[U-Boot] [PATCH v4 0/4] Add SMDK5250 board support
This patchset add support for Samsung's SMDK5250 board based on EXYNOS5250 based SoC. It also adds support for MMC SPL booting.
The porting is done by Samsung engineers at HQ in System LSI Team. I am contributing in upstreaming the code for the board.
Based upon discussions following patches are dropped in this version: Exynos: Add CONFIG_EXYNOS4 Macro to EXYNOS4 based boards Exynos: Clock.c: Replace exynos4 prefix with exynos
SMDK5250: enable device tree support is squashed with EXYNOS: Add SMDK5250 board support
Chander Kashyap (4): Exynos: Clock.c: Use CONFIG_SYS_CLK_FREQ macro ARM: EXYNOS: Add support for Exynos5 based SoCs EXYNOS: Add SMDK5250 board support EXYNOS: SMDK5250: Add MMC SPL support
MAINTAINERS | 1 + arch/arm/cpu/armv7/exynos/clock.c | 214 ++++++++++- arch/arm/include/asm/arch-exynos/clock.h | 326 ++++++++++++++++ arch/arm/include/asm/arch-exynos/cpu.h | 35 ++- arch/arm/include/asm/arch-exynos/dmc.h | 146 +++++++ arch/arm/include/asm/arch-exynos/gpio.h | 99 +++++- arch/arm/include/asm/arch-exynos/tzpc.h | 52 +++ board/samsung/smdk5250/Makefile | 67 ++++ board/samsung/smdk5250/clock_init.c | 202 ++++++++++ board/samsung/smdk5250/dmc_init.c | 508 +++++++++++++++++++++++++ board/samsung/smdk5250/lowlevel_init.S | 96 +++++ board/samsung/smdk5250/mmc_boot.c | 58 +++ board/samsung/smdk5250/setup.h | 353 +++++++++++++++++ board/samsung/smdk5250/smdk5250.c | 152 ++++++++ board/samsung/smdk5250/tools/mkexynos_image.c | 117 ++++++ board/samsung/smdk5250/tzpc_init.c | 48 +++ boards.cfg | 1 + include/configs/s5pc210_universal.h | 1 + include/configs/smdk5250.h | 202 ++++++++++ include/configs/trats.h | 1 + 20 files changed, 2662 insertions(+), 17 deletions(-) create mode 100644 arch/arm/include/asm/arch-exynos/dmc.h create mode 100644 arch/arm/include/asm/arch-exynos/tzpc.h create mode 100644 board/samsung/smdk5250/Makefile create mode 100644 board/samsung/smdk5250/clock_init.c create mode 100644 board/samsung/smdk5250/dmc_init.c create mode 100644 board/samsung/smdk5250/lowlevel_init.S create mode 100644 board/samsung/smdk5250/mmc_boot.c create mode 100644 board/samsung/smdk5250/setup.h create mode 100644 board/samsung/smdk5250/smdk5250.c create mode 100644 board/samsung/smdk5250/tools/mkexynos_image.c create mode 100644 board/samsung/smdk5250/tzpc_init.c create mode 100644 include/configs/smdk5250.h
CONFIG_SYS_CLK_FREQ_C210 macro giving notion of S5PC2XX (Exynos4) architecture. Replace CONFIG_SYS_CLK_FREQ_C210 with CONFIG_SYS_CLK_FREQ to make it generic for exynos architecture.
Signed-off-by: Chander Kashyap chander.kashyap@linaro.org --- Changes for v2: - None Changes for v3: - None Changes for V4: - Added CONFIG_SYS_CLK_FREQ to trats.h
arch/arm/cpu/armv7/exynos/clock.c | 6 +----- include/configs/s5pc210_universal.h | 1 + include/configs/trats.h | 1 + 3 files changed, 3 insertions(+), 5 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/clock.c b/arch/arm/cpu/armv7/exynos/clock.c index 0c199cd..4d92c53 100644 --- a/arch/arm/cpu/armv7/exynos/clock.c +++ b/arch/arm/cpu/armv7/exynos/clock.c @@ -26,10 +26,6 @@ #include <asm/arch/clock.h> #include <asm/arch/clk.h>
-#ifndef CONFIG_SYS_CLK_FREQ_C210 -#define CONFIG_SYS_CLK_FREQ_C210 24000000 -#endif - /* exynos4: return pll clock frequency */ static unsigned long exynos4_get_pll_clk(int pllreg) { @@ -76,7 +72,7 @@ static unsigned long exynos4_get_pll_clk(int pllreg) /* SDIV [2:0] */ s = r & 0x7;
- freq = CONFIG_SYS_CLK_FREQ_C210; + freq = CONFIG_SYS_CLK_FREQ;
if (pllreg == EPLL) { k = k & 0xffff; diff --git a/include/configs/s5pc210_universal.h b/include/configs/s5pc210_universal.h index be000cb..8286680 100644 --- a/include/configs/s5pc210_universal.h +++ b/include/configs/s5pc210_universal.h @@ -49,6 +49,7 @@
/* input clock of PLL: Universal has 24MHz input clock at EXYNOS4210 */ #define CONFIG_SYS_CLK_FREQ_C210 24000000 +#define CONFIG_SYS_CLK_FREQ CONFIG_SYS_CLK_FREQ_C210
#define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_CMDLINE_TAG diff --git a/include/configs/trats.h b/include/configs/trats.h index acb3241..10f11d9 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -49,6 +49,7 @@
/* input clock of PLL: TRATS has 24MHz input clock at EXYNOS4210 */ #define CONFIG_SYS_CLK_FREQ_C210 24000000 +#define CONFIG_SYS_CLK_FREQ CONFIG_SYS_CLK_FREQ_C210
Samsung's ARM Cortex-A15 based SoCs are known as Exynos5 series of SoCs. This patch adds the support for Exynos5.
Signed-off-by: Chander Kashyap chander.kashyap@linaro.org --- Changes for v2: - This patch was part of "EXYNOS: Add SMDK5250 board support" - Now it is seprated as SoC support. Changes for v3: - Populated complete exynos5 gpio structures Changes for v4: - Added dmc.h and tzpc.h header files - Renamed EXYNOS5_PHY*_CTRL_BASE to EXYNOS5_DMC_PHY*_BASE
arch/arm/cpu/armv7/exynos/clock.c | 208 +++++++++++++++++++- arch/arm/include/asm/arch-exynos/clock.h | 326 ++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-exynos/cpu.h | 35 +++- arch/arm/include/asm/arch-exynos/dmc.h | 146 +++++++++++++ arch/arm/include/asm/arch-exynos/gpio.h | 99 +++++++++- arch/arm/include/asm/arch-exynos/tzpc.h | 52 +++++ 6 files changed, 854 insertions(+), 12 deletions(-) create mode 100644 arch/arm/include/asm/arch-exynos/dmc.h create mode 100644 arch/arm/include/asm/arch-exynos/tzpc.h
diff --git a/arch/arm/cpu/armv7/exynos/clock.c b/arch/arm/cpu/armv7/exynos/clock.c index 4d92c53..2f7048b 100644 --- a/arch/arm/cpu/armv7/exynos/clock.c +++ b/arch/arm/cpu/armv7/exynos/clock.c @@ -92,6 +92,72 @@ static unsigned long exynos4_get_pll_clk(int pllreg) return fout; }
+/* exynos5: return pll clock frequency */ +static unsigned long exynos5_get_pll_clk(int pllreg) +{ + struct exynos5_clock *clk = + (struct exynos5_clock *)samsung_get_base_clock(); + unsigned long r, m, p, s, k = 0, mask, fout; + unsigned int freq; + + switch (pllreg) { + case APLL: + r = readl(&clk->apll_con0); + break; + case MPLL: + r = readl(&clk->mpll_con0); + break; + case EPLL: + r = readl(&clk->epll_con0); + k = readl(&clk->epll_con1); + break; + case VPLL: + r = readl(&clk->vpll_con0); + k = readl(&clk->vpll_con1); + break; + default: + printf("Unsupported PLL (%d)\n", pllreg); + return 0; + } + + /* + * APLL_CON: MIDV [25:16] + * MPLL_CON: MIDV [25:16] + * EPLL_CON: MIDV [24:16] + * VPLL_CON: MIDV [24:16] + */ + if (pllreg == APLL || pllreg == MPLL) + mask = 0x3ff; + else + mask = 0x1ff; + + m = (r >> 16) & mask; + + /* PDIV [13:8] */ + p = (r >> 8) & 0x3f; + /* SDIV [2:0] */ + s = r & 0x7; + + freq = CONFIG_SYS_CLK_FREQ; + + if (pllreg == EPLL) { + k = k & 0xffff; + /* FOUT = (MDIV + K / 65536) * FIN / (PDIV * 2^SDIV) */ + fout = (m + k / 65536) * (freq / (p * (1 << s))); + } else if (pllreg == VPLL) { + k = k & 0xfff; + /* FOUT = (MDIV + K / 1024) * FIN / (PDIV * 2^SDIV) */ + fout = (m + k / 1024) * (freq / (p * (1 << s))); + } else { + if (s < 1) + s = 1; + /* FOUT = MDIV * FIN / (PDIV * 2^(SDIV - 1)) */ + fout = m * (freq / (p * (1 << (s - 1)))); + } + + return fout; +} + /* exynos4: return ARM clock frequency */ static unsigned long exynos4_get_arm_clk(void) { @@ -114,6 +180,28 @@ static unsigned long exynos4_get_arm_clk(void) return armclk; }
+/* exynos5: return ARM clock frequency */ +static unsigned long exynos5_get_arm_clk(void) +{ + struct exynos5_clock *clk = + (struct exynos5_clock *)samsung_get_base_clock(); + unsigned long div; + unsigned long armclk; + unsigned int arm_ratio; + unsigned int arm2_ratio; + + div = readl(&clk->div_cpu0); + + /* ARM_RATIO: [2:0], ARM2_RATIO: [30:28] */ + arm_ratio = (div >> 0) & 0x7; + arm2_ratio = (div >> 28) & 0x7; + + armclk = get_pll_clk(APLL) / (arm_ratio + 1); + armclk /= (arm2_ratio + 1); + + return armclk; +} + /* exynos4: return pwm clock frequency */ static unsigned long exynos4_get_pwm_clk(void) { @@ -157,6 +245,27 @@ static unsigned long exynos4_get_pwm_clk(void) return pclk; }
+/* exynos5: return pwm clock frequency */ +static unsigned long exynos5_get_pwm_clk(void) +{ + struct exynos5_clock *clk = + (struct exynos5_clock *)samsung_get_base_clock(); + unsigned long pclk, sclk; + unsigned int ratio; + + /* + * CLK_DIV_PERIC3 + * PWM_RATIO [3:0] + */ + ratio = readl(&clk->div_peric3); + ratio = ratio & 0xf; + sclk = get_pll_clk(MPLL); + + pclk = sclk / (ratio + 1); + + return pclk; +} + /* exynos4: return uart clock frequency */ static unsigned long exynos4_get_uart_clk(int dev_index) { @@ -204,6 +313,53 @@ static unsigned long exynos4_get_uart_clk(int dev_index) return uclk; }
+/* exynos5: return uart clock frequency */ +static unsigned long exynos5_get_uart_clk(int dev_index) +{ + struct exynos5_clock *clk = + (struct exynos5_clock *)samsung_get_base_clock(); + unsigned long uclk, sclk; + unsigned int sel; + unsigned int ratio; + + /* + * CLK_SRC_PERIC0 + * UART0_SEL [3:0] + * UART1_SEL [7:4] + * UART2_SEL [8:11] + * UART3_SEL [12:15] + * UART4_SEL [16:19] + * UART5_SEL [23:20] + */ + sel = readl(&clk->src_peric0); + sel = (sel >> (dev_index << 2)) & 0xf; + + if (sel == 0x6) + sclk = get_pll_clk(MPLL); + else if (sel == 0x7) + sclk = get_pll_clk(EPLL); + else if (sel == 0x8) + sclk = get_pll_clk(VPLL); + else + return 0; + + /* + * CLK_DIV_PERIC0 + * UART0_RATIO [3:0] + * UART1_RATIO [7:4] + * UART2_RATIO [8:11] + * UART3_RATIO [12:15] + * UART4_RATIO [16:19] + * UART5_RATIO [23:20] + */ + ratio = readl(&clk->div_peric0); + ratio = (ratio >> (dev_index << 2)) & 0xf; + + uclk = sclk / (ratio + 1); + + return uclk; +} + /* exynos4: set the mmc clock */ static void exynos4_set_mmc_clk(int dev_index, unsigned int div) { @@ -231,27 +387,69 @@ static void exynos4_set_mmc_clk(int dev_index, unsigned int div) writel(val, addr); }
+/* exynos5: set the mmc clock */ +static void exynos5_set_mmc_clk(int dev_index, unsigned int div) +{ + struct exynos5_clock *clk = + (struct exynos5_clock *)samsung_get_base_clock(); + unsigned int addr; + unsigned int val; + + /* + * CLK_DIV_FSYS1 + * MMC0_PRE_RATIO [15:8], MMC1_PRE_RATIO [31:24] + * CLK_DIV_FSYS2 + * MMC2_PRE_RATIO [15:8], MMC3_PRE_RATIO [31:24] + */ + if (dev_index < 2) { + addr = (unsigned int)&clk->div_fsys1; + } else { + addr = (unsigned int)&clk->div_fsys2; + dev_index -= 2; + } + + val = readl(addr); + val &= ~(0xff << ((dev_index << 4) + 8)); + val |= (div & 0xff) << ((dev_index << 4) + 8); + writel(val, addr); +} + unsigned long get_pll_clk(int pllreg) { - return exynos4_get_pll_clk(pllreg); + if (cpu_is_exynos5()) + return exynos5_get_pll_clk(pllreg); + else + return exynos4_get_pll_clk(pllreg); }
unsigned long get_arm_clk(void) { - return exynos4_get_arm_clk(); + if (cpu_is_exynos5()) + return exynos5_get_arm_clk(); + else + return exynos4_get_arm_clk(); }
unsigned long get_pwm_clk(void) { - return exynos4_get_pwm_clk(); + if (cpu_is_exynos5()) + return exynos5_get_pwm_clk(); + else + return exynos4_get_pwm_clk(); }
unsigned long get_uart_clk(int dev_index) { - return exynos4_get_uart_clk(dev_index); + if (cpu_is_exynos5()) + return exynos5_get_uart_clk(dev_index); + else + return exynos4_get_uart_clk(dev_index); }
void set_mmc_clk(int dev_index, unsigned int div) { - exynos4_set_mmc_clk(dev_index, div); + if (cpu_is_exynos5()) + exynos5_set_mmc_clk(dev_index, div); + else + exynos4_set_mmc_clk(dev_index, div); } diff --git a/arch/arm/include/asm/arch-exynos/clock.h b/arch/arm/include/asm/arch-exynos/clock.h index 483c911..50da958 100644 --- a/arch/arm/include/asm/arch-exynos/clock.h +++ b/arch/arm/include/asm/arch-exynos/clock.h @@ -250,6 +250,332 @@ struct exynos4_clock { unsigned int div_iem_l2; unsigned int div_iem_l1; }; + +struct exynos5_clock { + unsigned int apll_lock; + unsigned char res1[0xfc]; + unsigned int apll_con0; + unsigned int apll_con1; + unsigned char res2[0xf8]; + unsigned int src_cpu; + unsigned char res3[0x1fc]; + unsigned int mux_stat_cpu; + unsigned char res4[0xfc]; + unsigned int div_cpu0; + unsigned int div_cpu1; + unsigned char res5[0xf8]; + unsigned int div_stat_cpu0; + unsigned int div_stat_cpu1; + unsigned char res6[0x1f8]; + unsigned int gate_sclk_cpu; + unsigned char res7[0x1fc]; + unsigned int clkout_cmu_cpu; + unsigned int clkout_cmu_cpu_div_stat; + unsigned char res8[0x5f8]; + unsigned int armclk_stopctrl; + unsigned int atclk_stopctrl; + unsigned char res9[0x8]; + unsigned int parityfail_status; + unsigned int parityfail_clear; + unsigned char res10[0x8]; + unsigned int pwr_ctrl; + unsigned int pwr_ctr2; + unsigned char res11[0xd8]; + unsigned int apll_con0_l8; + unsigned int apll_con0_l7; + unsigned int apll_con0_l6; + unsigned int apll_con0_l5; + unsigned int apll_con0_l4; + unsigned int apll_con0_l3; + unsigned int apll_con0_l2; + unsigned int apll_con0_l1; + unsigned int iem_control; + unsigned char res12[0xdc]; + unsigned int apll_con1_l8; + unsigned int apll_con1_l7; + unsigned int apll_con1_l6; + unsigned int apll_con1_l5; + unsigned int apll_con1_l4; + unsigned int apll_con1_l3; + unsigned int apll_con1_l2; + unsigned int apll_con1_l1; + unsigned char res13[0xe0]; + unsigned int div_iem_l8; + unsigned int div_iem_l7; + unsigned int div_iem_l6; + unsigned int div_iem_l5; + unsigned int div_iem_l4; + unsigned int div_iem_l3; + unsigned int div_iem_l2; + unsigned int div_iem_l1; + unsigned char res14[0x2ce0]; + unsigned int mpll_lock; + unsigned char res15[0xfc]; + unsigned int mpll_con0; + unsigned int mpll_con1; + unsigned char res16[0xf8]; + unsigned int src_core0; + unsigned int src_core1; + unsigned char res17[0xf8]; + unsigned int src_mask_core; + unsigned char res18[0x100]; + unsigned int mux_stat_core1; + unsigned char res19[0xf8]; + unsigned int div_core0; + unsigned int div_core1; + unsigned char res20[0xf8]; + unsigned int div_stat_core0; + unsigned int div_stat_core1; + unsigned char res21[0x2f8]; + unsigned int gate_ip_core; + unsigned char res22[0xfc]; + unsigned int clkout_cmu_core; + unsigned int clkout_cmu_core_div_stat; + unsigned char res23[0x5f8]; + unsigned int dcgidx_map0; + unsigned int dcgidx_map1; + unsigned int dcgidx_map2; + unsigned char res24[0x14]; + unsigned int dcgperf_map0; + unsigned int dcgperf_map1; + unsigned char res25[0x18]; + unsigned int dvcidx_map; + unsigned char res26[0x1c]; + unsigned int freq_cpu; + unsigned int freq_dpm; + unsigned char res27[0x18]; + unsigned int dvsemclk_en; + unsigned int maxperf; + unsigned char res28[0x3478]; + unsigned int div_acp; + unsigned char res29[0xfc]; + unsigned int div_stat_acp; + unsigned char res30[0x1fc]; + unsigned int gate_ip_acp; + unsigned char res31[0x1fc]; + unsigned int clkout_cmu_acp; + unsigned int clkout_cmu_acp_div_stat; + unsigned char res32[0x38f8]; + unsigned int div_isp0; + unsigned int div_isp1; + unsigned int div_isp2; + unsigned char res33[0xf4]; + unsigned int div_stat_isp0; + unsigned int div_stat_isp1; + unsigned int div_stat_isp2; + unsigned char res34[0x3f4]; + unsigned int gate_ip_isp0; + unsigned int gate_ip_isp1; + unsigned char res35[0xf8]; + unsigned int gate_sclk_isp; + unsigned char res36[0xc]; + unsigned int mcuisp_pwr_ctrl; + unsigned char res37[0xec]; + unsigned int clkout_cmu_isp; + unsigned int clkout_cmu_isp_div_stat; + unsigned char res38[0x3618]; + unsigned int cpll_lock; + unsigned char res39[0xc]; + unsigned int epll_lock; + unsigned char res40[0xc]; + unsigned int vpll_lock; + unsigned char res41[0xdc]; + unsigned int cpll_con0; + unsigned int cpll_con1; + unsigned char res42[0x8]; + unsigned int epll_con0; + unsigned int epll_con1; + unsigned int epll_con2; + unsigned char res43[0x4]; + unsigned int vpll_con0; + unsigned int vpll_con1; + unsigned int vpll_con2; + unsigned char res44[0xc4]; + unsigned int src_top0; + unsigned int src_top1; + unsigned int src_top2; + unsigned int src_top3; + unsigned int src_gscl; + unsigned int src_disp0_0; + unsigned int src_disp0_1; + unsigned int src_disp1_0; + unsigned int src_disp1_1; + unsigned char res46[0xc]; + unsigned int src_mau; + unsigned int src_fsys; + unsigned char res47[0x8]; + unsigned int src_peric0; + unsigned int src_peric1; + unsigned char res48[0x18]; + unsigned int sclk_src_isp; + unsigned char res49[0x9c]; + unsigned int src_mask_top; + unsigned char res50[0xc]; + unsigned int src_mask_gscl; + unsigned int src_mask_disp0_0; + unsigned int src_mask_disp0_1; + unsigned int src_mask_disp1_0; + unsigned int src_mask_disp1_1; + unsigned int src_mask_maudio; + unsigned char res52[0x8]; + unsigned int src_mask_fsys; + unsigned char res53[0xc]; + unsigned int src_mask_peric0; + unsigned int src_mask_peric1; + unsigned char res54[0x18]; + unsigned int src_mask_isp; + unsigned char res55[0x9c]; + unsigned int mux_stat_top0; + unsigned int mux_stat_top1; + unsigned int mux_stat_top2; + unsigned int mux_stat_top3; + unsigned char res56[0xf0]; + unsigned int div_top0; + unsigned int div_top1; + unsigned char res57[0x8]; + unsigned int div_gscl; + unsigned int div_disp0_0; + unsigned int div_disp0_1; + unsigned int div_disp1_0; + unsigned int div_disp1_1; + unsigned char res59[0x8]; + unsigned int div_gen; + unsigned char res60[0x4]; + unsigned int div_mau; + unsigned int div_fsys0; + unsigned int div_fsys1; + unsigned int div_fsys2; + unsigned int div_fsys3; + unsigned int div_peric0; + unsigned int div_peric1; + unsigned int div_peric2; + unsigned int div_peric3; + unsigned int div_peric4; + unsigned int div_peric5; + unsigned char res61[0x10]; + unsigned int sclk_div_isp; + unsigned char res62[0xc]; + unsigned int div2_ratio0; + unsigned int div2_ratio1; + unsigned char res63[0x8]; + unsigned int div4_ratio; + unsigned char res64[0x6c]; + unsigned int div_stat_top0; + unsigned int div_stat_top1; + unsigned char res65[0x8]; + unsigned int div_stat_gscl; + unsigned int div_stat_disp0_0; + unsigned int div_stat_disp0_1; + unsigned int div_stat_disp1_0; + unsigned int div_stat_disp1_1; + unsigned char res67[0x8]; + unsigned int div_stat_gen; + unsigned char res68[0x4]; + unsigned int div_stat_maudio; + unsigned int div_stat_fsys0; + unsigned int div_stat_fsys1; + unsigned int div_stat_fsys2; + unsigned int div_stat_fsys3; + unsigned int div_stat_peric0; + unsigned int div_stat_peric1; + unsigned int div_stat_peric2; + unsigned int div_stat_peric3; + unsigned int div_stat_peric4; + unsigned int div_stat_peric5; + unsigned char res69[0x10]; + unsigned int sclk_div_stat_isp; + unsigned char res70[0xc]; + unsigned int div2_stat0; + unsigned int div2_stat1; + unsigned char res71[0x8]; + unsigned int div4_stat; + unsigned char res72[0x180]; + unsigned int gate_top_sclk_disp0; + unsigned int gate_top_sclk_disp1; + unsigned int gate_top_sclk_gen; + unsigned char res74[0xc]; + unsigned int gate_top_sclk_mau; + unsigned int gate_top_sclk_fsys; + unsigned char res75[0xc]; + unsigned int gate_top_sclk_peric; + unsigned char res76[0x1c]; + unsigned int gate_top_sclk_isp; + unsigned char res77[0xac]; + unsigned int gate_ip_gscl; + unsigned int gate_ip_disp0; + unsigned int gate_ip_disp1; + unsigned int gate_ip_mfc; + unsigned int gate_ip_g3d; + unsigned int gate_ip_gen; + unsigned char res79[0xc]; + unsigned int gate_ip_fsys; + unsigned char res80[0x4]; + unsigned int gate_ip_gps; + unsigned int gate_ip_peric; + unsigned char res81[0xc]; + unsigned int gate_ip_peris; + unsigned char res82[0x1c]; + unsigned int gate_block; + unsigned char res83[0x7c]; + unsigned int clkout_cmu_top; + unsigned int clkout_cmu_top_div_stat; + unsigned char res84[0x37f8]; + unsigned int src_lex; + unsigned char res85[0x2fc]; + unsigned int div_lex; + unsigned char res86[0xfc]; + unsigned int div_stat_lex; + unsigned char res87[0x1fc]; + unsigned int gate_ip_lex; + unsigned char res88[0x1fc]; + unsigned int clkout_cmu_lex; + unsigned int clkout_cmu_lex_div_stat; + unsigned char res89[0x3af8]; + unsigned int div_r0x; + unsigned char res90[0xfc]; + unsigned int div_stat_r0x; + unsigned char res91[0x1fc]; + unsigned int gate_ip_r0x; + unsigned char res92[0x1fc]; + unsigned int clkout_cmu_r0x; + unsigned int clkout_cmu_r0x_div_stat; + unsigned char res94[0x3af8]; + unsigned int div_r1x; + unsigned char res95[0xfc]; + unsigned int div_stat_r1x; + unsigned char res96[0x1fc]; + unsigned int gate_ip_r1x; + unsigned char res97[0x1fc]; + unsigned int clkout_cmu_r1x; + unsigned int clkout_cmu_r1x_div_stat; + unsigned char res98[0x3608]; + unsigned int bpll_lock; + unsigned char res99[0xfc]; + unsigned int bpll_con0; + unsigned int bpll_con1; + unsigned char res100[0xe8]; + unsigned int src_cdrex; + unsigned char res101[0x1fc]; + unsigned int mux_stat_cdrex; + unsigned char res102[0xfc]; + unsigned int div_cdrex; + unsigned int div_cdrex2; + unsigned char res103[0xf8]; + unsigned int div_stat_cdrex; + unsigned char res104[0x2fc]; + unsigned int gate_ip_cdrex; + unsigned char res105[0xc]; + unsigned int c2c_monitor; + unsigned int dmc_pwr_ctrl; + unsigned char res106[0x4]; + unsigned int drex2_pause; + unsigned char res107[0xe0]; + unsigned int clkout_cmu_cdrex; + unsigned int clkout_cmu_cdrex_div_stat; + unsigned char res108[0x8]; + unsigned int lpddr3phy_ctrl; + unsigned char res109[0xf5f8]; +}; #endif
#endif diff --git a/arch/arm/include/asm/arch-exynos/cpu.h b/arch/arm/include/asm/arch-exynos/cpu.h index 3496616..89f2c2e 100644 --- a/arch/arm/include/asm/arch-exynos/cpu.h +++ b/arch/arm/include/asm/arch-exynos/cpu.h @@ -22,6 +22,8 @@ #ifndef _EXYNOS4_CPU_H #define _EXYNOS4_CPU_H
+#define DEVICE_NOT_AVAILABLE 0 + #define EXYNOS4_ADDR_BASE 0x10000000
/* EXYNOS4 */ @@ -46,7 +48,34 @@ #define EXYNOS4_ADC_BASE 0x13910000 #define EXYNOS4_PWMTIMER_BASE 0x139D0000 #define EXYNOS4_MODEM_BASE 0x13A00000 -#define EXYNOS4_USBPHY_CONTROL 0x10020704 +#define EXYNOS4_USBPHY_CONTROL 0x10020704 + +#define EXYNOS4_GPIO_PART4_BASE DEVICE_NOT_AVAILABLE + +/* EXYNOS5 */ +#define EXYNOS5_GPIO_PART4_BASE 0x03860000 +#define EXYNOS5_PRO_ID 0x10000000 +#define EXYNOS5_CLOCK_BASE 0x10010000 +#define EXYNOS5_POWER_BASE 0x10040000 +#define EXYNOS5_SWRESET 0x10040400 +#define EXYNOS5_SYSREG_BASE 0x10050000 +#define EXYNOS5_WATCHDOG_BASE 0x101D0000 +#define EXYNOS5_DMC_PHY0_BASE 0x10C00000 +#define EXYNOS5_DMC_PHY1_BASE 0x10C10000 +#define EXYNOS5_GPIO_PART3_BASE 0x10D10000 +#define EXYNOS5_DMC_CTRL_BASE 0x10DD0000 +#define EXYNOS5_GPIO_PART1_BASE 0x11400000 +#define EXYNOS5_MMC_BASE 0x12200000 +#define EXYNOS5_SROMC_BASE 0x12250000 +#define EXYNOS5_USBOTG_BASE 0x12480000 +#define EXYNOS5_USBPHY_BASE 0x12480000 +#define EXYNOS5_UART_BASE 0x12C00000 +#define EXYNOS5_PWMTIMER_BASE 0x12DD0000 +#define EXYNOS5_GPIO_PART2_BASE 0x13400000 +#define EXYNOS5_FIMD_BASE 0x14400000 + +#define EXYNOS5_ADC_BASE DEVICE_NOT_AVAILABLE +#define EXYNOS5_MODEM_BASE DEVICE_NOT_AVAILABLE
#ifndef __ASSEMBLY__ #include <asm/io.h> @@ -83,12 +112,15 @@ static inline int cpu_is_##type(void) \ }
IS_SAMSUNG_TYPE(exynos4, 0xc210) +IS_SAMSUNG_TYPE(exynos5, 0xc520)
#define SAMSUNG_BASE(device, base) \ static inline unsigned int samsung_get_base_##device(void) \ { \ if (cpu_is_exynos4()) \ return EXYNOS4_##base; \ + else if (cpu_is_exynos5()) \ + return EXYNOS5_##base; \ else \ return 0; \ } @@ -99,6 +131,7 @@ SAMSUNG_BASE(fimd, FIMD_BASE) SAMSUNG_BASE(gpio_part1, GPIO_PART1_BASE) SAMSUNG_BASE(gpio_part2, GPIO_PART2_BASE) SAMSUNG_BASE(gpio_part3, GPIO_PART3_BASE) +SAMSUNG_BASE(gpio_part4, GPIO_PART4_BASE) SAMSUNG_BASE(pro_id, PRO_ID) SAMSUNG_BASE(mmc, MMC_BASE) SAMSUNG_BASE(modem, MODEM_BASE) diff --git a/arch/arm/include/asm/arch-exynos/dmc.h b/arch/arm/include/asm/arch-exynos/dmc.h new file mode 100644 index 0000000..debbe50 --- /dev/null +++ b/arch/arm/include/asm/arch-exynos/dmc.h @@ -0,0 +1,146 @@ +#ifndef __DMC_H__ +#define __DMC_H__ + +#ifndef __ASSEMBLY__ +struct exynos5_dmc { + unsigned int concontrol; + unsigned int memcontrol; + unsigned int memconfig0; + unsigned int memconfig1; + unsigned int directcmd; + unsigned int prechconfig; + unsigned int phycontrol0; + unsigned char res1[0xc]; + unsigned int pwrdnconfig; + unsigned int timingpzq; + unsigned int timingref; + unsigned int timingrow; + unsigned int timingdata; + unsigned int timingpower; + unsigned int phystatus; + unsigned char res2[0x4]; + unsigned int chipstatus_ch0; + unsigned int chipstatus_ch1; + unsigned char res3[0x4]; + unsigned int mrstatus; + unsigned char res4[0x8]; + unsigned int qoscontrol0; + unsigned char resr5[0x4]; + unsigned int qoscontrol1; + unsigned char res6[0x4]; + unsigned int qoscontrol2; + unsigned char res7[0x4]; + unsigned int qoscontrol3; + unsigned char res8[0x4]; + unsigned int qoscontrol4; + unsigned char res9[0x4]; + unsigned int qoscontrol5; + unsigned char res10[0x4]; + unsigned int qoscontrol6; + unsigned char res11[0x4]; + unsigned int qoscontrol7; + unsigned char res12[0x4]; + unsigned int qoscontrol8; + unsigned char res13[0x4]; + unsigned int qoscontrol9; + unsigned char res14[0x4]; + unsigned int qoscontrol10; + unsigned char res15[0x4]; + unsigned int qoscontrol11; + unsigned char res16[0x4]; + unsigned int qoscontrol12; + unsigned char res17[0x4]; + unsigned int qoscontrol13; + unsigned char res18[0x4]; + unsigned int qoscontrol14; + unsigned char res19[0x4]; + unsigned int qoscontrol15; + unsigned char res20[0x14]; + unsigned int ivcontrol; + unsigned int wrtra_config; + unsigned int rdlvl_config; + unsigned char res21[0x8]; + unsigned int brbrsvconfig; + unsigned int brbqosconfig; + unsigned int membaseconfig0; + unsigned int membaseconfig1; + unsigned char res22[0xc]; + unsigned int wrlvl_config; + unsigned char res23[0xc]; + unsigned int perevcontrol; + unsigned int perev0config; + unsigned int perev1config; + unsigned int perev2config; + unsigned int perev3config; + unsigned char res24[0xdebc]; + unsigned int pmnc_ppc_a; + unsigned char res25[0xc]; + unsigned int cntens_ppc_a; + unsigned char res26[0xc]; + unsigned int cntenc_ppc_a; + unsigned char res27[0xc]; + unsigned int intens_ppc_a; + unsigned char res28[0xc]; + unsigned int intenc_ppc_a; + unsigned char res29[0xc]; + unsigned int flag_ppc_a; + unsigned char res30[0xac]; + unsigned int ccnt_ppc_a; + unsigned char res31[0xc]; + unsigned int pmcnt0_ppc_a; + unsigned char res32[0xc]; + unsigned int pmcnt1_ppc_a; + unsigned char res33[0xc]; + unsigned int pmcnt2_ppc_a; + unsigned char res34[0xc]; + unsigned int pmcnt3_ppc_a; +}; + +struct exynos5_phy_control { + unsigned int phy_con0; + unsigned int phy_con1; + unsigned int phy_con2; + unsigned int phy_con3; + unsigned int phy_con4; + unsigned char res1[4]; + unsigned int phy_con6; + unsigned char res2[4]; + unsigned int phy_con8; + unsigned int phy_con9; + unsigned int phy_con10; + unsigned char res3[4]; + unsigned int phy_con12; + unsigned int phy_con13; + unsigned int phy_con14; + unsigned int phy_con15; + unsigned int phy_con16; + unsigned char res4[4]; + unsigned int phy_con17; + unsigned int phy_con18; + unsigned int phy_con19; + unsigned int phy_con20; + unsigned int phy_con21; + unsigned int phy_con22; + unsigned int phy_con23; + unsigned int phy_con24; + unsigned int phy_con25; + unsigned int phy_con26; + unsigned int phy_con27; + unsigned int phy_con28; + unsigned int phy_con29; + unsigned int phy_con30; + unsigned int phy_con31; + unsigned int phy_con32; + unsigned int phy_con33; + unsigned int phy_con34; + unsigned int phy_con35; + unsigned int phy_con36; + unsigned int phy_con37; + unsigned int phy_con38; + unsigned int phy_con39; + unsigned int phy_con40; + unsigned int phy_con41; + unsigned int phy_con42; +}; +#endif +#endif diff --git a/arch/arm/include/asm/arch-exynos/gpio.h b/arch/arm/include/asm/arch-exynos/gpio.h index 9863a12..7a9bb90 100644 --- a/arch/arm/include/asm/arch-exynos/gpio.h +++ b/arch/arm/include/asm/arch-exynos/gpio.h @@ -79,6 +79,59 @@ struct exynos4_gpio_part3 { struct s5p_gpio_bank z; };
+struct exynos5_gpio_part1 { + struct s5p_gpio_bank a0; + struct s5p_gpio_bank a1; + struct s5p_gpio_bank a2; + struct s5p_gpio_bank b0; + struct s5p_gpio_bank b1; + struct s5p_gpio_bank b2; + struct s5p_gpio_bank b3; + struct s5p_gpio_bank c0; + struct s5p_gpio_bank c1; + struct s5p_gpio_bank c2; + struct s5p_gpio_bank c3; + struct s5p_gpio_bank d0; + struct s5p_gpio_bank d1; + struct s5p_gpio_bank y0; + struct s5p_gpio_bank y1; + struct s5p_gpio_bank y2; + struct s5p_gpio_bank y3; + struct s5p_gpio_bank y4; + struct s5p_gpio_bank y5; + struct s5p_gpio_bank y6; + struct s5p_gpio_bank res1[0x980]; + struct s5p_gpio_bank x0; + struct s5p_gpio_bank x1; + struct s5p_gpio_bank x2; + struct s5p_gpio_bank x3; +}; + +struct exynos5_gpio_part2 { + struct s5p_gpio_bank e0; + struct s5p_gpio_bank e1; + struct s5p_gpio_bank f0; + struct s5p_gpio_bank f1; + struct s5p_gpio_bank g0; + struct s5p_gpio_bank g1; + struct s5p_gpio_bank g2; + struct s5p_gpio_bank h0; + struct s5p_gpio_bank h1; +}; + +struct exynos5_gpio_part3 { + struct s5p_gpio_bank v0; + struct s5p_gpio_bank v1; + struct s5p_gpio_bank v2; + struct s5p_gpio_bank v3; + struct s5p_gpio_bank res1[0x20]; + struct s5p_gpio_bank v4; +}; + +struct exynos5_gpio_part4 { + struct s5p_gpio_bank z; +}; + /* functions */ void s5p_gpio_cfg_pin(struct s5p_gpio_bank *bank, int gpio, int cfg); void s5p_gpio_direction_output(struct s5p_gpio_bank *bank, int gpio, int en); @@ -98,21 +151,55 @@ void s5p_gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode); - EXYNOS4_GPIO_PART1_BASE) / sizeof(struct s5p_gpio_bank)) \ * GPIO_PER_BANK) + pin)
-#define GPIO_PART1_MAX ((sizeof(struct exynos4_gpio_part1) \ +#define EXYNOS4_GPIO_PART1_MAX ((sizeof(struct exynos4_gpio_part1) \ / sizeof(struct s5p_gpio_bank)) * GPIO_PER_BANK)
#define exynos4_gpio_part2_get_nr(bank, pin) \ (((((((unsigned int) &(((struct exynos4_gpio_part2 *) \ EXYNOS4_GPIO_PART2_BASE)->bank)) \ - EXYNOS4_GPIO_PART2_BASE) / sizeof(struct s5p_gpio_bank)) \ - * GPIO_PER_BANK) + pin) + GPIO_PART1_MAX) + * GPIO_PER_BANK) + pin) + EXYNOS4_GPIO_PART1_MAX) + +#define exynos5_gpio_part1_get_nr(bank, pin) \ + ((((((unsigned int) &(((struct exynos5_gpio_part1 *) \ + EXYNOS5_GPIO_PART1_BASE)->bank)) \ + - EXYNOS5_GPIO_PART1_BASE) / sizeof(struct s5p_gpio_bank)) \ + * GPIO_PER_BANK) + pin) + +#define EXYNOS5_GPIO_PART1_MAX ((sizeof(struct exynos5_gpio_part1) \ + / sizeof(struct s5p_gpio_bank)) * GPIO_PER_BANK) + +#define exynos5_gpio_part2_get_nr(bank, pin) \ + (((((((unsigned int) &(((struct exynos5_gpio_part2 *) \ + EXYNOS5_GPIO_PART2_BASE)->bank)) \ + - EXYNOS5_GPIO_PART2_BASE) / sizeof(struct s5p_gpio_bank)) \ + * GPIO_PER_BANK) + pin) + EXYNOS5_GPIO_PART1_MAX) + +#define EXYNOS5_GPIO_PART2_MAX ((sizeof(struct exynos5_gpio_part2) \ + / sizeof(struct s5p_gpio_bank)) * GPIO_PER_BANK) + +#define exynos5_gpio_part3_get_nr(bank, pin) \ + (((((((unsigned int) &(((struct exynos5_gpio_part3 *) \ + EXYNOS5_GPIO_PART3_BASE)->bank)) \ + - EXYNOS5_GPIO_PART3_BASE) / sizeof(struct s5p_gpio_bank)) \ + * GPIO_PER_BANK) + pin) + EXYNOS5_GPIO_PART2_MAX)
static inline unsigned int s5p_gpio_base(int nr) { - if (nr < GPIO_PART1_MAX) - return EXYNOS4_GPIO_PART1_BASE; - else - return EXYNOS4_GPIO_PART2_BASE; + if (cpu_is_exynos5()) { + if (nr < EXYNOS5_GPIO_PART1_MAX) + return EXYNOS5_GPIO_PART1_BASE; + else if (nr < EXYNOS5_GPIO_PART2_MAX) + return EXYNOS5_GPIO_PART2_BASE; + else + return EXYNOS5_GPIO_PART3_BASE; + + } else if (cpu_is_exynos4()) { + if (nr < EXYNOS4_GPIO_PART1_MAX) + return EXYNOS4_GPIO_PART1_BASE; + else + return EXYNOS4_GPIO_PART2_BASE; + }
return 0; } diff --git a/arch/arm/include/asm/arch-exynos/tzpc.h b/arch/arm/include/asm/arch-exynos/tzpc.h new file mode 100644 index 0000000..2c9a07b --- /dev/null +++ b/arch/arm/include/asm/arch-exynos/tzpc.h @@ -0,0 +1,52 @@ +/* + * (C) Copyright 2012 Samsung Electronics + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +#ifndef __TZPC_H_ +#define __TZPC_H_ + +#ifndef __ASSEMBLY__ +struct exynos5_tzpc { + unsigned int r0size; + char res1[0x7FC]; + unsigned int decprot0stat; + unsigned int decprot0set; + unsigned int decprot0clr; + unsigned int decprot1stat; + unsigned int decprot1set; + unsigned int decprot1clr; + unsigned int decprot2stat; + unsigned int decprot2set; + unsigned int decprot2clr; + unsigned int decprot3stat; + unsigned int decprot3set; + unsigned int decprot3clr; + char res2[0x7B0]; + unsigned int periphid0; + unsigned int periphid1; + unsigned int periphid2; + unsigned int periphid3; + unsigned int pcellid0; + unsigned int pcellid1; + unsigned int pcellid2; + unsigned int pcellid3; +}; +#endif + +#endif
SMDK5250 board is based on Samsungs EXYNOS5250 SoC.
Signed-off-by: Chander Kashyap chander.kashyap@linaro.org --- Changes for v2: - This patch is bifurcated into borad support and SoC support - Fixed typo: s/EEYNOS/EXYNOS - Squashed patch "SMDK5250: enable device tree support" in this. Changes for v3: - None Changes for v4: - Converted assembly routines for clock, memory, uart and tzpc - init to c functions - Moved uart init to smdk5250.c
MAINTAINERS | 1 + board/samsung/smdk5250/Makefile | 51 ++++ board/samsung/smdk5250/clock_init.c | 202 +++++++++++++ board/samsung/smdk5250/dmc_init.c | 508 ++++++++++++++++++++++++++++++++ board/samsung/smdk5250/lowlevel_init.S | 96 ++++++ board/samsung/smdk5250/setup.h | 353 ++++++++++++++++++++++ board/samsung/smdk5250/smdk5250.c | 152 ++++++++++ board/samsung/smdk5250/tzpc_init.c | 48 +++ boards.cfg | 1 + include/configs/smdk5250.h | 198 +++++++++++++ 10 files changed, 1610 insertions(+), 0 deletions(-) create mode 100644 board/samsung/smdk5250/Makefile create mode 100644 board/samsung/smdk5250/clock_init.c create mode 100644 board/samsung/smdk5250/dmc_init.c create mode 100644 board/samsung/smdk5250/lowlevel_init.S create mode 100644 board/samsung/smdk5250/setup.h create mode 100644 board/samsung/smdk5250/smdk5250.c create mode 100644 board/samsung/smdk5250/tzpc_init.c create mode 100644 include/configs/smdk5250.h
diff --git a/MAINTAINERS b/MAINTAINERS index acbd7f1..c03ebb4 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -713,6 +713,7 @@ Chander Kashyap k.chander@samsung.com
origen ARM ARMV7 (EXYNOS4210 SoC) SMDKV310 ARM ARMV7 (EXYNOS4210 SoC) + SMDK5250 ARM ARMV7 (EXYNOS5250 SoC)
Heungjun Kim riverful.kim@samsung.com
diff --git a/board/samsung/smdk5250/Makefile b/board/samsung/smdk5250/Makefile new file mode 100644 index 0000000..d9c2774 --- /dev/null +++ b/board/samsung/smdk5250/Makefile @@ -0,0 +1,51 @@ +# +# Copyright (C) 2011 Samsung Electronics +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +SOBJS := lowlevel_init.o + +COBJS := clock_init.o +COBJS += dmc_init.o +COBJS += tzpc_init.o +COBJS += smdk5250.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) + +ALL := $(obj).depend $(LIB) + +all: $(ALL) + +$(LIB): $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/samsung/smdk5250/clock_init.c b/board/samsung/smdk5250/clock_init.c new file mode 100644 index 0000000..2b53a47 --- /dev/null +++ b/board/samsung/smdk5250/clock_init.c @@ -0,0 +1,202 @@ +/* + * Clock setup for SMDK5250 board based on EXYNOS5 + * + * Copyright (C) 2011 Samsung Electronics + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <version.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/cpu.h> +#include <asm/arch/gpio.h> +#include "setup.h" + +void system_clock_init() +{ + struct exynos5_clock *clk = (struct exynos5_clock *)EXYNOS5_CLOCK_BASE; + + /* + * MUX_APLL_SEL[0]: FINPLL = 0 + * MUX_CPU_SEL[6]: MOUTAPLL = 0 + * MUX_HPM_SEL[20]: MOUTAPLL = 0 + */ + writel(0x0, &clk->src_cpu); + + /* MUX_MPLL_SEL[8]: FINPLL = 0 */ + writel(0x0, &clk->src_core1); + + /* + * VPLLSRC_SEL[0]: FINPLL = 0 + * MUX_{CPLL[8]}|{EPLL[12]}|{VPLL[16]}_SEL: FINPLL = 0 + */ + writel(0x0, &clk->src_top2); + + /* MUX_BPLL_SEL[0]: FINPLL = 0*/ + writel(0x0, &clk->src_cdrex); + + /* MUX_ACLK_* Clock Selection */ + writel(CLK_SRC_TOP0_VAL, &clk->src_top0); + + /* MUX_ACLK_* Clock Selection */ + writel(CLK_SRC_TOP1_VAL, &clk->src_top1); + + /* MUX_ACLK_* Clock Selection */ + writel(CLK_SRC_TOP3_VAL, &clk->src_top3); + + /* MUX_PWI_SEL[19:16]: SCLKMPLL = 6 */ + writel(CLK_SRC_CORE0_VAL, &clk->src_core0); + + /* MUX_ATCLK_LEX[0]: ACLK_200 = 0*/ + writel(CLK_SRC_LEX_VAL, &clk->src_lex); + + /* UART [0-5]: SCLKMPLL = 6 */ + writel(CLK_SRC_PERIC0_VAL, &clk->src_peric0); + + /* Set Clock Ratios */ + writel(CLK_DIV_CPU0_VAL, &clk->div_cpu0); + + /* Set COPY and HPM Ratio */ + writel(CLK_DIV_CPU1_VAL, &clk->div_cpu1); + + /* CORED_RATIO, COREP_RATIO */ + writel(CLK_DIV_CORE0_VAL, &clk->div_core0); + + /* PWI_RATIO[11:8], DVSEM_RATIO[22:16], DPM_RATIO[24:20] */ + writel(CLK_DIV_CORE1_VAL, &clk->div_core1); + + /* ACLK_*_RATIO */ + writel(CLK_DIV_TOP0_VAL, &clk->div_top0); + + /* ACLK_*_RATIO */ + writel(CLK_DIV_TOP1_VAL, &clk->div_top1); + + /* CDREX Ratio */ + writel(CLK_DIV_CDREX_VAL, &clk->div_cdrex); + + /* MCLK_EFPHY_RATIO[3:0] */ + writel(CLK_DIV_CDREX2_VAL, &clk->div_cdrex2); + + /* {PCLK[4:6]|ATCLK[10:8]}_RATIO */ + writel(CLK_DIV_LEX_VAL, &clk->div_lex); + + /* PCLK_R0X_RATIO[3:0] */ + writel(CLK_DIV_R0X_VAL, &clk->div_r0x); + + /* PCLK_R1X_RATIO[3:0] */ + writel(CLK_DIV_R1X_VAL, &clk->div_r1x); + + /* SATA[24]: SCLKMPLL=0, MMC[0-4]: SCLKMPLL = 6 */ + writel(CLK_SRC_FSYS_VAL, &clk->src_fsys); + + /* UART[0-4] */ + writel(CLK_DIV_PERIC0_VAL, &clk->div_peric0); + + /* PWM_RATIO[3:0] */ + writel(CLK_DIV_PERIC3_VAL, &clk->div_peric3); + + /* SATA_RATIO, USB_DRD_RATIO */ + writel(CLK_DIV_FSYS0_VAL, &clk->div_fsys0); + + /* MMC[0-1] */ + writel(CLK_DIV_FSYS1_VAL, &clk->div_fsys1); + + /* MMC[2-3] */ + writel(CLK_DIV_FSYS2_VAL, &clk->div_fsys2); + + /* MMC[4] */ + writel(CLK_DIV_FSYS3_VAL, &clk->div_fsys3); + + /* ACLK|PLCK_ACP_RATIO */ + writel(CLK_DIV_ACP_VAL, &clk->div_acp); + + /* ISPDIV0_RATIO, ISPDIV1_RATIO */ + writel(CLK_DIV_ISP0_VAL, &clk->div_isp0); + + /* MCUISPDIV0_RATIO, MCUISPDIV1_RATIO */ + writel(CLK_DIV_ISP1_VAL, &clk->div_isp1); + + /* MPWMDIV_RATIO */ + writel(CLK_DIV_ISP2_VAL, &clk->div_isp2); + + /* PLL locktime */ + writel(APLL_LOCK_VAL, &clk->apll_lock); + + writel(MPLL_LOCK_VAL, &clk->mpll_lock); + + writel(BPLL_LOCK_VAL, &clk->bpll_lock); + + writel(CPLL_LOCK_VAL, &clk->cpll_lock); + + writel(EPLL_LOCK_VAL, &clk->epll_lock); + + writel(VPLL_LOCK_VAL, &clk->vpll_lock); + + sdelay(0x10000); + + /* Set APLL */ + writel(APLL_CON1_VAL, &clk->apll_con1); + writel(APLL_CON0_VAL, &clk->apll_con0); + sdelay(0x30000); + + /* Set MPLL */ + writel(MPLL_CON1_VAL, &clk->mpll_con1); + writel(MPLL_CON0_VAL, &clk->mpll_con0); + sdelay(0x30000); + writel(BPLL_CON1_VAL, &clk->bpll_con1); + writel(BPLL_CON0_VAL, &clk->bpll_con0); + sdelay(0x30000); + + /* Set CPLL */ + writel(CPLL_CON1_VAL, &clk->cpll_con1); + writel(CPLL_CON0_VAL, &clk->cpll_con0); + sdelay(0x30000); + + /* Set EPLL */ + writel(EPLL_CON2_VAL, &clk->epll_con2); + writel(EPLL_CON1_VAL, &clk->epll_con1); + writel(EPLL_CON0_VAL, &clk->epll_con0); + sdelay(0x30000); + + /* Set VPLL */ + writel(VPLL_CON2_VAL, &clk->vpll_con2); + writel(VPLL_CON1_VAL, &clk->vpll_con1); + writel(VPLL_CON0_VAL, &clk->vpll_con0); + sdelay(0x30000); + + /* Set MPLL */ + /* After Initiallising th PLL select the sources accordingly */ + /* MUX_APLL_SEL[0]: MOUTAPLLFOUT = 1 */ + writel(CLK_SRC_CPU_VAL, &clk->src_cpu); + + /* MUX_MPLL_SEL[8]: MOUTMPLLFOUT = 1 */ + writel(CLK_SRC_CORE1_VAL, &clk->src_core1); + + /* MUX_BPLL_SEL[0]: FOUTBPLL = 1*/ + writel(CLK_SRC_CDREX_VAL, &clk->src_cdrex); + + /* + * VPLLSRC_SEL[0]: FINPLL = 0 + * MUX_{CPLL[8]}|{EPLL[12]}|{VPLL[16]}_SEL: MOUT{CPLL|EPLL|VPLL} = 1 + * MUX_{MPLL[20]}|{BPLL[24]}_USER_SEL: FOUT{MPLL|BPLL} = 1 + */ + writel(CLK_SRC_TOP2_VAL, &clk->src_top2); +} diff --git a/board/samsung/smdk5250/dmc_init.c b/board/samsung/smdk5250/dmc_init.c new file mode 100644 index 0000000..6f92d8a --- /dev/null +++ b/board/samsung/smdk5250/dmc_init.c @@ -0,0 +1,508 @@ +/* + * Memory setup for SMDK5250 board based on EXYNOS5 + * + * Copyright (C) 2011 Samsung Electronics + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <asm/io.h> +#include <asm/arch/dmc.h> +#include <asm/arch/clock.h> +#include <asm/arch/cpu.h> +#include "setup.h" + +/* APLL : 1GHz */ +/* MCLK_CDREX: MCLK_CDREX_533*/ +/* LPDDR support: LPDDR2 */ + +void mem_ctrl_asm_init() +{ + struct exynos5_clock *clk = (struct exynos5_clock *)EXYNOS5_CLOCK_BASE; + struct exynos5_phy_control *phy0_ctrl, *phy1_ctrl; + struct exynos5_dmc *dmc; + unsigned int val; + + phy0_ctrl = (struct exynos5_phy_control *)EXYNOS5_DMC_PHY0_BASE; + phy1_ctrl = (struct exynos5_phy_control *)EXYNOS5_DMC_PHY1_BASE; + dmc = (struct exynos5_dmc *)EXYNOS5_DMC_CTRL_BASE; + + /* Reset PHY Controllor: PHY_RESET[0] */ + writel(0x0, &clk->lpddr3phy_ctrl); + + sdelay(0x10000); + + /*set Read Latance and Burst Length for PHY0 and PHY1 */ + val = 0x408; + writel(val, &phy0_ctrl->phy_con42); + writel(val, &phy1_ctrl->phy_con42); + + /* + * ZQ Calibration: + * Select Driver Strength, + * long calibration for manual calibration + */ + val = 0x0DA40304; + writel(val, &phy0_ctrl->phy_con16); + writel(val, &phy1_ctrl->phy_con16); + + /* Enable termination */ + val = 0x0DAC0304; + writel(val, &phy0_ctrl->phy_con16); + writel(val, &phy1_ctrl->phy_con16); + + /* Start Manual Calibration */ + val = 0x0DAC0306; + writel(val, &phy0_ctrl->phy_con16); + writel(val, &phy1_ctrl->phy_con16); + + sdelay(0x10000); + + /* Enable termination */ + val = 0x0DAC0304; + writel(val, &phy0_ctrl->phy_con16); + writel(val, &phy1_ctrl->phy_con16); + + /* DDR Mode: LPDDR2 */ + val = 0x17021240; + writel(val, &phy0_ctrl->phy_con0); + writel(val, &phy1_ctrl->phy_con0); + + /* DQS, DQ: Signal, for LPDDR2: Always Set */ + val = 0x00000F0F; + writel(val, &phy0_ctrl->phy_con14); + writel(val, &phy1_ctrl->phy_con14); + + /* RD_FETCH: 1 */ + val = 0x1FFF1000; + writel(val, &dmc->concontrol); + sdelay(0x10000); + + val = 0x0FFF1000; + writel(val, &dmc->concontrol); + sdelay(0x10000); + + /* + * Update DLL Information: + * Force DLL Resyncronization + */ + val = 0x00000008; + writel(val, &dmc->phycontrol0); + + /* Reset Force DLL Resyncronization */ + val = 0x00000000; + writel(val, &dmc->phycontrol0); + + /* + * Dynamic Clock: Always Running + * Memory Burst length: 4 + * Number of chips: 2 + * Memory Bus width: 32 bit + * Memory Type: LPDDR2-S4 + * Additional Latancy for PLL: 1 Cycle + */ + val = 0x00212500; + writel(val, &dmc->memcontrol); + + /* + * Memory Configuration Chip 0 + * Address Mapping: Interleaved + * Number of Column address Bits: 10 bits + * Number of Rows Address Bits: 14 + * Number of Banks: 8 + */ + val = 0x00001323; + writel(val, &dmc->memconfig0); + + /* + * Memory Configuration Chip 1 + * Address Mapping: Interleaved + * Number of Column address Bits: 10 bits + * Number of Rows Address Bits: 14 + * Number of Banks: 8 + */ + val = 0x00001323; + writel(val, &dmc->memconfig1); + + /* + * Chip0: AXI + * AXI Base Address: 0x40000000 + * AXI Base Address Mask: 0x780 + */ + val = 0x00400780; + writel(val, &dmc->membaseconfig0); + + /* + * Chip1: AXI + * AXI Base Address: 0x80000000 + * AXI Base Address Mask: 0x780 + */ + val = 0x00800780; + writel(val, &dmc->membaseconfig1); + + /* Precharge Configuration */ + val = 0xFF000000; + writel(val, &dmc->prechconfig); + + /* Power Down mode Configuration */ + val = 0xFFFF00FF; + writel(val, &dmc->pwrdnconfig); + + /* Periodic Refrese Interval */ + val = 0x0000005D; + writel(val, &dmc->timingref); + + /* MCLK_CDREX_533 */ + /* + * TimingRow, TimingData, TimingPower Setting: + * Values as per Memory AC Parameters + */ + val = 0x2336544C; + writel(val, &dmc->timingrow); + + val = 0x24202408; + writel(val, &dmc->timingdata); + + val = 0x38260235; + writel(val, &dmc->timingpower); + + /* Memory Channel Inteleaving Size: 128 Bytes */ + val = CONFIG_IV_SIZE; + writel(val, &dmc->ivcontrol); + + /* Set Offsets to read DQS */ + val = 0x7F7F7F7F; + writel(val, &phy0_ctrl->phy_con4); + writel(val, &phy1_ctrl->phy_con4); + + /* Set Offsets to read DQ */ + val = 0x7F7F7F7F; + writel(val, &phy0_ctrl->phy_con6); + writel(val, &phy1_ctrl->phy_con6); + + /* Debug Offset */ + val = 0x0000007F; + writel(val, &phy0_ctrl->phy_con10); + writel(val, &phy1_ctrl->phy_con10); + + /* Start DLL Locking */ + val = 0x10107F50; + writel(val, &phy0_ctrl->phy_con12); + writel(val, &phy1_ctrl->phy_con12); + + sdelay(0x10000); + + /* + * Update DLL Information: + * Force DLL Resyncronization + */ + val = 0x00000008; + writel(val, &dmc->phycontrol0); + + /* Reset DLL Resyncronization */ + val = 0x00000000; + writel(val, &dmc->phycontrol0); + + /* + * NOP CMD: Channel 0, Chip 0 + * Exit from active/precharge power down or deep power down + */ + val = 0x07000000; + writel(val, &dmc->directcmd); + + sdelay(0x10000); + + /* EMRS2, EMRS3, EMRS, MRS Commands Using Direct Command */ + val = 0x00071C00; + writel(val, &dmc->directcmd); + + sdelay(0x10000); + + val = 0x00010BFC; + writel(val, &dmc->directcmd); + + sdelay(0x10000); + + /* MCLK_CDREX_533 */ + val = 0x00000708; + writel(val, &dmc->directcmd); + + sdelay(0x10000); + + val = 0x00000818; + writel(val, &dmc->directcmd); + + sdelay(0x10000); + + /* + * NOP CMD: Channel 0, Chip 1 + * Exit from active/precharge power down or deep power down + */ + val = 0x07100000; + writel(val, &dmc->directcmd); + + sdelay(0x10000); + + /* EMRS2, EMRS3, EMRS, MRS Commands Using Direct Command */ + val = 0x00171C00; + writel(val, &dmc->directcmd); + + sdelay(0x10000); + + val = 0x00110BFC; + writel(val, &dmc->directcmd); + + sdelay(0x10000); + + /* MCLK_CDREX_533 */ + val = 0x00100708; + writel(val, &dmc->directcmd); + + sdelay(0x10000); + + val = 0x00100818; + writel(val, &dmc->directcmd); + + sdelay(0x10000); + + /* + * NOP CMD: Channel 1, Chip 0 + * Exit from active/precharge power down or deep power down + */ + val = 0x17000000; + writel(val, &dmc->directcmd); + + sdelay(0x10000); + + /* EMRS2, EMRS3, EMRS, MRS Commands Using Direct Command */ + val = 0x10071C00; + writel(val, &dmc->directcmd); + + sdelay(0x10000); + + val = 0x10010BFC; + writel(val, &dmc->directcmd); + + sdelay(0x10000); + + /* MCLK_CDREX_533 */ + val = 0x10000708; + writel(val, &dmc->directcmd); + + sdelay(0x10000); + + val = 0x10000818; + writel(val, &dmc->directcmd); + + sdelay(0x10000); + + /* + * NOP CMD: Channel 1, Chip 1 + * Exit from active/precharge power down or deep power down + */ + val = 0x17100000; + writel(val, &dmc->directcmd); + + sdelay(0x10000); + + /* EMRS2, EMRS3, EMRS, MRS Commands Using Direct Command */ + val = 0x10171C00; + writel(val, &dmc->directcmd); + + sdelay(0x10000); + + val = 0x10110BFC; + writel(val, &dmc->directcmd); + + sdelay(0x10000); + + /* MCLK_CDREX_533 */ + val = 0x10100708; + writel(val, &dmc->directcmd); + + sdelay(0x10000); + + val = 0x10100818; + writel(val, &dmc->directcmd); + + sdelay(0x10000); + + /* Reset DQS Offsets */ + val = 0x08080808; + writel(val, &phy0_ctrl->phy_con4); + writel(val, &phy1_ctrl->phy_con4); + + /* Reset DQ Offsets */ + val = 0x08080808; + writel(val, &phy0_ctrl->phy_con6); + writel(val, &phy1_ctrl->phy_con6); + + /* Reset debug Offsets */ + val = 0x00000008; + writel(val, &phy0_ctrl->phy_con10); + writel(val, &phy1_ctrl->phy_con10); + + /* Set DLL Locking */ + val = 0x10107F30; + writel(val, &phy0_ctrl->phy_con12); + writel(val, &phy1_ctrl->phy_con12); + + sdelay(0x10000); + + /* Start DLL Locking */ + val = 0x10107F70; + writel(val, &phy0_ctrl->phy_con12); + writel(val, &phy1_ctrl->phy_con12); + + sdelay(0x10000); + + /* + * Update DLL Information: + * Force DLL Resyncronization + */ + val = 0x00000008; + writel(val, &dmc->phycontrol0); + + /* Reset DLL Resyncronization */ + val = 0x00000000; + writel(val, &dmc->phycontrol0); + + sdelay(0x10000); + + /* + * Update DLL Information: + * Force DLL Resyncronization + */ + val = 0x00000008; + writel(val, &dmc->phycontrol0); + + /* Reset DLL Resyncronization */ + val = 0x00000000; + writel(val, &dmc->phycontrol0); + + sdelay(0x10000); +#if defined(CONFIG_RD_LVL) + /* DLL On */ + val = 0x10102D50; + writel(val, &phy0_ctrl->phy_con12); + writel(val, &phy1_ctrl->phy_con12); + + /* + * Set ctrl_gateadj, ctrl_readadj + * ctrl_gateduradj, rdlvl_pass_adj + * rdlvl_rddataPadj + */ + val = 0x09210001; + writel(val, &phy0_ctrl->phy_con1); + writel(val, &phy1_ctrl->phy_con1); + + /* LPDDR2 Address */ + val = 0x00000208; + writel(val, &phy0_ctrl->phy_con22); + writel(val, &phy1_ctrl->phy_con22); + + /* Enable Byte Read Leleling */ + val = 0x17023240; + writel(val, &phy0_ctrl->phy_con0); + writel(val, &phy1_ctrl->phy_con0); + + /* rdlvl_en: Use levelling offset instead ctrl_shiftc */ + val = 0x02010004; + writel(val, &phy0_ctrl->phy_con2); + writel(val, &phy1_ctrl->phy_con2); + + sdelay(0x10000); + + /* Enable Data Eye Trainig */ + val = 0x00000002; + writel(val, &dmc->rdlvl_config); + + sdelay(0x10000); + + /* Disable Data Eye Trainig */ + val = 0x00000000; + writel(val, &dmc->rdlvl_config); + + /* RdDeSkew_clear: Clear */ + val = 0x02012004; + writel(val, &phy0_ctrl->phy_con2); + writel(val, &phy1_ctrl->phy_con2); + + /* Start DLL Locking */ + val = 0x10107F70; + writel(val, &phy0_ctrl->phy_con12); + writel(val, &phy1_ctrl->phy_con12); + + /* Force DLL Resyncronization */ + val = 0x00000008; + writel(val, &dmc->phycontrol0); + + /* Reset DLL Resyncronization */ + val = 0x00000000; + writel(val, &dmc->phycontrol0); + + sdelay(0x10000); + + /* ctrl_atgate: ctrl_gate_p*, ctrl_read_p* generated by PHY*/ + val = 0x17023200; + writel(val, &phy0_ctrl->phy_con0); + writel(val, &phy1_ctrl->phy_con0); + + /* Channel:0, Chip:0, PALL (all banks precharge) CMD */ + val = 0x01000000; + writel(val, &dmc->directcmd); + + sdelay(0x10000); + + /* Channel:0, Chip:1, PALL (all banks precharge) CMD */ + val = 0x01100000; + writel(val, &dmc->directcmd); + + sdelay(0x10000); + + /* Channel:1, Chip:0, PALL (all banks precharge) CMD */ + val = 0x11000000; + writel(val, &dmc->directcmd); + + sdelay(0x10000); + + /* Channel:1, Chip:1, PALL (all banks precharge) CMD */ + val = 0x11100000; + writel(val, &dmc->directcmd); + + sdelay(0x10000); +#endif + /* + * Dynamic Clock: Stops During Idle Period + * Dynamic Power Down: Enable + * Dynamic Self refresh: Enable + * Memory Burst length: 4 + * Number of chips: 2 + * Memory Bus width: 32 bit + * Memory Type: LPDDR2-S4 + * Additional Latancy for PLL: 1 Cycle + */ + val = 0x00212523; + writel(val, &dmc->memcontrol); + + /* Start Auto refresh */ + val = 0x0FFF10E0; + writel(val, &dmc->concontrol); +} diff --git a/board/samsung/smdk5250/lowlevel_init.S b/board/samsung/smdk5250/lowlevel_init.S new file mode 100644 index 0000000..d7a0c2e --- /dev/null +++ b/board/samsung/smdk5250/lowlevel_init.S @@ -0,0 +1,96 @@ +/* + * Lowlevel setup for SMDK5250 board based on S5PC520 + * + * Copyright (C) 2011 Samsung Electronics + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <version.h> +#include <asm/arch/cpu.h> + +_TEXT_BASE: + .word CONFIG_SYS_TEXT_BASE + + .globl lowlevel_init +lowlevel_init: + + /* use iRAM stack in bl2 */ + ldr sp, =CONFIG_IRAM_STACK + stmdb r13!, {ip,lr} + + /* check reset status */ + ldr r0, =(EXYNOS5_POWER_BASE + INFORM1_OFFSET) + ldr r1, [r0] + + /* AFTR wakeup reset */ + ldr r2, =S5P_CHECK_DIDLE + cmp r1, r2 + beq exit_wakeup + + /* LPA wakeup reset */ + ldr r2, =S5P_CHECK_LPA + cmp r1, r2 + beq exit_wakeup + + /* Sleep wakeup reset */ + ldr r2, =S5P_CHECK_SLEEP + cmp r1, r2 + beq wakeup_reset + + /* + * If U-boot is already running in RAM, no need to relocate U-Boot. + * Memory controller must be configured before relocating U-Boot + * in ram. + */ + ldr r0, =0x0ffffff /* r0 <- Mask Bits*/ + bic r1, pc, r0 /* pc <- current addr of code */ + /* r1 <- unmasked bits of pc */ + ldr r2, _TEXT_BASE /* r2 <- original base addr in ram */ + bic r2, r2, r0 /* r2 <- unmasked bits of r2*/ + cmp r1, r2 /* compare r1, r2 */ + beq 1f /* r0 == r1 then skip sdram init */ + + /* init system clock */ + bl system_clock_init + + /* Memory initialize */ + bl mem_ctrl_asm_init + +1: + bl tzpc_init + ldmia r13!, {ip,pc} + +wakeup_reset: + bl system_clock_init + bl mem_ctrl_asm_init + bl tzpc_init + +exit_wakeup: + /* Load return address and jump to kernel */ + ldr r0, =(EXYNOS5_POWER_BASE + INFORM0_OFFSET) + + /* r1 = physical address of exynos5_cpu_resume function*/ + ldr r1, [r0] + + /* Jump to kernel */ + mov pc, r1 + nop + nop diff --git a/board/samsung/smdk5250/setup.h b/board/samsung/smdk5250/setup.h new file mode 100644 index 0000000..2ff7400 --- /dev/null +++ b/board/samsung/smdk5250/setup.h @@ -0,0 +1,353 @@ +/* + * Machine Specific Values for SMDK5250 board based on S5PC520 + * + * Copyright (C) 2011 Samsung Electronics + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _SMDK5250_SETUP_H +#define _SMDK5250_SETUP_H + +#include <config.h> +#include <version.h> +#include <asm/arch/cpu.h> + +/* GPIO Offsets for UART: GPIO Contol Register */ +#define EXYNOS5_GPIO_A0_CON_OFFSET 0x0 +#define EXYNOS5_GPIO_A1_CON_OFFSET 0x20 + +/* TZPC : Register Offsets */ +#define TZPC0_BASE 0x10100000 +#define TZPC1_BASE 0x10110000 +#define TZPC2_BASE 0x10120000 +#define TZPC3_BASE 0x10130000 +#define TZPC4_BASE 0x10140000 +#define TZPC5_BASE 0x10150000 +#define TZPC6_BASE 0x10160000 +#define TZPC7_BASE 0x10170000 +#define TZPC8_BASE 0x10180000 +#define TZPC9_BASE 0x10190000 + +/* CLK_SRC_CPU */ +/* 0 = MOUTAPLL, 1 = SCLKMPLL */ +#define MUX_HPM_SEL 0 +#define MUX_CPU_SEL 0 +#define MUX_APLL_SEL 1 +#define CLK_SRC_CPU_VAL ((MUX_HPM_SEL << 20) \ + | (MUX_CPU_SEL << 16) \ + | (MUX_APLL_SEL)) + +/* CLK_DIV_CPU0 */ +#define ARM2_RATIO 0x0 +#define APLL_RATIO 0x1 +#define PCLK_DBG_RATIO 0x1 +#define ATB_RATIO 0x4 +#define PERIPH_RATIO 0x7 +#define ACP_RATIO 0x7 +#define CPUD_RATIO 0x2 +#define ARM_RATIO 0x0 +#define CLK_DIV_CPU0_VAL ((ARM2_RATIO << 28) \ + | (APLL_RATIO << 24) \ + | (PCLK_DBG_RATIO << 20) \ + | (ATB_RATIO << 16) \ + | (PERIPH_RATIO << 12) \ + | (ACP_RATIO << 8) \ + | (CPUD_RATIO << 4) \ + | (ARM_RATIO)) + +/* CLK_DIV_CPU1 */ +#define HPM_RATIO 0x4 +#define COPY_RATIO 0x0 +#define CLK_DIV_CPU1_VAL ((HPM_RATIO << 4) \ + | (COPY_RATIO)) + +#define APLL_MDIV 0x7D +#define APLL_PDIV 0x3 +#define APLL_SDIV 0x0 + +#define MPLL_MDIV 0x64 +#define MPLL_PDIV 0x3 +#define MPLL_SDIV 0x0 + +#define CPLL_MDIV 0x96 +#define CPLL_PDIV 0x4 +#define CPLL_SDIV 0x0 + +/* APLL_CON1 */ +#define APLL_CON1_VAL (0x00203800) + +/* MPLL_CON1 */ +#define MPLL_CON1_VAL (0x00203800) + +/* CPLL_CON1 */ +#define CPLL_CON1_VAL (0x00203800) + +#define EPLL_MDIV 0x60 +#define EPLL_PDIV 0x3 +#define EPLL_SDIV 0x3 + +#define EPLL_CON1_VAL 0x00000000 +#define EPLL_CON2_VAL 0x00000080 + +#define VPLL_MDIV 0x96 +#define VPLL_PDIV 0x3 +#define VPLL_SDIV 0x2 + +#define VPLL_CON1_VAL 0x00000000 +#define VPLL_CON2_VAL 0x00000080 + +#define BPLL_MDIV 0x215 +#define BPLL_PDIV 0xC +#define BPLL_SDIV 0x1 + +#define BPLL_CON1_VAL 0x00203800 + +/* Set PLL */ +#define set_pll(mdiv, pdiv, sdiv) (1<<31 | mdiv<<16 | pdiv<<8 | sdiv) + +#define APLL_CON0_VAL set_pll(APLL_MDIV, APLL_PDIV, APLL_SDIV) +#define MPLL_CON0_VAL set_pll(MPLL_MDIV, MPLL_PDIV, MPLL_SDIV) +#define CPLL_CON0_VAL set_pll(CPLL_MDIV, CPLL_PDIV, CPLL_SDIV) +#define EPLL_CON0_VAL set_pll(EPLL_MDIV, EPLL_PDIV, EPLL_SDIV) +#define VPLL_CON0_VAL set_pll(VPLL_MDIV, VPLL_PDIV, VPLL_SDIV) +#define BPLL_CON0_VAL set_pll(BPLL_MDIV, BPLL_PDIV, BPLL_SDIV) + +/* CLK_SRC_CORE0 */ +#define CLK_SRC_CORE0_VAL 0x00060000 + +/* CLK_SRC_CORE1 */ +#define CLK_SRC_CORE1_VAL 0x100 + +/* CLK_DIV_CORE0 */ +#define CLK_DIV_CORE0_VAL 0x120000 + +/* CLK_DIV_CORE1 */ +#define CLK_DIV_CORE1_VAL 0x07070700 + +/* CLK_SRC_CDREX */ +#define CLK_SRC_CDREX_VAL 0x111 + +/* CLK_DIV_CDREX */ +#define MCLK_CDREX2_RATIO 0x0 +#define ACLK_EFCON_RATIO 0x1 +#define MCLK_DPHY_RATIO 0x0 +#define MCLK_CDREX_RATIO 0x0 +#define ACLK_C2C_200_RATIO 0x1 +#define C2C_CLK_400_RATIO 0x1 +#define PCLK_CDREX_RATIO 0x3 +#define ACLK_CDREX_RATIO 0x1 +#define CLK_DIV_CDREX_VAL ((MCLK_DPHY_RATIO << 20) \ + | (MCLK_CDREX_RATIO << 16) \ + | (ACLK_C2C_200_RATIO << 12) \ + | (C2C_CLK_400_RATIO << 8) \ + | (PCLK_CDREX_RATIO << 4) \ + | (ACLK_CDREX_RATIO)) + +#define MCLK_EFPHY_RATIO 0x4 +#define CLK_DIV_CDREX2_VAL MCLK_EFPHY_RATIO + +/* CLK_DIV_ACP */ +#define CLK_DIV_ACP_VAL 0x12 + +/* CLK_SRC_TOP0 */ +#define MUX_ACLK_300_GSCL_SEL 0x1 +#define MUX_ACLK_300_GSCL_MID_SEL 0x0 +#define MUX_ACLK_400_SEL 0x0 +#define MUX_ACLK_333_SEL 0x0 +#define MUX_ACLK_300_DISP1_SEL 0x1 +#define MUX_ACLK_300_DISP1_MID_SEL 0x0 +#define MUX_ACLK_200_SEL 0x0 +#define MUX_ACLK_166_SEL 0x0 +#define CLK_SRC_TOP0_VAL ((MUX_ACLK_300_GSCL_SEL << 25) \ + | (MUX_ACLK_300_GSCL_MID_SEL << 24) \ + | (MUX_ACLK_400_SEL << 20) \ + | (MUX_ACLK_333_SEL << 16) \ + | (MUX_ACLK_300_DISP1_SEL << 15) \ + | (MUX_ACLK_300_DISP1_MID_SEL << 14) \ + | (MUX_ACLK_200_SEL << 12) \ + | (MUX_ACLK_166_SEL << 8)) + +/* CLK_SRC_TOP1 */ +#define MUX_ACLK_400_ISP_SEL 0x0 +#define MUX_ACLK_400_IOP_SEL 0x0 +#define MUX_ACLK_MIPI_HSI_TXBASE_SEL 0x0 +#define CLK_SRC_TOP1_VAL ((MUX_ACLK_400_ISP_SEL << 24) \ + |(MUX_ACLK_400_IOP_SEL << 20) \ + |(MUX_ACLK_MIPI_HSI_TXBASE_SEL << 16)) + +/* CLK_SRC_TOP2 */ +#define MUX_BPLL_USER_SEL 0x1 +#define MUX_MPLL_USER_SEL 0x1 +#define MUX_VPLL_SEL 0x0 +#define MUX_EPLL_SEL 0x0 +#define MUX_CPLL_SEL 0x0 +#define VPLLSRC_SEL 0x0 +#define CLK_SRC_TOP2_VAL ((MUX_BPLL_USER_SEL << 24) \ + | (MUX_MPLL_USER_SEL << 20) \ + | (MUX_VPLL_SEL << 16) \ + | (MUX_EPLL_SEL << 12) \ + | (MUX_CPLL_SEL << 8) \ + | (VPLLSRC_SEL)) +/* CLK_SRC_TOP3 */ +#define MUX_ACLK_333_SUB_SEL 0x1 +#define MUX_ACLK_400_SUB_SEL 0x1 +#define MUX_ACLK_266_ISP_SUB_SEL 0x1 +#define MUX_ACLK_266_GPS_SUB_SEL 0x1 +#define MUX_ACLK_300_GSCL_SUB_SEL 0x1 +#define MUX_ACLK_266_GSCL_SUB_SEL 0x1 +#define MUX_ACLK_300_DISP1_SUB_SEL 0x1 +#define MUX_ACLK_200_DISP1_SUB_SEL 0x1 +#define CLK_SRC_TOP3_VAL ((MUX_ACLK_333_SUB_SEL << 24) \ + | (MUX_ACLK_400_SUB_SEL << 20) \ + | (MUX_ACLK_266_ISP_SUB_SEL << 16) \ + | (MUX_ACLK_266_GPS_SUB_SEL << 12) \ + | (MUX_ACLK_300_GSCL_SUB_SEL << 10) \ + | (MUX_ACLK_266_GSCL_SUB_SEL << 8) \ + | (MUX_ACLK_300_DISP1_SUB_SEL << 6) \ + | (MUX_ACLK_200_DISP1_SUB_SEL << 4)) + +/* CLK_DIV_TOP0 */ +#define ACLK_300_RATIO 0x0 +#define ACLK_400_RATIO 0x3 +#define ACLK_333_RATIO 0x2 +#define ACLK_266_RATIO 0x2 +#define ACLK_200_RATIO 0x3 +#define ACLK_166_RATIO 0x5 +#define ACLK_133_RATIO 0x1 +#define ACLK_66_RATIO 0x5 +#define CLK_DIV_TOP0_VAL ((ACLK_300_RATIO << 28) \ + | (ACLK_400_RATIO << 24) \ + | (ACLK_333_RATIO << 20) \ + | (ACLK_266_RATIO << 16) \ + | (ACLK_200_RATIO << 12) \ + | (ACLK_166_RATIO << 8) \ + | (ACLK_133_RATIO << 4) \ + | (ACLK_66_RATIO)) + +/* CLK_DIV_TOP1 */ +#define ACLK_MIPI_HSI_TX_BASE_RATIO 0x3 +#define ACLK_66_PRE_RATIO 0x1 +#define ACLK_400_ISP_RATIO 0x1 +#define ACLK_400_IOP_RATIO 0x1 +#define ACLK_300_GSCL_RATIO 0x0 +#define ACLK_266_GPS_RATIO 0x7 + +#define CLK_DIV_TOP1_VAL ((ACLK_MIPI_HSI_TX_BASE_RATIO << 28) \ + | (ACLK_66_PRE_RATIO << 24) \ + | (ACLK_400_ISP_RATIO << 20) \ + | (ACLK_400_IOP_RATIO << 16) \ + | (ACLK_300_GSCL_RATIO << 12) \ + | (ACLK_266_GPS_RATIO << 8)) + +/* APLL_LOCK */ +#define APLL_LOCK_VAL (0x3E8) +/* MPLL_LOCK */ +#define MPLL_LOCK_VAL (0x2F1) +/* CPLL_LOCK */ +#define CPLL_LOCK_VAL (0x3E8) +/* EPLL_LOCK */ +#define EPLL_LOCK_VAL (0x2321) +/* VPLL_LOCK */ +#define VPLL_LOCK_VAL (0x2321) +/* BPLL_LOCK */ +#define BPLL_LOCK_VAL (0x3E8) + +/* CLK_SRC_PERIC0 */ +/* SRC_CLOCK = SCLK_MPLL */ +#define PWM_SEL 0 +#define UART4_SEL 6 +#define UART3_SEL 6 +#define UART2_SEL 6 +#define UART1_SEL 6 +#define UART0_SEL 6 +#define CLK_SRC_PERIC0_VAL ((PWM_SEL << 24) \ + | (UART4_SEL << 16) \ + | (UART3_SEL << 12) \ + | (UART2_SEL << 8) \ + | (UART1_SEL << 4) \ + | (UART0_SEL << 0)) + +#define CLK_SRC_FSYS_VAL 0x66666 +#define CLK_DIV_FSYS0_VAL 0x0BB00000 +#define CLK_DIV_FSYS1_VAL 0x000f000f +#define CLK_DIV_FSYS2_VAL 0x020f020f +#define CLK_DIV_FSYS3_VAL 0x000f + +/* CLK_DIV_PERIC0 */ +#define UART5_RATIO 8 +#define UART4_RATIO 8 +#define UART3_RATIO 8 +#define UART2_RATIO 8 +#define UART1_RATIO 8 +#define UART0_RATIO 8 +#define CLK_DIV_PERIC0_VAL ((UART4_RATIO << 16) \ + | (UART3_RATIO << 12) \ + | (UART2_RATIO << 8) \ + | (UART1_RATIO << 4) \ + | (UART0_RATIO << 0)) + +/* CLK_DIV_PERIC3 */ +#define PWM_RATIO 8 +#define CLK_DIV_PERIC3_VAL (PWM_RATIO << 0) + +/* CLK_SRC_LEX */ +#define CLK_SRC_LEX_VAL 0x0 + +/* CLK_DIV_LEX */ +#define CLK_DIV_LEX_VAL 0x10 + +/* CLK_DIV_R0X */ +#define CLK_DIV_R0X_VAL 0x10 + +/* CLK_DIV_L0X */ +#define CLK_DIV_R1X_VAL 0x10 + +/* SCLK_SRC_ISP */ +#define SCLK_SRC_ISP_VAL 0x600 +/* CLK_DIV_ISP0 */ +#define CLK_DIV_ISP0_VAL 0x31 + +/* CLK_DIV_ISP1 */ +#define CLK_DIV_ISP1_VAL 0x0 + +/* CLK_DIV_ISP2 */ +#define CLK_DIV_ISP2_VAL 0x1 + +#define MPLL_DEC (MPLL_MDIV * MPLL_MDIV / (MPLL_PDIV * 2^(MPLL_SDIV-1))) + +/* + * TZPC Register Value : + * R0SIZE: 0x0 : Size of secured ram + */ +#define R0SIZE 0x0 + +/* + * TZPC Decode Protection Register Value : + * DECPROTXSET: 0xFF : Set Decode region to non-secure + */ +#define DECPROTXSET 0xFF + +void sdelay(unsigned long); +void mem_ctrl_asm_init(void); +void system_clock_init(void); +void uart_asm_init(void); +void tzpc_init(void); + +#endif diff --git a/board/samsung/smdk5250/smdk5250.c b/board/samsung/smdk5250/smdk5250.c new file mode 100644 index 0000000..2684620 --- /dev/null +++ b/board/samsung/smdk5250/smdk5250.c @@ -0,0 +1,152 @@ +/* + * Copyright (C) 2011 Samsung Electronics + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <netdev.h> +#include <asm/arch/cpu.h> +#include <asm/arch/gpio.h> +#include <asm/arch/mmc.h> +#include <asm/arch/sromc.h> + +DECLARE_GLOBAL_DATA_PTR; +struct exynos5_gpio_part1 *gpio1; + +int board_init(void) +{ + gpio1 = (struct exynos5_gpio_part1 *) samsung_get_base_gpio_part1(); + + gd->bd->bi_boot_params = (PHYS_SDRAM_1 + 0x100UL); + return 0; +} + +int dram_init(void) +{ + gd->ram_size = get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE) + + get_ram_size((long *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE) + + get_ram_size((long *)PHYS_SDRAM_3, PHYS_SDRAM_3_SIZE) + + get_ram_size((long *)PHYS_SDRAM_4, PHYS_SDRAM_4_SIZE) + + get_ram_size((long *)PHYS_SDRAM_5, PHYS_SDRAM_7_SIZE) + + get_ram_size((long *)PHYS_SDRAM_6, PHYS_SDRAM_7_SIZE) + + get_ram_size((long *)PHYS_SDRAM_7, PHYS_SDRAM_7_SIZE) + + get_ram_size((long *)PHYS_SDRAM_8, PHYS_SDRAM_8_SIZE); + return 0; +} + +void dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = get_ram_size((long *)PHYS_SDRAM_1, \ + PHYS_SDRAM_1_SIZE); + gd->bd->bi_dram[1].start = PHYS_SDRAM_2; + gd->bd->bi_dram[1].size = get_ram_size((long *)PHYS_SDRAM_2, \ + PHYS_SDRAM_2_SIZE); + gd->bd->bi_dram[2].start = PHYS_SDRAM_3; + gd->bd->bi_dram[2].size = get_ram_size((long *)PHYS_SDRAM_3, \ + PHYS_SDRAM_3_SIZE); + gd->bd->bi_dram[3].start = PHYS_SDRAM_4; + gd->bd->bi_dram[3].size = get_ram_size((long *)PHYS_SDRAM_4, \ + PHYS_SDRAM_4_SIZE); + gd->bd->bi_dram[4].start = PHYS_SDRAM_5; + gd->bd->bi_dram[4].size = get_ram_size((long *)PHYS_SDRAM_5, \ + PHYS_SDRAM_5_SIZE); + gd->bd->bi_dram[5].start = PHYS_SDRAM_6; + gd->bd->bi_dram[5].size = get_ram_size((long *)PHYS_SDRAM_6, \ + PHYS_SDRAM_6_SIZE); + gd->bd->bi_dram[6].start = PHYS_SDRAM_7; + gd->bd->bi_dram[6].size = get_ram_size((long *)PHYS_SDRAM_7, \ + PHYS_SDRAM_7_SIZE); + gd->bd->bi_dram[7].start = PHYS_SDRAM_8; + gd->bd->bi_dram[7].size = get_ram_size((long *)PHYS_SDRAM_8, \ + PHYS_SDRAM_8_SIZE); +} + +#ifdef CONFIG_DISPLAY_BOARDINFO +int checkboard(void) +{ + printf("\nBoard: SMDK5250\n"); + + return 0; +} +#endif + +#ifdef CONFIG_GENERIC_MMC +int board_mmc_init(bd_t *bis) +{ + int i, err; + + /* + * MMC2 SD card GPIO: + * + * GPC2[0] SD_2_CLK(2) + * GPC2[1] SD_2_CMD(2) + * GPC2[2] SD_2_CDn + * GPC2[3:6] SD_2_DATA[0:3](2) + */ + for (i = 0; i < 7; i++) { + /* GPC2[0:6] special function 2 */ + s5p_gpio_cfg_pin(&gpio1->c2, i, GPIO_FUNC(0x2)); + + /* GPK2[0:6] drv 4x */ + s5p_gpio_set_drv(&gpio1->c2, i, GPIO_DRV_4X); + + /* GPK2[0:1] pull disable */ + if (i == 0 || i == 1) { + s5p_gpio_set_pull(&gpio1->c2, i, GPIO_PULL_NONE); + continue; + } + + /* GPK2[2:6] pull up */ + s5p_gpio_set_pull(&gpio1->c2, i, GPIO_PULL_UP); + } + + err = s5p_mmc_init(2, 4); + return err; +} +#endif + +static void board_uart_init(void) +{ + struct exynos5_gpio_part1 *gpio1 = + (struct exynos5_gpio_part1 *)samsung_get_base_gpio_part1(); + int i; + + /* UART0-UART1 GPIOs (part1) : 0x22222222 */ + for (i = 0; i < 7; i++) { + s5p_gpio_set_pull(&gpio1->a0, i, GPIO_PULL_NONE); + s5p_gpio_cfg_pin(&gpio1->a0, i, GPIO_FUNC(0x2)); + } + + /* UART2-UART3 GPIOs (part2) : 0x00223322 */ + for (i = 0; i < 5; i++) { + s5p_gpio_set_pull(&gpio1->a1, i, GPIO_PULL_NONE); + s5p_gpio_cfg_pin(&gpio1->a1, i, GPIO_FUNC(0x2)); + } +} + +#ifdef CONFIG_BOARD_EARLY_INIT_F +int board_early_init_f(void) +{ + board_uart_init(); + return 0; +} +#endif diff --git a/board/samsung/smdk5250/tzpc_init.c b/board/samsung/smdk5250/tzpc_init.c new file mode 100644 index 0000000..c2ccef3 --- /dev/null +++ b/board/samsung/smdk5250/tzpc_init.c @@ -0,0 +1,48 @@ +/* + * Lowlevel setup for SMDK5250 board based on S5PC520 + * + * Copyright (C) 2012 Samsung Electronics + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <asm/arch/tzpc.h> +#include"setup.h" + +/* Setting TZPC[TrustZone Protection Controller] */ +void tzpc_init(void) +{ + struct exynos5_tzpc *tzpc; + unsigned int addr; + + for (addr = TZPC0_BASE; addr <= TZPC9_BASE; addr += TZPC_BASE_OFFSET) { + tzpc = (struct exynos5_tzpc *)addr; + + if (addr == TZPC0_BASE) + writel(R0SIZE, &tzpc->r0size); + + writel(DECPROTXSET, &tzpc->decprot0set); + writel(DECPROTXSET, &tzpc->decprot1set); + + if (addr != TZPC9_BASE) { + writel(DECPROTXSET, &tzpc->decprot2set); + writel(DECPROTXSET, &tzpc->decprot3set); + } + } +} diff --git a/boards.cfg b/boards.cfg index 4aaa891..c0bac3c 100644 --- a/boards.cfg +++ b/boards.cfg @@ -221,6 +221,7 @@ s5p_goni arm armv7 goni samsung smdkc100 arm armv7 smdkc100 samsung s5pc1xx origen arm armv7 origen samsung exynos s5pc210_universal arm armv7 universal_c210 samsung exynos +smdk5250 arm armv7 smdk5250 samsung exynos smdkv310 arm armv7 smdkv310 samsung exynos trats arm armv7 trats samsung exynos harmony arm armv7 harmony nvidia tegra2 diff --git a/include/configs/smdk5250.h b/include/configs/smdk5250.h new file mode 100644 index 0000000..194130d --- /dev/null +++ b/include/configs/smdk5250.h @@ -0,0 +1,198 @@ +/* + * Copyright (C) 2011 Samsung Electronics + * + * Configuration settings for the SAMSUNG SMDK5250 (EXYNOS5250) board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* High Level Configuration Options */ +#define CONFIG_SAMSUNG 1 /* in a SAMSUNG core */ +#define CONFIG_S5P 1 /* S5P Family */ +#define CONFIG_EXYNOS5 1 /* which is in a Exynos5 Family */ +#define CONFIG_CPU_EXYNOS5250 1 /* which is in a Exynos5250 */ +#define CONFIG_SMDK5250 1 /* which is in a SMDK5250 */ + +#include <asm/arch/cpu.h> /* get chip and board defs */ + +#define CONFIG_ARCH_CPU_INIT +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +/* Keep L2 Cache Disabled */ +#define CONFIG_L2_OFF 1 +#define CONFIG_SYS_DCACHE_OFF 1 + +#define CONFIG_SYS_SDRAM_BASE 0x40000000 +#define CONFIG_SYS_TEXT_BASE 0x43E00000 + +/* input clock of PLL: SMDK5250 has 24MHz input clock */ +#define CONFIG_SYS_CLK_FREQ 24000000 + +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_CMDLINE_TAG +#define CONFIG_INITRD_TAG +#define CONFIG_CMDLINE_EDITING + +/* MACH_TYPE_SMDK5250 macro will be removed once added to mach-types */ +#define MACH_TYPE_SMDK5250 3774 +#define CONFIG_MACH_TYPE MACH_TYPE_SMDK5250 + +/* Power Down Modes */ +#define S5P_CHECK_SLEEP 0x00000BAD +#define S5P_CHECK_DIDLE 0xBAD00000 +#define S5P_CHECK_LPA 0xABAD0000 + +/* Offset for inform registers */ +#define INFORM0_OFFSET 0x800 +#define INFORM1_OFFSET 0x804 + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (1 << 20)) + +/* select serial console configuration */ +#define CONFIG_SERIAL_MULTI 1 +#define CONFIG_SERIAL1 1 /* use SERIAL 1 */ +#define CONFIG_BAUDRATE 115200 +#define EXYNOS5_DEFAULT_UART_OFFSET 0x010000 + +#define TZPC_BASE_OFFSET 0x10000 + +/* SD/MMC configuration */ +#define CONFIG_GENERIC_MMC 1 +#define CONFIG_MMC 1 +#define CONFIG_S5P_MMC 1 + +#define CONFIG_BOARD_EARLY_INIT_F + +/* PWM */ +#define CONFIG_PWM 1 + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +/* Command definition*/ +#include <config_cmd_default.h> + +#define CONFIG_CMD_PING +#define CONFIG_CMD_ELF +#define CONFIG_CMD_MMC +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_NFS + +#define CONFIG_BOOTDELAY 3 +#define CONFIG_ZERO_BOOTDELAY_CHECK + +#define CONFIG_BOOTCOMMAND "fatload mmc 0 40007000 uImage; bootm 40007000" + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_SYS_PROMPT "SMDK5250 # " +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0" +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5E00000) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x3E00000) + +#define CONFIG_SYS_HZ 1000 + +/* valid baudrates */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* Stack sizes */ +#define CONFIG_STACKSIZE (256 << 10) /* 256KB */ + +#define CONFIG_NR_DRAM_BANKS 8 +#define SDRAM_BANK_SIZE (256UL << 20UL) /* 256 MB */ +#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE +#define PHYS_SDRAM_1_SIZE SDRAM_BANK_SIZE +#define PHYS_SDRAM_2 (CONFIG_SYS_SDRAM_BASE + SDRAM_BANK_SIZE) +#define PHYS_SDRAM_2_SIZE SDRAM_BANK_SIZE +#define PHYS_SDRAM_3 (CONFIG_SYS_SDRAM_BASE + (2 * SDRAM_BANK_SIZE)) +#define PHYS_SDRAM_3_SIZE SDRAM_BANK_SIZE +#define PHYS_SDRAM_4 (CONFIG_SYS_SDRAM_BASE + (3 * SDRAM_BANK_SIZE)) +#define PHYS_SDRAM_4_SIZE SDRAM_BANK_SIZE +#define PHYS_SDRAM_5 (CONFIG_SYS_SDRAM_BASE + (4 * SDRAM_BANK_SIZE)) +#define PHYS_SDRAM_5_SIZE SDRAM_BANK_SIZE +#define PHYS_SDRAM_6 (CONFIG_SYS_SDRAM_BASE + (5 * SDRAM_BANK_SIZE)) +#define PHYS_SDRAM_6_SIZE SDRAM_BANK_SIZE +#define PHYS_SDRAM_7 (CONFIG_SYS_SDRAM_BASE + (6 * SDRAM_BANK_SIZE)) +#define PHYS_SDRAM_7_SIZE SDRAM_BANK_SIZE +#define PHYS_SDRAM_8 (CONFIG_SYS_SDRAM_BASE + (7 * SDRAM_BANK_SIZE)) +#define PHYS_SDRAM_8_SIZE SDRAM_BANK_SIZE + +#define CONFIG_SYS_MONITOR_BASE 0x00000000 + +/* (Memory Interleaving Size = 1 << IV_SIZE) */ +#define CONFIG_IV_SIZE 0x07 +#define CONFIG_RD_LVL 1 + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH 1 +#undef CONFIG_CMD_IMLS +#define CONFIG_IDENT_STRING " for SMDK5250" + +#define CONFIG_ENV_IS_IN_MMC 1 +#define CONFIG_SYS_MMC_ENV_DEV 0 + +#define CONFIG_SECURE_BL1_ONLY + +/* Secure FW size configuration */ +#ifdef CONFIG_SECURE_BL1_ONLY +#define CONFIG_SEC_FW_SIZE (8 << 10) /* 8KB */ +#else +#define CONFIG_SEC_FW_SIZE 0 +#endif + +/* Configuration of BL1, BL2, ENV Blocks on mmc */ +#define CONFIG_RES_BLOCK_SIZE (512) +#define CONFIG_BL1_SIZE (16 << 10) /*16 K reserved for BL1*/ +#define CONFIG_BL2_SIZE (512UL << 10UL) /* 512 KB */ +#define CONFIG_ENV_SIZE (16 << 10) /* 16 KB */ + +#define CONFIG_BL1_OFFSET (CONFIG_RES_BLOCK_SIZE + CONFIG_SEC_FW_SIZE) +#define CONFIG_BL2_OFFSET (CONFIG_BL1_OFFSET + CONFIG_BL1_SIZE) +#define CONFIG_ENV_OFFSET (CONFIG_BL2_OFFSET + CONFIG_BL2_SIZE) + +/* U-boot copy size from boot Media to DRAM.*/ +#define BL2_START_OFFSET (CONFIG_BL2_OFFSET/512) +#define BL2_SIZE_BLOC_COUNT (CONFIG_BL2_SIZE/512) +#define CONFIG_DOS_PARTITION 1 + +#define CONFIG_IRAM_STACK 0x02050000 + +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - 0x1000000) +#define MMC_MAX_CHANNEL 5 + +/* Enable devicetree support */ +#define CONFIG_OF_LIBFDT + +#endif /* __CONFIG_H */
Hi, There are some changes in previous patch set.
- Copyright (C) 2011 Samsung Electronics
- project.
- MA 02111-1307 USA
- gpio1 = (struct exynos5_gpio_part1 *) samsung_get_base_gpio_part1();
- gd->bd->bi_boot_params = (PHYS_SDRAM_1 + 0x100UL);
- gd->ram_size = get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE)
- + get_ram_size((long *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE)
- + get_ram_size((long *)PHYS_SDRAM_3, PHYS_SDRAM_3_SIZE)
- + get_ram_size((long *)PHYS_SDRAM_4, PHYS_SDRAM_4_SIZE)
- + get_ram_size((long *)PHYS_SDRAM_5, PHYS_SDRAM_7_SIZE)
- + get_ram_size((long *)PHYS_SDRAM_6, PHYS_SDRAM_7_SIZE)
- + get_ram_size((long *)PHYS_SDRAM_7, PHYS_SDRAM_7_SIZE)
- + get_ram_size((long *)PHYS_SDRAM_8, PHYS_SDRAM_8_SIZE);
- gd->bd->bi_dram[0].start = PHYS_SDRAM_1;
- gd->bd->bi_dram[0].size = get_ram_size((long *)PHYS_SDRAM_1, \
- PHYS_SDRAM_1_SIZE);
- gd->bd->bi_dram[1].start = PHYS_SDRAM_2;
- gd->bd->bi_dram[1].size = get_ram_size((long *)PHYS_SDRAM_2, \
- PHYS_SDRAM_2_SIZE);
- gd->bd->bi_dram[2].start = PHYS_SDRAM_3;
- gd->bd->bi_dram[2].size = get_ram_size((long *)PHYS_SDRAM_3, \
- PHYS_SDRAM_3_SIZE);
- gd->bd->bi_dram[3].start = PHYS_SDRAM_4;
- gd->bd->bi_dram[3].size = get_ram_size((long *)PHYS_SDRAM_4, \
- PHYS_SDRAM_4_SIZE);
- gd->bd->bi_dram[4].start = PHYS_SDRAM_5;
- gd->bd->bi_dram[4].size = get_ram_size((long *)PHYS_SDRAM_5, \
- PHYS_SDRAM_5_SIZE);
- gd->bd->bi_dram[5].start = PHYS_SDRAM_6;
- gd->bd->bi_dram[5].size = get_ram_size((long *)PHYS_SDRAM_6, \
- PHYS_SDRAM_6_SIZE);
- gd->bd->bi_dram[6].start = PHYS_SDRAM_7;
- gd->bd->bi_dram[6].size = get_ram_size((long *)PHYS_SDRAM_7, \
- PHYS_SDRAM_7_SIZE);
- gd->bd->bi_dram[7].start = PHYS_SDRAM_8;
- gd->bd->bi_dram[7].size = get_ram_size((long *)PHYS_SDRAM_8, \
- PHYS_SDRAM_8_SIZE);
- printf("\nBoard: SMDK5250\n");
+} +#endif
- int i, err;
- * MMC2 SD card GPIO:
- * GPC2[0] SD_2_CLK(2)
- * GPC2[1] SD_2_CMD(2)
- * GPC2[2] SD_2_CDn
- * GPC2[3:6] SD_2_DATA[0:3](2)
- for (i = 0; i < 7; i++) {
- /* GPC2[0:6] special function 2 */
- s5p_gpio_cfg_pin(&gpio1->c2, i, GPIO_FUNC(0x2));
- /* GPK2[0:6] drv 4x */
- s5p_gpio_set_drv(&gpio1->c2, i, GPIO_DRV_4X);
- /* GPK2[0:1] pull disable */
- if (i == 0 || i == 1) {
- s5p_gpio_set_pull(&gpio1->c2, i, GPIO_PULL_NONE);
- continue;
- /* GPK2[2:6] pull up */
- s5p_gpio_set_pull(&gpio1->c2, i, GPIO_PULL_UP);
- err = s5p_mmc_init(2, 4);
- return err;
+} +#endif
- struct exynos5_gpio_part1 *gpio1 =
- (struct exynos5_gpio_part1 *)samsung_get_base_gpio_part1();
Remove this, as its done already, as part of board_init()
- int i;
- /* UART0-UART1 GPIOs (part1) : 0x22222222 */
loop should go to i<8
- s5p_gpio_set_pull(&gpio1->a0, i, GPIO_PULL_NONE);
- s5p_gpio_cfg_pin(&gpio1->a0, i, GPIO_FUNC(0x2));
- /* UART2-UART3 GPIOs (part2) : 0x00223322 */
- for (i = 0; i < 5; i++) {
loop should go to i<6
- s5p_gpio_set_pull(&gpio1->a1, i, GPIO_PULL_NONE);
- s5p_gpio_cfg_pin(&gpio1->a1, i, GPIO_FUNC(0x2));
- board_uart_init();
+} +#endif
I will resubmit the patch set.
This patch adds support for MMC SPL booting.
Signed-off-by: Chander Kashyap chander.kashyap@linaro.org --- Changes for v2: - None Changes for v3: - None Changes for v4: None
board/samsung/smdk5250/Makefile | 16 ++++ board/samsung/smdk5250/mmc_boot.c | 58 ++++++++++++ board/samsung/smdk5250/tools/mkexynos_image.c | 117 +++++++++++++++++++++++++ include/configs/smdk5250.h | 6 +- 4 files changed, 196 insertions(+), 1 deletions(-) create mode 100644 board/samsung/smdk5250/mmc_boot.c create mode 100644 board/samsung/smdk5250/tools/mkexynos_image.c
diff --git a/board/samsung/smdk5250/Makefile b/board/samsung/smdk5250/Makefile index d9c2774..908ce5b 100644 --- a/board/samsung/smdk5250/Makefile +++ b/board/samsung/smdk5250/Makefile @@ -29,18 +29,34 @@ SOBJS := lowlevel_init.o COBJS := clock_init.o COBJS += dmc_init.o COBJS += tzpc_init.o + +ifndef CONFIG_SPL_BUILD COBJS += smdk5250.o +endif + +ifdef CONFIG_SPL_BUILD +COBJS += mmc_boot.o +endif
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS))
+ifdef CONFIG_SPL_BUILD +ALL += $(OBJTREE)/tools/mk$(BOARD)spl +endif + all: $(ALL)
$(LIB): $(OBJS) $(call cmd_link_o_target, $(OBJS))
+ifdef CONFIG_SPL_BUILD +$(OBJTREE)/tools/mk$(BOARD)spl: tools/mkexynos_image.c + $(HOSTCC) tools/mkexynos_image.c -o $(OBJTREE)/tools/mk$(BOARD)spl +endif + #########################################################################
# defines $(obj).depend target diff --git a/board/samsung/smdk5250/mmc_boot.c b/board/samsung/smdk5250/mmc_boot.c new file mode 100644 index 0000000..669c1a3 --- /dev/null +++ b/board/samsung/smdk5250/mmc_boot.c @@ -0,0 +1,58 @@ +/* + * Copyright (C) 2011 Samsung Electronics + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include<common.h> +#include<config.h> + +/* +* Copy U-boot from mmc to RAM: +* COPY_BL2_FNPTR_ADDR: Address in iRAM, which Contains +* Pointer to API (Data transfer from mmc to ram) +*/ +void copy_uboot_to_ram(void) +{ + u32 (*copy_bl2)(u32, u32, u32) = (void *) *(u32 *)COPY_BL2_FNPTR_ADDR; + + copy_bl2(BL2_START_OFFSET, BL2_SIZE_BLOC_COUNT, CONFIG_SYS_TEXT_BASE); +} + +void board_init_f(unsigned long bootflag) +{ + __attribute__((noreturn)) void (*uboot)(void); + copy_uboot_to_ram(); + + /* Jump to U-Boot image */ + uboot = (void *)CONFIG_SYS_TEXT_BASE; + (*uboot)(); + /* Never returns Here */ +} + +/* Place Holders */ +void board_init_r(gd_t *id, ulong dest_addr) +{ + /* Function attribute is no-return */ + /* This Function never executes */ + while (1) + ; +} + +void save_boot_params(u32 r0, u32 r1, u32 r2, u32 r3) {} diff --git a/board/samsung/smdk5250/tools/mkexynos_image.c b/board/samsung/smdk5250/tools/mkexynos_image.c new file mode 100644 index 0000000..e2b7805 --- /dev/null +++ b/board/samsung/smdk5250/tools/mkexynos_image.c @@ -0,0 +1,117 @@ +/* + * Copyright (C) 2011 Samsung Electronics + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <stdio.h> +#include <stdlib.h> +#include <unistd.h> +#include <fcntl.h> +#include <errno.h> +#include <string.h> +#include <sys/stat.h> + +#define CHECKSUM_OFFSET (14*1024-4) +#define BUFSIZE (16*1024) +#define FILE_PERM (S_IRUSR | S_IWUSR | S_IRGRP \ + | S_IWGRP | S_IROTH | S_IWOTH) +/* +* Requirement: +* IROM code reads first 14K bytes from boot device. +* It then calculates the checksum of 14K-4 bytes and compare with data at +* 14K-4 offset. +* +* This function takes two filenames: +* IN "u-boot-spl.bin" and +* OUT "$(BOARD)-spl.bin as filenames. +* It reads the "u-boot-spl.bin" in 16K buffer. +* It calculates checksum of 14K-4 Bytes and stores at 14K-4 offset in buffer. +* It writes the buffer to "$(BOARD)-spl.bin" file. +*/ + +int main(int argc, char **argv) +{ + int i, len; + unsigned char buffer[BUFSIZE] = {0}; + int ifd, ofd; + unsigned long checksum = 0, count; + + if (argc != 3) { + printf(" %d Wrong number of arguments\n", argc); + exit(EXIT_FAILURE); + } + + ifd = open(argv[1], O_RDONLY); + if (ifd < 0) { + fprintf(stderr, "%s: Can't open %s: %s\n", + argv[0], argv[1], strerror(errno)); + exit(EXIT_FAILURE); + } + + ofd = open(argv[2], O_WRONLY | O_CREAT | O_TRUNC, FILE_PERM); + if (ifd < 0) { + fprintf(stderr, "%s: Can't open %s: %s\n", + argv[0], argv[2], strerror(errno)); + if (ifd) + close(ifd); + exit(EXIT_FAILURE); + } + + len = lseek(ifd, 0, SEEK_END); + lseek(ifd, 0, SEEK_SET); + + count = (len < CHECKSUM_OFFSET) ? len : CHECKSUM_OFFSET; + + if (read(ifd, buffer, count) != count) { + fprintf(stderr, "%s: Can't read %s: %s\n", + argv[0], argv[1], strerror(errno)); + + if (ifd) + close(ifd); + if (ofd) + close(ofd); + + exit(EXIT_FAILURE); + } + + for (i = 0, checksum = 0; i < CHECKSUM_OFFSET; i++) + checksum += buffer[i]; + + memcpy(&buffer[CHECKSUM_OFFSET], &checksum, sizeof(checksum)); + + if (write(ofd, buffer, BUFSIZE) != BUFSIZE) { + fprintf(stderr, "%s: Can't write %s: %s\n", + argv[0], argv[2], strerror(errno)); + + if (ifd) + close(ifd); + if (ofd) + close(ofd); + + exit(EXIT_FAILURE); + } + + if (ifd) + close(ifd); + if (ofd) + close(ofd); + + return EXIT_SUCCESS; +} diff --git a/include/configs/smdk5250.h b/include/configs/smdk5250.h index 194130d..6f2ef4c 100644 --- a/include/configs/smdk5250.h +++ b/include/configs/smdk5250.h @@ -104,7 +104,11 @@ #define CONFIG_BOOTDELAY 3 #define CONFIG_ZERO_BOOTDELAY_CHECK
-#define CONFIG_BOOTCOMMAND "fatload mmc 0 40007000 uImage; bootm 40007000" +/* MMC SPL */ +#define CONFIG_SPL +#define COPY_BL2_FNPTR_ADDR 0x02020030 + +#define CONFIG_BOOTCOMMAND "mmc read 40007000 451 2000; bootm 40007000"
/* Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */
Chander Kashyap
