[PATCH] riscv: assembler versions of memcpy, memmove, memset
Provide optimized versions of memcpy(), memmove(), memset() copied from the Linux kernel.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- arch/riscv/Kconfig | 78 ++++++++++++++++++++++ arch/riscv/include/asm/string.h | 36 +++++----- arch/riscv/lib/Makefile | 5 ++ arch/riscv/lib/memcpy.S | 108 ++++++++++++++++++++++++++++++ arch/riscv/lib/memmove.S | 64 ++++++++++++++++++ arch/riscv/lib/memset.S | 113 ++++++++++++++++++++++++++++++++ 6 files changed, 383 insertions(+), 21 deletions(-) create mode 100644 arch/riscv/lib/memcpy.S create mode 100644 arch/riscv/lib/memmove.S create mode 100644 arch/riscv/lib/memset.S
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index 55eaee2da6..7d0bd73ce2 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -271,4 +271,82 @@ config STACK_SIZE_SHIFT config OF_BOARD_FIXUP default y if OF_SEPARATE && RISCV_SMODE
+config USE_ARCH_MEMCPY + bool "Use an assembly optimized implementation of memcpy" + default y + help + Enable the generation of an optimized version of memcpy. + Such an implementation may be faster under some conditions + but may increase the binary size. + +config SPL_USE_ARCH_MEMCPY + bool "Use an assembly optimized implementation of memcpy for SPL" + default y if USE_ARCH_MEMCPY + depends on SPL + help + Enable the generation of an optimized version of memcpy. + Such an implementation may be faster under some conditions + but may increase the binary size. + +config TPL_USE_ARCH_MEMCPY + bool "Use an assembly optimized implementation of memcpy for TPL" + default y if USE_ARCH_MEMCPY + depends on TPL + help + Enable the generation of an optimized version of memcpy. + Such an implementation may be faster under some conditions + but may increase the binary size. + +config USE_ARCH_MEMMOVE + bool "Use an assembly optimized implementation of memmove" + default y + help + Enable the generation of an optimized version of memmove. + Such an implementation may be faster under some conditions + but may increase the binary size. + +config SPL_USE_ARCH_MEMMOVE + bool "Use an assembly optimized implementation of memmove for SPL" + default y if USE_ARCH_MEMCPY + depends on SPL + help + Enable the generation of an optimized version of memmove. + Such an implementation may be faster under some conditions + but may increase the binary size. + +config TPL_USE_ARCH_MEMMOVE + bool "Use an assembly optimized implementation of memmove for TPL" + default y if USE_ARCH_MEMCPY + depends on TPL + help + Enable the generation of an optimized version of memmove. + Such an implementation may be faster under some conditions + but may increase the binary size. + +config USE_ARCH_MEMSET + bool "Use an assembly optimized implementation of memset" + default y + help + Enable the generation of an optimized version of memset. + Such an implementation may be faster under some conditions + but may increase the binary size. + +config SPL_USE_ARCH_MEMSET + bool "Use an assembly optimized implementation of memset for SPL" + default y if USE_ARCH_MEMSET + depends on SPL + help + Enable the generation of an optimized version of memset. + Such an implementation may be faster under some conditions + but may increase the binary size. + +config TPL_USE_ARCH_MEMSET + bool "Use an assembly optimized implementation of memset for TPL" + default y if USE_ARCH_MEMSET + depends on TPL + help + Enable the generation of an optimized version of memset. + Such an implementation may be faster under some conditions + but may increase the binary size. + endmenu diff --git a/arch/riscv/include/asm/string.h b/arch/riscv/include/asm/string.h index 0fc3424a2f..7dee3e4c9f 100644 --- a/arch/riscv/include/asm/string.h +++ b/arch/riscv/include/asm/string.h @@ -19,31 +19,25 @@
#undef __HAVE_ARCH_STRRCHR #undef __HAVE_ARCH_STRCHR -#undef __HAVE_ARCH_MEMCPY -#undef __HAVE_ARCH_MEMMOVE #undef __HAVE_ARCH_MEMCHR #undef __HAVE_ARCH_MEMZERO -#undef __HAVE_ARCH_MEMSET
-#ifdef CONFIG_MARCO_MEMSET -#define memset(_p, _v, _n) \ - (typeof(_p) (p) = (_p); \ - typeof(_v) (v) = (_v); \ - typeof(_n) (n) = (_n); \ - { \ - if ((n) != 0) { \ - if (__builtin_constant_p((v)) && (v) == 0) \ - __memzero((p), (n)); \ - else \ - memset((p), (v), (n)); \ - } \ - (p); \ - }) +#undef __HAVE_ARCH_MEMCPY +#if CONFIG_IS_ENABLED(USE_ARCH_MEMCPY) +#define __HAVE_ARCH_MEMCPY +#endif +extern void *memcpy(void *, const void *, __kernel_size_t); + +#undef __HAVE_ARCH_MEMMOVE +#if CONFIG_IS_ENABLED(USE_ARCH_MEMMOVE) +#define __HAVE_ARCH_MEMMOVE +#endif +extern void *memmove(void *, const void *, __kernel_size_t);
-#define memzero(_p, _n) \ - (typeof(_p) (p) = (_p); \ - typeof(_n) (n) = (_n); \ - { if ((n) != 0) __memzero((p), (n)); (p); }) +#undef __HAVE_ARCH_MEMZERO +#if CONFIG_IS_ENABLED(USE_ARCH_MEMSET) +#define __HAVE_ARCH_MEMSET #endif +extern void *memset(void *, int, __kernel_size_t);
#endif /* __ASM_RISCV_STRING_H */ diff --git a/arch/riscv/lib/Makefile b/arch/riscv/lib/Makefile index 12c14f2019..1c1500f5b3 100644 --- a/arch/riscv/lib/Makefile +++ b/arch/riscv/lib/Makefile @@ -36,3 +36,8 @@ CFLAGS_REMOVE_$(EFI_RELOC) := $(CFLAGS_NON_EFI) extra-$(CONFIG_CMD_BOOTEFI_HELLO_COMPILE) += $(EFI_CRT0) $(EFI_RELOC) extra-$(CONFIG_CMD_BOOTEFI_SELFTEST) += $(EFI_CRT0) $(EFI_RELOC) extra-$(CONFIG_EFI) += $(EFI_CRT0) $(EFI_RELOC) + +obj-$(CONFIG_$(SPL_TPL_)USE_ARCH_MEMSET) += memset.o +obj-$(CONFIG_$(SPL_TPL_)USE_ARCH_MEMMOVE) += memmove.o +obj-$(CONFIG_$(SPL_TPL_)USE_ARCH_MEMCPY) += memcpy.o +obj-$(CONFIG_$(SPL_TPL_)USE_ARCH_MEMCPY) += memcpy.o diff --git a/arch/riscv/lib/memcpy.S b/arch/riscv/lib/memcpy.S new file mode 100644 index 0000000000..51ab716253 --- /dev/null +++ b/arch/riscv/lib/memcpy.S @@ -0,0 +1,108 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ +/* + * Copyright (C) 2013 Regents of the University of California + */ + +#include <linux/linkage.h> +#include <asm/asm.h> + +/* void *memcpy(void *, const void *, size_t) */ +ENTRY(__memcpy) +WEAK(memcpy) + move t6, a0 /* Preserve return value */ + + /* Defer to byte-oriented copy for small sizes */ + sltiu a3, a2, 128 + bnez a3, 4f + /* Use word-oriented copy only if low-order bits match */ + andi a3, t6, SZREG-1 + andi a4, a1, SZREG-1 + bne a3, a4, 4f + + beqz a3, 2f /* Skip if already aligned */ + /* + * Round to nearest double word-aligned address + * greater than or equal to start address + */ + andi a3, a1, ~(SZREG-1) + addi a3, a3, SZREG + /* Handle initial misalignment */ + sub a4, a3, a1 +1: + lb a5, 0(a1) + addi a1, a1, 1 + sb a5, 0(t6) + addi t6, t6, 1 + bltu a1, a3, 1b + sub a2, a2, a4 /* Update count */ + +2: + andi a4, a2, ~((16*SZREG)-1) + beqz a4, 4f + add a3, a1, a4 +3: + REG_L a4, 0(a1) + REG_L a5, SZREG(a1) + REG_L a6, 2*SZREG(a1) + REG_L a7, 3*SZREG(a1) + REG_L t0, 4*SZREG(a1) + REG_L t1, 5*SZREG(a1) + REG_L t2, 6*SZREG(a1) + REG_L t3, 7*SZREG(a1) + REG_L t4, 8*SZREG(a1) + REG_L t5, 9*SZREG(a1) + REG_S a4, 0(t6) + REG_S a5, SZREG(t6) + REG_S a6, 2*SZREG(t6) + REG_S a7, 3*SZREG(t6) + REG_S t0, 4*SZREG(t6) + REG_S t1, 5*SZREG(t6) + REG_S t2, 6*SZREG(t6) + REG_S t3, 7*SZREG(t6) + REG_S t4, 8*SZREG(t6) + REG_S t5, 9*SZREG(t6) + REG_L a4, 10*SZREG(a1) + REG_L a5, 11*SZREG(a1) + REG_L a6, 12*SZREG(a1) + REG_L a7, 13*SZREG(a1) + REG_L t0, 14*SZREG(a1) + REG_L t1, 15*SZREG(a1) + addi a1, a1, 16*SZREG + REG_S a4, 10*SZREG(t6) + REG_S a5, 11*SZREG(t6) + REG_S a6, 12*SZREG(t6) + REG_S a7, 13*SZREG(t6) + REG_S t0, 14*SZREG(t6) + REG_S t1, 15*SZREG(t6) + addi t6, t6, 16*SZREG + bltu a1, a3, 3b + andi a2, a2, (16*SZREG)-1 /* Update count */ + +4: + /* Handle trailing misalignment */ + beqz a2, 6f + add a3, a1, a2 + + /* Use word-oriented copy if co-aligned to word boundary */ + or a5, a1, t6 + or a5, a5, a3 + andi a5, a5, 3 + bnez a5, 5f +7: + lw a4, 0(a1) + addi a1, a1, 4 + sw a4, 0(t6) + addi t6, t6, 4 + bltu a1, a3, 7b + + ret + +5: + lb a4, 0(a1) + addi a1, a1, 1 + sb a4, 0(t6) + addi t6, t6, 1 + bltu a1, a3, 5b +6: + ret +END(__memcpy) diff --git a/arch/riscv/lib/memmove.S b/arch/riscv/lib/memmove.S new file mode 100644 index 0000000000..07d1d2152b --- /dev/null +++ b/arch/riscv/lib/memmove.S @@ -0,0 +1,64 @@ +/* SPDX-License-Identifier: GPL-2.0 */ + +#include <linux/linkage.h> +#include <asm/asm.h> + +ENTRY(__memmove) +WEAK(memmove) + move t0, a0 + move t1, a1 + + beq a0, a1, exit_memcpy + beqz a2, exit_memcpy + srli t2, a2, 0x2 + + slt t3, a0, a1 + beqz t3, do_reverse + + andi a2, a2, 0x3 + li t4, 1 + beqz t2, byte_copy + +word_copy: + lw t3, 0(a1) + addi t2, t2, -1 + addi a1, a1, 4 + sw t3, 0(a0) + addi a0, a0, 4 + bnez t2, word_copy + beqz a2, exit_memcpy + j byte_copy + +do_reverse: + add a0, a0, a2 + add a1, a1, a2 + andi a2, a2, 0x3 + li t4, -1 + beqz t2, reverse_byte_copy + +reverse_word_copy: + addi a1, a1, -4 + addi t2, t2, -1 + lw t3, 0(a1) + addi a0, a0, -4 + sw t3, 0(a0) + bnez t2, reverse_word_copy + beqz a2, exit_memcpy + +reverse_byte_copy: + addi a0, a0, -1 + addi a1, a1, -1 + +byte_copy: + lb t3, 0(a1) + addi a2, a2, -1 + sb t3, 0(a0) + add a1, a1, t4 + add a0, a0, t4 + bnez a2, byte_copy + +exit_memcpy: + move a0, t0 + move a1, t1 + ret +END(__memmove) diff --git a/arch/riscv/lib/memset.S b/arch/riscv/lib/memset.S new file mode 100644 index 0000000000..34c5360c67 --- /dev/null +++ b/arch/riscv/lib/memset.S @@ -0,0 +1,113 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ +/* + * Copyright (C) 2013 Regents of the University of California + */ + + +#include <linux/linkage.h> +#include <asm/asm.h> + +/* void *memset(void *, int, size_t) */ +ENTRY(__memset) +WEAK(memset) + move t0, a0 /* Preserve return value */ + + /* Defer to byte-oriented fill for small sizes */ + sltiu a3, a2, 16 + bnez a3, 4f + + /* + * Round to nearest XLEN-aligned address + * greater than or equal to start address + */ + addi a3, t0, SZREG-1 + andi a3, a3, ~(SZREG-1) + beq a3, t0, 2f /* Skip if already aligned */ + /* Handle initial misalignment */ + sub a4, a3, t0 +1: + sb a1, 0(t0) + addi t0, t0, 1 + bltu t0, a3, 1b + sub a2, a2, a4 /* Update count */ + +2: /* Duff's device with 32 XLEN stores per iteration */ + /* Broadcast value into all bytes */ + andi a1, a1, 0xff + slli a3, a1, 8 + or a1, a3, a1 + slli a3, a1, 16 + or a1, a3, a1 +#ifdef CONFIG_64BIT + slli a3, a1, 32 + or a1, a3, a1 +#endif + + /* Calculate end address */ + andi a4, a2, ~(SZREG-1) + add a3, t0, a4 + + andi a4, a4, 31*SZREG /* Calculate remainder */ + beqz a4, 3f /* Shortcut if no remainder */ + neg a4, a4 + addi a4, a4, 32*SZREG /* Calculate initial offset */ + + /* Adjust start address with offset */ + sub t0, t0, a4 + + /* Jump into loop body */ + /* Assumes 32-bit instruction lengths */ + la a5, 3f +#ifdef CONFIG_64BIT + srli a4, a4, 1 +#endif + add a5, a5, a4 + jr a5 +3: + REG_S a1, 0(t0) + REG_S a1, SZREG(t0) + REG_S a1, 2*SZREG(t0) + REG_S a1, 3*SZREG(t0) + REG_S a1, 4*SZREG(t0) + REG_S a1, 5*SZREG(t0) + REG_S a1, 6*SZREG(t0) + REG_S a1, 7*SZREG(t0) + REG_S a1, 8*SZREG(t0) + REG_S a1, 9*SZREG(t0) + REG_S a1, 10*SZREG(t0) + REG_S a1, 11*SZREG(t0) + REG_S a1, 12*SZREG(t0) + REG_S a1, 13*SZREG(t0) + REG_S a1, 14*SZREG(t0) + REG_S a1, 15*SZREG(t0) + REG_S a1, 16*SZREG(t0) + REG_S a1, 17*SZREG(t0) + REG_S a1, 18*SZREG(t0) + REG_S a1, 19*SZREG(t0) + REG_S a1, 20*SZREG(t0) + REG_S a1, 21*SZREG(t0) + REG_S a1, 22*SZREG(t0) + REG_S a1, 23*SZREG(t0) + REG_S a1, 24*SZREG(t0) + REG_S a1, 25*SZREG(t0) + REG_S a1, 26*SZREG(t0) + REG_S a1, 27*SZREG(t0) + REG_S a1, 28*SZREG(t0) + REG_S a1, 29*SZREG(t0) + REG_S a1, 30*SZREG(t0) + REG_S a1, 31*SZREG(t0) + addi t0, t0, 32*SZREG + bltu t0, a3, 3b + andi a2, a2, SZREG-1 /* Update count */ + +4: + /* Handle trailing misalignment */ + beqz a2, 6f + add a3, t0, a2 +5: + sb a1, 0(t0) + addi t0, t0, 1 + bltu t0, a3, 5b +6: + ret +END(__memset) -- 2.31.0
- bool "Use an assembly optimized implementation of memcpy"
- default y
- help
- bool "Use an assembly optimized implementation of memcpy for SPL"
- default y if USE_ARCH_MEMCPY
- depends on SPL
- help
- bool "Use an assembly optimized implementation of memcpy for TPL"
- depends on TPL
- help
- bool "Use an assembly optimized implementation of memmove"
- default y
- help
- bool "Use an assembly optimized implementation of memmove for SPL"
- depends on SPL
- help
- bool "Use an assembly optimized implementation of memmove for TPL"
- depends on TPL
- help
- bool "Use an assembly optimized implementation of memset"
- default y
- help
- bool "Use an assembly optimized implementation of memset for SPL"
- default y if USE_ARCH_MEMSET
- depends on SPL
- help
- bool "Use an assembly optimized implementation of memset for TPL"
- depends on TPL
- help
if ((n) != 0) { \
else \
(p); \
The above line is duplicated.
- Copyright (C) 2013 Regents of the University of California
- move t6, a0 /* Preserve return value */
- /* Defer to byte-oriented copy for small sizes */
- sltiu a3, a2, 128
- bnez a3, 4f
- /* Use word-oriented copy only if low-order bits match */
- andi a3, t6, SZREG-1
- andi a4, a1, SZREG-1
- bne a3, a4, 4f
- beqz a3, 2f /* Skip if already aligned */
- andi a3, a1, ~(SZREG-1)
- addi a3, a3, SZREG
- /* Handle initial misalignment */
- sub a4, a3, a1
+1:
- lb a5, 0(a1)
- addi a1, a1, 1
- sb a5, 0(t6)
- addi t6, t6, 1
- bltu a1, a3, 1b
- sub a2, a2, a4 /* Update count */
+2:
- andi a4, a2, ~((16*SZREG)-1)
- beqz a4, 4f
- add a3, a1, a4
+3:
- REG_L a4, 0(a1)
- REG_L a5, SZREG(a1)
- REG_L a6, 2*SZREG(a1)
- REG_L a7, 3*SZREG(a1)
- REG_L t0, 4*SZREG(a1)
- REG_L t1, 5*SZREG(a1)
- REG_L t2, 6*SZREG(a1)
- REG_L t3, 7*SZREG(a1)
- REG_L t4, 8*SZREG(a1)
- REG_L t5, 9*SZREG(a1)
- REG_S a4, 0(t6)
- REG_S a5, SZREG(t6)
- REG_S a6, 2*SZREG(t6)
- REG_S a7, 3*SZREG(t6)
- REG_S t0, 4*SZREG(t6)
- REG_S t1, 5*SZREG(t6)
- REG_S t2, 6*SZREG(t6)
- REG_S t3, 7*SZREG(t6)
- REG_S t4, 8*SZREG(t6)
- REG_S t5, 9*SZREG(t6)
- REG_L a4, 10*SZREG(a1)
- REG_L a5, 11*SZREG(a1)
- REG_L a6, 12*SZREG(a1)
- REG_L a7, 13*SZREG(a1)
- REG_L t0, 14*SZREG(a1)
- REG_L t1, 15*SZREG(a1)
- addi a1, a1, 16*SZREG
- REG_S a4, 10*SZREG(t6)
- REG_S a5, 11*SZREG(t6)
- REG_S a6, 12*SZREG(t6)
- REG_S a7, 13*SZREG(t6)
- REG_S t0, 14*SZREG(t6)
- REG_S t1, 15*SZREG(t6)
- addi t6, t6, 16*SZREG
- bltu a1, a3, 3b
- andi a2, a2, (16*SZREG)-1 /* Update count */
+4:
- /* Handle trailing misalignment */
- beqz a2, 6f
- add a3, a1, a2
- /* Use word-oriented copy if co-aligned to word boundary */
- or a5, a1, t6
- or a5, a5, a3
- andi a5, a5, 3
- bnez a5, 5f
+7:
- lw a4, 0(a1)
- addi a1, a1, 4
- sw a4, 0(t6)
- addi t6, t6, 4
- bltu a1, a3, 7b
- ret
+5:
- lb a4, 0(a1)
- addi a1, a1, 1
- sb a4, 0(t6)
- addi t6, t6, 1
- bltu a1, a3, 5b
+6:
- ret
move t0, a0
move t1, a1
srli t2, a2, 0x2
slt t3, a0, a1
beqz t3, do_reverse
andi a2, a2, 0x3
li t4, 1
beqz t2, byte_copy
+word_copy:
lw t3, 0(a1)
addi t2, t2, -1
addi a1, a1, 4
sw t3, 0(a0)
addi a0, a0, 4
bnez t2, word_copy
j byte_copy
+do_reverse:
add a0, a0, a2
add a1, a1, a2
andi a2, a2, 0x3
li t4, -1
+reverse_word_copy:
addi a1, a1, -4
addi t2, t2, -1
lw t3, 0(a1)
addi a0, a0, -4
sw t3, 0(a0)
+reverse_byte_copy:
addi a0, a0, -1
addi a1, a1, -1
+byte_copy:
lb t3, 0(a1)
addi a2, a2, -1
sb t3, 0(a0)
add a1, a1, t4
add a0, a0, t4
bnez a2, byte_copy
+exit_memcpy:
move a0, t0
move a1, t1
ret
- move t0, a0 /* Preserve return value */
- /* Defer to byte-oriented fill for small sizes */
- sltiu a3, a2, 16
- bnez a3, 4f
- addi a3, t0, SZREG-1
- andi a3, a3, ~(SZREG-1)
- beq a3, t0, 2f /* Skip if already aligned */
- sub a4, a3, t0
+1:
- sb a1, 0(t0)
- addi t0, t0, 1
- bltu t0, a3, 1b
- /* Broadcast value into all bytes */
- andi a1, a1, 0xff
- slli a3, a1, 8
- or a1, a3, a1
- slli a3, a1, 16
- or a1, a3, a1
- slli a3, a1, 32
- or a1, a3, a1
- /* Calculate end address */
- andi a4, a2, ~(SZREG-1)
- add a3, t0, a4
- andi a4, a4, 31*SZREG /* Calculate remainder */
- beqz a4, 3f /* Shortcut if no remainder */
- neg a4, a4
- addi a4, a4, 32*SZREG /* Calculate initial offset */
- /* Adjust start address with offset */
- sub t0, t0, a4
- /* Jump into loop body */
- /* Assumes 32-bit instruction lengths */
- la a5, 3f
- srli a4, a4, 1
- add a5, a5, a4
- jr a5
+3:
- REG_S a1, 0(t0)
- REG_S a1, SZREG(t0)
- REG_S a1, 2*SZREG(t0)
- REG_S a1, 3*SZREG(t0)
- REG_S a1, 4*SZREG(t0)
- REG_S a1, 5*SZREG(t0)
- REG_S a1, 6*SZREG(t0)
- REG_S a1, 7*SZREG(t0)
- REG_S a1, 8*SZREG(t0)
- REG_S a1, 9*SZREG(t0)
- REG_S a1, 10*SZREG(t0)
- REG_S a1, 11*SZREG(t0)
- REG_S a1, 12*SZREG(t0)
- REG_S a1, 13*SZREG(t0)
- REG_S a1, 14*SZREG(t0)
- REG_S a1, 15*SZREG(t0)
- REG_S a1, 16*SZREG(t0)
- REG_S a1, 17*SZREG(t0)
- REG_S a1, 18*SZREG(t0)
- REG_S a1, 19*SZREG(t0)
- REG_S a1, 20*SZREG(t0)
- REG_S a1, 21*SZREG(t0)
- REG_S a1, 22*SZREG(t0)
- REG_S a1, 23*SZREG(t0)
- REG_S a1, 24*SZREG(t0)
- REG_S a1, 25*SZREG(t0)
- REG_S a1, 26*SZREG(t0)
- REG_S a1, 27*SZREG(t0)
- REG_S a1, 28*SZREG(t0)
- REG_S a1, 29*SZREG(t0)
- REG_S a1, 30*SZREG(t0)
- REG_S a1, 31*SZREG(t0)
- addi t0, t0, 32*SZREG
- bltu t0, a3, 3b
- andi a2, a2, SZREG-1 /* Update count */
+4:
- beqz a2, 6f
- add a3, t0, a2
+5:
- sb a1, 0(t0)
- addi t0, t0, 1
- bltu t0, a3, 5b
+6:
- ret
+END(__memset)
2.31.0
Otherwise, LGTM. Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com
Leo Liang
