cmd_tbl *cmdtp, int flag, int argc, char * const argv[]) { writel((readl(CAAM_SCFGR) & 0xFFFFFFFC) | 3, CAAM_SCFGR); printf("New priblob setting = 0x%x\n", readl(CAAM_SCFGR) & 0x3);
Peng Fan (OSS)
