[U-Boot] Please pull u-boot-dm
Hi Tom,
Here are the patches left over from last time, along with the two to fix the 'old dtc' problem you identified. Let me know if there are any problems.
I'm still a bit conflicted about the move from fdt@1, kernel@1 to fdt-1 and kernel-1 in the FIT format. I've been thinking whether we should just disable the DT warning. But I gather that everyone else is happy about it, so I suppose we should go ahead.
The following changes since commit 8e9801c283c0e5a7ccd5c04f5ba09003d01f1591:
Merge git://git.denx.de/u-boot-imx (2018-01-15 16:44:18 -0500)
git://git.denx.de/u-boot-dm.git
for you to fetch changes up to ed772fe79bf4419320e997de94b3f93dbbe0838a:
test: Set the DTC environment variable (2018-01-15 18:29:21 -0700)
---------------------------------------------------------------- Andre Przywara (7): doc: FIT image: fix incorrect description of DT node unit address doc: FIT image: fix incorrect examples of DT node unit address doc: fix incorrect usage of DT node unit address fix incorrect usage of DT node unit address in comments sunxi: arm64: correct usage of DT node address in FIT generation tools: fix incorrect usage of DT node unit address armv8: secure firmware: fix incorrect unit address in node name
Simon Glass (8): test: Run binman tests test: Run patman tests test: Run buildman tests test: Run dtoc tests travis.yml: Run tests for tools binman: Run code coverage tests dtoc: Allow DTC environment variable to provide path to dtc test: Set the DTC environment variable
.travis.yml | 15 ++++ .../arm/cpu/armv8/fsl-layerscape/doc/README.falcon | 16 ++-- arch/arm/cpu/armv8/sec_firmware.c | 2 +- board/sunxi/mksunxi_fit_atf.sh | 16 ++-- common/image-fit.c | 16 ++-- common/image-sig.c | 2 +- doc/README.uniphier | 36 ++++---- doc/chromium/chromebook_jerry.its | 16 ++-- doc/chromium/nyan-big.its | 16 ++-- doc/uImage.FIT/beaglebone_vboot.txt | 84 ++++++++--------- doc/uImage.FIT/command_syntax_extensions.txt | 42 ++++----- doc/uImage.FIT/howto.txt | 52 +++++------ doc/uImage.FIT/kernel.its | 28 +++--- doc/uImage.FIT/kernel_fdt.its | 20 ++--- doc/uImage.FIT/multi-with-fpga.its | 28 +++--- doc/uImage.FIT/multi-with-loadables.its | 40 ++++----- doc/uImage.FIT/multi.its | 54 +++++------ doc/uImage.FIT/multi_spl.its | 14 +-- doc/uImage.FIT/overlay-fdt-boot.txt | 78 ++++++++-------- doc/uImage.FIT/sign-configs.its | 18 ++-- doc/uImage.FIT/sign-images.its | 16 ++-- doc/uImage.FIT/signature.txt | 100 ++++++++++----------- doc/uImage.FIT/source_file_format.txt | 26 +++--- doc/uImage.FIT/update3.its | 12 +-- doc/uImage.FIT/update_uboot.its | 4 +- doc/uImage.FIT/x86-fit-boot.txt | 10 +-- include/image.h | 26 +++--- test/run | 15 ++++ tools/binman/README | 4 + tools/dtoc/fdt_util.py | 3 +- tools/fit_image.c | 24 ++--- tools/image-host.c | 10 +-- 32 files changed, 439 insertions(+), 404 deletions(-)
On Tue, Jan 16, 2018 at 06:56:13AM -0800, Simon Glass wrote:
Hi Tom,
Thanks for a checkpatch.pl clean PR and applied to u-boot/master, thanks!
