[U-Boot] Buildman problem
Hi Simon,
I found an error of buildman.
If the target branch has an upstream branch, buildman fails with the following message:
$ git branch --set-upstream-to=base Branch testtest set up to track local branch base. $ tools/buildman/buildman -b testtest uniphier Traceback (most recent call last): File "tools/buildman/buildman", line 64, in <module> ret_code = control.DoBuildman(options, args) File "/home/masahiro/workspace/u-boot-uniphier/tools/buildman/control.py", line 152, in DoBuildman options.branch) File "/home/masahiro/workspace/u-boot-uniphier/tools/buildman/../patman/gitutil.py", line 185, in CountCommitsInBranch range_expr, msg = GetRangeInBranch(git_dir, branch, include_upstream) File "/home/masahiro/workspace/u-boot-uniphier/tools/buildman/../patman/gitutil.py", line 151, in GetRangeInBranch upstream, msg = GetUpstream(git_dir, branch) ValueError: too many values to unpack
Is it no longer available to specify the upstream branch explicitly?
The first bad commit is:
commit 2a9e2c6a0962cb04a12d833cc5c1c0920fa3b4f5 Author: Simon Glass sjg@chromium.org Date: Mon Dec 1 17:33:54 2014 -0700
buildman: Try to guess the upstream commit
Buildman normally obtains the upstream commit by asking git. Provided that the branch was created with 'git checkout -b <branch> <some_upstream>' then this normally works.
When there is no upstream, we can try to guess one, by looking up through the commits until we find a branch. Add a function to try this and print a warning if buildman ends up relying on it.
Also update the documentation to match.
Signed-off-by: Simon Glass sjg@chromium.org Suggested-by: Wolfgang Denk wd@denx.de
Masahiro YAMADA
