[U-Boot] [PATCH 1/3] vsprintf.c: Always enable CONFIG_SYS_VSNPRINTF
Enabling this function always removes some class of string saftey issues. The size change here in general is about 400 bytes and this seems a reasonable trade-off.
Cc: Peng Fan peng.fan@nxp.com Cc: Peter Robinson pbrobinson@gmail.com Cc: Fabio Estevam fabio.estevam@freescale.com Cc: Adrian Alonso aalonso@freescale.com Cc: Stefano Babic sbabic@denx.de Cc: Hans de Goede hdegoede@redhat.com Signed-off-by: Tom Rini trini@konsulko.com
--- I ran my usual world build of buildman with size comparison options this time to test this out. The only exception to the general size change here are q8_a23_tablet_800x480 and gt90h_v4 both in the non-SPL case. These both grow by 3780 bytes in the non-SPL case. In all cases except those two, when paired with the gzwrite patch I posted yesterday we gain all of that back, or more. --- README | 9 --------- configs/bayleybay_defconfig | 1 - configs/chromebook_link_defconfig | 1 - configs/chromebox_panther_defconfig | 1 - configs/coreboot-x86_defconfig | 1 - configs/crownbay_defconfig | 1 - configs/galileo_defconfig | 1 - configs/minnowmax_defconfig | 1 - configs/qemu-x86_defconfig | 1 - configs/sandbox_defconfig | 1 - include/vsprintf.h | 12 ------------ lib/Kconfig | 9 --------- lib/vsprintf.c | 12 ------------ 13 files changed, 51 deletions(-)
diff --git a/README b/README index 5ac2d44..b7ce63d 100644 --- a/README +++ b/README @@ -890,15 +890,6 @@ The following options need to be configured: 'Sane' compilers will generate smaller code if CONFIG_PRE_CON_BUF_SZ is a power of 2
-- Safe printf() functions - Define CONFIG_SYS_VSNPRINTF to compile in safe versions of - the printf() functions. These are defined in - include/vsprintf.h and include snprintf(), vsnprintf() and - so on. Code size increase is approximately 300-500 bytes. - If this option is not given then these functions will - silently discard their buffer size argument - this means - you are not getting any overflow checking in this case. - - Boot Delay: CONFIG_BOOTDELAY - in seconds Delay before automatically booting the default image; set to -1 to disable autoboot. diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index f462e05..0879d1e 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -37,4 +37,3 @@ CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y CONFIG_USE_PRIVATE_LIBGCC=y -CONFIG_SYS_VSNPRINTF=y diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index dbfbb97..baa0ed8 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -38,5 +38,4 @@ CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y CONFIG_USE_PRIVATE_LIBGCC=y -CONFIG_SYS_VSNPRINTF=y CONFIG_TPM=y diff --git a/configs/chromebox_panther_defconfig b/configs/chromebox_panther_defconfig index ed4428f..c368cc0 100644 --- a/configs/chromebox_panther_defconfig +++ b/configs/chromebox_panther_defconfig @@ -33,5 +33,4 @@ CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y CONFIG_USE_PRIVATE_LIBGCC=y -CONFIG_SYS_VSNPRINTF=y CONFIG_TPM=y diff --git a/configs/coreboot-x86_defconfig b/configs/coreboot-x86_defconfig index cd2be18..fda0db2 100644 --- a/configs/coreboot-x86_defconfig +++ b/configs/coreboot-x86_defconfig @@ -25,5 +25,4 @@ CONFIG_TPM_TIS_LPC=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USE_PRIVATE_LIBGCC=y -CONFIG_SYS_VSNPRINTF=y CONFIG_TPM=y diff --git a/configs/crownbay_defconfig b/configs/crownbay_defconfig index 932d9ec..6bc4b8d 100644 --- a/configs/crownbay_defconfig +++ b/configs/crownbay_defconfig @@ -36,4 +36,3 @@ CONFIG_DM_USB=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_USE_PRIVATE_LIBGCC=y -CONFIG_SYS_VSNPRINTF=y diff --git a/configs/galileo_defconfig b/configs/galileo_defconfig index 0604aa7..925d3ee 100644 --- a/configs/galileo_defconfig +++ b/configs/galileo_defconfig @@ -28,4 +28,3 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USE_PRIVATE_LIBGCC=y -CONFIG_SYS_VSNPRINTF=y diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index 864fd1b..af6a8ec 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -39,4 +39,3 @@ CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y CONFIG_USE_PRIVATE_LIBGCC=y -CONFIG_SYS_VSNPRINTF=y diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index 8c86931..b0c935c 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -30,4 +30,3 @@ CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_111=y CONFIG_USE_PRIVATE_LIBGCC=y -CONFIG_SYS_VSNPRINTF=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 731fc25..caa7336 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -76,7 +76,6 @@ CONFIG_USB_EMUL=y CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL=y -CONFIG_SYS_VSNPRINTF=y CONFIG_CMD_DHRYSTONE=y CONFIG_TPM=y CONFIG_LZ4=y diff --git a/include/vsprintf.h b/include/vsprintf.h index b5bc9c1..376f5dd 100644 --- a/include/vsprintf.h +++ b/include/vsprintf.h @@ -124,7 +124,6 @@ int sprintf(char *buf, const char *fmt, ...) int vsprintf(char *buf, const char *fmt, va_list args); char *simple_itoa(ulong i);
-#ifdef CONFIG_SYS_VSNPRINTF /** * Format a string and place it in a buffer * @@ -199,17 +198,6 @@ int vsnprintf(char *buf, size_t size, const char *fmt, va_list args); * See the vsprintf() documentation for format string extensions over C99. */ int vscnprintf(char *buf, size_t size, const char *fmt, va_list args); -#else -/* - * Use macros to silently drop the size parameter. Note that the 'cn' - * versions are the same as the 'n' versions since the functions assume - * there is always enough buffer space when !CONFIG_SYS_VSNPRINTF - */ -#define snprintf(buf, size, fmt, args...) sprintf(buf, fmt, ##args) -#define scnprintf(buf, size, fmt, args...) sprintf(buf, fmt, ##args) -#define vsnprintf(buf, size, fmt, args...) vsprintf(buf, fmt, ##args) -#define vscnprintf(buf, size, fmt, args...) vsprintf(buf, fmt, ##args) -#endif /* CONFIG_SYS_VSNPRINTF */
/** * print_grouped_ull() - print a value with digits grouped by ',' diff --git a/lib/Kconfig b/lib/Kconfig index 9d580e4..46d7034 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -27,15 +27,6 @@ config SYS_HZ get_timer() must operate in milliseconds and this option must be set to 1000.
-config SYS_VSNPRINTF - bool "Enable safe version of sprintf()" - help - Since sprintf() can overflow its buffer, it is common to use - snprintf() instead, which knows the buffer size and can avoid - overflow. However, this does increase code size slightly (for - Thumb-2, about 420 bytes). Enable this option for safety when - using sprintf() with data you do not control. - config USE_TINY_PRINTF bool "Enable tiny printf() version" help diff --git a/lib/vsprintf.c b/lib/vsprintf.c index 24167a1..874a295 100644 --- a/lib/vsprintf.c +++ b/lib/vsprintf.c @@ -141,7 +141,6 @@ static noinline char *put_dec(char *buf, uint64_t num) #define SMALL 32 /* Must be 32 == 0x20 */ #define SPECIAL 64 /* 0x */
-#ifdef CONFIG_SYS_VSNPRINTF /* * Macro to add a new character to our output string, but only if it will * fit. The macro moves to the next character position in the output string. @@ -151,9 +150,6 @@ static noinline char *put_dec(char *buf, uint64_t num) *(str) = (ch); \ ++str; \ } while (0) -#else -#define ADDCH(str, ch) (*(str)++ = (ch)) -#endif
static char *number(char *buf, char *end, u64 num, int base, int size, int precision, int type) @@ -441,13 +437,11 @@ static int vsnprintf_internal(char *buf, size_t size, const char *fmt, /* 't' added for ptrdiff_t */ char *end = buf + size;
-#ifdef CONFIG_SYS_VSNPRINTF /* Make sure end is always >= buf - do we want this in U-Boot? */ if (end < buf) { end = ((void *)-1); size = end - buf; } -#endif str = buf;
for (; *fmt ; ++fmt) { @@ -609,21 +603,16 @@ repeat: flags); }
-#ifdef CONFIG_SYS_VSNPRINTF if (size > 0) { ADDCH(str, '\0'); if (str > end) end[-1] = '\0'; --str; } -#else - *str = '\0'; -#endif /* the trailing null byte doesn't count towards the total */ return str - buf; }
-#ifdef CONFIG_SYS_VSNPRINTF int vsnprintf(char *buf, size_t size, const char *fmt, va_list args) { @@ -666,7 +655,6 @@ int scnprintf(char *buf, size_t size, const char *fmt, ...)
return i; } -#endif /* CONFIG_SYS_VSNPRINT */
/** * Format a string and place it in a buffer (va_list version)
Both of these boards are very close to their limit and with some toolchains such as gcc 5.x are too large. Switch to tiny printf to reclaim some size.
Signed-off-by: Tom Rini trini@konsulko.com --- configs/axm_defconfig | 1 + configs/taurus_defconfig | 1 + 2 files changed, 2 insertions(+)
diff --git a/configs/axm_defconfig b/configs/axm_defconfig index 38bb9ab..25e4570 100644 --- a/configs/axm_defconfig +++ b/configs/axm_defconfig @@ -12,3 +12,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,MACH_TYPE=2068,BOARD_AXM" # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y +CONFIG_USE_TINY_PRINTF=y diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index d59912c..3f08cc1 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -13,3 +13,4 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y +CONFIG_USE_TINY_PRINTF=y
Hello Tom,
Am 19.01.2016 um 19:08 schrieb Tom Rini:
Missed this patch, tested it on the taurus board, works!
Thanks!
bye, Heiko
Only when we have CONFIG_CMD_UNZIP enabled do we have the 'gzwrite' command. While this command should be separated from CONFIG_CMD_UNZIP we should also only include the write portion of the gz code in that case as well.
Signed-off-by: Tom Rini trini@konsulko.com --- lib/gunzip.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/lib/gunzip.c b/lib/gunzip.c index d86aa87..80b157f 100644 --- a/lib/gunzip.c +++ b/lib/gunzip.c @@ -70,6 +70,7 @@ int gunzip(void *dst, int dstlen, unsigned char *src, unsigned long *lenp) return zunzip(dst, dstlen, src, lenp, 1, i); }
+#ifdef CONFIG_CMD_UNZIP __weak void gzwrite_progress_init(u64 expectedsize) { @@ -258,6 +259,7 @@ out:
return r; } +#endif
/* * Uncompress blocks compressed with zlib without headers
Hi Tom,
Reviewed-and-tested-by: Peng Fan peng.fan@nxp.com
Regards, Peng.
- Format a string and place it in a buffer
- See the vsprintf() documentation for format string extensions over C99.
- Use macros to silently drop the size parameter. Note that the 'cn'
- versions are the same as the 'n' versions since the functions assume
- there is always enough buffer space when !CONFIG_SYS_VSNPRINTF
- print_grouped_ull() - print a value with digits grouped by ','
- help
- Macro to add a new character to our output string, but only if it will
- fit. The macro moves to the next character position in the output string.
- *str = '\0';
- Format a string and place it in a buffer (va_list version)
-- 2.6.4
Heiko Schocher
Peng Fan
