[U-Boot] [PATCH] TI DaVinci DM646x: Adding initial support for DM6467 EVM
This patch adds the initial support for DM6467 EVM. Other features like NET and NAND support will be added as follow up patches.
Signed-off-by: Sandeep Paulraj s-paulraj@ti.com --- There are multiple flavours of the DM646x. The newest DM646x SOC can operate at 1 GHz. The DM6467 EVM from Spectrum Digital can be used for both speed grades of the DM646x SOC . The only change on the EVM being an oscilator that operated at a higher frequency. The same board file will be used to support both SOC's. Support for this feature will be added as follow up patches.
Patches will also be sent to enable EMAC, NAND and other features. Makefile | 3 + board/davinci/dm6467evm/Makefile | 52 ++++++++++++++ board/davinci/dm6467evm/config.mk | 2 + board/davinci/dm6467evm/dm6467evm.c | 31 ++++++++ include/configs/davinci_dm6467evm.h | 131 +++++++++++++++++++++++++++++++++++ 5 files changed, 219 insertions(+), 0 deletions(-) create mode 100644 board/davinci/dm6467evm/Makefile create mode 100644 board/davinci/dm6467evm/config.mk create mode 100644 board/davinci/dm6467evm/dm6467evm.c create mode 100644 include/configs/davinci_dm6467evm.h
diff --git a/Makefile b/Makefile index 0b61d05..dc797b0 100644 --- a/Makefile +++ b/Makefile @@ -2962,6 +2962,9 @@ davinci_dm355evm_config : unconfig davinci_dm365evm_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm926ejs dm365evm davinci davinci
+davinci_dm6467evm_config : unconfig + @$(MKCONFIG) $(@:_config=) arm arm926ejs dm6467evm davinci davinci + imx27lite_config: unconfig @$(MKCONFIG) $(@:_config=) arm arm926ejs imx27lite logicpd mx27
diff --git a/board/davinci/dm6467evm/Makefile b/board/davinci/dm6467evm/Makefile new file mode 100644 index 0000000..26b0705 --- /dev/null +++ b/board/davinci/dm6467evm/Makefile @@ -0,0 +1,52 @@ +# +# (C) Copyright 2000, 2001, 2002 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := $(BOARD).o +SOBJS := + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### +# This is for $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/davinci/dm6467evm/config.mk b/board/davinci/dm6467evm/config.mk new file mode 100644 index 0000000..ca801c2 --- /dev/null +++ b/board/davinci/dm6467evm/config.mk @@ -0,0 +1,2 @@ +#Provide at least 16MB spacing between us and the Linux Kernel image +TEXT_BASE = 0x81080000 diff --git a/board/davinci/dm6467evm/dm6467evm.c b/board/davinci/dm6467evm/dm6467evm.c new file mode 100644 index 0000000..9605818 --- /dev/null +++ b/board/davinci/dm6467evm/dm6467evm.c @@ -0,0 +1,31 @@ +/* + * Copyright (C) 2009 Texas Instruments Incorporated + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#include <common.h> +#include <asm/io.h> + +DECLARE_GLOBAL_DATA_PTR; + +int board_init(void) +{ + gd->bd->bi_arch_number = MACH_TYPE_DAVINCI_DM6467_EVM; + gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; + + return 0; +} + diff --git a/include/configs/davinci_dm6467evm.h b/include/configs/davinci_dm6467evm.h new file mode 100644 index 0000000..c23d533 --- /dev/null +++ b/include/configs/davinci_dm6467evm.h @@ -0,0 +1,131 @@ +/* + * Copyright (C) 2009 Texas Instruments Incorporated - http://www.ti.com/ + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* Spectrum Digital TMS320DM6467 EVM board */ +#define DAVINCI_DM6467EVM + +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_SKIP_RELOCATE_UBOOT + +/* SoC Configuration */ +#define CONFIG_ARM926EJS /* arm926ejs CPU */ +#define CONFIG_SYS_TIMERBASE 0x01c21400 /* use timer 0 */ +#define CONFIG_SYS_HZ_CLOCK 27000000 +#define CONFIG_SYS_HZ 1000 +#define CONFIG_SOC_DM646X + +/* EEPROM definitions for EEPROM */ +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 6 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 20 + +/* Memory Info */ +#define CONFIG_SYS_MALLOC_LEN (1 << 20) /* 1 MiB */ +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* initial data */ +#define CONFIG_SYS_MEMTEST_START 0x80000000 +#define CONFIG_SYS_MEMTEST_END 0x81000000 /* 16MB RAM test */ +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_STACKSIZE (256 << 10) /* 256 KiB */ +#define PHYS_SDRAM_1 0x80000000 /* DDR Start */ +#define PHYS_SDRAM_1_SIZE (256 << 20) /* DDR size 256MB */ + +/* Linux interfacing */ +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_SYS_BARGSIZE 1024 /* Bootarg Size */ +#define CONFIG_SYS_LOAD_ADDR 0x80700000 /* kernel address */ + +/* Serial Driver info */ +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE 4 +#define CONFIG_SYS_NS16550_COM1 0x01c20000 +#define CONFIG_SYS_NS16550_CLK 24000000 +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* I2C Configuration */ +#define CONFIG_HARD_I2C +#define CONFIG_DRIVER_DAVINCI_I2C +#define CONFIG_SYS_I2C_SPEED 80000 +#define CONFIG_SYS_I2C_SLAVE 10 + +/* Flash & Environment */ +#define CONFIG_SYS_NO_FLASH +#ifdef CONFIG_SYS_USE_NAND +#define CONFIG_NAND_DAVINCI +#undef CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_SIZE (16 << 10) /* 16 KiB */ +#define CONFIG_SYS_NAND_BASE_LIST {0x42000000, } +#define CONFIG_SYS_NAND_HW_ECC +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_ENV_OFFSET 0 +#else +#define CONFIG_ENV_IS_NOWHERE +#define CONFIG_ENV_SIZE (4 << 10) /* 4 KiB */ +#endif + +/* U-Boot general configuration */ +#undef CONFIG_USE_IRQ /* No IRQ/FIQ in U-Boot */ +#define CONFIG_BOOTDELAY 3 +#define CONFIG_BOOTFILE "uImage" /* Boot file name */ +#define CONFIG_SYS_PROMPT "DM6467 EVM > " /* Monitor Command Prompt */ +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_VERSION_VARIABLE +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_CMDLINE_EDITING +#define CONFIG_SYS_LONGHELP +#define CONFIG_CRC32_VERIFY +#define CONFIG_MX_CYCLIC +#define CONFIG_BOOTCOMMAND "source 0x82080000; dhcp; bootm" +#define CONFIG_BOOTARGS \ + "mem=120M console=ttyS0,115200n8 " \ + "root=/dev/hda1 rw noinitrd ip=dhcp" + +/* U-Boot commands */ +#include <config_cmd_default.h> +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DIAG +#define CONFIG_CMD_I2C +#define CONFIG_CMD_MII +#define CONFIG_CMD_SAVES +#define CONFIG_CMD_EEPROM +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_SETGETDCR +#ifdef CONFIG_SYS_USE_NAND +#undef CONFIG_CMD_FLASH +#undef CONFIG_CMD_IMLS +#define CONFIG_CMD_NAND +#endif + +#endif /* __CONFIG_H */ +
Needs an addition to MAKEALL and optionally Maintainers
- @$(MKCONFIG) $(@:_config=) arm arm926ejs dm6467evm davinci davinci
- $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS)
+clean:
- rm -f $(SOBJS) $(OBJS)
+distclean: clean
- rm -f $(LIB) core *.bak $(obj).depend
- Copyright (C) 2009 Texas Instruments Incorporated
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation; either version 2 of the License, or
- (at your option) any later version.
- Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
- gd->bd->bi_arch_number = MACH_TYPE_DAVINCI_DM6467_EVM;
- gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100;
- Copyright (C) 2009 Texas Instruments Incorporated - http://www.ti.com/
Above copyright did not have the http. You should be consistent. Add or remove, your choice.
- MA 02111-1307 USA
Is there a logical register #define you could use instead of the magic number?
This speed is unusual. davinci_sonata.h has a comment that it had a silicon bug with 100k Could the same comment be applied here ?
There is a TAB between #undef and CONFIG_USB_IRQ. Other undef's here use a space.
3 spaces at the end of CONFIG_BOOTCOMMAND can be removed.
Tom
Ok I will add
Ok I will rectify
I can include the hardware.h and get the value from there, but the way the hardware.h for DaVinci has evolved over the years, including it in the config will result in compilation failure. I'll add this to my TODO list and send in a patch to clean up for all DaVinci SOC's the moment I get some free cycles.
The same speed has been used with a slightly older version of U-boot and has worked fine
I don't believe so
Ok will fix.
Will fix
Tom
Thanks, Sandeep
Paulraj, Sandeep wrote:
<snip>
That is fine.
I don't believe so
Ok fine as-is.
Tom
Paulraj, Sandeep
s-paulraj@ti.com
Tom
