[U-Boot-Users] [PATCH 1/2] ppc4xx: Add DU440 board support
Signed-off-by: Matthias Fuchs matthias.fuchs@esd-electronics.com --- board/esd/du440/Makefile | 51 ++ board/esd/du440/config.mk | 41 ++ board/esd/du440/du440.c | 1171 ++++++++++++++++++++++++++++++++++++++++++++ board/esd/du440/du440.h | 42 ++ board/esd/du440/init.S | 80 +++ board/esd/du440/u-boot.lds | 145 ++++++ 6 files changed, 1530 insertions(+), 0 deletions(-) create mode 100644 board/esd/du440/Makefile create mode 100644 board/esd/du440/config.mk create mode 100644 board/esd/du440/du440.c create mode 100644 board/esd/du440/du440.h create mode 100644 board/esd/du440/init.S create mode 100644 board/esd/du440/u-boot.lds
diff --git a/board/esd/du440/Makefile b/board/esd/du440/Makefile new file mode 100644 index 0000000..e996a0a --- /dev/null +++ b/board/esd/du440/Makefile @@ -0,0 +1,51 @@ +# +# (C) Copyright 2002-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS = $(BOARD).o +SOBJS = init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/esd/du440/config.mk b/board/esd/du440/config.mk new file mode 100644 index 0000000..e62b8d3 --- /dev/null +++ b/board/esd/du440/config.mk @@ -0,0 +1,41 @@ +# +# (C) Copyright 2002 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# +# +# AMCC 440EPx Reference Platform (Sequoia) board +# + +sinclude $(OBJTREE)/board/$(BOARDDIR)/config.tmp + +ifndef TEXT_BASE +TEXT_BASE = 0xFFFA0000 +endif + +PLATFORM_CPPFLAGS += -DCONFIG_440=1 + +ifeq ($(debug),1) +PLATFORM_CPPFLAGS += -DDEBUG +endif + +ifeq ($(dbcr),1) +PLATFORM_CPPFLAGS += -DCFG_INIT_DBCR=0x8cff0000 +endif diff --git a/board/esd/du440/du440.c b/board/esd/du440/du440.c new file mode 100644 index 0000000..0c8d59b --- /dev/null +++ b/board/esd/du440/du440.c @@ -0,0 +1,1171 @@ +/* + * (C) Copyright 2008 + * Matthias Fuchs, esd gmbh, matthias.fuchs@esd-electronics.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/processor.h> +#include <asm/io.h> +#include <command.h> +#include <i2c.h> +#include <ppc440.h> +#include "du440.h" + +DECLARE_GLOBAL_DATA_PTR; + +extern flash_info_t flash_info[CFG_MAX_FLASH_BANKS]; +extern ulong flash_get_size (ulong base, int banknum); + +int usbhub_init(void); +int dvi_init(void); +int eeprom_write_enable (unsigned dev_addr, int state); +int board_revision(void); + +static int du440_post_errors; + +int board_early_init_f(void) +{ + u32 sdr0_cust0; + u32 sdr0_pfc1, sdr0_pfc2; + u32 reg; + + mtdcr(ebccfga, xbcfg); + mtdcr(ebccfgd, 0xb8400000); + + /*-------------------------------------------------------------------- + * Setup the GPIO pins + *-------------------------------------------------------------------*/ + out_be32((void*)GPIO0_OR, 0x00000000 | CFG_GPIO0_EP_EEP); + out_be32((void*)GPIO0_TCR, 0x0000000f | CFG_GPIO0_EP_EEP); + out_be32((void*)GPIO0_OSRL, 0x50055400); + out_be32((void*)GPIO0_OSRH, 0x550050aa); + out_be32((void*)GPIO0_TSRL, 0x50055400); + out_be32((void*)GPIO0_TSRH, 0x55005000); + out_be32((void*)GPIO0_ISR1L, 0x50000000); + out_be32((void*)GPIO0_ISR1H, 0x00000000); + out_be32((void*)GPIO0_ISR2L, 0x00000000); + out_be32((void*)GPIO0_ISR2H, 0x00000100); + out_be32((void*)GPIO0_ISR3L, 0x00000000); + out_be32((void*)GPIO0_ISR3H, 0x00000000); + + out_be32((void*)GPIO1_OR, 0x00000000); + out_be32((void*)GPIO1_TCR, 0xc2000000 | + CFG_GPIO1_IORSTN | + CFG_GPIO1_LEDUSR1 | + CFG_GPIO1_LEDUSR2 | + CFG_GPIO1_LEDPOST | + CFG_GPIO1_LEDDU); + out_be32((void*)GPIO1_ODR, CFG_GPIO1_LEDDU); + + out_be32((void*)GPIO1_OSRL, 0x5c280000); + out_be32((void*)GPIO1_OSRH, 0x00000000); + out_be32((void*)GPIO1_TSRL, 0x0c000000); + out_be32((void*)GPIO1_TSRH, 0x00000000); + out_be32((void*)GPIO1_ISR1L, 0x00005550); + out_be32((void*)GPIO1_ISR1H, 0x00000000); + out_be32((void*)GPIO1_ISR2L, 0x00050000); + out_be32((void*)GPIO1_ISR2H, 0x00000000); + out_be32((void*)GPIO1_ISR3L, 0x01400000); + out_be32((void*)GPIO1_ISR3H, 0x00000000); + + /*-------------------------------------------------------------------- + * Setup the interrupt controller polarities, triggers, etc. + *-------------------------------------------------------------------*/ + mtdcr(uic0sr, 0xffffffff); /* clear all */ + mtdcr(uic0er, 0x00000000); /* disable all */ + mtdcr(uic0cr, 0x00000005); /* ATI & UIC1 crit are critical */ + mtdcr(uic0pr, 0xfffff7ff); /* per ref-board manual */ + mtdcr(uic0tr, 0x00000000); /* per ref-board manual */ + mtdcr(uic0vr, 0x00000000); /* int31 highest, base=0x000 */ + mtdcr(uic0sr, 0xffffffff); /* clear all */ + + /* + * UIC1: + * bit30: ext. Irq 1: PLD : int 32+30 + */ + mtdcr(uic1sr, 0xffffffff); /* clear all */ + mtdcr(uic1er, 0x00000000); /* disable all */ + mtdcr(uic1cr, 0x00000000); /* all non-critical */ + mtdcr(uic1pr, 0xfffffffd); + mtdcr(uic1tr, 0x00000000); + mtdcr(uic1vr, 0x00000000); /* int31 highest, base=0x000 */ + mtdcr(uic1sr, 0xffffffff); /* clear all */ + + /* + * UIC2 + * bit3: ext. Irq 2: DCF77 : int 64+3 + */ + mtdcr(uic2sr, 0xffffffff); /* clear all */ + mtdcr(uic2er, 0x00000000); /* disable all */ + mtdcr(uic2cr, 0x00000000); /* all non-critical */ + mtdcr(uic2pr, 0xffffffff); /* per ref-board manual */ + mtdcr(uic2tr, 0x00000000); /* per ref-board manual */ + mtdcr(uic2vr, 0x00000000); /* int31 highest, base=0x000 */ + mtdcr(uic2sr, 0xffffffff); /* clear all */ + + /* select Ethernet pins */ + mfsdr(SDR0_PFC1, sdr0_pfc1); + mfsdr(SDR0_PFC2, sdr0_pfc2); + + /* setup EMAC bridge interface */ + if (board_revision() == 0) { + /* 1 x MII */ + sdr0_pfc1 = (sdr0_pfc1 & ~SDR0_PFC1_SELECT_MASK) | + SDR0_PFC1_SELECT_CONFIG_1_2; + sdr0_pfc2 = (sdr0_pfc2 & ~SDR0_PFC2_SELECT_MASK) | + SDR0_PFC2_SELECT_CONFIG_1_2; + } else { + /* 2 x SMII */ + sdr0_pfc1 = (sdr0_pfc1 & ~SDR0_PFC1_SELECT_MASK) | + SDR0_PFC1_SELECT_CONFIG_6; + sdr0_pfc2 = (sdr0_pfc2 & ~SDR0_PFC2_SELECT_MASK) | + SDR0_PFC2_SELECT_CONFIG_6; + } + + /* enable 2nd IIC */ + sdr0_pfc1 = (sdr0_pfc1 & ~SDR0_PFC1_SIS_MASK) | SDR0_PFC1_SIS_IIC1_SEL; + + mtsdr(SDR0_PFC2, sdr0_pfc2); + mtsdr(SDR0_PFC1, sdr0_pfc1); + + /* PCI arbiter enabled */ + mfsdr(sdr_pci0, reg); + mtsdr(sdr_pci0, 0x80000000 | reg); + + /* setup NAND FLASH */ + mfsdr(SDR0_CUST0, sdr0_cust0); + sdr0_cust0 = SDR0_CUST0_MUX_NDFC_SEL | + SDR0_CUST0_NDFC_ENABLE | + SDR0_CUST0_NDFC_BW_8_BIT | + SDR0_CUST0_NDFC_ARE_MASK | + (0x80000000 >> (28 + CFG_NAND0_CS)) | + (0x80000000 >> (28 + CFG_NAND1_CS)); + mtsdr(SDR0_CUST0, sdr0_cust0); + + return 0; +} + +/*---------------------------------------------------------------------------+ + | misc_init_r. + +---------------------------------------------------------------------------*/ +int misc_init_r(void) +{ + uint pbcr; + int size_val = 0; + u32 reg; + unsigned long usb2d0cr = 0; + unsigned long usb2phy0cr, usb2h0cr = 0; + unsigned long sdr0_pfc1; + int i, j; + + /* adjust flash start and offset */ + gd->bd->bi_flashstart = 0 - gd->bd->bi_flashsize; + gd->bd->bi_flashoffset = 0; + + mtdcr(ebccfga, pb0cr); + pbcr = mfdcr(ebccfgd); + switch (gd->bd->bi_flashsize) { + case 1 << 20: + size_val = 0; + break; + case 2 << 20: + size_val = 1; + break; + case 4 << 20: + size_val = 2; + break; + case 8 << 20: + size_val = 3; + break; + case 16 << 20: + size_val = 4; + break; + case 32 << 20: + size_val = 5; + break; + case 64 << 20: + size_val = 6; + break; + case 128 << 20: + size_val = 7; + break; + } + pbcr = (pbcr & 0x0001ffff) | gd->bd->bi_flashstart | (size_val << 17); + mtdcr(ebccfga, pb0cr); + mtdcr(ebccfgd, pbcr); + + /* + * Re-check to get correct base address + */ + flash_get_size(gd->bd->bi_flashstart, 0); + + /* + * USB suff... + */ + /* SDR Setting */ + mfsdr(SDR0_PFC1, sdr0_pfc1); + mfsdr(SDR0_USB0, usb2d0cr); + mfsdr(SDR0_USB2PHY0CR, usb2phy0cr); + mfsdr(SDR0_USB2H0CR, usb2h0cr); + + usb2phy0cr = usb2phy0cr &~SDR0_USB2PHY0CR_XOCLK_MASK; + usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_XOCLK_EXTERNAL; /*0*/ + usb2phy0cr = usb2phy0cr &~SDR0_USB2PHY0CR_WDINT_MASK; + usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_WDINT_16BIT_30MHZ; /*1*/ + usb2phy0cr = usb2phy0cr &~SDR0_USB2PHY0CR_DVBUS_MASK; + usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_DVBUS_PURDIS; /*0*/ + usb2phy0cr = usb2phy0cr &~SDR0_USB2PHY0CR_DWNSTR_MASK; + usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_DWNSTR_HOST; /*1*/ + usb2phy0cr = usb2phy0cr &~SDR0_USB2PHY0CR_UTMICN_MASK; + usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_UTMICN_HOST; /*1*/ + + /* An 8-bit/60MHz interface is the only possible alternative + when connecting the Device to the PHY */ + usb2h0cr = usb2h0cr &~SDR0_USB2H0CR_WDINT_MASK; + usb2h0cr = usb2h0cr | SDR0_USB2H0CR_WDINT_16BIT_30MHZ; /*1*/ + + /* To enable the USB 2.0 Device function through the UTMI interface */ + usb2d0cr = usb2d0cr &~SDR0_USB2D0CR_USB2DEV_EBC_SEL_MASK; + + sdr0_pfc1 = sdr0_pfc1 &~SDR0_PFC1_UES_MASK; + sdr0_pfc1 = sdr0_pfc1 | SDR0_PFC1_UES_EBCHR_SEL; /*1*/ + + mtsdr(SDR0_PFC1, sdr0_pfc1); + mtsdr(SDR0_USB0, usb2d0cr); + mtsdr(SDR0_USB2PHY0CR, usb2phy0cr); + mtsdr(SDR0_USB2H0CR, usb2h0cr); + + /* clear resets */ + udelay (1000); + mtsdr(SDR0_SRST1, 0x00000000); + udelay (1000); + mtsdr(SDR0_SRST0, 0x00000000); + + printf("USB: Host(int phy)\n"); + + /* + * Clear PLB4A0_ACR[WRP] + * This fix will make the MAL burst disabling patch for the Linux + * EMAC driver obsolete. + */ + reg = mfdcr(plb4_acr) & ~PLB4_ACR_WRP; + mtdcr(plb4_acr, reg); + + /* + * release IO-RST# + * We have to wait at least 560ms until we may call usbhub_init + */ + out_be32((void*)GPIO1_OR, in_be32((void*)GPIO1_OR) | CFG_GPIO1_IORSTN); + + /* + * flash USR1/2 LEDs (600ms) + * This results in the necessary delay from IORST# until + * calling usbhub_init will succeed + */ + for (j = 0; j < 3; j++) { + out_be32((void*)GPIO1_OR, + (in_be32((void*)GPIO1_OR) & ~CFG_GPIO1_LEDUSR2) | + CFG_GPIO1_LEDUSR1); + + for (i = 0; i < 100; i++) + udelay(1000); + + out_be32((void*)GPIO1_OR, + (in_be32((void*)GPIO1_OR) & ~CFG_GPIO1_LEDUSR1) | + CFG_GPIO1_LEDUSR2); + + for (i = 0; i < 100; i++) + udelay(1000); + } + + out_be32((void*)GPIO1_OR, in_be32((void*)GPIO1_OR) & + ~(CFG_GPIO1_LEDUSR1 | CFG_GPIO1_LEDUSR2)); + + if (usbhub_init()) + du440_post_errors++; + + if(dvi_init()) + du440_post_errors++; + + return 0; +} + +int pld_revision(void) +{ + out8(CFG_CPLD_BASE, 0x00); + return (int)(in8(CFG_CPLD_BASE) & CPLD_VERSION_MASK); +} + +int board_revision(void) +{ + int rpins = (int)((in_be32((void*)GPIO1_IR) & CFG_GPIO1_HWVER_MASK) + >> CFG_GPIO1_HWVER_SHIFT); + + return ((rpins & 1) << 3) | ((rpins & 2) << 1) | + ((rpins & 4) >> 1) | ((rpins & 8) >> 3); +} + +#ifdef CONFIG_SHOW_ACTIVITY +void board_show_activity (ulong timestamp) +{ + if ((timestamp % 100) == 0) + out_be32((void*)GPIO1_OR, + in_be32((void*)GPIO1_OR) ^ CFG_GPIO1_LEDUSR1); +} + +void show_activity(int arg) +{ +} +#endif /* CONFIG_SHOW_ACTIVITY */ + +int du440_phy_addr(int devnum) +{ + if (board_revision() == 0) + return devnum; + + return devnum + 1; +} + +int checkboard(void) +{ + char serno[32]; + + puts("Board: DU440"); + + if (getenv_r("serial#", serno, sizeof(serno)) > 0) { + puts(", serial# "); + puts(serno); + } + + printf(", HW-Rev. 1.%d, CPLD-Rev. 1.%d\n", + board_revision(), pld_revision()); + return (0); +} + +/************************************************************************* + * pci_pre_init + * + * This routine is called just prior to registering the hose and gives + * the board the opportunity to check things. Returning a value of zero + * indicates that things are bad & PCI initialization should be aborted. + * + * Different boards may wish to customize the pci controller structure + * (add regions, override default access routines, etc) or perform + * certain pre-initialization actions. + * + ************************************************************************/ +#if defined(CONFIG_PCI) && defined(CFG_PCI_PRE_INIT) +int pci_pre_init(struct pci_controller *hose) +{ + unsigned long addr; + + /*-------------------------------------------------------------------------+ + | Set priority for all PLB3 devices to 0. + | Set PLB3 arbiter to fair mode. + +-------------------------------------------------------------------------*/ + mfsdr(sdr_amp1, addr); + mtsdr(sdr_amp1, (addr & 0x000000FF) | 0x0000FF00); + addr = mfdcr(plb3_acr); + mtdcr(plb3_acr, addr | 0x80000000); + + /*-------------------------------------------------------------------------+ + | Set priority for all PLB4 devices to 0. + +-------------------------------------------------------------------------*/ + mfsdr(sdr_amp0, addr); + mtsdr(sdr_amp0, (addr & 0x000000FF) | 0x0000FF00); + addr = mfdcr(plb4_acr) | 0xa0000000; /* Was 0x8---- */ + mtdcr(plb4_acr, addr); + + /*-------------------------------------------------------------------------+ + | Set Nebula PLB4 arbiter to fair mode. + +-------------------------------------------------------------------------*/ + /* Segment0 */ + addr = (mfdcr(plb0_acr) & ~plb0_acr_ppm_mask) | plb0_acr_ppm_fair; + addr = (addr & ~plb0_acr_hbu_mask) | plb0_acr_hbu_enabled; + addr = (addr & ~plb0_acr_rdp_mask) | plb0_acr_rdp_4deep; + addr = (addr & ~plb0_acr_wrp_mask) | plb0_acr_wrp_2deep; + mtdcr(plb0_acr, addr); + + /* Segment1 */ + addr = (mfdcr(plb1_acr) & ~plb1_acr_ppm_mask) | plb1_acr_ppm_fair; + addr = (addr & ~plb1_acr_hbu_mask) | plb1_acr_hbu_enabled; + addr = (addr & ~plb1_acr_rdp_mask) | plb1_acr_rdp_4deep; + addr = (addr & ~plb1_acr_wrp_mask) | plb1_acr_wrp_2deep; + mtdcr(plb1_acr, addr); + + return 1; +} +#endif /* defined(CONFIG_PCI) && defined(CFG_PCI_PRE_INIT) */ + +/************************************************************************* + * pci_target_init + * + * The bootstrap configuration provides default settings for the pci + * inbound map (PIM). But the bootstrap config choices are limited and + * may not be sufficient for a given board. + * + ************************************************************************/ +#if defined(CONFIG_PCI) && defined(CFG_PCI_TARGET_INIT) +void pci_target_init(struct pci_controller *hose) +{ + /*--------------------------------------------------------------------------+ + * Set up Direct MMIO registers + *--------------------------------------------------------------------------*/ + /*--------------------------------------------------------------------------+ + | PowerPC440EPX PCI Master configuration. + | Map one 1Gig range of PLB/processor addresses to PCI memory space. + | PLB address 0xA0000000-0xDFFFFFFF ==> PCI address 0xA0000000-0xDFFFFFFF + | Use byte reversed out routines to handle endianess. + | Make this region non-prefetchable. + +--------------------------------------------------------------------------*/ + out32r(PCIX0_PMM0MA, 0x00000000); /* PMM0 Mask/Attribute - disabled b4 setting */ + out32r(PCIX0_PMM0LA, CFG_PCI_MEMBASE); /* PMM0 Local Address */ + out32r(PCIX0_PMM0PCILA, CFG_PCI_MEMBASE); /* PMM0 PCI Low Address */ + out32r(PCIX0_PMM0PCIHA, 0x00000000); /* PMM0 PCI High Address */ + out32r(PCIX0_PMM0MA, 0xE0000001); /* 512M + No prefetching, and enable region */ + + out32r(PCIX0_PMM1MA, 0x00000000); /* PMM0 Mask/Attribute - disabled b4 setting */ + out32r(PCIX0_PMM1LA, CFG_PCI_MEMBASE2); /* PMM0 Local Address */ + out32r(PCIX0_PMM1PCILA, CFG_PCI_MEMBASE2); /* PMM0 PCI Low Address */ + out32r(PCIX0_PMM1PCIHA, 0x00000000); /* PMM0 PCI High Address */ + out32r(PCIX0_PMM1MA, 0xE0000001); /* 512M + No prefetching, and enable region */ + + out32r(PCIX0_PTM1MS, 0x00000001); /* Memory Size/Attribute */ + out32r(PCIX0_PTM1LA, 0); /* Local Addr. Reg */ + out32r(PCIX0_PTM2MS, 0); /* Memory Size/Attribute */ + out32r(PCIX0_PTM2LA, 0); /* Local Addr. Reg */ + + /*--------------------------------------------------------------------------+ + * Set up Configuration registers + *--------------------------------------------------------------------------*/ + + /* Program the board's subsystem id/vendor id */ + pci_write_config_word(0, PCI_SUBSYSTEM_VENDOR_ID, + PCI_VENDOR_ID_ESDGMBH); + pci_write_config_word(0, PCI_SUBSYSTEM_ID, PCI_DEVICE_ID_DU440); + + pci_write_config_word(0, PCI_CLASS_SUB_CODE, PCI_CLASS_BRIDGE_HOST); + + /* Configure command register as bus master */ + pci_write_config_word(0, PCI_COMMAND, PCI_COMMAND_MASTER); + + /* 240nS PCI clock */ + pci_write_config_word(0, PCI_LATENCY_TIMER, 1); + + /* No error reporting */ + pci_write_config_word(0, PCI_ERREN, 0); + + pci_write_config_dword(0, PCI_BRDGOPT2, 0x00000101); + +} +#endif /* defined(CONFIG_PCI) && defined(CFG_PCI_TARGET_INIT) */ + +/************************************************************************* + * pci_master_init + * + ************************************************************************/ +#if defined(CONFIG_PCI) && defined(CFG_PCI_MASTER_INIT) +void pci_master_init(struct pci_controller *hose) +{ + unsigned short temp_short; + + /*---------------------------------------------------------------------+ + | Write the PowerPC440 EP PCI Configuration regs. + | Enable PowerPC440 EP to be a master on the PCI bus (PMM). + | Enable PowerPC440 EP to act as a PCI memory target (PTM). + +--------------------------------------------------------------------*/ + pci_read_config_word(0, PCI_COMMAND, &temp_short); + pci_write_config_word(0, PCI_COMMAND, + temp_short | PCI_COMMAND_MASTER | + PCI_COMMAND_MEMORY); +} +#endif /* defined(CONFIG_PCI) && defined(CFG_PCI_MASTER_INIT) */ + +/************************************************************************* + * is_pci_host + * + * This routine is called to determine if a pci scan should be + * performed. With various hardware environments (especially cPCI and + * PPMC) it's insufficient to depend on the state of the arbiter enable + * bit in the strap register, or generic host/adapter assumptions. + * + * Rather than hard-code a bad assumption in the general 440 code, the + * 440 pci code requires the board to decide at runtime. + * + * Return 0 for adapter mode, non-zero for host (monarch) mode. + * + * + ************************************************************************/ +#if defined(CONFIG_PCI) +int is_pci_host(struct pci_controller *hose) +{ + /* always configured as host. */ + return (1); +} +#endif /* defined(CONFIG_PCI) */ + +int last_stage_init(void) +{ + int e, i; + /* everyting is ok: turn on POST-LED */ + out_be32((void*)GPIO1_OR, in_be32((void*)GPIO1_OR) | CFG_GPIO1_LEDPOST); + + /* slowly blink on errors and finally keep LED off */ + for (e = 0; e < du440_post_errors; e++) { + out_be32((void*)GPIO1_OR, + in_be32((void*)GPIO1_OR) | CFG_GPIO1_LEDPOST); + + for (i = 0; i < 500; i++) + udelay(1000); + + out_be32((void*)GPIO1_OR, + in_be32((void*)GPIO1_OR) & ~CFG_GPIO1_LEDPOST); + + for (i = 0; i < 500; i++) + udelay(1000); + } + + return 0; +} + +#if defined(CONFIG_I2C_MULTI_BUS) +/* + * read field strength from I2C ADC + */ +int dcf77_status(void) +{ + unsigned int oldbus; + uchar u[2]; + int U; + + oldbus = I2C_GET_BUS(); + I2C_SET_BUS(1); + + if (i2c_read (IIC1_MCP3021_ADDR, 0, 0, u, 2)) { + I2C_SET_BUS(oldbus); + return -1; + } + + U = (int)(((u[0] << 8) | u[1]) >> 2) * 3300 / 1024; + + I2C_SET_BUS(oldbus); + return U; +} + +int do_dcf77(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + int U; + u32 pin, pinold; + unsigned long long t1, t2; + bd_t *bd = gd->bd; + + printf("DCF77: "); + U = dcf77_status(); + if (U > 0) + printf("signal=%d mV\n", U); + else + printf("ERROR - no signal\n"); + +#if 1 + t1 = t2 = 0; + pinold = in_be32((void*)GPIO1_IR) & CFG_GPIO1_DCF77; + while (!ctrlc()) { + pin = in_be32((void*)GPIO1_IR) & CFG_GPIO1_DCF77; + if (pin && !pinold) { /* bit start */ + t1 = get_ticks(); + if (t2 && ((unsigned int)(t1 - t2) / + (bd->bi_procfreq / 1000) >= 1800)) + printf("Start of minute\n"); + + t2 = t1; + } + if (t1 && !pin && pinold) { /* bit end */ + printf("%5d\n", (unsigned int)(get_ticks() - t1) / + (bd->bi_procfreq / 1000)); + } + pinold = pin; + } +#endif + + printf("Abort\n"); + return 0; +} +U_BOOT_CMD( + dcf77, 1, 1, do_dcf77, + "dcf77 - Check DCF77 receiver\n", + NULL + ); + +/* + * initialize USB hub via I2C1 + */ +int usbhub_init(void) +{ + int reg; + int ret = 0; + unsigned int oldbus; + uchar u[] = {0x04, 0x24, 0x04, 0x07, 0x25, 0x00, 0x00, 0xd3, + 0x18, 0xe0, 0x00, 0x00, 0x01, 0x64, 0x01, 0x64, + 0x32}; + + uchar stcd; + + printf("Hub: "); + + oldbus = I2C_GET_BUS(); + I2C_SET_BUS(1); + + for (reg = 0; reg < sizeof(u); reg++) + if (i2c_write (IIC1_USB2507_ADDR, reg, 1, &u[reg], 1)) { + ret = -1; + break; + } + + if (ret == 0) { + stcd = 0x03; + if (i2c_write (IIC1_USB2507_ADDR, 0, 1, &stcd, 1)) + ret = -1; + } + + if (ret == 0) + printf("initialized\n"); + else + printf("failed - cannot initialize USB hub\n"); + + I2C_SET_BUS(oldbus); + return ret; +} + +int do_hubinit(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + usbhub_init(); + return 0; +} +U_BOOT_CMD( + hubinit, 1, 1, do_hubinit, + "hubinit - Initialize USB hub\n", + NULL + ); +#endif /* CONFIG_I2C_MULTI_BUS */ + +#define CFG_BOOT_EEPROM_PAGE_WRITE_BITS 3 +int boot_eeprom_write (unsigned dev_addr, + unsigned offset, + uchar *buffer, + unsigned cnt) +{ + unsigned end = offset + cnt; + unsigned blk_off; + int rcode = 0; + +#if defined(CFG_EEPROM_WREN) + eeprom_write_enable(dev_addr, 1); +#endif + /* Write data until done or would cross a write page boundary. + * We must write the address again when changing pages + * because the address counter only increments within a page. + */ + + while (offset < end) { + unsigned alen, len; + unsigned maxlen; + + uchar addr[2]; + + blk_off = offset & 0xFF; /* block offset */ + + addr[0] = offset >> 8; /* block number */ + addr[1] = blk_off; /* block offset */ + alen = 2; + addr[0] |= dev_addr; /* insert device address */ + + len = end - offset; + + /* + * For a FRAM device there is no limit on the number of the + * bytes that can be ccessed with the single read or write + * operation. + */ +#if defined(CFG_BOOT_EEPROM_PAGE_WRITE_BITS) + +#define BOOT_EEPROM_PAGE_SIZE (1 << CFG_BOOT_EEPROM_PAGE_WRITE_BITS) +#define BOOT_EEPROM_PAGE_OFFSET(x) ((x) & (BOOT_EEPROM_PAGE_SIZE - 1)) + + maxlen = BOOT_EEPROM_PAGE_SIZE - + BOOT_EEPROM_PAGE_OFFSET(blk_off); +#else + maxlen = 0x100 - blk_off; +#endif + if (maxlen > I2C_RXTX_LEN) + maxlen = I2C_RXTX_LEN; + + if (len > maxlen) + len = maxlen; + + if (i2c_write (addr[0], offset, alen - 1, buffer, len) != 0) + rcode = 1; + + buffer += len; + offset += len; + +#if defined(CFG_EEPROM_PAGE_WRITE_DELAY_MS) + udelay(CFG_EEPROM_PAGE_WRITE_DELAY_MS * 1000); +#endif + } +#if defined(CFG_EEPROM_WREN) + eeprom_write_enable(dev_addr, 0); +#endif + return rcode; +} + +int do_setup_boot_eeprom(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + ulong sdsdp[4]; + + if (argc > 1) { + if (!strcmp(argv[1], "533")) { + printf("Bootstrapping for 533MHz\n"); + sdsdp[0] = 0x87788252; + /* PLB-PCI-divider = 3 : sync PCI clock=44MHz */ + sdsdp[1] = 0x095fa030; + sdsdp[2] = 0x40082350; + sdsdp[3] = 0x0d050000; + } else if (!strcmp(argv[1], "533-66")) { + printf("Bootstrapping for 533MHz (66MHz PCI)\n"); + sdsdp[0] = 0x87788252; + /* PLB-PCI-divider = 2 : sync PCI clock=66MHz */ + sdsdp[1] = 0x0957a030; + sdsdp[2] = 0x40082350; + sdsdp[3] = 0x0d050000; + } else if (!strcmp(argv[1], "667")) { + printf("Bootstrapping for 667MHz\n"); + sdsdp[0] = 0x8778a256; + /* PLB-PCI-divider = 4 : sync PCI clock=33MHz */ + sdsdp[1] = 0x0947a030; + /* PLB-PCI-divider = 3 : sync PCI clock=44MHz + * -> not working when overclocking 533MHz chips + * -> untested on 667MHz chips */ + /* sdsdp[1]=0x095fa030; */ + sdsdp[2] = 0x40082350; + sdsdp[3] = 0x0d050000; + } + } else { + printf("Bootstrapping for 533MHz (default)\n"); + sdsdp[0] = 0x87788252; + /* PLB-PCI-divider = 3 : sync PCI clock=44MHz */ + sdsdp[1] = 0x095fa030; + sdsdp[2] = 0x40082350; + sdsdp[3] = 0x0d050000; + } + + printf("Writing boot EEPROM ...\n"); + if (boot_eeprom_write(CFG_I2C_BOOT_EEPROM_ADDR, + 0, (uchar*)sdsdp, 16) != 0) + printf("boot_eeprom_write failed\n"); + else + printf("done (dump via 'i2c md 52 0.1 10')\n"); + + return 0; +} +U_BOOT_CMD( + sbe, 2, 0, do_setup_boot_eeprom, + "sbe - setup boot eeprom\n", + NULL + ); + +#if defined(CFG_EEPROM_WREN) +/* Input: <dev_addr> I2C address of EEPROM device to enable. + * <state> -1: deliver current state + * 0: disable write + * 1: enable write + * Returns: -1: wrong device address + * 0: dis-/en- able done + * 0/1: current state if <state> was -1. + */ +int eeprom_write_enable (unsigned dev_addr, int state) +{ + if ((CFG_I2C_EEPROM_ADDR != dev_addr) && + (CFG_I2C_BOOT_EEPROM_ADDR != dev_addr)) + return -1; + else { + switch (state) { + case 1: + /* Enable write access, clear bit GPIO_SINT2. */ + out_be32((void*)GPIO0_OR, + in_be32((void*)GPIO0_OR) & ~CFG_GPIO0_EP_EEP); + state = 0; + break; + case 0: + /* Disable write access, set bit GPIO_SINT2. */ + out_be32((void*)GPIO0_OR, + in_be32((void*)GPIO0_OR) | CFG_GPIO0_EP_EEP); + state = 0; + break; + default: + /* Read current status back. */ + state = (0 == (in_be32((void*)GPIO0_OR) & + CFG_GPIO0_EP_EEP)); + break; + } + } + return state; +} + +int do_eep_wren (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + int query = argc == 1; + int state = 0; + + if (query) { + /* Query write access state. */ + state = eeprom_write_enable(CFG_I2C_EEPROM_ADDR, -1); + if (state < 0) + puts ("Query of write access state failed.\n"); + else { + printf ("Write access for device 0x%0x is %sabled.\n", + CFG_I2C_EEPROM_ADDR, state ? "en" : "dis"); + state = 0; + } + } else { + if ('0' == argv[1][0]) { + /* Disable write access. */ + state = eeprom_write_enable(CFG_I2C_EEPROM_ADDR, 0); + } else { + /* Enable write access. */ + state = eeprom_write_enable(CFG_I2C_EEPROM_ADDR, 1); + } + if (state < 0) + puts ("Setup of write access state failed.\n"); + } + + return state; +} + +U_BOOT_CMD(eepwren, 2, 0, do_eep_wren, + "eepwren - Enable / disable / query EEPROM write access\n", + NULL); +#endif /* #if defined(CFG_EEPROM_WREN) */ + + +static int got_pldirq; + +static int pld_interrupt(u32 arg) +{ + int rc = -1; /* not for us */ + u8 status = in8(CFG_CPLD_BASE); + + /* check for PLD interrupt */ + if (status & PWR_INT_FLAG) { + /* reset this int */ + out8(CFG_CPLD_BASE, 0); + rc = 0; + got_pldirq = 1; /* trigger backend */ + } + + return rc; +} + + +int do_waitpwrirq(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + got_pldirq = 0; + + /* clear any pending interrupt */ + out8(CFG_CPLD_BASE, 0); + + irq_install_handler(CPLD_IRQ, + (interrupt_handler_t *)pld_interrupt, 0); + + printf("Waiting ...\n"); + while(!got_pldirq) { + /* Abort if ctrl-c was pressed */ + if (ctrlc()) { + puts("\nAbort\n"); + break; + } + } + if (got_pldirq) { + printf("Got interrupt!\n"); + printf("Power %sready!\n", + in8(CFG_CPLD_BASE) & PWR_RDY ? "":"NOT "); + } + + irq_free_handler(CPLD_IRQ); + return 0; +} +U_BOOT_CMD( + wpi, 1, 1, do_waitpwrirq, + "wpi - Wait for power change interrupt\n", + NULL + ); + + +/* + * initialize DVI panellink transmitter + */ +int dvi_init(void) +{ + int i; + int ret = 0; + unsigned int oldbus; + uchar u[] = {0x08, 0x34, + 0x09, 0x20, + 0x0a, 0x90, + 0x0c, 0x89, + 0x08, 0x35}; + + printf("DVI: "); + + oldbus = I2C_GET_BUS(); + I2C_SET_BUS(0); + + for (i = 0; i < sizeof(u); i += 2) + if (i2c_write (0x38, u[i], 1, &u[i + 1], 1)) { + ret = -1; + break; + } + + if (ret == 0) + printf("initialized\n"); + else + printf("failed - cannot initialize DVI transmitter\n"); + + I2C_SET_BUS(oldbus); + return ret; +} + +int do_dviinit(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + dvi_init(); + return 0; +} +U_BOOT_CMD( + dviinit, 1, 1, do_dviinit, + "dviinit - Initialize DVI Panellink transmitter\n", + NULL + ); + + +#if 1 +/* + * TODO: 'time' command might be useful for others as well. + * Move to 'common' directory. + */ +int do_time(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + unsigned long long start, end; + char c, cmd[CFG_CBSIZE]; + char *p, *d = cmd; + int ret, i; + ulong us; + + for (i = 1; i < argc; i++) { + p = argv[i]; + + if (i > 1) + *d++ = ' '; + + while ((c = *p++) != '\0') { + *d++ = c; + } + } + *d = '\0'; + + start = get_ticks(); + ret = run_command (cmd, 0); + end = get_ticks(); + + printf("ticks=%d\n", (ulong)(end - start)); + us = (ulong)((1000L * (end - start)) / (get_tbclk() / 1000)); + printf("usec=%d\n", us); + + return ret; +} +U_BOOT_CMD( + time, CFG_MAXARGS, 1, do_time, + "time - run command and output execution time\n", + NULL + ); +#endif + +extern void video_hw_rectfill ( + unsigned int bpp, /* bytes per pixel */ + unsigned int dst_x, /* dest pos x */ + unsigned int dst_y, /* dest pos y */ + unsigned int dim_x, /* frame width */ + unsigned int dim_y, /* frame height */ + unsigned int color /* fill color */ + ); + +#if 0 +/* + * test commands for SM722 2D acceleration + */ +extern void video_hw_bitblt ( + unsigned int bpp, /* bytes per pixel */ + unsigned int src_x, /* source pos x */ + unsigned int src_y, /* source pos y */ + unsigned int dst_x, /* dest pos x */ + unsigned int dst_y, /* dest pos y */ + unsigned int dim_x, /* frame width */ + unsigned int dim_y /* frame height */ + ); + +extern void video_hw_drawline ( + unsigned int bpp, + unsigned int x1, + unsigned int y1, + unsigned int x2, + unsigned int y2, + unsigned int color + ); + +int do_gfxfill(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + unsigned int color = 0x0000f800; + unsigned int x=0, y=0, dx=100, dy=100; + + if (argc > 1) + color = simple_strtoul (argv[1], NULL, 16); + + if (argc > 2) + x = simple_strtoul (argv[2], NULL, 10); + + if (argc > 3) + y = simple_strtoul (argv[3], NULL, 10); + + if (argc > 4) + dx = simple_strtoul (argv[4], NULL, 10); + + if (argc > 5) + dy = simple_strtoul (argv[5], NULL, 10); + + video_hw_rectfill(2, x, y, dx, dy, color); + + return 0; +} +U_BOOT_CMD( + gfxfill, CFG_MAXARGS, 1, do_gfxfill, + "gfxfill - fill rect\n", + "[color] [x] [y] [dx] [dy]\n" + ); + +int do_gfxblt(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + unsigned int x=0, y=0, xd=500, yd=500, dx=100, dy=100; + + if (argc > 1) + x = simple_strtoul (argv[1], NULL, 10); + + if (argc > 2) + y = simple_strtoul (argv[2], NULL, 10); + + if (argc > 3) + xd = simple_strtoul (argv[3], NULL, 10); + + if (argc > 4) + yd = simple_strtoul (argv[4], NULL, 10); + + if (argc > 5) + dx = simple_strtoul (argv[5], NULL, 10); + + if (argc > 6) + dy = simple_strtoul (argv[6], NULL, 10); + + video_hw_bitblt(2, x, y, xd, yd, dx, dy); + + return 0; +} +U_BOOT_CMD( + gfxblt, CFG_MAXARGS, 1, do_gfxblt, + "gfxblt - bit blit\n", + "[x] [y] [xd] [yd] [dx] [dy]\n" + ); + + +int do_gfxline(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + unsigned int color = 0x0000001f; + unsigned int x1=0, y1=0, x2=100, y2=100; + + if (argc > 1) + color = simple_strtoul (argv[1], NULL, 16); + + if (argc > 2) + x1 = simple_strtoul (argv[2], NULL, 10); + + if (argc > 3) + y1 = simple_strtoul (argv[3], NULL, 10); + + if (argc > 4) + x2 = simple_strtoul (argv[4], NULL, 10); + + if (argc > 5) + y2 = simple_strtoul (argv[5], NULL, 10); + + video_hw_drawline(2, x1, y1, x2, y2, color); + + return 0; +} +U_BOOT_CMD( + gfxline, CFG_MAXARGS, 1, do_gfxline, + "gfxline - draw line\n", + "[color] [x1] [y1] [x2] [y2]\n" + ); +#endif + +/* + * graphics demo + * draw rectangles using pseudorandom number generator + * (see http://www.embedded.com/columns/technicalinsights/20900500) + */ +unsigned int rprime = 9972; +static unsigned int r; +static unsigned int Y; + +unsigned int prng(unsigned int max) +{ + if (r == 0 || r == 1 || r == -1) + r = rprime; /* keep from getting stuck */ + + r = (9973 * ~r) + ((Y) % 701); /* the actual algorithm */ + Y = (r >> 16) % max; /* choose upper bits and reduce */ + return Y; +} + +int do_gfxdemo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + unsigned int color; + unsigned int x, y, dx, dy; + + while (!ctrlc()) { + x = prng(1280 - 1); + y = prng(1024 - 1); + dx = prng(1280- x - 1); + dy = prng(1024 - y - 1); + color = prng(0x10000); + video_hw_rectfill(2, x, y, dx, dy, color); + } + + return 0; +} +U_BOOT_CMD( + gfxdemo, CFG_MAXARGS, 1, do_gfxdemo, + "gfxdemo - demo\n", + NULL + ); diff --git a/board/esd/du440/du440.h b/board/esd/du440/du440.h new file mode 100644 index 0000000..5c362e4 --- /dev/null +++ b/board/esd/du440/du440.h @@ -0,0 +1,42 @@ +/* + * (C) Copyright 2008 + * Matthias Fuchs, esd gmbh, matthias.fuchs@esd-electronics.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#define SDR0_USB0 0x0320 /* USB Control Register */ + +#define CFG_GPIO0_EP_EEP (0x80000000 >> 23) /* GPIO0_23 */ +#define CFG_GPIO1_DCF77 (0x80000000 >> (42-32)) /* GPIO1_42 */ + +#define CFG_GPIO1_IORSTN (0x80000000 >> (55-32)) /* GPIO1_55 */ + +#define CFG_GPIO1_HWVER_MASK 0x000000f0 /* GPIO1_56-59 */ +#define CFG_GPIO1_HWVER_SHIFT 4 +#define CFG_GPIO1_LEDUSR1 0x00000008 /* GPIO1_60 */ +#define CFG_GPIO1_LEDUSR2 0x00000004 /* GPIO1_61 */ +#define CFG_GPIO1_LEDPOST 0x00000002 /* GPIO1_62 */ +#define CFG_GPIO1_LEDDU 0x00000001 /* GPIO1_63 */ + +#define CPLD_VERSION_MASK 0x0f +#define PWR_INT_FLAG 0x80 +#define PWR_RDY 0x10 + +#define CPLD_IRQ (32+30) + +#define PCI_VENDOR_ID_ESDGMBH 0x12fe +#define PCI_DEVICE_ID_DU440 0x0444 diff --git a/board/esd/du440/init.S b/board/esd/du440/init.S new file mode 100644 index 0000000..1e15e72 --- /dev/null +++ b/board/esd/du440/init.S @@ -0,0 +1,80 @@ +/* + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <ppc_asm.tmpl> +#include <asm-ppc/mmu.h> +#include <config.h> + +/************************************************************************** + * TLB TABLE + * + * This table is used by the cpu boot code to setup the initial tlb + * entries. Rather than make broad assumptions in the cpu source tree, + * this table lets each board set things up however they like. + * + * Pointer to the table is returned in r1 + * + *************************************************************************/ + .section .bootpg,"ax" + .globl tlbtab + +tlbtab: + tlbtab_start + + /* + * BOOT_CS (FLASH) must be first. Before relocation SA_I can be off to use the + * speed up boot process. It is patched after relocation to enable SA_I + */ + tlbentry( CFG_BOOT_BASE_ADDR, SZ_256M, CFG_BOOT_BASE_ADDR, 1, AC_R|AC_W|AC_X|SA_G ) + +#ifdef CFG_INIT_RAM_DCACHE + /* TLB-entry for init-ram in dcache (SA_I must be turned off!) */ + tlbentry( CFG_INIT_RAM_ADDR, SZ_64K, CFG_INIT_RAM_ADDR, 0, AC_R|AC_W|AC_X|SA_G ) +#endif + + /* TLB-entry for PCI Memory */ + tlbentry( CFG_PCI_MEMBASE, SZ_256M, CFG_PCI_MEMBASE, 1, AC_R|AC_W|SA_G|SA_I ) + tlbentry( CFG_PCI_MEMBASE1, SZ_256M, CFG_PCI_MEMBASE1, 1, AC_R|AC_W|SA_G|SA_I ) + tlbentry( CFG_PCI_MEMBASE2, SZ_256M, CFG_PCI_MEMBASE2, 1, AC_R|AC_W|SA_G|SA_I ) + tlbentry( CFG_PCI_MEMBASE3, SZ_256M, CFG_PCI_MEMBASE3, 1, AC_R|AC_W|SA_G|SA_I ) + + /* TLB-entry for PCI IO */ + tlbentry( CFG_PCI_IOBASE, SZ_64K, CFG_PCI_IOBASE, 1, AC_R|AC_W|SA_G|SA_I ) + + /* TLB-entries for EBC: CPLD, DUMEM, DUIO */ + tlbentry( CFG_CPLD_BASE, SZ_1K, CFG_CPLD_BASE, 1, AC_R|AC_W|AC_X|SA_G|SA_I ) + tlbentry( CFG_DUMEM_BASE, SZ_1M, CFG_DUMEM_BASE, 1, AC_R|AC_W|AC_X|SA_G|SA_I ) + tlbentry( CFG_DUIO_BASE, SZ_64K, CFG_DUIO_BASE, 1, AC_R|AC_W|AC_X|SA_G|SA_I ) + + /* TLB-entry for NAND */ + tlbentry( CFG_NAND0_ADDR, SZ_1K, CFG_NAND0_ADDR, 1, AC_R|AC_W|AC_X|SA_G|SA_I ) + tlbentry( CFG_NAND1_ADDR, SZ_1K, CFG_NAND1_ADDR, 1, AC_R|AC_W|AC_X|SA_G|SA_I ) + + /* TLB-entry for Internal Registers & OCM */ + tlbentry( 0xe0000000, SZ_16M, 0xe0000000, 0, AC_R|AC_W|AC_X|SA_I ) + + /* TLB-entry PCI registers */ + tlbentry( 0xEEC00000, SZ_1K, 0xEEC00000, 1, AC_R|AC_W|AC_X|SA_G|SA_I ) + + /* TLB-entry for peripherals */ + tlbentry( 0xEF000000, SZ_16M, 0xEF000000, 1, AC_R|AC_W|AC_X|SA_G|SA_I) + + tlbtab_end diff --git a/board/esd/du440/u-boot.lds b/board/esd/du440/u-boot.lds new file mode 100644 index 0000000..a423f98 --- /dev/null +++ b/board/esd/du440/u-boot.lds @@ -0,0 +1,145 @@ +/* + * (C) Copyright 2002 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_ARCH(powerpc) +SEARCH_DIR(/lib); SEARCH_DIR(/usr/lib); SEARCH_DIR(/usr/local/lib); SEARCH_DIR(/usr/local/powerpc-any-elf/lib); +/* Do we need any of these for elf? + __DYNAMIC = 0; */ +SECTIONS +{ + .resetvec 0xFFFFFFFC : + { + *(.resetvec) + } = 0xffff + + .bootpg 0xFFFFF000 : + { + cpu/ppc4xx/start.o (.bootpg) + } = 0xffff + + /* Read-only sections, merged into text segment: */ + . = + SIZEOF_HEADERS; + .interp : { *(.interp) } + .hash : { *(.hash) } + .dynsym : { *(.dynsym) } + .dynstr : { *(.dynstr) } + .rel.text : { *(.rel.text) } + .rela.text : { *(.rela.text) } + .rel.data : { *(.rel.data) } + .rela.data : { *(.rela.data) } + .rel.rodata : { *(.rel.rodata) } + .rela.rodata : { *(.rela.rodata) } + .rel.got : { *(.rel.got) } + .rela.got : { *(.rela.got) } + .rel.ctors : { *(.rel.ctors) } + .rela.ctors : { *(.rela.ctors) } + .rel.dtors : { *(.rel.dtors) } + .rela.dtors : { *(.rela.dtors) } + .rel.bss : { *(.rel.bss) } + .rela.bss : { *(.rela.bss) } + .rel.plt : { *(.rel.plt) } + .rela.plt : { *(.rela.plt) } + .init : { *(.init) } + .plt : { *(.plt) } + .text : + { + /* WARNING - the following is hand-optimized to fit within */ + /* the sector layout of our flash chips! XXX FIXME XXX */ + + cpu/ppc4xx/start.o (.text) + + *(.text) + *(.fixup) + *(.got1) + } + _etext = .; + PROVIDE (etext = .); + .rodata : + { + *(.rodata) + *(.rodata1) + *(.rodata.str1.4) + } + .fini : { *(.fini) } =0 + .ctors : { *(.ctors) } + .dtors : { *(.dtors) } + + /* Read-write section, merged into data segment: */ + . = (. + 0x00FF) & 0xFFFFFF00; + _erotext = .; + PROVIDE (erotext = .); + .reloc : + { + *(.got) + _GOT2_TABLE_ = .; + *(.got2) + _FIXUP_TABLE_ = .; + *(.fixup) + } + __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >>2; + __fixup_entries = (. - _FIXUP_TABLE_)>>2; + + .data : + { + *(.data) + *(.data1) + *(.sdata) + *(.sdata2) + *(.dynamic) + CONSTRUCTORS + } + _edata = .; + PROVIDE (edata = .); + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + + . = .; + __start___ex_table = .; + __ex_table : { *(__ex_table) } + __stop___ex_table = .; + + . = ALIGN(256); + __init_begin = .; + .text.init : { *(.text.init) } + .data.init : { *(.data.init) } + . = ALIGN(256); + __init_end = .; + + __bss_start = .; + .bss : + { + *(.sbss) *(.scommon) + *(.dynbss) + *(.bss) + *(COMMON) + } + + ppcenv_assert = ASSERT(. < 0xFFFF8000, ".bss section too big, overlaps .ppcenv section. Please update your confguration: CFG_MONITOR_BASE, CFG_MONITOR_LEN and TEXT_BASE may need to be modified."); + + _end = . ; + PROVIDE (end = .); +}
- switch (gd->bd->bi_flashsize) {
- case 1 << 20:
size_val = 0;
break;
- case 2 << 20:
size_val = 1;
break;
- case 4 << 20:
size_val = 2;
break;
- case 8 << 20:
size_val = 3;
break;
- case 16 << 20:
size_val = 4;
break;
- case 32 << 20:
size_val = 5;
break;
- case 64 << 20:
size_val = 6;
break;
- case 128 << 20:
size_val = 7;
break;
Ummm...
#include <asm/bitops.h> ... size_val = ffs(gd->bd->bi_flashsize) - 21;
seems more straigtforward to me...
Here and elsewhere: this is not the requested style for multiline comments.
- out32r(PCIX0_PMM0MA, 0x00000000); /* PMM0 Mask/Attribute - disabled b4 setting */
- out32r(PCIX0_PMM0LA, CFG_PCI_MEMBASE); /* PMM0 Local Address */
- out32r(PCIX0_PMM0PCILA, CFG_PCI_MEMBASE); /* PMM0 PCI Low Address */
- out32r(PCIX0_PMM0PCIHA, 0x00000000); /* PMM0 PCI High Address */
- out32r(PCIX0_PMM0MA, 0xE0000001); /* 512M + No prefetching, and enable region */
- out32r(PCIX0_PMM1MA, 0x00000000); /* PMM0 Mask/Attribute - disabled b4 setting */
- out32r(PCIX0_PMM1LA, CFG_PCI_MEMBASE2); /* PMM0 Local Address */
- out32r(PCIX0_PMM1PCILA, CFG_PCI_MEMBASE2); /* PMM0 PCI Low Address */
- out32r(PCIX0_PMM1PCIHA, 0x00000000); /* PMM0 PCI High Address */
- out32r(PCIX0_PMM1MA, 0xE0000001); /* 512M + No prefetching, and enable region */
Please mind the maximum line length!
- /* Write data until done or would cross a write page boundary.
Please:
/* * Write data until...
+U_BOOT_CMD(
- dviinit, 1, 1, do_dviinit,
- "dviinit - Initialize DVI Panellink transmitter\n",
- NULL
+#if 1
Please remove the '#if 1' as it's redundant.
+#if 0 +/*
- test commands for SM722 2D acceleration
+U_BOOT_CMD(
- gfxline, CFG_MAXARGS, 1, do_gfxline,
- "gfxline - draw line\n",
- "[color] [x1] [y1] [x2] [y2]\n"
Please remove the dead code.
- project.
- MA 02111-1307 USA
Copyright missing.
You probably may want to adjust the (C) messages in some other files, too.
- __bss_start = .;
- .bss :
NOLOAD attribute missing. Please fix.
Hi Wolfgang,
as you might have noticed the DU440 board is havily based on seuqoia code. Nearly all of your comments apply to that board as well. I thought of the sequoia code as exemplary reference code. And I prefer not to reformat comments when copy and pasting from one board to another.
But if you really insist of these changes I will change the patch.
On Sunday 13 January 2008 23:08, Wolfgang Denk wrote:
Ummm...
Good idea. Thanks.
+#if 1
Ack.
+#if 0 +/*
+U_BOOT_CMD(
Please not. The DU440 board will get an updated smi_lynxem driver with support for the SM722 soon. My current hack is to dirty for submission and I just got some more register dumps from SM to support more videomodes. I will need this commented out code to test it. I plan to remove it later.
- project.
- MA 02111-1307 USA
Copyright missing.
Ack. May I put my name on it? The source of this code has no copyright either.
- __bss_start = .;
- .bss :
This is new to me. But I just noticed that all other boards have been updated according to this. So will I.
I will update my patches. Perhaps you can comment on my comments above.
Matthias
Dear Matthias,
No, I wasn't aware of this.
Hm. So I have to talk with the maintainer of this board - especially how he managed to run this through the custodian without public review. Stefan, how did he bribe you? :-)
Please do. Ideally, please include the Sequoia in your cleanup, too.
+#if 0 +/*
+U_BOOT_CMD(
Please remove it. We use source code management systems to maintain test code etc. If it's "#if 0" is has no place in the public code.
Stefan???
- __bss_start = .;
- .bss :
Thanks.
Done :-)
I will update the DU440 patch tonight and also update the sequoia sources in the same manner. So Stefan can lean back :-)
Matthias
On Monday 14 January 2008 10:45, Wolfgang Denk wrote:
Dear Matthias,
+#if 0 +/*
+U_BOOT_CMD(
Stefan???
- __bss_start = .;
- .bss :
Thanks.
Done :-)
/me leans back and keeps busy with other high priority stuff. :)
Thanks Matthias!
Best regards, Stefan
Signed-off-by: Matthias Fuchs matthias.fuchs@esd-electronics.com --- board/amcc/sequoia/init.S | 7 +- board/amcc/sequoia/sequoia.c | 256 ++++++++++++++++++++---------------------- 2 files changed, 124 insertions(+), 139 deletions(-)
diff --git a/board/amcc/sequoia/init.S b/board/amcc/sequoia/init.S index ff6ae66..563f518 100644 --- a/board/amcc/sequoia/init.S +++ b/board/amcc/sequoia/init.S @@ -1,4 +1,6 @@ /* + * (C) Copyright 2008 + * Stefan Roese, DENX Software Engineering, sr@denx.de. * * See file CREDITS for list of people who contributed to this * project. @@ -23,7 +25,7 @@ #include <asm-ppc/mmu.h> #include <config.h>
-/************************************************************************** +/* * TLB TABLE * * This table is used by the cpu boot code to setup the initial tlb @@ -31,8 +33,7 @@ * this table lets each board set things up however they like. * * Pointer to the table is returned in r1 - * - *************************************************************************/ + */ .section .bootpg,"ax" .globl tlbtab
diff --git a/board/amcc/sequoia/sequoia.c b/board/amcc/sequoia/sequoia.c index e46efef..0cccfd2 100644 --- a/board/amcc/sequoia/sequoia.c +++ b/board/amcc/sequoia/sequoia.c @@ -4,7 +4,7 @@ * * (C) Copyright 2006 * Jacqueline Pira-Ferriol, AMCC/IBM, jpira-ferriol@fr.ibm.com - * Alain Saurel, AMCC/IBM, alain.saurel@fr.ibm.com + * Alain Saurel, AMCC/IBM, alain.saurel@fr.ibm.com * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License as @@ -29,11 +29,12 @@ #include <asm/gpio.h> #include <asm/processor.h> #include <asm/io.h> +#include <asm/bitops.h> #include <asm/ppc4xx-intvec.h>
-extern flash_info_t flash_info[CFG_MAX_FLASH_BANKS]; /* info for FLASH chips */ +extern flash_info_t flash_info[CFG_MAX_FLASH_BANKS]; /* info for FLASH chips */
@@ -46,9 +47,9 @@ int board_early_init_f(void) mtdcr(ebccfga, xbcfg); mtdcr(ebccfgd, 0xb8400000);
- /*-------------------------------------------------------------------- + /* * Setup the interrupt controller polarities, triggers, etc. - *-------------------------------------------------------------------*/ + */ mtdcr(uic0sr, 0xffffffff); /* clear all */ mtdcr(uic0er, 0x00000000); /* disable all */ mtdcr(uic0cr, 0x00000005); /* ATI & UIC1 crit are critical */ @@ -87,9 +88,11 @@ int board_early_init_f(void)
/* select Ethernet pins */ mfsdr(SDR0_PFC1, sdr0_pfc1); - sdr0_pfc1 = (sdr0_pfc1 & ~SDR0_PFC1_SELECT_MASK) | SDR0_PFC1_SELECT_CONFIG_4; + sdr0_pfc1 = (sdr0_pfc1 & ~SDR0_PFC1_SELECT_MASK) | + SDR0_PFC1_SELECT_CONFIG_4; mfsdr(SDR0_PFC2, sdr0_pfc2); - sdr0_pfc2 = (sdr0_pfc2 & ~SDR0_PFC2_SELECT_MASK) | SDR0_PFC2_SELECT_CONFIG_4; + sdr0_pfc2 = (sdr0_pfc2 & ~SDR0_PFC2_SELECT_MASK) | + SDR0_PFC2_SELECT_CONFIG_4; mtsdr(SDR0_PFC2, sdr0_pfc2); mtsdr(SDR0_PFC1, sdr0_pfc1);
@@ -109,9 +112,7 @@ int board_early_init_f(void) return 0; }
-/*---------------------------------------------------------------------------+ - | misc_init_r. - +---------------------------------------------------------------------------*/ + int misc_init_r(void) { uint pbcr; @@ -124,11 +125,7 @@ int misc_init_r(void) char *act = getenv("usbact"); #endif
- /* - * FLASH stuff... - */ - - /* Re-do sizing to get full correct info */ + /* Re-do flash sizing to get full correct info */
/* adjust flash start and offset */ gd->bd->bi_flashstart = 0 - gd->bd->bi_flashsize; @@ -140,32 +137,7 @@ int misc_init_r(void) mtdcr(ebccfga, pb0cr); #endif pbcr = mfdcr(ebccfgd); - switch (gd->bd->bi_flashsize) { - case 1 << 20: - size_val = 0; - break; - case 2 << 20: - size_val = 1; - break; - case 4 << 20: - size_val = 2; - break; - case 8 << 20: - size_val = 3; - break; - case 16 << 20: - size_val = 4; - break; - case 32 << 20: - size_val = 5; - break; - case 64 << 20: - size_val = 6; - break; - case 128 << 20: - size_val = 7; - break; - } + size_val = ffs(gd->bd->bi_flashsize) - 21; pbcr = (pbcr & 0x0001ffff) | gd->bd->bi_flashstart | (size_val << 17); #if defined(CONFIG_NAND_U_BOOT) || defined(CONFIG_NAND_SPL) mtdcr(ebccfga, pb3cr); @@ -197,7 +169,7 @@ int misc_init_r(void) * USB suff... */ #ifdef CONFIG_440EPX - if (act == NULL || strcmp(act, "hostdev") == 0) { + if (act == NULL || strcmp(act, "hostdev") == 0) { /* SDR Setting */ mfsdr(SDR0_PFC1, sdr0_pfc1); mfsdr(SDR0_USB2D0CR, usb2d0cr); @@ -205,27 +177,32 @@ int misc_init_r(void) mfsdr(SDR0_USB2H0CR, usb2h0cr);
usb2phy0cr = usb2phy0cr &~SDR0_USB2PHY0CR_XOCLK_MASK; - usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_XOCLK_EXTERNAL; /*0*/ + usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_XOCLK_EXTERNAL; usb2phy0cr = usb2phy0cr &~SDR0_USB2PHY0CR_WDINT_MASK; - usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_WDINT_16BIT_30MHZ; /*1*/ + usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_WDINT_16BIT_30MHZ; usb2phy0cr = usb2phy0cr &~SDR0_USB2PHY0CR_DVBUS_MASK; - usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_DVBUS_PURDIS; /*0*/ + usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_DVBUS_PURDIS; usb2phy0cr = usb2phy0cr &~SDR0_USB2PHY0CR_DWNSTR_MASK; - usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_DWNSTR_HOST; /*1*/ + usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_DWNSTR_HOST; usb2phy0cr = usb2phy0cr &~SDR0_USB2PHY0CR_UTMICN_MASK; - usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_UTMICN_HOST; /*1*/ + usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_UTMICN_HOST;
- /* An 8-bit/60MHz interface is the only possible alternative - when connecting the Device to the PHY */ + /* + * An 8-bit/60MHz interface is the only possible alternative + * when connecting the Device to the PHY + */ usb2h0cr = usb2h0cr &~SDR0_USB2H0CR_WDINT_MASK; - usb2h0cr = usb2h0cr | SDR0_USB2H0CR_WDINT_16BIT_30MHZ; /*1*/ + usb2h0cr = usb2h0cr | SDR0_USB2H0CR_WDINT_16BIT_30MHZ;
- /* To enable the USB 2.0 Device function through the UTMI interface */ + /* + * To enable the USB 2.0 Device function + * through the UTMI interface + */ usb2d0cr = usb2d0cr &~SDR0_USB2D0CR_USB2DEV_EBC_SEL_MASK; - usb2d0cr = usb2d0cr | SDR0_USB2D0CR_USB2DEV_SELECTION; /*1*/ + usb2d0cr = usb2d0cr | SDR0_USB2D0CR_USB2DEV_SELECTION;
sdr0_pfc1 = sdr0_pfc1 &~SDR0_PFC1_UES_MASK; - sdr0_pfc1 = sdr0_pfc1 | SDR0_PFC1_UES_USB2D_SEL; /*0*/ + sdr0_pfc1 = sdr0_pfc1 | SDR0_PFC1_UES_USB2D_SEL;
mtsdr(SDR0_PFC1, sdr0_pfc1); mtsdr(SDR0_USB2D0CR, usb2d0cr); @@ -245,13 +222,13 @@ int misc_init_r(void) mfsdr(SDR0_USB2PHY0CR, usb2phy0cr);
usb2phy0cr = usb2phy0cr &~SDR0_USB2PHY0CR_XOCLK_MASK; - usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_XOCLK_EXTERNAL; /*0*/ + usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_XOCLK_EXTERNAL; usb2phy0cr = usb2phy0cr &~SDR0_USB2PHY0CR_DVBUS_MASK; - usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_DVBUS_PURDIS; /*0*/ + usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_DVBUS_PURDIS; usb2phy0cr = usb2phy0cr &~SDR0_USB2PHY0CR_DWNSTR_MASK; - usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_DWNSTR_HOST; /*1*/ + usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_DWNSTR_HOST; usb2phy0cr = usb2phy0cr &~SDR0_USB2PHY0CR_UTMICN_MASK; - usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_UTMICN_HOST; /*1*/ + usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_UTMICN_HOST; mtsdr(SDR0_USB2PHY0CR, usb2phy0cr);
udelay (1000); @@ -276,31 +253,31 @@ int misc_init_r(void) mfsdr(SDR0_PFC1, sdr0_pfc1);
usb2phy0cr = usb2phy0cr &~SDR0_USB2PHY0CR_XOCLK_MASK; - usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_XOCLK_EXTERNAL; /*0*/ + usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_XOCLK_EXTERNAL; usb2phy0cr = usb2phy0cr &~SDR0_USB2PHY0CR_WDINT_MASK; - usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_WDINT_8BIT_60MHZ; /*0*/ + usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_WDINT_8BIT_60MHZ; usb2phy0cr = usb2phy0cr &~SDR0_USB2PHY0CR_DVBUS_MASK; - usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_DVBUS_PUREN; /*1*/ + usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_DVBUS_PUREN; usb2phy0cr = usb2phy0cr &~SDR0_USB2PHY0CR_DWNSTR_MASK; - usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_DWNSTR_DEV; /*0*/ + usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_DWNSTR_DEV; usb2phy0cr = usb2phy0cr &~SDR0_USB2PHY0CR_UTMICN_MASK; - usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_UTMICN_DEV; /*0*/ + usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_UTMICN_DEV;
usb2h0cr = usb2h0cr &~SDR0_USB2H0CR_WDINT_MASK; - usb2h0cr = usb2h0cr | SDR0_USB2H0CR_WDINT_8BIT_60MHZ; /*0*/ + usb2h0cr = usb2h0cr | SDR0_USB2H0CR_WDINT_8BIT_60MHZ;
usb2d0cr = usb2d0cr &~SDR0_USB2D0CR_USB2DEV_EBC_SEL_MASK; - usb2d0cr = usb2d0cr | SDR0_USB2D0CR_EBC_SELECTION; /*0*/ + usb2d0cr = usb2d0cr | SDR0_USB2D0CR_EBC_SELECTION;
sdr0_pfc1 = sdr0_pfc1 &~SDR0_PFC1_UES_MASK; - sdr0_pfc1 = sdr0_pfc1 | SDR0_PFC1_UES_EBCHR_SEL; /*1*/ + sdr0_pfc1 = sdr0_pfc1 | SDR0_PFC1_UES_EBCHR_SEL;
mtsdr(SDR0_USB2H0CR, usb2h0cr); mtsdr(SDR0_USB2PHY0CR, usb2phy0cr); mtsdr(SDR0_USB2D0CR, usb2d0cr); mtsdr(SDR0_PFC1, sdr0_pfc1);
- /*clear resets*/ + /* clear resets */ udelay (1000); mtsdr(SDR0_SRST1, 0x00000000); udelay (1000); @@ -325,6 +302,7 @@ int misc_init_r(void) return 0; }
+ int checkboard(void) { char *s = getenv("serial#"); @@ -350,6 +328,7 @@ int checkboard(void) return (0); }
+ #if defined(CFG_DRAM_TEST) int testdram(void) { @@ -388,6 +367,7 @@ int testdram(void) } #endif
+ #if defined(CONFIG_PCI) && defined(CONFIG_PCI_PNP) /* * Assign interrupts to PCI devices. @@ -398,43 +378,43 @@ void sequoia_pci_fixup_irq(struct pci_controller *hose, pci_dev_t dev) } #endif
-/************************************************************************* - * pci_pre_init - * - * This routine is called just prior to registering the hose and gives - * the board the opportunity to check things. Returning a value of zero - * indicates that things are bad & PCI initialization should be aborted. + +/* + * pci_pre_init * - * Different boards may wish to customize the pci controller structure - * (add regions, override default access routines, etc) or perform - * certain pre-initialization actions. + * This routine is called just prior to registering the hose and gives + * the board the opportunity to check things. Returning a value of zero + * indicates that things are bad & PCI initialization should be aborted. * - ************************************************************************/ + * Different boards may wish to customize the pci controller structure + * (add regions, override default access routines, etc) or perform + * certain pre-initialization actions. + */ #if defined(CONFIG_PCI) int pci_pre_init(struct pci_controller *hose) { unsigned long addr;
- /*-------------------------------------------------------------------------+ - | Set priority for all PLB3 devices to 0. - | Set PLB3 arbiter to fair mode. - +-------------------------------------------------------------------------*/ + /* + * Set priority for all PLB3 devices to 0. + * Set PLB3 arbiter to fair mode. + */ mfsdr(sdr_amp1, addr); mtsdr(sdr_amp1, (addr & 0x000000FF) | 0x0000FF00); addr = mfdcr(plb3_acr); mtdcr(plb3_acr, addr | 0x80000000);
- /*-------------------------------------------------------------------------+ - | Set priority for all PLB4 devices to 0. - +-------------------------------------------------------------------------*/ + /* + * Set priority for all PLB4 devices to 0. + */ mfsdr(sdr_amp0, addr); mtsdr(sdr_amp0, (addr & 0x000000FF) | 0x0000FF00); addr = mfdcr(plb4_acr) | 0xa0000000; /* Was 0x8---- */ mtdcr(plb4_acr, addr);
- /*-------------------------------------------------------------------------+ - | Set Nebula PLB4 arbiter to fair mode. - +-------------------------------------------------------------------------*/ + /* + * Set Nebula PLB4 arbiter to fair mode. + */ /* Segment0 */ addr = (mfdcr(plb0_acr) & ~plb0_acr_ppm_mask) | plb0_acr_ppm_fair; addr = (addr & ~plb0_acr_hbu_mask) | plb0_acr_hbu_enabled; @@ -456,47 +436,52 @@ int pci_pre_init(struct pci_controller *hose) } #endif /* defined(CONFIG_PCI) */
-/************************************************************************* - * pci_target_init - * - * The bootstrap configuration provides default settings for the pci - * inbound map (PIM). But the bootstrap config choices are limited and - * may not be sufficient for a given board. + +/* + * pci_target_init * - ************************************************************************/ + * The bootstrap configuration provides default settings for the pci + * inbound map (PIM). But the bootstrap config choices are limited and + * may not be sufficient for a given board. + */ #if defined(CONFIG_PCI) && defined(CFG_PCI_TARGET_INIT) void pci_target_init(struct pci_controller *hose) { - /*--------------------------------------------------------------------------+ + /* * Set up Direct MMIO registers - *--------------------------------------------------------------------------*/ - /*--------------------------------------------------------------------------+ - | PowerPC440EPX PCI Master configuration. - | Map one 1Gig range of PLB/processor addresses to PCI memory space. - | PLB address 0xA0000000-0xDFFFFFFF ==> PCI address 0xA0000000-0xDFFFFFFF - | Use byte reversed out routines to handle endianess. - | Make this region non-prefetchable. - +--------------------------------------------------------------------------*/ - out32r(PCIX0_PMM0MA, 0x00000000); /* PMM0 Mask/Attribute - disabled b4 setting */ + */ + /* + * PowerPC440EPX PCI Master configuration. + * Map one 1Gig range of PLB/processor addresses to PCI memory space. + * PLB address 0xA0000000-0xDFFFFFFF + * ==> PCI address 0xA0000000-0xDFFFFFFF + * Use byte reversed out routines to handle endianess. + * Make this region non-prefetchable. + */ + out32r(PCIX0_PMM0MA, 0x00000000); /* PMM0 Mask/Attribute */ + /* - disabled b4 setting */ out32r(PCIX0_PMM0LA, CFG_PCI_MEMBASE); /* PMM0 Local Address */ - out32r(PCIX0_PMM0PCILA, CFG_PCI_MEMBASE); /* PMM0 PCI Low Address */ + out32r(PCIX0_PMM0PCILA, CFG_PCI_MEMBASE); /* PMM0 PCI Low Address */ out32r(PCIX0_PMM0PCIHA, 0x00000000); /* PMM0 PCI High Address */ - out32r(PCIX0_PMM0MA, 0xE0000001); /* 512M + No prefetching, and enable region */ + out32r(PCIX0_PMM0MA, 0xE0000001); /* 512M + No prefetching, */ + /* and enable region */
- out32r(PCIX0_PMM1MA, 0x00000000); /* PMM0 Mask/Attribute - disabled b4 setting */ + out32r(PCIX0_PMM1MA, 0x00000000); /* PMM0 Mask/Attribute */ + /* - disabled b4 setting */ out32r(PCIX0_PMM1LA, CFG_PCI_MEMBASE2); /* PMM0 Local Address */ - out32r(PCIX0_PMM1PCILA, CFG_PCI_MEMBASE2); /* PMM0 PCI Low Address */ + out32r(PCIX0_PMM1PCILA, CFG_PCI_MEMBASE2); /* PMM0 PCI Low Address */ out32r(PCIX0_PMM1PCIHA, 0x00000000); /* PMM0 PCI High Address */ - out32r(PCIX0_PMM1MA, 0xE0000001); /* 512M + No prefetching, and enable region */ + out32r(PCIX0_PMM1MA, 0xE0000001); /* 512M + No prefetching, */ + /* and enable region */
out32r(PCIX0_PTM1MS, 0x00000001); /* Memory Size/Attribute */ - out32r(PCIX0_PTM1LA, 0); /* Local Addr. Reg */ - out32r(PCIX0_PTM2MS, 0); /* Memory Size/Attribute */ - out32r(PCIX0_PTM2LA, 0); /* Local Addr. Reg */ + out32r(PCIX0_PTM1LA, 0); /* Local Addr. Reg */ + out32r(PCIX0_PTM2MS, 0); /* Memory Size/Attribute */ + out32r(PCIX0_PTM2LA, 0); /* Local Addr. Reg */
- /*--------------------------------------------------------------------------+ + /* * Set up Configuration registers - *--------------------------------------------------------------------------*/ + */
/* Program the board's subsystem id/vendor id */ pci_write_config_word(0, PCI_SUBSYSTEM_VENDOR_ID, @@ -515,51 +500,49 @@ void pci_target_init(struct pci_controller *hose) pci_write_config_dword(0, PCI_BRDGOPT2, 0x00000101);
} -#endif /* defined(CONFIG_PCI) && defined(CFG_PCI_TARGET_INIT) */ +#endif /* defined(CONFIG_PCI) && defined(CFG_PCI_TARGET_INIT) */ +
-/************************************************************************* - * pci_master_init - * - ************************************************************************/ #if defined(CONFIG_PCI) && defined(CFG_PCI_MASTER_INIT) void pci_master_init(struct pci_controller *hose) { unsigned short temp_short;
- /*--------------------------------------------------------------------------+ - | Write the PowerPC440 EP PCI Configuration regs. - | Enable PowerPC440 EP to be a master on the PCI bus (PMM). - | Enable PowerPC440 EP to act as a PCI memory target (PTM). - +--------------------------------------------------------------------------*/ + /* + * Write the PowerPC440 EP PCI Configuration regs. + * Enable PowerPC440 EP to be a master on the PCI bus (PMM). + * Enable PowerPC440 EP to act as a PCI memory target (PTM). + */ pci_read_config_word(0, PCI_COMMAND, &temp_short); pci_write_config_word(0, PCI_COMMAND, temp_short | PCI_COMMAND_MASTER | PCI_COMMAND_MEMORY); } -#endif /* defined(CONFIG_PCI) && defined(CFG_PCI_MASTER_INIT) */ +#endif /* defined(CONFIG_PCI) && defined(CFG_PCI_MASTER_INIT) */
-/************************************************************************* - * is_pci_host - * - * This routine is called to determine if a pci scan should be - * performed. With various hardware environments (especially cPCI and - * PPMC) it's insufficient to depend on the state of the arbiter enable - * bit in the strap register, or generic host/adapter assumptions. - * - * Rather than hard-code a bad assumption in the general 440 code, the - * 440 pci code requires the board to decide at runtime. + +/* + * is_pci_host * - * Return 0 for adapter mode, non-zero for host (monarch) mode. + * This routine is called to determine if a pci scan should be + * performed. With various hardware environments (especially cPCI and + * PPMC) it's insufficient to depend on the state of the arbiter enable + * bit in the strap register, or generic host/adapter assumptions. * + * Rather than hard-code a bad assumption in the general 440 code, the + * 440 pci code requires the board to decide at runtime. * - ************************************************************************/ + * Return 0 for adapter mode, non-zero for host (monarch) mode. + */ #if defined(CONFIG_PCI) int is_pci_host(struct pci_controller *hose) { /* Cactus is always configured as host. */ return (1); } -#endif /* defined(CONFIG_PCI) */ +#endif /* defined(CONFIG_PCI) */ + + #if defined(CONFIG_POST) /* * Returns 1 if keys pressed to start the power-on long-running tests @@ -571,6 +554,7 @@ int post_hotkeys_pressed(void) } #endif /* CONFIG_POST */
+ #if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) void ft_board_setup(void *blob, bd_t *bd) {
Thanks.
One thing I don't like (anymore) though: You patch adds 2 newlines between the functions. I prefer 1 empty line now. Could you please resend the patch with only 1 newline between the functions?
Thanks.
Signed-off-by: Matthias Fuchs matthias.fuchs@esd-electronics.com --- board/amcc/sequoia/init.S | 7 +- board/amcc/sequoia/sequoia.c | 246 +++++++++++++++++++----------------------- 2 files changed, 114 insertions(+), 139 deletions(-)
diff --git a/board/amcc/sequoia/sequoia.c b/board/amcc/sequoia/sequoia.c index e46efef..ce0537f 100644 --- a/board/amcc/sequoia/sequoia.c +++ b/board/amcc/sequoia/sequoia.c @@ -4,7 +4,7 @@ * * (C) Copyright 2006 * Jacqueline Pira-Ferriol, AMCC/IBM, jpira-ferriol@fr.ibm.com - * Alain Saurel, AMCC/IBM, alain.saurel@fr.ibm.com + * Alain Saurel, AMCC/IBM, alain.saurel@fr.ibm.com * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License as @@ -29,11 +29,12 @@ #include <asm/gpio.h> #include <asm/processor.h> #include <asm/io.h> +#include <asm/bitops.h> #include <asm/ppc4xx-intvec.h>
DECLARE_GLOBAL_DATA_PTR;
ulong flash_get_size (ulong base, int banknum);
@@ -109,9 +112,6 @@ int board_early_init_f(void) return 0; }
-/*---------------------------------------------------------------------------+ - | misc_init_r. - +---------------------------------------------------------------------------*/ int misc_init_r(void) { uint pbcr; @@ -124,11 +124,7 @@ int misc_init_r(void) char *act = getenv("usbact"); #endif
/* adjust flash start and offset */ gd->bd->bi_flashstart = 0 - gd->bd->bi_flashsize; @@ -140,32 +136,7 @@ int misc_init_r(void) mtdcr(ebccfga, pb0cr); #endif pbcr = mfdcr(ebccfgd); - switch (gd->bd->bi_flashsize) { - case 1 << 20: - size_val = 0; - break; - case 2 << 20: - size_val = 1; - break; - case 4 << 20: - size_val = 2; - break; - case 8 << 20: - size_val = 3; - break; - case 16 << 20: - size_val = 4; - break; - case 32 << 20: - size_val = 5; - break; - case 64 << 20: - size_val = 6; - break; - case 128 << 20: - size_val = 7; - break; - } + size_val = ffs(gd->bd->bi_flashsize) - 21; pbcr = (pbcr & 0x0001ffff) | gd->bd->bi_flashstart | (size_val << 17); #if defined(CONFIG_NAND_U_BOOT) || defined(CONFIG_NAND_SPL) mtdcr(ebccfga, pb3cr); @@ -197,7 +168,7 @@ int misc_init_r(void) * USB suff... */ #ifdef CONFIG_440EPX - if (act == NULL || strcmp(act, "hostdev") == 0) { + if (act == NULL || strcmp(act, "hostdev") == 0) { /* SDR Setting */ mfsdr(SDR0_PFC1, sdr0_pfc1); mfsdr(SDR0_USB2D0CR, usb2d0cr); @@ -205,27 +176,32 @@ int misc_init_r(void) mfsdr(SDR0_USB2H0CR, usb2h0cr);
mtsdr(SDR0_PFC1, sdr0_pfc1); mtsdr(SDR0_USB2D0CR, usb2d0cr); @@ -245,13 +221,13 @@ int misc_init_r(void) mfsdr(SDR0_USB2PHY0CR, usb2phy0cr);
udelay (1000); @@ -276,31 +252,31 @@ int misc_init_r(void) mfsdr(SDR0_PFC1, sdr0_pfc1);
- /*clear resets*/ + /* clear resets */ udelay (1000); mtsdr(SDR0_SRST1, 0x00000000); udelay (1000); @@ -398,43 +374,42 @@ void sequoia_pci_fixup_irq(struct pci_controller *hose, pci_dev_t dev) } #endif
-/************************************************************************* - * pci_pre_init - * - * This routine is called just prior to registering the hose and gives - * the board the opportunity to check things. Returning a value of zero - * indicates that things are bad & PCI initialization should be aborted. +/* + * pci_pre_init * - * Different boards may wish to customize the pci controller structure - * (add regions, override default access routines, etc) or perform - * certain pre-initialization actions. + * This routine is called just prior to registering the hose and gives + * the board the opportunity to check things. Returning a value of zero + * indicates that things are bad & PCI initialization should be aborted. * - ************************************************************************/ + * Different boards may wish to customize the pci controller structure + * (add regions, override default access routines, etc) or perform + * certain pre-initialization actions. + */ #if defined(CONFIG_PCI) int pci_pre_init(struct pci_controller *hose) { unsigned long addr;
- /*-------------------------------------------------------------------------+ - | Set Nebula PLB4 arbiter to fair mode. - +-------------------------------------------------------------------------*/ + /* + * Set Nebula PLB4 arbiter to fair mode. + */ /* Segment0 */ addr = (mfdcr(plb0_acr) & ~plb0_acr_ppm_mask) | plb0_acr_ppm_fair; addr = (addr & ~plb0_acr_hbu_mask) | plb0_acr_hbu_enabled; @@ -456,47 +431,51 @@ int pci_pre_init(struct pci_controller *hose) } #endif /* defined(CONFIG_PCI) */
-/************************************************************************* - * pci_target_init - * - * The bootstrap configuration provides default settings for the pci - * inbound map (PIM). But the bootstrap config choices are limited and - * may not be sufficient for a given board. +/* + * pci_target_init * - ************************************************************************/ + * The bootstrap configuration provides default settings for the pci + * inbound map (PIM). But the bootstrap config choices are limited and + * may not be sufficient for a given board. + */ #if defined(CONFIG_PCI) && defined(CFG_PCI_TARGET_INIT) void pci_target_init(struct pci_controller *hose) { - /*--------------------------------------------------------------------------+ + /* * Set up Direct MMIO registers - *--------------------------------------------------------------------------*/ - /*--------------------------------------------------------------------------+ - | PowerPC440EPX PCI Master configuration. - | Map one 1Gig range of PLB/processor addresses to PCI memory space. - | PLB address 0xA0000000-0xDFFFFFFF ==> PCI address 0xA0000000-0xDFFFFFFF - | Use byte reversed out routines to handle endianess. - | Make this region non-prefetchable. - +--------------------------------------------------------------------------*/ - out32r(PCIX0_PMM0MA, 0x00000000); /* PMM0 Mask/Attribute - disabled b4 setting */ + */ + /* + * PowerPC440EPX PCI Master configuration. + * Map one 1Gig range of PLB/processor addresses to PCI memory space. + * PLB address 0xA0000000-0xDFFFFFFF + * ==> PCI address 0xA0000000-0xDFFFFFFF + * Use byte reversed out routines to handle endianess. + * Make this region non-prefetchable. + */ + out32r(PCIX0_PMM0MA, 0x00000000); /* PMM0 Mask/Attribute */ + /* - disabled b4 setting */ out32r(PCIX0_PMM0LA, CFG_PCI_MEMBASE); /* PMM0 Local Address */ - out32r(PCIX0_PMM0PCILA, CFG_PCI_MEMBASE); /* PMM0 PCI Low Address */ + out32r(PCIX0_PMM0PCILA, CFG_PCI_MEMBASE); /* PMM0 PCI Low Address */ out32r(PCIX0_PMM0PCIHA, 0x00000000); /* PMM0 PCI High Address */ - out32r(PCIX0_PMM0MA, 0xE0000001); /* 512M + No prefetching, and enable region */ + out32r(PCIX0_PMM0MA, 0xE0000001); /* 512M + No prefetching, */ + /* and enable region */
/* Program the board's subsystem id/vendor id */ pci_write_config_word(0, PCI_SUBSYSTEM_VENDOR_ID, @@ -515,51 +494,46 @@ void pci_target_init(struct pci_controller *hose) pci_write_config_dword(0, PCI_BRDGOPT2, 0x00000101);
-/************************************************************************* - * is_pci_host - * - * This routine is called to determine if a pci scan should be - * performed. With various hardware environments (especially cPCI and - * PPMC) it's insufficient to depend on the state of the arbiter enable - * bit in the strap register, or generic host/adapter assumptions. - * - * Rather than hard-code a bad assumption in the general 440 code, the - * 440 pci code requires the board to decide at runtime. +/* + * is_pci_host * - * Return 0 for adapter mode, non-zero for host (monarch) mode. + * This routine is called to determine if a pci scan should be + * performed. With various hardware environments (especially cPCI and + * PPMC) it's insufficient to depend on the state of the arbiter enable + * bit in the strap register, or generic host/adapter assumptions. * + * Rather than hard-code a bad assumption in the general 440 code, the + * 440 pci code requires the board to decide at runtime. * - ************************************************************************/ + * Return 0 for adapter mode, non-zero for host (monarch) mode. + */ #if defined(CONFIG_PCI) int is_pci_host(struct pci_controller *hose) { /* Cactus is always configured as host. */ return (1); } -#endif /* defined(CONFIG_PCI) */ +#endif /* defined(CONFIG_PCI) */ + #if defined(CONFIG_POST) /* * Returns 1 if keys pressed to start the power-on long-running tests
Applied, thanks.
Stefan,
You should not lean back! There are a couple of coding style issue's in makalu.c and kilauea.c (very long lines, comment format). I cannot understand how these files made it into the repository:-)
Matthias
Signed-off-by: Matthias Fuchs matthias.fuchs@esd-electronics.com --- board/esd/du440/Makefile | 51 +++ board/esd/du440/config.mk | 41 ++ board/esd/du440/du440.c | 1018 ++++++++++++++++++++++++++++++++++++++++++++ board/esd/du440/du440.h | 42 ++ board/esd/du440/init.S | 81 ++++ board/esd/du440/u-boot.lds | 145 +++++++ 6 files changed, 1378 insertions(+), 0 deletions(-) create mode 100644 board/esd/du440/Makefile create mode 100644 board/esd/du440/config.mk create mode 100644 board/esd/du440/du440.c create mode 100644 board/esd/du440/du440.h create mode 100644 board/esd/du440/init.S create mode 100644 board/esd/du440/u-boot.lds
diff --git a/board/esd/du440/Makefile b/board/esd/du440/Makefile new file mode 100644 index 0000000..e996a0a --- /dev/null +++ b/board/esd/du440/Makefile @@ -0,0 +1,51 @@ +# +# (C) Copyright 2002-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS = $(BOARD).o +SOBJS = init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/esd/du440/config.mk b/board/esd/du440/config.mk new file mode 100644 index 0000000..e62b8d3 --- /dev/null +++ b/board/esd/du440/config.mk @@ -0,0 +1,41 @@ +# +# (C) Copyright 2002 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# +# +# AMCC 440EPx Reference Platform (Sequoia) board +# + +sinclude $(OBJTREE)/board/$(BOARDDIR)/config.tmp + +ifndef TEXT_BASE +TEXT_BASE = 0xFFFA0000 +endif + +PLATFORM_CPPFLAGS += -DCONFIG_440=1 + +ifeq ($(debug),1) +PLATFORM_CPPFLAGS += -DDEBUG +endif + +ifeq ($(dbcr),1) +PLATFORM_CPPFLAGS += -DCFG_INIT_DBCR=0x8cff0000 +endif diff --git a/board/esd/du440/du440.c b/board/esd/du440/du440.c new file mode 100644 index 0000000..49213ad --- /dev/null +++ b/board/esd/du440/du440.c @@ -0,0 +1,1018 @@ +/* + * (C) Copyright 2008 + * Matthias Fuchs, esd gmbh, matthias.fuchs@esd-electronics.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/processor.h> +#include <asm/io.h> +#include <asm/bitops.h> +#include <command.h> +#include <i2c.h> +#include <ppc440.h> +#include "du440.h" + +DECLARE_GLOBAL_DATA_PTR; + +extern flash_info_t flash_info[CFG_MAX_FLASH_BANKS]; +extern ulong flash_get_size (ulong base, int banknum); + +int usbhub_init(void); +int dvi_init(void); +int eeprom_write_enable (unsigned dev_addr, int state); +int board_revision(void); + +static int du440_post_errors; + +int board_early_init_f(void) +{ + u32 sdr0_cust0; + u32 sdr0_pfc1, sdr0_pfc2; + u32 reg; + + mtdcr(ebccfga, xbcfg); + mtdcr(ebccfgd, 0xb8400000); + + /* + * Setup the GPIO pins + */ + out_be32((void*)GPIO0_OR, 0x00000000 | CFG_GPIO0_EP_EEP); + out_be32((void*)GPIO0_TCR, 0x0000000f | CFG_GPIO0_EP_EEP); + out_be32((void*)GPIO0_OSRL, 0x50055400); + out_be32((void*)GPIO0_OSRH, 0x550050aa); + out_be32((void*)GPIO0_TSRL, 0x50055400); + out_be32((void*)GPIO0_TSRH, 0x55005000); + out_be32((void*)GPIO0_ISR1L, 0x50000000); + out_be32((void*)GPIO0_ISR1H, 0x00000000); + out_be32((void*)GPIO0_ISR2L, 0x00000000); + out_be32((void*)GPIO0_ISR2H, 0x00000100); + out_be32((void*)GPIO0_ISR3L, 0x00000000); + out_be32((void*)GPIO0_ISR3H, 0x00000000); + + out_be32((void*)GPIO1_OR, 0x00000000); + out_be32((void*)GPIO1_TCR, 0xc2000000 | + CFG_GPIO1_IORSTN | + CFG_GPIO1_LEDUSR1 | + CFG_GPIO1_LEDUSR2 | + CFG_GPIO1_LEDPOST | + CFG_GPIO1_LEDDU); + out_be32((void*)GPIO1_ODR, CFG_GPIO1_LEDDU); + + out_be32((void*)GPIO1_OSRL, 0x5c280000); + out_be32((void*)GPIO1_OSRH, 0x00000000); + out_be32((void*)GPIO1_TSRL, 0x0c000000); + out_be32((void*)GPIO1_TSRH, 0x00000000); + out_be32((void*)GPIO1_ISR1L, 0x00005550); + out_be32((void*)GPIO1_ISR1H, 0x00000000); + out_be32((void*)GPIO1_ISR2L, 0x00050000); + out_be32((void*)GPIO1_ISR2H, 0x00000000); + out_be32((void*)GPIO1_ISR3L, 0x01400000); + out_be32((void*)GPIO1_ISR3H, 0x00000000); + + /* + * Setup the interrupt controller polarities, triggers, etc. + */ + mtdcr(uic0sr, 0xffffffff); /* clear all */ + mtdcr(uic0er, 0x00000000); /* disable all */ + mtdcr(uic0cr, 0x00000005); /* ATI & UIC1 crit are critical */ + mtdcr(uic0pr, 0xfffff7ff); /* per ref-board manual */ + mtdcr(uic0tr, 0x00000000); /* per ref-board manual */ + mtdcr(uic0vr, 0x00000000); /* int31 highest, base=0x000 */ + mtdcr(uic0sr, 0xffffffff); /* clear all */ + + /* + * UIC1: + * bit30: ext. Irq 1: PLD : int 32+30 + */ + mtdcr(uic1sr, 0xffffffff); /* clear all */ + mtdcr(uic1er, 0x00000000); /* disable all */ + mtdcr(uic1cr, 0x00000000); /* all non-critical */ + mtdcr(uic1pr, 0xfffffffd); + mtdcr(uic1tr, 0x00000000); + mtdcr(uic1vr, 0x00000000); /* int31 highest, base=0x000 */ + mtdcr(uic1sr, 0xffffffff); /* clear all */ + + /* + * UIC2 + * bit3: ext. Irq 2: DCF77 : int 64+3 + */ + mtdcr(uic2sr, 0xffffffff); /* clear all */ + mtdcr(uic2er, 0x00000000); /* disable all */ + mtdcr(uic2cr, 0x00000000); /* all non-critical */ + mtdcr(uic2pr, 0xffffffff); /* per ref-board manual */ + mtdcr(uic2tr, 0x00000000); /* per ref-board manual */ + mtdcr(uic2vr, 0x00000000); /* int31 highest, base=0x000 */ + mtdcr(uic2sr, 0xffffffff); /* clear all */ + + /* select Ethernet pins */ + mfsdr(SDR0_PFC1, sdr0_pfc1); + mfsdr(SDR0_PFC2, sdr0_pfc2); + + /* setup EMAC bridge interface */ + if (board_revision() == 0) { + /* 1 x MII */ + sdr0_pfc1 = (sdr0_pfc1 & ~SDR0_PFC1_SELECT_MASK) | + SDR0_PFC1_SELECT_CONFIG_1_2; + sdr0_pfc2 = (sdr0_pfc2 & ~SDR0_PFC2_SELECT_MASK) | + SDR0_PFC2_SELECT_CONFIG_1_2; + } else { + /* 2 x SMII */ + sdr0_pfc1 = (sdr0_pfc1 & ~SDR0_PFC1_SELECT_MASK) | + SDR0_PFC1_SELECT_CONFIG_6; + sdr0_pfc2 = (sdr0_pfc2 & ~SDR0_PFC2_SELECT_MASK) | + SDR0_PFC2_SELECT_CONFIG_6; + } + + /* enable 2nd IIC */ + sdr0_pfc1 = (sdr0_pfc1 & ~SDR0_PFC1_SIS_MASK) | SDR0_PFC1_SIS_IIC1_SEL; + + mtsdr(SDR0_PFC2, sdr0_pfc2); + mtsdr(SDR0_PFC1, sdr0_pfc1); + + /* PCI arbiter enabled */ + mfsdr(sdr_pci0, reg); + mtsdr(sdr_pci0, 0x80000000 | reg); + + /* setup NAND FLASH */ + mfsdr(SDR0_CUST0, sdr0_cust0); + sdr0_cust0 = SDR0_CUST0_MUX_NDFC_SEL | + SDR0_CUST0_NDFC_ENABLE | + SDR0_CUST0_NDFC_BW_8_BIT | + SDR0_CUST0_NDFC_ARE_MASK | + (0x80000000 >> (28 + CFG_NAND0_CS)) | + (0x80000000 >> (28 + CFG_NAND1_CS)); + mtsdr(SDR0_CUST0, sdr0_cust0); + + return 0; +} + +int misc_init_r(void) +{ + uint pbcr; + int size_val = 0; + u32 reg; + unsigned long usb2d0cr = 0; + unsigned long usb2phy0cr, usb2h0cr = 0; + unsigned long sdr0_pfc1; + int i, j; + + /* adjust flash start and offset */ + gd->bd->bi_flashstart = 0 - gd->bd->bi_flashsize; + gd->bd->bi_flashoffset = 0; + + mtdcr(ebccfga, pb0cr); + pbcr = mfdcr(ebccfgd); + size_val = ffs(gd->bd->bi_flashsize) - 21; + pbcr = (pbcr & 0x0001ffff) | gd->bd->bi_flashstart | (size_val << 17); + mtdcr(ebccfga, pb0cr); + mtdcr(ebccfgd, pbcr); + + /* + * Re-check to get correct base address + */ + flash_get_size(gd->bd->bi_flashstart, 0); + + /* + * USB suff... + */ + /* SDR Setting */ + mfsdr(SDR0_PFC1, sdr0_pfc1); + mfsdr(SDR0_USB0, usb2d0cr); + mfsdr(SDR0_USB2PHY0CR, usb2phy0cr); + mfsdr(SDR0_USB2H0CR, usb2h0cr); + + usb2phy0cr = usb2phy0cr &~SDR0_USB2PHY0CR_XOCLK_MASK; + usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_XOCLK_EXTERNAL; + usb2phy0cr = usb2phy0cr &~SDR0_USB2PHY0CR_WDINT_MASK; + usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_WDINT_16BIT_30MHZ; + usb2phy0cr = usb2phy0cr &~SDR0_USB2PHY0CR_DVBUS_MASK; + usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_DVBUS_PURDIS; + usb2phy0cr = usb2phy0cr &~SDR0_USB2PHY0CR_DWNSTR_MASK; + usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_DWNSTR_HOST; + usb2phy0cr = usb2phy0cr &~SDR0_USB2PHY0CR_UTMICN_MASK; + usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_UTMICN_HOST; + + /* An 8-bit/60MHz interface is the only possible alternative + when connecting the Device to the PHY */ + usb2h0cr = usb2h0cr &~SDR0_USB2H0CR_WDINT_MASK; + usb2h0cr = usb2h0cr | SDR0_USB2H0CR_WDINT_16BIT_30MHZ; + + /* To enable the USB 2.0 Device function through the UTMI interface */ + usb2d0cr = usb2d0cr &~SDR0_USB2D0CR_USB2DEV_EBC_SEL_MASK; + + sdr0_pfc1 = sdr0_pfc1 &~SDR0_PFC1_UES_MASK; + sdr0_pfc1 = sdr0_pfc1 | SDR0_PFC1_UES_EBCHR_SEL; + + mtsdr(SDR0_PFC1, sdr0_pfc1); + mtsdr(SDR0_USB0, usb2d0cr); + mtsdr(SDR0_USB2PHY0CR, usb2phy0cr); + mtsdr(SDR0_USB2H0CR, usb2h0cr); + + /* clear resets */ + udelay (1000); + mtsdr(SDR0_SRST1, 0x00000000); + udelay (1000); + mtsdr(SDR0_SRST0, 0x00000000); + + printf("USB: Host(int phy)\n"); + + /* + * Clear PLB4A0_ACR[WRP] + * This fix will make the MAL burst disabling patch for the Linux + * EMAC driver obsolete. + */ + reg = mfdcr(plb4_acr) & ~PLB4_ACR_WRP; + mtdcr(plb4_acr, reg); + + /* + * release IO-RST# + * We have to wait at least 560ms until we may call usbhub_init + */ + out_be32((void*)GPIO1_OR, in_be32((void*)GPIO1_OR) | CFG_GPIO1_IORSTN); + + /* + * flash USR1/2 LEDs (600ms) + * This results in the necessary delay from IORST# until + * calling usbhub_init will succeed + */ + for (j = 0; j < 3; j++) { + out_be32((void*)GPIO1_OR, + (in_be32((void*)GPIO1_OR) & ~CFG_GPIO1_LEDUSR2) | + CFG_GPIO1_LEDUSR1); + + for (i = 0; i < 100; i++) + udelay(1000); + + out_be32((void*)GPIO1_OR, + (in_be32((void*)GPIO1_OR) & ~CFG_GPIO1_LEDUSR1) | + CFG_GPIO1_LEDUSR2); + + for (i = 0; i < 100; i++) + udelay(1000); + } + + out_be32((void*)GPIO1_OR, in_be32((void*)GPIO1_OR) & + ~(CFG_GPIO1_LEDUSR1 | CFG_GPIO1_LEDUSR2)); + + if (usbhub_init()) + du440_post_errors++; + + if(dvi_init()) + du440_post_errors++; + + return 0; +} + +int pld_revision(void) +{ + out8(CFG_CPLD_BASE, 0x00); + return (int)(in8(CFG_CPLD_BASE) & CPLD_VERSION_MASK); +} + +int board_revision(void) +{ + int rpins = (int)((in_be32((void*)GPIO1_IR) & CFG_GPIO1_HWVER_MASK) + >> CFG_GPIO1_HWVER_SHIFT); + + return ((rpins & 1) << 3) | ((rpins & 2) << 1) | + ((rpins & 4) >> 1) | ((rpins & 8) >> 3); +} + +#ifdef CONFIG_SHOW_ACTIVITY +void board_show_activity (ulong timestamp) +{ + if ((timestamp % 100) == 0) + out_be32((void*)GPIO1_OR, + in_be32((void*)GPIO1_OR) ^ CFG_GPIO1_LEDUSR1); +} + +void show_activity(int arg) +{ +} +#endif /* CONFIG_SHOW_ACTIVITY */ + +int du440_phy_addr(int devnum) +{ + if (board_revision() == 0) + return devnum; + + return devnum + 1; +} + +int checkboard(void) +{ + char serno[32]; + + puts("Board: DU440"); + + if (getenv_r("serial#", serno, sizeof(serno)) > 0) { + puts(", serial# "); + puts(serno); + } + + printf(", HW-Rev. 1.%d, CPLD-Rev. 1.%d\n", + board_revision(), pld_revision()); + return (0); +} + +/* + * pci_pre_init + * + * This routine is called just prior to registering the hose and gives + * the board the opportunity to check things. Returning a value of zero + * indicates that things are bad & PCI initialization should be aborted. + * + * Different boards may wish to customize the pci controller structure + * (add regions, override default access routines, etc) or perform + * certain pre-initialization actions. + */ +#if defined(CONFIG_PCI) && defined(CFG_PCI_PRE_INIT) +int pci_pre_init(struct pci_controller *hose) +{ + unsigned long addr; + + /* + * Set priority for all PLB3 devices to 0. + * Set PLB3 arbiter to fair mode. + */ + mfsdr(sdr_amp1, addr); + mtsdr(sdr_amp1, (addr & 0x000000FF) | 0x0000FF00); + addr = mfdcr(plb3_acr); + mtdcr(plb3_acr, addr | 0x80000000); + + /* + * Set priority for all PLB4 devices to 0. + */ + mfsdr(sdr_amp0, addr); + mtsdr(sdr_amp0, (addr & 0x000000FF) | 0x0000FF00); + addr = mfdcr(plb4_acr) | 0xa0000000; /* Was 0x8---- */ + mtdcr(plb4_acr, addr); + + /* + * Set Nebula PLB4 arbiter to fair mode. + */ + /* Segment0 */ + addr = (mfdcr(plb0_acr) & ~plb0_acr_ppm_mask) | plb0_acr_ppm_fair; + addr = (addr & ~plb0_acr_hbu_mask) | plb0_acr_hbu_enabled; + addr = (addr & ~plb0_acr_rdp_mask) | plb0_acr_rdp_4deep; + addr = (addr & ~plb0_acr_wrp_mask) | plb0_acr_wrp_2deep; + mtdcr(plb0_acr, addr); + + /* Segment1 */ + addr = (mfdcr(plb1_acr) & ~plb1_acr_ppm_mask) | plb1_acr_ppm_fair; + addr = (addr & ~plb1_acr_hbu_mask) | plb1_acr_hbu_enabled; + addr = (addr & ~plb1_acr_rdp_mask) | plb1_acr_rdp_4deep; + addr = (addr & ~plb1_acr_wrp_mask) | plb1_acr_wrp_2deep; + mtdcr(plb1_acr, addr); + + return 1; +} +#endif /* defined(CONFIG_PCI) && defined(CFG_PCI_PRE_INIT) */ + +/* + * pci_target_init + * + * The bootstrap configuration provides default settings for the pci + * inbound map (PIM). But the bootstrap config choices are limited and + * may not be sufficient for a given board. + */ +#if defined(CONFIG_PCI) && defined(CFG_PCI_TARGET_INIT) +void pci_target_init(struct pci_controller *hose) +{ + /* + * Set up Direct MMIO registers + */ + /* + * PowerPC440EPX PCI Master configuration. + * Map one 1Gig range of PLB/processor addresses to PCI memory space. + * PLB address 0xA0000000-0xDFFFFFFF + * ==> PCI address 0xA0000000-0xDFFFFFFF + * Use byte reversed out routines to handle endianess. + * Make this region non-prefetchable. + */ + out32r(PCIX0_PMM0MA, 0x00000000); /* PMM0 Mask/Attribute */ + /* - disabled b4 setting */ + out32r(PCIX0_PMM0LA, CFG_PCI_MEMBASE); /* PMM0 Local Address */ + out32r(PCIX0_PMM0PCILA, CFG_PCI_MEMBASE); /* PMM0 PCI Low Address */ + out32r(PCIX0_PMM0PCIHA, 0x00000000); /* PMM0 PCI High Address */ + out32r(PCIX0_PMM0MA, 0xE0000001); /* 512M + No prefetching, */ + /* and enable region */ + + out32r(PCIX0_PMM1MA, 0x00000000); /* PMM0 Mask/Attribute */ + /* - disabled b4 setting */ + out32r(PCIX0_PMM1LA, CFG_PCI_MEMBASE2); /* PMM0 Local Address */ + out32r(PCIX0_PMM1PCILA, CFG_PCI_MEMBASE2); /* PMM0 PCI Low Address */ + out32r(PCIX0_PMM1PCIHA, 0x00000000); /* PMM0 PCI High Address */ + out32r(PCIX0_PMM1MA, 0xE0000001); /* 512M + No prefetching, */ + /* and enable region */ + + out32r(PCIX0_PTM1MS, 0x00000001); /* Memory Size/Attribute */ + out32r(PCIX0_PTM1LA, 0); /* Local Addr. Reg */ + out32r(PCIX0_PTM2MS, 0); /* Memory Size/Attribute */ + out32r(PCIX0_PTM2LA, 0); /* Local Addr. Reg */ + + /* + * Set up Configuration registers + */ + + /* Program the board's subsystem id/vendor id */ + pci_write_config_word(0, PCI_SUBSYSTEM_VENDOR_ID, + PCI_VENDOR_ID_ESDGMBH); + pci_write_config_word(0, PCI_SUBSYSTEM_ID, PCI_DEVICE_ID_DU440); + + pci_write_config_word(0, PCI_CLASS_SUB_CODE, PCI_CLASS_BRIDGE_HOST); + + /* Configure command register as bus master */ + pci_write_config_word(0, PCI_COMMAND, PCI_COMMAND_MASTER); + + /* 240nS PCI clock */ + pci_write_config_word(0, PCI_LATENCY_TIMER, 1); + + /* No error reporting */ + pci_write_config_word(0, PCI_ERREN, 0); + + pci_write_config_dword(0, PCI_BRDGOPT2, 0x00000101); + +} +#endif /* defined(CONFIG_PCI) && defined(CFG_PCI_TARGET_INIT) */ + +#if defined(CONFIG_PCI) && defined(CFG_PCI_MASTER_INIT) +void pci_master_init(struct pci_controller *hose) +{ + unsigned short temp_short; + + /* + * Write the PowerPC440 EP PCI Configuration regs. + * Enable PowerPC440 EP to be a master on the PCI bus (PMM). + * Enable PowerPC440 EP to act as a PCI memory target (PTM). + */ + pci_read_config_word(0, PCI_COMMAND, &temp_short); + pci_write_config_word(0, PCI_COMMAND, + temp_short | PCI_COMMAND_MASTER | + PCI_COMMAND_MEMORY); +} +#endif /* defined(CONFIG_PCI) && defined(CFG_PCI_MASTER_INIT) */ + +/* + * is_pci_host + * + * This routine is called to determine if a pci scan should be + * performed. With various hardware environments (especially cPCI and + * PPMC) it's insufficient to depend on the state of the arbiter enable + * bit in the strap register, or generic host/adapter assumptions. + * + * Rather than hard-code a bad assumption in the general 440 code, the + * 440 pci code requires the board to decide at runtime. + * + * Return 0 for adapter mode, non-zero for host (monarch) mode. + */ +#if defined(CONFIG_PCI) +int is_pci_host(struct pci_controller *hose) +{ + /* always configured as host. */ + return (1); +} +#endif /* defined(CONFIG_PCI) */ + +int last_stage_init(void) +{ + int e, i; + /* everyting is ok: turn on POST-LED */ + out_be32((void*)GPIO1_OR, in_be32((void*)GPIO1_OR) | CFG_GPIO1_LEDPOST); + + /* slowly blink on errors and finally keep LED off */ + for (e = 0; e < du440_post_errors; e++) { + out_be32((void*)GPIO1_OR, + in_be32((void*)GPIO1_OR) | CFG_GPIO1_LEDPOST); + + for (i = 0; i < 500; i++) + udelay(1000); + + out_be32((void*)GPIO1_OR, + in_be32((void*)GPIO1_OR) & ~CFG_GPIO1_LEDPOST); + + for (i = 0; i < 500; i++) + udelay(1000); + } + + return 0; +} + +#if defined(CONFIG_I2C_MULTI_BUS) +/* + * read field strength from I2C ADC + */ +int dcf77_status(void) +{ + unsigned int oldbus; + uchar u[2]; + int U; + + oldbus = I2C_GET_BUS(); + I2C_SET_BUS(1); + + if (i2c_read (IIC1_MCP3021_ADDR, 0, 0, u, 2)) { + I2C_SET_BUS(oldbus); + return -1; + } + + U = (int)(((u[0] << 8) | u[1]) >> 2) * 3300 / 1024; + + I2C_SET_BUS(oldbus); + return U; +} + +int do_dcf77(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + int U; + u32 pin, pinold; + unsigned long long t1, t2; + bd_t *bd = gd->bd; + + printf("DCF77: "); + U = dcf77_status(); + if (U > 0) + printf("signal=%d mV\n", U); + else + printf("ERROR - no signal\n"); + + t1 = t2 = 0; + pinold = in_be32((void*)GPIO1_IR) & CFG_GPIO1_DCF77; + while (!ctrlc()) { + pin = in_be32((void*)GPIO1_IR) & CFG_GPIO1_DCF77; + if (pin && !pinold) { /* bit start */ + t1 = get_ticks(); + if (t2 && ((unsigned int)(t1 - t2) / + (bd->bi_procfreq / 1000) >= 1800)) + printf("Start of minute\n"); + + t2 = t1; + } + if (t1 && !pin && pinold) { /* bit end */ + printf("%5d\n", (unsigned int)(get_ticks() - t1) / + (bd->bi_procfreq / 1000)); + } + pinold = pin; + } + + printf("Abort\n"); + return 0; +} +U_BOOT_CMD( + dcf77, 1, 1, do_dcf77, + "dcf77 - Check DCF77 receiver\n", + NULL + ); + +/* + * initialize USB hub via I2C1 + */ +int usbhub_init(void) +{ + int reg; + int ret = 0; + unsigned int oldbus; + uchar u[] = {0x04, 0x24, 0x04, 0x07, 0x25, 0x00, 0x00, 0xd3, + 0x18, 0xe0, 0x00, 0x00, 0x01, 0x64, 0x01, 0x64, + 0x32}; + + uchar stcd; + + printf("Hub: "); + + oldbus = I2C_GET_BUS(); + I2C_SET_BUS(1); + + for (reg = 0; reg < sizeof(u); reg++) + if (i2c_write (IIC1_USB2507_ADDR, reg, 1, &u[reg], 1)) { + ret = -1; + break; + } + + if (ret == 0) { + stcd = 0x03; + if (i2c_write (IIC1_USB2507_ADDR, 0, 1, &stcd, 1)) + ret = -1; + } + + if (ret == 0) + printf("initialized\n"); + else + printf("failed - cannot initialize USB hub\n"); + + I2C_SET_BUS(oldbus); + return ret; +} + +int do_hubinit(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + usbhub_init(); + return 0; +} +U_BOOT_CMD( + hubinit, 1, 1, do_hubinit, + "hubinit - Initialize USB hub\n", + NULL + ); +#endif /* CONFIG_I2C_MULTI_BUS */ + +#define CFG_BOOT_EEPROM_PAGE_WRITE_BITS 3 +int boot_eeprom_write (unsigned dev_addr, + unsigned offset, + uchar *buffer, + unsigned cnt) +{ + unsigned end = offset + cnt; + unsigned blk_off; + int rcode = 0; + +#if defined(CFG_EEPROM_WREN) + eeprom_write_enable(dev_addr, 1); +#endif + /* + * Write data until done or would cross a write page boundary. + * We must write the address again when changing pages + * because the address counter only increments within a page. + */ + + while (offset < end) { + unsigned alen, len; + unsigned maxlen; + + uchar addr[2]; + + blk_off = offset & 0xFF; /* block offset */ + + addr[0] = offset >> 8; /* block number */ + addr[1] = blk_off; /* block offset */ + alen = 2; + addr[0] |= dev_addr; /* insert device address */ + + len = end - offset; + + /* + * For a FRAM device there is no limit on the number of the + * bytes that can be ccessed with the single read or write + * operation. + */ +#if defined(CFG_BOOT_EEPROM_PAGE_WRITE_BITS) + +#define BOOT_EEPROM_PAGE_SIZE (1 << CFG_BOOT_EEPROM_PAGE_WRITE_BITS) +#define BOOT_EEPROM_PAGE_OFFSET(x) ((x) & (BOOT_EEPROM_PAGE_SIZE - 1)) + + maxlen = BOOT_EEPROM_PAGE_SIZE - + BOOT_EEPROM_PAGE_OFFSET(blk_off); +#else + maxlen = 0x100 - blk_off; +#endif + if (maxlen > I2C_RXTX_LEN) + maxlen = I2C_RXTX_LEN; + + if (len > maxlen) + len = maxlen; + + if (i2c_write (addr[0], offset, alen - 1, buffer, len) != 0) + rcode = 1; + + buffer += len; + offset += len; + +#if defined(CFG_EEPROM_PAGE_WRITE_DELAY_MS) + udelay(CFG_EEPROM_PAGE_WRITE_DELAY_MS * 1000); +#endif + } +#if defined(CFG_EEPROM_WREN) + eeprom_write_enable(dev_addr, 0); +#endif + return rcode; +} + +int do_setup_boot_eeprom(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + ulong sdsdp[4]; + + if (argc > 1) { + if (!strcmp(argv[1], "533")) { + printf("Bootstrapping for 533MHz\n"); + sdsdp[0] = 0x87788252; + /* PLB-PCI-divider = 3 : sync PCI clock=44MHz */ + sdsdp[1] = 0x095fa030; + sdsdp[2] = 0x40082350; + sdsdp[3] = 0x0d050000; + } else if (!strcmp(argv[1], "533-66")) { + printf("Bootstrapping for 533MHz (66MHz PCI)\n"); + sdsdp[0] = 0x87788252; + /* PLB-PCI-divider = 2 : sync PCI clock=66MHz */ + sdsdp[1] = 0x0957a030; + sdsdp[2] = 0x40082350; + sdsdp[3] = 0x0d050000; + } else if (!strcmp(argv[1], "667")) { + printf("Bootstrapping for 667MHz\n"); + sdsdp[0] = 0x8778a256; + /* PLB-PCI-divider = 4 : sync PCI clock=33MHz */ + sdsdp[1] = 0x0947a030; + /* PLB-PCI-divider = 3 : sync PCI clock=44MHz + * -> not working when overclocking 533MHz chips + * -> untested on 667MHz chips */ + /* sdsdp[1]=0x095fa030; */ + sdsdp[2] = 0x40082350; + sdsdp[3] = 0x0d050000; + } + } else { + printf("Bootstrapping for 533MHz (default)\n"); + sdsdp[0] = 0x87788252; + /* PLB-PCI-divider = 3 : sync PCI clock=44MHz */ + sdsdp[1] = 0x095fa030; + sdsdp[2] = 0x40082350; + sdsdp[3] = 0x0d050000; + } + + printf("Writing boot EEPROM ...\n"); + if (boot_eeprom_write(CFG_I2C_BOOT_EEPROM_ADDR, + 0, (uchar*)sdsdp, 16) != 0) + printf("boot_eeprom_write failed\n"); + else + printf("done (dump via 'i2c md 52 0.1 10')\n"); + + return 0; +} +U_BOOT_CMD( + sbe, 2, 0, do_setup_boot_eeprom, + "sbe - setup boot eeprom\n", + NULL + ); + +#if defined(CFG_EEPROM_WREN) +/* + * Input: <dev_addr> I2C address of EEPROM device to enable. + * <state> -1: deliver current state + * 0: disable write + * 1: enable write + * Returns: -1: wrong device address + * 0: dis-/en- able done + * 0/1: current state if <state> was -1. + */ +int eeprom_write_enable (unsigned dev_addr, int state) +{ + if ((CFG_I2C_EEPROM_ADDR != dev_addr) && + (CFG_I2C_BOOT_EEPROM_ADDR != dev_addr)) + return -1; + else { + switch (state) { + case 1: + /* Enable write access, clear bit GPIO_SINT2. */ + out_be32((void*)GPIO0_OR, + in_be32((void*)GPIO0_OR) & ~CFG_GPIO0_EP_EEP); + state = 0; + break; + case 0: + /* Disable write access, set bit GPIO_SINT2. */ + out_be32((void*)GPIO0_OR, + in_be32((void*)GPIO0_OR) | CFG_GPIO0_EP_EEP); + state = 0; + break; + default: + /* Read current status back. */ + state = (0 == (in_be32((void*)GPIO0_OR) & + CFG_GPIO0_EP_EEP)); + break; + } + } + return state; +} + +int do_eep_wren (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + int query = argc == 1; + int state = 0; + + if (query) { + /* Query write access state. */ + state = eeprom_write_enable(CFG_I2C_EEPROM_ADDR, -1); + if (state < 0) + puts ("Query of write access state failed.\n"); + else { + printf ("Write access for device 0x%0x is %sabled.\n", + CFG_I2C_EEPROM_ADDR, state ? "en" : "dis"); + state = 0; + } + } else { + if ('0' == argv[1][0]) { + /* Disable write access. */ + state = eeprom_write_enable(CFG_I2C_EEPROM_ADDR, 0); + } else { + /* Enable write access. */ + state = eeprom_write_enable(CFG_I2C_EEPROM_ADDR, 1); + } + if (state < 0) + puts ("Setup of write access state failed.\n"); + } + + return state; +} + +U_BOOT_CMD(eepwren, 2, 0, do_eep_wren, + "eepwren - Enable / disable / query EEPROM write access\n", + NULL); +#endif /* #if defined(CFG_EEPROM_WREN) */ + +static int got_pldirq; + +static int pld_interrupt(u32 arg) +{ + int rc = -1; /* not for us */ + u8 status = in8(CFG_CPLD_BASE); + + /* check for PLD interrupt */ + if (status & PWR_INT_FLAG) { + /* reset this int */ + out8(CFG_CPLD_BASE, 0); + rc = 0; + got_pldirq = 1; /* trigger backend */ + } + + return rc; +} + +int do_waitpwrirq(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + got_pldirq = 0; + + /* clear any pending interrupt */ + out8(CFG_CPLD_BASE, 0); + + irq_install_handler(CPLD_IRQ, + (interrupt_handler_t *)pld_interrupt, 0); + + printf("Waiting ...\n"); + while(!got_pldirq) { + /* Abort if ctrl-c was pressed */ + if (ctrlc()) { + puts("\nAbort\n"); + break; + } + } + if (got_pldirq) { + printf("Got interrupt!\n"); + printf("Power %sready!\n", + in8(CFG_CPLD_BASE) & PWR_RDY ? "":"NOT "); + } + + irq_free_handler(CPLD_IRQ); + return 0; +} +U_BOOT_CMD( + wpi, 1, 1, do_waitpwrirq, + "wpi - Wait for power change interrupt\n", + NULL + ); + +/* + * initialize DVI panellink transmitter + */ +int dvi_init(void) +{ + int i; + int ret = 0; + unsigned int oldbus; + uchar u[] = {0x08, 0x34, + 0x09, 0x20, + 0x0a, 0x90, + 0x0c, 0x89, + 0x08, 0x35}; + + printf("DVI: "); + + oldbus = I2C_GET_BUS(); + I2C_SET_BUS(0); + + for (i = 0; i < sizeof(u); i += 2) + if (i2c_write (0x38, u[i], 1, &u[i + 1], 1)) { + ret = -1; + break; + } + + if (ret == 0) + printf("initialized\n"); + else + printf("failed - cannot initialize DVI transmitter\n"); + + I2C_SET_BUS(oldbus); + return ret; +} + +int do_dviinit(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + dvi_init(); + return 0; +} +U_BOOT_CMD( + dviinit, 1, 1, do_dviinit, + "dviinit - Initialize DVI Panellink transmitter\n", + NULL + ); + +/* + * TODO: 'time' command might be useful for others as well. + * Move to 'common' directory. + */ +int do_time(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + unsigned long long start, end; + char c, cmd[CFG_CBSIZE]; + char *p, *d = cmd; + int ret, i; + ulong us; + + for (i = 1; i < argc; i++) { + p = argv[i]; + + if (i > 1) + *d++ = ' '; + + while ((c = *p++) != '\0') { + *d++ = c; + } + } + *d = '\0'; + + start = get_ticks(); + ret = run_command (cmd, 0); + end = get_ticks(); + + printf("ticks=%d\n", (ulong)(end - start)); + us = (ulong)((1000L * (end - start)) / (get_tbclk() / 1000)); + printf("usec=%d\n", us); + + return ret; +} +U_BOOT_CMD( + time, CFG_MAXARGS, 1, do_time, + "time - run command and output execution time\n", + NULL + ); + +extern void video_hw_rectfill ( + unsigned int bpp, /* bytes per pixel */ + unsigned int dst_x, /* dest pos x */ + unsigned int dst_y, /* dest pos y */ + unsigned int dim_x, /* frame width */ + unsigned int dim_y, /* frame height */ + unsigned int color /* fill color */ + ); + +/* + * graphics demo + * draw rectangles using pseudorandom number generator + * (see http://www.embedded.com/columns/technicalinsights/20900500) + */ +unsigned int rprime = 9972; +static unsigned int r; +static unsigned int Y; + +unsigned int prng(unsigned int max) +{ + if (r == 0 || r == 1 || r == -1) + r = rprime; /* keep from getting stuck */ + + r = (9973 * ~r) + ((Y) % 701); /* the actual algorithm */ + Y = (r >> 16) % max; /* choose upper bits and reduce */ + return Y; +} + +int do_gfxdemo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + unsigned int color; + unsigned int x, y, dx, dy; + + while (!ctrlc()) { + x = prng(1280 - 1); + y = prng(1024 - 1); + dx = prng(1280- x - 1); + dy = prng(1024 - y - 1); + color = prng(0x10000); + video_hw_rectfill(2, x, y, dx, dy, color); + } + + return 0; +} +U_BOOT_CMD( + gfxdemo, CFG_MAXARGS, 1, do_gfxdemo, + "gfxdemo - demo\n", + NULL + ); diff --git a/board/esd/du440/du440.h b/board/esd/du440/du440.h new file mode 100644 index 0000000..5c362e4 --- /dev/null +++ b/board/esd/du440/du440.h @@ -0,0 +1,42 @@ +/* + * (C) Copyright 2008 + * Matthias Fuchs, esd gmbh, matthias.fuchs@esd-electronics.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#define SDR0_USB0 0x0320 /* USB Control Register */ + +#define CFG_GPIO0_EP_EEP (0x80000000 >> 23) /* GPIO0_23 */ +#define CFG_GPIO1_DCF77 (0x80000000 >> (42-32)) /* GPIO1_42 */ + +#define CFG_GPIO1_IORSTN (0x80000000 >> (55-32)) /* GPIO1_55 */ + +#define CFG_GPIO1_HWVER_MASK 0x000000f0 /* GPIO1_56-59 */ +#define CFG_GPIO1_HWVER_SHIFT 4 +#define CFG_GPIO1_LEDUSR1 0x00000008 /* GPIO1_60 */ +#define CFG_GPIO1_LEDUSR2 0x00000004 /* GPIO1_61 */ +#define CFG_GPIO1_LEDPOST 0x00000002 /* GPIO1_62 */ +#define CFG_GPIO1_LEDDU 0x00000001 /* GPIO1_63 */ + +#define CPLD_VERSION_MASK 0x0f +#define PWR_INT_FLAG 0x80 +#define PWR_RDY 0x10 + +#define CPLD_IRQ (32+30) + +#define PCI_VENDOR_ID_ESDGMBH 0x12fe +#define PCI_DEVICE_ID_DU440 0x0444 diff --git a/board/esd/du440/init.S b/board/esd/du440/init.S new file mode 100644 index 0000000..4390b50 --- /dev/null +++ b/board/esd/du440/init.S @@ -0,0 +1,81 @@ +/* + * (C) Copyright 2008 + * Matthias Fuchs, esd gmbh, matthias.fuchs@esd-electronics.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <ppc_asm.tmpl> +#include <asm-ppc/mmu.h> +#include <config.h> + +/* + * TLB TABLE + * + * This table is used by the cpu boot code to setup the initial tlb + * entries. Rather than make broad assumptions in the cpu source tree, + * this table lets each board set things up however they like. + * + * Pointer to the table is returned in r1 + */ + .section .bootpg,"ax" + .globl tlbtab + +tlbtab: + tlbtab_start + + /* + * BOOT_CS (FLASH) must be first. Before relocation SA_I can be off to use the + * speed up boot process. It is patched after relocation to enable SA_I + */ + tlbentry( CFG_BOOT_BASE_ADDR, SZ_256M, CFG_BOOT_BASE_ADDR, 1, AC_R|AC_W|AC_X|SA_G ) + +#ifdef CFG_INIT_RAM_DCACHE + /* TLB-entry for init-ram in dcache (SA_I must be turned off!) */ + tlbentry( CFG_INIT_RAM_ADDR, SZ_64K, CFG_INIT_RAM_ADDR, 0, AC_R|AC_W|AC_X|SA_G ) +#endif + + /* TLB-entry for PCI Memory */ + tlbentry( CFG_PCI_MEMBASE, SZ_256M, CFG_PCI_MEMBASE, 1, AC_R|AC_W|SA_G|SA_I ) + tlbentry( CFG_PCI_MEMBASE1, SZ_256M, CFG_PCI_MEMBASE1, 1, AC_R|AC_W|SA_G|SA_I ) + tlbentry( CFG_PCI_MEMBASE2, SZ_256M, CFG_PCI_MEMBASE2, 1, AC_R|AC_W|SA_G|SA_I ) + tlbentry( CFG_PCI_MEMBASE3, SZ_256M, CFG_PCI_MEMBASE3, 1, AC_R|AC_W|SA_G|SA_I ) + + /* TLB-entry for PCI IO */ + tlbentry( CFG_PCI_IOBASE, SZ_64K, CFG_PCI_IOBASE, 1, AC_R|AC_W|SA_G|SA_I ) + + /* TLB-entries for EBC: CPLD, DUMEM, DUIO */ + tlbentry( CFG_CPLD_BASE, SZ_1K, CFG_CPLD_BASE, 1, AC_R|AC_W|AC_X|SA_G|SA_I ) + tlbentry( CFG_DUMEM_BASE, SZ_1M, CFG_DUMEM_BASE, 1, AC_R|AC_W|AC_X|SA_G|SA_I ) + tlbentry( CFG_DUIO_BASE, SZ_64K, CFG_DUIO_BASE, 1, AC_R|AC_W|AC_X|SA_G|SA_I ) + + /* TLB-entry for NAND */ + tlbentry( CFG_NAND0_ADDR, SZ_1K, CFG_NAND0_ADDR, 1, AC_R|AC_W|AC_X|SA_G|SA_I ) + tlbentry( CFG_NAND1_ADDR, SZ_1K, CFG_NAND1_ADDR, 1, AC_R|AC_W|AC_X|SA_G|SA_I ) + + /* TLB-entry for Internal Registers & OCM */ + tlbentry( 0xe0000000, SZ_16M, 0xe0000000, 0, AC_R|AC_W|AC_X|SA_I ) + + /* TLB-entry PCI registers */ + tlbentry( 0xEEC00000, SZ_1K, 0xEEC00000, 1, AC_R|AC_W|AC_X|SA_G|SA_I ) + + /* TLB-entry for peripherals */ + tlbentry( 0xEF000000, SZ_16M, 0xEF000000, 1, AC_R|AC_W|AC_X|SA_G|SA_I) + + tlbtab_end diff --git a/board/esd/du440/u-boot.lds b/board/esd/du440/u-boot.lds new file mode 100644 index 0000000..e140737 --- /dev/null +++ b/board/esd/du440/u-boot.lds @@ -0,0 +1,145 @@ +/* + * (C) Copyright 2002 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_ARCH(powerpc) +SEARCH_DIR(/lib); SEARCH_DIR(/usr/lib); SEARCH_DIR(/usr/local/lib); SEARCH_DIR(/usr/local/powerpc-any-elf/lib); +/* Do we need any of these for elf? + __DYNAMIC = 0; */ +SECTIONS +{ + .resetvec 0xFFFFFFFC : + { + *(.resetvec) + } = 0xffff + + .bootpg 0xFFFFF000 : + { + cpu/ppc4xx/start.o (.bootpg) + } = 0xffff + + /* Read-only sections, merged into text segment: */ + . = + SIZEOF_HEADERS; + .interp : { *(.interp) } + .hash : { *(.hash) } + .dynsym : { *(.dynsym) } + .dynstr : { *(.dynstr) } + .rel.text : { *(.rel.text) } + .rela.text : { *(.rela.text) } + .rel.data : { *(.rel.data) } + .rela.data : { *(.rela.data) } + .rel.rodata : { *(.rel.rodata) } + .rela.rodata : { *(.rela.rodata) } + .rel.got : { *(.rel.got) } + .rela.got : { *(.rela.got) } + .rel.ctors : { *(.rel.ctors) } + .rela.ctors : { *(.rela.ctors) } + .rel.dtors : { *(.rel.dtors) } + .rela.dtors : { *(.rela.dtors) } + .rel.bss : { *(.rel.bss) } + .rela.bss : { *(.rela.bss) } + .rel.plt : { *(.rel.plt) } + .rela.plt : { *(.rela.plt) } + .init : { *(.init) } + .plt : { *(.plt) } + .text : + { + /* WARNING - the following is hand-optimized to fit within */ + /* the sector layout of our flash chips! XXX FIXME XXX */ + + cpu/ppc4xx/start.o (.text) + + *(.text) + *(.fixup) + *(.got1) + } + _etext = .; + PROVIDE (etext = .); + .rodata : + { + *(.rodata) + *(.rodata1) + *(.rodata.str1.4) + } + .fini : { *(.fini) } =0 + .ctors : { *(.ctors) } + .dtors : { *(.dtors) } + + /* Read-write section, merged into data segment: */ + . = (. + 0x00FF) & 0xFFFFFF00; + _erotext = .; + PROVIDE (erotext = .); + .reloc : + { + *(.got) + _GOT2_TABLE_ = .; + *(.got2) + _FIXUP_TABLE_ = .; + *(.fixup) + } + __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >>2; + __fixup_entries = (. - _FIXUP_TABLE_)>>2; + + .data : + { + *(.data) + *(.data1) + *(.sdata) + *(.sdata2) + *(.dynamic) + CONSTRUCTORS + } + _edata = .; + PROVIDE (edata = .); + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + + . = .; + __start___ex_table = .; + __ex_table : { *(__ex_table) } + __stop___ex_table = .; + + . = ALIGN(256); + __init_begin = .; + .text.init : { *(.text.init) } + .data.init : { *(.data.init) } + . = ALIGN(256); + __init_end = .; + + __bss_start = .; + .bss (NOLOAD) : + { + *(.sbss) *(.scommon) + *(.dynbss) + *(.bss) + *(COMMON) + } + + ppcenv_assert = ASSERT(. < 0xFFFF8000, ".bss section too big, overlaps .ppcenv section. Please update your confguration: CFG_MONITOR_BASE, CFG_MONITOR_LEN and TEXT_BASE may need to be modified."); + + _end = . ; + PROVIDE (end = .); +}
Signed-off-by: Matthias Fuchs matthias.fuchs@esd-electronics.com --- MAINTAINERS | 1 + MAKEALL | 1 + Makefile | 3 + include/configs/DU440.h | 438 +++++++++++++++++++++++++++++++++++++++++++++++ 4 files changed, 443 insertions(+), 0 deletions(-) create mode 100644 include/configs/DU440.h
diff --git a/MAINTAINERS b/MAINTAINERS index 2ef2f5c..1996688 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -150,6 +150,7 @@ Matthias Fuchs matthias.fuchs@esd-electronics.com DASA_SIM IOP480 (PPC401) DP405 PPC405EP DU405 PPC405GP + DU440 PPC440EPx G2000 PPC405EP HH405 PPC405EP HUB405 PPC405EP diff --git a/MAKEALL b/MAKEALL index ebc5a22..0777dac 100755 --- a/MAKEALL +++ b/MAKEALL @@ -175,6 +175,7 @@ LIST_4xx=" \ DASA_SIM \ DP405 \ DU405 \ + DU440 \ ebony \ ERIC \ EXBITGEN \ diff --git a/Makefile b/Makefile index 1983ca0..7de2286 100644 --- a/Makefile +++ b/Makefile @@ -1191,6 +1191,9 @@ DP405_config: unconfig DU405_config: unconfig @$(MKCONFIG) $(@:_config=) ppc ppc4xx du405 esd
+DU440_config: unconfig + @$(MKCONFIG) $(@:_config=) ppc ppc4xx du440 esd + ebony_config: unconfig @$(MKCONFIG) $(@:_config=) ppc ppc4xx ebony amcc
diff --git a/include/configs/DU440.h b/include/configs/DU440.h new file mode 100644 index 0000000..30ac437 --- /dev/null +++ b/include/configs/DU440.h @@ -0,0 +1,438 @@ +/* + * (C) Copyright 2008 + * Matthias Fuchs, esd gmbh, matthias.fuchs@esd-electronics.com + * + * based on the Sequoia board configuration by + * Stefan Roese, Jacqueline Pira-Ferriol and Alain Saurel + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/************************************************************************ + * DU440.h - configuration for esd DU440 board (PowerPC440EPx) + ***********************************************************************/ +#ifndef __CONFIG_H +#define __CONFIG_H + +/*----------------------------------------------------------------------- + * High Level Configuration Options + *----------------------------------------------------------------------*/ +#define CONFIG_DU440 1 /* Board is esd DU440 */ +#define CONFIG_440EPX 1 /* Specific PPC440EPx */ +#define CONFIG_4xx 1 /* ... PPC4xx family */ +#define CONFIG_SYS_CLK_FREQ 33333400 /* external freq to pll */ + +#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_early_init_f */ +#define CONFIG_MISC_INIT_R 1 /* Call misc_init_r */ +#define CONFIG_LAST_STAGE_INIT 1 /* last_stage_init */ + +/*----------------------------------------------------------------------- + * Base addresses -- Note these are effective addresses where the + * actual resources get mapped (not physical addresses) + *----------------------------------------------------------------------*/ +#define CFG_MONITOR_LEN (384 * 1024) /* Reserve 384 kB for Monitor */ +#define CFG_MALLOC_LEN (8 << 20) /* Reserve 8 MB for malloc() */ + +#define CFG_BOOT_BASE_ADDR 0xf0000000 +#define CFG_SDRAM_BASE 0x00000000 /* _must_ be 0 */ +#define CFG_FLASH_BASE 0xfc000000 /* start of FLASH */ +#define CFG_MONITOR_BASE TEXT_BASE +#define CFG_NAND0_ADDR 0xd0000000 /* NAND Flash */ +#define CFG_NAND1_ADDR 0xd0100000 /* NAND Flash */ +#define CFG_OCM_BASE 0xe0010000 /* ocm */ +#define CFG_PCI_BASE 0xe0000000 /* Internal PCI regs */ +#define CFG_PCI_MEMBASE 0x80000000 /* mapped pci memory */ +#define CFG_PCI_MEMBASE1 CFG_PCI_MEMBASE + 0x10000000 +#define CFG_PCI_MEMBASE2 CFG_PCI_MEMBASE1 + 0x10000000 +#define CFG_PCI_MEMBASE3 CFG_PCI_MEMBASE2 + 0x10000000 +#define CFG_PCI_IOBASE 0xe8000000 + + +/* Don't change either of these */ +#define CFG_PERIPHERAL_BASE 0xef600000 /* internal peripherals */ + +#define CFG_USB2D0_BASE 0xe0000100 +#define CFG_USB_DEVICE 0xe0000000 +#define CFG_USB_HOST 0xe0000400 + +/*----------------------------------------------------------------------- + * Initial RAM & stack pointer + *----------------------------------------------------------------------*/ +/* 440EPx/440GRx have 16KB of internal SRAM, so no need for D-Cache */ +#define CFG_INIT_RAM_OCM 1 /* OCM as init ram */ +#define CFG_INIT_RAM_ADDR CFG_OCM_BASE /* OCM */ + +#define CFG_INIT_RAM_END (4 << 10) +#define CFG_GBL_DATA_SIZE 256 /* num bytes initial data */ +#define CFG_GBL_DATA_OFFSET (CFG_INIT_RAM_END - CFG_GBL_DATA_SIZE) +#define CFG_INIT_SP_OFFSET CFG_GBL_DATA_OFFSET + +/*----------------------------------------------------------------------- + * Serial Port + *----------------------------------------------------------------------*/ +/* TODO: external clock oscillator will be removed */ +#define CFG_EXT_SERIAL_CLOCK 11059200 /* ext. 11.059MHz clk */ +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SERIAL_MULTI 1 +#undef CONFIG_UART1_CONSOLE + +#define CFG_BAUDRATE_TABLE \ + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200} + +/*----------------------------------------------------------------------- + * Video Port + *----------------------------------------------------------------------*/ +#define CONFIG_VIDEO +#define CONFIG_VIDEO_SMI_LYNXEM +#define CONFIG_CFB_CONSOLE +#define CONFIG_VIDEO_LOGO +#define CONFIG_VGA_AS_SINGLE_DEVICE +#define CONFIG_SPLASH_SCREEN +#define CONFIG_SPLASH_SCREEN_ALIGN +#define CONFIG_VIDEO_BMP_GZIP /* gzip compressed bmp images */ +#define CFG_VIDEO_LOGO_MAX_SIZE (4 << 20) /* for decompressed img */ +#define CFG_DEFAULT_VIDEO_MODE 0x31a /* 1280x1024,16bpp */ +#define CFG_CONSOLE_IS_IN_ENV +#define CFG_ISA_IO CFG_PCI_IOBASE + +/*----------------------------------------------------------------------- + * Environment + *----------------------------------------------------------------------*/ +#define CFG_ENV_IS_IN_EEPROM 1 /* use FLASH for environment vars */ + +/*----------------------------------------------------------------------- + * FLASH related + *----------------------------------------------------------------------*/ +#define CFG_FLASH_CFI /* The flash is CFI compatible */ +#define CFG_FLASH_CFI_DRIVER /* Use common CFI driver */ + +#define CFG_FLASH_BANKS_LIST { CFG_FLASH_BASE } + +#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ +#define CFG_MAX_FLASH_SECT 512 /* max number of sectors on one chip */ + +#define CFG_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ +#define CFG_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ + +#define CFG_FLASH_USE_BUFFER_WRITE 1 /* use buffered writes (20x faster) */ +/* CFI_FLASH_PROTECTION make flash_protect hang sometimes -> disabled */ +#define CFG_FLASH_PROTECTION 1 /* use hardware flash protection */ + +#define CFG_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */ +#define CFG_FLASH_QUIET_TEST 1 /* don't warn upon unknown flash */ + +#ifdef CFG_ENV_IS_IN_FLASH +#define CFG_ENV_SECT_SIZE 0x20000 /* size of one complete sector */ +#define CFG_ENV_ADDR ((-CFG_MONITOR_LEN)-CFG_ENV_SECT_SIZE) +#define CFG_ENV_SIZE 0x2000 /* Total Size of Environment Sector */ + +/* Address and size of Redundant Environment Sector */ +#define CFG_ENV_ADDR_REDUND (CFG_ENV_ADDR-CFG_ENV_SECT_SIZE) +#define CFG_ENV_SIZE_REDUND (CFG_ENV_SIZE) +#endif + +#ifdef CFG_ENV_IS_IN_EEPROM +#define CFG_ENV_OFFSET 0 /* environment starts at the beginning of the EEPROM */ +#define CFG_ENV_SIZE 0x1000 /* 4096 bytes may be used for env vars*/ +#endif + +/*----------------------------------------------------------------------- + * DDR SDRAM + *----------------------------------------------------------------------*/ +#define CFG_MBYTES_SDRAM (1024) /* 512 MiB TODO: remove */ +#define CONFIG_DDR_DATA_EYE /* use DDR2 optimization */ +#define CONFIG_SPD_EEPROM /* Use SPD EEPROM for setup */ +#if 0 +#define CONFIG_ZERO_SDRAM /* Zero SDRAM after setup */ +#endif +#define CONFIG_DDR_ECC /* Use ECC when available */ +#define SPD_EEPROM_ADDRESS {0x50} +#define CONFIG_PROG_SDRAM_TLB + +/*----------------------------------------------------------------------- + * I2C + *----------------------------------------------------------------------*/ +#define CONFIG_HARD_I2C 1 /* I2C with hardware support */ +#undef CONFIG_SOFT_I2C /* I2C bit-banged */ +#define CFG_I2C_SPEED 100000 /* I2C speed and slave address */ +#define CFG_I2C_SLAVE 0x7F +#define CONFIG_I2C_CMD_TREE 1 +#define CONFIG_I2C_MULTI_BUS 1 + +#define CFG_SPD_BUS_NUM 0 +#define IIC1_MCP3021_ADDR 0x4d +#define IIC1_USB2507_ADDR 0x2c +#ifdef CONFIG_I2C_MULTI_BUS +#define CFG_I2C_NOPROBES {{1, IIC1_USB2507_ADDR}} +#endif +#define CFG_I2C_MULTI_EEPROMS +#define CFG_I2C_EEPROM_ADDR 0x54 +#define CFG_I2C_EEPROM_ADDR_LEN 2 +#define CFG_EEPROM_PAGE_WRITE_ENABLE +#define CFG_EEPROM_PAGE_WRITE_BITS 5 +#define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 +#define CFG_I2C_EEPROM_ADDR_OVERFLOW 0x01 + +#define CFG_EEPROM_WREN 1 +#define CFG_I2C_BOOT_EEPROM_ADDR 0x52 + +/* + * standard dtt sensor configuration - bottom bit will determine local or + * remote sensor of the TMP401 + */ +#define CONFIG_DTT_SENSORS { 0, 1 } + +/* + * The PMC440 uses a TI TMP401 temperature sensor. This part + * is basically compatible to the ADM1021 that is supported + * by U-Boot. + * + * - i2c addr 0x4c + * - conversion rate 0x02 = 0.25 conversions/second + * - ALERT ouput disabled + * - local temp sensor enabled, min set to 0 deg, max set to 70 deg + * - remote temp sensor enabled, min set to 0 deg, max set to 70 deg + */ +#define CONFIG_DTT_ADM1021 +#define CFG_DTT_ADM1021 { { 0x4c, 0x02, 0, 1, 70, 0, 1, 70, 0} } + +/*----------------------------------------------------------------------- + * RTC stuff + *----------------------------------------------------------------------- + */ +#define CONFIG_RTC_DS1338 +#define CFG_I2C_RTC_ADDR 0x68 + +#undef CONFIG_BOOTARGS + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "netdev=eth0\0" \ + "ethrotate=no\0" \ + "hostname=du440\0" \ + "nfsargs=setenv bootargs root=/dev/nfs rw " \ + "nfsroot=${serverip}:${rootpath}\0" \ + "ramargs=setenv bootargs root=/dev/ram rw\0" \ + "addip=setenv bootargs ${bootargs} " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ + ":${hostname}:${netdev}:off panic=1\0" \ + "addtty=setenv bootargs ${bootargs} console=ttyS0,${baudrate}\0"\ + "flash_self=run ramargs addip addtty optargs;" \ + "bootm ${kernel_addr} ${ramdisk_addr}\0" \ + "net_nfs=tftp 200000 ${img};run nfsargs addip addtty optargs;" \ + "bootm\0" \ + "rootpath=/tftpboot/du440/target_root_du440\0" \ + "img=/tftpboot/du440/uImage\0" \ + "kernel_addr=FFC00000\0" \ + "ramdisk_addr=FFE00000\0" \ + "initrd_high=30000000\0" \ + "load=tftp 100000 /tftpboot/du440/u-boot.bin\0" \ + "update=protect off FFFA0000 FFFFFFFF;era FFFA0000 FFFFFFFF;" \ + "cp.b 100000 FFFA0000 60000\0" \ + "" +#if 0 +#define CONFIG_BOOTCOMMAND "run flash_self" +#endif + +#define CONFIG_PREBOOT /* enable preboot variable */ + +#define CONFIG_BOOTDELAY 3 /* autoboot after 5 seconds */ + +#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ +#define CFG_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ + +#ifndef __ASSEMBLY__ +int du440_phy_addr(int devnum); +#endif + +#define CONFIG_IBM_EMAC4_V4 1 +#define CONFIG_MII 1 /* MII PHY management */ +#define CONFIG_PHY_ADDR du440_phy_addr(0) /* PHY address, See schematics */ + +#define CONFIG_PHY_RESET 1 /* reset phy upon startup */ +#define CONFIG_PHY_GIGE 1 /* Include GbE speed/duplex detection */ + +#define CONFIG_HAS_ETH0 +#define CFG_RX_ETH_BUFFER 128 /* Number of ethernet rx buffers & descriptors */ + +#define CONFIG_NET_MULTI 1 +#define CONFIG_HAS_ETH1 1 /* add support for "eth1addr" */ +#define CONFIG_PHY1_ADDR du440_phy_addr(1) + +/* USB */ +#define CONFIG_USB_OHCI_NEW +#define CONFIG_USB_STORAGE +#define CFG_OHCI_BE_CONTROLLER + +#define CFG_USB_OHCI_CPU_INIT 1 +#define CFG_USB_OHCI_REGS_BASE CFG_USB_HOST +#define CFG_USB_OHCI_SLOT_NAME "du440" +#define CFG_USB_OHCI_MAX_ROOT_PORTS 15 + +/* Comment this out to enable USB 1.1 device */ +#define USB_2_0_DEVICE + +/* Partitions */ +#define CONFIG_MAC_PARTITION +#define CONFIG_DOS_PARTITION +#define CONFIG_ISO_PARTITION + +#include <config_cmd_default.h> + +#define CONFIG_CMD_BSP +#define CONFIG_CMD_DATE +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_DTT +#define CONFIG_CMD_DIAG +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_ELF +#define CONFIG_CMD_FAT +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_MII +#define CONFIG_CMD_NAND +#define CONFIG_CMD_NET +#define CONFIG_CMD_NFS +#define CONFIG_CMD_PCI +#define CONFIG_CMD_PING +#define CONFIG_CMD_USB +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_SDRAM + +#define CONFIG_SUPPORT_VFAT + +/*----------------------------------------------------------------------- + * Miscellaneous configurable options + *----------------------------------------------------------------------*/ +#define CFG_LONGHELP /* undef to save memory */ +#define CFG_PROMPT "=> " /* Monitor Command Prompt */ +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ +#else +#define CFG_CBSIZE 256 /* Console I/O Buffer Size */ +#endif +#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print Buffer Size */ +#define CFG_MAXARGS 16 /* max number of command args */ +#define CFG_BARGSIZE CFG_CBSIZE /* Boot Argument Buffer Size */ + +#define CFG_MEMTEST_START 0x00400000 /* memtest works on */ +#define CFG_MEMTEST_END 0x3f000000 /* 4 ... < 1GB DRAM */ + +#define CFG_LOAD_ADDR 0x100000 /* default load address */ +#define CFG_EXTBDINFO 1 /* To use extended board_into (bd_t) */ + +#define CFG_HZ 1000 /* decrementer freq: 1 ms ticks */ + +#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ +#define CONFIG_LOOPW 1 /* enable loopw command */ +#define CONFIG_MX_CYCLIC 1 /* enable mdc/mwc commands */ +#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ +#define CONFIG_VERSION_VARIABLE 1 /* include version env variable */ + +#define CONFIG_AUTOBOOT_KEYED 1 +#define CONFIG_AUTOBOOT_PROMPT "Press SPACE to abort autoboot in %d seconds\n" +#define CONFIG_AUTOBOOT_DELAY_STR "d" +#define CONFIG_AUTOBOOT_STOP_STR " " + +/*----------------------------------------------------------------------- + * PCI stuff + *----------------------------------------------------------------------*/ +/* General PCI */ +#define CONFIG_PCI /* include pci support */ +#define CONFIG_PCI_PNP /* do (not) pci plug-and-play */ +#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ +#define CFG_PCI_TARGBASE 0x80000000 /* PCIaddr mapped to CFG_PCI_MEMBASE*/ + +/* Board-specific PCI */ +#define CFG_PCI_PRE_INIT /* enable board pci_pre_init() */ +#define CFG_PCI_TARGET_INIT +#define CFG_PCI_MASTER_INIT + +/* + * For booting Linux, the board info and command line data + * have to be in the first 8 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CFG_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ + +/*----------------------------------------------------------------------- + * External Bus Controller (EBC) Setup + *----------------------------------------------------------------------*/ +#define CFG_FLASH CFG_FLASH_BASE + +#define CFG_CPLD_BASE 0xC0000000 +#define CFG_CPLD_RANGE 0x00000010 +#define CFG_DUMEM_BASE 0xC0100000 +#define CFG_DUMEM_RANGE 0x00100000 +#define CFG_DUIO_BASE 0xC0200000 +#define CFG_DUIO_RANGE 0x00010000 + +/* + * On Sequoia CS0 and CS3 are switched when configuring for NAND booting + */ +#define CFG_NAND0_CS 2 /* NAND chip connected to CSx */ +#define CFG_NAND1_CS 3 /* NAND chip connected to CSx */ +/* Memory Bank 0 (NOR-FLASH) initialization */ +#define CFG_EBC_PB0AP 0x04017200 /* mf test-only - disabled ready# */ +/* 0x03017200 = 90ns */ /* mf test-only - use 0x04017200 for 120ns */ +#define CFG_EBC_PB0CR (CFG_FLASH_BASE | 0xda000) + +/* Memory Bank 1 (CPLD, 16 bytes needed, but 1MB is minimum) */ +#define CFG_EBC_PB1AP 0x018003c0 +#define CFG_EBC_PB1CR (CFG_CPLD_BASE | 0x18000) + +/* Memory Bank 2 (NAND-FLASH) initialization */ +#define CFG_EBC_PB2AP 0x018003c0 +#define CFG_EBC_PB2CR (CFG_NAND0_ADDR | 0x1c000) + +/* Memory Bank 3 (NAND-FLASH) initialization */ +#define CFG_EBC_PB3AP 0x018003c0 +#define CFG_EBC_PB3CR (CFG_NAND1_ADDR | 0x1c000) + +/* Memory Bank 4 (DUMEM, 1MB) initialization */ +#define CFG_EBC_PB4AP 0x018053c0 +#define CFG_EBC_PB4CR (CFG_DUMEM_BASE | 0x18000) + +/* Memory Bank 5 (DUIO, 64KB needed, but 1MB is minimum) */ +#define CFG_EBC_PB5AP 0x018053c0 +#define CFG_EBC_PB5CR (CFG_DUIO_BASE | 0x18000) + +/*----------------------------------------------------------------------- + * NAND FLASH + *----------------------------------------------------------------------*/ +#define CFG_MAX_NAND_DEVICE 2 +#define NAND_MAX_CHIPS CFG_MAX_NAND_DEVICE +#define CFG_NAND_SELECT_DEVICE 1 /* nand driver supports mutipl. chips */ +#define CFG_NAND_BASE_LIST {CFG_NAND0_ADDR + CFG_NAND0_CS, CFG_NAND1_ADDR + CFG_NAND1_CS} + +/* + * Internal Definitions + * + * Boot Flags + */ +#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ +#define BOOTFLAG_WARM 0x02 /* Software reboot */ + +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +#if 0 +#define CONFIG_SHOW_ACTIVITY 1 +#endif + +#endif /* __CONFIG_H */
Comments below.
- DU440 PPC440EPx G2000 PPC405EP HH405 PPC405EP HUB405 PPC405EP
- DU440 \ ebony \ ERIC \ EXBITGEN \
- @$(MKCONFIG) $(@:_config=) ppc ppc4xx du440 esd
- (C) Copyright 2008
- Matthias Fuchs, esd gmbh, matthias.fuchs@esd-electronics.com
- based on the Sequoia board configuration by
- Stefan Roese, Jacqueline Pira-Ferriol and Alain Saurel
- MA 02111-1307 USA
- DU440.h - configuration for esd DU440 board (PowerPC440EPx)
- High Level Configuration Options
- Base addresses -- Note these are effective addresses where the
- actual resources get mapped (not physical addresses)
- Initial RAM & stack pointer
- Serial Port
- {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200}
- Video Port
- Environment
- FLASH related
- DDR SDRAM
- I2C
- standard dtt sensor configuration - bottom bit will determine local or
- remote sensor of the TMP401
- The PMC440 uses a TI TMP401 temperature sensor. This part
- is basically compatible to the ADM1021 that is supported
- by U-Boot.
- i2c addr 0x4c
- RTC stuff
- "netdev=eth0\0" \
- "ethrotate=no\0" \
- "hostname=du440\0" \
- "nfsargs=setenv bootargs root=/dev/nfs rw " \
- "ramargs=setenv bootargs root=/dev/ram rw\0" \
- "addip=setenv bootargs ${bootargs} " \
- "addtty=setenv bootargs ${bootargs} console=ttyS0,${baudrate}\0"\
- "flash_self=run ramargs addip addtty optargs;" \
- "net_nfs=tftp 200000 ${img};run nfsargs addip addtty optargs;" \
"bootm\0" \
- "rootpath=/tftpboot/du440/target_root_du440\0" \
- "img=/tftpboot/du440/uImage\0" \
- "kernel_addr=FFC00000\0" \
- "ramdisk_addr=FFE00000\0" \
- "initrd_high=30000000\0" \
- "load=tftp 100000 /tftpboot/du440/u-boot.bin\0" \
- "update=protect off FFFA0000 FFFFFFFF;era FFFA0000 FFFFFFFF;" \
- Miscellaneous configurable options
- PCI stuff
- For booting Linux, the board info and command line data
- have to be in the first 8 MB of memory, since this is
- the maximum mapped by the Linux kernel during initialization.
- External Bus Controller (EBC) Setup
- On Sequoia CS0 and CS3 are switched when configuring for NAND booting
Comment above is not correct. Please fix or remove.
- NAND FLASH
- CFG_NAND1_CS} +
- Internal Definitions
- Boot Flags
Signed-off-by: Matthias Fuchs matthias.fuchs@esd-electronics.com --- MAINTAINERS | 1 + MAKEALL | 1 + Makefile | 3 + include/configs/DU440.h | 435 +++++++++++++++++++++++++++++++++++++++++++++++ 4 files changed, 440 insertions(+), 0 deletions(-) create mode 100644 include/configs/DU440.h
diff --git a/include/configs/DU440.h b/include/configs/DU440.h new file mode 100644 index 0000000..001e8a8 --- /dev/null +++ b/include/configs/DU440.h @@ -0,0 +1,435 @@ +/* + * (C) Copyright 2008 + * Matthias Fuchs, esd gmbh, matthias.fuchs@esd-electronics.com + * + * based on the Sequoia board configuration by + * Stefan Roese, Jacqueline Pira-Ferriol and Alain Saurel + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/************************************************************************ + * DU440.h - configuration for esd DU440 board (PowerPC440EPx) + ***********************************************************************/ +#ifndef __CONFIG_H +#define __CONFIG_H + +/*----------------------------------------------------------------------- + * High Level Configuration Options + *----------------------------------------------------------------------*/ +#define CONFIG_DU440 1 /* Board is esd DU440 */ +#define CONFIG_440EPX 1 /* Specific PPC440EPx */ +#define CONFIG_4xx 1 /* ... PPC4xx family */ +#define CONFIG_SYS_CLK_FREQ 33333400 /* external freq to pll */ + +#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_early_init_f */ +#define CONFIG_MISC_INIT_R 1 /* Call misc_init_r */ +#define CONFIG_LAST_STAGE_INIT 1 /* last_stage_init */ + +/*----------------------------------------------------------------------- + * Base addresses -- Note these are effective addresses where the + * actual resources get mapped (not physical addresses) + *----------------------------------------------------------------------*/ +#define CFG_MONITOR_LEN (384 * 1024) /* Reserve 384 kB for Monitor */ +#define CFG_MALLOC_LEN (8 << 20) /* Reserve 8 MB for malloc() */ + +#define CFG_BOOT_BASE_ADDR 0xf0000000 +#define CFG_SDRAM_BASE 0x00000000 /* _must_ be 0 */ +#define CFG_FLASH_BASE 0xfc000000 /* start of FLASH */ +#define CFG_MONITOR_BASE TEXT_BASE +#define CFG_NAND0_ADDR 0xd0000000 /* NAND Flash */ +#define CFG_NAND1_ADDR 0xd0100000 /* NAND Flash */ +#define CFG_OCM_BASE 0xe0010000 /* ocm */ +#define CFG_PCI_BASE 0xe0000000 /* Internal PCI regs */ +#define CFG_PCI_MEMBASE 0x80000000 /* mapped pci memory */ +#define CFG_PCI_MEMBASE1 CFG_PCI_MEMBASE + 0x10000000 +#define CFG_PCI_MEMBASE2 CFG_PCI_MEMBASE1 + 0x10000000 +#define CFG_PCI_MEMBASE3 CFG_PCI_MEMBASE2 + 0x10000000 +#define CFG_PCI_IOBASE 0xe8000000 + + +/* Don't change either of these */ +#define CFG_PERIPHERAL_BASE 0xef600000 /* internal peripherals */ + +#define CFG_USB2D0_BASE 0xe0000100 +#define CFG_USB_DEVICE 0xe0000000 +#define CFG_USB_HOST 0xe0000400 + +/*----------------------------------------------------------------------- + * Initial RAM & stack pointer + *----------------------------------------------------------------------*/ +/* 440EPx/440GRx have 16KB of internal SRAM, so no need for D-Cache */ +#define CFG_INIT_RAM_OCM 1 /* OCM as init ram */ +#define CFG_INIT_RAM_ADDR CFG_OCM_BASE /* OCM */ + +#define CFG_INIT_RAM_END (4 << 10) +#define CFG_GBL_DATA_SIZE 256 /* num bytes initial data */ +#define CFG_GBL_DATA_OFFSET (CFG_INIT_RAM_END - CFG_GBL_DATA_SIZE) +#define CFG_INIT_SP_OFFSET CFG_GBL_DATA_OFFSET + +/*----------------------------------------------------------------------- + * Serial Port + *----------------------------------------------------------------------*/ +/* TODO: external clock oscillator will be removed */ +#define CFG_EXT_SERIAL_CLOCK 11059200 /* ext. 11.059MHz clk */ +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SERIAL_MULTI 1 +#undef CONFIG_UART1_CONSOLE + +#define CFG_BAUDRATE_TABLE \ + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200} + +/*----------------------------------------------------------------------- + * Video Port + *----------------------------------------------------------------------*/ +#define CONFIG_VIDEO +#define CONFIG_VIDEO_SMI_LYNXEM +#define CONFIG_CFB_CONSOLE +#define CONFIG_VIDEO_LOGO +#define CONFIG_VGA_AS_SINGLE_DEVICE +#define CONFIG_SPLASH_SCREEN +#define CONFIG_SPLASH_SCREEN_ALIGN +#define CONFIG_VIDEO_BMP_GZIP /* gzip compressed bmp images */ +#define CFG_VIDEO_LOGO_MAX_SIZE (4 << 20) /* for decompressed img */ +#define CFG_DEFAULT_VIDEO_MODE 0x31a /* 1280x1024,16bpp */ +#define CFG_CONSOLE_IS_IN_ENV +#define CFG_ISA_IO CFG_PCI_IOBASE + +/*----------------------------------------------------------------------- + * Environment + *----------------------------------------------------------------------*/ +#define CFG_ENV_IS_IN_EEPROM 1 /* use FLASH for environment vars */ + +/*----------------------------------------------------------------------- + * FLASH related + *----------------------------------------------------------------------*/ +#define CFG_FLASH_CFI /* The flash is CFI compatible */ +#define CFG_FLASH_CFI_DRIVER /* Use common CFI driver */ + +#define CFG_FLASH_BANKS_LIST { CFG_FLASH_BASE } + +#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ +#define CFG_MAX_FLASH_SECT 512 /* max number of sectors on one chip */ + +#define CFG_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ +#define CFG_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ + +#define CFG_FLASH_USE_BUFFER_WRITE 1 /* use buffered writes (20x faster) */ +/* CFI_FLASH_PROTECTION make flash_protect hang sometimes -> disabled */ +#define CFG_FLASH_PROTECTION 1 /* use hardware flash protection */ + +#define CFG_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */ +#define CFG_FLASH_QUIET_TEST 1 /* don't warn upon unknown flash */ + +#ifdef CFG_ENV_IS_IN_FLASH +#define CFG_ENV_SECT_SIZE 0x20000 /* size of one complete sector */ +#define CFG_ENV_ADDR ((-CFG_MONITOR_LEN)-CFG_ENV_SECT_SIZE) +#define CFG_ENV_SIZE 0x2000 /* Total Size of Environment Sector */ + +/* Address and size of Redundant Environment Sector */ +#define CFG_ENV_ADDR_REDUND (CFG_ENV_ADDR-CFG_ENV_SECT_SIZE) +#define CFG_ENV_SIZE_REDUND (CFG_ENV_SIZE) +#endif + +#ifdef CFG_ENV_IS_IN_EEPROM +#define CFG_ENV_OFFSET 0 /* environment starts at the beginning of the EEPROM */ +#define CFG_ENV_SIZE 0x1000 /* 4096 bytes may be used for env vars*/ +#endif + +/*----------------------------------------------------------------------- + * DDR SDRAM + *----------------------------------------------------------------------*/ +#define CFG_MBYTES_SDRAM (1024) /* 512 MiB TODO: remove */ +#define CONFIG_DDR_DATA_EYE /* use DDR2 optimization */ +#define CONFIG_SPD_EEPROM /* Use SPD EEPROM for setup */ +#if 0 +#define CONFIG_ZERO_SDRAM /* Zero SDRAM after setup */ +#endif +#define CONFIG_DDR_ECC /* Use ECC when available */ +#define SPD_EEPROM_ADDRESS {0x50} +#define CONFIG_PROG_SDRAM_TLB + +/*----------------------------------------------------------------------- + * I2C + *----------------------------------------------------------------------*/ +#define CONFIG_HARD_I2C 1 /* I2C with hardware support */ +#undef CONFIG_SOFT_I2C /* I2C bit-banged */ +#define CFG_I2C_SPEED 100000 /* I2C speed and slave address */ +#define CFG_I2C_SLAVE 0x7F +#define CONFIG_I2C_CMD_TREE 1 +#define CONFIG_I2C_MULTI_BUS 1 + +#define CFG_SPD_BUS_NUM 0 +#define IIC1_MCP3021_ADDR 0x4d +#define IIC1_USB2507_ADDR 0x2c +#ifdef CONFIG_I2C_MULTI_BUS +#define CFG_I2C_NOPROBES {{1, IIC1_USB2507_ADDR}} +#endif +#define CFG_I2C_MULTI_EEPROMS +#define CFG_I2C_EEPROM_ADDR 0x54 +#define CFG_I2C_EEPROM_ADDR_LEN 2 +#define CFG_EEPROM_PAGE_WRITE_ENABLE +#define CFG_EEPROM_PAGE_WRITE_BITS 5 +#define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 +#define CFG_I2C_EEPROM_ADDR_OVERFLOW 0x01 + +#define CFG_EEPROM_WREN 1 +#define CFG_I2C_BOOT_EEPROM_ADDR 0x52 + +/* + * standard dtt sensor configuration - bottom bit will determine local or + * remote sensor of the TMP401 + */ +#define CONFIG_DTT_SENSORS { 0, 1 } + +/* + * The PMC440 uses a TI TMP401 temperature sensor. This part + * is basically compatible to the ADM1021 that is supported + * by U-Boot. + * + * - i2c addr 0x4c + * - conversion rate 0x02 = 0.25 conversions/second + * - ALERT ouput disabled + * - local temp sensor enabled, min set to 0 deg, max set to 70 deg + * - remote temp sensor enabled, min set to 0 deg, max set to 70 deg + */ +#define CONFIG_DTT_ADM1021 +#define CFG_DTT_ADM1021 { { 0x4c, 0x02, 0, 1, 70, 0, 1, 70, 0} } + +/*----------------------------------------------------------------------- + * RTC stuff + *----------------------------------------------------------------------- + */ +#define CONFIG_RTC_DS1338 +#define CFG_I2C_RTC_ADDR 0x68 + +#undef CONFIG_BOOTARGS + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "netdev=eth0\0" \ + "ethrotate=no\0" \ + "hostname=du440\0" \ + "nfsargs=setenv bootargs root=/dev/nfs rw " \ + "nfsroot=${serverip}:${rootpath}\0" \ + "ramargs=setenv bootargs root=/dev/ram rw\0" \ + "addip=setenv bootargs ${bootargs} " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ + ":${hostname}:${netdev}:off panic=1\0" \ + "addtty=setenv bootargs ${bootargs} console=ttyS0,${baudrate}\0"\ + "flash_self=run ramargs addip addtty optargs;" \ + "bootm ${kernel_addr} ${ramdisk_addr}\0" \ + "net_nfs=tftp 200000 ${img};run nfsargs addip addtty optargs;" \ + "bootm\0" \ + "rootpath=/tftpboot/du440/target_root_du440\0" \ + "img=/tftpboot/du440/uImage\0" \ + "kernel_addr=FFC00000\0" \ + "ramdisk_addr=FFE00000\0" \ + "initrd_high=30000000\0" \ + "load=tftp 100000 /tftpboot/du440/u-boot.bin\0" \ + "update=protect off FFFA0000 FFFFFFFF;era FFFA0000 FFFFFFFF;" \ + "cp.b 100000 FFFA0000 60000\0" \ + "" +#if 0 +#define CONFIG_BOOTCOMMAND "run flash_self" +#endif + +#define CONFIG_PREBOOT /* enable preboot variable */ + +#define CONFIG_BOOTDELAY 3 /* autoboot after 5 seconds */ + +#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ +#define CFG_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ + +#ifndef __ASSEMBLY__ +int du440_phy_addr(int devnum); +#endif + +#define CONFIG_IBM_EMAC4_V4 1 +#define CONFIG_MII 1 /* MII PHY management */ +#define CONFIG_PHY_ADDR du440_phy_addr(0) /* PHY address, See schematics */ + +#define CONFIG_PHY_RESET 1 /* reset phy upon startup */ +#define CONFIG_PHY_GIGE 1 /* Include GbE speed/duplex detection */ + +#define CONFIG_HAS_ETH0 +#define CFG_RX_ETH_BUFFER 128 /* Number of ethernet rx buffers & descriptors */ + +#define CONFIG_NET_MULTI 1 +#define CONFIG_HAS_ETH1 1 /* add support for "eth1addr" */ +#define CONFIG_PHY1_ADDR du440_phy_addr(1) + +/* USB */ +#define CONFIG_USB_OHCI_NEW +#define CONFIG_USB_STORAGE +#define CFG_OHCI_BE_CONTROLLER + +#define CFG_USB_OHCI_CPU_INIT 1 +#define CFG_USB_OHCI_REGS_BASE CFG_USB_HOST +#define CFG_USB_OHCI_SLOT_NAME "du440" +#define CFG_USB_OHCI_MAX_ROOT_PORTS 15 + +/* Comment this out to enable USB 1.1 device */ +#define USB_2_0_DEVICE + +/* Partitions */ +#define CONFIG_MAC_PARTITION +#define CONFIG_DOS_PARTITION +#define CONFIG_ISO_PARTITION + +#include <config_cmd_default.h> + +#define CONFIG_CMD_BSP +#define CONFIG_CMD_DATE +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_DTT +#define CONFIG_CMD_DIAG +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_ELF +#define CONFIG_CMD_FAT +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_MII +#define CONFIG_CMD_NAND +#define CONFIG_CMD_NET +#define CONFIG_CMD_NFS +#define CONFIG_CMD_PCI +#define CONFIG_CMD_PING +#define CONFIG_CMD_USB +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_SDRAM + +#define CONFIG_SUPPORT_VFAT + +/*----------------------------------------------------------------------- + * Miscellaneous configurable options + *----------------------------------------------------------------------*/ +#define CFG_LONGHELP /* undef to save memory */ +#define CFG_PROMPT "=> " /* Monitor Command Prompt */ +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ +#else +#define CFG_CBSIZE 256 /* Console I/O Buffer Size */ +#endif +#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print Buffer Size */ +#define CFG_MAXARGS 16 /* max number of command args */ +#define CFG_BARGSIZE CFG_CBSIZE /* Boot Argument Buffer Size */ + +#define CFG_MEMTEST_START 0x00400000 /* memtest works on */ +#define CFG_MEMTEST_END 0x3f000000 /* 4 ... < 1GB DRAM */ + +#define CFG_LOAD_ADDR 0x100000 /* default load address */ +#define CFG_EXTBDINFO 1 /* To use extended board_into (bd_t) */ + +#define CFG_HZ 1000 /* decrementer freq: 1 ms ticks */ + +#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ +#define CONFIG_LOOPW 1 /* enable loopw command */ +#define CONFIG_MX_CYCLIC 1 /* enable mdc/mwc commands */ +#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ +#define CONFIG_VERSION_VARIABLE 1 /* include version env variable */ + +#define CONFIG_AUTOBOOT_KEYED 1 +#define CONFIG_AUTOBOOT_PROMPT "Press SPACE to abort autoboot in %d seconds\n" +#define CONFIG_AUTOBOOT_DELAY_STR "d" +#define CONFIG_AUTOBOOT_STOP_STR " " + +/*----------------------------------------------------------------------- + * PCI stuff + *----------------------------------------------------------------------*/ +/* General PCI */ +#define CONFIG_PCI /* include pci support */ +#define CONFIG_PCI_PNP /* do (not) pci plug-and-play */ +#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ +#define CFG_PCI_TARGBASE 0x80000000 /* PCIaddr mapped to CFG_PCI_MEMBASE*/ + +/* Board-specific PCI */ +#define CFG_PCI_PRE_INIT /* enable board pci_pre_init() */ +#define CFG_PCI_TARGET_INIT +#define CFG_PCI_MASTER_INIT + +/* + * For booting Linux, the board info and command line data + * have to be in the first 8 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CFG_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ + +/*----------------------------------------------------------------------- + * External Bus Controller (EBC) Setup + *----------------------------------------------------------------------*/ +#define CFG_FLASH CFG_FLASH_BASE + +#define CFG_CPLD_BASE 0xC0000000 +#define CFG_CPLD_RANGE 0x00000010 +#define CFG_DUMEM_BASE 0xC0100000 +#define CFG_DUMEM_RANGE 0x00100000 +#define CFG_DUIO_BASE 0xC0200000 +#define CFG_DUIO_RANGE 0x00010000 + +#define CFG_NAND0_CS 2 /* NAND chip connected to CSx */ +#define CFG_NAND1_CS 3 /* NAND chip connected to CSx */ +/* Memory Bank 0 (NOR-FLASH) initialization */ +#define CFG_EBC_PB0AP 0x04017200 /* mf test-only - disabled ready# */ +/* 0x03017200 = 90ns */ /* mf test-only - use 0x04017200 for 120ns */ +#define CFG_EBC_PB0CR (CFG_FLASH_BASE | 0xda000) + +/* Memory Bank 1 (CPLD, 16 bytes needed, but 1MB is minimum) */ +#define CFG_EBC_PB1AP 0x018003c0 +#define CFG_EBC_PB1CR (CFG_CPLD_BASE | 0x18000) + +/* Memory Bank 2 (NAND-FLASH) initialization */ +#define CFG_EBC_PB2AP 0x018003c0 +#define CFG_EBC_PB2CR (CFG_NAND0_ADDR | 0x1c000) + +/* Memory Bank 3 (NAND-FLASH) initialization */ +#define CFG_EBC_PB3AP 0x018003c0 +#define CFG_EBC_PB3CR (CFG_NAND1_ADDR | 0x1c000) + +/* Memory Bank 4 (DUMEM, 1MB) initialization */ +#define CFG_EBC_PB4AP 0x018053c0 +#define CFG_EBC_PB4CR (CFG_DUMEM_BASE | 0x18000) + +/* Memory Bank 5 (DUIO, 64KB needed, but 1MB is minimum) */ +#define CFG_EBC_PB5AP 0x018053c0 +#define CFG_EBC_PB5CR (CFG_DUIO_BASE | 0x18000) + +/*----------------------------------------------------------------------- + * NAND FLASH + *----------------------------------------------------------------------*/ +#define CFG_MAX_NAND_DEVICE 2 +#define NAND_MAX_CHIPS CFG_MAX_NAND_DEVICE +#define CFG_NAND_SELECT_DEVICE 1 /* nand driver supports mutipl. chips */ +#define CFG_NAND_BASE_LIST {CFG_NAND0_ADDR + CFG_NAND0_CS, CFG_NAND1_ADDR + CFG_NAND1_CS} + +/* + * Internal Definitions + * + * Boot Flags + */ +#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ +#define BOOTFLAG_WARM 0x02 /* Software reboot */ + +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +#if 0 +#define CONFIG_SHOW_ACTIVITY 1 +#endif + +#endif /* __CONFIG_H */
Comments below.
- MA 02111-1307 USA
- Serial Port
- Video Port
- Environment
- FLASH related
- DDR SDRAM
- I2C
- by U-Boot.
- i2c addr 0x4c
- RTC stuff
- "netdev=eth0\0" \
"bootm\0" \
#if defined(CONFIG_CMD_KGDB)
- PCI stuff
Isn't necessary anymore. Please remove.
- NAND FLASH
- Boot Flags
Please fix and resubmit.
Thanks.
Best regards, Stefan
diff --git a/include/configs/DU440.h b/include/configs/DU440.h new file mode 100644 index 0000000..4fb6921 --- /dev/null +++ b/include/configs/DU440.h @@ -0,0 +1,438 @@ +/* + * (C) Copyright 2008 + * Matthias Fuchs, esd gmbh, matthias.fuchs@esd-electronics.com + * + * based on the Sequoia board configuration by + * Stefan Roese, Jacqueline Pira-Ferriol and Alain Saurel + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + ********************************************************************** + * DU440.h - configuration for esd's DU440 board (Power PC440EPx) + ********************************************************************** + */ +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * High Level Configuration Options + */ +#define CONFIG_DU440 1 /* Board is esd DU440 */ +#define CONFIG_440EPX 1 /* Specific PPC440EPx */ +#define CONFIG_4xx 1 /* ... PPC4xx family */ +#define CONFIG_SYS_CLK_FREQ 33333400 /* external freq to pll */ + +#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_early_init_f */ +#define CONFIG_MISC_INIT_R 1 /* Call misc_init_r */ +#define CONFIG_LAST_STAGE_INIT 1 /* last_stage_init */ + +/* + * Base addresses -- Note these are effective addresses where the + * actual resources get mapped (not physical addresses) + */ +#define CFG_MONITOR_LEN (384 * 1024) /* Reserve 384 kB for Monitor */ +#define CFG_MALLOC_LEN (8 << 20) /* Reserve 8 MB for malloc() */ + +#define CFG_BOOT_BASE_ADDR 0xf0000000 +#define CFG_SDRAM_BASE 0x00000000 /* _must_ be 0 */ +#define CFG_FLASH_BASE 0xfc000000 /* start of FLASH */ +#define CFG_MONITOR_BASE TEXT_BASE +#define CFG_NAND0_ADDR 0xd0000000 /* NAND Flash */ +#define CFG_NAND1_ADDR 0xd0100000 /* NAND Flash */ +#define CFG_OCM_BASE 0xe0010000 /* ocm */ +#define CFG_PCI_BASE 0xe0000000 /* Internal PCI regs */ +#define CFG_PCI_MEMBASE 0x80000000 /* mapped pci memory */ +#define CFG_PCI_MEMBASE1 CFG_PCI_MEMBASE + 0x10000000 +#define CFG_PCI_MEMBASE2 CFG_PCI_MEMBASE1 + 0x10000000 +#define CFG_PCI_MEMBASE3 CFG_PCI_MEMBASE2 + 0x10000000 +#define CFG_PCI_IOBASE 0xe8000000 + + +/* Don't change either of these */ +#define CFG_PERIPHERAL_BASE 0xef600000 /* internal peripherals */ + +#define CFG_USB2D0_BASE 0xe0000100 +#define CFG_USB_DEVICE 0xe0000000 +#define CFG_USB_HOST 0xe0000400 + +/* + * Initial RAM & stack pointer + */ +/* 440EPx/440GRx have 16KB of internal SRAM, so no need for D-Cache */ +#define CFG_INIT_RAM_OCM 1 /* OCM as init ram */ +#define CFG_INIT_RAM_ADDR CFG_OCM_BASE /* OCM */ + +#define CFG_INIT_RAM_END (4 << 10) +#define CFG_GBL_DATA_SIZE 256 /* num bytes initial data */ +#define CFG_GBL_DATA_OFFSET (CFG_INIT_RAM_END - CFG_GBL_DATA_SIZE) +#define CFG_INIT_SP_OFFSET CFG_GBL_DATA_OFFSET + +/* + * Serial Port + */ +/* TODO: external clock oscillator will be removed */ +#define CFG_EXT_SERIAL_CLOCK 11059200 /* ext. 11.059MHz clk */ +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SERIAL_MULTI 1 +#undef CONFIG_UART1_CONSOLE + +#define CFG_BAUDRATE_TABLE \ + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200} + +/* + * Video Port + */ +#define CONFIG_VIDEO +#define CONFIG_VIDEO_SMI_LYNXEM +#define CONFIG_CFB_CONSOLE +#define CONFIG_VIDEO_LOGO +#define CONFIG_VGA_AS_SINGLE_DEVICE +#define CONFIG_SPLASH_SCREEN +#define CONFIG_SPLASH_SCREEN_ALIGN +#define CONFIG_VIDEO_BMP_GZIP /* gzip compressed bmp images */ +#define CFG_VIDEO_LOGO_MAX_SIZE (4 << 20) /* for decompressed img */ +#define CFG_DEFAULT_VIDEO_MODE 0x31a /* 1280x1024,16bpp */ +#define CFG_CONSOLE_IS_IN_ENV +#define CFG_ISA_IO CFG_PCI_IOBASE + +/* + * Environment + */ +#define CFG_ENV_IS_IN_EEPROM 1 /* use FLASH for environment vars */ + +/* + * FLASH related + */ +#define CFG_FLASH_CFI /* The flash is CFI compatible */ +#define CFG_FLASH_CFI_DRIVER /* Use common CFI driver */ + +#define CFG_FLASH_BANKS_LIST { CFG_FLASH_BASE } + +#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ +#define CFG_MAX_FLASH_SECT 512 /* max number of sectors on one chip */ + +#define CFG_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ +#define CFG_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ + +#define CFG_FLASH_USE_BUFFER_WRITE 1 /* use buffered writes (20x faster) */ +/* CFI_FLASH_PROTECTION make flash_protect hang sometimes -> disabled */ +#define CFG_FLASH_PROTECTION 1 /* use hardware flash protection */ + +#define CFG_FLASH_EMPTY_INFO +#define CFG_FLASH_QUIET_TEST 1 /* don't warn upon unknown flash */ + +#ifdef CFG_ENV_IS_IN_FLASH +#define CFG_ENV_SECT_SIZE 0x20000 /* size of one complete sector */ +#define CFG_ENV_ADDR ((-CFG_MONITOR_LEN)-CFG_ENV_SECT_SIZE) +#define CFG_ENV_SIZE 0x2000 /* Total Size of Environment Sector */ + +/* Address and size of Redundant Environment Sector */ +#define CFG_ENV_ADDR_REDUND (CFG_ENV_ADDR-CFG_ENV_SECT_SIZE) +#define CFG_ENV_SIZE_REDUND (CFG_ENV_SIZE) +#endif + +#ifdef CFG_ENV_IS_IN_EEPROM +#define CFG_ENV_OFFSET 0 /* environment starts at */ + /* the beginning of the EEPROM */ +#define CFG_ENV_SIZE 0x1000 /* 4096 bytes may be used for env vars */ +#endif + +/* + * DDR SDRAM + */ +#define CFG_MBYTES_SDRAM (1024) /* 512 MiB TODO: remove */ +#define CONFIG_DDR_DATA_EYE /* use DDR2 optimization */ +#define CONFIG_SPD_EEPROM /* Use SPD EEPROM for setup */ +#if 0 +#define CONFIG_ZERO_SDRAM /* Zero SDRAM after setup */ +#endif +#define CONFIG_DDR_ECC /* Use ECC when available */ +#define SPD_EEPROM_ADDRESS {0x50} +#define CONFIG_PROG_SDRAM_TLB + +/* + * I2C + */ +#define CONFIG_HARD_I2C 1 /* I2C with hardware support */ +#undef CONFIG_SOFT_I2C /* I2C bit-banged */ +#define CFG_I2C_SPEED 100000 /* I2C speed and slave address */ +#define CFG_I2C_SLAVE 0x7F +#define CONFIG_I2C_CMD_TREE 1 +#define CONFIG_I2C_MULTI_BUS 1 + +#define CFG_SPD_BUS_NUM 0 +#define IIC1_MCP3021_ADDR 0x4d +#define IIC1_USB2507_ADDR 0x2c +#ifdef CONFIG_I2C_MULTI_BUS +#define CFG_I2C_NOPROBES {{1, IIC1_USB2507_ADDR}} +#endif +#define CFG_I2C_MULTI_EEPROMS +#define CFG_I2C_EEPROM_ADDR 0x54 +#define CFG_I2C_EEPROM_ADDR_LEN 2 +#define CFG_EEPROM_PAGE_WRITE_ENABLE +#define CFG_EEPROM_PAGE_WRITE_BITS 5 +#define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 +#define CFG_I2C_EEPROM_ADDR_OVERFLOW 0x01 + +#define CFG_EEPROM_WREN 1 +#define CFG_I2C_BOOT_EEPROM_ADDR 0x52 + +/* + * standard dtt sensor configuration - bottom bit will determine local or + * remote sensor of the TMP401 + */ +#define CONFIG_DTT_SENSORS { 0, 1 } + +/* + * The PMC440 uses a TI TMP401 temperature sensor. This part + * is basically compatible to the ADM1021 that is supported + * by U-Boot. + * + * - i2c addr 0x4c + * - conversion rate 0x02 = 0.25 conversions/second + * - ALERT ouput disabled + * - local temp sensor enabled, min set to 0 deg, max set to 70 deg + * - remote temp sensor enabled, min set to 0 deg, max set to 70 deg + */ +#define CONFIG_DTT_ADM1021 +#define CFG_DTT_ADM1021 { { 0x4c, 0x02, 0, 1, 70, 0, 1, 70, 0} } + +/* + * RTC stuff + */ +#define CONFIG_RTC_DS1338 +#define CFG_I2C_RTC_ADDR 0x68 + +#undef CONFIG_BOOTARGS + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "netdev=eth0\0" \ + "ethrotate=no\0" \ + "hostname=du440\0" \ + "nfsargs=setenv bootargs root=/dev/nfs rw " \ + "nfsroot=${serverip}:${rootpath}\0" \ + "ramargs=setenv bootargs root=/dev/ram rw\0" \ + "addip=setenv bootargs ${bootargs} " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ + ":${hostname}:${netdev}:off panic=1\0" \ + "addtty=setenv bootargs ${bootargs} console=ttyS0,${baudrate}\0"\ + "flash_self=run ramargs addip addtty optargs;" \ + "bootm ${kernel_addr} ${ramdisk_addr}\0" \ + "net_nfs=tftp 200000 ${img};run nfsargs addip addtty optargs;" \ + "bootm\0" \ + "rootpath=/tftpboot/du440/target_root_du440\0" \ + "img=/tftpboot/du440/uImage\0" \ + "kernel_addr=FFC00000\0" \ + "ramdisk_addr=FFE00000\0" \ + "initrd_high=30000000\0" \ + "load=tftp 100000 /tftpboot/du440/u-boot.bin\0" \ + "update=protect off FFFA0000 FFFFFFFF;era FFFA0000 FFFFFFFF;" \ + "cp.b 100000 FFFA0000 60000\0" \ + "" +#if 0 +#define CONFIG_BOOTCOMMAND "run flash_self" +#endif + +#define CONFIG_PREBOOT /* enable preboot variable */ + +#define CONFIG_BOOTDELAY 3 /* autoboot after 5 seconds */ + +#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ +#define CFG_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ + +#ifndef __ASSEMBLY__ +int du440_phy_addr(int devnum); +#endif + +#define CONFIG_IBM_EMAC4_V4 1 +#define CONFIG_MII 1 /* MII PHY management */ +#define CONFIG_PHY_ADDR du440_phy_addr(0) /* PHY address */ + +#define CONFIG_PHY_RESET 1 /* reset phy upon startup */ +#define CONFIG_PHY_GIGE 1 /* Include GbE detection */ + +#define CONFIG_HAS_ETH0 +#define CFG_RX_ETH_BUFFER 128 + +#define CONFIG_NET_MULTI 1 +#define CONFIG_HAS_ETH1 1 /* add support for "eth1addr" */ +#define CONFIG_PHY1_ADDR du440_phy_addr(1) + +/* + * USB + */ +#define CONFIG_USB_OHCI_NEW +#define CONFIG_USB_STORAGE +#define CFG_OHCI_BE_CONTROLLER + +#define CFG_USB_OHCI_CPU_INIT 1 +#define CFG_USB_OHCI_REGS_BASE CFG_USB_HOST +#define CFG_USB_OHCI_SLOT_NAME "du440" +#define CFG_USB_OHCI_MAX_ROOT_PORTS 15 + +/* Comment this out to enable USB 1.1 device */ +#define USB_2_0_DEVICE + +/* Partitions */ +#define CONFIG_MAC_PARTITION +#define CONFIG_DOS_PARTITION +#define CONFIG_ISO_PARTITION + +#include <config_cmd_default.h> + +#define CONFIG_CMD_BSP +#define CONFIG_CMD_DATE +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_DTT +#define CONFIG_CMD_DIAG +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_ELF +#define CONFIG_CMD_FAT +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_MII +#define CONFIG_CMD_NAND +#define CONFIG_CMD_NET +#define CONFIG_CMD_NFS +#define CONFIG_CMD_PCI +#define CONFIG_CMD_PING +#define CONFIG_CMD_USB +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_SDRAM + +#define CONFIG_SUPPORT_VFAT + +/* + * Miscellaneous configurable options + */ +#define CFG_LONGHELP /* undef to save memory */ +#define CFG_PROMPT "=> " /* Monitor Command Prompt */ +#if defined(CONFIG_CMD_KGDB) +#define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ +#else +#define CFG_CBSIZE 256 /* Console I/O Buffer Size */ +#endif +/* Print Buffer Size */ +#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) +#define CFG_MAXARGS 16 /* max number of command args */ +#define CFG_BARGSIZE CFG_CBSIZE /* Boot Argument Buffer Size */ + +#define CFG_MEMTEST_START 0x00400000 /* memtest works on */ +#define CFG_MEMTEST_END 0x3f000000 /* 4 ... < 1GB DRAM */ + +#define CFG_LOAD_ADDR 0x100000 /* default load address */ +#define CFG_EXTBDINFO 1 /* To use extended board_into (bd_t) */ + +#define CFG_HZ 1000 /* decrementer freq: 1 ms ticks */ + +#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ +#define CONFIG_LOOPW 1 /* enable loopw command */ +#define CONFIG_MX_CYCLIC 1 /* enable mdc/mwc commands */ +#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ +#define CONFIG_VERSION_VARIABLE 1 /* include version env variable */ + +#define CONFIG_AUTOBOOT_KEYED 1 +#define CONFIG_AUTOBOOT_PROMPT "Press SPACE to abort autoboot in %d seconds\n" +#define CONFIG_AUTOBOOT_DELAY_STR "d" +#define CONFIG_AUTOBOOT_STOP_STR " " + +/* + * PCI stuff + */ +#define CONFIG_PCI /* include pci support */ +#define CONFIG_PCI_PNP /* do (not) pci plug-and-play */ +#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ +#define CFG_PCI_TARGBASE 0x80000000 /* PCIaddr mapped to CFG_PCI_MEMBASE*/ + +/* Board-specific PCI */ +#define CFG_PCI_TARGET_INIT +#define CFG_PCI_MASTER_INIT + +/* + * For booting Linux, the board info and command line data + * have to be in the first 8 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CFG_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ + +/* + * External Bus Controller (EBC) Setup + */ +#define CFG_FLASH CFG_FLASH_BASE + +#define CFG_CPLD_BASE 0xC0000000 +#define CFG_CPLD_RANGE 0x00000010 +#define CFG_DUMEM_BASE 0xC0100000 +#define CFG_DUMEM_RANGE 0x00100000 +#define CFG_DUIO_BASE 0xC0200000 +#define CFG_DUIO_RANGE 0x00010000 + +#define CFG_NAND0_CS 2 /* NAND chip connected to CSx */ +#define CFG_NAND1_CS 3 /* NAND chip connected to CSx */ +/* Memory Bank 0 (NOR-FLASH) initialization */ +#define CFG_EBC_PB0AP 0x04017200 +#define CFG_EBC_PB0CR (CFG_FLASH_BASE | 0xda000) + +/* Memory Bank 1 (CPLD, 16 bytes needed, but 1MB is minimum) */ +#define CFG_EBC_PB1AP 0x018003c0 +#define CFG_EBC_PB1CR (CFG_CPLD_BASE | 0x18000) + +/* Memory Bank 2 (NAND-FLASH) initialization */ +#define CFG_EBC_PB2AP 0x018003c0 +#define CFG_EBC_PB2CR (CFG_NAND0_ADDR | 0x1c000) + +/* Memory Bank 3 (NAND-FLASH) initialization */ +#define CFG_EBC_PB3AP 0x018003c0 +#define CFG_EBC_PB3CR (CFG_NAND1_ADDR | 0x1c000) + +/* Memory Bank 4 (DUMEM, 1MB) initialization */ +#define CFG_EBC_PB4AP 0x018053c0 +#define CFG_EBC_PB4CR (CFG_DUMEM_BASE | 0x18000) + +/* Memory Bank 5 (DUIO, 64KB needed, but 1MB is minimum) */ +#define CFG_EBC_PB5AP 0x018053c0 +#define CFG_EBC_PB5CR (CFG_DUIO_BASE | 0x18000) + +/* + * NAND FLASH + */ +#define CFG_MAX_NAND_DEVICE 2 +#define NAND_MAX_CHIPS CFG_MAX_NAND_DEVICE +#define CFG_NAND_SELECT_DEVICE 1 /* nand driver supports mutipl. chips */ +#define CFG_NAND_BASE_LIST {CFG_NAND0_ADDR + CFG_NAND0_CS, \ + CFG_NAND1_ADDR + CFG_NAND1_CS} + +/* + * Internal Definitions + * + * Boot Flags + */ +#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ +#define BOOTFLAG_WARM 0x02 /* Software reboot */ + +#if defined(CONFIG_CMD_KGDB) +#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +#if 0 +#define CONFIG_SHOW_ACTIVITY 1 +#endif + +#endif /* __CONFIG_H */
Applied, thanks.
Matthias Fuchs
Stefan Roese
