Re: [U-Boot-Users] Replacing AT91 u-boot
Sorry, I missed this. Remove the initrd= and mem= part. U-Boot passes correct ATAGS to the kernel.
Thank you again. I followed your suggestions:
U-Boot> printenv bootdelay=3 baudrate=115200 ethaddr=00:02:a5:6e:3f:fd filesize=3638c0 fileaddr=21140000 netmask=255.255.255.0 ipaddr=192.168.0.184 serverip=192.168.0.11 bootargs=root=/dev/ram rw ramdisk_size=15360 console=ttyS0,115200 stdin=serial stdout=serial stderr=serial
U-Boot> tftp 21100000 ramdisk TFTP from server 192.168.0.11; our IP address is 192.168.0.184 Filename 'ramdisk'. Load address: 0x21100000 Loading: ### .snip. ######## done Bytes transferred = 3553472 (3638c0 hex)
U-Boot> tftp 21000000 uImage TFTP from server 192.168.0.11; our IP address is 192.168.0.184 Filename 'uImage'. Load address: 0x21000000 Loading: ############################################## ####################################### done Bytes transferred = 646841 (9deb9 hex)
U-Boot> bootm ## Booting image at 21000000 ... Image Name: Image Type: ARM Linux Kernel Image (gzip compressed) Data Size: 646777 Bytes = 631.6 kB Load Address: 20008000 Entry Point: 20008000 Verifying Checksum ... OK Uncompressing Kernel Image ...
[here is still freezed]
Every test I do I'm more confused. Please apologize my question, but did you ever used an AT91RM9200DK board with u-boot (reading help and your site seems that you are a PPC expert but there is no examples using AT91) ? Why Atmel give out and say to use boot.bin as pre-bootloader and you say not ? Why the u-boot-1.1.3 default configuration for this board don't work ? Maybe there is something missing or wrong ? TIA
My own ARM knowledge is indeed limited, but there are other engineers in our team who know exactly what they are doing; DENX supports PowerPC, ARM and MIPS.
And yes, I did. Here is an example (not exactly the AT91RM9200DK board but the CMC_PU2, but there is no difference between these two boards relevant to this discussion):
U-Boot 1.1.3 (Apr 6 2005 - 15:40:24)
U-Boot code: 20F00000 -> 20F18A38 BSS: -> 20F1D23C RAM Configuration: Bank #0: 20000000 16 MB Board: CMC-PU2 (Rittal GmbH) Flash: 8 MB In: serial Out: serial Err: serial ... => tftp 20800000 /tftpboot/cmcpu2/uImage TFTP from server 192.168.1.1; our IP address is 192.168.20.1 Filename '/tftpboot/cmcpu2/uImage'. Load address: 0x20800000 Loading: ################################################################# ################################################################# ######## done Bytes transferred = 702805 (ab955 hex) => tftp 20900000 /tftpboot/cmcpu2/uRamdisk TFTP from server 192.168.1.1; our IP address is 192.168.20.1 Filename '/tftpboot/cmcpu2/uRamdisk'. Load address: 0x20900000 Loading: ################################################################# ################################################################# ################################################################# ################################################################# ################################## done Bytes transferred = 1502281 (16ec49 hex) => print bootargs bootargs=root=/dev/ram rw ip=192.168.20.1:192.168.1.1:192.168.1.254:255.255.0.0:cmcpu2:eth0:off panic=1 => bootm 20800000 20900000 ## Booting image at 20800000 ... Image Name: ARM Linux-2.4.27 Created: 2005-07-11 15:13:23 UTC Image Type: ARM Linux Kernel Image (gzip compressed) Data Size: 702741 Bytes = 686.3 kB Load Address: 20008000 Entry Point: 20008000 Verifying Checksum ... OK Uncompressing Kernel Image ... OK ## Loading Ramdisk Image at 20900000 ... Image Name: Simple Embedded Linux Framework Created: 2004-11-10 0:35:20 UTC Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 1502217 Bytes = 1.4 MB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK
Starting kernel ...
Linux version 2.4.27-vrs1-mk1 (mk@pollux) (gcc version 3.3.3 (DENX ELDK 3.1.1 3.3.3-9)) #1 Mon Jul 11 17:10:44 MEST 2005 CPU: Arm920Tid(wb) revision 0 Machine: ATMEL AT91RM9200 On node 0 totalpages: 4096 zone(0): 4096 pages. zone(1): 0 pages. zone(2): 0 pages. Kernel command line: root=/dev/ram rw ip=192.168.20.1:192.168.1.1:192.168.1.254:255.255.0.0:cmcpu2:eth0:off panic=1 Calibrating delay loop... 34.50 BogoMIPS Memory: 16MB = 16MB total Memory: 13068KB available (1299K code, 277K data, 56K init) Dentry cache hash table entries: 2048 (order: 2, 16384 bytes) Inode cache hash table entries: 1024 (order: 1, 8192 bytes) Mount cache hash table entries: 512 (order: 0, 4096 bytes) Buffer cache hash table entries: 1024 (order: 0, 4096 bytes) Page-cache hash table entries: 4096 (order: 2, 16384 bytes) CPU: Testing write buffer: pass POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.4 Based upon Swansea University Computer Society NET3.039 Initializing RT netlink socket Starting kswapd Installing knfsd (copyright (C) 1996 okir@monad.swb.de). JFFS2 version 2.1. (C) 2001 Red Hat, Inc., designed by Axis Communications AB. RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize Amd/Fujitsu Extended Query Table v1.3 at 0x0040 number of CFI chips: 1 cfi_cmdset_0002: Disabling fast programming due to code brokenness. Creating 5 MTD partitions on "CMC PU2 flash": 0x00000000-0x00020000 : "Firmware" 0x00020000-0x00030000 : "Environment" 0x00030000-0x000f0000 : "Kernel" 0x000f0000-0x00780000 : "Filesystem 1" 0x00780000-0x00800000 : "Filesystem 2" i2c-core.o: i2c core module version 2.6.1 (20010830) i2c-dev.o: i2c /dev entries driver module version 2.6.1 (20010830) ttyS0 at MMIO 0xfefc0000 (irq = 6) is a AT91_SERIAL ttyS1 at MMIO 0xfefc4000 (irq = 7) is a AT91_SERIAL ttyS2 at MMIO 0xfefc8000 (irq = 8) is a AT91_SERIAL ttyS3 at MMIO 0xfefcc000 (irq = 9) is a AT91_SERIAL ttyS4 at MMIO 0xfefff200 (irq = 1) is a AT91_SERIAL eth0: Link now 100-FullDuplex eth0: AT91 ethernet at 0xfefbc000 int=24 100-FullDuplex (f6:70:1d:61:b5:9d) eth0: Davicom 9196 PHY (Copper) AT91 Watchdog Timer enabled (5 seconds) Found AT91 i2c I2C: RS5C372 RTC driver successfully loaded CMC buzzer driver $Revision: 0.2 $ CMC digital IO driver $Revision: 0.2 $ Serial driver version 0.03 (2004-12-17) with no serial options enabled ttyS5 at 0xc2084000 (irq = 29) is a TI16752 ttyS6 at 0xc2086000 (irq = 30) is a TI16752 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP IP: routing cache hash table of 512 buckets, 4Kbytes TCP: Hash tables configured (established 1024 bind 2048) eth0: Link now 100-FullDuplex IP-Config: Complete: device=eth0, addr=192.168.20.1, mask=255.255.0.0, gw=192.168.1.254, host=cmcpu2, domain=, nis-domain=(none), bootserver=192.168.1.1, rootserver=192.168.1.1, rootpath= NET4: Unix domain sockets 1.0/SMP for Linux NET4.0. NetWinder Floating Point Emulator V0.97 (double precision) RAMDISK: Compressed image found at block 0 Freeing initrd memory: 1467K VFS: Mounted root (ext2 filesystem). Freeing init memory: 56K
BusyBox v0.60.5 (2004.11.10-00:31+0000) Built-in shell (msh) Enter 'help' for a list of built-in commands.
# cat /proc/cpuinfo Processor : Arm920Tid(wb) rev 0 (v4l) BogoMIPS : 34.50 Features : swp half thumb
Hardware : ATMEL AT91RM9200 Revision : 0000 Serial : 0000000000000000 #
There are several reasons. For example, Atmel supports booting from dataflash, too, where a minimal bootstrap loader is necessary.
Why do you think so? From your postings it's clear that U-Boot works - you can even load and start your kernel. It's just that your Linux kernel is not working.
Seems to be some problem with your kernel. Check the typical problems on ARM systems, like if you're using a correct machine ID. Attach a debugger and check where the kernel is hanging, and why. Etc. But this actually is off topic here as it is unrelated to U-Boot.
The messages you showed make it clear that U-Boot *is* running fine on your board.
kentropy
