[U-Boot] [PATCH] rtc: ds1337: drop "SYS" from config variables
There is some inconsistency between uses of CONFIG_RTC_DS13xx and CONFIG_SYS_RTC_DS13xx. Address this by dropping the "SYS" from these variables.
Signed-off-by: Chris Packham judge.packham@gmail.com --- README | 2 +- drivers/rtc/ds1337.c | 16 ++++++++-------- include/configs/UCP1020.h | 2 +- include/configs/tqma6_wru4.h | 2 +- scripts/config_whitelist.txt | 8 +++----- 5 files changed, 14 insertions(+), 16 deletions(-)
diff --git a/README b/README index 9d351ec5ad8c..d2a98e11ace2 100644 --- a/README +++ b/README @@ -1019,7 +1019,7 @@ The following options need to be configured: CONFIG_RTC_DS164x - use Dallas DS164x RTC CONFIG_RTC_ISL1208 - use Intersil ISL1208 RTC CONFIG_RTC_MAX6900 - use Maxim, Inc. MAX6900 RTC - CONFIG_SYS_RTC_DS1337_NOOSC - Turn off the OSC output for DS1337 + CONFIG_RTC_DS1337_NOOSC - Turn off the OSC output for DS1337 CONFIG_SYS_RV3029_TCR - enable trickle charger on RV3029 RTC.
diff --git a/drivers/rtc/ds1337.c b/drivers/rtc/ds1337.c index dae1b3c5cf04..4b73d1718c24 100644 --- a/drivers/rtc/ds1337.c +++ b/drivers/rtc/ds1337.c @@ -150,11 +150,11 @@ int rtc_set (struct rtc_time *tmp) * SQW/INTB* pin and program it for 32,768 Hz output. Note that * according to the datasheet, turning on the square wave output * increases the current drain on the backup battery from about - * 600 nA to 2uA. Define CONFIG_SYS_RTC_DS1337_NOOSC if you wish to turn + * 600 nA to 2uA. Define CONFIG_RTC_DS1337_NOOSC if you wish to turn * off the OSC output. */
-#ifdef CONFIG_SYS_RTC_DS1337_NOOSC +#ifdef CONFIG_RTC_DS1337_NOOSC #define RTC_DS1337_RESET_VAL \ (RTC_CTL_BIT_INTCN | RTC_CTL_BIT_RS1 | RTC_CTL_BIT_RS2) #else @@ -162,16 +162,16 @@ int rtc_set (struct rtc_time *tmp) #endif void rtc_reset (void) { -#ifdef CONFIG_SYS_RTC_DS1337 +#ifdef CONFIG_RTC_DS1337 rtc_write (RTC_CTL_REG_ADDR, RTC_DS1337_RESET_VAL); -#elif defined CONFIG_SYS_RTC_DS1388 +#elif defined CONFIG_RTC_DS1388 rtc_write(RTC_CTL_REG_ADDR, 0x0); /* hw default */ #endif -#ifdef CONFIG_SYS_DS1339_TCR_VAL - rtc_write (RTC_TC_REG_ADDR, CONFIG_SYS_DS1339_TCR_VAL); +#ifdef CONFIG_RTC_DS1339_TCR_VAL + rtc_write (RTC_TC_REG_ADDR, CONFIG_RTC_DS1339_TCR_VAL); #endif -#ifdef CONFIG_SYS_DS1388_TCR_VAL - rtc_write(RTC_TC_REG_ADDR, CONFIG_SYS_DS1388_TCR_VAL); +#ifdef CONFIG_RTC_DS1388_TCR_VAL + rtc_write(RTC_TC_REG_ADDR, CONFIG_RTC_DS1388_TCR_VAL); #endif }
diff --git a/include/configs/UCP1020.h b/include/configs/UCP1020.h index b2feccfd39b9..8579290e81d3 100644 --- a/include/configs/UCP1020.h +++ b/include/configs/UCP1020.h @@ -311,7 +311,7 @@ #define CONFIG_SYS_SPD_BUS_NUM 1 /* For rom_loc and flash bank */
#define CONFIG_RTC_DS1337 -#define CONFIG_SYS_RTC_DS1337_NOOSC +#define CONFIG_RTC_DS1337_NOOSC #define CONFIG_SYS_I2C_RTC_ADDR 0x68 #define CONFIG_SYS_I2C_PCA9557_ADDR 0x18 #define CONFIG_SYS_I2C_NCT72_ADDR 0x4C diff --git a/include/configs/tqma6_wru4.h b/include/configs/tqma6_wru4.h index 4ab4c6559d87..4e99cdbb59ee 100644 --- a/include/configs/tqma6_wru4.h +++ b/include/configs/tqma6_wru4.h @@ -29,7 +29,7 @@ #define CONFIG_SYS_RTC_BUS_NUM 2 #define CONFIG_SYS_I2C_RTC_ADDR 0x68 /* Turn off RTC square-wave output to save battery */ -#define CONFIG_SYS_RTC_DS1337_NOOSC +#define CONFIG_RTC_DS1337_NOOSC
/* LED */
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index e8f49ebe5df7..02153c35513f 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -2269,9 +2269,12 @@ CONFIG_RSK7264 CONFIG_RSK7269 CONFIG_RTC_DS1307 CONFIG_RTC_DS1337 +CONFIG_RTC_DS1337_NOOSC CONFIG_RTC_DS1338 +CONFIG_RTC_DS1339_TCR_VAL CONFIG_RTC_DS1374 CONFIG_RTC_DS1388 +CONFIG_RTC_DS1388_TCR_VAL CONFIG_RTC_DS1556 CONFIG_RTC_DS174x CONFIG_RTC_DS3231 @@ -3383,8 +3386,6 @@ CONFIG_SYS_DRAMSZ1 CONFIG_SYS_DRAM_BASE CONFIG_SYS_DRAM_SIZE CONFIG_SYS_DRAM_TEST -CONFIG_SYS_DS1339_TCR_VAL -CONFIG_SYS_DS1388_TCR_VAL CONFIG_SYS_DSPIC_TEST_ADDR CONFIG_SYS_DSPIC_TEST_MASK CONFIG_SYS_DSPI_CS0 @@ -5515,9 +5516,6 @@ CONFIG_SYS_RSTC_RMR_VAL CONFIG_SYS_RTCSC CONFIG_SYS_RTC_BUS_NUM CONFIG_SYS_RTC_CNT -CONFIG_SYS_RTC_DS1337 -CONFIG_SYS_RTC_DS1337_NOOSC -CONFIG_SYS_RTC_DS1388 CONFIG_SYS_RTC_OSCILLATOR CONFIG_SYS_RTC_PL031_BASE CONFIG_SYS_RTC_REG_BASE_ADDR
Signed-off-by: Chris Packham judge.packham@gmail.com Reviewed-by: Simon Glass sjg@chromium.org
Chris Packham
