[U-Boot] [PATCH 00/11] imx: add i.MX6UL and basic board support
Add i.MX 6UltraLite support and include mx6ul_14x14_evk basic board support i.MX 6UltraLite is a high performance, ultra-efficient processor family featuring an advanced implementation of a single Cortex-A7 core.
This patch set is based on: https://patchwork.ozlabs.org/patch/489977/ https://patchwork.ozlabs.org/patch/489976/
i.MX6QP patch set: https://patchwork.ozlabs.org/patch/489464/ https://patchwork.ozlabs.org/patch/489465/ https://patchwork.ozlabs.org/patch/489466/ https://patchwork.ozlabs.org/patch/489467/ https://patchwork.ozlabs.org/patch/489468/ https://patchwork.ozlabs.org/patch/489469/
Peng Fan (11): imx: mx6ul: Add i.MX6UL CPU type imx: mx6ul: Add pins IOMUX head file imx: mx6ul: Update imx registers head file imx-common: add syscounter driver imx: mx6ul remove errata for i.MX6UL and use syscounter imx:mx6ul add clock support imx: mx6ul update soc related settings imx: mx6 add PAD_CTL_SPEED_LOW for i.MX6SX/UL mxc: gpio add i.MX6UL support mx6_common: Fix LOADADDR and SYS_TEXT_BASE for i.MX6UL imx: mx6ul_14x14_evk add basic board support
arch/arm/Kconfig | 7 + arch/arm/cpu/armv7/mx6/Kconfig | 4 + arch/arm/cpu/armv7/mx6/clock.c | 151 +-- arch/arm/cpu/armv7/mx6/soc.c | 4 +- arch/arm/imx-common/Makefile | 7 +- arch/arm/imx-common/cpu.c | 2 + arch/arm/imx-common/syscounter.c | 124 +++ arch/arm/imx-common/timer.c | 8 +- arch/arm/include/asm/arch-imx/cpu.h | 3 +- arch/arm/include/asm/arch-mx6/crm_regs.h | 79 +- arch/arm/include/asm/arch-mx6/imx-regs.h | 60 +- arch/arm/include/asm/arch-mx6/mx6-pins.h | 2 + arch/arm/include/asm/arch-mx6/mx6ul_pins.h | 1065 +++++++++++++++++++++ arch/arm/include/asm/imx-common/iomux-v3.h | 4 + arch/arm/include/asm/imx-common/syscounter.h | 29 + board/freescale/mx6ul_14x14_evk/Kconfig | 15 + board/freescale/mx6ul_14x14_evk/MAINTAINERS | 6 + board/freescale/mx6ul_14x14_evk/Makefile | 6 + board/freescale/mx6ul_14x14_evk/imximage.cfg | 99 ++ board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c | 502 ++++++++++ configs/mx6ul_14x14_evk_defconfig | 3 + drivers/gpio/mxc_gpio.c | 4 + include/configs/mx6_common.h | 10 +- include/configs/mx6ul_14x14_evk.h | 221 +++++ 24 files changed, 2300 insertions(+), 115 deletions(-) create mode 100644 arch/arm/imx-common/syscounter.c create mode 100644 arch/arm/include/asm/arch-mx6/mx6ul_pins.h create mode 100644 arch/arm/include/asm/imx-common/syscounter.h create mode 100644 board/freescale/mx6ul_14x14_evk/Kconfig create mode 100644 board/freescale/mx6ul_14x14_evk/MAINTAINERS create mode 100644 board/freescale/mx6ul_14x14_evk/Makefile create mode 100644 board/freescale/mx6ul_14x14_evk/imximage.cfg create mode 100644 board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c create mode 100644 configs/mx6ul_14x14_evk_defconfig create mode 100644 include/configs/mx6ul_14x14_evk.h
Add MXC_CPU_MX6UL for i.MX6UL CPU type which is got at runtime. The 0x64 is defined as i.MX6UL CPU type value in Reference mannual, but the value has been occupied by i.MX6D as a dummy CPU type. So we also change i.MX6D to value 0x67.
Signed-off-by: Peng Fan Peng.Fan@freescale.com Signed-off-by: Ye.Li B37916@freescale.com --- arch/arm/imx-common/cpu.c | 2 ++ arch/arm/include/asm/arch-imx/cpu.h | 3 ++- 2 files changed, 4 insertions(+), 1 deletion(-)
diff --git a/arch/arm/imx-common/cpu.c b/arch/arm/imx-common/cpu.c index 096d22e..e27546c 100644 --- a/arch/arm/imx-common/cpu.c +++ b/arch/arm/imx-common/cpu.c @@ -138,6 +138,8 @@ const char *get_imx_type(u32 imxtype) return "6SL"; /* Solo-Lite version of the mx6 */ case MXC_CPU_MX6SX: return "6SX"; /* SoloX version of the mx6 */ + case MXC_CPU_MX6UL: + return "6UL"; /* Ultra-Lite version of the mx6 */ case MXC_CPU_MX51: return "51"; case MXC_CPU_MX53: diff --git a/arch/arm/include/asm/arch-imx/cpu.h b/arch/arm/include/asm/arch-imx/cpu.h index 99e0e32..c7f9fff 100644 --- a/arch/arm/include/asm/arch-imx/cpu.h +++ b/arch/arm/include/asm/arch-imx/cpu.h @@ -10,8 +10,9 @@ #define MXC_CPU_MX6DL 0x61 #define MXC_CPU_MX6SX 0x62 #define MXC_CPU_MX6Q 0x63 -#define MXC_CPU_MX6D 0x64 +#define MXC_CPU_MX6UL 0x64 #define MXC_CPU_MX6SOLO 0x65 /* dummy ID */ +#define MXC_CPU_MX6D 0x67 #define MXC_CPU_MX6DP 0x68 #define MXC_CPU_MX6QP 0x69
nit: manual, one N .
Isn't the dummy ID for Solo ? ;-)
Acked-by: Marek Vasut marex@denx.de
Best regards, Marek Vasut
Hi Marek,
About the dummy Id, it does not matter what the value is. You can look into function get_cpu_rev for i.MX6.
Regards, Peng. --
On Friday, July 03, 2015 at 03:17:28 AM, Peng Fan wrote:
Hi Marek,
Hi!
Your patch description is incorrect nonetheless ;-)
Add i.MX6UL pins IOMUX file which defines the IOMUX settings for choose.
Signed-off-by: Peng Fan Peng.Fan@freescale.com Signed-off-by: Ye.Li B37916@freescale.com --- arch/arm/include/asm/arch-mx6/mx6-pins.h | 2 + arch/arm/include/asm/arch-mx6/mx6ul_pins.h | 1065 ++++++++++++++++++++++++++++ 2 files changed, 1067 insertions(+) create mode 100644 arch/arm/include/asm/arch-mx6/mx6ul_pins.h
diff --git a/arch/arm/include/asm/arch-mx6/mx6-pins.h b/arch/arm/include/asm/arch-mx6/mx6-pins.h index 534f780..4b6bb18 100644 --- a/arch/arm/include/asm/arch-mx6/mx6-pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6-pins.h @@ -37,6 +37,8 @@ enum { #include "mx6sl_pins.h" #elif defined(CONFIG_MX6SX) #include "mx6sx_pins.h" +#elif defined(CONFIG_MX6UL) +#include "mx6ul_pins.h" #else #error "Please select cpu" #endif /* CONFIG_MX6Q */ diff --git a/arch/arm/include/asm/arch-mx6/mx6ul_pins.h b/arch/arm/include/asm/arch-mx6/mx6ul_pins.h new file mode 100644 index 0000000..c92b4f0 --- /dev/null +++ b/arch/arm/include/asm/arch-mx6/mx6ul_pins.h @@ -0,0 +1,1065 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ASM_ARCH_IMX6UL_PINS_H__ +#define __ASM_ARCH_IMX6UL_PINS_H__ + +#include <asm/imx-common/iomux-v3.h> + +enum { + + MX6_PAD_BOOT_MODE0__GPIO5_IO10 = IOMUX_PAD(0x02A0, 0x0014, 5, 0x0000, 0, 0), + MX6_PAD_BOOT_MODE1__GPIO5_IO11 = IOMUX_PAD(0x02A4, 0x0018, 5, 0x0000, 0, 0), + /* + * The TAMPER Pin can be used for GPIO, which depends on + * fusemap TAMPER_PIN_DISABLE[1:0] settings. + */ + MX6_PAD_SNVS_TAMPER0__GPIO5_IO00 = IOMUX_PAD(0x02A8, 0x001C, 5, 0x0000, 0, 0), + MX6_PAD_SNVS_TAMPER1__GPIO5_IO01 = IOMUX_PAD(0x02AC, 0x0020, 5, 0x0000, 0, 0), + MX6_PAD_SNVS_TAMPER2__GPIO5_IO02 = IOMUX_PAD(0x02B0, 0x0024, 5, 0x0000, 0, 0), + MX6_PAD_SNVS_TAMPER3__GPIO5_IO03 = IOMUX_PAD(0x02B4, 0x0028, 5, 0x0000, 0, 0), + MX6_PAD_SNVS_TAMPER4__GPIO5_IO04 = IOMUX_PAD(0x02B8, 0x002C, 5, 0x0000, 0, 0), + MX6_PAD_SNVS_TAMPER5__GPIO5_IO05 = IOMUX_PAD(0x02BC, 0x0030, 5, 0x0000, 0, 0), + MX6_PAD_SNVS_TAMPER6__GPIO5_IO06 = IOMUX_PAD(0x02C0, 0x0034, 5, 0x0000, 0, 0), + MX6_PAD_SNVS_TAMPER7__GPIO5_IO07 = IOMUX_PAD(0x02C4, 0x0038, 5, 0x0000, 0, 0), + MX6_PAD_SNVS_TAMPER8__GPIO5_IO08 = IOMUX_PAD(0x02C8, 0x003C, 5, 0x0000, 0, 0), + MX6_PAD_SNVS_TAMPER9__GPIO5_IO09 = IOMUX_PAD(0x02CC, 0x0040, 5, 0x0000, 0, 0), + + MX6_PAD_JTAG_MOD__SJC_MOD = IOMUX_PAD(0x02D0, 0x0044, 0, 0x0000, 0, 0), + MX6_PAD_JTAG_MOD__GPT2_CLK = IOMUX_PAD(0x02D0, 0x0044, 1, 0x05A0, 0, 0), + MX6_PAD_JTAG_MOD__SPDIF_OUT = IOMUX_PAD(0x02D0, 0x0044, 2, 0x0000, 0, 0), + MX6_PAD_JTAG_MOD__ENET1_REF_CLK_25M = IOMUX_PAD(0x02D0, 0x0044, 3, 0x0000, 0, 0), + MX6_PAD_JTAG_MOD__CCM_PMIC_RDY = IOMUX_PAD(0x02D0, 0x0044, 4, 0x04C0, 0, 0), + MX6_PAD_JTAG_MOD__GPIO1_IO10 = IOMUX_PAD(0x02D0, 0x0044, 5, 0x0000, 0, 0), + MX6_PAD_JTAG_MOD__SDMA_EXT_EVENT00 = IOMUX_PAD(0x02D0, 0x0044, 6, 0x0610, 0, 0), + + MX6_PAD_JTAG_TMS__SJC_TMS = IOMUX_PAD(0x02D4, 0x0048, 0, 0x0000, 0, 0), + MX6_PAD_JTAG_TMS__GPT2_CAPTURE1 = IOMUX_PAD(0x02D4, 0x0048, 1, 0x0598, 0, 0), + MX6_PAD_JTAG_TMS__SAI2_MCLK = IOMUX_PAD(0x02D4, 0x0048, 2, 0x05F0, 0, 0), + MX6_PAD_JTAG_TMS__CCM_CLKO1 = IOMUX_PAD(0x02D4, 0x0048, 3, 0x0000, 0, 0), + MX6_PAD_JTAG_TMS__CCM_WAIT = IOMUX_PAD(0x02D4, 0x0048, 4, 0x0000, 0, 0), + MX6_PAD_JTAG_TMS__GPIO1_IO11 = IOMUX_PAD(0x02D4, 0x0048, 5, 0x0000, 0, 0), + MX6_PAD_JTAG_TMS__SDMA_EXT_EVENT01 = IOMUX_PAD(0x02D4, 0x0048, 6, 0x0614, 0, 0), + MX6_PAD_JTAG_TMS__EPIT1_OUT = IOMUX_PAD(0x02D4, 0x0048, 8, 0x0000, 0, 0), + + MX6_PAD_JTAG_TDO__SJC_TDO = IOMUX_PAD(0x02D8, 0x004C, 0, 0x0000, 0, 0), + MX6_PAD_JTAG_TDO__GPT2_CAPTURE2 = IOMUX_PAD(0x02D8, 0x004C, 1, 0x059C, 0, 0), + MX6_PAD_JTAG_TDO__SAI2_TX_SYNC = IOMUX_PAD(0x02D8, 0x004C, 2, 0x05FC, 0, 0), + MX6_PAD_JTAG_TDO__CCM_CLKO2 = IOMUX_PAD(0x02D8, 0x004C, 3, 0x0000, 0, 0), + MX6_PAD_JTAG_TDO__CCM_STOP = IOMUX_PAD(0x02D8, 0x004C, 4, 0x0000, 0, 0), + MX6_PAD_JTAG_TDO__GPIO1_IO12 = IOMUX_PAD(0x02D8, 0x004C, 5, 0x0000, 0, 0), + MX6_PAD_JTAG_TDO__MQS_RIGHT = IOMUX_PAD(0x02D8, 0x004C, 6, 0x0000, 0, 0), + MX6_PAD_JTAG_TDO__EPIT2_OUT = IOMUX_PAD(0x02D8, 0x004C, 8, 0x0000, 0, 0), + + MX6_PAD_JTAG_TDI__SJC_TDI = IOMUX_PAD(0x02DC, 0x0050, 0, 0x0000, 0, 0), + MX6_PAD_JTAG_TDI__GPT2_COMPARE1 = IOMUX_PAD(0x02DC, 0x0050, 1, 0x0000, 0, 0), + MX6_PAD_JTAG_TDI__SAI2_TX_BCLK = IOMUX_PAD(0x02DC, 0x0050, 2, 0x05F8, 0, 0), + MX6_PAD_JTAG_TDI__PWM6_OUT = IOMUX_PAD(0x02DC, 0x0050, 4, 0x0000, 0, 0), + MX6_PAD_JTAG_TDI__GPIO1_IO13 = IOMUX_PAD(0x02DC, 0x0050, 5, 0x0000, 0, 0), + MX6_PAD_JTAG_TDI__MQS_LEFT = IOMUX_PAD(0x02DC, 0x0050, 6, 0x0000, 0, 0), + MX6_PAD_JTAG_TDI__SIM1_POWER_FAIL = IOMUX_PAD(0x02DC, 0x0050, 8, 0x0000, 0, 0), + + MX6_PAD_JTAG_TCK__SJC_TCK = IOMUX_PAD(0x02E0, 0x0054, 0, 0x0000, 0, 0), + MX6_PAD_JTAG_TCK__GPT2_COMPARE2 = IOMUX_PAD(0x02E0, 0x0054, 1, 0x0000, 0, 0), + MX6_PAD_JTAG_TCK__SAI2_RX_DATA = IOMUX_PAD(0x02E0, 0x0054, 2, 0x05F4, 0, 0), + MX6_PAD_JTAG_TCK__PWM7_OUT = IOMUX_PAD(0x02E0, 0x0054, 4, 0x0000, 0, 0), + MX6_PAD_JTAG_TCK__GPIO1_IO14 = IOMUX_PAD(0x02E0, 0x0054, 5, 0x0000, 0, 0), + MX6_PAD_JTAG_TCK__SIM2_POWER_FAIL = IOMUX_PAD(0x02E0, 0x0054, 8, 0x0000, 0, 0), + + MX6_PAD_JTAG_TRST_B__SJC_TRSTB = IOMUX_PAD(0x02E4, 0x0058, 0, 0x0000, 0, 0), + MX6_PAD_JTAG_TRST_B__GPT2_COMPARE3 = IOMUX_PAD(0x02E4, 0x0058, 1, 0x0000, 0, 0), + MX6_PAD_JTAG_TRST_B__SAI2_TX_DATA = IOMUX_PAD(0x02E4, 0x0058, 2, 0x0000, 0, 0), + MX6_PAD_JTAG_TRST_B__PWM8_OUT = IOMUX_PAD(0x02E4, 0x0058, 4, 0x0000, 0, 0), + MX6_PAD_JTAG_TRST_B__GPIO1_IO15 = IOMUX_PAD(0x02E4, 0x0058, 5, 0x0000, 0, 0), + MX6_PAD_JTAG_TRST_B__CAAM_RNG_OSC_OBS = IOMUX_PAD(0x02E4, 0x0058, 8, 0x0000, 0, 0), + + MX6_PAD_GPIO1_IO00__I2C2_SCL = IOMUX_PAD(0x02E8, 0x005C, IOMUX_CONFIG_SION | 0, 0x05AC, 1, 0), + MX6_PAD_GPIO1_IO00__GPT1_CAPTURE1 = IOMUX_PAD(0x02E8, 0x005C, 1, 0x058C, 0, 0), + MX6_PAD_GPIO1_IO00__ANATOP_OTG1_ID = IOMUX_PAD(0x02E8, 0x005C, 2, 0x04B8, 0, 0), + MX6_PAD_GPIO1_IO00__ENET1_REF_CLK1 = IOMUX_PAD(0x02E8, 0x005C, 3, 0x0574, 0, 0), + MX6_PAD_GPIO1_IO00__MQS_RIGHT = IOMUX_PAD(0x02E8, 0x005C, 4, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO00__GPIO1_IO00 = IOMUX_PAD(0x02E8, 0x005C, 5, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO00__ENET1_1588_EVENT0_IN = IOMUX_PAD(0x02E8, 0x005C, 6, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO00__SRC_SYSTEM_RESET = IOMUX_PAD(0x02E8, 0x005C, 7, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO00__WDOG3_WDOG_B = IOMUX_PAD(0x02E8, 0x005C, 8, 0x0000, 0, 0), + + MX6_PAD_GPIO1_IO01__I2C2_SDA = IOMUX_PAD(0x02EC, 0x0060, IOMUX_CONFIG_SION | 0, 0x05B0, 1, 0), + MX6_PAD_GPIO1_IO01__GPT1_COMPARE1 = IOMUX_PAD(0x02EC, 0x0060, 1, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO01__USB_OTG1_OC = IOMUX_PAD(0x02EC, 0x0060, 2, 0x0664, 0, 0), + MX6_PAD_GPIO1_IO01__ENET2_REF_CLK2 = IOMUX_PAD(0x02EC, 0x0060, 3, 0x057C, 0, 0), + MX6_PAD_GPIO1_IO01__MQS_LEFT = IOMUX_PAD(0x02EC, 0x0060, 4, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO01__GPIO1_IO01 = IOMUX_PAD(0x02EC, 0x0060, 5, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO01__ENET1_1588_EVENT0_OUT = IOMUX_PAD(0x02EC, 0x0060, 6, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO01__SRC_EARLY_RESET = IOMUX_PAD(0x02EC, 0x0060, 7, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO01__WDOG1_WDOG_B = IOMUX_PAD(0x02EC, 0x0060, 8, 0x0000, 0, 0), + + MX6_PAD_GPIO1_IO02__I2C1_SCL = IOMUX_PAD(0x02F0, 0x0064, IOMUX_CONFIG_SION | 0, 0x05A4, 0, 0), + MX6_PAD_GPIO1_IO02__GPT1_COMPARE2 = IOMUX_PAD(0x02F0, 0x0064, 1, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO02__USB_OTG2_PWR = IOMUX_PAD(0x02F0, 0x0064, 2, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO02__ENET1_REF_CLK_25M = IOMUX_PAD(0x02F0, 0x0064, 3, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO02__USDHC1_WP = IOMUX_PAD(0x02F0, 0x0064, 4, 0x066C, 0, 0), + MX6_PAD_GPIO1_IO02__GPIO1_IO02 = IOMUX_PAD(0x02F0, 0x0064, 5, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO02__SDMA_EXT_EVENT00 = IOMUX_PAD(0x02F0, 0x0064, 6, 0x0610, 1, 0), + MX6_PAD_GPIO1_IO02__SRC_ANY_PU_RESET = IOMUX_PAD(0x02F0, 0x0064, 7, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO02__UART1_DCE_TX = IOMUX_PAD(0x02F0, 0x0064, 8, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO02__UART1_DTE_RX = IOMUX_PAD(0x02F0, 0x0064, 8, 0x0624, 0, 0), + + MX6_PAD_GPIO1_IO03__I2C1_SDA = IOMUX_PAD(0x02F4, 0x0068, IOMUX_CONFIG_SION | 0, 0x05A8, 1, 0), + MX6_PAD_GPIO1_IO03__GPT1_COMPARE3 = IOMUX_PAD(0x02F4, 0x0068, 1, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO03__USB_OTG2_OC = IOMUX_PAD(0x02F4, 0x0068, 2, 0x0660, 0, 0), + MX6_PAD_GPIO1_IO03__USDHC1_CD_B = IOMUX_PAD(0x02F4, 0x0068, 4, 0x0668, 0, 0), + MX6_PAD_GPIO1_IO03__GPIO1_IO03 = IOMUX_PAD(0x02F4, 0x0068, 5, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO03__CCM_DI0_EXT_CLK = IOMUX_PAD(0x02F4, 0x0068, 6, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO03__SRC_TESTER_ACK = IOMUX_PAD(0x02F4, 0x0068, 7, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO03__UART1_DCE_RX = IOMUX_PAD(0x02F4, 0x0068, 8, 0x0624, 1, 0), + MX6_PAD_GPIO1_IO03__UART1_DTE_TX = IOMUX_PAD(0x02F4, 0x0068, 8, 0x0000, 0, 0), + + MX6_PAD_GPIO1_IO04__ENET1_REF_CLK1 = IOMUX_PAD(0x02F8, 0x006C, 0, 0x0574, 1, 0), + MX6_PAD_GPIO1_IO04__PWM3_OUT = IOMUX_PAD(0x02F8, 0x006C, 1, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO04__USB_OTG1_PWR = IOMUX_PAD(0x02F8, 0x006C, 2, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO04__USDHC1_RESET_B = IOMUX_PAD(0x02F8, 0x006C, 4, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO04__GPIO1_IO04 = IOMUX_PAD(0x02F8, 0x006C, 5, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO04__ENET2_1588_EVENT0_IN = IOMUX_PAD(0x02F8, 0x006C, 6, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO04__UART5_DCE_TX = IOMUX_PAD(0x02F8, 0x006C, 8, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO04__UART5_DTE_RX = IOMUX_PAD(0x02F8, 0x006C, 8, 0x0644, 2, 0), + + MX6_PAD_GPIO1_IO05__ENET2_REF_CLK2 = IOMUX_PAD(0x02FC, 0x0070, 0, 0x057C, 1, 0), + MX6_PAD_GPIO1_IO05__PWM4_OUT = IOMUX_PAD(0x02FC, 0x0070, 1, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO05__ANATOP_OTG2_ID = IOMUX_PAD(0x02FC, 0x0070, 2, 0x04BC, 0, 0), + MX6_PAD_GPIO1_IO05__CSI_FIELD = IOMUX_PAD(0x02FC, 0x0070, 3, 0x0530, 0, 0), + MX6_PAD_GPIO1_IO05__USDHC1_VSELECT = IOMUX_PAD(0x02FC, 0x0070, 4, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO05__GPIO1_IO05 = IOMUX_PAD(0x02FC, 0x0070, 5, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO05__ENET2_1588_EVENT0_OUT = IOMUX_PAD(0x02FC, 0x0070, 6, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO05__UART5_DCE_RX = IOMUX_PAD(0x02FC, 0x0070, 8, 0x0644, 3, 0), + MX6_PAD_GPIO1_IO05__UART5_DTE_TX = IOMUX_PAD(0x02FC, 0x0070, 8, 0x0000, 0, 0), + + MX6_PAD_GPIO1_IO06__ENET1_MDIO = IOMUX_PAD(0x0300, 0x0074, 0, 0x0578, 0, 0), + MX6_PAD_GPIO1_IO06__ENET2_MDIO = IOMUX_PAD(0x0300, 0x0074, 1, 0x0580, 0, 0), + MX6_PAD_GPIO1_IO06__USB_OTG_PWR_WAKE = IOMUX_PAD(0x0300, 0x0074, 2, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO06__CSI_MCLK = IOMUX_PAD(0x0300, 0x0074, 3, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO06__USDHC2_WP = IOMUX_PAD(0x0300, 0x0074, 4, 0x069C, 0, 0), + MX6_PAD_GPIO1_IO06__GPIO1_IO06 = IOMUX_PAD(0x0300, 0x0074, 5, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO06__CCM_WAIT = IOMUX_PAD(0x0300, 0x0074, 6, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO06__CCM_REF_EN_B = IOMUX_PAD(0x0300, 0x0074, 7, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO06__UART1_DCE_CTS = IOMUX_PAD(0x0300, 0x0074, 8, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO06__UART1_DTE_RTS = IOMUX_PAD(0x0300, 0x0074, 8, 0x0620, 0, 0), + + MX6_PAD_GPIO1_IO07__ENET1_MDC = IOMUX_PAD(0x0304, 0x0078, 0, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO07__ENET2_MDC = IOMUX_PAD(0x0304, 0x0078, 1, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO07__USB_OTG_HOST_MODE = IOMUX_PAD(0x0304, 0x0078, 2, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO07__CSI_PIXCLK = IOMUX_PAD(0x0304, 0x0078, 3, 0x0528, 0, 0), + MX6_PAD_GPIO1_IO07__USDHC2_CD_B = IOMUX_PAD(0x0304, 0x0078, 4, 0x0674, 1, 0), + MX6_PAD_GPIO1_IO07__GPIO1_IO07 = IOMUX_PAD(0x0304, 0x0078, 5, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO07__CCM_STOP = IOMUX_PAD(0x0304, 0x0078, 6, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO07__UART1_DCE_RTS = IOMUX_PAD(0x0304, 0x0078, 8, 0x0620, 1, 0), + MX6_PAD_GPIO1_IO07__UART1_DTE_CTS = IOMUX_PAD(0x0304, 0x0078, 8, 0x0000, 0, 0), + + MX6_PAD_GPIO1_IO08__PWM1_OUT = IOMUX_PAD(0x0308, 0x007C, 0, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO08__WDOG1_WDOG_B = IOMUX_PAD(0x0308, 0x007C, 1, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO08__SPDIF_OUT = IOMUX_PAD(0x0308, 0x007C, 2, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO08__CSI_VSYNC = IOMUX_PAD(0x0308, 0x007C, 3, 0x052C, 1, 0), + MX6_PAD_GPIO1_IO08__USDHC2_VSELECT = IOMUX_PAD(0x0308, 0x007C, 4, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO08__GPIO1_IO08 = IOMUX_PAD(0x0308, 0x007C, 5, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO08__CCM_PMIC_RDY = IOMUX_PAD(0x0308, 0x007C, 6, 0x04C0, 1, 0), + MX6_PAD_GPIO1_IO08__UART5_DCE_RTS = IOMUX_PAD(0x0308, 0x007C, 8, 0x0640, 1, 0), + MX6_PAD_GPIO1_IO08__UART5_DTE_CTS = IOMUX_PAD(0x0308, 0x007C, 8, 0x0000, 0, 0), + + MX6_PAD_GPIO1_IO09__PWM2_OUT = IOMUX_PAD(0x030C, 0x0080, 0, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO09__WDOG1_WDOG_ANY = IOMUX_PAD(0x030C, 0x0080, 1, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO09__SPDIF_IN = IOMUX_PAD(0x030C, 0x0080, 2, 0x0618, 0, 0), + MX6_PAD_GPIO1_IO09__CSI_HSYNC = IOMUX_PAD(0x030C, 0x0080, 3, 0x0524, 1, 0), + MX6_PAD_GPIO1_IO09__USDHC2_RESET_B = IOMUX_PAD(0x030C, 0x0080, 4, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO09__GPIO1_IO09 = IOMUX_PAD(0x030C, 0x0080, 5, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO09__USDHC1_RESET_B = IOMUX_PAD(0x030C, 0x0080, 6, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO09__UART5_DCE_CTS = IOMUX_PAD(0x030C, 0x0080, 8, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO09__UART5_DTE_RTS = IOMUX_PAD(0x030C, 0x0080, 8, 0x0640, 2, 0), + + MX6_PAD_UART1_TX_DATA__UART1_DCE_TX = IOMUX_PAD(0x0310, 0x0084, 0, 0x0000, 0, 0), + + MX6_PAD_UART1_TX_DATA__UART1_DTE_RX = IOMUX_PAD(0x0310, 0x0084, 0, 0x0624, 2, 0), + MX6_PAD_UART1_TX_DATA__ENET1_RDATA02 = IOMUX_PAD(0x0310, 0x0084, 1, 0x0000, 0, 0), + MX6_PAD_UART1_TX_DATA__I2C3_SCL = IOMUX_PAD(0x0310, 0x0084, IOMUX_CONFIG_SION | 2, 0x05B4, 0, 0), + MX6_PAD_UART1_TX_DATA__CSI_DATA02 = IOMUX_PAD(0x0310, 0x0084, 3, 0x04C4, 1, 0), + MX6_PAD_UART1_TX_DATA__GPT1_COMPARE1 = IOMUX_PAD(0x0310, 0x0084, 4, 0x0000, 0, 0), + MX6_PAD_UART1_TX_DATA__GPIO1_IO16 = IOMUX_PAD(0x0310, 0x0084, 5, 0x0000, 0, 0), + MX6_PAD_UART1_TX_DATA__SPDIF_OUT = IOMUX_PAD(0x0310, 0x0084, 8, 0x0000, 0, 0), + + MX6_PAD_UART1_RX_DATA__UART1_DCE_RX = IOMUX_PAD(0x0314, 0x0088, 0, 0x0624, 3, 0), + + MX6_PAD_UART1_RX_DATA__UART1_DTE_TX = IOMUX_PAD(0x0314, 0x0088, 0, 0x0000, 0, 0), + MX6_PAD_UART1_RX_DATA__ENET1_RDATA03 = IOMUX_PAD(0x0314, 0x0088, 1, 0x0000, 0, 0), + MX6_PAD_UART1_RX_DATA__I2C3_SDA = IOMUX_PAD(0x0314, 0x0088, IOMUX_CONFIG_SION | 2, 0x05B8, 0, 0), + MX6_PAD_UART1_RX_DATA__CSI_DATA03 = IOMUX_PAD(0x0314, 0x0088, 3, 0x04C8, 1, 0), + MX6_PAD_UART1_RX_DATA__GPT1_CLK = IOMUX_PAD(0x0314, 0x0088, 4, 0x0594, 0, 0), + MX6_PAD_UART1_RX_DATA__GPIO1_IO17 = IOMUX_PAD(0x0314, 0x0088, 5, 0x0000, 0, 0), + MX6_PAD_UART1_RX_DATA__SPDIF_IN = IOMUX_PAD(0x0314, 0x0088, 8, 0x0618, 1, 0), + + MX6_PAD_UART1_CTS_B__UART1_DCE_CTS = IOMUX_PAD(0x0318, 0x008C, 0, 0x0000, 0, 0), + + MX6_PAD_UART1_CTS_B__UART1_DTE_RTS = IOMUX_PAD(0x0318, 0x008C, 0, 0x0620, 2, 0), + MX6_PAD_UART1_CTS_B__ENET1_RX_CLK = IOMUX_PAD(0x0318, 0x008C, 1, 0x0000, 0, 0), + MX6_PAD_UART1_CTS_B__USDHC1_WP = IOMUX_PAD(0x0318, 0x008C, 2, 0x066C, 1, 0), + MX6_PAD_UART1_CTS_B__CSI_DATA04 = IOMUX_PAD(0x0318, 0x008C, 3, 0x04D8, 0, 0), + MX6_PAD_UART1_CTS_B__ENET2_1588_EVENT1_IN = IOMUX_PAD(0x0318, 0x008C, 4, 0x0000, 0, 0), + MX6_PAD_UART1_CTS_B__GPIO1_IO18 = IOMUX_PAD(0x0318, 0x008C, 5, 0x0000, 0, 0), + MX6_PAD_UART1_CTS_B__USDHC2_WP = IOMUX_PAD(0x0318, 0x008C, 8, 0x069C, 1, 0), + + MX6_PAD_UART1_RTS_B__UART1_DCE_RTS = IOMUX_PAD(0x031C, 0x0090, 0, 0x0620, 3, 0), + + MX6_PAD_UART1_RTS_B__UART1_DTE_CTS = IOMUX_PAD(0x031C, 0x0090, 0, 0x0000, 0, 0), + MX6_PAD_UART1_RTS_B__ENET1_TX_ER = IOMUX_PAD(0x031C, 0x0090, 1, 0x0000, 0, 0), + MX6_PAD_UART1_RTS_B__USDHC1_CD_B = IOMUX_PAD(0x031C, 0x0090, 2, 0x0668, 1, 0), + MX6_PAD_UART1_RTS_B__CSI_DATA05 = IOMUX_PAD(0x031C, 0x0090, 3, 0x04CC, 1, 0), + MX6_PAD_UART1_RTS_B__ENET2_1588_EVENT1_OUT = IOMUX_PAD(0x031C, 0x0090, 4, 0x0000, 0, 0), + MX6_PAD_UART1_RTS_B__GPIO1_IO19 = IOMUX_PAD(0x031C, 0x0090, 5, 0x0000, 0, 0), + MX6_PAD_UART1_RTS_B__USDHC2_CD_B = IOMUX_PAD(0x031C, 0x0090, 8, 0x0674, 2, 0), + + MX6_PAD_UART2_TX_DATA__UART2_DCE_TX = IOMUX_PAD(0x0320, 0x0094, 0, 0x0000, 0, 0), + + MX6_PAD_UART2_TX_DATA__UART2_DTE_RX = IOMUX_PAD(0x0320, 0x0094, 0, 0x062C, 0, 0), + MX6_PAD_UART2_TX_DATA__ENET1_TDATA02 = IOMUX_PAD(0x0320, 0x0094, 1, 0x0000, 0, 0), + MX6_PAD_UART2_TX_DATA__I2C4_SCL = IOMUX_PAD(0x0320, 0x0094, IOMUX_CONFIG_SION | 2, 0x05BC, 0, 0), + MX6_PAD_UART2_TX_DATA__CSI_DATA06 = IOMUX_PAD(0x0320, 0x0094, 3, 0x04DC, 0, 0), + MX6_PAD_UART2_TX_DATA__GPT1_CAPTURE1 = IOMUX_PAD(0x0320, 0x0094, 4, 0x058C, 1, 0), + MX6_PAD_UART2_TX_DATA__GPIO1_IO20 = IOMUX_PAD(0x0320, 0x0094, 5, 0x0000, 0, 0), + MX6_PAD_UART2_TX_DATA__ECSPI3_SS0 = IOMUX_PAD(0x0320, 0x0094, 8, 0x0560, 0, 0), + + MX6_PAD_UART2_RX_DATA__UART2_DCE_RX = IOMUX_PAD(0x0324, 0x0098, 0, 0x062C, 1, 0), + + MX6_PAD_UART2_RX_DATA__UART2_DTE_TX = IOMUX_PAD(0x0324, 0x0098, 0, 0x0000, 0, 0), + MX6_PAD_UART2_RX_DATA__ENET1_TDATA03 = IOMUX_PAD(0x0324, 0x0098, 1, 0x0000, 0, 0), + MX6_PAD_UART2_RX_DATA__I2C4_SDA = IOMUX_PAD(0x0324, 0x0098, IOMUX_CONFIG_SION | 2, 0x05C0, 0, 0), + MX6_PAD_UART2_RX_DATA__CSI_DATA07 = IOMUX_PAD(0x0324, 0x0098, 3, 0x04E0, 0, 0), + MX6_PAD_UART2_RX_DATA__GPT1_CAPTURE2 = IOMUX_PAD(0x0324, 0x0098, 4, 0x0590, 0, 0), + MX6_PAD_UART2_RX_DATA__GPIO1_IO21 = IOMUX_PAD(0x0324, 0x0098, 5, 0x0000, 0, 0), + MX6_PAD_UART2_RX_DATA__SJC_DONE = IOMUX_PAD(0x0324, 0x0098, 7, 0x0000, 0, 0), + MX6_PAD_UART2_RX_DATA__ECSPI3_SCLK = IOMUX_PAD(0x0324, 0x0098, 8, 0x0554, 0, 0), + + MX6_PAD_UART2_CTS_B__UART2_DCE_CTS = IOMUX_PAD(0x0328, 0x009C, 0, 0x0000, 0, 0), + + MX6_PAD_UART2_CTS_B__UART2_DTE_RTS = IOMUX_PAD(0x0328, 0x009C, 0, 0x0628, 0, 0), + MX6_PAD_UART2_CTS_B__ENET1_CRS = IOMUX_PAD(0x0328, 0x009C, 1, 0x0000, 0, 0), + MX6_PAD_UART2_CTS_B__FLEXCAN2_TX = IOMUX_PAD(0x0328, 0x009C, 2, 0x0000, 0, 0), + MX6_PAD_UART2_CTS_B__CSI_DATA08 = IOMUX_PAD(0x0328, 0x009C, 3, 0x04E4, 0, 0), + MX6_PAD_UART2_CTS_B__GPT1_COMPARE2 = IOMUX_PAD(0x0328, 0x009C, 4, 0x0000, 0, 0), + MX6_PAD_UART2_CTS_B__GPIO1_IO22 = IOMUX_PAD(0x0328, 0x009C, 5, 0x0000, 0, 0), + MX6_PAD_UART2_CTS_B__SJC_DE_B = IOMUX_PAD(0x0328, 0x009C, 7, 0x0000, 0, 0), + MX6_PAD_UART2_CTS_B__ECSPI3_MOSI = IOMUX_PAD(0x0328, 0x009C, 8, 0x055C, 0, 0), + + MX6_PAD_UART2_RTS_B__UART2_DCE_RTS = IOMUX_PAD(0x032C, 0x00A0, 0, 0x0628, 1, 0), + + MX6_PAD_UART2_RTS_B__UART2_DTE_CTS = IOMUX_PAD(0x032C, 0x00A0, 0, 0x0000, 0, 0), + MX6_PAD_UART2_RTS_B__ENET1_COL = IOMUX_PAD(0x032C, 0x00A0, 1, 0x0000, 0, 0), + MX6_PAD_UART2_RTS_B__FLEXCAN2_RX = IOMUX_PAD(0x032C, 0x00A0, 2, 0x0588, 0, 0), + MX6_PAD_UART2_RTS_B__CSI_DATA09 = IOMUX_PAD(0x032C, 0x00A0, 3, 0x04E8, 0, 0), + MX6_PAD_UART2_RTS_B__GPT1_COMPARE3 = IOMUX_PAD(0x032C, 0x00A0, 4, 0x0000, 0, 0), + MX6_PAD_UART2_RTS_B__GPIO1_IO23 = IOMUX_PAD(0x032C, 0x00A0, 5, 0x0000, 0, 0), + MX6_PAD_UART2_RTS_B__SJC_FAIL = IOMUX_PAD(0x032C, 0x00A0, 7, 0x0000, 0, 0), + MX6_PAD_UART2_RTS_B__ECSPI3_MISO = IOMUX_PAD(0x032C, 0x00A0, 8, 0x0558, 0, 0), + + MX6_PAD_UART3_TX_DATA__UART3_DCE_TX = IOMUX_PAD(0x0330, 0x00A4, 0, 0x0000, 0, 0), + + MX6_PAD_UART3_TX_DATA__UART3_DTE_RX = IOMUX_PAD(0x0330, 0x00A4, 0, 0x0634, 0, 0), + MX6_PAD_UART3_TX_DATA__ENET2_RDATA02 = IOMUX_PAD(0x0330, 0x00A4, 1, 0x0000, 0, 0), + MX6_PAD_UART3_TX_DATA__SIM1_PORT0_PD = IOMUX_PAD(0x0330, 0x00A4, 2, 0x0000, 0, 0), + MX6_PAD_UART3_TX_DATA__CSI_DATA01 = IOMUX_PAD(0x0330, 0x00A4, 3, 0x04D4, 0, 0), + MX6_PAD_UART3_TX_DATA__UART2_DCE_CTS = IOMUX_PAD(0x0330, 0x00A4, 4, 0x0000, 0, 0), + MX6_PAD_UART3_TX_DATA__UART2_DTE_RTS = IOMUX_PAD(0x0330, 0x00A4, 4, 0x0628, 2, 0), + MX6_PAD_UART3_TX_DATA__GPIO1_IO24 = IOMUX_PAD(0x0330, 0x00A4, 5, 0x0000, 0, 0), + MX6_PAD_UART3_TX_DATA__SJC_JTAG_ACT = IOMUX_PAD(0x0330, 0x00A4, 7, 0x0000, 0, 0), + MX6_PAD_UART3_TX_DATA__ANATOP_OTG1_ID = IOMUX_PAD(0x0330, 0x00A4, 8, 0x04B8, 1, 0), + + MX6_PAD_UART3_RX_DATA__UART3_DCE_RX = IOMUX_PAD(0x0334, 0x00A8, 0, 0x0634, 1, 0), + + MX6_PAD_UART3_RX_DATA__UART3_DTE_TX = IOMUX_PAD(0x0334, 0x00A8, 0, 0x0000, 0, 0), + MX6_PAD_UART3_RX_DATA__ENET2_RDATA03 = IOMUX_PAD(0x0334, 0x00A8, 1, 0x0000, 0, 0), + MX6_PAD_UART3_RX_DATA__SIM2_PORT0_PD = IOMUX_PAD(0x0334, 0x00A8, 2, 0x0000, 0, 0), + MX6_PAD_UART3_RX_DATA__CSI_DATA00 = IOMUX_PAD(0x0334, 0x00A8, 3, 0x04D0, 0, 0), + MX6_PAD_UART3_RX_DATA__UART2_DCE_RTS = IOMUX_PAD(0x0334, 0x00A8, 4, 0x0628, 3, 0), + MX6_PAD_UART3_RX_DATA__UART2_DTE_CTS = IOMUX_PAD(0x0334, 0x00A8, 4, 0x0000, 0, 0), + MX6_PAD_UART3_RX_DATA__GPIO1_IO25 = IOMUX_PAD(0x0334, 0x00A8, 5, 0x0000, 0, 0), + MX6_PAD_UART3_RX_DATA__EPIT1_OUT = IOMUX_PAD(0x0334, 0x00A8, 8, 0x0000, 0, 0), + + MX6_PAD_UART3_CTS_B__UART3_DCE_CTS = IOMUX_PAD(0x0338, 0x00AC, 0, 0x0000, 0, 0), + + MX6_PAD_UART3_CTS_B__UART3_DTE_RTS = IOMUX_PAD(0x0338, 0x00AC, 0, 0x0630, 0, 0), + MX6_PAD_UART3_CTS_B__ENET2_RX_CLK = IOMUX_PAD(0x0338, 0x00AC, IOMUX_CONFIG_SION | 1, 0x0000, 0, 0), + MX6_PAD_UART3_CTS_B__FLEXCAN1_TX = IOMUX_PAD(0x0338, 0x00AC, 2, 0x0000, 0, 0), + MX6_PAD_UART3_CTS_B__CSI_DATA10 = IOMUX_PAD(0x0338, 0x00AC, 3, 0x04EC, 0, 0), + MX6_PAD_UART3_CTS_B__ENET1_1588_EVENT1_IN = IOMUX_PAD(0x0338, 0x00AC, 4, 0x0000, 0, 0), + MX6_PAD_UART3_CTS_B__GPIO1_IO26 = IOMUX_PAD(0x0338, 0x00AC, 5, 0x0000, 0, 0), + MX6_PAD_UART3_CTS_B__EPIT2_OUT = IOMUX_PAD(0x0338, 0x00AC, 8, 0x0000, 0, 0), + + MX6_PAD_UART3_RTS_B__UART3_DCE_RTS = IOMUX_PAD(0x033C, 0x00B0, 0, 0x0630, 1, 0), + + MX6_PAD_UART3_RTS_B__UART3_DTE_CTS = IOMUX_PAD(0x033C, 0x00B0, 0, 0x0000, 0, 0), + MX6_PAD_UART3_RTS_B__ENET2_TX_ER = IOMUX_PAD(0x033C, 0x00B0, 1, 0x0000, 0, 0), + MX6_PAD_UART3_RTS_B__FLEXCAN1_RX = IOMUX_PAD(0x033C, 0x00B0, 2, 0x0584, 0, 0), + MX6_PAD_UART3_RTS_B__CSI_DATA11 = IOMUX_PAD(0x033C, 0x00B0, 3, 0x04F0, 0, 0), + MX6_PAD_UART3_RTS_B__ENET1_1588_EVENT1_OUT = IOMUX_PAD(0x033C, 0x00B0, 4, 0x0000, 0, 0), + MX6_PAD_UART3_RTS_B__GPIO1_IO27 = IOMUX_PAD(0x033C, 0x00B0, 5, 0x0000, 0, 0), + MX6_PAD_UART3_RTS_B__WDOG1_WDOG_B = IOMUX_PAD(0x033C, 0x00B0, 8, 0x0000, 0, 0), + + MX6_PAD_UART4_TX_DATA__UART4_DCE_TX = IOMUX_PAD(0x0340, 0x00B4, 0, 0x0000, 0, 0), + + MX6_PAD_UART4_TX_DATA__UART4_DTE_RX = IOMUX_PAD(0x0340, 0x00B4, 0, 0x063C, 0, 0), + MX6_PAD_UART4_TX_DATA__ENET2_TDATA02 = IOMUX_PAD(0x0340, 0x00B4, 1, 0x0000, 0, 0), + MX6_PAD_UART4_TX_DATA__I2C1_SCL = IOMUX_PAD(0x0340, 0x00B4, IOMUX_CONFIG_SION | 2, 0x05A4, 1, 0), + MX6_PAD_UART4_TX_DATA__CSI_DATA12 = IOMUX_PAD(0x0340, 0x00B4, 3, 0x04F4, 0, 0), + MX6_PAD_UART4_TX_DATA__CSU_CSU_ALARM_AUT02 = IOMUX_PAD(0x0340, 0x00B4, 4, 0x0000, 0, 0), + MX6_PAD_UART4_TX_DATA__GPIO1_IO28 = IOMUX_PAD(0x0340, 0x00B4, 5, 0x0000, 0, 0), + MX6_PAD_UART4_TX_DATA__ECSPI2_SCLK = IOMUX_PAD(0x0340, 0x00B4, 8, 0x0544, 1, 0), + + MX6_PAD_UART4_RX_DATA__UART4_DCE_RX = IOMUX_PAD(0x0344, 0x00B8, 0, 0x063C, 1, 0), + + MX6_PAD_UART4_RX_DATA__UART4_DTE_TX = IOMUX_PAD(0x0344, 0x00B8, 0, 0x0000, 0, 0), + MX6_PAD_UART4_RX_DATA__ENET2_TDATA03 = IOMUX_PAD(0x0344, 0x00B8, 1, 0x0000, 0, 0), + MX6_PAD_UART4_RX_DATA__I2C1_SDA = IOMUX_PAD(0x0344, 0x00B8, IOMUX_CONFIG_SION | 2, 0x05A8, 2, 0), + MX6_PAD_UART4_RX_DATA__CSI_DATA13 = IOMUX_PAD(0x0344, 0x00B8, 3, 0x04F8, 0, 0), + MX6_PAD_UART4_RX_DATA__CSU_CSU_ALARM_AUT01 = IOMUX_PAD(0x0344, 0x00B8, 4, 0x0000, 0, 0), + MX6_PAD_UART4_RX_DATA__GPIO1_IO29 = IOMUX_PAD(0x0344, 0x00B8, 5, 0x0000, 0, 0), + MX6_PAD_UART4_RX_DATA__ECSPI2_SS0 = IOMUX_PAD(0x0344, 0x00B8, 8, 0x0550, 1, 0), + MX6_PAD_UART5_TX_DATA__GPIO1_IO30 = IOMUX_PAD(0x0348, 0x00BC, 5, 0x0000, 0, 0), + MX6_PAD_UART5_TX_DATA__ECSPI2_MOSI = IOMUX_PAD(0x0348, 0x00BC, 8, 0x054C, 0, 0), + + MX6_PAD_UART5_TX_DATA__UART5_DCE_TX = IOMUX_PAD(0x0348, 0x00BC, 0, 0x0000, 0, 0), + + MX6_PAD_UART5_TX_DATA__UART5_DTE_RX = IOMUX_PAD(0x0348, 0x00BC, 0, 0x0644, 4, 0), + MX6_PAD_UART5_TX_DATA__ENET2_CRS = IOMUX_PAD(0x0348, 0x00BC, 1, 0x0000, 0, 0), + MX6_PAD_UART5_TX_DATA__I2C2_SCL = IOMUX_PAD(0x0348, 0x00BC, IOMUX_CONFIG_SION | 2, 0x05AC, 2, 0), + MX6_PAD_UART5_TX_DATA__CSI_DATA14 = IOMUX_PAD(0x0348, 0x00BC, 3, 0x04FC, 0, 0), + MX6_PAD_UART5_TX_DATA__CSU_CSU_ALARM_AUT00 = IOMUX_PAD(0x0348, 0x00BC, 4, 0x0000, 0, 0), + + MX6_PAD_UART5_RX_DATA__UART5_DCE_RX = IOMUX_PAD(0x034C, 0x00C0, 0, 0x0644, 5, 0), + + MX6_PAD_UART5_RX_DATA__UART5_DTE_TX = IOMUX_PAD(0x034C, 0x00C0, 0, 0x0000, 0, 0), + MX6_PAD_UART5_RX_DATA__ENET2_COL = IOMUX_PAD(0x034C, 0x00C0, 1, 0x0000, 0, 0), + MX6_PAD_UART5_RX_DATA__I2C2_SDA = IOMUX_PAD(0x034C, 0x00C0, IOMUX_CONFIG_SION | 2, 0x05B0, 2, 0), + MX6_PAD_UART5_RX_DATA__CSI_DATA15 = IOMUX_PAD(0x034C, 0x00C0, 3, 0x0500, 0, 0), + MX6_PAD_UART5_RX_DATA__CSU_CSU_INT_DEB = IOMUX_PAD(0x034C, 0x00C0, 4, 0x0000, 0, 0), + MX6_PAD_UART5_RX_DATA__GPIO1_IO31 = IOMUX_PAD(0x034C, 0x00C0, 5, 0x0000, 0, 0), + MX6_PAD_UART5_RX_DATA__ECSPI2_MISO = IOMUX_PAD(0x034C, 0x00C0, 8, 0x0548, 1, 0), + + MX6_PAD_ENET1_RX_DATA0__ENET1_RDATA00 = IOMUX_PAD(0x0350, 0x00C4, 0, 0x0000, 0, 0), + MX6_PAD_ENET1_RX_DATA0__UART4_DCE_RTS = IOMUX_PAD(0x0350, 0x00C4, 1, 0x0638, 0, 0), + MX6_PAD_ENET1_RX_DATA0__UART4_DTE_CTS = IOMUX_PAD(0x0350, 0x00C4, 1, 0x0000, 0, 0), + MX6_PAD_ENET1_RX_DATA0__PWM1_OUT = IOMUX_PAD(0x0350, 0x00C4, 2, 0x0000, 0, 0), + MX6_PAD_ENET1_RX_DATA0__CSI_DATA16 = IOMUX_PAD(0x0350, 0x00C4, 3, 0x0504, 0, 0), + MX6_PAD_ENET1_RX_DATA0__FLEXCAN1_TX = IOMUX_PAD(0x0350, 0x00C4, 4, 0x0000, 0, 0), + MX6_PAD_ENET1_RX_DATA0__GPIO2_IO00 = IOMUX_PAD(0x0350, 0x00C4, 5, 0x0000, 0, 0), + MX6_PAD_ENET1_RX_DATA0__KPP_ROW00 = IOMUX_PAD(0x0350, 0x00C4, 6, 0x05D0, 0, 0), + MX6_PAD_ENET1_RX_DATA0__USDHC1_LCTL = IOMUX_PAD(0x0350, 0x00C4, 8, 0x0000, 0, 0), + + MX6_PAD_ENET1_RX_DATA1__ENET1_RDATA01 = IOMUX_PAD(0x0354, 0x00C8, 0, 0x0000, 0, 0), + MX6_PAD_ENET1_RX_DATA1__UART4_DCE_CTS = IOMUX_PAD(0x0354, 0x00C8, 1, 0x0000, 0, 0), + MX6_PAD_ENET1_RX_DATA1__UART4_DTE_RTS = IOMUX_PAD(0x0354, 0x00C8, 1, 0x0638, 1, 0), + MX6_PAD_ENET1_RX_DATA1__PWM2_OUT = IOMUX_PAD(0x0354, 0x00C8, 2, 0x0000, 0, 0), + MX6_PAD_ENET1_RX_DATA1__CSI_DATA17 = IOMUX_PAD(0x0354, 0x00C8, 3, 0x0508, 0, 0), + MX6_PAD_ENET1_RX_DATA1__FLEXCAN1_RX = IOMUX_PAD(0x0354, 0x00C8, 4, 0x0584, 1, 0), + MX6_PAD_ENET1_RX_DATA1__GPIO2_IO01 = IOMUX_PAD(0x0354, 0x00C8, 5, 0x0000, 0, 0), + MX6_PAD_ENET1_RX_DATA1__KPP_COL00 = IOMUX_PAD(0x0354, 0x00C8, 6, 0x05C4, 0, 0), + MX6_PAD_ENET1_RX_DATA1__USDHC2_LCTL = IOMUX_PAD(0x0354, 0x00C8, 8, 0x0000, 0, 0), + + MX6_PAD_ENET1_RX_EN__ENET1_RX_EN = IOMUX_PAD(0x0358, 0x00CC, 0, 0x0000, 0, 0), + MX6_PAD_ENET1_RX_EN__UART5_DCE_RTS = IOMUX_PAD(0x0358, 0x00CC, 1, 0x0640, 3, 0), + MX6_PAD_ENET1_RX_EN__UART5_DTE_CTS = IOMUX_PAD(0x0358, 0x00CC, 1, 0x0000, 0, 0), + MX6_PAD_ENET1_RX_EN__CSI_DATA18 = IOMUX_PAD(0x0358, 0x00CC, 3, 0x050C, 0, 0), + MX6_PAD_ENET1_RX_EN__FLEXCAN2_TX = IOMUX_PAD(0x0358, 0x00CC, 4, 0x0000, 0, 0), + MX6_PAD_ENET1_RX_EN__GPIO2_IO02 = IOMUX_PAD(0x0358, 0x00CC, 5, 0x0000, 0, 0), + MX6_PAD_ENET1_RX_EN__KPP_ROW01 = IOMUX_PAD(0x0358, 0x00CC, 6, 0x05D4, 0, 0), + MX6_PAD_ENET1_RX_EN__USDHC1_VSELECT = IOMUX_PAD(0x0358, 0x00CC, 8, 0x0000, 0, 0), + + MX6_PAD_ENET1_TX_DATA0__ENET1_TDATA00 = IOMUX_PAD(0x035C, 0x00D0, 0, 0x0000, 0, 0), + MX6_PAD_ENET1_TX_DATA0__UART5_DCE_CTS = IOMUX_PAD(0x035C, 0x00D0, 1, 0x0000, 0, 0), + MX6_PAD_ENET1_TX_DATA0__UART5_DTE_RTS = IOMUX_PAD(0x035C, 0x00D0, 1, 0x0640, 4, 0), + MX6_PAD_ENET1_TX_DATA0__CSI_DATA19 = IOMUX_PAD(0x035C, 0x00D0, 3, 0x0510, 0, 0), + MX6_PAD_ENET1_TX_DATA0__FLEXCAN2_RX = IOMUX_PAD(0x035C, 0x00D0, 4, 0x0588, 1, 0), + MX6_PAD_ENET1_TX_DATA0__GPIO2_IO03 = IOMUX_PAD(0x035C, 0x00D0, 5, 0x0000, 0, 0), + MX6_PAD_ENET1_TX_DATA0__KPP_COL01 = IOMUX_PAD(0x035C, 0x00D0, 6, 0x05C8, 0, 0), + MX6_PAD_ENET1_TX_DATA0__USDHC2_VSELECT = IOMUX_PAD(0x035C, 0x00D0, 8, 0x0000, 0, 0), + + MX6_PAD_ENET1_TX_DATA1__ENET1_TDATA01 = IOMUX_PAD(0x0360, 0x00D4, 0, 0x0000, 0, 0), + MX6_PAD_ENET1_TX_DATA1__UART6_DCE_CTS = IOMUX_PAD(0x0360, 0x00D4, 1, 0x0000, 0, 0), + MX6_PAD_ENET1_TX_DATA1__UART6_DTE_RTS = IOMUX_PAD(0x0360, 0x00D4, 1, 0x0648, 2, 0), + MX6_PAD_ENET1_TX_DATA1__PWM5_OUT = IOMUX_PAD(0x0360, 0x00D4, 2, 0x0000, 0, 0), + MX6_PAD_ENET1_TX_DATA1__CSI_DATA20 = IOMUX_PAD(0x0360, 0x00D4, 3, 0x0514, 0, 0), + MX6_PAD_ENET1_TX_DATA1__ENET2_MDIO = IOMUX_PAD(0x0360, 0x00D4, 4, 0x0580, 1, 0), + MX6_PAD_ENET1_TX_DATA1__GPIO2_IO04 = IOMUX_PAD(0x0360, 0x00D4, 5, 0x0000, 0, 0), + MX6_PAD_ENET1_TX_DATA1__KPP_ROW02 = IOMUX_PAD(0x0360, 0x00D4, 6, 0x05D8, 0, 0), + MX6_PAD_ENET1_TX_DATA1__WDOG1_WDOG_RST_B_DEB = IOMUX_PAD(0x0360, 0x00D4, 8, 0x0000, 0, 0), + + MX6_PAD_ENET1_TX_EN__ENET1_TX_EN = IOMUX_PAD(0x0364, 0x00D8, 0, 0x0000, 0, 0), + MX6_PAD_ENET1_TX_EN__UART6_DCE_RTS = IOMUX_PAD(0x0364, 0x00D8, 1, 0x0648, 3, 0), + MX6_PAD_ENET1_TX_EN__UART6_DTE_CTS = IOMUX_PAD(0x0364, 0x00D8, 1, 0x0000, 0, 0), + MX6_PAD_ENET1_TX_EN__PWM6_OUT = IOMUX_PAD(0x0364, 0x00D8, 2, 0x0000, 0, 0), + MX6_PAD_ENET1_TX_EN__CSI_DATA21 = IOMUX_PAD(0x0364, 0x00D8, 3, 0x0518, 0, 0), + MX6_PAD_ENET1_TX_EN__ENET2_MDC = IOMUX_PAD(0x0364, 0x00D8, 4, 0x0000, 0, 0), + MX6_PAD_ENET1_TX_EN__GPIO2_IO05 = IOMUX_PAD(0x0364, 0x00D8, 5, 0x0000, 0, 0), + MX6_PAD_ENET1_TX_EN__KPP_COL02 = IOMUX_PAD(0x0364, 0x00D8, 6, 0x05CC, 0, 0), + MX6_PAD_ENET1_TX_EN__WDOG2_WDOG_RST_B_DEB = IOMUX_PAD(0x0364, 0x00D8, 8, 0x0000, 0, 0), + + MX6_PAD_ENET1_TX_CLK__ENET1_TX_CLK = IOMUX_PAD(0x0368, 0x00DC, 0, 0x0000, 0, 0), + MX6_PAD_ENET1_TX_CLK__UART7_DCE_CTS = IOMUX_PAD(0x0368, 0x00DC, 1, 0x0000, 0, 0), + MX6_PAD_ENET1_TX_CLK__UART7_DTE_RTS = IOMUX_PAD(0x0368, 0x00DC, 1, 0x0650, 0, 0), + MX6_PAD_ENET1_TX_CLK__PWM7_OUT = IOMUX_PAD(0x0368, 0x00DC, 2, 0x0000, 0, 0), + MX6_PAD_ENET1_TX_CLK__CSI_DATA22 = IOMUX_PAD(0x0368, 0x00DC, 3, 0x051C, 0, 0), + MX6_PAD_ENET1_TX_CLK__ENET1_REF_CLK1 = IOMUX_PAD(0x0368, 0x00DC, IOMUX_CONFIG_SION | 4, 0x0574, 2, 0), + MX6_PAD_ENET1_TX_CLK__GPIO2_IO06 = IOMUX_PAD(0x0368, 0x00DC, 5, 0x0000, 0, 0), + MX6_PAD_ENET1_TX_CLK__KPP_ROW03 = IOMUX_PAD(0x0368, 0x00DC, 6, 0x0000, 0, 0), + MX6_PAD_ENET1_TX_CLK__GPT1_CLK = IOMUX_PAD(0x0368, 0x00DC, 8, 0x0594, 1, 0), + + MX6_PAD_ENET1_RX_ER__ENET1_RX_ER = IOMUX_PAD(0x036C, 0x00E0, 0, 0x0000, 0, 0), + MX6_PAD_ENET1_RX_ER__UART7_DCE_RTS = IOMUX_PAD(0x036C, 0x00E0, 1, 0x0650, 1, 0), + MX6_PAD_ENET1_RX_ER__UART7_DTE_CTS = IOMUX_PAD(0x036C, 0x00E0, 1, 0x0000, 0, 0), + MX6_PAD_ENET1_RX_ER__PWM8_OUT = IOMUX_PAD(0x036C, 0x00E0, 2, 0x0000, 0, 0), + MX6_PAD_ENET1_RX_ER__CSI_DATA23 = IOMUX_PAD(0x036C, 0x00E0, 3, 0x0520, 0, 0), + MX6_PAD_ENET1_RX_ER__EIM_CRE = IOMUX_PAD(0x036C, 0x00E0, 4, 0x0000, 0, 0), + MX6_PAD_ENET1_RX_ER__GPIO2_IO07 = IOMUX_PAD(0x036C, 0x00E0, 5, 0x0000, 0, 0), + MX6_PAD_ENET1_RX_ER__KPP_COL03 = IOMUX_PAD(0x036C, 0x00E0, 6, 0x0000, 0, 0), + MX6_PAD_ENET1_RX_ER__GPT1_CAPTURE2 = IOMUX_PAD(0x036C, 0x00E0, 8, 0x0590, 1, 0), + + MX6_PAD_ENET2_RX_DATA0__ENET2_RDATA00 = IOMUX_PAD(0x0370, 0x00E4, 0, 0x0000, 0, 0), + MX6_PAD_ENET2_RX_DATA0__UART6_DCE_TX = IOMUX_PAD(0x0370, 0x00E4, 1, 0x0000, 0, 0), + MX6_PAD_ENET2_RX_DATA0__UART6_DTE_RX = IOMUX_PAD(0x0370, 0x00E4, 1, 0x064C, 1, 0), + MX6_PAD_ENET2_RX_DATA0__SIM1_PORT0_TRXD = IOMUX_PAD(0x0370, 0x00E4, 2, 0x0000, 0, 0), + MX6_PAD_ENET2_RX_DATA0__I2C3_SCL = IOMUX_PAD(0x0370, 0x00E4, IOMUX_CONFIG_SION | 3, 0x05B4, 1, 0), + MX6_PAD_ENET2_RX_DATA0__ENET1_MDIO = IOMUX_PAD(0x0370, 0x00E4, 4, 0x0578, 1, 0), + MX6_PAD_ENET2_RX_DATA0__GPIO2_IO08 = IOMUX_PAD(0x0370, 0x00E4, 5, 0x0000, 0, 0), + MX6_PAD_ENET2_RX_DATA0__KPP_ROW04 = IOMUX_PAD(0x0370, 0x00E4, 6, 0x0000, 0, 0), + MX6_PAD_ENET2_RX_DATA0__USB_OTG1_PWR = IOMUX_PAD(0x0370, 0x00E4, 8, 0x0000, 0, 0), + + MX6_PAD_ENET2_RX_DATA1__ENET2_RDATA01 = IOMUX_PAD(0x0374, 0x00E8, 0, 0x0000, 0, 0), + MX6_PAD_ENET2_RX_DATA1__UART6_DCE_RX = IOMUX_PAD(0x0374, 0x00E8, 1, 0x064C, 2, 0), + MX6_PAD_ENET2_RX_DATA1__UART6_DTE_TX = IOMUX_PAD(0x0374, 0x00E8, 1, 0x0000, 0, 0), + MX6_PAD_ENET2_RX_DATA1__SIM1_PORT0_CLK = IOMUX_PAD(0x0374, 0x00E8, 2, 0x0000, 0, 0), + MX6_PAD_ENET2_RX_DATA1__I2C3_SDA = IOMUX_PAD(0x0374, 0x00E8, IOMUX_CONFIG_SION | 3, 0x05B8, 1, 0), + MX6_PAD_ENET2_RX_DATA1__ENET1_MDC = IOMUX_PAD(0x0374, 0x00E8, 4, 0x0000, 0, 0), + MX6_PAD_ENET2_RX_DATA1__GPIO2_IO09 = IOMUX_PAD(0x0374, 0x00E8, 5, 0x0000, 0, 0), + MX6_PAD_ENET2_RX_DATA1__KPP_COL04 = IOMUX_PAD(0x0374, 0x00E8, 6, 0x0000, 0, 0), + MX6_PAD_ENET2_RX_DATA1__USB_OTG1_OC = IOMUX_PAD(0x0374, 0x00E8, 8, 0x0664, 1, 0), + + MX6_PAD_ENET2_RX_EN__ENET2_RX_EN = IOMUX_PAD(0x0378, 0x00EC, 0, 0x0000, 0, 0), + MX6_PAD_ENET2_RX_EN__UART7_DCE_TX = IOMUX_PAD(0x0378, 0x00EC, 1, 0x0000, 0, 0), + MX6_PAD_ENET2_RX_EN__UART7_DTE_RX = IOMUX_PAD(0x0378, 0x00EC, 1, 0x0654, 0, 0), + MX6_PAD_ENET2_RX_EN__SIM1_PORT0_RST_B = IOMUX_PAD(0x0378, 0x00EC, 2, 0x0000, 0, 0), + MX6_PAD_ENET2_RX_EN__I2C4_SCL = IOMUX_PAD(0x0378, 0x00EC, IOMUX_CONFIG_SION | 3, 0x05BC, 1, 0), + MX6_PAD_ENET2_RX_EN__EIM_ADDR26 = IOMUX_PAD(0x0378, 0x00EC, 4, 0x0000, 0, 0), + MX6_PAD_ENET2_RX_EN__GPIO2_IO10 = IOMUX_PAD(0x0378, 0x00EC, 5, 0x0000, 0, 0), + MX6_PAD_ENET2_RX_EN__KPP_ROW05 = IOMUX_PAD(0x0378, 0x00EC, 6, 0x0000, 0, 0), + MX6_PAD_ENET2_RX_EN__ENET1_REF_CLK_25M = IOMUX_PAD(0x0378, 0x00EC, 8, 0x0000, 0, 0), + + MX6_PAD_ENET2_TX_DATA0__ENET2_TDATA00 = IOMUX_PAD(0x037C, 0x00F0, 0, 0x0000, 0, 0), + MX6_PAD_ENET2_TX_DATA0__UART7_DCE_RX = IOMUX_PAD(0x037C, 0x00F0, 1, 0x0654, 1, 0), + MX6_PAD_ENET2_TX_DATA0__UART7_DTE_TX = IOMUX_PAD(0x037C, 0x00F0, 1, 0x0000, 0, 0), + MX6_PAD_ENET2_TX_DATA0__SIM1_PORT0_SVEN = IOMUX_PAD(0x037C, 0x00F0, 2, 0x0000, 0, 0), + MX6_PAD_ENET2_TX_DATA0__I2C4_SDA = IOMUX_PAD(0x037C, 0x00F0, IOMUX_CONFIG_SION | 3, 0x05C0, 1, 0), + MX6_PAD_ENET2_TX_DATA0__EIM_EB_B02 = IOMUX_PAD(0x037C, 0x00F0, 4, 0x0000, 0, 0), + MX6_PAD_ENET2_TX_DATA0__GPIO2_IO11 = IOMUX_PAD(0x037C, 0x00F0, 5, 0x0000, 0, 0), + MX6_PAD_ENET2_TX_DATA0__KPP_COL05 = IOMUX_PAD(0x037C, 0x00F0, 6, 0x0000, 0, 0), + + MX6_PAD_ENET2_TX_DATA1__ENET2_TDATA01 = IOMUX_PAD(0x0380, 0x00F4, 0, 0x0000, 0, 0), + MX6_PAD_ENET2_TX_DATA1__UART8_DCE_TX = IOMUX_PAD(0x0380, 0x00F4, 1, 0x0000, 0, 0), + MX6_PAD_ENET2_TX_DATA1__UART8_DTE_RX = IOMUX_PAD(0x0380, 0x00F4, 1, 0x065C, 0, 0), + MX6_PAD_ENET2_TX_DATA1__SIM2_PORT0_TRXD = IOMUX_PAD(0x0380, 0x00F4, 2, 0x0000, 0, 0), + MX6_PAD_ENET2_TX_DATA1__ECSPI4_SCLK = IOMUX_PAD(0x0380, 0x00F4, 3, 0x0564, 0, 0), + MX6_PAD_ENET2_TX_DATA1__EIM_EB_B03 = IOMUX_PAD(0x0380, 0x00F4, 4, 0x0000, 0, 0), + MX6_PAD_ENET2_TX_DATA1__GPIO2_IO12 = IOMUX_PAD(0x0380, 0x00F4, 5, 0x0000, 0, 0), + MX6_PAD_ENET2_TX_DATA1__KPP_ROW06 = IOMUX_PAD(0x0380, 0x00F4, 6, 0x0000, 0, 0), + MX6_PAD_ENET2_TX_DATA1__USB_OTG2_PWR = IOMUX_PAD(0x0380, 0x00F4, 8, 0x0000, 0, 0), + + MX6_PAD_ENET2_TX_EN__ENET2_TX_EN = IOMUX_PAD(0x0384, 0x00F8, 0, 0x0000, 0, 0), + MX6_PAD_ENET2_TX_EN__UART8_DCE_RX = IOMUX_PAD(0x0384, 0x00F8, 1, 0x065C, 1, 0), + MX6_PAD_ENET2_TX_EN__UART8_DTE_TX = IOMUX_PAD(0x0384, 0x00F8, 1, 0x0000, 0, 0), + MX6_PAD_ENET2_TX_EN__SIM2_PORT0_CLK = IOMUX_PAD(0x0384, 0x00F8, 2, 0x0000, 0, 0), + MX6_PAD_ENET2_TX_EN__ECSPI4_MOSI = IOMUX_PAD(0x0384, 0x00F8, 3, 0x056C, 0, 0), + MX6_PAD_ENET2_TX_EN__EIM_ACLK_FREERUN = IOMUX_PAD(0x0384, 0x00F8, 4, 0x0000, 0, 0), + MX6_PAD_ENET2_TX_EN__GPIO2_IO13 = IOMUX_PAD(0x0384, 0x00F8, 5, 0x0000, 0, 0), + MX6_PAD_ENET2_TX_EN__KPP_COL06 = IOMUX_PAD(0x0384, 0x00F8, 6, 0x0000, 0, 0), + MX6_PAD_ENET2_TX_EN__USB_OTG2_OC = IOMUX_PAD(0x0384, 0x00F8, 8, 0x0660, 1, 0), + + MX6_PAD_ENET2_TX_CLK__ENET2_TX_CLK = IOMUX_PAD(0x0388, 0x00FC, IOMUX_CONFIG_SION | 0, 0x0000, 0, 0), + MX6_PAD_ENET2_TX_CLK__UART8_DCE_CTS = IOMUX_PAD(0x0388, 0x00FC, 1, 0x0000, 0, 0), + MX6_PAD_ENET2_TX_CLK__UART8_DTE_RTS = IOMUX_PAD(0x0388, 0x00FC, 1, 0x0658, 0, 0), + MX6_PAD_ENET2_TX_CLK__SIM2_PORT0_RST_B = IOMUX_PAD(0x0388, 0x00FC, 2, 0x0000, 0, 0), + MX6_PAD_ENET2_TX_CLK__ECSPI4_MISO = IOMUX_PAD(0x0388, 0x00FC, 3, 0x0568, 0, 0), + MX6_PAD_ENET2_TX_CLK__ENET2_REF_CLK2 = IOMUX_PAD(0x0388, 0x00FC, IOMUX_CONFIG_SION | 4, 0x057C, 2, 0), + MX6_PAD_ENET2_TX_CLK__GPIO2_IO14 = IOMUX_PAD(0x0388, 0x00FC, 5, 0x0000, 0, 0), + MX6_PAD_ENET2_TX_CLK__KPP_ROW07 = IOMUX_PAD(0x0388, 0x00FC, 6, 0x0000, 0, 0), + MX6_PAD_ENET2_TX_CLK__ANATOP_OTG2_ID = IOMUX_PAD(0x0388, 0x00FC, 8, 0x04BC, 1, 0), + + MX6_PAD_ENET2_RX_ER__ENET2_RX_ER = IOMUX_PAD(0x038C, 0x0100, 0, 0x0000, 0, 0), + MX6_PAD_ENET2_RX_ER__UART8_DCE_RTS = IOMUX_PAD(0x038C, 0x0100, 1, 0x0658, 1, 0), + MX6_PAD_ENET2_RX_ER__UART8_DTE_CTS = IOMUX_PAD(0x038C, 0x0100, 1, 0x0000, 0, 0), + MX6_PAD_ENET2_RX_ER__SIM2_PORT0_SVEN = IOMUX_PAD(0x038C, 0x0100, 2, 0x0000, 0, 0), + MX6_PAD_ENET2_RX_ER__ECSPI4_SS0 = IOMUX_PAD(0x038C, 0x0100, 3, 0x0570, 0, 0), + MX6_PAD_ENET2_RX_ER__EIM_ADDR25 = IOMUX_PAD(0x038C, 0x0100, 4, 0x0000, 0, 0), + MX6_PAD_ENET2_RX_ER__GPIO2_IO15 = IOMUX_PAD(0x038C, 0x0100, 5, 0x0000, 0, 0), + MX6_PAD_ENET2_RX_ER__KPP_COL07 = IOMUX_PAD(0x038C, 0x0100, 6, 0x0000, 0, 0), + MX6_PAD_ENET2_RX_ER__WDOG1_WDOG_ANY = IOMUX_PAD(0x038C, 0x0100, 8, 0x0000, 0, 0), + + MX6_PAD_LCD_CLK__LCDIF_CLK = IOMUX_PAD(0x0390, 0x0104, 0, 0x0000, 0, 0), + MX6_PAD_LCD_CLK__LCDIF_WR_RWN = IOMUX_PAD(0x0390, 0x0104, 1, 0x0000, 0, 0), + MX6_PAD_LCD_CLK__UART4_DCE_TX = IOMUX_PAD(0x0390, 0x0104, 2, 0x0000, 0, 0), + MX6_PAD_LCD_CLK__UART4_DTE_RX = IOMUX_PAD(0x0390, 0x0104, 2, 0x063C, 2, 0), + MX6_PAD_LCD_CLK__SAI3_MCLK = IOMUX_PAD(0x0390, 0x0104, 3, 0x0600, 0, 0), + MX6_PAD_LCD_CLK__EIM_CS2_B = IOMUX_PAD(0x0390, 0x0104, 4, 0x0000, 0, 0), + MX6_PAD_LCD_CLK__GPIO3_IO00 = IOMUX_PAD(0x0390, 0x0104, 5, 0x0000, 0, 0), + MX6_PAD_LCD_CLK__WDOG1_WDOG_RST_B_DEB = IOMUX_PAD(0x0390, 0x0104, 8, 0x0000, 0, 0), + + MX6_PAD_LCD_ENABLE__LCDIF_ENABLE = IOMUX_PAD(0x0394, 0x0108, 0, 0x0000, 0, 0), + MX6_PAD_LCD_ENABLE__LCDIF_RD_E = IOMUX_PAD(0x0394, 0x0108, 1, 0x0000, 0, 0), + MX6_PAD_LCD_ENABLE__UART4_DCE_RX = IOMUX_PAD(0x0394, 0x0108, 2, 0x063C, 3, 0), + MX6_PAD_LCD_ENABLE__UART4_DTE_TX = IOMUX_PAD(0x0394, 0x0108, 2, 0x0000, 0, 0), + MX6_PAD_LCD_ENABLE__SAI3_TX_SYNC = IOMUX_PAD(0x0394, 0x0108, 3, 0x060C, 0, 0), + MX6_PAD_LCD_ENABLE__EIM_CS3_B = IOMUX_PAD(0x0394, 0x0108, 4, 0x0000, 0, 0), + MX6_PAD_LCD_ENABLE__GPIO3_IO01 = IOMUX_PAD(0x0394, 0x0108, 5, 0x0000, 0, 0), + MX6_PAD_LCD_ENABLE__ECSPI2_RDY = IOMUX_PAD(0x0394, 0x0108, 8, 0x0000, 0, 0), + + MX6_PAD_LCD_HSYNC__LCDIF_HSYNC = IOMUX_PAD(0x0398, 0x010C, 0, 0x05DC, 0, 0), + MX6_PAD_LCD_HSYNC__LCDIF_RS = IOMUX_PAD(0x0398, 0x010C, 1, 0x0000, 0, 0), + MX6_PAD_LCD_HSYNC__UART4_DCE_CTS = IOMUX_PAD(0x0398, 0x010C, 2, 0x0000, 0, 0), + MX6_PAD_LCD_HSYNC__UART4_DTE_RTS = IOMUX_PAD(0x0398, 0x010C, 2, 0x0638, 2, 0), + MX6_PAD_LCD_HSYNC__SAI3_TX_BCLK = IOMUX_PAD(0x0398, 0x010C, 3, 0x0608, 0, 0), + MX6_PAD_LCD_HSYNC__WDOG3_WDOG_RST_B_DEB = IOMUX_PAD(0x0398, 0x010C, 4, 0x0000, 0, 0), + MX6_PAD_LCD_HSYNC__GPIO3_IO02 = IOMUX_PAD(0x0398, 0x010C, 5, 0x0000, 0, 0), + MX6_PAD_LCD_HSYNC__ECSPI2_SS1 = IOMUX_PAD(0x0398, 0x010C, 8, 0x0000, 0, 0), + + MX6_PAD_LCD_VSYNC__LCDIF_VSYNC = IOMUX_PAD(0x039C, 0x0110, 0, 0x0000, 0, 0), + MX6_PAD_LCD_VSYNC__LCDIF_BUSY = IOMUX_PAD(0x039C, 0x0110, 1, 0x05DC, 1, 0), + MX6_PAD_LCD_VSYNC__UART4_DCE_RTS = IOMUX_PAD(0x039C, 0x0110, 2, 0x0638, 3, 0), + MX6_PAD_LCD_VSYNC__UART4_DTE_CTS = IOMUX_PAD(0x039C, 0x0110, 2, 0x0000, 0, 0), + MX6_PAD_LCD_VSYNC__SAI3_RX_DATA = IOMUX_PAD(0x039C, 0x0110, 3, 0x0604, 0, 0), + MX6_PAD_LCD_VSYNC__WDOG2_WDOG_B = IOMUX_PAD(0x039C, 0x0110, 4, 0x0000, 0, 0), + MX6_PAD_LCD_VSYNC__GPIO3_IO03 = IOMUX_PAD(0x039C, 0x0110, 5, 0x0000, 0, 0), + MX6_PAD_LCD_VSYNC__ECSPI2_SS2 = IOMUX_PAD(0x039C, 0x0110, 8, 0x0000, 0, 0), + + MX6_PAD_LCD_RESET__LCDIF_RESET = IOMUX_PAD(0x03A0, 0x0114, 0, 0x0000, 0, 0), + MX6_PAD_LCD_RESET__LCDIF_CS = IOMUX_PAD(0x03A0, 0x0114, 1, 0x0000, 0, 0), + MX6_PAD_LCD_RESET__CA7_MX6UL_EVENTI = IOMUX_PAD(0x03A0, 0x0114, 2, 0x0000, 0, 0), + MX6_PAD_LCD_RESET__SAI3_TX_DATA = IOMUX_PAD(0x03A0, 0x0114, 3, 0x0000, 0, 0), + MX6_PAD_LCD_RESET__WDOG1_WDOG_ANY = IOMUX_PAD(0x03A0, 0x0114, 4, 0x0000, 0, 0), + MX6_PAD_LCD_RESET__GPIO3_IO04 = IOMUX_PAD(0x03A0, 0x0114, 5, 0x0000, 0, 0), + MX6_PAD_LCD_RESET__ECSPI2_SS3 = IOMUX_PAD(0x03A0, 0x0114, 8, 0x0000, 0, 0), + + MX6_PAD_LCD_DATA00__LCDIF_DATA00 = IOMUX_PAD(0x03A4, 0x0118, 0, 0x0000, 0, 0), + MX6_PAD_LCD_DATA00__PWM1_OUT = IOMUX_PAD(0x03A4, 0x0118, 1, 0x0000, 0, 0), + MX6_PAD_LCD_DATA00__ENET1_1588_EVENT2_IN = IOMUX_PAD(0x03A4, 0x0118, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DATA00__I2C3_SDA = IOMUX_PAD(0x03A4, 0x0118, IOMUX_CONFIG_SION | 4, 0x05B8, 2, 0), + MX6_PAD_LCD_DATA00__GPIO3_IO05 = IOMUX_PAD(0x03A4, 0x0118, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DATA00__SRC_BT_CFG00 = IOMUX_PAD(0x03A4, 0x0118, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DATA00__SAI1_MCLK = IOMUX_PAD(0x03A4, 0x0118, 8, 0x05E0, 1, 0), + + MX6_PAD_LCD_DATA01__LCDIF_DATA01 = IOMUX_PAD(0x03A8, 0x011C, 0, 0x0000, 0, 0), + MX6_PAD_LCD_DATA01__PWM2_OUT = IOMUX_PAD(0x03A8, 0x011C, 1, 0x0000, 0, 0), + MX6_PAD_LCD_DATA01__ENET1_1588_EVENT2_OUT = IOMUX_PAD(0x03A8, 0x011C, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DATA01__I2C3_SCL = IOMUX_PAD(0x03A8, 0x011C, IOMUX_CONFIG_SION | 4, 0x05B4, 2, 0), + MX6_PAD_LCD_DATA01__GPIO3_IO06 = IOMUX_PAD(0x03A8, 0x011C, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DATA01__SRC_BT_CFG01 = IOMUX_PAD(0x03A8, 0x011C, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DATA01__SAI1_TX_SYNC = IOMUX_PAD(0x03A8, 0x011C, 8, 0x05EC, 0, 0), + + MX6_PAD_LCD_DATA02__LCDIF_DATA02 = IOMUX_PAD(0x03AC, 0x0120, 0, 0x0000, 0, 0), + MX6_PAD_LCD_DATA02__PWM3_OUT = IOMUX_PAD(0x03AC, 0x0120, 1, 0x0000, 0, 0), + MX6_PAD_LCD_DATA02__ENET1_1588_EVENT3_IN = IOMUX_PAD(0x03AC, 0x0120, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DATA02__I2C4_SDA = IOMUX_PAD(0x03AC, 0x0120, IOMUX_CONFIG_SION | 4, 0x05C0, 2, 0), + MX6_PAD_LCD_DATA02__GPIO3_IO07 = IOMUX_PAD(0x03AC, 0x0120, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DATA02__SRC_BT_CFG02 = IOMUX_PAD(0x03AC, 0x0120, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DATA02__SAI1_TX_BCLK = IOMUX_PAD(0x03AC, 0x0120, 8, 0x05E8, 0, 0), + + MX6_PAD_LCD_DATA03__LCDIF_DATA03 = IOMUX_PAD(0x03B0, 0x0124, 0, 0x0000, 0, 0), + MX6_PAD_LCD_DATA03__PWM4_OUT = IOMUX_PAD(0x03B0, 0x0124, 1, 0x0000, 0, 0), + MX6_PAD_LCD_DATA03__ENET1_1588_EVENT3_OUT = IOMUX_PAD(0x03B0, 0x0124, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DATA03__I2C4_SCL = IOMUX_PAD(0x03B0, 0x0124, IOMUX_CONFIG_SION | 4, 0x05BC, 2, 0), + MX6_PAD_LCD_DATA03__GPIO3_IO08 = IOMUX_PAD(0x03B0, 0x0124, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DATA03__SRC_BT_CFG03 = IOMUX_PAD(0x03B0, 0x0124, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DATA03__SAI1_RX_DATA = IOMUX_PAD(0x03B0, 0x0124, 8, 0x05E4, 0, 0), + + MX6_PAD_LCD_DATA04__LCDIF_DATA04 = IOMUX_PAD(0x03B4, 0x0128, 0, 0x0000, 0, 0), + MX6_PAD_LCD_DATA04__UART8_DCE_CTS = IOMUX_PAD(0x03B4, 0x0128, 1, 0x0000, 0, 0), + MX6_PAD_LCD_DATA04__UART8_DTE_RTS = IOMUX_PAD(0x03B4, 0x0128, 1, 0x0658, 2, 0), + MX6_PAD_LCD_DATA04__ENET2_1588_EVENT2_IN = IOMUX_PAD(0x03B4, 0x0128, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DATA04__SPDIF_SR_CLK = IOMUX_PAD(0x03B4, 0x0128, 4, 0x0000, 0, 0), + MX6_PAD_LCD_DATA04__GPIO3_IO09 = IOMUX_PAD(0x03B4, 0x0128, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DATA04__SRC_BT_CFG04 = IOMUX_PAD(0x03B4, 0x0128, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DATA04__SAI1_TX_DATA = IOMUX_PAD(0x03B4, 0x0128, 8, 0x0000, 0, 0), + + MX6_PAD_LCD_DATA05__LCDIF_DATA05 = IOMUX_PAD(0x03B8, 0x012C, 0, 0x0000, 0, 0), + MX6_PAD_LCD_DATA05__UART8_DCE_RTS = IOMUX_PAD(0x03B8, 0x012C, 1, 0x0658, 3, 0), + MX6_PAD_LCD_DATA05__UART8_DTE_CTS = IOMUX_PAD(0x03B8, 0x012C, 1, 0x0000, 0, 0), + MX6_PAD_LCD_DATA05__ENET2_1588_EVENT2_OUT = IOMUX_PAD(0x03B8, 0x012C, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DATA05__SPDIF_OUT = IOMUX_PAD(0x03B8, 0x012C, 4, 0x0000, 0, 0), + MX6_PAD_LCD_DATA05__GPIO3_IO10 = IOMUX_PAD(0x03B8, 0x012C, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DATA05__SRC_BT_CFG05 = IOMUX_PAD(0x03B8, 0x012C, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DATA05__ECSPI1_SS1 = IOMUX_PAD(0x03B8, 0x012C, 8, 0x0000, 0, 0), + + MX6_PAD_LCD_DATA06__LCDIF_DATA06 = IOMUX_PAD(0x03BC, 0x0130, 0, 0x0000, 0, 0), + MX6_PAD_LCD_DATA06__UART7_DCE_CTS = IOMUX_PAD(0x03BC, 0x0130, 1, 0x0000, 0, 0), + MX6_PAD_LCD_DATA06__UART7_DTE_RTS = IOMUX_PAD(0x03BC, 0x0130, 1, 0x0650, 2, 0), + MX6_PAD_LCD_DATA06__ENET2_1588_EVENT3_IN = IOMUX_PAD(0x03BC, 0x0130, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DATA06__SPDIF_LOCK = IOMUX_PAD(0x03BC, 0x0130, 4, 0x0000, 0, 0), + MX6_PAD_LCD_DATA06__GPIO3_IO11 = IOMUX_PAD(0x03BC, 0x0130, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DATA06__SRC_BT_CFG06 = IOMUX_PAD(0x03BC, 0x0130, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DATA06__ECSPI1_SS2 = IOMUX_PAD(0x03BC, 0x0130, 8, 0x0000, 0, 0), + + MX6_PAD_LCD_DATA07__LCDIF_DATA07 = IOMUX_PAD(0x03C0, 0x0134, 0, 0x0000, 0, 0), + MX6_PAD_LCD_DATA07__UART7_DCE_RTS = IOMUX_PAD(0x03C0, 0x0134, 1, 0x0650, 3, 0), + MX6_PAD_LCD_DATA07__UART7_DTE_CTS = IOMUX_PAD(0x03C0, 0x0134, 1, 0x0000, 0, 0), + MX6_PAD_LCD_DATA07__ENET2_1588_EVENT3_OUT = IOMUX_PAD(0x03C0, 0x0134, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DATA07__SPDIF_EXT_CLK = IOMUX_PAD(0x03C0, 0x0134, 4, 0x061C, 0, 0), + MX6_PAD_LCD_DATA07__GPIO3_IO12 = IOMUX_PAD(0x03C0, 0x0134, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DATA07__SRC_BT_CFG07 = IOMUX_PAD(0x03C0, 0x0134, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DATA07__ECSPI1_SS3 = IOMUX_PAD(0x03C0, 0x0134, 8, 0x0000, 0, 0), + + MX6_PAD_LCD_DATA08__LCDIF_DATA08 = IOMUX_PAD(0x03C4, 0x0138, 0, 0x0000, 0, 0), + MX6_PAD_LCD_DATA08__SPDIF_IN = IOMUX_PAD(0x03C4, 0x0138, 1, 0x0618, 2, 0), + MX6_PAD_LCD_DATA08__CSI_DATA16 = IOMUX_PAD(0x03C4, 0x0138, 3, 0x0504, 1, 0), + MX6_PAD_LCD_DATA08__EIM_DATA00 = IOMUX_PAD(0x03C4, 0x0138, 4, 0x0000, 0, 0), + MX6_PAD_LCD_DATA08__GPIO3_IO13 = IOMUX_PAD(0x03C4, 0x0138, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DATA08__SRC_BT_CFG08 = IOMUX_PAD(0x03C4, 0x0138, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DATA08__FLEXCAN1_TX = IOMUX_PAD(0x03C4, 0x0138, 8, 0x0000, 0, 0), + + MX6_PAD_LCD_DATA09__LCDIF_DATA09 = IOMUX_PAD(0x03C8, 0x013C, 0, 0x0000, 0, 0), + MX6_PAD_LCD_DATA09__SAI3_MCLK = IOMUX_PAD(0x03C8, 0x013C, 1, 0x0600, 1, 0), + MX6_PAD_LCD_DATA09__CSI_DATA17 = IOMUX_PAD(0x03C8, 0x013C, 3, 0x0508, 1, 0), + MX6_PAD_LCD_DATA09__EIM_DATA01 = IOMUX_PAD(0x03C8, 0x013C, 4, 0x0000, 0, 0), + MX6_PAD_LCD_DATA09__GPIO3_IO14 = IOMUX_PAD(0x03C8, 0x013C, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DATA09__SRC_BT_CFG09 = IOMUX_PAD(0x03C8, 0x013C, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DATA09__FLEXCAN1_RX = IOMUX_PAD(0x03C8, 0x013C, 8, 0x0584, 2, 0), + + MX6_PAD_LCD_DATA10__LCDIF_DATA10 = IOMUX_PAD(0x03CC, 0x0140, 0, 0x0000, 0, 0), + MX6_PAD_LCD_DATA10__SAI3_RX_SYNC = IOMUX_PAD(0x03CC, 0x0140, 1, 0x0000, 0, 0), + MX6_PAD_LCD_DATA10__CSI_DATA18 = IOMUX_PAD(0x03CC, 0x0140, 3, 0x050C, 1, 0), + MX6_PAD_LCD_DATA10__EIM_DATA02 = IOMUX_PAD(0x03CC, 0x0140, 4, 0x0000, 0, 0), + MX6_PAD_LCD_DATA10__GPIO3_IO15 = IOMUX_PAD(0x03CC, 0x0140, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DATA10__SRC_BT_CFG10 = IOMUX_PAD(0x03CC, 0x0140, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DATA10__FLEXCAN2_TX = IOMUX_PAD(0x03CC, 0x0140, 8, 0x0000, 0, 0), + + MX6_PAD_LCD_DATA11__LCDIF_DATA11 = IOMUX_PAD(0x03D0, 0x0144, 0, 0x0000, 0, 0), + MX6_PAD_LCD_DATA11__SAI3_RX_BCLK = IOMUX_PAD(0x03D0, 0x0144, 1, 0x0000, 0, 0), + MX6_PAD_LCD_DATA11__CSI_DATA19 = IOMUX_PAD(0x03D0, 0x0144, 3, 0x0510, 1, 0), + MX6_PAD_LCD_DATA11__EIM_DATA03 = IOMUX_PAD(0x03D0, 0x0144, 4, 0x0000, 0, 0), + MX6_PAD_LCD_DATA11__GPIO3_IO16 = IOMUX_PAD(0x03D0, 0x0144, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DATA11__SRC_BT_CFG11 = IOMUX_PAD(0x03D0, 0x0144, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DATA11__FLEXCAN2_RX = IOMUX_PAD(0x03D0, 0x0144, 8, 0x0588, 2, 0), + + MX6_PAD_LCD_DATA12__LCDIF_DATA12 = IOMUX_PAD(0x03D4, 0x0148, 0, 0x0000, 0, 0), + MX6_PAD_LCD_DATA12__SAI3_TX_SYNC = IOMUX_PAD(0x03D4, 0x0148, 1, 0x060C, 1, 0), + MX6_PAD_LCD_DATA12__CSI_DATA20 = IOMUX_PAD(0x03D4, 0x0148, 3, 0x0514, 1, 0), + MX6_PAD_LCD_DATA12__EIM_DATA04 = IOMUX_PAD(0x03D4, 0x0148, 4, 0x0000, 0, 0), + MX6_PAD_LCD_DATA12__GPIO3_IO17 = IOMUX_PAD(0x03D4, 0x0148, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DATA12__SRC_BT_CFG12 = IOMUX_PAD(0x03D4, 0x0148, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DATA12__ECSPI1_RDY = IOMUX_PAD(0x03D4, 0x0148, 8, 0x0000, 0, 0), + + MX6_PAD_LCD_DATA13__LCDIF_DATA13 = IOMUX_PAD(0x03D8, 0x014C, 0, 0x0000, 0, 0), + MX6_PAD_LCD_DATA13__SAI3_TX_BCLK = IOMUX_PAD(0x03D8, 0x014C, 1, 0x0608, 1, 0), + MX6_PAD_LCD_DATA13__CSI_DATA21 = IOMUX_PAD(0x03D8, 0x014C, 3, 0x0518, 1, 0), + MX6_PAD_LCD_DATA13__EIM_DATA05 = IOMUX_PAD(0x03D8, 0x014C, 4, 0x0000, 0, 0), + MX6_PAD_LCD_DATA13__GPIO3_IO18 = IOMUX_PAD(0x03D8, 0x014C, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DATA13__SRC_BT_CFG13 = IOMUX_PAD(0x03D8, 0x014C, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DATA13__USDHC2_RESET_B = IOMUX_PAD(0x03D8, 0x014C, 8, 0x0000, 0, 0), + + MX6_PAD_LCD_DATA14__LCDIF_DATA14 = IOMUX_PAD(0x03DC, 0x0150, 0, 0x0000, 0, 0), + MX6_PAD_LCD_DATA14__SAI3_RX_DATA = IOMUX_PAD(0x03DC, 0x0150, 1, 0x0604, 1, 0), + MX6_PAD_LCD_DATA14__CSI_DATA22 = IOMUX_PAD(0x03DC, 0x0150, 3, 0x051C, 1, 0), + MX6_PAD_LCD_DATA14__EIM_DATA06 = IOMUX_PAD(0x03DC, 0x0150, 4, 0x0000, 0, 0), + MX6_PAD_LCD_DATA14__GPIO3_IO19 = IOMUX_PAD(0x03DC, 0x0150, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DATA14__SRC_BT_CFG14 = IOMUX_PAD(0x03DC, 0x0150, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DATA14__USDHC2_DATA4 = IOMUX_PAD(0x03DC, 0x0150, 8, 0x068C, 0, 0), + + MX6_PAD_LCD_DATA15__LCDIF_DATA15 = IOMUX_PAD(0x03E0, 0x0154, 0, 0x0000, 0, 0), + MX6_PAD_LCD_DATA15__SAI3_TX_DATA = IOMUX_PAD(0x03E0, 0x0154, 1, 0x0000, 0, 0), + MX6_PAD_LCD_DATA15__CSI_DATA23 = IOMUX_PAD(0x03E0, 0x0154, 3, 0x0520, 1, 0), + MX6_PAD_LCD_DATA15__EIM_DATA07 = IOMUX_PAD(0x03E0, 0x0154, 4, 0x0000, 0, 0), + MX6_PAD_LCD_DATA15__GPIO3_IO20 = IOMUX_PAD(0x03E0, 0x0154, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DATA15__SRC_BT_CFG15 = IOMUX_PAD(0x03E0, 0x0154, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DATA15__USDHC2_DATA5 = IOMUX_PAD(0x03E0, 0x0154, 8, 0x0690, 0, 0), + + MX6_PAD_LCD_DATA16__LCDIF_DATA16 = IOMUX_PAD(0x03E4, 0x0158, 0, 0x0000, 0, 0), + MX6_PAD_LCD_DATA16__UART7_DCE_TX = IOMUX_PAD(0x03E4, 0x0158, 1, 0x0000, 0, 0), + MX6_PAD_LCD_DATA16__UART7_DTE_RX = IOMUX_PAD(0x03E4, 0x0158, 1, 0x0654, 2, 0), + MX6_PAD_LCD_DATA16__CSI_DATA01 = IOMUX_PAD(0x03E4, 0x0158, 3, 0x04D4, 1, 0), + MX6_PAD_LCD_DATA16__EIM_DATA08 = IOMUX_PAD(0x03E4, 0x0158, 4, 0x0000, 0, 0), + MX6_PAD_LCD_DATA16__GPIO3_IO21 = IOMUX_PAD(0x03E4, 0x0158, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DATA16__SRC_BT_CFG24 = IOMUX_PAD(0x03E4, 0x0158, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DATA16__USDHC2_DATA6 = IOMUX_PAD(0x03E4, 0x0158, 8, 0x0694, 0, 0), + + MX6_PAD_LCD_DATA17__LCDIF_DATA17 = IOMUX_PAD(0x03E8, 0x015C, 0, 0x0000, 0, 0), + MX6_PAD_LCD_DATA17__UART7_DCE_RX = IOMUX_PAD(0x03E8, 0x015C, 1, 0x0654, 3, 0), + MX6_PAD_LCD_DATA17__UART7_DTE_TX = IOMUX_PAD(0x03E8, 0x015C, 1, 0x0000, 0, 0), + MX6_PAD_LCD_DATA17__CSI_DATA00 = IOMUX_PAD(0x03E8, 0x015C, 3, 0x04D0, 1, 0), + MX6_PAD_LCD_DATA17__EIM_DATA09 = IOMUX_PAD(0x03E8, 0x015C, 4, 0x0000, 0, 0), + MX6_PAD_LCD_DATA17__GPIO3_IO22 = IOMUX_PAD(0x03E8, 0x015C, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DATA17__SRC_BT_CFG25 = IOMUX_PAD(0x03E8, 0x015C, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DATA17__USDHC2_DATA7 = IOMUX_PAD(0x03E8, 0x015C, 8, 0x0698, 0, 0), + + MX6_PAD_LCD_DATA18__LCDIF_DATA18 = IOMUX_PAD(0x03EC, 0x0160, 0, 0x0000, 0, 0), + MX6_PAD_LCD_DATA18__PWM5_OUT = IOMUX_PAD(0x03EC, 0x0160, 1, 0x0000, 0, 0), + MX6_PAD_LCD_DATA18__CA7_MX6UL_EVENTO = IOMUX_PAD(0x03EC, 0x0160, 2, 0x0000, 0, 0), + MX6_PAD_LCD_DATA18__CSI_DATA10 = IOMUX_PAD(0x03EC, 0x0160, 3, 0x04EC, 1, 0), + MX6_PAD_LCD_DATA18__EIM_DATA10 = IOMUX_PAD(0x03EC, 0x0160, 4, 0x0000, 0, 0), + MX6_PAD_LCD_DATA18__GPIO3_IO23 = IOMUX_PAD(0x03EC, 0x0160, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DATA18__SRC_BT_CFG26 = IOMUX_PAD(0x03EC, 0x0160, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DATA18__USDHC2_CMD = IOMUX_PAD(0x03EC, 0x0160, 8, 0x0678, 1, 0), + MX6_PAD_LCD_DATA19__EIM_DATA11 = IOMUX_PAD(0x03F0, 0x0164, 4, 0x0000, 0, 0), + MX6_PAD_LCD_DATA19__GPIO3_IO24 = IOMUX_PAD(0x03F0, 0x0164, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DATA19__SRC_BT_CFG27 = IOMUX_PAD(0x03F0, 0x0164, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DATA19__USDHC2_CLK = IOMUX_PAD(0x03F0, 0x0164, 8, 0x0670, 1, 0), + + MX6_PAD_LCD_DATA19__LCDIF_DATA19 = IOMUX_PAD(0x03F0, 0x0164, 0, 0x0000, 0, 0), + MX6_PAD_LCD_DATA19__PWM6_OUT = IOMUX_PAD(0x03F0, 0x0164, 1, 0x0000, 0, 0), + MX6_PAD_LCD_DATA19__WDOG1_WDOG_ANY = IOMUX_PAD(0x03F0, 0x0164, 2, 0x0000, 0, 0), + MX6_PAD_LCD_DATA19__CSI_DATA11 = IOMUX_PAD(0x03F0, 0x0164, 3, 0x04F0, 1, 0), + MX6_PAD_LCD_DATA20__EIM_DATA12 = IOMUX_PAD(0x03F4, 0x0168, 4, 0x0000, 0, 0), + MX6_PAD_LCD_DATA20__GPIO3_IO25 = IOMUX_PAD(0x03F4, 0x0168, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DATA20__SRC_BT_CFG28 = IOMUX_PAD(0x03F4, 0x0168, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DATA20__USDHC2_DATA0 = IOMUX_PAD(0x03F4, 0x0168, 8, 0x067C, 1, 0), + + MX6_PAD_LCD_DATA20__LCDIF_DATA20 = IOMUX_PAD(0x03F4, 0x0168, 0, 0x0000, 0, 0), + MX6_PAD_LCD_DATA20__UART8_DCE_TX = IOMUX_PAD(0x03F4, 0x0168, 1, 0x0000, 0, 0), + MX6_PAD_LCD_DATA20__UART8_DTE_RX = IOMUX_PAD(0x03F4, 0x0168, 1, 0x065C, 2, 0), + MX6_PAD_LCD_DATA20__ECSPI1_SCLK = IOMUX_PAD(0x03F4, 0x0168, 2, 0x0534, 0, 0), + MX6_PAD_LCD_DATA20__CSI_DATA12 = IOMUX_PAD(0x03F4, 0x0168, 3, 0x04F4, 1, 0), + + MX6_PAD_LCD_DATA21__LCDIF_DATA21 = IOMUX_PAD(0x03F8, 0x016C, 0, 0x0000, 0, 0), + MX6_PAD_LCD_DATA21__UART8_DCE_RX = IOMUX_PAD(0x03F8, 0x016C, 1, 0x065C, 3, 0), + MX6_PAD_LCD_DATA21__UART8_DTE_TX = IOMUX_PAD(0x03F8, 0x016C, 1, 0x0000, 0, 0), + MX6_PAD_LCD_DATA21__ECSPI1_SS0 = IOMUX_PAD(0x03F8, 0x016C, 2, 0x0540, 0, 0), + MX6_PAD_LCD_DATA21__CSI_DATA13 = IOMUX_PAD(0x03F8, 0x016C, 3, 0x04F8, 1, 0), + MX6_PAD_LCD_DATA21__EIM_DATA13 = IOMUX_PAD(0x03F8, 0x016C, 4, 0x0000, 0, 0), + MX6_PAD_LCD_DATA21__GPIO3_IO26 = IOMUX_PAD(0x03F8, 0x016C, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DATA21__SRC_BT_CFG29 = IOMUX_PAD(0x03F8, 0x016C, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DATA21__USDHC2_DATA1 = IOMUX_PAD(0x03F8, 0x016C, 8, 0x0680, 1, 0), + + MX6_PAD_LCD_DATA22__LCDIF_DATA22 = IOMUX_PAD(0x03FC, 0x0170, 0, 0x0000, 0, 0), + MX6_PAD_LCD_DATA22__MQS_RIGHT = IOMUX_PAD(0x03FC, 0x0170, 1, 0x0000, 0, 0), + MX6_PAD_LCD_DATA22__ECSPI1_MOSI = IOMUX_PAD(0x03FC, 0x0170, 2, 0x053C, 0, 0), + MX6_PAD_LCD_DATA22__CSI_DATA14 = IOMUX_PAD(0x03FC, 0x0170, 3, 0x04FC, 1, 0), + MX6_PAD_LCD_DATA22__EIM_DATA14 = IOMUX_PAD(0x03FC, 0x0170, 4, 0x0000, 0, 0), + MX6_PAD_LCD_DATA22__GPIO3_IO27 = IOMUX_PAD(0x03FC, 0x0170, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DATA22__SRC_BT_CFG30 = IOMUX_PAD(0x03FC, 0x0170, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DATA22__USDHC2_DATA2 = IOMUX_PAD(0x03FC, 0x0170, 8, 0x0684, 0, 0), + + MX6_PAD_LCD_DATA23__LCDIF_DATA23 = IOMUX_PAD(0x0400, 0x0174, 0, 0x0000, 0, 0), + MX6_PAD_LCD_DATA23__MQS_LEFT = IOMUX_PAD(0x0400, 0x0174, 1, 0x0000, 0, 0), + MX6_PAD_LCD_DATA23__ECSPI1_MISO = IOMUX_PAD(0x0400, 0x0174, 2, 0x0538, 0, 0), + MX6_PAD_LCD_DATA23__CSI_DATA15 = IOMUX_PAD(0x0400, 0x0174, 3, 0x0500, 1, 0), + MX6_PAD_LCD_DATA23__EIM_DATA15 = IOMUX_PAD(0x0400, 0x0174, 4, 0x0000, 0, 0), + MX6_PAD_LCD_DATA23__GPIO3_IO28 = IOMUX_PAD(0x0400, 0x0174, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DATA23__SRC_BT_CFG31 = IOMUX_PAD(0x0400, 0x0174, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DATA23__USDHC2_DATA3 = IOMUX_PAD(0x0400, 0x0174, 8, 0x0688, 1, 0), + + MX6_PAD_NAND_RE_B__RAWNAND_RE_B = IOMUX_PAD(0x0404, 0x0178, 0, 0x0000, 0, 0), + MX6_PAD_NAND_RE_B__USDHC2_CLK = IOMUX_PAD(0x0404, 0x0178, 1, 0x0670, 2, 0), + MX6_PAD_NAND_RE_B__QSPI_B_SCLK = IOMUX_PAD(0x0404, 0x0178, 2, 0x0000, 0, 0), + MX6_PAD_NAND_RE_B__KPP_ROW00 = IOMUX_PAD(0x0404, 0x0178, 3, 0x05D0, 1, 0), + MX6_PAD_NAND_RE_B__EIM_EB_B00 = IOMUX_PAD(0x0404, 0x0178, 4, 0x0000, 0, 0), + MX6_PAD_NAND_RE_B__GPIO4_IO00 = IOMUX_PAD(0x0404, 0x0178, 5, 0x0000, 0, 0), + MX6_PAD_NAND_RE_B__ECSPI3_SS2 = IOMUX_PAD(0x0404, 0x0178, 8, 0x0000, 0, 0), + + MX6_PAD_NAND_WE_B__RAWNAND_WE_B = IOMUX_PAD(0x0408, 0x017C, 0, 0x0000, 0, 0), + MX6_PAD_NAND_WE_B__USDHC2_CMD = IOMUX_PAD(0x0408, 0x017C, 1, 0x0678, 2, 0), + MX6_PAD_NAND_WE_B__QSPI_B_SS0_B = IOMUX_PAD(0x0408, 0x017C, 2, 0x0000, 0, 0), + MX6_PAD_NAND_WE_B__KPP_COL00 = IOMUX_PAD(0x0408, 0x017C, 3, 0x05C4, 1, 0), + MX6_PAD_NAND_WE_B__EIM_EB_B01 = IOMUX_PAD(0x0408, 0x017C, 4, 0x0000, 0, 0), + MX6_PAD_NAND_WE_B__GPIO4_IO01 = IOMUX_PAD(0x0408, 0x017C, 5, 0x0000, 0, 0), + MX6_PAD_NAND_WE_B__ECSPI3_SS3 = IOMUX_PAD(0x0408, 0x017C, 8, 0x0000, 0, 0), + + MX6_PAD_NAND_DATA00__RAWNAND_DATA00 = IOMUX_PAD(0x040C, 0x0180, 0, 0x0000, 0, 0), + MX6_PAD_NAND_DATA00__USDHC2_DATA0 = IOMUX_PAD(0x040C, 0x0180, 1, 0x067C, 2, 0), + MX6_PAD_NAND_DATA00__QSPI_B_SS1_B = IOMUX_PAD(0x040C, 0x0180, 2, 0x0000, 0, 0), + MX6_PAD_NAND_DATA00__KPP_ROW01 = IOMUX_PAD(0x040C, 0x0180, 3, 0x05D4, 1, 0), + MX6_PAD_NAND_DATA00__EIM_AD08 = IOMUX_PAD(0x040C, 0x0180, 4, 0x0000, 0, 0), + MX6_PAD_NAND_DATA00__GPIO4_IO02 = IOMUX_PAD(0x040C, 0x0180, 5, 0x0000, 0, 0), + MX6_PAD_NAND_DATA00__ECSPI4_RDY = IOMUX_PAD(0x040C, 0x0180, 8, 0x0000, 0, 0), + + MX6_PAD_NAND_DATA01__RAWNAND_DATA01 = IOMUX_PAD(0x0410, 0x0184, 0, 0x0000, 0, 0), + MX6_PAD_NAND_DATA01__USDHC2_DATA1 = IOMUX_PAD(0x0410, 0x0184, 1, 0x0680, 2, 0), + MX6_PAD_NAND_DATA01__QSPI_B_DQS = IOMUX_PAD(0x0410, 0x0184, 2, 0x0000, 0, 0), + MX6_PAD_NAND_DATA01__KPP_COL01 = IOMUX_PAD(0x0410, 0x0184, 3, 0x05C8, 1, 0), + MX6_PAD_NAND_DATA01__EIM_AD09 = IOMUX_PAD(0x0410, 0x0184, 4, 0x0000, 0, 0), + MX6_PAD_NAND_DATA01__GPIO4_IO03 = IOMUX_PAD(0x0410, 0x0184, 5, 0x0000, 0, 0), + MX6_PAD_NAND_DATA01__ECSPI4_SS1 = IOMUX_PAD(0x0410, 0x0184, 8, 0x0000, 0, 0), + + MX6_PAD_NAND_DATA02__RAWNAND_DATA02 = IOMUX_PAD(0x0414, 0x0188, 0, 0x0000, 0, 0), + MX6_PAD_NAND_DATA02__USDHC2_DATA2 = IOMUX_PAD(0x0414, 0x0188, 1, 0x0684, 1, 0), + MX6_PAD_NAND_DATA02__QSPI_B_DATA00 = IOMUX_PAD(0x0414, 0x0188, 2, 0x0000, 0, 0), + MX6_PAD_NAND_DATA02__KPP_ROW02 = IOMUX_PAD(0x0414, 0x0188, 3, 0x05D8, 1, 0), + MX6_PAD_NAND_DATA02__EIM_AD10 = IOMUX_PAD(0x0414, 0x0188, 4, 0x0000, 0, 0), + MX6_PAD_NAND_DATA02__GPIO4_IO04 = IOMUX_PAD(0x0414, 0x0188, 5, 0x0000, 0, 0), + MX6_PAD_NAND_DATA02__ECSPI4_SS2 = IOMUX_PAD(0x0414, 0x0188, 8, 0x0000, 0, 0), + + MX6_PAD_NAND_DATA03__RAWNAND_DATA03 = IOMUX_PAD(0x0418, 0x018C, 0, 0x0000, 0, 0), + MX6_PAD_NAND_DATA03__USDHC2_DATA3 = IOMUX_PAD(0x0418, 0x018C, 1, 0x0688, 2, 0), + MX6_PAD_NAND_DATA03__QSPI_B_DATA01 = IOMUX_PAD(0x0418, 0x018C, 2, 0x0000, 0, 0), + MX6_PAD_NAND_DATA03__KPP_COL02 = IOMUX_PAD(0x0418, 0x018C, 3, 0x05CC, 1, 0), + MX6_PAD_NAND_DATA03__EIM_AD11 = IOMUX_PAD(0x0418, 0x018C, 4, 0x0000, 0, 0), + MX6_PAD_NAND_DATA03__GPIO4_IO05 = IOMUX_PAD(0x0418, 0x018C, 5, 0x0000, 0, 0), + MX6_PAD_NAND_DATA03__ECSPI4_SS3 = IOMUX_PAD(0x0418, 0x018C, 8, 0x0000, 0, 0), + + MX6_PAD_NAND_DATA04__RAWNAND_DATA04 = IOMUX_PAD(0x041C, 0x0190, 0, 0x0000, 0, 0), + MX6_PAD_NAND_DATA04__USDHC2_DATA4 = IOMUX_PAD(0x041C, 0x0190, 1, 0x068C, 1, 0), + MX6_PAD_NAND_DATA04__QSPI_B_DATA02 = IOMUX_PAD(0x041C, 0x0190, 2, 0x0000, 0, 0), + MX6_PAD_NAND_DATA04__ECSPI4_SCLK = IOMUX_PAD(0x041C, 0x0190, 3, 0x0564, 1, 0), + MX6_PAD_NAND_DATA04__EIM_AD12 = IOMUX_PAD(0x041C, 0x0190, 4, 0x0000, 0, 0), + MX6_PAD_NAND_DATA04__GPIO4_IO06 = IOMUX_PAD(0x041C, 0x0190, 5, 0x0000, 0, 0), + MX6_PAD_NAND_DATA04__UART2_DCE_TX = IOMUX_PAD(0x041C, 0x0190, 8, 0x0000, 0, 0), + MX6_PAD_NAND_DATA04__UART2_DTE_RX = IOMUX_PAD(0x041C, 0x0190, 8, 0x062C, 2, 0), + + MX6_PAD_NAND_DATA05__RAWNAND_DATA05 = IOMUX_PAD(0x0420, 0x0194, 0, 0x0000, 0, 0), + MX6_PAD_NAND_DATA05__USDHC2_DATA5 = IOMUX_PAD(0x0420, 0x0194, 1, 0x0690, 1, 0), + MX6_PAD_NAND_DATA05__QSPI_B_DATA03 = IOMUX_PAD(0x0420, 0x0194, 2, 0x0000, 0, 0), + MX6_PAD_NAND_DATA05__ECSPI4_MOSI = IOMUX_PAD(0x0420, 0x0194, 3, 0x056C, 1, 0), + MX6_PAD_NAND_DATA05__EIM_AD13 = IOMUX_PAD(0x0420, 0x0194, 4, 0x0000, 0, 0), + MX6_PAD_NAND_DATA05__GPIO4_IO07 = IOMUX_PAD(0x0420, 0x0194, 5, 0x0000, 0, 0), + MX6_PAD_NAND_DATA05__UART2_DCE_RX = IOMUX_PAD(0x0420, 0x0194, 8, 0x062C, 3, 0), + MX6_PAD_NAND_DATA05__UART2_DTE_TX = IOMUX_PAD(0x0420, 0x0194, 8, 0x0000, 0, 0), + + MX6_PAD_NAND_DATA06__RAWNAND_DATA06 = IOMUX_PAD(0x0424, 0x0198, 0, 0x0000, 0, 0), + MX6_PAD_NAND_DATA06__USDHC2_DATA6 = IOMUX_PAD(0x0424, 0x0198, 1, 0x0694, 1, 0), + MX6_PAD_NAND_DATA06__SAI2_RX_BCLK = IOMUX_PAD(0x0424, 0x0198, 2, 0x0000, 0, 0), + MX6_PAD_NAND_DATA06__ECSPI4_MISO = IOMUX_PAD(0x0424, 0x0198, 3, 0x0568, 1, 0), + MX6_PAD_NAND_DATA06__EIM_AD14 = IOMUX_PAD(0x0424, 0x0198, 4, 0x0000, 0, 0), + MX6_PAD_NAND_DATA06__GPIO4_IO08 = IOMUX_PAD(0x0424, 0x0198, 5, 0x0000, 0, 0), + MX6_PAD_NAND_DATA06__UART2_DCE_CTS = IOMUX_PAD(0x0424, 0x0198, 8, 0x0000, 0, 0), + MX6_PAD_NAND_DATA06__UART2_DTE_RTS = IOMUX_PAD(0x0424, 0x0198, 8, 0x0628, 4, 0), + + MX6_PAD_NAND_DATA07__RAWNAND_DATA07 = IOMUX_PAD(0x0428, 0x019C, 0, 0x0000, 0, 0), + MX6_PAD_NAND_DATA07__USDHC2_DATA7 = IOMUX_PAD(0x0428, 0x019C, 1, 0x0698, 1, 0), + MX6_PAD_NAND_DATA07__QSPI_A_SS1_B = IOMUX_PAD(0x0428, 0x019C, 2, 0x0000, 0, 0), + MX6_PAD_NAND_DATA07__ECSPI4_SS0 = IOMUX_PAD(0x0428, 0x019C, 3, 0x0570, 1, 0), + MX6_PAD_NAND_DATA07__EIM_AD15 = IOMUX_PAD(0x0428, 0x019C, 4, 0x0000, 0, 0), + MX6_PAD_NAND_DATA07__GPIO4_IO09 = IOMUX_PAD(0x0428, 0x019C, 5, 0x0000, 0, 0), + MX6_PAD_NAND_DATA07__UART2_DCE_RTS = IOMUX_PAD(0x0428, 0x019C, 8, 0x0628, 5, 0), + MX6_PAD_NAND_DATA07__UART2_DTE_CTS = IOMUX_PAD(0x0428, 0x019C, 8, 0x0000, 0, 0), + + MX6_PAD_NAND_ALE__RAWNAND_ALE = IOMUX_PAD(0x042C, 0x01A0, 0, 0x0000, 0, 0), + MX6_PAD_NAND_ALE__USDHC2_RESET_B = IOMUX_PAD(0x042C, 0x01A0, 1, 0x0000, 0, 0), + MX6_PAD_NAND_ALE__QSPI_A_DQS = IOMUX_PAD(0x042C, 0x01A0, 2, 0x0000, 0, 0), + MX6_PAD_NAND_ALE__PWM3_OUT = IOMUX_PAD(0x042C, 0x01A0, 3, 0x0000, 0, 0), + MX6_PAD_NAND_ALE__EIM_ADDR17 = IOMUX_PAD(0x042C, 0x01A0, 4, 0x0000, 0, 0), + MX6_PAD_NAND_ALE__GPIO4_IO10 = IOMUX_PAD(0x042C, 0x01A0, 5, 0x0000, 0, 0), + MX6_PAD_NAND_ALE__ECSPI3_SS1 = IOMUX_PAD(0x042C, 0x01A0, 8, 0x0000, 0, 0), + + MX6_PAD_NAND_WP_B__RAWNAND_WP_B = IOMUX_PAD(0x0430, 0x01A4, 0, 0x0000, 0, 0), + MX6_PAD_NAND_WP_B__USDHC1_RESET_B = IOMUX_PAD(0x0430, 0x01A4, 1, 0x0000, 0, 0), + MX6_PAD_NAND_WP_B__QSPI_A_SCLK = IOMUX_PAD(0x0430, 0x01A4, 2, 0x0000, 0, 0), + MX6_PAD_NAND_WP_B__PWM4_OUT = IOMUX_PAD(0x0430, 0x01A4, 3, 0x0000, 0, 0), + MX6_PAD_NAND_WP_B__EIM_BCLK = IOMUX_PAD(0x0430, 0x01A4, 4, 0x0000, 0, 0), + MX6_PAD_NAND_WP_B__GPIO4_IO11 = IOMUX_PAD(0x0430, 0x01A4, 5, 0x0000, 0, 0), + MX6_PAD_NAND_WP_B__ECSPI3_RDY = IOMUX_PAD(0x0430, 0x01A4, 8, 0x0000, 0, 0), + + MX6_PAD_NAND_READY_B__RAWNAND_READY_B = IOMUX_PAD(0x0434, 0x01A8, 0, 0x0000, 0, 0), + MX6_PAD_NAND_READY_B__USDHC1_DATA4 = IOMUX_PAD(0x0434, 0x01A8, 1, 0x0000, 0, 0), + MX6_PAD_NAND_READY_B__QSPI_A_DATA00 = IOMUX_PAD(0x0434, 0x01A8, 2, 0x0000, 0, 0), + MX6_PAD_NAND_READY_B__ECSPI3_SS0 = IOMUX_PAD(0x0434, 0x01A8, 3, 0x0560, 1, 0), + MX6_PAD_NAND_READY_B__EIM_CS1_B = IOMUX_PAD(0x0434, 0x01A8, 4, 0x0000, 0, 0), + MX6_PAD_NAND_READY_B__GPIO4_IO12 = IOMUX_PAD(0x0434, 0x01A8, 5, 0x0000, 0, 0), + MX6_PAD_NAND_READY_B__UART3_DCE_TX = IOMUX_PAD(0x0434, 0x01A8, 8, 0x0000, 0, 0), + MX6_PAD_NAND_READY_B__UART3_DTE_RX = IOMUX_PAD(0x0434, 0x01A8, 8, 0x0634, 2, 0), + + MX6_PAD_NAND_CE0_B__RAWNAND_CE0_B = IOMUX_PAD(0x0438, 0x01AC, 0, 0x0000, 0, 0), + MX6_PAD_NAND_CE0_B__USDHC1_DATA5 = IOMUX_PAD(0x0438, 0x01AC, 1, 0x0000, 0, 0), + MX6_PAD_NAND_CE0_B__QSPI_A_DATA01 = IOMUX_PAD(0x0438, 0x01AC, 2, 0x0000, 0, 0), + MX6_PAD_NAND_CE0_B__ECSPI3_SCLK = IOMUX_PAD(0x0438, 0x01AC, 3, 0x0554, 1, 0), + MX6_PAD_NAND_CE0_B__EIM_DTACK_B = IOMUX_PAD(0x0438, 0x01AC, 4, 0x0000, 0, 0), + MX6_PAD_NAND_CE0_B__GPIO4_IO13 = IOMUX_PAD(0x0438, 0x01AC, 5, 0x0000, 0, 0), + MX6_PAD_NAND_CE0_B__UART3_DCE_RX = IOMUX_PAD(0x0438, 0x01AC, 8, 0x0634, 3, 0), + MX6_PAD_NAND_CE0_B__UART3_DTE_TX = IOMUX_PAD(0x0438, 0x01AC, 8, 0x0000, 0, 0), + + MX6_PAD_NAND_CE1_B__RAWNAND_CE1_B = IOMUX_PAD(0x043C, 0x01B0, 0, 0x0000, 0, 0), + MX6_PAD_NAND_CE1_B__USDHC1_DATA6 = IOMUX_PAD(0x043C, 0x01B0, 1, 0x0000, 0, 0), + MX6_PAD_NAND_CE1_B__QSPI_A_DATA02 = IOMUX_PAD(0x043C, 0x01B0, 2, 0x0000, 0, 0), + MX6_PAD_NAND_CE1_B__ECSPI3_MOSI = IOMUX_PAD(0x043C, 0x01B0, 3, 0x055C, 1, 0), + MX6_PAD_NAND_CE1_B__EIM_ADDR18 = IOMUX_PAD(0x043C, 0x01B0, 4, 0x0000, 0, 0), + MX6_PAD_NAND_CE1_B__GPIO4_IO14 = IOMUX_PAD(0x043C, 0x01B0, 5, 0x0000, 0, 0), + MX6_PAD_NAND_CE1_B__UART3_DCE_CTS = IOMUX_PAD(0x043C, 0x01B0, 8, 0x0000, 0, 0), + MX6_PAD_NAND_CE1_B__UART3_DTE_RTS = IOMUX_PAD(0x043C, 0x01B0, 8, 0x0630, 2, 0), + + MX6_PAD_NAND_CLE__RAWNAND_CLE = IOMUX_PAD(0x0440, 0x01B4, 0, 0x0000, 0, 0), + MX6_PAD_NAND_CLE__USDHC1_DATA7 = IOMUX_PAD(0x0440, 0x01B4, 1, 0x0000, 0, 0), + MX6_PAD_NAND_CLE__QSPI_A_DATA03 = IOMUX_PAD(0x0440, 0x01B4, 2, 0x0000, 0, 0), + MX6_PAD_NAND_CLE__ECSPI3_MISO = IOMUX_PAD(0x0440, 0x01B4, 3, 0x0558, 1, 0), + MX6_PAD_NAND_CLE__EIM_ADDR16 = IOMUX_PAD(0x0440, 0x01B4, 4, 0x0000, 0, 0), + MX6_PAD_NAND_CLE__GPIO4_IO15 = IOMUX_PAD(0x0440, 0x01B4, 5, 0x0000, 0, 0), + MX6_PAD_NAND_CLE__UART3_DCE_RTS = IOMUX_PAD(0x0440, 0x01B4, 8, 0x0630, 3, 0), + MX6_PAD_NAND_CLE__UART3_DTE_CTS = IOMUX_PAD(0x0440, 0x01B4, 8, 0x0000, 0, 0), + + MX6_PAD_NAND_DQS__RAWNAND_DQS = IOMUX_PAD(0x0444, 0x01B8, 0, 0x0000, 0, 0), + MX6_PAD_NAND_DQS__CSI_FIELD = IOMUX_PAD(0x0444, 0x01B8, 1, 0x0530, 1, 0), + MX6_PAD_NAND_DQS__QSPI_A_SS0_B = IOMUX_PAD(0x0444, 0x01B8, 2, 0x0000, 0, 0), + MX6_PAD_NAND_DQS__PWM5_OUT = IOMUX_PAD(0x0444, 0x01B8, 3, 0x0000, 0, 0), + MX6_PAD_NAND_DQS__EIM_WAIT = IOMUX_PAD(0x0444, 0x01B8, 4, 0x0000, 0, 0), + MX6_PAD_NAND_DQS__GPIO4_IO16 = IOMUX_PAD(0x0444, 0x01B8, 5, 0x0000, 0, 0), + MX6_PAD_NAND_DQS__SDMA_EXT_EVENT01 = IOMUX_PAD(0x0444, 0x01B8, 6, 0x0614, 1, 0), + MX6_PAD_NAND_DQS__SPDIF_EXT_CLK = IOMUX_PAD(0x0444, 0x01B8, 8, 0x061C, 1, 0), + + MX6_PAD_SD1_CMD__USDHC1_CMD = IOMUX_PAD(0x0448, 0x01BC, 0, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__GPT2_COMPARE1 = IOMUX_PAD(0x0448, 0x01BC, 1, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__SAI2_RX_SYNC = IOMUX_PAD(0x0448, 0x01BC, 2, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__SPDIF_OUT = IOMUX_PAD(0x0448, 0x01BC, 3, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__EIM_ADDR19 = IOMUX_PAD(0x0448, 0x01BC, 4, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__GPIO2_IO16 = IOMUX_PAD(0x0448, 0x01BC, 5, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__SDMA_EXT_EVENT00 = IOMUX_PAD(0x0448, 0x01BC, 6, 0x0610, 2, 0), + MX6_PAD_SD1_CMD__USB_OTG1_PWR = IOMUX_PAD(0x0448, 0x01BC, 8, 0x0000, 0, 0), + + MX6_PAD_SD1_CLK__USDHC1_CLK = IOMUX_PAD(0x044C, 0x01C0, 0, 0x0000, 0, 0), + MX6_PAD_SD1_CLK__GPT2_COMPARE2 = IOMUX_PAD(0x044C, 0x01C0, 1, 0x0000, 0, 0), + MX6_PAD_SD1_CLK__SAI2_MCLK = IOMUX_PAD(0x044C, 0x01C0, 2, 0x05F0, 1, 0), + MX6_PAD_SD1_CLK__SPDIF_IN = IOMUX_PAD(0x044C, 0x01C0, 3, 0x0618, 3, 0), + MX6_PAD_SD1_CLK__EIM_ADDR20 = IOMUX_PAD(0x044C, 0x01C0, 4, 0x0000, 0, 0), + MX6_PAD_SD1_CLK__GPIO2_IO17 = IOMUX_PAD(0x044C, 0x01C0, 5, 0x0000, 0, 0), + MX6_PAD_SD1_CLK__USB_OTG1_OC = IOMUX_PAD(0x044C, 0x01C0, 8, 0x0664, 2, 0), + + MX6_PAD_SD1_DATA0__USDHC1_DATA0 = IOMUX_PAD(0x0450, 0x01C4, 0, 0x0000, 0, 0), + MX6_PAD_SD1_DATA0__GPT2_COMPARE3 = IOMUX_PAD(0x0450, 0x01C4, 1, 0x0000, 0, 0), + MX6_PAD_SD1_DATA0__SAI2_TX_SYNC = IOMUX_PAD(0x0450, 0x01C4, 2, 0x05FC, 1, 0), + MX6_PAD_SD1_DATA0__FLEXCAN1_TX = IOMUX_PAD(0x0450, 0x01C4, 3, 0x0000, 0, 0), + MX6_PAD_SD1_DATA0__EIM_ADDR21 = IOMUX_PAD(0x0450, 0x01C4, 4, 0x0000, 0, 0), + MX6_PAD_SD1_DATA0__GPIO2_IO18 = IOMUX_PAD(0x0450, 0x01C4, 5, 0x0000, 0, 0), + MX6_PAD_SD1_DATA0__ANATOP_OTG1_ID = IOMUX_PAD(0x0450, 0x01C4, 8, 0x04B8, 2, 0), + + MX6_PAD_SD1_DATA1__USDHC1_DATA1 = IOMUX_PAD(0x0454, 0x01C8, 0, 0x0000, 0, 0), + MX6_PAD_SD1_DATA1__GPT2_CLK = IOMUX_PAD(0x0454, 0x01C8, 1, 0x05A0, 1, 0), + MX6_PAD_SD1_DATA1__SAI2_TX_BCLK = IOMUX_PAD(0x0454, 0x01C8, 2, 0x05F8, 1, 0), + MX6_PAD_SD1_DATA1__FLEXCAN1_RX = IOMUX_PAD(0x0454, 0x01C8, 3, 0x0584, 3, 0), + MX6_PAD_SD1_DATA1__EIM_ADDR22 = IOMUX_PAD(0x0454, 0x01C8, 4, 0x0000, 0, 0), + MX6_PAD_SD1_DATA1__GPIO2_IO19 = IOMUX_PAD(0x0454, 0x01C8, 5, 0x0000, 0, 0), + MX6_PAD_SD1_DATA1__USB_OTG2_PWR = IOMUX_PAD(0x0454, 0x01C8, 8, 0x0000, 0, 0), + + MX6_PAD_SD1_DATA2__USDHC1_DATA2 = IOMUX_PAD(0x0458, 0x01CC, 0, 0x0000, 0, 0), + MX6_PAD_SD1_DATA2__GPT2_CAPTURE1 = IOMUX_PAD(0x0458, 0x01CC, 1, 0x0598, 1, 0), + MX6_PAD_SD1_DATA2__SAI2_RX_DATA = IOMUX_PAD(0x0458, 0x01CC, 2, 0x05F4, 1, 0), + MX6_PAD_SD1_DATA2__FLEXCAN2_TX = IOMUX_PAD(0x0458, 0x01CC, 3, 0x0000, 0, 0), + MX6_PAD_SD1_DATA2__EIM_ADDR23 = IOMUX_PAD(0x0458, 0x01CC, 4, 0x0000, 0, 0), + MX6_PAD_SD1_DATA2__GPIO2_IO20 = IOMUX_PAD(0x0458, 0x01CC, 5, 0x0000, 0, 0), + MX6_PAD_SD1_DATA2__CCM_CLKO1 = IOMUX_PAD(0x0458, 0x01CC, 6, 0x0000, 0, 0), + MX6_PAD_SD1_DATA2__USB_OTG2_OC = IOMUX_PAD(0x0458, 0x01CC, 8, 0x0660, 2, 0), + + MX6_PAD_SD1_DATA3__USDHC1_DATA3 = IOMUX_PAD(0x045C, 0x01D0, 0, 0x0000, 0, 0), + MX6_PAD_SD1_DATA3__GPT2_CAPTURE2 = IOMUX_PAD(0x045C, 0x01D0, 1, 0x059C, 1, 0), + MX6_PAD_SD1_DATA3__SAI2_TX_DATA = IOMUX_PAD(0x045C, 0x01D0, 2, 0x0000, 0, 0), + MX6_PAD_SD1_DATA3__FLEXCAN2_RX = IOMUX_PAD(0x045C, 0x01D0, 3, 0x0588, 3, 0), + MX6_PAD_SD1_DATA3__EIM_ADDR24 = IOMUX_PAD(0x045C, 0x01D0, 4, 0x0000, 0, 0), + MX6_PAD_SD1_DATA3__GPIO2_IO21 = IOMUX_PAD(0x045C, 0x01D0, 5, 0x0000, 0, 0), + MX6_PAD_SD1_DATA3__CCM_CLKO2 = IOMUX_PAD(0x045C, 0x01D0, 6, 0x0000, 0, 0), + MX6_PAD_SD1_DATA3__ANATOP_OTG2_ID = IOMUX_PAD(0x045C, 0x01D0, 8, 0x04BC, 2, 0), + + MX6_PAD_CSI_MCLK__CSI_MCLK = IOMUX_PAD(0x0460, 0x01D4, 0, 0x0000, 0, 0), + MX6_PAD_CSI_MCLK__USDHC2_CD_B = IOMUX_PAD(0x0460, 0x01D4, 1, 0x0674, 0, 0), + MX6_PAD_CSI_MCLK__RAWNAND_CE2_B = IOMUX_PAD(0x0460, 0x01D4, 2, 0x0000, 0, 0), + MX6_PAD_CSI_MCLK__I2C1_SDA = IOMUX_PAD(0x0460, 0x01D4, IOMUX_CONFIG_SION | 3, 0x05A8, 0, 0), + MX6_PAD_CSI_MCLK__EIM_CS0_B = IOMUX_PAD(0x0460, 0x01D4, 4, 0x0000, 0, 0), + MX6_PAD_CSI_MCLK__GPIO4_IO17 = IOMUX_PAD(0x0460, 0x01D4, 5, 0x0000, 0, 0), + MX6_PAD_CSI_MCLK__SNVS_HP_VIO_5_CTL = IOMUX_PAD(0x0460, 0x01D4, 6, 0x0000, 0, 0), + MX6_PAD_CSI_MCLK__UART6_DCE_TX = IOMUX_PAD(0x0460, 0x01D4, 8, 0x0000, 0, 0), + MX6_PAD_CSI_MCLK__UART6_DTE_RX = IOMUX_PAD(0x0460, 0x01D4, 8, 0x064C, 0, 0), + + MX6_PAD_CSI_PIXCLK__CSI_PIXCLK = IOMUX_PAD(0x0464, 0x01D8, 0, 0x0528, 1, 0), + MX6_PAD_CSI_PIXCLK__USDHC2_WP = IOMUX_PAD(0x0464, 0x01D8, 1, 0x069C, 2, 0), + MX6_PAD_CSI_PIXCLK__RAWNAND_CE3_B = IOMUX_PAD(0x0464, 0x01D8, 2, 0x0000, 0, 0), + MX6_PAD_CSI_PIXCLK__I2C1_SCL = IOMUX_PAD(0x0464, 0x01D8, IOMUX_CONFIG_SION | 3, 0x05A4, 2, 0), + MX6_PAD_CSI_PIXCLK__EIM_OE = IOMUX_PAD(0x0464, 0x01D8, 4, 0x0000, 0, 0), + MX6_PAD_CSI_PIXCLK__GPIO4_IO18 = IOMUX_PAD(0x0464, 0x01D8, 5, 0x0000, 0, 0), + MX6_PAD_CSI_PIXCLK__SNVS_HP_VIO_5 = IOMUX_PAD(0x0464, 0x01D8, 6, 0x0000, 0, 0), + MX6_PAD_CSI_PIXCLK__UART6_DCE_RX = IOMUX_PAD(0x0464, 0x01D8, 8, 0x064C, 3, 0), + MX6_PAD_CSI_PIXCLK__UART6_DTE_TX = IOMUX_PAD(0x0464, 0x01D8, 8, 0x0000, 0, 0), + + MX6_PAD_CSI_VSYNC__CSI_VSYNC = IOMUX_PAD(0x0468, 0x01DC, 0, 0x052C, 0, 0), + MX6_PAD_CSI_VSYNC__USDHC2_CLK = IOMUX_PAD(0x0468, 0x01DC, 1, 0x0670, 0, 0), + MX6_PAD_CSI_VSYNC__SIM1_PORT1_CLK = IOMUX_PAD(0x0468, 0x01DC, 2, 0x0000, 0, 0), + MX6_PAD_CSI_VSYNC__I2C2_SDA = IOMUX_PAD(0x0468, 0x01DC, IOMUX_CONFIG_SION | 3, 0x05B0, 0, 0), + MX6_PAD_CSI_VSYNC__EIM_RW = IOMUX_PAD(0x0468, 0x01DC, 4, 0x0000, 0, 0), + MX6_PAD_CSI_VSYNC__GPIO4_IO19 = IOMUX_PAD(0x0468, 0x01DC, 5, 0x0000, 0, 0), + MX6_PAD_CSI_VSYNC__PWM7_OUT = IOMUX_PAD(0x0468, 0x01DC, 6, 0x0000, 0, 0), + MX6_PAD_CSI_VSYNC__UART6_DCE_RTS = IOMUX_PAD(0x0468, 0x01DC, 8, 0x0648, 0, 0), + MX6_PAD_CSI_VSYNC__UART6_DTE_CTS = IOMUX_PAD(0x0468, 0x01DC, 8, 0x0000, 0, 0), + + MX6_PAD_CSI_HSYNC__CSI_HSYNC = IOMUX_PAD(0x046C, 0x01E0, 0, 0x0524, 0, 0), + MX6_PAD_CSI_HSYNC__USDHC2_CMD = IOMUX_PAD(0x046C, 0x01E0, 1, 0x0678, 0, 0), + MX6_PAD_CSI_HSYNC__SIM1_PORT1_PD = IOMUX_PAD(0x046C, 0x01E0, 2, 0x0000, 0, 0), + MX6_PAD_CSI_HSYNC__I2C2_SCL = IOMUX_PAD(0x046C, 0x01E0, IOMUX_CONFIG_SION | 3, 0x05AC, 0, 0), + MX6_PAD_CSI_HSYNC__EIM_LBA_B = IOMUX_PAD(0x046C, 0x01E0, 4, 0x0000, 0, 0), + MX6_PAD_CSI_HSYNC__GPIO4_IO20 = IOMUX_PAD(0x046C, 0x01E0, 5, 0x0000, 0, 0), + MX6_PAD_CSI_HSYNC__PWM8_OUT = IOMUX_PAD(0x046C, 0x01E0, 6, 0x0000, 0, 0), + MX6_PAD_CSI_HSYNC__UART6_DCE_CTS = IOMUX_PAD(0x046C, 0x01E0, 8, 0x0000, 0, 0), + MX6_PAD_CSI_HSYNC__UART6_DTE_RTS = IOMUX_PAD(0x046C, 0x01E0, 8, 0x0648, 1, 0), + + MX6_PAD_CSI_DATA00__CSI_DATA02 = IOMUX_PAD(0x0470, 0x01E4, 0, 0x04C4, 0, 0), + MX6_PAD_CSI_DATA00__USDHC2_DATA0 = IOMUX_PAD(0x0470, 0x01E4, 1, 0x067C, 0, 0), + MX6_PAD_CSI_DATA00__SIM1_PORT1_RST_B = IOMUX_PAD(0x0470, 0x01E4, 2, 0x0000, 0, 0), + MX6_PAD_CSI_DATA00__ECSPI2_SCLK = IOMUX_PAD(0x0470, 0x01E4, 3, 0x0544, 0, 0), + MX6_PAD_CSI_DATA00__EIM_AD00 = IOMUX_PAD(0x0470, 0x01E4, 4, 0x0000, 0, 0), + MX6_PAD_CSI_DATA00__GPIO4_IO21 = IOMUX_PAD(0x0470, 0x01E4, 5, 0x0000, 0, 0), + MX6_PAD_CSI_DATA00__SRC_INT_BOOT = IOMUX_PAD(0x0470, 0x01E4, 6, 0x0000, 0, 0), + MX6_PAD_CSI_DATA00__UART5_DCE_TX = IOMUX_PAD(0x0470, 0x01E4, 8, 0x0000, 0, 0), + MX6_PAD_CSI_DATA00__UART5_DTE_RX = IOMUX_PAD(0x0470, 0x01E4, 8, 0x0644, 0, 0), + + MX6_PAD_CSI_DATA01__CSI_DATA03 = IOMUX_PAD(0x0474, 0x01E8, 0, 0x04C8, 0, 0), + MX6_PAD_CSI_DATA01__USDHC2_DATA1 = IOMUX_PAD(0x0474, 0x01E8, 1, 0x0680, 0, 0), + MX6_PAD_CSI_DATA01__SIM1_PORT1_SVEN = IOMUX_PAD(0x0474, 0x01E8, 2, 0x0000, 0, 0), + MX6_PAD_CSI_DATA01__ECSPI2_SS0 = IOMUX_PAD(0x0474, 0x01E8, 3, 0x0550, 0, 0), + MX6_PAD_CSI_DATA01__EIM_AD01 = IOMUX_PAD(0x0474, 0x01E8, 4, 0x0000, 0, 0), + MX6_PAD_CSI_DATA01__GPIO4_IO22 = IOMUX_PAD(0x0474, 0x01E8, 5, 0x0000, 0, 0), + MX6_PAD_CSI_DATA01__SAI1_MCLK = IOMUX_PAD(0x0474, 0x01E8, 6, 0x05E0, 0, 0), + MX6_PAD_CSI_DATA01__UART5_DCE_RX = IOMUX_PAD(0x0474, 0x01E8, 8, 0x0644, 1, 0), + MX6_PAD_CSI_DATA01__UART5_DTE_TX = IOMUX_PAD(0x0474, 0x01E8, 8, 0x0000, 0, 0), + + MX6_PAD_CSI_DATA02__CSI_DATA04 = IOMUX_PAD(0x0478, 0x01EC, 0, 0x04D8, 1, 0), + MX6_PAD_CSI_DATA02__USDHC2_DATA2 = IOMUX_PAD(0x0478, 0x01EC, 1, 0x0684, 2, 0), + MX6_PAD_CSI_DATA02__SIM1_PORT1_TRXD = IOMUX_PAD(0x0478, 0x01EC, 2, 0x0000, 0, 0), + MX6_PAD_CSI_DATA02__ECSPI2_MOSI = IOMUX_PAD(0x0478, 0x01EC, 3, 0x054C, 1, 0), + MX6_PAD_CSI_DATA02__EIM_AD02 = IOMUX_PAD(0x0478, 0x01EC, 4, 0x0000, 0, 0), + MX6_PAD_CSI_DATA02__GPIO4_IO23 = IOMUX_PAD(0x0478, 0x01EC, 5, 0x0000, 0, 0), + MX6_PAD_CSI_DATA02__SAI1_RX_SYNC = IOMUX_PAD(0x0478, 0x01EC, 6, 0x0000, 0, 0), + MX6_PAD_CSI_DATA02__UART5_DCE_RTS = IOMUX_PAD(0x0478, 0x01EC, 8, 0x0640, 5, 0), + MX6_PAD_CSI_DATA02__UART5_DTE_CTS = IOMUX_PAD(0x0478, 0x01EC, 8, 0x0000, 0, 0), + + MX6_PAD_CSI_DATA03__CSI_DATA05 = IOMUX_PAD(0x047C, 0x01F0, 0, 0x04CC, 0, 0), + MX6_PAD_CSI_DATA03__USDHC2_DATA3 = IOMUX_PAD(0x047C, 0x01F0, 1, 0x0688, 0, 0), + MX6_PAD_CSI_DATA03__SIM2_PORT1_PD = IOMUX_PAD(0x047C, 0x01F0, 2, 0x0000, 0, 0), + MX6_PAD_CSI_DATA03__ECSPI2_MISO = IOMUX_PAD(0x047C, 0x01F0, 3, 0x0548, 0, 0), + MX6_PAD_CSI_DATA03__EIM_AD03 = IOMUX_PAD(0x047C, 0x01F0, 4, 0x0000, 0, 0), + MX6_PAD_CSI_DATA03__GPIO4_IO24 = IOMUX_PAD(0x047C, 0x01F0, 5, 0x0000, 0, 0), + MX6_PAD_CSI_DATA03__SAI1_RX_BCLK = IOMUX_PAD(0x047C, 0x01F0, 6, 0x0000, 0, 0), + MX6_PAD_CSI_DATA03__UART5_DCE_CTS = IOMUX_PAD(0x047C, 0x01F0, 8, 0x0000, 0, 0), + MX6_PAD_CSI_DATA03__UART5_DTE_RTS = IOMUX_PAD(0x047C, 0x01F0, 8, 0x0640, 0, 0), + + MX6_PAD_CSI_DATA04__CSI_DATA06 = IOMUX_PAD(0x0480, 0x01F4, 0, 0x04DC, 1, 0), + MX6_PAD_CSI_DATA04__USDHC2_DATA4 = IOMUX_PAD(0x0480, 0x01F4, 1, 0x068C, 2, 0), + MX6_PAD_CSI_DATA04__SIM2_PORT1_CLK = IOMUX_PAD(0x0480, 0x01F4, 2, 0x0000, 0, 0), + MX6_PAD_CSI_DATA04__ECSPI1_SCLK = IOMUX_PAD(0x0480, 0x01F4, 3, 0x0534, 1, 0), + MX6_PAD_CSI_DATA04__EIM_AD04 = IOMUX_PAD(0x0480, 0x01F4, 4, 0x0000, 0, 0), + MX6_PAD_CSI_DATA04__GPIO4_IO25 = IOMUX_PAD(0x0480, 0x01F4, 5, 0x0000, 0, 0), + MX6_PAD_CSI_DATA04__SAI1_TX_SYNC = IOMUX_PAD(0x0480, 0x01F4, 6, 0x05EC, 1, 0), + MX6_PAD_CSI_DATA04__USDHC1_WP = IOMUX_PAD(0x0480, 0x01F4, 8, 0x066C, 2, 0), + + MX6_PAD_CSI_DATA05__CSI_DATA07 = IOMUX_PAD(0x0484, 0x01F8, 0, 0x04E0, 1, 0), + MX6_PAD_CSI_DATA05__USDHC2_DATA5 = IOMUX_PAD(0x0484, 0x01F8, 1, 0x0690, 2, 0), + MX6_PAD_CSI_DATA05__SIM2_PORT1_RST_B = IOMUX_PAD(0x0484, 0x01F8, 2, 0x0000, 0, 0), + MX6_PAD_CSI_DATA05__ECSPI1_SS0 = IOMUX_PAD(0x0484, 0x01F8, 3, 0x0540, 1, 0), + MX6_PAD_CSI_DATA05__EIM_AD05 = IOMUX_PAD(0x0484, 0x01F8, 4, 0x0000, 0, 0), + MX6_PAD_CSI_DATA05__GPIO4_IO26 = IOMUX_PAD(0x0484, 0x01F8, 5, 0x0000, 0, 0), + MX6_PAD_CSI_DATA05__SAI1_TX_BCLK = IOMUX_PAD(0x0484, 0x01F8, 6, 0x05E8, 1, 0), + MX6_PAD_CSI_DATA05__USDHC1_CD_B = IOMUX_PAD(0x0484, 0x01F8, 8, 0x0668, 2, 0), + + MX6_PAD_CSI_DATA06__CSI_DATA08 = IOMUX_PAD(0x0488, 0x01FC, 0, 0x04E4, 1, 0), + MX6_PAD_CSI_DATA06__USDHC2_DATA6 = IOMUX_PAD(0x0488, 0x01FC, 1, 0x0694, 2, 0), + MX6_PAD_CSI_DATA06__SIM2_PORT1_SVEN = IOMUX_PAD(0x0488, 0x01FC, 2, 0x0000, 0, 0), + MX6_PAD_CSI_DATA06__ECSPI1_MOSI = IOMUX_PAD(0x0488, 0x01FC, 3, 0x053C, 1, 0), + MX6_PAD_CSI_DATA06__EIM_AD06 = IOMUX_PAD(0x0488, 0x01FC, 4, 0x0000, 0, 0), + MX6_PAD_CSI_DATA06__GPIO4_IO27 = IOMUX_PAD(0x0488, 0x01FC, 5, 0x0000, 0, 0), + MX6_PAD_CSI_DATA06__SAI1_RX_DATA = IOMUX_PAD(0x0488, 0x01FC, 6, 0x05E4, 1, 0), + MX6_PAD_CSI_DATA06__USDHC1_RESET_B = IOMUX_PAD(0x0488, 0x01FC, 8, 0x0000, 0, 0), + + MX6_PAD_CSI_DATA07__CSI_DATA09 = IOMUX_PAD(0x048C, 0x0200, 0, 0x04E8, 1, 0), + MX6_PAD_CSI_DATA07__USDHC2_DATA7 = IOMUX_PAD(0x048C, 0x0200, 1, 0x0698, 2, 0), + MX6_PAD_CSI_DATA07__SIM2_PORT1_TRXD = IOMUX_PAD(0x048C, 0x0200, 2, 0x0000, 0, 0), + MX6_PAD_CSI_DATA07__ECSPI1_MISO = IOMUX_PAD(0x048C, 0x0200, 3, 0x0538, 1, 0), + MX6_PAD_CSI_DATA07__EIM_AD07 = IOMUX_PAD(0x048C, 0x0200, 4, 0x0000, 0, 0), + MX6_PAD_CSI_DATA07__GPIO4_IO28 = IOMUX_PAD(0x048C, 0x0200, 5, 0x0000, 0, 0), + MX6_PAD_CSI_DATA07__SAI1_TX_DATA = IOMUX_PAD(0x048C, 0x0200, 6, 0x0000, 0, 0), + MX6_PAD_CSI_DATA07__USDHC1_VSELECT = IOMUX_PAD(0x048C, 0x0200, 8, 0x0000, 0, 0), +}; +#endif /* __ASM_ARCH_IMX6UL_PINS_H__ */
On Thursday, July 02, 2015 at 01:02:59 PM, Peng Fan wrote:
Add i.MX6UL pins IOMUX file which defines the IOMUX settings for choose.
Signed-off-by: Peng Fan Peng.Fan@freescale.com Signed-off-by: Ye.Li B37916@freescale.com
arch/arm/include/asm/arch-mx6/mx6-pins.h | 2 + arch/arm/include/asm/arch-mx6/mx6ul_pins.h | 1065 ++++++++++++++++++++++++++++ 2 files changed, 1067 insertions(+) create mode 100644 arch/arm/include/asm/arch-mx6/mx6ul_pins.h
diff --git a/arch/arm/include/asm/arch-mx6/mx6-pins.h b/arch/arm/include/asm/arch-mx6/mx6-pins.h index 534f780..4b6bb18 100644 --- a/arch/arm/include/asm/arch-mx6/mx6-pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6-pins.h @@ -37,6 +37,8 @@ enum { #include "mx6sl_pins.h" #elif defined(CONFIG_MX6SX) #include "mx6sx_pins.h" +#elif defined(CONFIG_MX6UL) +#include "mx6ul_pins.h" #else #error "Please select cpu" #endif /* CONFIG_MX6Q */
Would it be possible to build a single image for an entire MX6 lineup of CPUs ? I think it is now possible to build a single image for MX6 Quad/Dual/DualLite/Solo ... do SX and UL integrate well into this too? Seeing this patch, I don't think so ...
diff --git a/arch/arm/include/asm/arch-mx6/mx6ul_pins.h b/arch/arm/include/asm/arch-mx6/mx6ul_pins.h new file mode 100644 index 0000000..c92b4f0
How very different is this from Solo or SoloX ? Is the pinmux map really that different that it needs a new file of it's own (I did not check) ?
Best regards, Marek Vasut
Hi, Marek
A single image you mean like linux kernel, one image cover all the arch/driver code, and using dts to cover board part? If so, agree to build a single image for i.MX6, but dtb is not added now. To kernel, pinmux header are used for dtb, but now we do need this file to set pinmux in uboot board file.
SX and UL have different pinmux from others.
SX and UL have different pinmux map.
Regards, Peng. --
On Friday, July 03, 2015 at 03:31:09 AM, Peng Fan wrote:
Hi, Marek
Eventually yes, but this can be done without DT too.
See arch/arm/include/asm/arch-mx6/mx6-pins.h and in particular CONFIG_MX6QDL option. It allows defining pins for both MX6Q and DL (and solo), thus you can build single image for a board which might use all three options. I think it should be possible to add SX and UL into this mix too.
OK
OK
Update imx register base address for i.MX6UL
Signed-off-by: Peng Fan Peng.Fan@freescale.com Signed-off-by: Ye.Li B37916@freescale.com --- arch/arm/include/asm/arch-mx6/imx-regs.h | 60 ++++++++++++++++++++++---------- 1 file changed, 41 insertions(+), 19 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx6/imx-regs.h b/arch/arm/include/asm/arch-mx6/imx-regs.h index 35a324c..d78daac 100644 --- a/arch/arm/include/asm/arch-mx6/imx-regs.h +++ b/arch/arm/include/asm/arch-mx6/imx-regs.h @@ -9,7 +9,11 @@
#define ARCH_MXC
+#ifdef CONFIG_MX6UL +#define CONFIG_SYS_CACHELINE_SIZE 64 +#else #define CONFIG_SYS_CACHELINE_SIZE 32 +#endif
#define ROMCP_ARB_BASE_ADDR 0x00000000 #define ROMCP_ARB_END_ADDR 0x000FFFFF @@ -19,7 +23,7 @@ #define GPU_2D_ARB_END_ADDR 0x02203FFF #define OPENVG_ARB_BASE_ADDR 0x02204000 #define OPENVG_ARB_END_ADDR 0x02207FFF -#elif CONFIG_MX6SX +#elif (defined(CONFIG_MX6SX) || defined(CONFIG_MX6UL)) #define CAAM_ARB_BASE_ADDR 0x00100000 #define CAAM_ARB_END_ADDR 0x00107FFF #define GPU_ARB_BASE_ADDR 0x01800000 @@ -28,10 +32,6 @@ #define APBH_DMA_ARB_END_ADDR 0x0180BFFF #define M4_BOOTROM_BASE_ADDR 0x007F8000
-#define MXS_APBH_BASE APBH_DMA_ARB_BASE_ADDR -#define MXS_GPMI_BASE (APBH_DMA_ARB_BASE_ADDR + 0x02000) -#define MXS_BCH_BASE (APBH_DMA_ARB_BASE_ADDR + 0x04000) - #else #define CAAM_ARB_BASE_ADDR 0x00100000 #define CAAM_ARB_END_ADDR 0x00103FFF @@ -52,13 +52,13 @@ #define MXS_BCH_BASE (APBH_DMA_ARB_BASE_ADDR + 0x04000)
/* GPV - PL301 configuration ports */ -#if (defined(CONFIG_MX6SL) || defined(CONFIG_MX6SX)) +#if (defined(CONFIG_MX6SL) || defined(CONFIG_MX6SX) || defined(CONFIG_MX6UL)) #define GPV2_BASE_ADDR 0x00D00000 #else #define GPV2_BASE_ADDR 0x00200000 #endif
-#ifdef CONFIG_MX6SX +#if (defined(CONFIG_MX6SX) || defined(CONFIG_MX6UL)) #define GPV3_BASE_ADDR 0x00E00000 #define GPV4_BASE_ADDR 0x00F00000 #define GPV5_BASE_ADDR 0x01000000 @@ -96,6 +96,11 @@ #define QSPI0_AMBA_END 0x6FFFFFFF #define QSPI1_AMBA_BASE 0x70000000 #define QSPI1_AMBA_END 0x7FFFFFFF +#elif defined(CONFIG_MX6UL) +#define WEIM_ARB_BASE_ADDR 0x50000000 +#define WEIM_ARB_END_ADDR 0x57FFFFFF +#define QSPI0_AMBA_BASE 0x60000000 +#define QSPI0_AMBA_END 0x6FFFFFFF #else #define SATA_ARB_BASE_ADDR 0x02200000 #define SATA_ARB_END_ADDR 0x02203FFF @@ -111,7 +116,7 @@ #define WEIM_ARB_END_ADDR 0x0FFFFFFF #endif
-#if (defined(CONFIG_MX6SL) || defined(CONFIG_MX6SX)) +#if (defined(CONFIG_MX6SL) || defined(CONFIG_MX6SX) || defined(CONFIG_MX6UL)) #define MMDC0_ARB_BASE_ADDR 0x80000000 #define MMDC0_ARB_END_ADDR 0xFFFFFFFF #define MMDC1_ARB_BASE_ADDR 0xC0000000 @@ -179,8 +184,13 @@ #define GPIO3_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x24000) #define GPIO4_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x28000) #define GPIO5_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x2C000) +#ifdef CONFIG_MX6UL +#define SNVS_LP_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x30000) +#define ENET2_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x34000) +#else #define GPIO6_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x30000) #define GPIO7_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x34000) +#endif #define KPP_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x38000) #define WDOG1_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x3C000) #define WDOG2_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x40000) @@ -249,6 +259,12 @@ #define WEIM_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x38000) #define OCOTP_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x3C000) #define CSU_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x40000) +#ifdef CONFIG_MX6UL +#define CSI_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x44000) +#define LCDIF1_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x48000) +#define LCDIF2_BASE_ADDR LCDIF1_BASE_ADDR +#define PXP_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x4C000) +#else #define IP2APB_PERFMON1_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x44000) #define IP2APB_PERFMON2_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x48000) #ifdef CONFIG_MX6SX @@ -256,19 +272,23 @@ #else #define IP2APB_PERFMON3_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x4C000) #endif +#endif #define IP2APB_TZASC1_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x50000) -#ifdef CONFIG_MX6SX +#ifdef CONFIG_MX6UL +#define SYSCNT_RD_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x54000) +#define SYSCNT_CMP_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x58000) +#define SYSCNT_CTRL_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x5C000) +#define SCTR_BASE_ADDR SYSCNT_CTRL_IPS_BASE_ADDR +#define QSPI0_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x60000) +#define WDOG3_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x64000) +#elif defined(CONFIG_MX6SX) #define SAI1_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x54000) -#else -#define IP2APB_TZASC2_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x54000) -#endif #define AUDMUX_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x58000) -#define AUDMUX_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x58000) -#ifdef CONFIG_MX6SX #define SAI2_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x5C000) #define QSPI0_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x60000) #define QSPI1_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x64000) #else +#define IP2APB_TZASC2_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x54000) #define MIPI_CSI2_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x5C000) #define MIPI_DSI_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x60000) #define VDOA_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x64000) @@ -313,7 +333,7 @@ #define CHIP_REV_1_2 0x12 #define CHIP_REV_1_5 0x15 #define CHIP_REV_2_0 0x20 -#ifndef CONFIG_MX6SX +#if !(defined(CONFIG_MX6SX) || defined(CONFIG_MX6UL)) #define IRAM_SIZE 0x00040000 #else #define IRAM_SIZE 0x00020000 @@ -451,7 +471,7 @@ struct src {
struct iomuxc { -#ifdef CONFIG_MX6SX +#if (defined(CONFIG_MX6SX) || defined(CONFIG_MX6UL)) u8 reserved[0x4000]; #endif u32 gpr[14]; @@ -577,7 +597,7 @@ struct cspi_regs { #define MXC_CSPICON_POL 4 /* SCLK polarity */ #define MXC_CSPICON_SSPOL 12 /* SS polarity */ #define MXC_CSPICON_CTL 20 /* inactive state of SCLK */ -#if defined(CONFIG_MX6SL) || defined(CONFIG_MX6DL) +#if defined(CONFIG_MX6SL) || defined(CONFIG_MX6DL) || defined(CONFIG_MX6UL) #define MXC_SPI_BASE_ADDRESSES \ ECSPI1_BASE_ADDR, \ ECSPI2_BASE_ADDR, \ @@ -661,7 +681,7 @@ struct fuse_bank1_regs { u32 rsvd7[3]; };
-#ifdef CONFIG_MX6SX +#if (defined(CONFIG_MX6SX) || defined(CONFIG_MX6UL)) struct fuse_bank4_regs { u32 sjc_resp_low; u32 rsvd0[3]; @@ -674,7 +694,9 @@ struct fuse_bank4_regs { u32 mac_addr2; u32 rsvd4[7]; u32 gp1; - u32 rsvd5[7]; + u32 rsvd5[3]; + u32 gp2; + u32 rsvd6[3]; }; #else struct fuse_bank4_regs {
#define ARCH_MXC
This doesn't seem like register base at all . This is cacheline size. The patch description is thus misleading. It also fails to explain this change ... probably because UL is C-A7 ?
Hi Marek,
#define ARCH_MXC
Will consider to split this part into a single patch, and fix in V2.
Regards, Peng --
syscounter exists on i.MX6UL and i.MX7D, so implement the driver in imx-common. If want to use syscounter, define CONFIG_SYSCOUNTER_TIMER; if still want to use GPT timer, #define CONFIG_GPT_TIMER.
Signed-off-by: Ye.Li B37916@freescale.com Signed-off-by: Peng Fan Peng.Fan@freescale.com --- arch/arm/imx-common/Makefile | 7 +- arch/arm/imx-common/syscounter.c | 124 +++++++++++++++++++++++++++ arch/arm/imx-common/timer.c | 8 +- arch/arm/include/asm/imx-common/syscounter.h | 29 +++++++ 4 files changed, 164 insertions(+), 4 deletions(-) create mode 100644 arch/arm/imx-common/syscounter.c create mode 100644 arch/arm/include/asm/imx-common/syscounter.h
diff --git a/arch/arm/imx-common/Makefile b/arch/arm/imx-common/Makefile index b9f1ca4..947c452 100644 --- a/arch/arm/imx-common/Makefile +++ b/arch/arm/imx-common/Makefile @@ -10,8 +10,11 @@ ifeq ($(SOC),$(filter $(SOC),mx25 mx35 mx5 mx6 vf610)) obj-y = iomux-v3.o endif +ifeq ($(SOC),$(filter $(SOC),mx5)) +obj-y += timer.o +endif ifeq ($(SOC),$(filter $(SOC),mx5 mx6)) -obj-y += timer.o cpu.o speed.o +obj-y += cpu.o speed.o obj-$(CONFIG_SYS_I2C_MXC) += i2c-mxv7.o endif ifeq ($(SOC),$(filter $(SOC),mx6 mxs)) @@ -21,6 +24,8 @@ endif ifeq ($(SOC),$(filter $(SOC),mx6)) obj-$(CONFIG_CMD_SATA) += sata.o obj-$(CONFIG_IMX_VIDEO_SKIP) += video.o +obj-$(CONFIG_GPT_TIMER) += timer.o +obj-$(CONFIG_SYSCOUNTER_TIMER) += syscounter.o endif ifeq ($(SOC),$(filter $(SOC),vf610)) obj-y += ddrmc-vf610.o diff --git a/arch/arm/imx-common/syscounter.c b/arch/arm/imx-common/syscounter.c new file mode 100644 index 0000000..1bdf281 --- /dev/null +++ b/arch/arm/imx-common/syscounter.c @@ -0,0 +1,124 @@ +/* + * Copyright (C) 2014-2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <div64.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/sys_proto.h> +#include <asm/imx-common/syscounter.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * This function is intended for SHORT delays only. + * It will overflow at around 10 seconds @ 400MHz, + * or 20 seconds @ 200MHz. + */ +unsigned long usec2ticks(unsigned long usec) +{ + ulong ticks; + + if (usec < 1000) + ticks = ((usec * (get_tbclk()/1000)) + 500) / 1000; + else + ticks = ((usec / 10) * (get_tbclk() / 100000)); + + return ticks; +} + +static inline unsigned long long tick_to_time(unsigned long long tick) +{ + unsigned long freq; + + asm volatile("mrc p15, 0, %0, c14, c0, 0" : "=r" (freq)); + + tick *= CONFIG_SYS_HZ; + do_div(tick, freq); + + return tick; +} + +static inline unsigned long long us_to_tick(unsigned long long usec) +{ + unsigned long freq; + + asm volatile("mrc p15, 0, %0, c14, c0, 0" : "=r" (freq)); + + usec = usec * freq + 999999; + do_div(usec, 1000000); + + return usec; +} + +int timer_init(void) +{ + struct sctr_regs *sctr = (struct sctr_regs *)SCTR_BASE_ADDR; + unsigned long val, freq; + + freq = CONFIG_SC_TIMER_CLK; + asm("mcr p15, 0, %0, c14, c0, 0" : : "r" (freq)); + + writel(freq, &sctr->cntfid0); + + /* Enable system counter */ + val = readl(&sctr->cntcr); + val &= ~(SC_CNTCR_FREQ0 | SC_CNTCR_FREQ1); + val |= SC_CNTCR_FREQ0 | SC_CNTCR_ENABLE | SC_CNTCR_HDBG; + writel(val, &sctr->cntcr); + + gd->arch.tbl = 0; + gd->arch.tbu = 0; + + return 0; +} + +unsigned long long get_ticks(void) +{ + unsigned long long now; + + asm("mrrc p15, 0, %Q0, %R0, c14" : "=r" (now)); + + gd->arch.tbl = (unsigned long)(now & 0xffffffff); + gd->arch.tbu = (unsigned long)(now >> 32); + + return now; +} + +ulong get_timer_masked(void) +{ + return tick_to_time(get_ticks()); +} + +ulong get_timer(ulong base) +{ + return get_timer_masked() - base; +} + +void __udelay(unsigned long usec) +{ + unsigned long long tmp; + ulong tmo; + + tmo = us_to_tick(usec); + tmp = get_ticks() + tmo; /* get current timestamp */ + + while (get_ticks() < tmp) /* loop till event */ + /*NOP*/; +} + +/* + * This function is derived from PowerPC code (timebase clock frequency). + * On ARM it returns the number of timer ticks per second. + */ +ulong get_tbclk(void) +{ + unsigned long freq; + + asm volatile("mrc p15, 0, %0, c14, c0, 0" : "=r" (freq)); + + return freq; +} diff --git a/arch/arm/imx-common/timer.c b/arch/arm/imx-common/timer.c index c12556a..7262107 100644 --- a/arch/arm/imx-common/timer.c +++ b/arch/arm/imx-common/timer.c @@ -45,7 +45,8 @@ static inline int gpt_has_clk_source_osc(void) #if defined(CONFIG_MX6) if (((is_cpu_type(MXC_CPU_MX6Q) || is_cpu_type(MXC_CPU_MX6D)) && (soc_rev() > CHIP_REV_1_0)) || is_cpu_type(MXC_CPU_MX6DL) || - is_cpu_type(MXC_CPU_MX6SOLO) || is_cpu_type(MXC_CPU_MX6SX)) + is_cpu_type(MXC_CPU_MX6SOLO) || is_cpu_type(MXC_CPU_MX6SX) || + is_cpu_type(MXC_CPU_MX6UL)) return 1;
return 0; @@ -103,10 +104,11 @@ int timer_init(void) if (gpt_has_clk_source_osc()) { i |= GPTCR_CLKSOURCE_OSC | GPTCR_TEN;
- /* For DL/S, SX, set 24Mhz OSC Enable bit and prescaler */ + /* For DL/S, SX, UL, set 24Mhz OSC Enable bit and prescaler */ if (is_cpu_type(MXC_CPU_MX6DL) || is_cpu_type(MXC_CPU_MX6SOLO) || - is_cpu_type(MXC_CPU_MX6SX)) { + is_cpu_type(MXC_CPU_MX6SX)|| + is_cpu_type(MXC_CPU_MX6UL)) { i |= GPTCR_24MEN;
/* Produce 3Mhz clock */ diff --git a/arch/arm/include/asm/imx-common/syscounter.h b/arch/arm/include/asm/imx-common/syscounter.h new file mode 100644 index 0000000..ddb412e --- /dev/null +++ b/arch/arm/include/asm/imx-common/syscounter.h @@ -0,0 +1,29 @@ +/* + * Copyright (C) 2014-2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _ASM_ARCH_SYSTEM_COUNTER_H +#define _ASM_ARCH_SYSTEM_COUNTER_H + +/* System Counter */ +struct sctr_regs { + u32 cntcr; + u32 cntsr; + u32 cntcv1; + u32 cntcv2; + u32 resv1[4]; + u32 cntfid0; + u32 cntfid1; + u32 cntfid2; + u32 resv2[1001]; + u32 counterid[1]; +}; + +#define SC_CNTCR_ENABLE (1 << 0) +#define SC_CNTCR_HDBG (1 << 1) +#define SC_CNTCR_FREQ0 (1 << 8) +#define SC_CNTCR_FREQ1 (1 << 9) + +#endif
Can this be converted to generic timer framework (see lib/time.c) ? I think it can , which would trim down this body of code considerably.
Hi Marek,
Will try lib/time.c. Thanks for suggestion.
Regards, Peng. --
Since i.MX6UL use A7 core, but not A9 core, we do not need the erratas for i.MX6UL. Also use syscounter for i.MX6UL.
Signed-off-by: Ye.Li B37916@freescale.com Signed-off-by: Peng Fan Peng.Fan@freescale.com --- include/configs/mx6_common.h | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/include/configs/mx6_common.h b/include/configs/mx6_common.h index b37477a..6808674 100644 --- a/include/configs/mx6_common.h +++ b/include/configs/mx6_common.h @@ -17,11 +17,11 @@ #ifndef __MX6_COMMON_H #define __MX6_COMMON_H
+#ifndef CONFIG_MX6UL #define CONFIG_ARM_ERRATA_743622 #define CONFIG_ARM_ERRATA_751472 #define CONFIG_ARM_ERRATA_794072 #define CONFIG_ARM_ERRATA_761320 -#define CONFIG_BOARD_POSTCLK_INIT
#ifndef CONFIG_SYS_L2CACHE_OFF #define CONFIG_SYS_L2_PL310 @@ -29,6 +29,12 @@ #endif
#define CONFIG_MP +#define CONFIG_GPT_TIMER +#else +#define CONFIG_SYSCOUNTER_TIMER +#define CONFIG_SC_TIMER_CLK 8000000 /* 8MHz */ +#endif +#define CONFIG_BOARD_POSTCLK_INIT #define CONFIG_MXC_GPT_HCLK
#define CONFIG_SYS_NO_FLASH
Add enet, uart, i2c, ipg clock support.
Correct get_periph_clk, should account for MXC_CCM_CBCDR_PERIPH_CLK2_PODF_MASK.
Refactor get_mmdc_ch0_clk to make all i.MX6 share one function, but not 'ifdef'
Use CONFIG_FSL_QSPI for enable_qspi_clk, but not #ifdef CONFIG_MX6SX. Use CONFIG_PCIE_IMX for pcie clock settings, use CONFIG_CMD_SATA for sata clock settings. In this way, we not need "#if defined(CONFIG_MX6Q) || defined....", only need one CONFIG_PCIE_IMX in header file.
Signed-off-by: Ye.Li B37916@freescale.com Signed-off-by: Peng Fan Peng.Fan@freescale.com --- arch/arm/cpu/armv7/mx6/clock.c | 151 +++++++++++++++++++------------ arch/arm/include/asm/arch-mx6/crm_regs.h | 79 ++++++++++------ 2 files changed, 143 insertions(+), 87 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/clock.c b/arch/arm/cpu/armv7/mx6/clock.c index 3e94472..9cf4eec 100644 --- a/arch/arm/cpu/armv7/mx6/clock.c +++ b/arch/arm/cpu/armv7/mx6/clock.c @@ -81,19 +81,32 @@ void enable_usboh3_clk(unsigned char enable) #if defined(CONFIG_FEC_MXC) && !defined(CONFIG_MX6SX) void enable_enet_clk(unsigned char enable) { - u32 mask = MXC_CCM_CCGR1_ENET_CLK_ENABLE_MASK; + u32 mask, *addr; + + if (is_cpu_type(MXC_CPU_MX6UL)) { + mask = MXC_CCM_CCGR3_ENET_MASK; + addr = &imx_ccm->CCGR3; + } else { + mask = MXC_CCM_CCGR1_ENET_MASK; + addr = &imx_ccm->CCGR1; + }
if (enable) - setbits_le32(&imx_ccm->CCGR1, mask); + setbits_le32(addr, mask); else - clrbits_le32(&imx_ccm->CCGR1, mask); + clrbits_le32(addr, mask); } #endif
#ifdef CONFIG_MXC_UART void enable_uart_clk(unsigned char enable) { - u32 mask = MXC_CCM_CCGR5_UART_MASK | MXC_CCM_CCGR5_UART_SERIAL_MASK; + u32 mask; + + if (is_cpu_type(MXC_CPU_MX6UL)) + mask = MXC_CCM_CCGR5_UART_MASK; + else + mask = MXC_CCM_CCGR5_UART_MASK | MXC_CCM_CCGR5_UART_SERIAL_MASK;
if (enable) setbits_le32(&imx_ccm->CCGR5, mask); @@ -141,7 +154,7 @@ int enable_i2c_clk(unsigned char enable, unsigned i2c_num) reg &= ~mask; __raw_writel(reg, &imx_ccm->CCGR2); } else { - if (is_cpu_type(MXC_CPU_MX6SX)) { + if (is_cpu_type(MXC_CPU_MX6SX) || is_cpu_type(MXC_CPU_MX6UL)) { mask = MXC_CCM_CCGR6_I2C4_MASK; addr = &imx_ccm->CCGR6; } else { @@ -214,9 +227,11 @@ static u32 mxc_get_pll_pfd(enum pll_clocks pll, int pfd_num)
switch (pll) { case PLL_BUS: - if (pfd_num == 3) { - /* No PFD3 on PPL2 */ - return 0; + if (!is_cpu_type(MXC_CPU_MX6UL)) { + if (pfd_num == 3) { + /* No PFD3 on PPL2 */ + return 0; + } } div = __raw_readl(&imx_ccm->analog_pfd_528); freq = (u64)decode_pll(PLL_BUS, MXC_HCLK); @@ -248,10 +263,12 @@ static u32 get_mcu_main_clk(void)
u32 get_periph_clk(void) { - u32 reg, freq = 0; + u32 reg, div = 0, freq = 0;
reg = __raw_readl(&imx_ccm->cbcdr); if (reg & MXC_CCM_CBCDR_PERIPH_CLK_SEL) { + div = (reg & MXC_CCM_CBCDR_PERIPH_CLK2_PODF_MASK) >> + MXC_CCM_CBCDR_PERIPH_CLK2_PODF_OFFSET; reg = __raw_readl(&imx_ccm->cbcmr); reg &= MXC_CCM_CBCMR_PERIPH_CLK2_SEL_MASK; reg >>= MXC_CCM_CBCMR_PERIPH_CLK2_SEL_OFFSET; @@ -291,7 +308,7 @@ u32 get_periph_clk(void) } }
- return freq; + return freq / (div + 1); }
static u32 get_ipg_clk(void) @@ -311,7 +328,7 @@ static u32 get_ipg_per_clk(void)
reg = __raw_readl(&imx_ccm->cscmr1); if (is_cpu_type(MXC_CPU_MX6SL) || is_cpu_type(MXC_CPU_MX6SX) || - is_mx6dqp()) { + is_mx6dqp() || is_cpu_type(MXC_CPU_MX6UL)) { if (reg & MXC_CCM_CSCMR1_PER_CLK_SEL_MASK) return MXC_HCLK; /* OSC 24Mhz */ } @@ -328,7 +345,7 @@ static u32 get_uart_clk(void) reg = __raw_readl(&imx_ccm->cscdr1);
if (is_cpu_type(MXC_CPU_MX6SL) || is_cpu_type(MXC_CPU_MX6SX) || - is_mx6dqp()) { + is_mx6dqp() || is_cpu_type(MXC_CPU_MX6UL)) { if (reg & MXC_CCM_CSCDR1_UART_CLK_SEL) freq = MXC_HCLK; } @@ -347,7 +364,8 @@ static u32 get_cspi_clk(void) cspi_podf = (reg & MXC_CCM_CSCDR2_ECSPI_CLK_PODF_MASK) >> MXC_CCM_CSCDR2_ECSPI_CLK_PODF_OFFSET;
- if (is_mx6dqp()) { + if (is_mx6dqp() || is_cpu_type(MXC_CPU_MX6SL) || + is_cpu_type(MXC_CPU_MX6SX) || is_cpu_type(MXC_CPU_MX6UL)) { if (reg & MXC_CCM_CSCDR2_ECSPI_CLK_SEL_MASK) return MXC_HCLK / (cspi_podf + 1); } @@ -402,47 +420,60 @@ static u32 get_emi_slow_clk(void) return root_freq / (emi_slow_podf + 1); }
-#if (defined(CONFIG_MX6SL) || defined(CONFIG_MX6SX)) static u32 get_mmdc_ch0_clk(void) { u32 cbcmr = __raw_readl(&imx_ccm->cbcmr); u32 cbcdr = __raw_readl(&imx_ccm->cbcdr); - u32 freq, podf;
- podf = (cbcdr & MXC_CCM_CBCDR_MMDC_CH1_PODF_MASK) \ - >> MXC_CCM_CBCDR_MMDC_CH1_PODF_OFFSET; - - switch ((cbcmr & MXC_CCM_CBCMR_PRE_PERIPH2_CLK_SEL_MASK) >> - MXC_CCM_CBCMR_PRE_PERIPH2_CLK_SEL_OFFSET) { - case 0: - freq = decode_pll(PLL_BUS, MXC_HCLK); - break; - case 1: - freq = mxc_get_pll_pfd(PLL_BUS, 2); - break; - case 2: - freq = mxc_get_pll_pfd(PLL_BUS, 0); - break; - case 3: - /* static / 2 divider */ - freq = mxc_get_pll_pfd(PLL_BUS, 2) / 2; + u32 freq, podf, per2_clk2_podf; + + if (is_cpu_type(MXC_CPU_MX6SX) || is_cpu_type(MXC_CPU_MX6UL) || + is_cpu_type(MXC_CPU_MX6SL)) { + podf = (cbcdr & MXC_CCM_CBCDR_MMDC_CH1_PODF_MASK) >> + MXC_CCM_CBCDR_MMDC_CH1_PODF_OFFSET; + if (cbcdr & MXC_CCM_CBCDR_PERIPH2_CLK_SEL) { + per2_clk2_podf = (cbcdr & MXC_CCM_CBCDR_PERIPH2_CLK2_PODF_MASK) >> + MXC_CCM_CBCDR_PERIPH2_CLK2_PODF_OFFSET; + if (is_cpu_type(MXC_CPU_MX6SL)) { + if (cbcmr & MXC_CCM_CBCMR_PERIPH2_CLK2_SEL) + freq = MXC_HCLK; + else + freq = decode_pll(PLL_USBOTG, MXC_HCLK); + } else { + if (cbcmr & MXC_CCM_CBCMR_PERIPH2_CLK2_SEL) + freq = decode_pll(PLL_BUS, MXC_HCLK); + else + freq = decode_pll(PLL_USBOTG, MXC_HCLK); + } + } else { + per2_clk2_podf = 0; + switch ((cbcmr & + MXC_CCM_CBCMR_PRE_PERIPH2_CLK_SEL_MASK) >> + MXC_CCM_CBCMR_PRE_PERIPH2_CLK_SEL_OFFSET) { + case 0: + freq = decode_pll(PLL_BUS, MXC_HCLK); + break; + case 1: + freq = mxc_get_pll_pfd(PLL_BUS, 2); + break; + case 2: + freq = mxc_get_pll_pfd(PLL_BUS, 0); + break; + case 3: + /* static / 2 divider */ + freq = mxc_get_pll_pfd(PLL_BUS, 2) / 2; + break; + } + } + return freq / (podf + 1) / (per2_clk2_podf + 1); + } else { + podf = (cbcdr & MXC_CCM_CBCDR_MMDC_CH0_PODF_MASK) >> + MXC_CCM_CBCDR_MMDC_CH0_PODF_OFFSET; + return get_periph_clk() / (podf + 1); } - - return freq / (podf + 1); - } -#else -static u32 get_mmdc_ch0_clk(void) -{ - u32 cbcdr = __raw_readl(&imx_ccm->cbcdr); - u32 mmdc_ch0_podf = (cbcdr & MXC_CCM_CBCDR_MMDC_CH0_PODF_MASK) >> - MXC_CCM_CBCDR_MMDC_CH0_PODF_OFFSET;
- return get_periph_clk() / (mmdc_ch0_podf + 1); -} -#endif - -#ifdef CONFIG_MX6SX +#ifdef CONFIG_FSL_QSPI /* qspi_num can be from 0 - 1 */ void enable_qspi_clk(int qspi_num) { @@ -603,6 +634,7 @@ u32 imx_get_fecclk(void) return mxc_get_clock(MXC_IPG_CLK); }
+#if defined(CONFIG_CMD_SATA) || defined(CONFIG_PCIE_IMX) static int enable_enet_pll(uint32_t en) { struct mxc_ccm_reg *const imx_ccm @@ -627,8 +659,9 @@ static int enable_enet_pll(uint32_t en) writel(reg, &imx_ccm->analog_pll_enet); return 0; } +#endif
-#ifndef CONFIG_MX6SX +#ifdef CONFIG_CMD_SATA static void ungate_sata_clock(void) { struct mxc_ccm_reg *const imx_ccm = @@ -637,18 +670,7 @@ static void ungate_sata_clock(void) /* Enable SATA clock. */ setbits_le32(&imx_ccm->CCGR5, MXC_CCM_CCGR5_SATA_MASK); } -#endif - -static void ungate_pcie_clock(void) -{ - struct mxc_ccm_reg *const imx_ccm = - (struct mxc_ccm_reg *)CCM_BASE_ADDR;
- /* Enable PCIe clock. */ - setbits_le32(&imx_ccm->CCGR4, MXC_CCM_CCGR4_PCIE_MASK); -} - -#ifndef CONFIG_MX6SX int enable_sata_clock(void) { ungate_sata_clock(); @@ -664,6 +686,16 @@ void disable_sata_clock(void) } #endif
+#ifdef CONFIG_PCIE_IMX +static void ungate_pcie_clock(void) +{ + struct mxc_ccm_reg *const imx_ccm = + (struct mxc_ccm_reg *)CCM_BASE_ADDR; + + /* Enable PCIe clock. */ + setbits_le32(&imx_ccm->CCGR4, MXC_CCM_CCGR4_PCIE_MASK); +} + int enable_pcie_clock(void) { struct anatop_regs *anatop_regs = @@ -703,7 +735,7 @@ int enable_pcie_clock(void) clrbits_le32(&ccm_regs->cbcmr, MXC_CCM_CBCMR_PCIE_AXI_CLK_SEL);
/* Party time! Ungate the clock to the PCIe. */ -#ifndef CONFIG_MX6SX +#ifdef CONFIG_CMD_SATA ungate_sata_clock(); #endif ungate_pcie_clock(); @@ -711,6 +743,7 @@ int enable_pcie_clock(void) return enable_enet_pll(BM_ANADIG_PLL_ENET_ENABLE_SATA | BM_ANADIG_PLL_ENET_ENABLE_PCIE); } +#endif
#ifdef CONFIG_SECURE_BOOT void hab_caam_clock_enable(unsigned char enable) diff --git a/arch/arm/include/asm/arch-mx6/crm_regs.h b/arch/arm/include/asm/arch-mx6/crm_regs.h index 7d9fe73..61681e6 100644 --- a/arch/arm/include/asm/arch-mx6/crm_regs.h +++ b/arch/arm/include/asm/arch-mx6/crm_regs.h @@ -110,6 +110,7 @@ struct mxc_ccm_reg { #define MXC_CCM_CCR_RBC_EN (1 << 27) #define MXC_CCM_CCR_REG_BYPASS_CNT_MASK (0x3F << 21) #define MXC_CCM_CCR_REG_BYPASS_CNT_OFFSET 21 +/* CCR_WB does not exist on i.MX6SX/UL */ #define MXC_CCM_CCR_WB_COUNT_MASK 0x7 #define MXC_CCM_CCR_WB_COUNT_OFFSET (1 << 16) #define MXC_CCM_CCR_COSC_EN (1 << 12) @@ -150,12 +151,11 @@ struct mxc_ccm_reg { /* Define the bits in register CBCDR */ #define MXC_CCM_CBCDR_PERIPH_CLK2_PODF_MASK (0x7 << 27) #define MXC_CCM_CBCDR_PERIPH_CLK2_PODF_OFFSET 27 -#define MXC_CCM_CBCDR_PERIPH2_CLK2_SEL (1 << 26) +#define MXC_CCM_CBCDR_PERIPH2_CLK_SEL (1 << 26) #define MXC_CCM_CBCDR_PERIPH_CLK_SEL (1 << 25) -#ifndef CONFIG_MX6SX +/* MMDC_CH0 not exists on i.MX6SX */ #define MXC_CCM_CBCDR_MMDC_CH0_PODF_MASK (0x7 << 19) #define MXC_CCM_CBCDR_MMDC_CH0_PODF_OFFSET 19 -#endif #define MXC_CCM_CBCDR_AXI_PODF_MASK (0x7 << 16) #define MXC_CCM_CBCDR_AXI_PODF_OFFSET 16 #define MXC_CCM_CBCDR_AHB_PODF_MASK (0x7 << 10) @@ -178,7 +178,7 @@ struct mxc_ccm_reg { #define MXC_CCM_CBCMR_GPU2D_CORE_PODF_OFFSET 23 #define MXC_CCM_CBCMR_PRE_PERIPH2_CLK_SEL_MASK (0x3 << 21) #define MXC_CCM_CBCMR_PRE_PERIPH2_CLK_SEL_OFFSET 21 -#define MXC_CCM_CBCMR_PRE_PERIPH2_CLK2_SEL (1 << 20) +#define MXC_CCM_CBCMR_PERIPH2_CLK2_SEL (1 << 20) #define MXC_CCM_CBCMR_PRE_PERIPH_CLK_SEL_MASK (0x3 << 18) #define MXC_CCM_CBCMR_PRE_PERIPH_CLK_SEL_OFFSET 18 #ifndef CONFIG_MX6SX @@ -203,18 +203,19 @@ struct mxc_ccm_reg { /* Define the bits in register CSCMR1 */ #define MXC_CCM_CSCMR1_ACLK_EMI_SLOW_MASK (0x3 << 29) #define MXC_CCM_CSCMR1_ACLK_EMI_SLOW_OFFSET 29 -#ifdef CONFIG_MX6SX +/* QSPI1 exist on i.MX6SX/UL */ #define MXC_CCM_CSCMR1_QSPI1_PODF_MASK (0x7 << 26) #define MXC_CCM_CSCMR1_QSPI1_PODF_OFFSET 26 -#else #define MXC_CCM_CSCMR1_ACLK_EMI_MASK (0x3 << 27) #define MXC_CCM_CSCMR1_ACLK_EMI_OFFSET 27 -#endif #define MXC_CCM_CSCMR1_ACLK_EMI_SLOW_PODF_MASK (0x7 << 23) #define MXC_CCM_CSCMR1_ACLK_EMI_SLOW_PODF_OFFSET 23 /* ACLK_EMI_PODF is LCFIF2_PODF on MX6SX */ #define MXC_CCM_CSCMR1_ACLK_EMI_PODF_MASK (0x7 << 20) #define MXC_CCM_CSCMR1_ACLK_EMI_PODF_OFFSET 20 +/* CSCMR1_GPMI/BCH exist on i.MX6UL */ +#define MXC_CCM_CSCMR1_GPMI_CLK_SEL (1 << 19) +#define MXC_CCM_CSCMR1_BCH_CLK_SEL (1 << 18) #define MXC_CCM_CSCMR1_USDHC4_CLK_SEL (1 << 19) #define MXC_CCM_CSCMR1_USDHC3_CLK_SEL (1 << 18) #define MXC_CCM_CSCMR1_USDHC2_CLK_SEL (1 << 17) @@ -225,10 +226,9 @@ struct mxc_ccm_reg { #define MXC_CCM_CSCMR1_SSI2_CLK_SEL_OFFSET 12 #define MXC_CCM_CSCMR1_SSI1_CLK_SEL_MASK (0x3 << 10) #define MXC_CCM_CSCMR1_SSI1_CLK_SEL_OFFSET 10 -#ifdef CONFIG_MX6SX +/* QSPI1 exist on i.MX6SX/UL */ #define MXC_CCM_CSCMR1_QSPI1_CLK_SEL_MASK (0x7 << 7) #define MXC_CCM_CSCMR1_QSPI1_CLK_SEL_OFFSET 7 -#endif /* CSCMR1_PER_CLK exists on i.MX6SX/SL/QP */ #define MXC_CCM_CSCMR1_PER_CLK_SEL_MASK (1 << 6) #define MXC_CCM_CSCMR1_PER_CLK_SEL_OFFSET 6 @@ -256,6 +256,12 @@ struct mxc_ccm_reg { #define MXC_CCM_CSCDR1_VPU_AXI_PODF_MASK (0x7 << 25) #define MXC_CCM_CSCDR1_VPU_AXI_PODF_OFFSET 25 #endif +/* CSCDR1_GPMI/BCH exist on i.MX6UL */ +#define MXC_CCM_CSCDR1_GPMI_PODF_MASK (0x7 << 22) +#define MXC_CCM_CSCDR1_GPMI_PODF_OFFSET 22 +#define MXC_CCM_CSCDR1_BCH_PODF_MASK (0x7 << 19) +#define MXC_CCM_CSCDR1_BCH_PODF_OFFSET 19 + #define MXC_CCM_CSCDR1_USDHC4_PODF_MASK (0x7 << 22) #define MXC_CCM_CSCDR1_USDHC4_PODF_OFFSET 22 #define MXC_CCM_CSCDR1_USDHC3_PODF_MASK (0x7 << 19) @@ -290,7 +296,7 @@ struct mxc_ccm_reg { #define MXC_CCM_CS1CDR_SSI1_CLK_PODF_OFFSET 0
/* Define the bits in register CS2CDR */ -#ifdef CONFIG_MX6SX +/* QSPI2 on i.MX6SX */ #define MXC_CCM_CS2CDR_QSPI2_CLK_PODF_MASK (0x3F << 21) #define MXC_CCM_CS2CDR_QSPI2_CLK_PODF_OFFSET 21 #define MXC_CCM_CS2CDR_QSPI2_CLK_PODF(v) (((v) & 0x3f) << 21) @@ -300,7 +306,7 @@ struct mxc_ccm_reg { #define MXC_CCM_CS2CDR_QSPI2_CLK_SEL_MASK (0x7 << 15) #define MXC_CCM_CS2CDR_QSPI2_CLK_SEL_OFFSET 15 #define MXC_CCM_CS2CDR_QSPI2_CLK_SEL(v) (((v) & 0x7) << 15) -#else + #define MXC_CCM_CS2CDR_ENFC_CLK_PODF_MASK (0x3F << 21) #define MXC_CCM_CS2CDR_ENFC_CLK_PODF_OFFSET 21 #define MXC_CCM_CS2CDR_ENFC_CLK_PODF(v) (((v) & 0x3f) << 21) @@ -309,13 +315,12 @@ struct mxc_ccm_reg { #define MXC_CCM_CS2CDR_ENFC_CLK_PRED(v) (((v) & 0x7) << 18)
#define MXC_CCM_CS2CDR_ENFC_CLK_SEL_MASK \ - (is_mx6dqp() ? (0x7 << 15) : (0x3 << 16)) + ((is_mx6dqp() || is_cpu_type(MXC_CPU_MX6UL)) ? (0x7 << 15) : (0x3 << 16)) #define MXC_CCM_CS2CDR_ENFC_CLK_SEL_OFFSET \ - (is_mx6dqp() ? 15 : 16) + ((is_mx6dqp() || is_cpu_type(MXC_CPU_MX6UL)) ? 15 : 16) #define MXC_CCM_CS2CDR_ENFC_CLK_SEL(v) \ - (is_mx6dqp() ? (((v) & 0x7) << 15) : (((v) & 0x3) << 16)) + ((is_mx6dqp() || is_cpu_type(MXC_CPU_MX6UL)) ? (((v) & 0x7) << 15) : (((v) & 0x3) << 16))
-#endif #define MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_MASK (0x7 << 12) #define MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_OFFSET 12 #define MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_MASK (0x7 << 9) @@ -543,10 +548,9 @@ struct mxc_ccm_reg { #define MXC_CCM_CCGR1_ECSPI4S_MASK (3 << MXC_CCM_CCGR1_ECSPI4S_OFFSET) #define MXC_CCM_CCGR1_ECSPI5S_OFFSET 8 #define MXC_CCM_CCGR1_ECSPI5S_MASK (3 << MXC_CCM_CCGR1_ECSPI5S_OFFSET) -#ifndef CONFIG_MX6SX -#define MXC_CCM_CCGR1_ENET_CLK_ENABLE_OFFSET 10 -#define MXC_CCM_CCGR1_ENET_CLK_ENABLE_MASK (3 << MXC_CCM_CCGR1_ENET_CLK_ENABLE_OFFSET) -#endif +/* CCGR1_ENET does not exist on i.MX6SX/UL */ +#define MXC_CCM_CCGR1_ENET_OFFSET 10 +#define MXC_CCM_CCGR1_ENET_MASK (3 << MXC_CCM_CCGR1_ENET_OFFSET) #define MXC_CCM_CCGR1_EPIT1S_OFFSET 12 #define MXC_CCM_CCGR1_EPIT1S_MASK (3 << MXC_CCM_CCGR1_EPIT1S_OFFSET) #define MXC_CCM_CCGR1_EPIT2S_OFFSET 14 @@ -617,21 +621,21 @@ struct mxc_ccm_reg { #define MXC_CCM_CCGR2_IPSYNC_VDOA_IPG_MASTER_CLK_MASK (3 << MXC_CCM_CCGR2_IPSYNC_VDOA_IPG_MASTER_CLK_OFFSET) #endif
-#ifdef CONFIG_MX6SX +/* Exist on i.MX6SX */ #define MXC_CCM_CCGR3_M4_OFFSET 2 #define MXC_CCM_CCGR3_M4_MASK (3 << MXC_CCM_CCGR3_M4_OFFSET) #define MXC_CCM_CCGR3_ENET_OFFSET 4 #define MXC_CCM_CCGR3_ENET_MASK (3 << MXC_CCM_CCGR3_ENET_OFFSET) #define MXC_CCM_CCGR3_QSPI_OFFSET 14 #define MXC_CCM_CCGR3_QSPI_MASK (3 << MXC_CCM_CCGR3_QSPI_OFFSET) -#else + #define MXC_CCM_CCGR3_IPU1_IPU_OFFSET 0 #define MXC_CCM_CCGR3_IPU1_IPU_MASK (3 << MXC_CCM_CCGR3_IPU1_IPU_OFFSET) #define MXC_CCM_CCGR3_IPU1_IPU_DI0_OFFSET 2 #define MXC_CCM_CCGR3_IPU1_IPU_DI0_MASK (3 << MXC_CCM_CCGR3_IPU1_IPU_DI0_OFFSET) #define MXC_CCM_CCGR3_IPU1_IPU_DI1_OFFSET 4 #define MXC_CCM_CCGR3_IPU1_IPU_DI1_MASK (3 << MXC_CCM_CCGR3_IPU1_IPU_DI1_OFFSET) -#endif + #define MXC_CCM_CCGR3_IPU2_IPU_OFFSET 6 #define MXC_CCM_CCGR3_IPU2_IPU_MASK (3 << MXC_CCM_CCGR3_IPU2_IPU_OFFSET) #define MXC_CCM_CCGR3_IPU2_IPU_DI0_OFFSET 8 @@ -640,15 +644,22 @@ struct mxc_ccm_reg { #define MXC_CCM_CCGR3_IPU2_IPU_DI1_MASK (3 << MXC_CCM_CCGR3_IPU2_IPU_DI1_OFFSET) #define MXC_CCM_CCGR3_LDB_DI0_OFFSET 12 #define MXC_CCM_CCGR3_LDB_DI0_MASK (3 << MXC_CCM_CCGR3_LDB_DI0_OFFSET) -#ifdef CONFIG_MX6SX + +/* QSPI1 exists on i.MX6SX/UL */ #define MXC_CCM_CCGR3_QSPI1_OFFSET 14 #define MXC_CCM_CCGR3_QSPI1_MASK (3 << MXC_CCM_CCGR3_QSPI1_OFFSET) -#else + #define MXC_CCM_CCGR3_LDB_DI1_OFFSET 14 #define MXC_CCM_CCGR3_LDB_DI1_MASK (3 << MXC_CCM_CCGR3_LDB_DI1_OFFSET) #define MXC_CCM_CCGR3_MIPI_CORE_CFG_OFFSET 16 #define MXC_CCM_CCGR3_MIPI_CORE_CFG_MASK (3 << MXC_CCM_CCGR3_MIPI_CORE_CFG_OFFSET) -#endif + +/* A7_CLKDIV/WDOG1 on i.MX6UL */ +#define MXC_CCM_CCGR3_WDOG1_CLK_ENABLE_OFFSET 16 +#define MXC_CCM_CCGR3_WDOG1_CLK_ENABLE_MASK (3 << MXC_CCM_CCGR3_WDOG1_CLK_ENABLE_OFFSET) +#define MXC_CCM_CCGR3_A7_CLKDIV_PATCH_OFFSET 18 +#define MXC_CCM_CCGR3_A7_CLKDIV_PATCH_MASK (3 << MXC_CCM_CCGR3_A7_CLKDIV_PATCH_OFFSET) + #define MXC_CCM_CCGR3_MLB_OFFSET 18 #define MXC_CCM_CCGR3_MLB_MASK (3 << MXC_CCM_CCGR3_MLB_OFFSET) #define MXC_CCM_CCGR3_MMDC_CORE_ACLK_FAST_CORE_P0_OFFSET 20 @@ -661,8 +672,16 @@ struct mxc_ccm_reg { #define MXC_CCM_CCGR3_MMDC_CORE_IPG_CLK_P0_MASK (3 << MXC_CCM_CCGR3_MMDC_CORE_IPG_CLK_P0_OFFSET) #define MXC_CCM_CCGR3_MMDC_CORE_IPG_CLK_P1_OFFSET 26 #define MXC_CCM_CCGR3_MMDC_CORE_IPG_CLK_P1_MASK (3 << MXC_CCM_CCGR3_MMDC_CORE_IPG_CLK_P1_OFFSET) +/* AXI on i.MX6UL */ +#define MXC_CCM_CCGR3_AXI_CLK_OFFSET 28 +#define MXC_CCM_CCGR3_AXI_CLK_MASK (3 << MXC_CCM_CCGR3_AXI_CLK_OFFSET) #define MXC_CCM_CCGR3_OCRAM_OFFSET 28 #define MXC_CCM_CCGR3_OCRAM_MASK (3 << MXC_CCM_CCGR3_OCRAM_OFFSET) + +/* GPIO4 on i.MX6UL */ +#define MXC_CCM_CCGR3_GPIO4_CLK_OFFSET 30 +#define MXC_CCM_CCGR3_GPIO4_CLK_MASK (3 << MXC_CCM_CCGR3_GPIO4_CLK_OFFSET) + #ifndef CONFIG_MX6SX #define MXC_CCM_CCGR3_OPENVGAXICLK_OFFSET 30 #define MXC_CCM_CCGR3_OPENVGAXICLK_MASK (3 << MXC_CCM_CCGR3_OPENVGAXICLK_OFFSET) @@ -670,13 +689,11 @@ struct mxc_ccm_reg {
#define MXC_CCM_CCGR4_PCIE_OFFSET 0 #define MXC_CCM_CCGR4_PCIE_MASK (3 << MXC_CCM_CCGR4_PCIE_OFFSET) -#ifdef CONFIG_MX6SX +/* QSPI2 on i.MX6SX */ #define MXC_CCM_CCGR4_QSPI2_ENFC_OFFSET 10 #define MXC_CCM_CCGR4_QSPI2_ENFC_MASK (3 << MXC_CCM_CCGR4_QSPI2_ENFC_OFFSET) -#else #define MXC_CCM_CCGR4_PL301_MX6QFAST1_S133_OFFSET 8 #define MXC_CCM_CCGR4_PL301_MX6QFAST1_S133_MASK (3 << MXC_CCM_CCGR4_PL301_MX6QFAST1_S133_OFFSET) -#endif #define MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_OFFSET 12 #define MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_MASK (3 << MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_OFFSET) #define MXC_CCM_CCGR4_PL301_MX6QPER2_MAINCLK_ENABLE_OFFSET 14 @@ -736,6 +753,12 @@ struct mxc_ccm_reg { #define MXC_CCM_CCGR6_USDHC1_MASK (3 << MXC_CCM_CCGR6_USDHC1_OFFSET) #define MXC_CCM_CCGR6_USDHC2_OFFSET 4 #define MXC_CCM_CCGR6_USDHC2_MASK (3 << MXC_CCM_CCGR6_USDHC2_OFFSET) +/* GPMI/BCH on i.MX6UL */ +#define MXC_CCM_CCGR6_BCH_OFFSET 6 +#define MXC_CCM_CCGR6_BCH_MASK (3 << MXC_CCM_CCGR6_BCH_OFFSET) +#define MXC_CCM_CCGR6_GPMI_OFFSET 8 +#define MXC_CCM_CCGR6_GPMI_MASK (3 << MXC_CCM_CCGR6_GPMI_OFFSET) + #define MXC_CCM_CCGR6_USDHC3_OFFSET 6 #define MXC_CCM_CCGR6_USDHC3_MASK (3 << MXC_CCM_CCGR6_USDHC3_OFFSET) #define MXC_CCM_CCGR6_USDHC4_OFFSET 8
Add MX6UL in Kconfig, default select SYS_L2CACHE_OFF. update WDOG settings. No need to gate/ungate all PFDs for i.MX6UL.
Signed-off-by: Ye.Li B37916@freescale.com Signed-off-by: Peng Fan Peng.Fan@freescale.com --- arch/arm/cpu/armv7/mx6/Kconfig | 4 ++++ arch/arm/cpu/armv7/mx6/soc.c | 4 ++-- 2 files changed, 6 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/Kconfig b/arch/arm/cpu/armv7/mx6/Kconfig index 10908c4..fceba27 100644 --- a/arch/arm/cpu/armv7/mx6/Kconfig +++ b/arch/arm/cpu/armv7/mx6/Kconfig @@ -25,6 +25,10 @@ config MX6SL config MX6SX bool
+config MX6UL + select SYS_L2CACHE_OFF + bool + choice prompt "MX6 board select" optional diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index e80c09c..20abe3f 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -317,7 +317,7 @@ static void imx_set_wdog_powerdown(bool enable) struct wdog_regs *wdog1 = (struct wdog_regs *)WDOG1_BASE_ADDR; struct wdog_regs *wdog2 = (struct wdog_regs *)WDOG2_BASE_ADDR;
-#ifdef CONFIG_MX6SX +#if defined(CONFIG_MX6SX) || defined(CONFIG_MX6UL) struct wdog_regs *wdog3 = (struct wdog_regs *)WDOG3_BASE_ADDR; writew(enable, &wdog3->wmcr); #endif @@ -530,7 +530,7 @@ void s_init(void) u32 mask528; u32 reg, periph1, periph2;
- if (is_cpu_type(MXC_CPU_MX6SX)) + if (is_cpu_type(MXC_CPU_MX6SX) || is_cpu_type(MXC_CPU_MX6UL)) return;
/* Due to hardware limitation, on MX6Q we need to gate/ungate all PFDs
Hi Peng,
Could you tell us more about this? Why L2 cache needs to be disabled?
Regards,
Fabio Estevam
Why ?
I'd put this into separate patch, since L2 cache and watchdog are completely unrelated (and so is L2 cache and clock).
Hi, Marek and Fabio
Why ?
i.MX6UL features an Cortex-A7 core, it does not have PL310. As we know Cortex-A7 does not support L2 Cache open/close switch. When you enable D-Cache, L2 Cache default enabled. I'll add more commit msg to explain this.
Will split this patch into small patches.
Regards, Peng. --
On Friday, July 03, 2015 at 03:36:00 AM, Peng Fan wrote:
Hi, Marek and Fabio
Why ?
Thanks, now you wrote yourself a nice commit message ;-)
Thanks!
PAD_CTL_SPEED_LOW for i.MX6SX/UL is (0 << 6)
Signed-off-by: Ye.Li B37916@freescale.com Signed-off-by: Peng Fan Peng.Fan@freescale.com --- arch/arm/include/asm/imx-common/iomux-v3.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/include/asm/imx-common/iomux-v3.h b/arch/arm/include/asm/imx-common/iomux-v3.h index 2581019..7f9bb26 100644 --- a/arch/arm/include/asm/imx-common/iomux-v3.h +++ b/arch/arm/include/asm/imx-common/iomux-v3.h @@ -98,7 +98,11 @@ typedef u64 iomux_v3_cfg_t;
#define PAD_CTL_ODE (1 << 11)
+#if defined(CONFIG_MX6SX) || defined(CONFIG_MX6UL) +#define PAD_CTL_SPEED_LOW (0 << 6) +#else #define PAD_CTL_SPEED_LOW (1 << 6) +#endif #define PAD_CTL_SPEED_MED (2 << 6) #define PAD_CTL_SPEED_HIGH (3 << 6)
i.MX6UL does not have GPIO6/7, so do not include them for i.MX6UL.
Signed-off-by: Peng Fan Peng.Fan@freescale.com --- drivers/gpio/mxc_gpio.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/gpio/mxc_gpio.c b/drivers/gpio/mxc_gpio.c index 2012f99..57a650f 100644 --- a/drivers/gpio/mxc_gpio.c +++ b/drivers/gpio/mxc_gpio.c @@ -45,11 +45,15 @@ static unsigned long gpio_ports[] = { #endif #if defined(CONFIG_MX27) || defined(CONFIG_MX53) || defined(CONFIG_MX6) [4] = GPIO5_BASE_ADDR, +#ifndef CONFIG_MX6UL [5] = GPIO6_BASE_ADDR, #endif +#endif #if defined(CONFIG_MX53) || defined(CONFIG_MX6) +#ifndef CONFIG_MX6UL [6] = GPIO7_BASE_ADDR, #endif +#endif };
static int mxc_gpio_direction(unsigned int gpio,
ddr for i.MX6UL starts from 0x80000000
Signed-off-by: Peng Fan Peng.Fan@freescale.com --- include/configs/mx6_common.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/mx6_common.h b/include/configs/mx6_common.h index 6808674..ccb2d04 100644 --- a/include/configs/mx6_common.h +++ b/include/configs/mx6_common.h @@ -59,7 +59,7 @@ #define CONFIG_REVISION_TAG
/* Boot options */ -#if (defined(CONFIG_MX6SX) || defined(CONFIG_MX6SL)) +#if (defined(CONFIG_MX6SX) || defined(CONFIG_MX6SL) || defined(CONFIG_MX6UL)) #define CONFIG_LOADADDR 0x82000000 #ifndef CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_TEXT_BASE 0x87800000
You really should work on your patch descriptions. I'm not asking you for essays, but at least a sentence starting with a capital letter and ending with a fullstop would be nice ...
Add USDHC, I2C, UART, 74LV, USB, QSPI support.
Boot Log: U-Boot 2015.07-rc2-00085-gb5dc629 (Jul 02 2015 - 18:47:15 +0800)
CPU: Freescale i.MX6UL rev1.0 792 MHz (running at 396 MHz) Reset cause: POR Board: MX6UL 14x14 EVK I2C: ready DRAM: 512 MiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 *** Warning - bad CRC, using default environment
In: serial Out: serial Err: serial Hit any key to stop autoboot: 0
Signed-off-by: Ye.Li B37916@freescale.com Signed-off-by: Peng Fan Peng.Fan@freescale.com --- arch/arm/Kconfig | 7 + board/freescale/mx6ul_14x14_evk/Kconfig | 15 + board/freescale/mx6ul_14x14_evk/MAINTAINERS | 6 + board/freescale/mx6ul_14x14_evk/Makefile | 6 + board/freescale/mx6ul_14x14_evk/imximage.cfg | 99 +++++ board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c | 502 ++++++++++++++++++++++ configs/mx6ul_14x14_evk_defconfig | 3 + include/configs/mx6ul_14x14_evk.h | 221 ++++++++++ 8 files changed, 859 insertions(+) create mode 100644 board/freescale/mx6ul_14x14_evk/Kconfig create mode 100644 board/freescale/mx6ul_14x14_evk/MAINTAINERS create mode 100644 board/freescale/mx6ul_14x14_evk/Makefile create mode 100644 board/freescale/mx6ul_14x14_evk/imximage.cfg create mode 100644 board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c create mode 100644 configs/mx6ul_14x14_evk_defconfig create mode 100644 include/configs/mx6ul_14x14_evk.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 3e07ecc..88da06c 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -562,6 +562,12 @@ config TARGET_MX6SXSABRESD select DM select DM_THERMAL
+config TARGET_MX6UL_14X14_EVK + bool "Support mx6ul_14x14_evk" + select CPU_V7 + select DM + select DM_THERMAL + config TARGET_GW_VENTANA bool "Support gw_ventana" select CPU_V7 @@ -903,6 +909,7 @@ source "board/freescale/mx6qsabreauto/Kconfig" source "board/freescale/mx6sabresd/Kconfig" source "board/freescale/mx6slevk/Kconfig" source "board/freescale/mx6sxsabresd/Kconfig" +source "board/freescale/mx6ul_14x14_evk/Kconfig" source "board/freescale/vf610twr/Kconfig" source "board/gateworks/gw_ventana/Kconfig" source "board/genesi/mx51_efikamx/Kconfig" diff --git a/board/freescale/mx6ul_14x14_evk/Kconfig b/board/freescale/mx6ul_14x14_evk/Kconfig new file mode 100644 index 0000000..393aca6 --- /dev/null +++ b/board/freescale/mx6ul_14x14_evk/Kconfig @@ -0,0 +1,15 @@ +if TARGET_MX6UL_14X14_EVK + +config SYS_BOARD + default "mx6ul_14x14_evk" + +config SYS_VENDOR + default "freescale" + +config SYS_SOC + default "mx6" + +config SYS_CONFIG_NAME + default "mx6ul_14x14_evk" + +endif diff --git a/board/freescale/mx6ul_14x14_evk/MAINTAINERS b/board/freescale/mx6ul_14x14_evk/MAINTAINERS new file mode 100644 index 0000000..fe65153 --- /dev/null +++ b/board/freescale/mx6ul_14x14_evk/MAINTAINERS @@ -0,0 +1,6 @@ +MX6ULEVK BOARD +M: Peng Fan Peng.Fan@freescale.com +S: Maintained +F: board/freescale/mx6ulevk/ +F: include/configs/mx6ulevk.h +F: configs/mx6ulevk_defconfig diff --git a/board/freescale/mx6ul_14x14_evk/Makefile b/board/freescale/mx6ul_14x14_evk/Makefile new file mode 100644 index 0000000..61f6778 --- /dev/null +++ b/board/freescale/mx6ul_14x14_evk/Makefile @@ -0,0 +1,6 @@ +# (C) Copyright 2015 Freescale Semiconductor, Inc. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := mx6ul_14x14_evk.o diff --git a/board/freescale/mx6ul_14x14_evk/imximage.cfg b/board/freescale/mx6ul_14x14_evk/imximage.cfg new file mode 100644 index 0000000..2169938 --- /dev/null +++ b/board/freescale/mx6ul_14x14_evk/imximage.cfg @@ -0,0 +1,99 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Refer docs/README.imxmage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +#define __ASSEMBLY__ +#include <config.h> + +/* image version */ + +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi/sd/nand/onenand, qspi/nor + */ + +BOOT_FROM sd + +/* + * Device Configuration Data (DCD) + * + * Each entry must have the format: + * Addr-type Address Value + * + * where: + * Addr-type register length (1,2 or 4 bytes) + * Address absolute address of the register + * value value to be stored in the register + */ + +DATA 4 0x020c4068 0xffffffff +DATA 4 0x020c406c 0xffffffff +DATA 4 0x020c4070 0xffffffff +DATA 4 0x020c4074 0xffffffff +DATA 4 0x020c4078 0xffffffff +DATA 4 0x020c407c 0xffffffff +DATA 4 0x020c4080 0xffffffff +DATA 4 0x020c4084 0xffffffff + +DATA 4 0x020E04B4 0x000C0000 +DATA 4 0x020E04AC 0x00000000 +DATA 4 0x020E027C 0x00000008 +DATA 4 0x020E0250 0x00000030 +DATA 4 0x020E024C 0x00000030 +DATA 4 0x020E0490 0x00000030 +DATA 4 0x020E0288 0x00000030 +DATA 4 0x020E0270 0x00000000 +DATA 4 0x020E0260 0x00000030 +DATA 4 0x020E0264 0x00000030 +DATA 4 0x020E04A0 0x00000030 +DATA 4 0x020E0494 0x00020000 +DATA 4 0x020E0280 0x00000038 +DATA 4 0x020E0284 0x00000030 +DATA 4 0x020E04B0 0x00020000 +DATA 4 0x020E0498 0x00000030 +DATA 4 0x020E04A4 0x00000030 +DATA 4 0x020E0244 0x00000030 +DATA 4 0x020E0248 0x00000030 +DATA 4 0x021B001C 0x00008000 +DATA 4 0x021B0800 0xA1390003 +DATA 4 0x021B080C 0x00070007 +DATA 4 0x021B083C 0x41490145 +DATA 4 0x021B0848 0x40404546 +DATA 4 0x021B0850 0x4040524D +DATA 4 0x021B081C 0x33333333 +DATA 4 0x021B0820 0x33333333 +DATA 4 0x021B082C 0xf3333333 +DATA 4 0x021B0830 0xf3333333 +DATA 4 0x021B08C0 0x00922012 +DATA 4 0x021B0858 0x00000F00 +DATA 4 0x021B08b8 0x00000800 +DATA 4 0x021B0004 0x0002002D +DATA 4 0x021B0008 0x1B333000 +DATA 4 0x021B000C 0x676B54F3 +DATA 4 0x021B0010 0xB68E0A83 +DATA 4 0x021B0014 0x01FF00DB +DATA 4 0x021B0018 0x00211740 +DATA 4 0x021B001C 0x00008000 +DATA 4 0x021B002C 0x000026D2 +DATA 4 0x021B0030 0x006B1023 +DATA 4 0x021B0040 0x0000004F +DATA 4 0x021B0000 0x84180000 +DATA 4 0x021B001C 0x02008032 +DATA 4 0x021B001C 0x00008033 +DATA 4 0x021B001C 0x00048031 +DATA 4 0x021B001C 0x15208030 +DATA 4 0x021B001C 0x04008040 +DATA 4 0x021B0020 0x00000800 +DATA 4 0x021B0818 0x00000227 +DATA 4 0x021B0004 0x0002552D +DATA 4 0x021B0404 0x00011006 +DATA 4 0x021B001C 0x00000000 diff --git a/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c b/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c new file mode 100644 index 0000000..3d0260b --- /dev/null +++ b/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c @@ -0,0 +1,502 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm/arch/clock.h> +#include <asm/arch/iomux.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/mx6ul_pins.h> +#include <asm/arch/mx6-pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/gpio.h> +#include <asm/imx-common/iomux-v3.h> +#include <asm/imx-common/boot_mode.h> +#include <asm/imx-common/mxc_i2c.h> +#include <asm/io.h> +#include <common.h> +#include <fsl_esdhc.h> +#include <i2c.h> +#include <linux/sizes.h> +#include <mmc.h> +#include <usb.h> +#include <usb/ehci-fsl.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define USDHC_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_22K_UP | PAD_CTL_SPEED_LOW | \ + PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define USDHC_DAT3_CD_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_DOWN | PAD_CTL_SPEED_LOW | \ + PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + + +#define I2C_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ + PAD_CTL_ODE) + +#define IOX_SDI IMX_GPIO_NR(5, 10) +#define IOX_STCP IMX_GPIO_NR(5, 7) +#define IOX_SHCP IMX_GPIO_NR(5, 11) +#define IOX_OE IMX_GPIO_NR(5, 18) + +static iomux_v3_cfg_t const iox_pads[] = { + /* IOX_SDI */ + MX6_PAD_BOOT_MODE0__GPIO5_IO10 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* IOX_SHCP */ + MX6_PAD_BOOT_MODE1__GPIO5_IO11 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* IOX_STCP */ + MX6_PAD_SNVS_TAMPER7__GPIO5_IO07 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* IOX_nOE */ + MX6_PAD_SNVS_TAMPER8__GPIO5_IO08 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +/* + * HDMI_nRST --> Q0 + * ENET1_nRST --> Q1 + * ENET2_nRST --> Q2 + * CAN1_2_STBY --> Q3 + * BT_nPWD --> Q4 + * CSI_RST --> Q5 + * CSI_PWDN --> Q6 + * LCD_nPWREN --> Q7 + */ +enum qn { + HDMI_NRST, + ENET1_NRST, + ENET2_NRST, + CAN1_2_STBY, + BT_NPWD, + CSI_RST, + CSI_PWDN, + LCD_NPWREN, +}; + +enum qn_func { + qn_reset, + qn_enable, + qn_disable, +}; + +enum qn_level { + qn_low = 0, + qn_high = 1, +}; + +static enum qn_level seq[3][2] = { + {0, 1}, {1, 1}, {0, 0} +}; + +static enum qn_func qn_output[8] = { + qn_reset, qn_reset, qn_reset, qn_enable, qn_disable, qn_reset, + qn_disable, qn_enable +}; + +void iox74lv_init(void) +{ + int i; + + gpio_direction_output(IOX_OE, 0); + + for (i = 7; i >= 0; i--) { + gpio_direction_output(IOX_SHCP, 0); + gpio_direction_output(IOX_SDI, seq[qn_output[i]][0]); + udelay(500); + gpio_direction_output(IOX_SHCP, 1); + udelay(500); + } + + gpio_direction_output(IOX_STCP, 0); + udelay(500); + /* + * shift register will be output to pins + */ + gpio_direction_output(IOX_STCP, 1); + + for (i = 7; i >= 0; i--) { + gpio_direction_output(IOX_SHCP, 0); + gpio_direction_output(IOX_SDI, seq[qn_output[i]][1]); + udelay(500); + gpio_direction_output(IOX_SHCP, 1); + udelay(500); + } + gpio_direction_output(IOX_STCP, 0); + udelay(500); + /* + * shift register will be output to pins + */ + gpio_direction_output(IOX_STCP, 1); + + gpio_direction_output(IOX_OE, 1); +}; + +void iox74lv_set(int index) +{ + int i; + + gpio_direction_output(IOX_OE, 0); + + for (i = 7; i >= 0; i--) { + gpio_direction_output(IOX_SHCP, 0); + + if (i == index) + gpio_direction_output(IOX_SDI, seq[qn_output[i]][0]); + else + gpio_direction_output(IOX_SDI, seq[qn_output[i]][1]); + udelay(500); + gpio_direction_output(IOX_SHCP, 1); + udelay(500); + } + + gpio_direction_output(IOX_STCP, 0); + udelay(500); + /* + * shift register will be output to pins + */ + gpio_direction_output(IOX_STCP, 1); + + for (i = 7; i >= 0; i--) { + gpio_direction_output(IOX_SHCP, 0); + gpio_direction_output(IOX_SDI, seq[qn_output[i]][1]); + udelay(500); + gpio_direction_output(IOX_SHCP, 1); + udelay(500); + } + + gpio_direction_output(IOX_STCP, 0); + udelay(500); + /* + * shift register will be output to pins + */ + gpio_direction_output(IOX_STCP, 1); + + gpio_direction_output(IOX_OE, 1); +}; + +#ifdef CONFIG_SYS_I2C_MXC +#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) +/* I2C1 for PMIC and EEPROM */ +struct i2c_pads_info i2c_pad_info1 = { + .scl = { + .i2c_mode = MX6_PAD_UART4_TX_DATA__I2C1_SCL | PC, + .gpio_mode = MX6_PAD_UART4_TX_DATA__GPIO1_IO28 | PC, + .gp = IMX_GPIO_NR(1, 28), + }, + .sda = { + .i2c_mode = MX6_PAD_UART4_RX_DATA__I2C1_SDA | PC, + .gpio_mode = MX6_PAD_UART4_RX_DATA__GPIO1_IO29 | PC, + .gp = IMX_GPIO_NR(1, 29), + }, +}; +#endif + +int dram_init(void) +{ + gd->ram_size = PHYS_SDRAM_SIZE; + + return 0; +} + +static iomux_v3_cfg_t const uart1_pads[] = { + MX6_PAD_UART1_TX_DATA__UART1_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_UART1_RX_DATA__UART1_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static iomux_v3_cfg_t const usdhc1_pads[] = { + MX6_PAD_SD1_CLK__USDHC1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_CMD__USDHC1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DATA0__USDHC1_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DATA1__USDHC1_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DATA2__USDHC1_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DATA3__USDHC1_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + + /* VSELECT */ + MX6_PAD_GPIO1_IO05__USDHC1_VSELECT | MUX_PAD_CTRL(USDHC_PAD_CTRL), + /* CD */ + MX6_PAD_UART1_RTS_B__GPIO1_IO19 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* RST_B */ + MX6_PAD_GPIO1_IO09__GPIO1_IO09 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +#if defined(CONFIG_MX6UL_EVK_EMMC_REWORK) +static iomux_v3_cfg_t const usdhc2_emmc_pads[] = { + MX6_PAD_NAND_RE_B__USDHC2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NAND_WE_B__USDHC2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NAND_DATA00__USDHC2_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NAND_DATA01__USDHC2_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NAND_DATA02__USDHC2_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NAND_DATA03__USDHC2_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NAND_DATA04__USDHC2_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NAND_DATA05__USDHC2_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NAND_DATA06__USDHC2_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NAND_DATA07__USDHC2_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + + /* + * RST_B + */ + MX6_PAD_NAND_ALE__GPIO4_IO10 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; +#else +static iomux_v3_cfg_t const usdhc2_pads[] = { + MX6_PAD_NAND_RE_B__USDHC2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NAND_WE_B__USDHC2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NAND_DATA00__USDHC2_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NAND_DATA01__USDHC2_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NAND_DATA02__USDHC2_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NAND_DATA03__USDHC2_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), +}; + +static iomux_v3_cfg_t const usdhc2_cd_pads[] = { + /* + * The evk board uses DAT3 to detect CD card plugin, + * in u-boot we mux the pin to GPIO when doing board_mmc_getcd. + */ + MX6_PAD_NAND_DATA03__GPIO4_IO05 | MUX_PAD_CTRL(USDHC_DAT3_CD_PAD_CTRL), +}; + +static iomux_v3_cfg_t const usdhc2_dat3_pads[] = { + MX6_PAD_NAND_DATA03__USDHC2_DATA3 | + MUX_PAD_CTRL(USDHC_DAT3_CD_PAD_CTRL), +}; +#endif + +static void setup_iomux_uart(void) +{ + imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); +} + +#ifdef CONFIG_FSL_QSPI + +#define QSPI_PAD_CTRL1 \ + (PAD_CTL_SRE_FAST | PAD_CTL_SPEED_MED | \ + PAD_CTL_PKE | PAD_CTL_PUE | PAD_CTL_PUS_47K_UP | PAD_CTL_DSE_60ohm) + +static iomux_v3_cfg_t const quadspi_pads[] = { + MX6_PAD_NAND_WP_B__QSPI_A_SCLK | MUX_PAD_CTRL(QSPI_PAD_CTRL1), + MX6_PAD_NAND_READY_B__QSPI_A_DATA00 | MUX_PAD_CTRL(QSPI_PAD_CTRL1), + MX6_PAD_NAND_CE0_B__QSPI_A_DATA01 | MUX_PAD_CTRL(QSPI_PAD_CTRL1), + MX6_PAD_NAND_CE1_B__QSPI_A_DATA02 | MUX_PAD_CTRL(QSPI_PAD_CTRL1), + MX6_PAD_NAND_CLE__QSPI_A_DATA03 | MUX_PAD_CTRL(QSPI_PAD_CTRL1), + MX6_PAD_NAND_DQS__QSPI_A_SS0_B | MUX_PAD_CTRL(QSPI_PAD_CTRL1), +}; + +int board_qspi_init(void) +{ + /* Set the iomux */ + imx_iomux_v3_setup_multiple_pads(quadspi_pads, + ARRAY_SIZE(quadspi_pads)); + /* Set the clock */ + enable_qspi_clk(0); + + return 0; +} +#endif + +#ifdef CONFIG_FSL_ESDHC +static struct fsl_esdhc_cfg usdhc_cfg[2] = { + {USDHC1_BASE_ADDR, 0, 4}, +#if defined(CONFIG_MX6UL_EVK_EMMC_REWORK) + {USDHC2_BASE_ADDR, 0, 8}, +#else + {USDHC2_BASE_ADDR, 0, 4}, +#endif +}; + +#define USDHC1_CD_GPIO IMX_GPIO_NR(1, 19) +#define USDHC1_PWR_GPIO IMX_GPIO_NR(1, 9) +#define USDHC2_CD_GPIO IMX_GPIO_NR(4, 5) +#define USDHC2_PWR_GPIO IMX_GPIO_NR(4, 10) + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret = 0; + + switch (cfg->esdhc_base) { + case USDHC1_BASE_ADDR: + ret = !gpio_get_value(USDHC1_CD_GPIO); + break; + case USDHC2_BASE_ADDR: +#if defined(CONFIG_MX6UL_EVK_EMMC_REWORK) + ret = 1; +#else + imx_iomux_v3_setup_multiple_pads(usdhc2_cd_pads, + ARRAY_SIZE(usdhc2_cd_pads)); + gpio_direction_input(USDHC2_CD_GPIO); + + /* + * Since it is the DAT3 pin, this pin is pulled to + * low voltage if no card + */ + ret = gpio_get_value(USDHC2_CD_GPIO); + + imx_iomux_v3_setup_multiple_pads(usdhc2_dat3_pads, + ARRAY_SIZE(usdhc2_dat3_pads)); +#endif + break; + } + + return ret; +} + +int board_mmc_init(bd_t *bis) +{ + int i, ret; + + /* + * According to the board_mmc_init() the following map is done: + * (U-boot device node) (Physical Port) + * mmc0 USDHC1 + * mmc1 USDHC2 + */ + for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { + switch (i) { + case 0: + imx_iomux_v3_setup_multiple_pads( + usdhc1_pads, ARRAY_SIZE(usdhc1_pads)); + gpio_direction_input(USDHC1_CD_GPIO); + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); + + gpio_direction_output(USDHC1_PWR_GPIO, 0); + udelay(500); + gpio_direction_output(USDHC1_PWR_GPIO, 1); + break; + case 1: +#if defined(CONFIG_MX6UL_EVK_EMMC_REWORK) + imx_iomux_v3_setup_multiple_pads( + usdhc2_emmc_pads, ARRAY_SIZE(usdhc2_emmc_pads)); +#else + imx_iomux_v3_setup_multiple_pads( + usdhc2_pads, ARRAY_SIZE(usdhc2_pads)); +#endif + gpio_direction_output(USDHC2_PWR_GPIO, 0); + udelay(500); + gpio_direction_output(USDHC2_PWR_GPIO, 1); + usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); + break; + default: + printf("Warning: you configured more USDHC controllers (%d) than supported by the board\n", i + 1); + return -EINVAL; + } + + ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]); + if (ret) { + printf("Warning: failed to initialize mmc dev %d\n", i); + return ret; + } + } + + return 0; +} +#endif + +#ifdef CONFIG_USB_EHCI_MX6 +#define USB_OTHERREGS_OFFSET 0x800 +#define UCTRL_PWR_POL (1 << 9) + +static iomux_v3_cfg_t const usb_otg_pads[] = { + MX6_PAD_GPIO1_IO00__ANATOP_OTG1_ID | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +/* At default the 3v3 enables the MIC2026 for VBUS power */ +static void setup_usb(void) +{ + imx_iomux_v3_setup_multiple_pads(usb_otg_pads, + ARRAY_SIZE(usb_otg_pads)); +} + +int board_usb_phy_mode(int port) +{ + if (port == 1) + return USB_INIT_HOST; + else + return usb_phy_mode(port); +} + +int board_ehci_hcd_init(int port) +{ + u32 *usbnc_usb_ctrl; + + if (port > 1) + return -EINVAL; + + usbnc_usb_ctrl = (u32 *)(USB_BASE_ADDR + USB_OTHERREGS_OFFSET + + port * 4); + + /* Set Power polarity */ + setbits_le32(usbnc_usb_ctrl, UCTRL_PWR_POL); + + return 0; +} +#endif + +int board_early_init_f(void) +{ + setup_iomux_uart(); + + return 0; +} + +int board_init(void) +{ + /* Address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + imx_iomux_v3_setup_multiple_pads(iox_pads, ARRAY_SIZE(iox_pads)); + + iox74lv_init(); + +#ifdef CONFIG_SYS_I2C_MXC + setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1); +#endif + +#ifdef CONFIG_USB_EHCI_MX6 + setup_usb(); +#endif + +#ifdef CONFIG_FSL_QSPI + board_qspi_init(); +#endif + + return 0; +} + +#ifdef CONFIG_CMD_BMODE +static const struct boot_mode board_boot_modes[] = { + /* 4 bit bus width */ + {"sd1", MAKE_CFGVAL(0x42, 0x20, 0x00, 0x00)}, + {"sd2", MAKE_CFGVAL(0x40, 0x28, 0x00, 0x00)}, + {"qspi1", MAKE_CFGVAL(0x10, 0x00, 0x00, 0x00)}, + {NULL, 0}, +}; +#endif + +int board_late_init(void) +{ +#ifdef CONFIG_CMD_BMODE + add_board_boot_modes(board_boot_modes); +#endif + + return 0; +} + +u32 get_board_rev(void) +{ + return get_cpu_rev(); +} + +int checkboard(void) +{ + puts("Board: MX6UL 14x14 EVK\n"); + + return 0; +} diff --git a/configs/mx6ul_14x14_evk_defconfig b/configs/mx6ul_14x14_evk_defconfig new file mode 100644 index 0000000..b4fd39e --- /dev/null +++ b/configs/mx6ul_14x14_evk_defconfig @@ -0,0 +1,3 @@ +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6ul_14x14_evk/imximage.cfg,MX6UL" +CONFIG_ARM=y +CONFIG_TARGET_MX6UL_14X14_EVK=y diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h new file mode 100644 index 0000000..cfbf701 --- /dev/null +++ b/include/configs/mx6ul_14x14_evk.h @@ -0,0 +1,221 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * Configuration settings for the Freescale i.MX6UL 14x14 EVK board. + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef __MX6UL_14X14_EVK_CONFIG_H +#define __MX6UL_14X14_EVK_CONFIG_H + + +#include <asm/arch/imx-regs.h> +#include <linux/sizes.h> +#include "mx6_common.h" +#include <asm/imx-common/gpio.h> + +#define CONFIG_MX6 +#define CONFIG_ROM_UNIFIED_SECTIONS +#define CONFIG_SYS_GENERIC_BOARD +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (16 * SZ_1M) + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_BOARD_LATE_INIT + +#define CONFIG_MXC_UART +#define CONFIG_MXC_UART_BASE UART1_BASE + +#define CONFIG_CMD_FUSE +#ifdef CONFIG_CMD_FUSE +#define CONFIG_MXC_OCOTP +#endif + +/* MMC Configs */ +#ifdef CONFIG_FSL_USDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR USDHC2_BASE_ADDR + +#ifdef CONFIG_SYS_USE_NAND +#define CONFIG_SYS_FSL_USDHC_NUM 1 +#else +#define CONFIG_SYS_FSL_USDHC_NUM 2 +#endif + +#define CONFIG_SUPPORT_EMMC_BOOT /* eMMC specific */ +#endif + +#undef CONFIG_BOOTM_NETBSD +#undef CONFIG_BOOTM_PLAN9 +#undef CONFIG_BOOTM_RTEMS + +#undef CONFIG_CMD_EXPORTENV +#undef CONFIG_CMD_IMPORTENV + +/* I2C configs */ +#define CONFIG_CMD_I2C +#ifdef CONFIG_CMD_I2C +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_SPEED 100000 +#endif + +#define PHYS_SDRAM_SIZE SZ_512M + +/* Command definition */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_IMLS + +#define CONFIG_SYS_MMC_IMG_LOAD_PART 1 + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "script=boot.scr\0" \ + "image=zImage\0" \ + "console=ttymxc0\0" \ + "fdt_high=0xffffffff\0" \ + "initrd_high=0xffffffff\0" \ + "fdt_file=imx6ul-14x14-evk.dtb\0" \ + "fdt_addr=0x83000000\0" \ + "boot_fdt=try\0" \ + "ip_dyn=yes\0" \ + "mmcdev="__stringify(CONFIG_SYS_MMC_ENV_DEV)"\0" \ + "mmcpart=" __stringify(CONFIG_SYS_MMC_IMG_LOAD_PART) "\0" \ + "mmcroot=" CONFIG_MMCROOT " rootwait rw\0" \ + "mmcautodetect=yes\0" \ + "mmcargs=setenv bootargs console=${console},${baudrate} " \ + "root=${mmcroot}\0" \ + "loadbootscript=" \ + "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if run loadfdt; then " \ + "bootz ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootz; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootz; " \ + "fi;\0" \ + "netargs=setenv bootargs console=${console},${baudrate} " \ + "root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ + "netboot=echo Booting from net ...; " \ + "run netargs; " \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${image}; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "bootz ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootz; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootz; " \ + "fi;\0" + +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcdev};" \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loadimage; then " \ + "run mmcboot; " \ + "else run netboot; " \ + "fi; " \ + "fi; " \ + "else run netboot; fi" + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_PROMPT "=> " +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) + +#define CONFIG_CMD_MEMTEST +#define CONFIG_SYS_MEMTEST_START 0x80000000 +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + 0x10000000) + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_CMDLINE_EDITING +#define CONFIG_STACKSIZE SZ_128K + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH + +#define CONFIG_ENV_SIZE SZ_8K +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_ENV_OFFSET (8 * SZ_64K) +#define CONFIG_SYS_MMC_ENV_DEV 1 /* USDHC2 */ +#define CONFIG_SYS_MMC_ENV_PART 0 /* user area */ +#define CONFIG_MMCROOT "/dev/mmcblk1p2" /* USDHC2 */ + +#define CONFIG_OF_LIBFDT +#define CONFIG_CMD_BOOTZ +#define CONFIG_CMD_BMODE + +#ifndef CONFIG_SYS_DCACHE_OFF +#define CONFIG_CMD_CACHE +#endif + +#define CONFIG_FSL_QSPI +#ifdef CONFIG_FSL_QSPI +#define CONFIG_CMD_SF +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_STMICRO +#define CONFIG_SPI_FLASH_BAR +#define CONFIG_SF_DEFAULT_BUS 0 +#define CONFIG_SF_DEFAULT_CS 0 +#define CONFIG_SF_DEFAULT_SPEED 40000000 +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 +#define FSL_QSPI_FLASH_NUM 1 +#define FSL_QSPI_FLASH_SIZE SZ_32M +#endif + +/* USB Configs */ +#define CONFIG_CMD_USB +#ifdef CONFIG_CMD_USB +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_MX6 +#define CONFIG_USB_STORAGE +#define CONFIG_EHCI_HCD_INIT_AFTER_RESET +#define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) +#define CONFIG_MXC_USB_FLAGS 0 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 +#endif + +#endif
Why do we need this config option?
When should a user select it? Please explain it.
Regards,
Fabio Estevam
Hi Fabio,
This board default support sd. If want to use emmc, need to rework the board. So introduce this option.
Will fix in V2.
Regards,
Fabio Estevam
Regards, Peng. --
I think you should consider switching this board to SPL and get rid of this imximage way of configuring DDR DRAM from the getgo.
Best regards, Marek Vasut
Fabio Estevam
Peng Fan
Peng Fan
