[PATCH v4 0/4] imx8m: move env_get_location for imx8mn and imx8mp at board level
This series move env_get_location from soc to board level. As suggested by Michael michael@amarulasolutions.com make no sense to define an unique way for multiple board. One board can boot from emmc and having env on spi flash etc.. Anyways, this function is kept in imx8mn_evk, imx8mp_evk, phycore-imx8mp and imx8mn_beacon boards instead of being completely dropped.
Note for all imx8mp/imx8mn users: This patch move only the env_get_location function at board level in this way every users can override it depending on own needs. Test it.
Tommaso Merciai (4): imx8m: drop env_get_location for imx8mn and imx8mp imx: imx8mn_evk: override env_get_location imx: imx8mp_evk: override env_get_location phytec: phycore_imx8mp: override env_get_location
arch/arm/mach-imx/imx8m/soc.c | 39 -------------------- board/freescale/imx8mn_evk/imx8mn_evk.c | 35 ++++++++++++++++++ board/freescale/imx8mp_evk/imx8mp_evk.c | 34 +++++++++++++++++ board/phytec/phycore_imx8mp/phycore-imx8mp.c | 33 +++++++++++++++++ 4 files changed, 102 insertions(+), 39 deletions(-)
This function defined for two architecture is not really generic and can generate problem when people add a new board.
Signed-off-by: Tommaso Merciai tommaso.merciai@amarulasolutions.com --- arch/arm/mach-imx/imx8m/soc.c | 39 ----------------------------------- 1 file changed, 39 deletions(-)
diff --git a/arch/arm/mach-imx/imx8m/soc.c b/arch/arm/mach-imx/imx8m/soc.c index 863508776d..f0030a557a 100644 --- a/arch/arm/mach-imx/imx8m/soc.c +++ b/arch/arm/mach-imx/imx8m/soc.c @@ -1313,45 +1313,6 @@ void do_error(struct pt_regs *pt_regs, unsigned int esr) #endif
#if defined(CONFIG_IMX8MN) || defined(CONFIG_IMX8MP) -enum env_location env_get_location(enum env_operation op, int prio) -{ - enum boot_device dev = get_boot_device(); - enum env_location env_loc = ENVL_UNKNOWN; - - if (prio) - return env_loc; - - switch (dev) { -#ifdef CONFIG_ENV_IS_IN_SPI_FLASH - case QSPI_BOOT: - env_loc = ENVL_SPI_FLASH; - break; -#endif -#ifdef CONFIG_ENV_IS_IN_NAND - case NAND_BOOT: - env_loc = ENVL_NAND; - break; -#endif -#ifdef CONFIG_ENV_IS_IN_MMC - case SD1_BOOT: - case SD2_BOOT: - case SD3_BOOT: - case MMC1_BOOT: - case MMC2_BOOT: - case MMC3_BOOT: - env_loc = ENVL_MMC; - break; -#endif - default: -#if defined(CONFIG_ENV_IS_NOWHERE) - env_loc = ENVL_NOWHERE; -#endif - break; - } - - return env_loc; -} - #ifndef ENV_IS_EMBEDDED long long env_get_offset(long long defautl_offset) {
Does git bisect still work with only this patch applied ?
On Mon, Jan 31, 2022 at 10:59 AM Tommaso Merciai tommaso.merciai@amarulasolutions.com wrote:
This actually fixes some issues I was trying to solve on the imx8mn-beacon board, so thank you for doing this.
Tested-by: Adam Ford aford173@gmail.com #imx8mn-beacon
if (prio)
return env_loc;
switch (dev) {
case QSPI_BOOT:
break;
case NAND_BOOT:
break;
case SD1_BOOT:
case SD2_BOOT:
case SD3_BOOT:
case MMC1_BOOT:
case MMC2_BOOT:
case MMC3_BOOT:
env_loc = ENVL_MMC;
break;
-#endif
default:
-#endif
break;
return env_loc;
#ifndef ENV_IS_EMBEDDED long long env_get_offset(long long defautl_offset) { -- 2.25.1
Override env_get_location function at board level, previously dropped down from soc.c
References: - commit 98af80d3c969e69a1b8ce98bb20e5ad844022da2
Signed-off-by: Tommaso Merciai tommaso.merciai@amarulasolutions.com --- Changes since v1: - Fix code indentation using checkpatch as suggested by MBehĂșn
board/freescale/imx8mn_evk/imx8mn_evk.c | 35 +++++++++++++++++++++++++ 1 file changed, 35 insertions(+)
diff --git a/board/freescale/imx8mn_evk/imx8mn_evk.c b/board/freescale/imx8mn_evk/imx8mn_evk.c index 9a0a0488bf..ec1ab202a6 100644 --- a/board/freescale/imx8mn_evk/imx8mn_evk.c +++ b/board/freescale/imx8mn_evk/imx8mn_evk.c @@ -5,11 +5,46 @@
#include <common.h> #include <env.h> +#include <env_internal.h> #include <init.h> +#include <asm/arch/sys_proto.h> +#include <asm/mach-imx/boot_mode.h> #include <asm/global_data.h>
DECLARE_GLOBAL_DATA_PTR;
+enum env_location env_get_location(enum env_operation op, int prio) +{ + enum boot_device dev = get_boot_device(); + enum env_location env_loc = ENVL_UNKNOWN; + + if (prio) + return env_loc; + + if (IS_ENABLED(CONFIG_ENV_IS_IN_SPI_FLASH) && dev == QSPI_BOOT) { + env_loc = ENVL_SPI_FLASH; + } else if (IS_ENABLED(CONFIG_ENV_IS_IN_NAND) && dev == NAND_BOOT) { + env_loc = ENVL_NAND; + } else if (IS_ENABLED(CONFIG_ENV_IS_IN_MMC)) { + switch (dev) { + case SD1_BOOT: + case SD2_BOOT: + case SD3_BOOT: + case MMC1_BOOT: + case MMC2_BOOT: + case MMC3_BOOT: + env_loc = ENVL_MMC; + break; + default: + break; + } + } else if (IS_ENABLED(CONFIG_ENV_IS_NOWHERE)) { + env_loc = ENVL_MMC; + } + + return env_loc; +} + int board_init(void) { return 0;
board/freescale/imx8mp_evk/imx8mp_evk.c | 34 +++++++++++++++++++++++++ 1 file changed, 34 insertions(+)
diff --git a/board/freescale/imx8mp_evk/imx8mp_evk.c b/board/freescale/imx8mp_evk/imx8mp_evk.c index 62096c24fb..8548f606d2 100644 --- a/board/freescale/imx8mp_evk/imx8mp_evk.c +++ b/board/freescale/imx8mp_evk/imx8mp_evk.c @@ -5,6 +5,7 @@
#include <common.h> #include <env.h> +#include <env_internal.h> #include <errno.h> #include <init.h> #include <miiphy.h> @@ -17,6 +18,7 @@ #include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> #include <asm/mach-imx/gpio.h> +#include <asm/mach-imx/boot_mode.h>
@@ -32,6 +34,38 @@ static iomux_v3_cfg_t const wdog_pads[] = { MX8MP_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), };
+enum env_location env_get_location(enum env_operation op, int prio) +{ + enum boot_device dev = get_boot_device(); + enum env_location env_loc = ENVL_UNKNOWN; + + if (prio) + return env_loc; + + if (IS_ENABLED(CONFIG_ENV_IS_IN_SPI_FLASH) && dev == QSPI_BOOT) { + env_loc = ENVL_SPI_FLASH; + } else if (IS_ENABLED(CONFIG_ENV_IS_IN_NAND) && dev == NAND_BOOT) { + env_loc = ENVL_NAND; + } else if (IS_ENABLED(CONFIG_ENV_IS_IN_MMC)) { + switch (dev) { + case SD1_BOOT: + case SD2_BOOT: + case SD3_BOOT: + case MMC1_BOOT: + case MMC2_BOOT: + case MMC3_BOOT: + env_loc = ENVL_MMC; + break; + default: + break; + } + } else if (IS_ENABLED(CONFIG_ENV_IS_NOWHERE)) { + env_loc = ENVL_MMC; + } + + return env_loc; +} + int board_early_init_f(void) { struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR;
Override env_get_location function at board level, previously dropped down from arch/arm/mach-imx/imx8m/soc.c
Signed-off-by: Tommaso Merciai tommaso.merciai@amarulasolutions.com --- board/phytec/phycore_imx8mp/phycore-imx8mp.c | 33 ++++++++++++++++++++ 1 file changed, 33 insertions(+)
diff --git a/board/phytec/phycore_imx8mp/phycore-imx8mp.c b/board/phytec/phycore_imx8mp/phycore-imx8mp.c index a8f0821437..05926eefa3 100644 --- a/board/phytec/phycore_imx8mp/phycore-imx8mp.c +++ b/board/phytec/phycore_imx8mp/phycore-imx8mp.c @@ -11,9 +11,42 @@ #include <asm/mach-imx/boot_mode.h> #include <env.h> #include <miiphy.h> +#include <env_internal.h>
+enum env_location env_get_location(enum env_operation op, int prio) +{ + enum boot_device dev = get_boot_device(); + enum env_location env_loc = ENVL_UNKNOWN; + + if (prio) + return env_loc; + + if (IS_ENABLED(CONFIG_ENV_IS_IN_SPI_FLASH) && dev == QSPI_BOOT) { + env_loc = ENVL_SPI_FLASH; + } else if (IS_ENABLED(CONFIG_ENV_IS_IN_NAND) && dev == NAND_BOOT) { + env_loc = ENVL_NAND; + } else if (IS_ENABLED(CONFIG_ENV_IS_IN_MMC)) { + switch (dev) { + case SD1_BOOT: + case SD2_BOOT: + case SD3_BOOT: + case MMC1_BOOT: + case MMC2_BOOT: + case MMC3_BOOT: + env_loc = ENVL_MMC; + break; + default: + break; + } + } else if (IS_ENABLED(CONFIG_ENV_IS_NOWHERE)) { + env_loc = ENVL_MMC; + } + + return env_loc; +} + static int setup_fec(void) { struct iomuxc_gpr_base_regs *gpr =
References:
Why don't you just turn this into default __weak function and override it on board level when it is really needed to be overridden ?
References:
diff --git a/board/phytec/phycore_imx8mp/phycore-imx8mp.c b/board/phytec/phycore_imx8mp/phycore-imx8mp.c index a8f0821437..05926eefa3 100644 --- a/board/phytec/phycore_imx8mp/phycore-imx8mp.c +++ b/board/phytec/phycore_imx8mp/phycore-imx8mp.c @@ -11,9 +11,42 @@ #include <asm/mach-imx/boot_mode.h> #include <env.h> #include <miiphy.h> +#include <env_internal.h> DECLARE_GLOBAL_DATA_PTR; +enum env_location env_get_location(enum env_operation op, int prio) +{
Hi Marek, env_get_location is already declared as __weak, check env/env.c. We can't override it 2 times.
References: - https://developer.arm.com/documentation/dui0491/i/Compiler-specific-Features...
On Mon, Jan 31, 2022 at 4:16 PM Tommaso Merciai tommaso.merciai@amarulasolutions.com wrote:
References:
The original version (before it was added in 2707faf01f04 ("imx8mn/imx8mp: override env_get_offset and env_get_location") is located in env/env.c and for my board, this is the preferred method. This replacement method actually is the opposite behavior from what I want, which is to force the environment to a fixed location regardless of the boot device.
I think Tommaso's method is better, because as it is, the users cannot override it any more.
adam
References:
-- Tommaso Merciai Embedded Linux Developer tommaso.merciai@amarulasolutions.com __________________________________
Amarula Solutions SRL Via Le Canevare 30, 31100 Treviso, Veneto, IT T. +39 042 243 5310 info@amarulasolutions.com www.amarulasolutions.com
References:
Doesn't 1/4 patch break env on pretty much every single imx8m board ?
See my other reply regarding arch and board level __weak symbols, that's likely the way to go here.
References:
For me, patch 1/4 fixed the issue of not being able to define a fixed environment location. It now sits where I put it. It also allows me to boot over USB without having to define ENV_IS_NOWHERE.
Sure, it also likely breaks every other MX8M board which does not define that env_get_location() on board level, i.e. every MX8M board.
On 1/31/22 17:58, Tommaso Merciai wrote: > Override env_get_location function at board level, previously dropped > down from arch/arm/mach-imx/imx8m/soc.c > > References: > - commit 98af80d3c969e69a1b8ce98bb20e5ad844022da2 > > Signed-off-by: Tommaso Merciai tommaso.merciai@amarulasolutions.com > --- > board/phytec/phycore_imx8mp/phycore-imx8mp.c | 33 ++++++++++++++++++++ > 1 file changed, 33 insertions(+) > > diff --git a/board/phytec/phycore_imx8mp/phycore-imx8mp.c b/board/phytec/phycore_imx8mp/phycore-imx8mp.c > index a8f0821437..05926eefa3 100644 > --- a/board/phytec/phycore_imx8mp/phycore-imx8mp.c > +++ b/board/phytec/phycore_imx8mp/phycore-imx8mp.c > @@ -11,9 +11,42 @@ > #include <asm/mach-imx/boot_mode.h> > #include <env.h> > #include <miiphy.h> > +#include <env_internal.h> > DECLARE_GLOBAL_DATA_PTR; > +enum env_location env_get_location(enum env_operation op, int prio) > +{
env_get_location is defined in env/env.c
On Mon, Jan 31, 2022 at 06:03:58PM +0100, Marek Vasut wrote: > On 1/31/22 17:58, Tommaso Merciai wrote: >> Override env_get_location function at board level, previously dropped >> down from arch/arm/mach-imx/imx8m/soc.c >> >> References: >> - commit 98af80d3c969e69a1b8ce98bb20e5ad844022da2 >> >> Signed-off-by: Tommaso Merciai tommaso.merciai@amarulasolutions.com >> --- >> board/phytec/phycore_imx8mp/phycore-imx8mp.c | 33 ++++++++++++++++++++ >> 1 file changed, 33 insertions(+) >> >> diff --git a/board/phytec/phycore_imx8mp/phycore-imx8mp.c b/board/phytec/phycore_imx8mp/phycore-imx8mp.c >> index a8f0821437..05926eefa3 100644 >> --- a/board/phytec/phycore_imx8mp/phycore-imx8mp.c >> +++ b/board/phytec/phycore_imx8mp/phycore-imx8mp.c >> @@ -11,9 +11,42 @@ >> #include <asm/mach-imx/boot_mode.h> >> #include <env.h> >> #include <miiphy.h> >> +#include <env_internal.h> >> DECLARE_GLOBAL_DATA_PTR; >> +enum env_location env_get_location(enum env_operation op, int prio) >> +{ > > Why don't you just turn this into default __weak function and override it on > board level when it is really needed to be overridden ?
Except not the NXP SoC-specific variant of it which is pulled in by most of the MX8M boards, and which is removed in 1/4, thus 1/4 changes the behavior of many boards.
References:
Oh, it is this problem with missing ability to define multiple levels of symbol strength.
__weak enum env_location arch_env_get_location(enum env_operation op, int prio) { if (prio >= ARRAY_SIZE(env_locations)) return ENVL_UNKNOWN;
return env_locations[prio]; }
__weak enum env_location board_env_get_location(enum env_operation op, int prio) { return arch_env_get_location(op, prio); }
__weak enum env_location env_get_location(enum env_operation op, int prio) { return board_env_get_location(op, prio); }
By default, the compiler will optimize it all out. If you have arch-specific default (like imx does), implement arch_env_get_location(), if you have even board-specific default (like your board likely does), implement board_env_get_location(), if you need to override both, then override env_get_location() (unlikely).
This is also inline with all the other arch_*() and board_*() functions we have, and you won't have much duplication either.
References:
Hi Marek, Thanks for the tips, then if I understand correctly, your idea is: use:
arch_env_get_location in (soc.c)
In this way imx8m users can override this function at board level using:
right?
Thanks, Tommaso
On Tue, Feb 1, 2022 at 3:09 AM Tommaso Merciai tommaso.merciai@amarulasolutions.com wrote:
References:
right?
What about those of us who want to use the default option found in env.c? It seems like we're creating more abstraction to address the abstraction we don't all want. From my interpretation, the whole point of creating the default in env.c was to let people define the location of their environment, and this function in soc.c undid that. If people want it for their boards, put this function in their boards, otherwise, just use the default, or write your own.
adam
Thanks, Tommaso
right?
On MX8M platforms which have their own arch-specific default, you override the env settings on your board level with the same stuff that is in env/env.c already. Most of the MX8M users will likely stick to the arch-specific MX8M default as they do so far.
right?
This function is encapsulated in an ifdef which is only true for 8MN and 8MP. It's not defined for 8MM or 8MQ, so those boards already default back to the __weak function in env.c
adam
right?
So, it is also inconsistent, very nice.
Anyway, if we have arch and board level overrides, then we cover all the requirements on all MX8Ms, without breaking existing boards.
References:
right?
Hi Adam, You are right. Mmm in this way you have to duplicate the code of env.c into your board.c. This doesn't look very functional. I think remove it from soc.c is the right way.
Ack.
tommaso
adam
Thanks, Tommaso
right?
How do you propose to fix all the boards which depend on the current arch-specific behavior, duplicate that code in multiple copies into board code ? That will be a lot of duplication too.
right?
I would think we should ask the users of 8MP and 8MN to test theirs without this patch to see if it impacts them. The original patch was done by NXP, so I assume they want it for their EVK's. This code explicitly makes it impossible to set the environment location to a device that was not a boot device. From what I can tell, we're talking about a small number of boards since it's just 8MN and 8MP.
What about a compromise:
Rename env_get_location() in the soc.c to imx_env_get_location().
From the 8MN and 8MP boards (for people who want it or need it), write
a board function called env_get_location() which calls imx_env_get_location(). This way the code remains, and people can choose whether they want this behavior, or the behavior or the default behavior used by 8MM and 8MQ. It's less duplicated code, and it doesn't break the default behavior for those who want that.
adam
On 1/31/22 23:15, Tommaso Merciai wrote: > On Mon, Jan 31, 2022 at 06:03:58PM +0100, Marek Vasut wrote: >> On 1/31/22 17:58, Tommaso Merciai wrote: >>> Override env_get_location function at board level, previously dropped >>> down from arch/arm/mach-imx/imx8m/soc.c >>> >>> References: >>> - commit 98af80d3c969e69a1b8ce98bb20e5ad844022da2 >>> >>> Signed-off-by: Tommaso Merciai tommaso.merciai@amarulasolutions.com >>> --- >>> board/phytec/phycore_imx8mp/phycore-imx8mp.c | 33 ++++++++++++++++++++ >>> 1 file changed, 33 insertions(+) >>> >>> diff --git a/board/phytec/phycore_imx8mp/phycore-imx8mp.c b/board/phytec/phycore_imx8mp/phycore-imx8mp.c >>> index a8f0821437..05926eefa3 100644 >>> --- a/board/phytec/phycore_imx8mp/phycore-imx8mp.c >>> +++ b/board/phytec/phycore_imx8mp/phycore-imx8mp.c >>> @@ -11,9 +11,42 @@ >>> #include <asm/mach-imx/boot_mode.h> >>> #include <env.h> >>> #include <miiphy.h> >>> +#include <env_internal.h> >>> DECLARE_GLOBAL_DATA_PTR; >>> +enum env_location env_get_location(enum env_operation op, int prio) >>> +{ >> >> Why don't you just turn this into default __weak function and override it on >> board level when it is really needed to be overridden ? > > Hi Marek, > env_get_location is already declared as __weak, check env/env.c. We > can't override it 2 times.
right?
We are still talking about 40 lines of code being copied to 12 different places, or, 12 boards which need to be fixed up -- instead of -- one board which needs to be configured correctly to pick env from wherever it should pick it from instead of the NXP default.
right?
Yes, I think that is the most flexible way with least duplication.
Adam Ford
Tommaso Merciai
